[PATCH 3/3] board: phytec: imx93: Add phyCORE-i.MX93 support all SOM variants
The phyCORE-i.MX 93 is available in various variants (e.g. different ram sizes, eMMC HS400 yes/no). Add a new SOM-scoped defconfig that makes use of the hardware introspection of the phycore-imx93 board-code, to detect the SOM module variant, and to configure the hardware accordingly. The resulting SPL and u-boot binary shall able to boot each phyCORE-i.MX93 module variant on each carrier board.
Signed-off-by: Christoph Stoidner c.stoidner@phytec.de Cc: Mathieu Othacehe m.othacehe@gmail.com, Christoph Stoidner c.stoidner@phytec.de, Stefano Babic sbabic@denx.de, Fabio Estevam festevam@gmail.com, "NXP i.MX U-Boot Team" uboot-imx@nxp.com, Tom Rini trini@konsulko.com, Yannic Moog y.moog@phytec.de, Primoz Fiser primoz.fiser@norik.com, Andrej Picej andrej.picej@norik.com, Wadim Egorov w.egorov@phytec.de --- arch/arm/dts/imx93-phyboard-segin-u-boot.dtsi | 14 +- board/phytec/phycore_imx93/MAINTAINERS | 1 + configs/imx93-phycore_defconfig | 156 ++++++++++++++++++ 3 files changed, 169 insertions(+), 2 deletions(-) create mode 100644 configs/imx93-phycore_defconfig
diff --git a/arch/arm/dts/imx93-phyboard-segin-u-boot.dtsi b/arch/arm/dts/imx93-phyboard-segin-u-boot.dtsi index 25c778bb07..e84476c38a 100644 --- a/arch/arm/dts/imx93-phyboard-segin-u-boot.dtsi +++ b/arch/arm/dts/imx93-phyboard-segin-u-boot.dtsi @@ -2,15 +2,25 @@ /* * Copyright (C) 2023 PHYTEC Messtechnik GmbH * Christoph Stoidner c.stoidner@phytec.de + * Copyright (C) 2024 PHYTEC Messtechnik GmbH * * Product homepage: - * phyBOARD-Segin carrier board is reused for the i.MX93 design. - * https://www.phytec.eu/en/produkte/single-board-computer/phyboard-segin-imx6u... + https://www.phytec.de/produkte/system-on-modules/phycore-imx-91-93/ */
#include "imx93-u-boot.dtsi"
/ { + + /* + * If the u-boot build uses the device tree of a phyCORE-i.MX93 carrier + * board (i.E. imx93-phyboard-segin.dts), then this u-boot.dtsi + * deactivates all carrier board-specific peripherals. This means that + * the resulting SPL and u-boot binary can boot the phyCORE-i.MX 93 module + * on each carrier board. + */ + model = "PHYTEC phyCORE-i.MX93"; + wdt-reboot { compatible = "wdt-reboot"; wdt = <&wdog3>; diff --git a/board/phytec/phycore_imx93/MAINTAINERS b/board/phytec/phycore_imx93/MAINTAINERS index cea817ffdc..d6eb5eb287 100644 --- a/board/phytec/phycore_imx93/MAINTAINERS +++ b/board/phytec/phycore_imx93/MAINTAINERS @@ -9,5 +9,6 @@ F: arch/arm/dts/imx93-phyboard-segin-u-boot.dtsi F: board/phytec/phycore_imx93/ F: board/phytec/common/imx93_som_detection.c F: board/phytec/common/imx93_som_detection.h +F: configs/imx93-phycore_defconfig F: configs/imx93-phyboard-segin_defconfig F: include/configs/phycore_imx93.h diff --git a/configs/imx93-phycore_defconfig b/configs/imx93-phycore_defconfig new file mode 100644 index 0000000000..2c818d01b7 --- /dev/null +++ b/configs/imx93-phycore_defconfig @@ -0,0 +1,156 @@ +CONFIG_ARM=y +CONFIG_ARCH_IMX9=y +CONFIG_TEXT_BASE=0x80200000 +CONFIG_SYS_MALLOC_LEN=0x2000000 +CONFIG_SYS_MALLOC_F_LEN=0x20000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SOURCE_FILE="phycore_imx93" +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x700000 +CONFIG_IMX_CONFIG="arch/arm/mach-imx/imx9/imximage.cfg" +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="imx93-phyboard-segin" +CONFIG_SPL_TEXT_BASE=0x2049A000 +CONFIG_PHYTEC_SOM_DETECTION=y +CONFIG_TARGET_PHYCORE_IMX93=y +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_SYS_MONITOR_LEN=524288 +CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL_STACK=0x20519dd0 +CONFIG_SPL=y +CONFIG_ENV_OFFSET_REDUND=0x720000 +CONFIG_CMD_DEKBLOB=y +CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x88000000 +CONFIG_SYS_LOAD_ADDR=0x80400000 +CONFIG_SYS_MEMTEST_START=0x80000000 +CONFIG_SYS_MEMTEST_END=0x90000000 +CONFIG_REMAKE_ELF=y +# CONFIG_ANDROID_BOOT_IMAGE is not set +CONFIG_DISTRO_DEFAULTS=y +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if test ${doraucboot} = 1; then run raucinit; fi; if run loadimage; then run mmcboot; else run netboot; fi; fi;" +CONFIG_DEFAULT_FDT_FILE="oftree" +CONFIG_SYS_CBSIZE=2048 +CONFIG_SYS_PBSIZE=2074 +CONFIG_ARCH_MISC_INIT=y +CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x26000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x2051a000 +CONFIG_SPL_BSS_MAX_SIZE=0x2000 +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_BOOTROM_SUPPORT=y +CONFIG_SPL_LOAD_IMX_CONTAINER=y +CONFIG_IMX_CONTAINER_CFG="arch/arm/mach-imx/imx9/container.cfg" +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1040 +CONFIG_SPL_I2C=y +CONFIG_SPL_POWER=y +CONFIG_SPL_WATCHDOG=y +CONFIG_SYS_PROMPT="u-boot=> " +CONFIG_CMD_ERASEENV=y +CONFIG_CMD_NVEDIT_EFI=y +CONFIG_CRC32_VERIFY=y +CONFIG_CMD_EEPROM=y +CONFIG_SYS_I2C_EEPROM_BUS=2 +CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 +CONFIG_SYS_EEPROM_SIZE=4096 +CONFIG_SYS_EEPROM_PAGE_WRITE_BITS=5 +CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=5 +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_CLK=y +CONFIG_CMD_DFU=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_POWEROFF=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EFIDEBUG=y +CONFIG_CMD_RTC=y +CONFIG_CMD_TIME=y +CONFIG_CMD_GETTIME=y +CONFIG_CMD_TIMER=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_HASH=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_NOWHERE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_DEV=1 +CONFIG_USE_ETHPRIME=y +CONFIG_ETHPRIME="eth1" +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM=y +CONFIG_SYSCON=y +CONFIG_SPL_CLK_IMX93=y +CONFIG_CLK_IMX93=y +CONFIG_CPU=y +CONFIG_CPU_IMX=y +CONFIG_DFU_MMC=y +CONFIG_DFU_RAM=y +CONFIG_IMX_RGPIO2P=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_IMX_LPI2C=y +CONFIG_I2C_EEPROM=y +CONFIG_SYS_I2C_EEPROM_ADDR=0x50 +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS400_ES_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_FSL_USDHC=y +CONFIG_PHY_TI_GENERIC=y +CONFIG_DM_ETH_PHY=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_IMX=y +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_MIPI_DPHY_HELPERS=y +CONFIG_PHY_IMX93_MIPI_DPHY=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX93=y +CONFIG_POWER_DOMAIN=y +CONFIG_IMX93_BLK_CTRL=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_PCA9450=y +CONFIG_SPL_DM_PMIC_PCA9450=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_PCA9450=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_RTC=y +CONFIG_DM_SERIAL=y +CONFIG_FSL_LPUART=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y +CONFIG_SYSRESET_WATCHDOG=y +CONFIG_DM_THERMAL=y +CONFIG_IMX_TMU=y +CONFIG_USB=y +CONFIG_SPL_USB_HOST=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_GADGET=y +CONFIG_SPL_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="PHYTEC" +CONFIG_USB_GADGET_VENDOR_NUM=0x1fc9 +CONFIG_USB_GADGET_PRODUCT_NUM=0x0152 +CONFIG_CI_UDC=y +CONFIG_USB_PORT_AUTO=y +CONFIG_ULP_WATCHDOG=y +CONFIG_LZO=y +CONFIG_BZIP2=y
Sorry, unfortunately that patch got separated from its patch-series. Please note, it belongs to the patch-series "Add support for all variants of the phyCORE-i.MX93 SOM".
