[PATCH v4 0/1] efi: Minor improvements for the EFI app
This series collects a few fixes and improvements useful when booting U-Boot as an EFI app.
Changes in v4: - Create a new file inside lib/efi instead of board/
Changes in v2: - Drop duplicate acpi_xsdt patch - Put the board_early_init_r code into board/
Simon Glass (1): efi: Avoid using dm_scan_other()
configs/efi-x86_app64_defconfig | 1 + lib/efi/Makefile | 2 +- lib/efi/efi_app.c | 187 ----------------------------- lib/efi/efi_app_init.c | 205 ++++++++++++++++++++++++++++++++ 4 files changed, 207 insertions(+), 188 deletions(-) create mode 100644 lib/efi/efi_app_init.c
This function is defined by bootstd so using it precludes using that feature. Use the board_early_init_r() feature instead.
Nove the affected code into a new file, so that it is clear that this relates to board init.
diff --git a/configs/efi-x86_app64_defconfig b/configs/efi-x86_app64_defconfig index 14b5cd0fa0ee..ed0506fe25cb 100644 --- a/configs/efi-x86_app64_defconfig +++ b/configs/efi-x86_app64_defconfig @@ -17,6 +17,7 @@ CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="ext2load scsi 0:3 01000000 /boot/vmlinuz; zboot 01000000" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_BOARD_EARLY_INIT_R=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PBSIZE=532 CONFIG_CMD_BOOTZ=y diff --git a/lib/efi/Makefile b/lib/efi/Makefile index a790d2d554cd..232fa684360e 100644 --- a/lib/efi/Makefile +++ b/lib/efi/Makefile @@ -2,7 +2,7 @@ # # (C) Copyright 2015 Google, Inc
-obj-$(CONFIG_EFI_APP) += efi_app.o efi.o +obj-$(CONFIG_EFI_APP) += efi_app.o efi.o efi_app_init.o obj-$(CONFIG_EFI_STUB) += efi_info.o
CFLAGS_REMOVE_efi_stub.o := -mregparm=3 \ diff --git a/lib/efi/efi_app.c b/lib/efi/efi_app.c index c5eb816655ea..e79fa5dad176 100644 --- a/lib/efi/efi_app.c +++ b/lib/efi/efi_app.c @@ -68,49 +68,6 @@ int efi_get_mmap(struct efi_mem_desc **descp, int *sizep, uint *keyp, return 0; }
-/** - * efi_bind_block() - bind a new block device to an EFI device - * - * Binds a new top-level EFI_MEDIA device as well as a child block device so - * that the block device can be accessed in U-Boot. - * - * The device can then be accessed using 'part list efi 0', 'fat ls efi 0:1', - * for example, just like any other interface type. - * - * @handle: handle of the controller on which this driver is installed - * @blkio: block io protocol proxied by this driver - * @device_path: EFI device path structure for this - * @len: Length of @device_path in bytes - * @devp: Returns the bound device - * Return: 0 if OK, -ve on error - */ -int efi_bind_block(efi_handle_t handle, struct efi_block_io *blkio, - struct efi_device_path *device_path, int len, - struct udevice **devp) -{ - struct efi_media_plat plat; - struct udevice *dev; - char name[18]; - int ret; - - plat.handle = handle; - plat.blkio = blkio; - plat.device_path = malloc(device_path->length); - if (!plat.device_path) - return log_msg_ret("path", -ENOMEM); - memcpy(plat.device_path, device_path, device_path->length); - ret = device_bind(dm_root(), DM_DRIVER_GET(efi_media), "efi_media", - &plat, ofnode_null(), &dev); - if (ret) - return log_msg_ret("bind", ret); - - snprintf(name, sizeof(name), "efi_media_%x", dev_seq(dev)); - device_set_name(dev, name); - *devp = dev; - - return 0; -} - static efi_status_t setup_memory(struct efi_priv *priv) { struct efi_boot_services *boot = priv->boot; @@ -179,150 +136,6 @@ static void free_memory(struct efi_priv *priv) global_data_ptr = NULL; }
