[U-Boot] u-boot-2010.03 build errors with USE_PRIVATE_LIBGCC=yes option
Hello,
While building uboot-2010.03 for any arm board, with USE_PRIVATE_LIBGCC=yes is throwing the following errors.
Any help would be appriciated
net/libnet.a(net.o): In function `ip_to_string': /data/csd_sw/spear/drives_os/vipink/spear/uboot/u-boot/net/net.c:1886: undefined reference to `__bswapsi2' net/libnet.a(nfs.o): In function `__fswab32': /data/csd_sw/spear/drives_os/vipink/spear/uboot/u-boot/include/linux/byteorder/swab.h:113: undefined reference to `__bswapsi2' net/libnet.a(bootp.o): In function `__fswab32': /data/csd_sw/spear/drives_os/vipink/spear/uboot/u-boot/include/linux/byteorder/swab.h:113: undefined reference to `__bswapsi2' common/libcommon.a(cmd_bootm.o): In function `__fswab32': /data/csd_sw/spear/drives_os/vipink/spear/uboot/u-boot/include/linux/byteorder/swab.h:113: undefined reference to `__bswapsi2' common/libcommon.a(cmd_nand.o): In function `nand_load_image': /data/csd_sw/spear/drives_os/vipink/spear/uboot/u-boot/common/cmd_nand.c:542: undefined reference to `__bswapsi2' common/libcommon.a(cmd_nvedit.o):/data/csd_sw/spear/drives_os/vipink/spear/uboot/u-boot/common/cmd_nvedit.c:369: more undefined references to `__bswapsi2' follow lib/libgeneric.a(display_options.o): In function `print_size': /data/csd_sw/spear/drives_os/vipink/spear/uboot/u-boot/lib/display_options.c:66: undefined reference to `__aeabi_uldivmod' /data/csd_sw/spear/drives_os/vipink/spear/uboot/u-boot/lib/display_options.c:69: undefined reference to `__aeabi_uldivmod' /data/csd_sw/spear/drives_os/vipink/spear/uboot/u-boot/lib/display_options.c:70: undefined reference to `__aeabi_uldivmod' lib/libgeneric.a(net_utils.o): In function `string_to_ip': /data/csd_sw/spear/drives_os/vipink/spear/uboot/u-boot/lib/net_utils.c:40: undefined reference to `__bswapsi2' make: *** [u-boot] Error 1
Thanks in advance
Regards Vipin
I had a similar problem with sh2a 7203 based board and gcc version 4.4.1 (Sourcery G++ Lite 4.4-206) Verify if the undefined symbols are of libgcc.
Regards
In data giovedì 15 luglio 2010 09:01:43, Vipin KUMAR ha scritto: : > Hello,
net/libnet.a(net.o): In function `ip_to_string': /data/csd_sw/spear/drives_os/vipink/spear/uboot/u-boot/net/net.c:1886: undefined reference to `__bswapsi2' net/libnet.a(nfs.o): In function `__fswab32': /data/csd_sw/spear/drives_os/vipink/spear/uboot/u-boot/include/linux/byteor der/swab.h:113: undefined reference to `__bswapsi2' net/libnet.a(bootp.o): In function `__fswab32': /data/csd_sw/spear/drives_os/vipink/spear/uboot/u-boot/include/linux/byteor der/swab.h:113: undefined reference to `__bswapsi2' common/libcommon.a(cmd_bootm.o): In function `__fswab32': /data/csd_sw/spear/drives_os/vipink/spear/uboot/u-boot/include/linux/byteor der/swab.h:113: undefined reference to `__bswapsi2' common/libcommon.a(cmd_nand.o): In function `nand_load_image': /data/csd_sw/spear/drives_os/vipink/spear/uboot/u-boot/common/cmd_nand.c:54 2: undefined reference to `__bswapsi2' common/libcommon.a(cmd_nvedit.o):/data/csd_sw/spear/drives_os/vipink/spear /uboot/u-boot/common/cmd_nvedit.c:369: more undefined references to `__bswapsi2' follow lib/libgeneric.a(display_options.o): In function `print_size': /data/csd_sw/spear/drives_os/vipink/spear/uboot/u-boot/lib/display_options. c:66: undefined reference to `__aeabi_uldivmod' /data/csd_sw/spear/drives_os/vipink/spear/uboot/u-boot/lib/display_options .c:69: undefined reference to `__aeabi_uldivmod' /data/csd_sw/spear/drives_os/vipink/spear/uboot/u-boot/lib/display_options .c:70: undefined reference to `__aeabi_uldivmod' lib/libgeneric.a(net_utils.o): In function `string_to_ip': /data/csd_sw/spear/drives_os/vipink/spear/uboot/u-boot/lib/net_utils.c:40: undefined reference to `__bswapsi2' make: *** [u-boot] Error 1
Thanks in advance
Regards Vipin _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Ciao Fabio,
They must be, because I can compile the source without USE_PRIVATE_LIBGCC=yes option But due to a few constraints, I have to compile the code with USE_PRIVATE_LIBGCC=yes option enabled
Regards Vipin
Regards
Thanks in advance
Ciao Vipin, ok, so the only way is to select the source file containing the fuction from libgcc and include at source level into your source u-boot tree. I did the same but I started from the lib dir of linux kernel
Regards
