[U-Boot-Users] toolchain for u-boot 1.0.0
I am porting U-boot to Intrinsyc cerfboard(PXA250 based). The toolchain used is 2.95.3. U-boot hangs just after relocating to RAM and there is no console output. Is there any later stable toolchain available to build u-boot. I have checked with 3.3.2 which does not work(glibc 3.3.2 uses hard FP).
thanks, Prakash
-------------------------------------------------------------------- mail2web - Check your email from the web at http://mail2web.com/ .
What makes you think your problem has anything o do with the toolchain?
Most definitely this is NOT a toolchain issue. Please see the FAQ: http://www.denx.de/twiki/bin/view/DULG/UBootCrashAfterRelocation
Wrong. There is no glibc 3.3.2. The latest stable version is 2.3.2. And nm matter which version you use, it doese not "use hard FP" per se - it always uses what it was configured for; if you don;t want har FP then don't configure it for it.
prakash@embedx.com
