[U-Boot-Users] [PATCH] (Resubmit) : Remove unused code from uboot-1.3.3/lib_arm/bootm.c
Sorry i had generated the patch from with uboot/lib_arm directory and hence i think it failed. now i have created the diff for the root directory where the uboot-1.3.3 folder resides. sorry for the trouble.
Thanks in advance.
Regards Gururaja
Signed off by: Gururaja Hebbar gururajakr@sanyo.co.in
diff -purN uboot/lib_arm_orig/bootm.c uboot/lib_arm/bootm.c --- uboot/lib_arm_orig/bootm.c 2008-05-19 03:47:11.000000000 -0700 +++ uboot/lib_arm/bootm.c 2008-07-15 16:51:38.250000000 -0700 @@ -43,9 +43,6 @@ static void setup_memory_tags (bd_t *bd) # endif static void setup_commandline_tag (bd_t *bd, char *commandline);
-#if 0 -static void setup_ramdisk_tag (bd_t *bd); -#endif # ifdef CONFIG_INITRD_TAG static void setup_initrd_tag (bd_t *bd, ulong initrd_start, ulong initrd_end);
In message 5BF78BCE8D9BF14A83F836BD9E3916BA23C0C6@blrms.slti.sanyo.co.in you wrote:
Sorry i had generated the patch from with uboot/lib_arm directory and hence i think it failed. now i have created the diff for the root directory where the uboot-1.3.3 folder resides. sorry for the trouble.=20
Applied manually after fixing format problems (see previous message). Thanks.
Gururaja Hebbar K R
