[PATCH 0/2] regulators: qcom-rpmh: support SM8550 and SM8650 platforms
Fix the RSC and add the tables for the PM8550 and related regulators.
Signed-off-by: Neil Armstrong neil.armstrong@linaro.org --- Neil Armstrong (2): soc: qcom: rpmh-rsc: add back __tcs_set_trigger() for SM8550/SM8650 regulator: qcom-rpmh-regulator: add support for PM8550 & related regulators
drivers/power/regulator/qcom-rpmh-regulator.c | 136 ++++++++++++++++++++++++++ drivers/soc/qcom/rpmh-rsc.c | 43 ++++++++ 2 files changed, 179 insertions(+) --- base-commit: bb403c895887eb5b29652f916646f886b34c6309 change-id: 20240903-topic-sm8x50-regulators-support-b149f2417299
The TCS writes has no effect after the removal of the __tcs_set_trigger() call, obviously it seems the RSC version 3 requires it to complete the transactions.
Fixes: 80c5be164ad ("soc: qcom: rpmh-rsc: drop unused multi-threading and non-active TCS support") Signed-off-by: Neil Armstrong neil.armstrong@linaro.org --- drivers/soc/qcom/rpmh-rsc.c | 43 +++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 43 insertions(+)
diff --git a/drivers/soc/qcom/rpmh-rsc.c b/drivers/soc/qcom/rpmh-rsc.c index 61fb2e69558..aee9e55194e 100644 --- a/drivers/soc/qcom/rpmh-rsc.c +++ b/drivers/soc/qcom/rpmh-rsc.c @@ -293,6 +293,48 @@ static void __tcs_buffer_write(struct rsc_drv *drv, int tcs_id, int cmd_id, write_tcs_reg(drv, drv->regs[RSC_DRV_CMD_ENABLE], tcs_id, cmd_enable); }
+/** + * __tcs_set_trigger() - Start xfer on a TCS or unset trigger on a borrowed TCS + * @drv: The controller. + * @tcs_id: The global ID of this TCS. + * @trigger: If true then untrigger/retrigger. If false then just untrigger. + * + * In the normal case we only ever call with "trigger=true" to start a + * transfer. That will un-trigger/disable the TCS from the last transfer + * then trigger/enable for this transfer. + * + * If we borrowed a wake TCS for an active-only transfer we'll also call + * this function with "trigger=false" to just do the un-trigger/disable + * before using the TCS for wake purposes again. + * + * Note that the AP is only in charge of triggering active-only transfers. + * The AP never triggers sleep/wake values using this function. + */ +static void __tcs_set_trigger(struct rsc_drv *drv, int tcs_id, bool trigger) +{ + u32 enable; + u32 reg = drv->regs[RSC_DRV_CONTROL]; + + /* + * HW req: Clear the DRV_CONTROL and enable TCS again + * While clearing ensure that the AMC mode trigger is cleared + * and then the mode enable is cleared. + */ + enable = read_tcs_reg(drv, reg, tcs_id); + enable &= ~TCS_AMC_MODE_TRIGGER; + write_tcs_reg_sync(drv, reg, tcs_id, enable); + enable &= ~TCS_AMC_MODE_ENABLE; + write_tcs_reg_sync(drv, reg, tcs_id, enable); + + if (trigger) { + /* Enable the AMC mode on the TCS and then trigger the TCS */ + enable = TCS_AMC_MODE_ENABLE; + write_tcs_reg_sync(drv, reg, tcs_id, enable); + enable |= TCS_AMC_MODE_TRIGGER; + write_tcs_reg(drv, reg, tcs_id, enable); + } +} + /** * rpmh_rsc_send_data() - Write / trigger active-only message. * @drv: The controller. @@ -348,6 +390,7 @@ int rpmh_rsc_send_data(struct rsc_drv *drv, const struct tcs_request *msg) * of __tcs_set_trigger() below. */ __tcs_buffer_write(drv, tcs_id, 0, msg); + __tcs_set_trigger(drv, tcs_id, true);
/* U-Boot: Now wait for the TCS to be cleared, indicating that we're done */ for (i = 0; i < USEC_PER_SEC; i++) {
Add the PM8550 & related regulators found on the SM8550 and SM8650 platforms. The tables are imported from the Linux driver.