-/** - * devpath_is_partition() - Figure out if a device path is a partition - * - * Checks if a device path refers to a partition on some media device. This - * works by checking for a valid partition number in a hard-driver media device - * as the final component of the device path. - * - * @path: device path - * Return: true if a partition, false if not - * (e.g. it might be media which contains partitions) - */ -static bool devpath_is_partition(const struct efi_device_path *path) -{ - const struct efi_device_path *p; - bool was_part = false; - - for (p = path; p->type != DEVICE_PATH_TYPE_END; - p = (void *)p + p->length) { - was_part = false; - if (p->type == DEVICE_PATH_TYPE_MEDIA_DEVICE && - p->sub_type == DEVICE_PATH_SUB_TYPE_HARD_DRIVE_PATH) { - struct efi_device_path_hard_drive_path *hd = - (void *)path; - - if (hd->partition_number) - was_part = true; - } - } - - return was_part; -} - -/** - * setup_block() - Find all block devices and setup EFI devices for them - * - * Partitions are ignored, since U-Boot has partition handling. Errors with - * particular devices produce a warning but execution continues to try to - * find others. - * - * Return: 0 if found, -ENOSYS if there is no boot-services table, -ENOTSUPP - * if a required protocol is not supported - */ -static int setup_block(void) -{ - efi_guid_t efi_blkio_guid = EFI_BLOCK_IO_PROTOCOL_GUID; - efi_guid_t efi_devpath_guid = EFI_DEVICE_PATH_PROTOCOL_GUID; - efi_guid_t efi_pathutil_guid = EFI_DEVICE_PATH_UTILITIES_PROTOCOL_GUID; - efi_guid_t efi_pathtext_guid = EFI_DEVICE_PATH_TO_TEXT_PROTOCOL_GUID; - struct efi_boot_services *boot = efi_get_boot(); - struct efi_device_path_utilities_protocol *util; - struct efi_device_path_to_text_protocol *text; - struct efi_device_path *path; - struct efi_block_io *blkio; - efi_uintn_t num_handles; - efi_handle_t *handle; - int ret, i; - - if (!boot) - return log_msg_ret("sys", -ENOSYS); - - /* Find all devices which support the block I/O protocol */ - ret = boot->locate_handle_buffer(BY_PROTOCOL, &efi_blkio_guid, NULL, - &num_handles, &handle); - if (ret) - return log_msg_ret("loc", -ENOTSUPP); - log_debug("Found %d handles:\n", (int)num_handles); - - /* We need to look up the path size and convert it to text */ - ret = boot->locate_protocol(&efi_pathutil_guid, NULL, (void **)&util); - if (ret) - return log_msg_ret("util", -ENOTSUPP); - ret = boot->locate_protocol(&efi_pathtext_guid, NULL, (void **)&text); - if (ret) - return log_msg_ret("text", -ENOTSUPP); - - for (i = 0; i < num_handles; i++) { - struct udevice *dev; - const u16 *name; - bool is_part; - int len; - - ret = boot->handle_protocol(handle[i], &efi_devpath_guid, - (void **)&path); - if (ret) { - log_warning("- devpath %d failed (ret=%d)\n", i, ret); - continue; - } - - ret = boot->handle_protocol(handle[i], &efi_blkio_guid, - (void **)&blkio); - if (ret) { - log_warning("- blkio %d failed (ret=%d)\n", i, ret); - continue; - } - - name = text->convert_device_path_to_text(path, true, false); - is_part = devpath_is_partition(path); - - if (!is_part) { - len = util->get_device_path_size(path); - ret = efi_bind_block(handle[i], blkio, path, len, &dev); - if (ret) { - log_warning("- blkio bind %d failed (ret=%d)\n", - i, ret); - continue; - } - } else { - dev = NULL; - } - - /* - * Show the device name if we created one. Otherwise indicate - * that it is a partition. - */ - printf("%2d: %-12s %ls\n", i, dev ? dev->name : "<partition>", - name); - } - boot->free_pool(handle); - - return 0; -} - -/** - * dm_scan_other() - Scan for UEFI devices that should be available to U-Boot - * - * This sets up block devices within U-Boot for those found in UEFI. With this, - * U-Boot can access those devices - * - * @pre_reloc_only: true to only bind pre-relocation devices (ignored) - * Returns: 0 on success, -ve on error - */ -int dm_scan_other(bool pre_reloc_only) -{ - if (gd->flags & GD_FLG_RELOC) { - int ret; - - ret = setup_block(); - if (ret) - return ret; - } - - return 0; -} - static void scan_tables(struct efi_system_table *sys_table) { efi_guid_t acpi = EFI_ACPI_TABLE_GUID; diff --git a/lib/efi/efi_app_init.c b/lib/efi/efi_app_init.c new file mode 100644 index 000000000000..c5e4192fe06c --- /dev/null +++ b/lib/efi/efi_app_init.c @@ -0,0 +1,205 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * EFI-app board implementation + * + * Copyright 2023 Google LLC + * Written by Simon Glass sjg@chromium.org + */ + +#include <dm.h> +#include <efi.h> +#include <efi_api.h> +#include <errno.h> +#include <malloc.h> +#include <asm/global_data.h> +#include <dm/device-internal.h> +#include <dm/root.h> +#include <linux/types.h> + +DECLARE_GLOBAL_DATA_PTR; + +/** + * efi_bind_block() - bind a new block device to an EFI device + * + * Binds a new top-level EFI_MEDIA device as well as a child block device so + * that the block device can be accessed in U-Boot. + * + * The device can then be accessed using 'part list efi 0', 'fat ls efi 0:1', + * for example, just like any other interface type. + * + * @handle: handle of the controller on which this driver is installed + * @blkio: block io protocol proxied by this driver + * @device_path: EFI device path structure for this + * @len: Length of @device_path in bytes + * @devp: Returns the bound device + * Return: 0 if OK, -ve on error + */ +int efi_bind_block(efi_handle_t handle, struct efi_block_io *blkio, + struct efi_device_path *device_path, int len, + struct udevice **devp) +{ + struct efi_media_plat plat; + struct udevice *dev; + char name[18]; + int ret; + + plat.handle = handle; + plat.blkio = blkio; + plat.device_path = malloc(device_path->length); + if (!plat.device_path) + return log_msg_ret("path", -ENOMEM); + memcpy(plat.device_path, device_path, device_path->length); + ret = device_bind(dm_root(), DM_DRIVER_GET(efi_media), "efi_media", + &plat, ofnode_null(), &dev); + if (ret) + return log_msg_ret("bind", ret); + + snprintf(name, sizeof(name), "efi_media_%x", dev_seq(dev)); + device_set_name(dev, name); + *devp = dev; + + return 0; +} + +/** + * devpath_is_partition() - Figure out if a device path is a partition + * + * Checks if a device path refers to a partition on some media device. This + * works by checking for a valid partition number in a hard-driver media device + * as the final component of the device path. + * + * @path: device path + * Return: true if a partition, false if not + * (e.g. it might be media which contains partitions) + */ +static bool devpath_is_partition(const struct efi_device_path *path) +{ + const struct efi_device_path *p; + bool was_part = false; + + for (p = path; p->type != DEVICE_PATH_TYPE_END; + p = (void *)p + p->length) { + was_part = false; + if (p->type == DEVICE_PATH_TYPE_MEDIA_DEVICE && + p->sub_type == DEVICE_PATH_SUB_TYPE_HARD_DRIVE_PATH) { + struct efi_device_path_hard_drive_path *hd = + (void *)path; + + if (hd->partition_number) + was_part = true; + } + } + + return was_part; +} + +/** + * setup_block() - Find all block devices and setup EFI devices for them + * + * Partitions are ignored, since U-Boot has partition handling. Errors with + * particular devices produce a warning but execution continues to try to + * find others. + * + * Return: 0 if found, -ENOSYS if there is no boot-services table, -ENOTSUPP + * if a required protocol is not supported + */ +static int setup_block(void) +{ + efi_guid_t efi_blkio_guid = EFI_BLOCK_IO_PROTOCOL_GUID; + efi_guid_t efi_devpath_guid = EFI_DEVICE_PATH_PROTOCOL_GUID; + efi_guid_t efi_pathutil_guid = EFI_DEVICE_PATH_UTILITIES_PROTOCOL_GUID; + efi_guid_t efi_pathtext_guid = EFI_DEVICE_PATH_TO_TEXT_PROTOCOL_GUID; + struct efi_boot_services *boot = efi_get_boot(); + struct efi_device_path_utilities_protocol *util; + struct efi_device_path_to_text_protocol *text; + struct efi_device_path *path; + struct efi_block_io *blkio; + efi_uintn_t num_handles; + efi_handle_t *handle; + int ret, i; + + if (!boot) + return log_msg_ret("sys", -ENOSYS); + + /* Find all devices which support the block I/O protocol */ + ret = boot->locate_handle_buffer(BY_PROTOCOL, &efi_blkio_guid, NULL, + &num_handles, &handle); + if (ret) + return log_msg_ret("loc", -ENOTSUPP); + log_debug("Found %d handles:\n", (int)num_handles); + + /* We need to look up the path size and convert it to text */ + ret = boot->locate_protocol(&efi_pathutil_guid, NULL, (void **)&util); + if (ret) + return log_msg_ret("util", -ENOTSUPP); + ret = boot->locate_protocol(&efi_pathtext_guid, NULL, (void **)&text); + if (ret) + return log_msg_ret("text", -ENOTSUPP); + + for (i = 0; i < num_handles; i++) { + struct