[U-Boot] [PATCH v3 0/3] exynos config updates
This series rebases my exynos config_distro_*.h patches as requested. Baseline is u-boot.git#master 11ada9225a16 (ahead of current u-boot-samsung).
I also included "Increase command line buffer size (CONFIG_SYS_CBSIZE)" which was previously posted separately.
Ian.
...and remove explicit setting of things which this implies. This is done for all exynos platforms (4 & 5) so it is added to exynos-common.h
I'm mainly interested in CONFIG_CMD_BOOTZ and CONFIG_SUPPORT_RAW_INITRD
I have build tested on all exynos platforms (MAKEALL -s exynos), but only boot tested on arndale.
Signed-off-by: Ian Campbell ian.campbell@citrix.com Reviewed-by: Simon Glass sjg@chromium.org --- include/configs/arndale.h | 2 -- include/configs/exynos-common.h | 13 ++----------- include/configs/exynos5-common.h | 11 ----------- 3 files changed, 2 insertions(+), 24 deletions(-)
diff --git a/include/configs/arndale.h b/include/configs/arndale.h index f9ee40f..a87806d 100644 --- a/include/configs/arndale.h +++ b/include/configs/arndale.h @@ -17,8 +17,6 @@ /* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE
-#define CONFIG_CMD_EXT2 - /* USB */ #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_EXYNOS diff --git a/include/configs/exynos-common.h b/include/configs/exynos-common.h index b258cb9..1246305 100644 --- a/include/configs/exynos-common.h +++ b/include/configs/exynos-common.h @@ -30,9 +30,6 @@ #define CONFIG_SKIP_LOWLEVEL_INIT #define CONFIG_BOARD_EARLY_INIT_F
-/* Enable fdt support */ -#define CONFIG_OF_LIBFDT - /* Keep L2 Cache Disabled */ #define CONFIG_CMD_CACHE
@@ -42,7 +39,6 @@ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_CMDLINE_TAG #define CONFIG_INITRD_TAG -#define CONFIG_CMDLINE_EDITING #define CONFIG_ENV_OVERWRITE
/* Size of malloc() pool before and after relocation */ @@ -61,7 +57,6 @@ #define CONFIG_EXYNOS_DWMMC #define CONFIG_BOUNCE_BUFFER
-#define CONFIG_BOOTDELAY 3 #define CONFIG_ZERO_BOOTDELAY_CHECK
/* PWM */ @@ -71,20 +66,14 @@ #include <config_cmd_default.h>
#define CONFIG_CMD_MMC -#define CONFIG_CMD_EXT4 #define CONFIG_CMD_EXT4_WRITE -#define CONFIG_CMD_FAT #define CONFIG_FAT_WRITE #define CONFIG_CMD_FS_GENERIC
-#define CONFIG_DOS_PARTITION -#define CONFIG_EFI_PARTITION #define CONFIG_CMD_PART #define CONFIG_PARTITION_UUIDS
/* Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ @@ -96,4 +85,6 @@ #define CONFIG_SYS_NO_FLASH #undef CONFIG_CMD_IMLS
+#include <config_distro_defaults.h> + #endif /* __CONFIG_H */ diff --git a/include/configs/exynos5-common.h b/include/configs/exynos5-common.h index ba591e7..b03966d 100644 --- a/include/configs/exynos5-common.h +++ b/include/configs/exynos5-common.h @@ -55,9 +55,6 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ EXYNOS_DEVICE_SETTINGS
-#define CONFIG_CMD_PING -#define CONFIG_CMD_ELF -#define CONFIG_CMD_NET #define CONFIG_CMD_HASH
/* Thermal Management Unit */ @@ -174,12 +171,6 @@ #define CONFIG_ENV_SROM_BANK 1 #endif /*CONFIG_CMD_NET*/
-/* Enable PXE Support */ -#ifdef CONFIG_CMD_NET -#define CONFIG_CMD_PXE -#define CONFIG_MENU -#endif - /* SHA hashing */ #define CONFIG_CMD_HASH #define CONFIG_HASH_VERIFY @@ -189,8 +180,6 @@ /* Enable Time Command */ #define CONFIG_CMD_TIME
-#define CONFIG_CMD_BOOTZ - #define CONFIG_CMD_GPIO
/* USB boot mode */
I successfully tested it on my arndale board.
