[U-Boot] [PATCH v2 1/2] common: Add support for Android DT image
Android documentation recommends new image format for storing DTB/DTBO files: [1]. To support that format, two things should be done:
1. Add dt_table.h file from Android (BSD-3 relicensed version): [2]. This header defines structures and constants that we need to work with that DT image format.
Changes: - re-licensed from Apache to BSD-3 - removed functions declarations - change the coding style to kernel (make checkpatch happy)
2. Add helper functions for Android DTB/DTBO format. In image-android-dt.* files you can find helper functions to work with Android DT image format, such us routines for: - printing the dump of image structure - getting the address and size of desired dtb/dtbo file
[1] https://source.android.com/devices/architecture/dto/partitions [2] https://android.googlesource.com/platform/system/libufdt/+/58a7582180f477032...
Signed-off-by: Sam Protsenko semen.protsenko@linaro.org --- common/image-android-dt.c | 157 +++++++++++++++++++++++++++++++++++++ include/dt_table.h | 46 +++++++++++ include/image-android-dt.h | 21 +++++ 3 files changed, 224 insertions(+) create mode 100644 common/image-android-dt.c create mode 100644 include/dt_table.h create mode 100644 include/image-android-dt.h
diff --git a/common/image-android-dt.c b/common/image-android-dt.c new file mode 100644 index 0000000000..9b7683faab --- /dev/null +++ b/common/image-android-dt.c @@ -0,0 +1,157 @@ +/* + * (C) Copyright 2018 Linaro Ltd. + * Sam Protsenko semen.protsenko@linaro.org + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <image-android-dt.h> +#include <dt_table.h> +#include <common.h> +#include <linux/libfdt.h> +#include <mapmem.h> + +/** + * Check if image header is correct. + * + * @param hdr_addr Start address of DT image + * @return true if header is correct or false if header is incorrect + */ +bool android_dt_check_header(ulong hdr_addr) +{ + const struct dt_table_header *hdr; + u32 magic; + + hdr = map_sysmem(hdr_addr, sizeof(*hdr)); + magic = fdt32_to_cpu(hdr->magic); + unmap_sysmem(hdr); + + return magic == DT_TABLE_MAGIC; +} + +/** + * Get the address of FDT (dtb or dtbo) in memory by its index in image. + * + * @param hdr_addr Start address of DT image + * @param index Index of desired FDT in image (starting from 0) + * @param[out] addr If not NULL, will contain address to specified FDT + * @param[out] size If not NULL, will contain size of specified FDT + * + * @return true on success or false on error + */ +bool android_dt_get_fdt_by_index(ulong hdr_addr, u32 index, ulong *addr, + u32 *size) +{ + const struct dt_table_header *hdr; + const struct dt_table_entry *e; + u32 entry_count, entries_offset, entry_size; + ulong e_addr; + u32 dt_offset, dt_size; + + hdr = map_sysmem(hdr_addr, sizeof(*hdr)); + entry_count = fdt32_to_cpu(hdr->dt_entry_count); + entries_offset = fdt32_to_cpu(hdr->dt_entries_offset); + entry_size = fdt32_to_cpu(hdr->dt_entry_size); + unmap_sysmem(hdr); + + if (index > entry_count) { + printf("Error: index > dt_entry_count (%u > %u)\n", index, + entry_count); + return false; + } + + e_addr = hdr_addr + entries_offset + index * entry_size; + e = map_sysmem(e_addr, sizeof(*e)); + dt_offset = fdt32_to_cpu(e->dt_offset); + dt_size = fdt32_to_cpu(e->dt_size); + unmap_sysmem(e); + + if (addr) + *addr = hdr_addr + dt_offset; + if (size) + *size = dt_size; + + return true; +} + +#if !defined(CONFIG_SPL_BUILD) +static void android_dt_print_fdt_info(const struct fdt_header *fdt) +{ + u32 fdt_size; + int root_node_off; + const char *compatible = NULL; + + fdt_size = fdt_totalsize(fdt); + root_node_off = fdt_path_offset(fdt, "/"); + if (root_node_off < 0) { + printf("Error: Root node not found\n"); + } else { + compatible = fdt_getprop(fdt, root_node_off, "compatible", + NULL); + } + + printf(" (FDT)size = %d\n", fdt_size); + printf(" (FDT)compatible = %s\n", + compatible ? compatible : "(unknown)"); +} + +/** + * Print information about DT image structure. + * + * @param hdr_addr Start address of DT image + */ +void android_dt_print_contents(ulong hdr_addr) +{ + const struct dt_table_header *hdr; + u32 entry_count, entries_offset, entry_size; + u32 i; + + hdr = map_sysmem(hdr_addr, sizeof(*hdr)); + entry_count = fdt32_to_cpu(hdr->dt_entry_count); + entries_offset = fdt32_to_cpu(hdr->dt_entries_offset); + entry_size = fdt32_to_cpu(hdr->dt_entry_size); + + /* Print image header info */ + printf("dt_table_header:\n"); + printf(" magic = %08x\n", fdt32_to_cpu(hdr->magic)); + printf(" total_size = %d\n", fdt32_to_cpu(hdr->total_size)); + printf(" header_size = %d\n", fdt32_to_cpu(hdr->header_size)); + printf(" dt_entry_size = %d\n", entry_size); + printf(" dt_entry_count = %d\n", entry_count); + printf(" dt_entries_offset = %d\n", entries_offset); + printf(" page_size = %d\n", fdt32_to_cpu(hdr->page_size)); + printf(" reserved[0] = %08x\n", fdt32_to_cpu(hdr->reserved[0])); + + unmap_sysmem(hdr); + + /* Print image entries info */ + for (i = 0; i < entry_count; ++i) { + const ulong e_addr = hdr_addr + entries_offset + i * entry_size; + const struct dt_table_entry *e; + const struct fdt_header *fdt; + u32 dt_offset, dt_size; + u32 j; + + e = map_sysmem(e_addr, sizeof(*e)); + dt_offset = fdt32_to_cpu(e->dt_offset); + dt_size = fdt32_to_cpu(e->dt_size); + + printf("dt_table_entry[%d]:\n", i); + printf(" dt_size = %d\n", dt_size); + printf(" dt_offset = %d\n", dt_offset); + printf(" id = %08x\n", fdt32_to_cpu(e->id)); + printf(" rev = %08x\n", fdt32_to_cpu(e->rev)); + for (j = 0; j < 4; ++j) { + printf(" custom[%d] = %08x\n", j, + fdt32_to_cpu(e->custom[j])); + } + + unmap_sysmem(e); + + /* Print FDT info for this entry */ + fdt = map_sysmem(hdr_addr + dt_offset, sizeof(*fdt)); + android_dt_print_fdt_info(fdt); + unmap_sysmem(fdt); + } +} +#endif diff --git a/include/dt_table.h b/include/dt_table.h new file mode 100644 index 0000000000..19cbbeab2a --- /dev/null +++ b/include/dt_table.h @@ -0,0 +1,46 @@ +/* + * This is from the Android Project, + * Repository: https://android.googlesource.com/platform/system/libufdt + * File: utils/src/dt_table.h + * Commit: 58a7582180f477032cd6c74f8d9afad0038e74c3 + * Copyright (C) 2017 The Android Open Source Project + * + * SPDX-License-Identifier: BSD-3-Clause + */ + +#ifndef DT_TABLE_H +#define DT_TABLE_H + +#include <linux/types.h> + +#define DT_TABLE_MAGIC 0xd7b7ab1e +#define DT_TABLE_DEFAULT_PAGE_SIZE 2048 + +struct dt_table_header { + u32 magic; /* DT_TABLE_MAGIC */ + u32 total_size; /* includes dt_table_header + all dt_table_entry + * and all dtb/dtbo + */ + u32 header_size; /* sizeof(dt_table_header) */ + + u32 dt_entry_size; /* sizeof(dt_table_entry) */ + u32 dt_entry_count; /* number of dt_table_entry */ + u32 dt_entries_offset; /* offset to the first