Re: [U-Boot] [linux-sunxi] Re: [PATCH 1/6] sunxi: makes an invisible option for H3-like DRAM controllers
2017年3月15日 08:23于 André Przywara andre.przywara@arm.com写道:
On 13/03/17 17:50, Icenowy Zheng wrote:
Hi Icenowy,
as mentioned before, I like this patch. In general, can you rebase this series on top of sunxi/master? There are some rather easy conflicts due to the H5 support being merged in.
One minor thing below...
Allwinner SoCs after H3 (e.g. A64, H5, R40, V3s) uses a H3-like DesignWare DRAM controller, which do not have official free DRAM initialization code, but can use modified dram_sun8i_h3.c.
Add a invisible option for easier DRAM initialization code reuse.
Signed-off-by: Icenowy Zheng icenowy@aosc.xyz Acked-by: Maxime Ripard maxime.ripard@free-electrons.com
arch/arm/include/asm/arch-sunxi/dram.h | 4 ++-- .../include/asm/arch-sunxi/{dram_sun8i_h3.h => dram_sunxi_dw.h} | 0 arch/arm/mach-sunxi/Makefile | 2 +- arch/arm/mach-sunxi/{dram_sun8i_h3.c => dram_sunxi_dw.c} | 0 board/sunxi/Kconfig | 9 +++++++++ 5 files changed, 12 insertions(+), 3 deletions(-) rename arch/arm/include/asm/arch-sunxi/{dram_sun8i_h3.h => dram_sunxi_dw.h} (100%) rename arch/arm/mach-sunxi/{dram_sun8i_h3.c => dram_sunxi_dw.c} (100%)
diff --git a/arch/arm/include/asm/arch-sunxi/dram.h b/arch/arm/include/asm/arch-sunxi/dram.h index 53e6d471d2..80abac95b8 100644 --- a/arch/arm/include/asm/arch-sunxi/dram.h +++ b/arch/arm/include/asm/arch-sunxi/dram.h @@ -24,8 +24,8 @@ #include <asm/arch/dram_sun8i_a33.h> #elif defined(CONFIG_MACH_SUN8I_A83T) #include <asm/arch/dram_sun8i_a83t.h> -#elif defined(CONFIG_MACH_SUN8I_H3) || defined(CONFIG_MACH_SUN50I) -#include <asm/arch/dram_sun8i_h3.h> +#elif defined(CONFIG_SUNXI_DRAM_DW) +#include <asm/arch/dram_sunxi_dw.h> #elif defined(CONFIG_MACH_SUN9I) #include <asm/arch/dram_sun9i.h> #else diff --git a/arch/arm/include/asm/arch-sunxi/dram_sun8i_h3.h b/arch/arm/include/asm/arch-sunxi/dram_sunxi_dw.h similarity index 100% rename from arch/arm/include/asm/arch-sunxi/dram_sun8i_h3.h rename to arch/arm/include/asm/arch-sunxi/dram_sunxi_dw.h diff --git a/arch/arm/mach-sunxi/Makefile b/arch/arm/mach-sunxi/Makefile index 7daba1169c..b8f01e3b61 100644 --- a/arch/arm/mach-sunxi/Makefile +++ b/arch/arm/mach-sunxi/Makefile @@ -48,7 +48,7 @@ obj-$(CONFIG_MACH_SUN7I) += dram_sun4i.o obj-$(CONFIG_MACH_SUN8I_A23) += dram_sun8i_a23.o obj-$(CONFIG_MACH_SUN8I_A33) += dram_sun8i_a33.o obj-$(CONFIG_MACH_SUN8I_A83T) += dram_sun8i_a83t.o -obj-$(CONFIG_MACH_SUN8I_H3) += dram_sun8i_h3.o +obj-$(CONFIG_SUNXI_DRAM_DW) += dram_sunxi_dw.o obj-$(CONFIG_MACH_SUN9I) += dram_sun9i.o obj-$(CONFIG_MACH_SUN50I) += dram_sun8i_h3.o
This line needs to be removed as well, otherwise you break the build for A64 boards.
Yes I found it.
I will fix it in next ver.
Cheers, Andre.
endif diff --git a/arch/arm/mach-sunxi/dram_sun8i_h3.c b/arch/arm/mach-sunxi/dram_sunxi_dw.c similarity index 100% rename from arch/arm/mach-sunxi/dram_sun8i_h3.c rename to arch/arm/mach-sunxi/dram_sunxi_dw.c diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index 56b7513fe3..e71fdaee86 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -42,6 +42,13 @@ config SUNXI_GEN_SUN6I separate ahb reset control registers, custom pmic bus, new style watchdog, etc. +config SUNXI_DRAM_DW
- bool
- ---help---
- Select this for sunxi SoCs which uses a DRAM controller like the
- DesignWare controller used in H3, mainly SoCs after H3, which do
- not have official open-source DRAM initialization code, but can
- use modified H3 DRAM initialization code.
choice prompt "Sunxi SoC Variant" @@ -113,6 +120,7 @@ config MACH_SUN8I_H3 select ARCH_SUPPORT_PSCI select SUNXI_GEN_SUN6I select SUPPORT_SPL
- select SUNXI_DRAM_DW
select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT config MACH_SUN8I_V3S @@ -135,6 +143,7 @@ config MACH_SUN50I select ARM64 select SUNXI_GEN_SUN6I select SUPPORT_SPL
endchoice
-- You received this message because you are subscribed to the Google Groups "linux-sunxi" group. To unsubscribe from this group and stop receiving emails from it, send an email to linux-sunxi+unsubscribe@googlegroups.com. For more options, visit https://groups.google.com/d/optout.
Icenowy Zheng
