[U-Boot] [PATCH] odroid: dts: change the buck8 min-microvolt value
Change the buck8's min-microvolt to 750000. Whent thor protocol is used, board_usb_init() should be tried to set to 750000. But it was returned -EINVAL, because '750000' too lower than 2850000. (thor command doesn't work fine because of this problem.)
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com --- arch/arm/dts/exynos4412-odroid.dts | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/exynos4412-odroid.dts b/arch/arm/dts/exynos4412-odroid.dts index 188cb93..8710747 100644 --- a/arch/arm/dts/exynos4412-odroid.dts +++ b/arch/arm/dts/exynos4412-odroid.dts @@ -213,7 +213,7 @@
buck8_reg: BUCK8 { regulator-name = "VCC_P3V3_2.85V"; - regulator-min-microvolt = <2850000>; + regulator-min-microvolt = <750000>; regulator-max-microvolt = <3300000>; }; };
Hi
2017년 3월 30일 (목) 18:59, Jaehoon Chung jh80.chung@samsung.com님이 작성:
<2850000>;
<3300000>; }; }; -- 2.10.2
applied to u-boot-samsung.
Thanks
Jaehoon Chung
Minkyu Kang
