[U-Boot] [PATCH 5/7] driver/ifc: define nand_spl_load_image() for SPL
nand_spl_load_image() can also be used for non TPL framework.
Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- Changes for v2: Sending as it is
drivers/mtd/nand/fsl_ifc_spl.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/nand/fsl_ifc_spl.c b/drivers/mtd/nand/fsl_ifc_spl.c index 2f82f7c..8a7a3a3 100644 --- a/drivers/mtd/nand/fsl_ifc_spl.c +++ b/drivers/mtd/nand/fsl_ifc_spl.c @@ -88,7 +88,7 @@ static inline int bad_block(uchar *marker, int port_size) return __raw_readw((u16 *)marker) != 0xffff; }
-#ifdef CONFIG_TPL_BUILD +#if defined(CONFIG_TPL_BUILD) || defined(CONFIG_SPL_BUILD) int nand_spl_load_image(uint32_t offs, unsigned int uboot_size, void *vdst) #else static int nand_load(uint32_t offs, unsigned int uboot_size, void *vdst) @@ -221,7 +221,7 @@ static int nand_load(uint32_t offs, unsigned int uboot_size, void *vdst) * Defines a static function nand_load_image() here, because non-static makes * the code too large for certain SPLs(minimal SPL, maximum size <= 4Kbytes) */ -#ifndef CONFIG_TPL_BUILD +#if !defined(CONFIG_TPL_BUILD) && !defined(CONFIG_SPL_BUILD) #define nand_spl_load_image(offs, uboot_size, vdst) \ nand_load(offs, uboot_size, vdst) #endif
When would you ever be building this file without one of those two set?
The reason for exempting SPL was concern that making the function non-static would push some targets over the size limit. Have you successfully built them all, with a variety of compilers?
Perhaps this was only an issue on eLBC.
-Scott
Prabhakar Kushwaha
Scott Wood