dt_table_entry + * from head of dt_table_header. + * The value will be equal to header_size if + * no padding is appended + */ + u32 page_size; /* flash page size we assume */ + u32 reserved[1]; /* must be zero */ +}; + +struct dt_table_entry { + u32 dt_size; + u32 dt_offset; /* offset from head of dt_table_header */ + + u32 id; /* optional, must be zero if unused */ + u32 rev; /* optional, must be zero if unused */ + u32 custom[4]; /* optional, must be zero if unused */ +}; + +#endif diff --git a/include/image-android-dt.h b/include/image-android-dt.h new file mode 100644 index 0000000000..08b810d461 --- /dev/null +++ b/include/image-android-dt.h @@ -0,0 +1,21 @@ +/* + * (C) Copyright 2018 Linaro Ltd. + * Sam Protsenko semen.protsenko@linaro.org + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef IMAGE_ANDROID_DT_H +#define IMAGE_ANDROID_DT_H + +#include <linux/types.h> + +bool android_dt_check_header(ulong hdr_addr); +bool android_dt_get_fdt_by_index(ulong hdr_addr, u32 index, ulong *addr, + u32 *size); + +#if !defined(CONFIG_SPL_BUILD) +void android_dt_print_contents(ulong hdr_addr); +#endif + +#endif /* IMAGE_ANDROID_DT_H */
dtimg command allows user to work with Android DTB/DTBO image format. Such as, getting the address of desired DTB/DTBO file, printing the dump of the image in U-Boot shell, etc.
This command is needed to provide Android boot with new Android DT image format further.
Signed-off-by: Sam Protsenko semen.protsenko@linaro.org --- cmd/Kconfig | 8 +++ cmd/Makefile | 1 + cmd/dtimg.c | 142 ++++++++++++++++++++++++++++++++++++++++++++++++ common/Makefile | 4 ++ 4 files changed, 155 insertions(+) create mode 100644 cmd/dtimg.c
diff --git a/cmd/Kconfig b/cmd/Kconfig index bc1d2f31c0..68f3cc7b48 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -256,6 +256,14 @@ config CMD_BOOTMENU help Add an ANSI terminal boot menu command.
+config CMD_DTIMG + bool "dtimg" + help + Android DTB/DTBO image manipulation commands. Read dtb/dtbo files from + image into RAM, dump image structure information, etc. Those dtb/dtbo + files should be merged in one dtb further, which needs to be passed to + the kernel, as part of a boot process. + config CMD_ELF bool "bootelf, bootvx" default y diff --git a/cmd/Makefile b/cmd/Makefile index c4269ac8ac..1cc2e74e9e 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -43,6 +43,7 @@ ifdef CONFIG_POST obj-$(CONFIG_CMD_DIAG) += diag.o endif obj-$(CONFIG_CMD_DISPLAY) += display.o +obj-$(CONFIG_CMD_DTIMG) += dtimg.o obj-$(CONFIG_CMD_ECHO) += echo.o obj-$(CONFIG_ENV_IS_IN_EEPROM) += eeprom.o obj-$(CONFIG_CMD_EEPROM) += eeprom.o diff --git a/cmd/dtimg.c b/cmd/dtimg.c new file mode 100644 index 0000000000..5295a341ad --- /dev/null +++ b/cmd/dtimg.c @@ -0,0 +1,142 @@ +/* + * (C) Copyright 2018 Linaro Ltd. + * Sam Protsenko semen.protsenko@linaro.org + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <image-android-dt.h> +#include <common.h> + +enum cmd_dtimg_info { + CMD_DTIMG_START = 0, + CMD_DTIMG_SIZE, +}; + +static int do_dtimg_dump(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + char *endp; + ulong hdr_addr; + + if (argc != 2) + return CMD_RET_USAGE; + + hdr_addr = simple_strtoul(argv[1], &endp, 16); + if (*endp != '\0') { + printf("Error: Wrong image address\n"); + return CMD_RET_FAILURE; + } + + if (!android_dt_check_header(hdr_addr)) { + printf("Error: DT image header is incorrect\n"); + return