udevice *dev; + const u16 *name; + bool is_part; + int len; + + ret = boot->handle_protocol(handle[i], &efi_devpath_guid, + (void **)&path); + if (ret) { + log_warning("- devpath %d failed (ret=%d)\n", i, ret); + continue; + } + + ret = boot->handle_protocol(handle[i], &efi_blkio_guid, + (void **)&blkio); + if (ret) { + log_warning("- blkio %d failed (ret=%d)\n", i, ret); + continue; + } + + name = text->convert_device_path_to_text(path, true, false); + is_part = devpath_is_partition(path); + + if (!is_part) { + len = util->get_device_path_size(path); + ret = efi_bind_block(handle[i], blkio, path, len, &dev); + if (ret) { + log_warning("- blkio bind %d failed (ret=%d)\n", + i, ret); + continue; + } + } else { + dev = NULL; + } + + /* + * Show the device name if we created one. Otherwise indicate + * that it is a partition. + */ + printf("%2d: %-12s %ls\n", i, dev ? dev->name : "<partition>", + name); + } + boot->free_pool(handle); + + return 0; +} + +/** + * board_early_init_r() - Scan for UEFI devices that should be available + * + * This sets up block devices within U-Boot for those found in UEFI. With this, + * U-Boot can access those devices + * + * Returns: 0 on success, -ve on error + */ +int board_early_init_r(void) +{ + if (gd->flags & GD_FLG_RELOC) { + int ret; + + ret = setup_block(); + if (ret) + return ret; + } + + return 0; +}
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
Changes in v4:
Changes in v2:
- efi_bind_block() - bind a new block device to an EFI device
- Binds a new top-level EFI_MEDIA device as well as a child block device so
- that the block device can be accessed in U-Boot.
- The device can then be accessed using 'part list efi 0', 'fat ls efi 0:1',
- for example, just like any other interface type.
- @handle: handle of the controller on which this driver is installed
- @blkio: block io protocol proxied by this driver
- @device_path: EFI device path structure for this
- @len: Length of @device_path in bytes
- @devp: Returns the bound device
- Return: 0 if OK, -ve on error
- char name[18];
- int ret;
- if (ret)
- *devp = dev;
- devpath_is_partition() - Figure out if a device path is a partition
- Checks if a device path refers to a partition on some media device. This
- works by checking for a valid partition number in a hard-driver media device
- as the final component of the device path.
- @path: device path
- Return: true if a partition, false if not
was_part = false;
(void *)path;
was_part = true;
- return was_part;
- setup_block() - Find all block devices and setup EFI devices for them
- Partitions are ignored, since U-Boot has partition handling. Errors with
- particular devices produce a warning but execution continues to try to
- find others.
- Return: 0 if found, -ENOSYS if there is no boot-services table, -ENOTSUPP
- if a required protocol is not supported
- int ret, i;
- if (!boot)
- if (ret)
- if (ret)
- if (ret)
const u16 *name;
bool is_part;
int len;
(void **)&path);
if (ret) {
continue;
(void **)&blkio);
if (ret) {
continue;
if (!is_part) {
if (ret) {
i, ret);
continue;
} else {
dev = NULL;
name);
- dm_scan_other() - Scan for UEFI devices that should be available to U-Boot
- This sets up block devices within U-Boot for those found in UEFI. With this,
- U-Boot can access those devices
- @pre_reloc_only: true to only bind pre-relocation devices (ignored)
- Returns: 0 on success, -ve on error
int ret;
if (ret)
return ret;
- EFI-app board implementation
- Copyright 2023 Google LLC
- Written by Simon Glass sjg@chromium.org
- char name[18];
- int ret;
- if (ret)
- *devp = dev;
was_part = false;
(void *)path;
was_part = true;
- return was_part;
- find others.
- int ret, i;
- if (!boot)
- if (ret)
- if (ret)
- if (ret)
const u16 *name;
bool is_part;
int len;
(void **)&path);
if (ret) {
continue;
(void **)&blkio);
if (ret) {
continue;
if (!is_part) {
if (ret) {
i, ret);
continue;
} else {
dev = NULL;
name);
- board_early_init_r() - Scan for UEFI devices that should be available
int ret;
if (ret)
return ret;