Signed-off-by: Neil Armstrong neil.armstrong@linaro.org --- drivers/power/regulator/qcom-rpmh-regulator.c | 136 ++++++++++++++++++++++++++ 1 file changed, 136 insertions(+)
diff --git a/drivers/power/regulator/qcom-rpmh-regulator.c b/drivers/power/regulator/qcom-rpmh-regulator.c index 06fd3f31956..2dc261d83e3 100644 --- a/drivers/power/regulator/qcom-rpmh-regulator.c +++ b/drivers/power/regulator/qcom-rpmh-regulator.c @@ -357,6 +357,69 @@ static const struct dm_regulator_ops rpmh_regulator_vrm_drms_ops = { .get_mode = rpmh_regulator_vrm_get_mode, };
+static struct dm_regulator_mode pmic_mode_map_pmic5_bob[] = { + { + .id = REGULATOR_MODE_LPM, + .register_value = PMIC5_BOB_MODE_PFM, + .name = "PMIC5_BOB_MODE_PFM" + }, { + .id = REGULATOR_MODE_AUTO, + .register_value = PMIC5_BOB_MODE_AUTO, + .name = "PMIC5_BOB_MODE_AUTO" + }, { + .id = REGULATOR_MODE_HPM, + .register_value = PMIC5_BOB_MODE_PWM, + .name = "PMIC5_BOB_MODE_PWM" + }, +}; + +static struct dm_regulator_mode pmic_mode_map_pmic5_smps[] = { + { + .id = REGULATOR_MODE_RETENTION, + .register_value = PMIC5_SMPS_MODE_RETENTION, + .name = "PMIC5_SMPS_MODE_RETENTION" + }, { + .id = REGULATOR_MODE_LPM, + .register_value = PMIC5_SMPS_MODE_PFM, + .name = "PMIC5_SMPS_MODE_PFM" + }, { + .id = REGULATOR_MODE_AUTO, + .register_value = PMIC5_SMPS_MODE_AUTO, + .name = "PMIC5_SMPS_MODE_AUTO" + }, { + .id = REGULATOR_MODE_HPM, + .register_value = PMIC5_SMPS_MODE_PWM, + .name = "PMIC5_SMPS_MODE_PWM" + }, +}; + +static const struct rpmh_vreg_hw_data pmic5_bob = { + .regulator_type = VRM, + .ops = &rpmh_regulator_vrm_drms_ops, + .voltage_range = REGULATOR_LINEAR_RANGE(3000000, 0, 31, 32000), + .n_voltages = 32, + .pmic_mode_map = pmic_mode_map_pmic5_bob, + .n_modes = ARRAY_SIZE(pmic_mode_map_pmic5_bob), +}; + +static const struct rpmh_vreg_hw_data pmic5_ftsmps525_lv = { + .regulator_type = VRM, + .ops = &rpmh_regulator_vrm_drms_ops, + .voltage_range = REGULATOR_LINEAR_RANGE(300000, 0, 267, 4000), + .n_voltages = 268, + .pmic_mode_map = pmic_mode_map_pmic5_smps, + .n_modes = ARRAY_SIZE(pmic_mode_map_pmic5_smps), +}; + +static const struct rpmh_vreg_hw_data pmic5_ftsmps525_mv = { + .regulator_type = VRM, + .ops = &rpmh_regulator_vrm_drms_ops, + .voltage_range = REGULATOR_LINEAR_RANGE(600000, 0, 267, 8000), + .n_voltages = 268, + .pmic_mode_map = pmic_mode_map_pmic5_smps, + .n_modes = ARRAY_SIZE(pmic_mode_map_pmic5_smps), +}; + static struct dm_regulator_mode pmic_mode_map_pmic5_ldo[] = { { .id = REGULATOR_MODE_RETENTION, @@ -393,6 +456,16 @@ static const struct rpmh_vreg_hw_data pmic5_pldo_lv = { .n_modes = ARRAY_SIZE(pmic_mode_map_pmic5_ldo), };
+static const struct rpmh_vreg_hw_data pmic5_nldo515 = { + .regulator_type = VRM, + .ops = &rpmh_regulator_vrm_drms_ops, + .voltage_range = REGULATOR_LINEAR_RANGE(320000, 0, 210, 8000), + .n_voltages = 211, + .hpm_min_load_uA = 30000, + .pmic_mode_map = pmic_mode_map_pmic5_ldo, + .n_modes = ARRAY_SIZE(pmic_mode_map_pmic5_ldo), +}; + #define RPMH_VREG(_name, _resource_name, _hw_data, _supply_name) \ { \ .name = _name, \ @@ -412,6 +485,57 @@ static const struct rpmh_vreg_init_data pm8150l_vreg_data[] = { {} };