CMD_RET_FAILURE; + } + + android_dt_print_contents(hdr_addr); + + return CMD_RET_SUCCESS; +} + +static int dtimg_get_fdt(int argc, char * const argv[], enum cmd_dtimg_info cmd) +{ + ulong hdr_addr; + u32 index; + char *endp; + ulong fdt_addr; + u32 fdt_size; + char buf[65]; + + if (argc != 4) + return CMD_RET_USAGE; + + hdr_addr = simple_strtoul(argv[1], &endp, 16); + if (*endp != '\0') { + printf("Error: Wrong image address\n"); + return CMD_RET_FAILURE; + } + + if (!android_dt_check_header(hdr_addr)) { + printf("Error: DT image header is incorrect\n"); + return CMD_RET_FAILURE; + } + + index = simple_strtoul(argv[2], &endp, 0); + if (*endp != '\0') { + printf("Error: Wrong index\n"); + return CMD_RET_FAILURE; + } + + if (!android_dt_get_fdt_by_index(hdr_addr, index, &fdt_addr, &fdt_size)) + return CMD_RET_FAILURE; + + switch (cmd) { + case CMD_DTIMG_START: + snprintf(buf, sizeof(buf), "%lx", fdt_addr); + break; + case CMD_DTIMG_SIZE: + snprintf(buf, sizeof(buf), "%x", fdt_size); + break; + default: + printf("Error: Unknown cmd_dtimg_info value: %d\n", cmd); + return CMD_RET_FAILURE; + } + + env_set(argv[3], buf); + + return CMD_RET_SUCCESS; +} + +static int do_dtimg_start(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + return dtimg_get_fdt(argc, argv, CMD_DTIMG_START); +} + +static int do_dtimg_size(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + return dtimg_get_fdt(argc, argv, CMD_DTIMG_SIZE); +} + +static cmd_tbl_t cmd_dtimg_sub[] = { + U_BOOT_CMD_MKENT(dump, 2, 0, do_dtimg_dump, "", ""), + U_BOOT_CMD_MKENT(start, 4, 0, do_dtimg_start, "", ""), + U_BOOT_CMD_MKENT(size, 4, 0, do_dtimg_size, "", ""), +}; + +static int do_dtimg(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + cmd_tbl_t *cp; + + cp = find_cmd_tbl(argv[1], cmd_dtimg_sub, ARRAY_SIZE(cmd_dtimg_sub)); + + /* Strip off leading 'dtimg' command argument */ + argc--; + argv++; + + if (!cp || argc > cp->maxargs) + return CMD_RET_USAGE; + if (flag == CMD_FLAG_REPEAT && !cp->repeatable) + return CMD_RET_SUCCESS; + + return cp->cmd(cmdtp, flag, argc, argv); +} + +U_BOOT_CMD( + dtimg, CONFIG_SYS_MAXARGS, 0, do_dtimg, + "manipulate dtb/dtbo Android image", + "dump <addr>\n" + " - parse specified image and print its structure info\n" + " <addr>: image address in RAM, in hex\n" + "dtimg start <addr> <index> <varname>\n" + " - get address (hex) of FDT in the image, by index\n" + " <addr>: image address in RAM, in hex\n" + " <index>: index of desired FDT in the image\n" + " <varname>: name of variable where to store address of FDT\n" + "dtimg size <addr> <index> <varname>\n" + " - get size (hex, bytes) of FDT in the image, by index\n" + " <addr>: image address in RAM, in hex\n" + " <index>: index of desired FDT in the image\n" + " <varname>: name of variable where to store size of FDT" +); diff --git a/common/Makefile b/common/Makefile index 7011dada99..6ef55d0d7a 100644 --- a/common/Makefile +++ b/common/Makefile @@ -111,6 +111,10 @@ obj-$(CONFIG_IO_TRACE) += iotrace.o obj-y += memsize.o obj-y += stdio.o
+ifdef CONFIG_CMD_DTIMG +obj-y += image-android-dt.o +endif + ifndef CONFIG_SPL_BUILD # This option is not just y/n - it can have a numeric value ifdef CONFIG_FASTBOOT_FLASH
Le jeu. 19 avr. 2018 à 22:52, Sam Protsenko semen.protsenko@linaro.org a écrit :
+config CMD_DTIMG
bool "dtimg"
help
files from
dtb/dtbo
passed to
- (C) Copyright 2018 Linaro Ltd.
