[U-Boot] [PATCH] ColdFire: Fix M5329EVB and M5373EVB nand issue
Fix compilation issue caused by a few mismatches. Provide proper nand chip select enable/disable in nand_hwcontrol() rather than in board_nand_init() just enable once. Remove redundant local nand driver functions - nand_read_byte(), nand_write_byte() and nand_dev_ready() to use common nand driver.
Signed-off-by: TsiChung Liew Tsi-Chung.Liew@freescale.com --- board/freescale/m5329evb/nand.c | 57 +++++++++++++------------------------- board/freescale/m5373evb/nand.c | 17 +++++++---- 2 files changed, 31 insertions(+), 43 deletions(-)
diff --git a/board/freescale/m5329evb/nand.c b/board/freescale/m5329evb/nand.c index 82492f6..cf27dda 100644 --- a/board/freescale/m5329evb/nand.c +++ b/board/freescale/m5329evb/nand.c @@ -36,56 +36,42 @@ DECLARE_GLOBAL_DATA_PTR; #include <linux/mtd/mtd.h>
#define SET_CLE 0x10 -#define CLR_CLE ~SET_CLE #define SET_ALE 0x08 -#define CLR_ALE ~SET_ALE
-static void nand_hwcontrol(struct mtd_info *mtd, int cmd, unsigned int ctrl) +static void nand_hwcontrol(struct mtd_info *mtdinfo, int cmd, unsigned int ctrl) { struct nand_chip *this = mtdinfo->priv; -/* volatile fbcs_t *fbcs = (fbcs_t *) MMAP_FBCS; TODO: handle wp */ - u32 nand_baseaddr = (u32) this->IO_ADDR_W; + volatile u16 *nCE = (u16 *) CONFIG_SYS_LATCH_ADDR;
if (ctrl & NAND_CTRL_CHANGE) { - if ( ctrl & NAND_CLE ) - nand_baseaddr |= SET_CLE; - else - nand_baseaddr &= CLR_CLE; - if ( ctrl & NAND_ALE ) - nand_baseaddr |= SET_ALE; - else - nand_baseaddr &= CLR_ALE; - } - this->IO_ADDR_W = (void __iomem *)(nand_baseaddr); + ulong IO_ADDR_W = (ulong) this->IO_ADDR_W;
- if (cmd != NAND_CMD_NONE) - writeb(cmd, this->IO_ADDR_W); -} + IO_ADDR_W &= ~(SET_ALE | SET_CLE); + *nCE &= 0xFFFB;
-static void nand_write_byte(struct mtd_info *mtdinfo, u_char byte) -{ - struct nand_chip *this = mtdinfo->priv; - *((volatile u8 *)(this->IO_ADDR_W)) = byte; -} + if (ctrl & NAND_NCE) + *nCE |= 0x0004; + if (ctrl & NAND_CLE) + IO_ADDR_W |= SET_CLE; + if (ctrl & NAND_ALE) + IO_ADDR_W |= SET_ALE;
-static u8 nand_read_byte(struct mtd_info *mtdinfo) -{ - struct nand_chip *this = mtdinfo->priv; - return (u8) (*((volatile u8 *)this->IO_ADDR_R)); -} + this->IO_ADDR_W = (void *)IO_ADDR_W; + }
-static int nand_dev_ready(struct mtd_info *mtdinfo) -{ - return 1; + if (cmd != NAND_CMD_NONE) + writeb(cmd, this->IO_ADDR_W); }
int board_nand_init(struct nand_chip *nand) { volatile gpio_t *gpio = (gpio_t *) MMAP_GPIO;
- *((volatile u16 *)CONFIG_SYS_LATCH_ADDR) |= 0x0004; - - /* set up pin configuration */ + /* + * set up pin configuration - enabled 2nd output buffer's signals + * (nand_ngpio - nCE USB1/2_PWR_EN, LATCH_GPIOs, LCD_VEEEN, etc) + * to use nCE signal + */ gpio->par_timer &= ~GPIO_PAR_TIN3_TIN3; gpio->pddr_timer |= 0x08; gpio->ppd_timer |= 0x08; @@ -95,9 +81,6 @@ int board_nand_init(struct nand_chip *nand) nand->chip_delay = 50; nand->ecc.mode = NAND_ECC_SOFT; nand->cmd_ctrl = nand_hwcontrol; - nand->read_byte = nand_read_byte; - nand->write_byte = nand_write_byte; - nand->dev_ready = nand_dev_ready;
return 0; } diff --git a/board/freescale/m5373evb/nand.c b/board/freescale/m5373evb/nand.c index d01b819..3ebef05 100644 --- a/board/freescale/m5373evb/nand.c +++ b/board/freescale/m5373evb/nand.c @@ -41,19 +41,21 @@ DECLARE_GLOBAL_DATA_PTR; static void nand_hwcontrol(struct mtd_info *mtdinfo, int cmd, unsigned int ctrl) { struct nand_chip *this = mtdinfo->priv; - volatile fbcs_t *fbcs = (fbcs_t *) MMAP_FBCS; - u32 nand_baseaddr = (u32) this->IO_ADDR_W; + volatile u16 *nCE = (u16 *) CONFIG_SYS_LATCH_ADDR;
if (ctrl & NAND_CTRL_CHANGE) { ulong IO_ADDR_W = (ulong) this->IO_ADDR_W; - IO_ADDR_W &= ~(SET_ALE | SE_CLE);
+ IO_ADDR_W &= ~(SET_ALE | SET_CLE); + *nCE &= 0xFFFB; + + if (ctrl & NAND_NCE) + *nCE |= 0x0004; if (ctrl & NAND_CLE) IO_ADDR_W |= SET_CLE; if (ctrl & NAND_ALE) IO_ADDR_W |= SET_ALE;
- at91_set_gpio_value(AT91_PIN_PD15, !(ctrl & NAND_NCE)); this->IO_ADDR_W = (void *)IO_ADDR_W;
} @@ -67,10 +69,13 @@ int board_nand_init(struct nand_chip *nand) volatile gpio_t *gpio = (gpio_t *) MMAP_GPIO; volatile fbcs_t *fbcs = (fbcs_t *) MMAP_FBCS;
- *((volatile u16 *)CONFIG_SYS_LATCH_ADDR) |= 0x0004; fbcs->csmr2 &= ~FBCS_CSMR_WP;
Tsi-Chung Liew
