[U-Boot-Users] tftp errors/times out on large files
Hi all,
I am having problem tftping large files (>30M.) The tftp will start download, and then immediately get an error, and it will say:
Load address: 0x80100000 Loading: * TFTP error: 'Undefined error code' (0) Starting again
or sometimes I get the 'T' (timeout) and it will repeat again.
and repeat. I can download smaller files just fine. What could it be the problem? Increasing the MALLOC_LEN doesn't seem to help, and I need some advice. (FYI, I have 128M ram.)
Any suggestions will be greatly appreciated!
On 8/14/06, mitsy mitsy12@gmail.com wrote:
Hi all,
the TFTP protocol has a file size limit of 32M unless one of the later RFC versions is followed. Try configuring/using NFS instead.
mitsy wrote:
Hi all,
I am having problem tftping large files (>30M.) The tftp will start download, and then immediately get an error, and it will say: (snip) and repeat. I can download smaller files just fine. What could it be the problem? Increasing the MALLOC_LEN doesn't seem to help, and I need some advice. (FYI, I have 128M ram.)
The original TFTP protocol is limited to file sizes of 32MB. A later RFC compliant TFTP allows file sizes of up to 4GB but I am not sure if U-Boot and/or your TFTP server implements the new RFC. Details are in Wikipedia.
Thank you Tolunay. Since nfs isn't an option for what I'm doing (as Andrew suggested yesterday,) I think I need to either add gzip decompression support and/or modify tftp to support larger files.
On 8/14/06, Tolunay Orkun listmember@orkun.us wrote:
mitsy wrote:
Hi all,
mitsy wrote:
Hi all,
FWIIW, most of the problem is because the authors of the RFC apparently didn't contemplate more than 64K data packets and so did not describe handling sequence number overflow/wrap around.
RFC-1350 p.3 Section 4 (first paragraph) states: "Each data packet has associated with it a block number; block numbers are consecutive and begin with one. Since the positive response to a write request is an acknowledgment packet, in this special case the block number will be zero."
The above is somewhat ambiguous (to me) whether the wrap-around should wrap to zero (0) or one (1). If you decide it should be zero (0), see http://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=23725
FWIIW, ARINC-615A aircraft data loader has specified it to wrap to one (1). https://www.arinc.com/cf/store/catalog_detail.cfm?item_id=71
Perhaps you (mitsy) should write a RFC to superceed 1350 to fix the problem. Here is your chance to be famous!
Most (buggy) implementations use a 32 bit (default) integer as the local variable and don't address the wrap-around issue, so the local variable goes from 65535 to 65536 while the block number in the packet goes from 65535 to 0 (buggy or wrap-to-zero implementation) or 65535 to 1 (wrap-to-one implementation).
When we addressed this problem (several years ago), we found a couple of TFTP clients that support wrap-around on the block numbers, but it has been a long time since I looked at this and I cannot find the information any more. :-(
gvb
Andrew Dyer
Jerry Van Baren
mitsy
Tolunay Orkun