- Sam Protsenko semen.protsenko@linaro.org
CMD_DTIMG_SIZE,
char *endp;
ulong hdr_addr;
if (argc != 2)
ulong hdr_addr;
u32 index;
char *endp;
ulong fdt_addr;
u32 fdt_size;
char buf[65];
if (argc != 4)
&fdt_size))
switch (cmd) {
break;
break;
default:
cmd_tbl_t *cp;
argc--;
argv++;
+U_BOOT_CMD(
"dump <addr>\n"
"dtimg dump <addr>\n"
ifndef CONFIG_SPL_BUILD # This option is not just y/n - it can have a numeric value ifdef CONFIG_FASTBOOT_FLASH -- 2.17.0
You would likely need review from a maintainer, but otherwise this looks fine (just one nit) Reviewed-by: Alex Deymo deymo@google.com
Changes:
I'm not familiar with how you handle these re-licensing so I can't say anything about that.
You also removed DT_TABLE_DEFAULT_VERSION but left DT_TABLE_DEFAULT_PAGE_SIZE, was that intentional?
- Add helper functions for Android DTB/DTBO format. In image-android-dt.* files you can find helper functions to work with Android DT image format, such us routines for:
- Check if image header is correct.
- @param hdr_addr Start address of DT image
- @return true if header is correct or false if header is incorrect
u32 magic;
unmap_sysmem(hdr);
- Get the address of FDT (dtb or dtbo) in memory by its index in image.
- @param index Index of desired FDT in image (starting from 0)
- @param[out] addr If not NULL, will contain address to specified FDT
- @param[out] size If not NULL, will contain size of specified FDT
- @return true on success or false on error
u32 *size)
ulong e_addr;
unmap_sysmem(hdr);
entry_count);
return false;
This function assumes the image is valid in several places, but here you could also check that the relative offset you are going to load falls within the the fdt32_to_cpu(hdr->total_size).
unmap_sysmem(e);
if (addr)
if (size)
*size = dt_size;
return true;
u32 fdt_size;
int root_node_off;
} else {
NULL);
- Print information about DT image structure.
u32 i;
unmap_sysmem(hdr);
entry_size;
u32 j;
unmap_sysmem(e);
unmap_sysmem(fdt);
- This is from the Android Project,
- File: utils/src/dt_table.h
- Commit: 58a7582180f477032cd6c74f8d9afad0038e74c3
- Copyright (C) 2017 The Android Open Source Project
- SPDX-License-Identifier: BSD-3-Clause
dt_table_entry
* and all dtb/dtbo
if
u32 dt_size;
u32 *size);
2.17.0
I haven't test this. Again, you probably want some maintainer to take a look too. Reviewed-by: Alex Deymo deymo@google.com
Regards, Alex
Changes:
Why is it OK to change the license on the code? AFAICT someone can't just relicense Apache to BSD-3. What happened for include/android_image.h was that Google relicensed the Android code in question to BSD-2 (which in turn allows us in GPL projects). Thanks!
Changes:
Ok, I will try to ask Google to do the same for the header I used. Do you know what exactly should be done? Do they need to publish relicensed file somewhere, or exactly in Android, or we just need a confirmation from their side? Also, which license is preferable for us?
Thanks.
-- Tom
Changes:
I believe Alex helped us last time, and it was done, iirc, by someone from Google submitting the file with the license we need and a Signed-off-by from their google.com address.
Hi, I checked with our team and the include/dt_table.h import as BSD-3 here is fine with us. Would you like me to send a patch with just this header file or just Signed-off-by this whole patch? Thanks, deymo@
Changes:
-- Tom
Thanks and please submit a stand-alone patch for just the header.
Alex Deymo
Sam Protsenko