On Mo, 2024-11-04 at 12:25 +0100, Christoph Stoidner wrote:
The phyCORE-i.MX 93 is available in various variants (e.g. different ram sizes, eMMC HS400 yes/no). Add a new SOM-scoped defconfig that makes use of the hardware introspection of the phycore-imx93 board-code, to detect the SOM module variant, and to configure the hardware accordingly. The resulting SPL and u-boot binary shall able to boot each phyCORE- i.MX93 module variant on each carrier board.
- Copyright (C) 2024 PHYTEC Messtechnik GmbH
- phyBOARD-Segin carrier board is reused for the i.MX93 design.
segin-imx6ul/ + https://www.phytec.de/produkte/system-on-modules/phycore-imx-91- 93/ */ #include "imx93-u-boot.dtsi" / {
+ /* + * If the u-boot build uses the device tree of a phyCORE- i.MX93 carrier + * board (i.E. imx93-phyboard-segin.dts), then this u- boot.dtsi + * deactivates all carrier board-specific peripherals. This means that + * the resulting SPL and u-boot binary can boot the phyCORE- i.MX 93 module + * on each carrier board. + */ + model = "PHYTEC phyCORE-i.MX93";
wdt-reboot { compatible = "wdt-reboot"; wdt = <&wdog3>; diff --git a/board/phytec/phycore_imx93/MAINTAINERS b/board/phytec/phycore_imx93/MAINTAINERS index cea817ffdc..d6eb5eb287 100644 --- a/board/phytec/phycore_imx93/MAINTAINERS +++ b/board/phytec/phycore_imx93/MAINTAINERS @@ -9,5 +9,6 @@ F: arch/arm/dts/imx93-phyboard-segin-u-boot.dtsi F: board/phytec/phycore_imx93/ F: board/phytec/common/imx93_som_detection.c F: board/phytec/common/imx93_som_detection.h +F: configs/imx93-phycore_defconfig F: configs/imx93-phyboard-segin_defconfig F: include/configs/phycore_imx93.h diff --git a/configs/imx93-phycore_defconfig b/configs/imx93- phycore_defconfig new file mode 100644 index 0000000000..2c818d01b7 --- /dev/null +++ b/configs/imx93-phycore_defconfig @@ -0,0 +1,156 @@ +CONFIG_ARM=y +CONFIG_ARCH_IMX9=y +CONFIG_TEXT_BASE=0x80200000 +CONFIG_SYS_MALLOC_LEN=0x2000000 +CONFIG_SYS_MALLOC_F_LEN=0x20000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_ENV_SOURCE_FILE="phycore_imx93" +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0x700000 +CONFIG_IMX_CONFIG="arch/arm/mach-imx/imx9/imximage.cfg" +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="imx93-phyboard-segin" +CONFIG_SPL_TEXT_BASE=0x2049A000 +CONFIG_PHYTEC_SOM_DETECTION=y +CONFIG_TARGET_PHYCORE_IMX93=y +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_SYS_MONITOR_LEN=524288 +CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL_STACK=0x20519dd0 +CONFIG_SPL=y +CONFIG_ENV_OFFSET_REDUND=0x720000 +CONFIG_CMD_DEKBLOB=y +CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x88000000 +CONFIG_SYS_LOAD_ADDR=0x80400000 +CONFIG_SYS_MEMTEST_START=0x80000000 +CONFIG_SYS_MEMTEST_END=0x90000000 +CONFIG_REMAKE_ELF=y +# CONFIG_ANDROID_BOOT_IMAGE is not set +CONFIG_DISTRO_DEFAULTS=y +CONFIG_OF_SYSTEM_SETUP=y +CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then if test ${doraucboot} = 1; then run raucinit; fi; if run loadimage; then run mmcboot; else run netboot; fi; fi;" +CONFIG_DEFAULT_FDT_FILE="oftree" +CONFIG_SYS_CBSIZE=2048 +CONFIG_SYS_PBSIZE=2074 +CONFIG_ARCH_MISC_INIT=y +CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_MAX_SIZE=0x26000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x2051a000 +CONFIG_SPL_BSS_MAX_SIZE=0x2000 +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_BOOTROM_SUPPORT=y +CONFIG_SPL_LOAD_IMX_CONTAINER=y +CONFIG_IMX_CONTAINER_CFG="arch/arm/mach-imx/imx9/container.cfg" +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1040 +CONFIG_SPL_I2C=y +CONFIG_SPL_POWER=y +CONFIG_SPL_WATCHDOG=y +CONFIG_SYS_PROMPT="u-boot=> " +CONFIG_CMD_ERASEENV=y +CONFIG_CMD_NVEDIT_EFI=y +CONFIG_CRC32_VERIFY=y +CONFIG_CMD_EEPROM=y +CONFIG_SYS_I2C_EEPROM_BUS=2 +CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 +CONFIG_SYS_EEPROM_SIZE=4096 +CONFIG_SYS_EEPROM_PAGE_WRITE_BITS=5 +CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS=5 +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_CLK=y +CONFIG_CMD_DFU=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_POWEROFF=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EFIDEBUG=y +CONFIG_CMD_RTC=y +CONFIG_CMD_TIME=y +CONFIG_CMD_GETTIME=y +CONFIG_CMD_TIMER=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_HASH=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_NOWHERE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_DEV=1 +CONFIG_USE_ETHPRIME=y +CONFIG_ETHPRIME="eth1" +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM=y +CONFIG_SYSCON=y +CONFIG_SPL_CLK_IMX93=y +CONFIG_CLK_IMX93=y +CONFIG_CPU=y +CONFIG_CPU_IMX=y +CONFIG_DFU_MMC=y +CONFIG_DFU_RAM=y +CONFIG_IMX_RGPIO2P=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_IMX_LPI2C=y +CONFIG_I2C_EEPROM=y +CONFIG_SYS_I2C_EEPROM_ADDR=0x50 +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS400_ES_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y +CONFIG_FSL_USDHC=y +CONFIG_PHY_TI_GENERIC=y +CONFIG_DM_ETH_PHY=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_IMX=y +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_MIPI_DPHY_HELPERS=y +CONFIG_PHY_IMX93_MIPI_DPHY=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_IMX93=y +CONFIG_POWER_DOMAIN=y +CONFIG_IMX93_BLK_CTRL=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_PCA9450=y +CONFIG_SPL_DM_PMIC_PCA9450=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_PCA9450=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_RTC=y +CONFIG_DM_SERIAL=y +CONFIG_FSL_LPUART=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y +CONFIG_SYSRESET_WATCHDOG=y +CONFIG_DM_THERMAL=y +CONFIG_IMX_TMU=y +CONFIG_USB=y +CONFIG_SPL_USB_HOST=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_GADGET=y +CONFIG_SPL_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="PHYTEC" +CONFIG_USB_GADGET_VENDOR_NUM=0x1fc9 +CONFIG_USB_GADGET_PRODUCT_NUM=0x0152 +CONFIG_CI_UDC=y +CONFIG_USB_PORT_AUTO=y +CONFIG_ULP_WATCHDOG=y +CONFIG_LZO=y +CONFIG_BZIP2=y
Hi Christoph,
Am 04.11.24 um 12:25 schrieb Christoph Stoidner:
I think it would be better to simply rename the current imx93-phyboard-segin_defconfig to phycore_imx93_defconfig. This is less confusing and follows the idea of our other SoMs.
- Copyright (C) 2023 PHYTEC Messtechnik GmbH
- Christoph Stoidner c.stoidner@phytec.de
- Product homepage:
This comment does not seem to reflect what imx93-phyboard-segin-u-boot.dtsi is actually doing.