+static const struct rpmh_vreg_init_data pm8550_vreg_data[] = { + RPMH_VREG("ldo1", "ldo%s1", &pmic5_nldo515, "vdd-l1-l4-l10"), + RPMH_VREG("ldo2", "ldo%s2", &pmic5_pldo, "vdd-l2-l13-l14"), + RPMH_VREG("ldo3", "ldo%s3", &pmic5_nldo515, "vdd-l3"), + RPMH_VREG("ldo4", "ldo%s4", &pmic5_nldo515, "vdd-l1-l4-l10"), + RPMH_VREG("ldo5", "ldo%s5", &pmic5_pldo, "vdd-l5-l16"), + RPMH_VREG("ldo6", "ldo%s6", &pmic5_pldo, "vdd-l6-l7"), + RPMH_VREG("ldo7", "ldo%s7", &pmic5_pldo, "vdd-l6-l7"), + RPMH_VREG("ldo8", "ldo%s8", &pmic5_pldo, "vdd-l8-l9"), + RPMH_VREG("ldo9", "ldo%s9", &pmic5_pldo, "vdd-l8-l9"), + RPMH_VREG("ldo10", "ldo%s10", &pmic5_nldo515, "vdd-l1-l4-l10"), + RPMH_VREG("ldo11", "ldo%s11", &pmic5_nldo515, "vdd-l11"), + RPMH_VREG("ldo12", "ldo%s12", &pmic5_nldo515, "vdd-l12"), + RPMH_VREG("ldo13", "ldo%s13", &pmic5_pldo, "vdd-l2-l13-l14"), + RPMH_VREG("ldo14", "ldo%s14", &pmic5_pldo, "vdd-l2-l13-l14"), + RPMH_VREG("ldo15", "ldo%s15", &pmic5_nldo515, "vdd-l15"), + RPMH_VREG("ldo16", "ldo%s16", &pmic5_pldo, "vdd-l5-l16"), + RPMH_VREG("ldo17", "ldo%s17", &pmic5_pldo, "vdd-l17"), + RPMH_VREG("bob1", "bob%s1", &pmic5_bob, "vdd-bob1"), + RPMH_VREG("bob2", "bob%s2", &pmic5_bob, "vdd-bob2"), + {} +}; + +static const struct rpmh_vreg_init_data pm8550vs_vreg_data[] = { + RPMH_VREG("smps1", "smp%s1", &pmic5_ftsmps525_lv, "vdd-s1"), + RPMH_VREG("smps2", "smp%s2", &pmic5_ftsmps525_lv, "vdd-s2"), + RPMH_VREG("smps3", "smp%s3", &pmic5_ftsmps525_lv, "vdd-s3"), + RPMH_VREG("smps4", "smp%s4", &pmic5_ftsmps525_lv, "vdd-s4"), + RPMH_VREG("smps5", "smp%s5", &pmic5_ftsmps525_lv, "vdd-s5"), + RPMH_VREG("smps6", "smp%s6", &pmic5_ftsmps525_mv, "vdd-s6"), + RPMH_VREG("ldo1", "ldo%s1", &pmic5_nldo515, "vdd-l1"), + RPMH_VREG("ldo2", "ldo%s2", &pmic5_nldo515, "vdd-l2"), + RPMH_VREG("ldo3", "ldo%s3", &pmic5_nldo515, "vdd-l3"), + {} +}; + +static const struct rpmh_vreg_init_data pm8550ve_vreg_data[] = { + RPMH_VREG("smps1", "smp%s1", &pmic5_ftsmps525_lv, "vdd-s1"), + RPMH_VREG("smps2", "smp%s2", &pmic5_ftsmps525_lv, "vdd-s2"), + RPMH_VREG("smps3", "smp%s3", &pmic5_ftsmps525_lv, "vdd-s3"), + RPMH_VREG("smps4", "smp%s4", &pmic5_ftsmps525_mv, "vdd-s4"), + RPMH_VREG("smps5", "smp%s5", &pmic5_ftsmps525_lv, "vdd-s5"), + RPMH_VREG("smps6", "smp%s6", &pmic5_ftsmps525_lv, "vdd-s6"), + RPMH_VREG("smps7", "smp%s7", &pmic5_ftsmps525_lv, "vdd-s7"), + RPMH_VREG("smps8", "smp%s8", &pmic5_ftsmps525_lv, "vdd-s8"), + RPMH_VREG("ldo1", "ldo%s1", &pmic5_nldo515, "vdd-l1"), + RPMH_VREG("ldo2", "ldo%s2", &pmic5_nldo515, "vdd-l2"), + RPMH_VREG("ldo3", "ldo%s3", &pmic5_nldo515, "vdd-l3"), + {} +}; + /* probe an individual regulator */ static int rpmh_regulator_probe(struct udevice *dev) { @@ -526,6 +650,18 @@ static const struct udevice_id rpmh_regulator_ids[] = { .compatible = "qcom,pm8150l-rpmh-regulators", .data = (ulong)pm8150l_vreg_data, }, + { + .compatible = "qcom,pm8550-rpmh-regulators", + .data = (ulong)pm8550_vreg_data, + }, + { + .compatible = "qcom,pm8550ve-rpmh-regulators", + .data = (ulong)pm8550ve_vreg_data, + }, + { + .compatible = "qcom,pm8550vs-rpmh-regulators", + .data = (ulong)pm8550vs_vreg_data, + }, { /* sentinal */ }, };
Thanks Neil
Tested-by: Caleb Connolly caleb.connolly@linaro.org # sm8250 rb5 Reviewed-by: Caleb Connolly caleb.connolly@linaro.org
Applied, thanks!
[1/2] soc: qcom: rpmh-rsc: add back __tcs_set_trigger() for SM8550/SM8650 commit: 0fa4617861299b42effb5faf4afafd6fe1a79192 [2/2] regulator: qcom-rpmh-regulator: add support for PM8550 & related regulators commit: cb8cc050f827654e70c8e1ac5020a2cc4d42aefc
Caleb Connolly
Neil Armstrong
