[U-Boot] [PATCH] Revert "spi: add config option to enable the WP pin function on st micron flashes"
This reverts commit 562f8df18da62ae02c4ace1e530451fe82c3312d.
Never see the issue with N25Q128 flash without need of W#/Vpp signal during probe.
Signed-off-by: Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com Cc: Heiko Schocher hs@denx.de --- README | 11 ----------- drivers/mtd/spi/sf_internal.h | 4 ---- drivers/mtd/spi/sf_probe.c | 30 ------------------------------ 3 files changed, 45 deletions(-)
diff --git a/README b/README index 4ca04d0..908646f 100644 --- a/README +++ b/README @@ -3090,17 +3090,6 @@ CBFS (Coreboot Filesystem) support memories can be connected with a given cs line. currently Xilinx Zynq qspi support these type of connections.
- CONFIG_SYS_SPI_ST_ENABLE_WP_PIN - enable the W#/Vpp signal to disable writing to the status - register on ST MICRON flashes like the N25Q128. - The status register write enable/disable bit, combined with - the W#/VPP signal provides hardware data protection for the - device as follows: When the enable/disable bit is set to 1, - and the W#/VPP signal is driven LOW, the status register - nonvolatile bits become read-only and the WRITE STATUS REGISTER - operation will not execute. The only way to exit this - hardware-protected mode is to drive W#/VPP HIGH. - - SystemACE Support: CONFIG_SYSTEMACE
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 785f7a9..bd834dc 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -97,10 +97,6 @@ enum { #define STATUS_QEB_MXIC (1 << 6) #define STATUS_PEC (1 << 7)
-#ifdef CONFIG_SYS_SPI_ST_ENABLE_WP_PIN -#define STATUS_SRWD (1 << 7) /* SR write protect */ -#endif - /* Flash timeout values */ #define SPI_FLASH_PROG_TIMEOUT (2 * CONFIG_SYS_HZ) #define SPI_FLASH_PAGE_ERASE_TIMEOUT (5 * CONFIG_SYS_HZ) diff --git a/drivers/mtd/spi/sf_probe.c b/drivers/mtd/spi/sf_probe.c index ce9987f..3b0e652 100644 --- a/drivers/mtd/spi/sf_probe.c +++ b/drivers/mtd/spi/sf_probe.c @@ -287,34 +287,6 @@ int spi_flash_decode_fdt(const void *blob, struct spi_flash *flash) } #endif /* CONFIG_OF_CONTROL */
-#ifdef CONFIG_SYS_SPI_ST_ENABLE_WP_PIN -/* enable the W#/Vpp signal to disable writing to the status register */ -static int spi_enable_wp_pin(struct spi_flash *flash) -{ - u8 status; - int ret; - - ret = spi_flash_cmd_read_status(flash, &status); - if (ret < 0) - return ret; - - ret = spi_flash_cmd_write_status(flash, STATUS_SRWD); - if (ret < 0) - return ret; - - ret = spi_flash_cmd_write_disable(flash); - if (ret < 0) - return ret; - - return 0; -} -#else -static int spi_enable_wp_pin(struct spi_flash *flash) -{ - return 0; -} -#endif - /** * spi_flash_probe_slave() - Probe for a SPI flash device on a bus * @@ -393,8 +365,6 @@ int spi_flash_probe_slave(struct spi_slave *spi, struct spi_flash *flash) puts(" Full access #define CONFIG_SPI_FLASH_BAR\n"); } #endif - if (spi_enable_wp_pin(flash)) - puts("Enable WP pin failed\n");
/* Release spi bus */ spi_release_bus(spi);
On 18 December 2014 at 19:21, Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com wrote:
u8 status;
int ret;
if (ret < 0)
return ret;
if (ret < 0)
return ret;
if (ret < 0)
return ret;
-} -#endif
- spi_flash_probe_slave() - Probe for a SPI flash device on a bus
puts("Enable WP pin failed\n"); /* Release spi bus */ spi_release_bus(spi);
-- 1.9.1
Ping!
thanks!
Hello Jagan,
Am 22.12.2014 09:58, schrieb Jagan Teki:
I found this issue on the aristainetos board, there the "W#/Vpp" signal is connected to a gpio pin.
bye, Heiko
BTW: What is with the patchset:
[U-Boot] [PATCH v3 0/3] spi, sf: add mtdparts feature to spi and sf commands http://lists.denx.de/pipermail/u-boot/2014-September/188098.html
Patchwork [U-Boot,v3,1/3] mtd, spi: add MTD layer driver http://patchwork.ozlabs.org/patch/386102/
Patchwork [U-Boot,v3,2/3] mtd, nand: move common functions from cmd_nand.c to common place http://patchwork.ozlabs.org/patch/386103/
Patchwork [U-Boot,v3,3/3] spi, sf: use offset and size in sf cmd from mtdpartition http://patchwork.ozlabs.org/patch/386101/
u8 status;
int ret;
if (ret < 0)
return ret;
if (ret < 0)
return ret;
if (ret < 0)
return ret;
-} -#endif
-- 1.9.1
Ping!
thanks!
Hi Heiko,
On 23 December 2014 at 12:04, Heiko Schocher hs@denx.de wrote:
Hello Jagan,
Did you test the same board on Linux? what about the status there?
Will come back next.
with
the
1,
REGISTER
u8 status;
int ret;
if (ret < 0)
return ret;
if (ret < 0)
return ret;
if (ret < 0)
return ret;
-} -#endif
-- 1.9.1
Ping!
thanks!
On 23 December 2014 at 13:45, Jagan Teki jagannadh.teki@gmail.com wrote:
Hi Heiko,
Hello Jagan,
with
the
1,
REGISTER
u8 status;
int ret;
if (ret < 0)
return ret;
if (ret < 0)
return ret;
if (ret < 0)
return ret;
-} -#endif
-- 1.9.1
Ping!
Ping!
Hello Jagan,
Am 22.04.2015 13:03, schrieb Jagan Teki:
Hi Heiko,
Hello Jagan,
with
the
1,
REGISTER
u8 status;
int ret;
if (ret < 0)
return ret;
if (ret < 0)
return ret;
if (ret < 0)
return ret;
-} -#endif
-- 1.9.1
Ping!
Ping!
I try to test it today.
bye, Heiko
Hello Jagan,
Hi Heiko,
Hello Jagan,
You can revert this patch. It seems it works not as expected, so it is better to revert it, and I maybe get time for reworking it.
bye, Heiko
On 23 April 2015 at 18:28, Heiko Schocher hs@denx.de wrote:
Hello Jagan,
Hi Heiko,
Hello Jagan,
Ok, Shall I apply this revert patch?
thanks!
Hello Jagan,
Am 23.04.2015 15:06, schrieb Jagan Teki:
Hello Jagan,
Hi Heiko,
Hello Jagan,
On 18 December 2014 at 19:21, Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com wrote: > > > This reverts commit 562f8df18da62ae02c4ace1e530451fe82c3312d. > > Never see the issue with N25Q128 flash without need of W#/Vpp signal > during probe. > > Signed-off-by: Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com > Cc: Heiko Schocher hs@denx.de > --- > README | 11 ----------- > drivers/mtd/spi/sf_internal.h | 4 ---- > drivers/mtd/spi/sf_probe.c | 30 ------------------------------ > 3 files changed, 45 deletions(-)
Yes, please.
bye, Heiko
Heiko Schocher
Jagan Teki