In data giovedì 15 luglio 2010 10:59:52, Vipin KUMAR ha scritto: : > Ciao Fabio,
Regards Vipin
Regards
net/libnet.a(net.o): In function `ip_to_string': /data/csd_sw/spear/drives_os/vipink/spear/uboot/u-boot/net/net.c:1886: undefined reference to `__bswapsi2' net/libnet.a(nfs.o): In function `__fswab32': /data/csd_sw/spear/drives_os/vipink/spear/uboot/u-boot/include/linux/byt eor der/swab.h:113: undefined reference to `__bswapsi2' net/libnet.a(bootp.o): In function `__fswab32': /data/csd_sw/spear/drives_os/vipink/spear/uboot/u-boot/include/linux/byt eor der/swab.h:113: undefined reference to `__bswapsi2' common/libcommon.a(cmd_bootm.o): In function `__fswab32': /data/csd_sw/spear/drives_os/vipink/spear/uboot/u-boot/include/linux/byt eor der/swab.h:113: undefined reference to `__bswapsi2' common/libcommon.a(cmd_nand.o): In function `nand_load_image': /data/csd_sw/spear/drives_os/vipink/spear/uboot/u-boot/common/cmd_nand.c :54 2: undefined reference to `__bswapsi2'
common/libcommon.a(cmd_nvedit.o):/data/csd_sw/spear/drives_os/vipink/spe ar /uboot/u-boot/common/cmd_nvedit.c:369: more undefined references to `__bswapsi2' follow lib/libgeneric.a(display_options.o): In function `print_size': /data/csd_sw/spear/drives_os/vipink/spear/uboot/u-boot/lib/display_optio ns. c:66: undefined reference to `__aeabi_uldivmod'
/data/csd_sw/spear/drives_os/vipink/spear/uboot/u-boot/lib/display_optio ns .c:69: undefined reference to `__aeabi_uldivmod'
/data/csd_sw/spear/drives_os/vipink/spear/uboot/u-boot/lib/display_optio ns .c:70: undefined reference to `__aeabi_uldivmod' lib/libgeneric.a(net_utils.o): In function `string_to_ip': /data/csd_sw/spear/drives_os/vipink/spear/uboot/u-boot/lib/net_utils.c:4 0: undefined reference to `__bswapsi2' make: *** [u-boot] Error 1
Thanks in advance
On 7/15/2010 2:34 PM, Fabio Giovagnini wrote:
Ciao Vipin,
Ciao Again,
Hmmm, I was just avoiding it thinking that maybe someone somewhere would have already done that. May be that patch can also be sent to the community
Regards Vipin
Regards
Regards Vipin
Regards
Thanks in advance
Dear Vipin KUMAR,
Feel free to go on - we're looking forward to seeing your patch.
Just for my info. I did USE_PRIVATE_LIBGCC=yes modifing directly the makfile. Is iot possible to specify this in board dependent config file?
I'll send my patches as soon as i'll finish the porting on my boadl called mlcd7203
Regards
In data giovedì 15 luglio 2010 11:13:08, Wolfgang Denk ha scritto: : > Dear Vipin KUMAR,
Dear Fabio Giovagnini,
Why? Just pass it on the command line, or set it as envrionment variable.
something like u-boot-sh$ make USE_PRIVATE_LIBGCC=yes <enter>
Right?
Ok Thanks a lot
In data giovedì 15 luglio 2010 12:22:43, Wolfgang Denk ha scritto: : > Dear Fabio Giovagnini,
On 7/15/2010 2:43 PM, Wolfgang Denk wrote:
Dear Vipin KUMAR,
Dear Wolfgang,
The problem why I was looking for this is that the tool-chain I am using only supports -mhard-float option and this toolchain is specifically meant for armv7 (basically Cortex-A9 with FPU enabled).
Since this option -msoft-float is passed from arch/arm/cpu/config.mk, and it is common for all arm configurations. Is there a good way to pass -mhard-float..
Regards Vipin
Dear Vipin KUMAR,
Why would you want to do that? We don't use any FP code in U-Boot anyway.
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot- bounces@lists.denx.de] On Behalf Of Wolfgang Denk Sent: Thursday, July 15, 2010 10:58 AM To: Vipin KUMAR Cc: u-boot@lists.denx.de; Shiraz HASHIM Subject: Re: [U-Boot] u-boot-2010.03 build errors with USE_PRIVATE_LIBGCC=yes option
Dear Vipin KUMAR,
and it
mhard-float..
We have actually seen issues with the post memory tests using the -mfpu=neon and -ftree-vectorize under gcc 4.4.1. So, I would be very careful with FP flags until someone figures out how to fix the 64-bit access operators that the memory test uses.
DaR
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de When you say "I wrote a program that crashed Windows", people just stare at you blankly and say "Hey, I got those with the system, *for free*". - Linus Torvalds in 3itc77$9lj@ninurta.fer.uni-lj.si _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Dear "Dennis Ruffer",
Well, there _is_ a reason for using -msoft-float as we are doing in U-Boot. Thanks for confirming this again.
Dennis Ruffer
Fabio Giovagnini
Vipin KUMAR