Tested-by: Guillaume GARDET guillaume.gardet@free.fr
Guillaume
- #endif /* __CONFIG_H */
/* USB boot mode */
This replaces the existing CONFIG_BOOTCOMMAND for exynos5250 and 5420.
exynos4 platforms seem to have existing complex extra env configuration for booting and so are excluded here. Hence the bootcmd.h is added to exynos5-common.h.
Signed-off-by: Ian Campbell ian.campbell@citrix.com Reviewed-by: Simon Glass sjg@chromium.org --- include/configs/arndale.h | 3 +++ include/configs/exynos5-common.h | 45 ++++++++++++++++++++++++++++++------- include/configs/exynos5-dt-common.h | 17 ++++++-------- include/configs/exynos5250-common.h | 2 -- include/configs/exynos5420-common.h | 2 -- 5 files changed, 47 insertions(+), 22 deletions(-)
diff --git a/include/configs/arndale.h b/include/configs/arndale.h index a87806d..919729d 100644 --- a/include/configs/arndale.h +++ b/include/configs/arndale.h @@ -9,6 +9,9 @@ #ifndef __CONFIG_ARNDALE_H #define __CONFIG_ARNDALE_H
+#define EXYNOS_FDTFILE_SETTING \ + "fdtfile=exynos5250-arndale.dtb\0" + #include "exynos5250-common.h"
/* SD/MMC configuration */ diff --git a/include/configs/exynos5-common.h b/include/configs/exynos5-common.h index b03966d..8f9b780 100644 --- a/include/configs/exynos5-common.h +++ b/include/configs/exynos5-common.h @@ -47,14 +47,6 @@ #define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_CONSOLE_MUX
-#define EXYNOS_DEVICE_SETTINGS \ - "stdin=serial\0" \ - "stdout=serial\0" \ - "stderr=serial\0" - -#define CONFIG_EXTRA_ENV_SETTINGS \ - EXYNOS_DEVICE_SETTINGS - #define CONFIG_CMD_HASH
/* Thermal Management Unit */ @@ -192,4 +184,41 @@ #define CONFIG_FIT #define CONFIG_FIT_BEST_MATCH
+ +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 1) \ + func(MMC, mmc, 0) \ + func(PXE, pxe, na) \ + func(DHCP, dhcp, na) + +#include <config_distro_bootcmd.h> + +#ifndef MEM_LAYOUT_ENV_SETTINGS +/* 2GB RAM, bootm size of 256M, load scripts after that */ +#define MEM_LAYOUT_ENV_SETTINGS \ + "bootm_size=0x10000000\0" \ + "kernel_addr_r=0x42000000\0" \ + "fdt_addr_r=0x43000000\0" \ + "ramdisk_addr_r=0x43300000\0" \ + "scriptaddr=0x50000000\0" \ + "pxefile_addr_r=0x51000000\0" +#endif + +#ifndef EXYNOS_DEVICE_SETTINGS +#define EXYNOS_DEVICE_SETTINGS \ + "stdin=serial\0" \ + "stdout=serial\0" \ + "stderr=serial\0" +#endif + +#ifndef EXYNOS_FDTFILE_SETTING +#define EXYNOS_FDTFILE_SETTING +#endif + +#define CONFIG_EXTRA_ENV_SETTINGS \ + EXYNOS_DEVICE_SETTINGS \ + EXYNOS_FDTFILE_SETTING \ + MEM_LAYOUT_ENV_SETTINGS \ + BOOTENV + #endif /* __CONFIG_EXYNOS5_COMMON_H */ diff --git a/include/configs/exynos5-dt-common.h b/include/configs/exynos5-dt-common.h index 66547fa..9cef0b0 100644 --- a/include/configs/exynos5-dt-common.h +++ b/include/configs/exynos5-dt-common.h @@ -9,6 +9,13 @@ #ifndef __CONFIG_EXYNOS5_DT_COMMON_H #define __CONFIG_EXYNOS5_DT_COMMON_H
+/* Console configuration */ +#undef EXYNOS_DEVICE_SETTINGS +#define EXYNOS_DEVICE_SETTINGS \ + "stdin=serial,cros-ec-keyb\0" \ + "stdout=serial,lcd\0" \ + "stderr=serial,lcd\0" + #include "exynos5-common.h"