- model = "PHYTEC phyCORE-i.MX93";
- wdt-reboot { compatible = "wdt-reboot"; wdt = <&wdog3>;
Looking at the diff between both imx93 configs I can see that CONFIG_PHYTEC_SOM_DETECTION is the only relevant differece you added.
The SoM detection should be applied also for the imx93-phyboard-segin_defconfig. The detection is not related to anything board related.
Why can't we have a single defconfig?
Regards, Wadim
Hi Wadim,
On Di, 2024-11-05 at 08:42 +0100, Wadim Egorov wrote:
Hi Christoph,
I see. My original reason to keep the existing imx93-phyboard-segin_defconfig was to avoid any breaking change. And I thought limiting the existing one to the SOM would be a breaking change. But a further look to the imx93-phyboard-segin_defconfig confirms what you said. It is already scoped to the SOM, only the name "phyboard" is confusing.
So, I will rename imx93-phyboard-segin_defconfig and just add the SOM detection. I will send a v2 for that.
Just one more note: Other than you suggested above I will use the final name "imx93-phycore_defconfig" instead of "phycore_imx93_defconfig". Although this does not match the Phytec names, it does fit the existing naming scheme in the upstream u-boot. I talked a while ago with Teresa about that. The existing phytec names have historically grown, and later the naming scheme with imx* prefix has established in upstream. Teresa and me agreed that we should use the upstream way.
Signed-off-by: Christoph Stoidner c.stoidner@phytec.de Cc: Mathieu Othacehe m.othacehe@gmail.com, Christoph Stoidner c.stoidner@phytec.de, Stefano Babic sbabic@denx.de, Fabio Estevam festevam@gmail.com, "NXP i.MX U-Boot Team" <uboot- imx@nxp.com>, Tom Rini trini@konsulko.com, Yannic Moog y.moog@phytec.de, Primoz Fiser primoz.fiser@norik.com, Andrej Picej andrej.picej@norik.com, Wadim Egorov w.egorov@phytec.de
computer/phyboard-segin-imx6ul/ + https://www.phytec.de/produkte/system-on-modules/phycore-imx- 91-93/ */ #include "imx93-u-boot.dtsi" / {
+ /* + * If the u-boot build uses the device tree of a phyCORE- i.MX93 carrier + * board (i.E. imx93-phyboard-segin.dts), then this u- boot.dtsi + * deactivates all carrier board-specific peripherals. This means that + * the resulting SPL and u-boot binary can boot the phyCORE-i.MX 93 module + * on each carrier board. + */
I dont know what you mean. Do you see any carrier board peripherals that keep activated? Or anything else? What missmatch do you mean?
wdt-reboot { compatible = "wdt-reboot"; wdt = <&wdog3>; diff --git a/board/phytec/phycore_imx93/MAINTAINERS b/board/phytec/phycore_imx93/MAINTAINERS index cea817ffdc..d6eb5eb287 100644 --- a/board/phytec/phycore_imx93/MAINTAINERS +++ b/board/phytec/phycore_imx93/MAINTAINERS @@ -9,5 +9,6 @@ F: arch/arm/dts/imx93-phyboard-segin-u- boot.dtsi F: board/phytec/phycore_imx93/ F: board/phytec/common/imx93_som_detection.c F: board/phytec/common/imx93_som_detection.h +F: configs/imx93-phycore_defconfig F: configs/imx93-phyboard-segin_defconfig F: include/configs/phycore_imx93.h diff --git a/configs/imx93-phycore_defconfig b/configs/imx93- phycore_defconfig
Looking at the diff between both imx93 configs I can see that g is the only relevant differece you added.
True. This will be solved in a v2 (see my response in that mail on top).
Thanks, Christoph
Regards, Wadim
Am 08.11.24 um 19:02 schrieb Christoph Stoidner:
Hi Wadim,
Hi Christoph,
You are not deactivating anything in this u-boot.dtsi file so the comment does not make a lot of sense to me.
Regards, Wadim
Christoph Stoidner
Christoph Stoidner
Wadim Egorov