/* PMIC */ @@ -22,14 +29,4 @@ #define CONFIG_CMD_CROS_EC #define CONFIG_KEYBOARD
-/* Console configuration */ -#undef EXYNOS_DEVICE_SETTINGS -#define EXYNOS_DEVICE_SETTINGS \ - "stdin=serial,cros-ec-keyb\0" \ - "stdout=serial,lcd\0" \ - "stderr=serial,lcd\0" - -#define CONFIG_EXTRA_ENV_SETTINGS \ - EXYNOS_DEVICE_SETTINGS - #endif diff --git a/include/configs/exynos5250-common.h b/include/configs/exynos5250-common.h index 713614f..a0107e8 100644 --- a/include/configs/exynos5250-common.h +++ b/include/configs/exynos5250-common.h @@ -29,8 +29,6 @@
#define CONFIG_SPL_TEXT_BASE 0x02023400
-#define CONFIG_BOOTCOMMAND "mmc read 40007000 451 2000; bootm 40007000" - #define CONFIG_IRAM_STACK 0x02050000
#define CONFIG_SYS_INIT_SP_ADDR CONFIG_IRAM_STACK diff --git a/include/configs/exynos5420-common.h b/include/configs/exynos5420-common.h index b0f940c..3cf9f01 100644 --- a/include/configs/exynos5420-common.h +++ b/include/configs/exynos5420-common.h @@ -44,8 +44,6 @@
#define CONFIG_BOARD_REV_GPIO_COUNT 2
-#define CONFIG_BOOTCOMMAND "mmc read 20007000 451 2000; bootm 20007000" - #define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2
Guillaume
"stdin=serial\0" \
"stdout=serial\0" \
"stderr=serial\0"
- func(MMC, mmc, 1) \
- func(MMC, mmc, 0) \
- func(PXE, pxe, na) \
- func(DHCP, dhcp, na)
- "bootm_size=0x10000000\0" \
- "kernel_addr_r=0x42000000\0" \
- "fdt_addr_r=0x43000000\0" \
- "ramdisk_addr_r=0x43300000\0" \
- "scriptaddr=0x50000000\0" \
- "pxefile_addr_r=0x51000000\0"
- "stderr=serial\0"
- EXYNOS_DEVICE_SETTINGS \
- EXYNOS_FDTFILE_SETTING \
- MEM_LAYOUT_ENV_SETTINGS \
- BOOTENV
- #endif /* __CONFIG_EXYNOS5_COMMON_H */
/* PMIC */
- #endif
I was running into this limit with a not overly long PXE append line.
Since the PXE code wants to print the resulting command line increase CONFIG_SYS_PBSIZE too.
Signed-off-by: Ian Campbell ian.campbell@citrix.com --- v2: Apply to exynos generally since consolidation. --- include/configs/exynos-common.h | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/exynos-common.h b/include/configs/exynos-common.h index 1246305..1f3ee55 100644 --- a/include/configs/exynos-common.h +++ b/include/configs/exynos-common.h @@ -74,8 +74,8 @@ #define CONFIG_PARTITION_UUIDS
/* Miscellaneous configurable options */ -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE 1024 /* Print Buffer Size */ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */
/* Boot Argument Buffer Size */
What if we add a default definition like this:
#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE 1024 /* Print Buffer Size */
,then if CONFIG_SYS_CBSIZE and CONFIG_SYS_PBSIZE are not defined in the board file, we just use the default?
I had the same issue sometime ago and I am wondering if this could be a better way to handle it.
Ian.
applied to u-boot-samsung.
Thanks, Minkyu Kang.
participants (5)
Fabio Estevam
Guillaume Gardet
Ian Campbell
Minkyu Kang
