[PATCH 1/2] serial: Add riscv_sbi console support
- This patch supports debug serial and console from SBI syscall.
Signed-off-by: Kongou Hikari hikari@nucleisys.com --- drivers/serial/Kconfig | 17 +++++ drivers/serial/Makefile | 1 + drivers/serial/serial_riscv_sbi.c | 104 ++++++++++++++++++++++++++++++ 3 files changed, 122 insertions(+) create mode 100644 drivers/serial/serial_riscv_sbi.c
diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 90e3983170..60dcf9bc9a 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -388,12 +388,20 @@ config DEBUG_UART_MTK driver will be available until the real driver model serial is running.
+ +config DEBUG_UART_RISCV_SBI + bool "RISC-V SBI CONSOLE" + depends on RISCV_SBI_CONSOLE + help + Select this to enable a debug UART using RISC-V SBI console driver. + endchoice
config DEBUG_UART_BASE hex "Base address of UART" depends on DEBUG_UART default 0 if DEBUG_UART_SANDBOX + default 0 if DEBUG_UART_RISCV_SBI help This is the base address of your UART for memory-mapped UARTs.
@@ -404,6 +412,7 @@ config DEBUG_UART_CLOCK int "UART input clock" depends on DEBUG_UART default 0 if DEBUG_UART_SANDBOX + default 0 if DEBUG_UART_RISCV_SBI help The UART input clock determines the speed of the internal UART circuitry. The baud rate is derived from this by dividing the input @@ -481,6 +490,14 @@ config ALTERA_JTAG_UART_BYPASS output will wait forever until a JTAG terminal is connected. If you not are sure, say Y.
+config RISCV_SBI_CONSOLE + bool "RISC-V SBI console support" + depends on RISCV + help + This enables support for console via RISC-V SBI calls. + + If you don't know what do to here, say Y. + config ALTERA_UART bool "Altera UART support" depends on DM_SERIAL diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index e4a92bbbb7..15b2a3ea6f 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -46,6 +46,7 @@ obj-$(CONFIG_MXC_UART) += serial_mxc.o obj-$(CONFIG_PXA_SERIAL) += serial_pxa.o obj-$(CONFIG_MESON_SERIAL) += serial_meson.o obj-$(CONFIG_INTEL_MID_SERIAL) += serial_intel_mid.o +obj-$(CONFIG_RISCV_SBI_CONSOLE) += serial_riscv_sbi.o ifdef CONFIG_SPL_BUILD obj-$(CONFIG_ROCKCHIP_SERIAL) += serial_rockchip.o endif diff --git a/drivers/serial/serial_riscv_sbi.c b/drivers/serial/serial_riscv_sbi.c new file mode 100644 index 0000000000..add11be04e --- /dev/null +++ b/drivers/serial/serial_riscv_sbi.c @@ -0,0 +1,104 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2008 David Gibson, IBM Corporation + * Copyright (C) 2012 Regents of the University of California + * Copyright (C) 2020 Nuclei System Technologies + * Copyright (C) 2020 Ruigang Wan rgwan@nucleisys.com + */ + +#include <common.h> +#include <serial.h> +#include <errno.h> +#include <dm.h> +#include <fdtdec.h> + +#include <asm/sbi.h> + + +#ifdef CONFIG_DEBUG_UART_RISCV_SBI + +#include <debug_uart.h> + + +static inline void _debug_uart_init(void) +{ + //Nothing +} + +static inline void _debug_uart_putc(int ch) +{ + sbi_console_putchar(ch); +} + +DEBUG_UART_FUNCS + +#endif + +static int sbi_tty_pending_char = -1; + +static int sbi_tty_put(struct udevice *dev, const char ch) +{ + + sbi_console_putchar(ch); + + return 0; +} + +static int sbi_tty_get(struct udevice *dev) +{ + int c; + if (sbi_tty_pending_char != -1) + { + c = sbi_tty_pending_char; + sbi_tty_pending_char = -1; + } + else + { + c = sbi_console_getchar(); + if (c < 0) + return -EAGAIN; + } + + return c; +} + +static int sbi_tty_setbrg(struct udevice *dev, int baudrate) +{ + return 0; +} + +static int sbi_tty_pending(struct udevice *dev, bool input) +{ + int c; + if (input) + { + if (sbi_tty_pending_char != -1) + return 1; + + c = sbi_console_getchar(); + if(c < 0) + return 0; + sbi_tty_pending_char = c; + return 1; + } + return 0; +} + +static const struct udevice_id serial_riscv_sbi_ids[] = { + { .compatible = "sbi,console" }, + { } +}; + +const struct dm_serial_ops serial_riscv_sbi_ops = { + .putc = sbi_tty_put, + .pending = sbi_tty_pending, + .getc = sbi_tty_get, + .setbrg = sbi_tty_setbrg, +}; + +U_BOOT_DRIVER(serial_riscv_sbi) = { + .name = "serial_riscv_sbi", + .id = UCLASS_SERIAL, + .of_match = serial_riscv_sbi_ids, + .ops = &serial_riscv_sbi_ops, +};
--- arch/riscv/Kconfig | 4 + arch/riscv/dts/Makefile | 1 + arch/riscv/dts/nuclei-hbird.dts | 132 ++++++++++++++++++++++++++++++++ board/nuclei/hbird/Kconfig | 53 +++++++++++++ board/nuclei/hbird/MAINTAINERS | 6 ++ board/nuclei/hbird/Makefile | 5 ++ board/nuclei/hbird/hbird.c | 27 +++++++ configs/nuclei_hbird_defconfig | 20 +++++ include/configs/nuclei-hbird.h | 46 +++++++++++ 9 files changed, 294 insertions(+) create mode 100644 arch/riscv/dts/nuclei-hbird.dts create mode 100644 board/nuclei/hbird/Kconfig create mode 100644 board/nuclei/hbird/MAINTAINERS create mode 100644 board/nuclei/hbird/Makefile create mode 100644 board/nuclei/hbird/hbird.c create mode 100644 configs/nuclei_hbird_defconfig create mode 100644 include/configs/nuclei-hbird.h
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index fb5fe5afff..b2807c33d7 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -11,6 +11,9 @@ choice config TARGET_AX25_AE350 bool "Support ax25-ae350"
+config TARGET_NUCLEI_HBIRD + bool "Support Nuclei HBird" + config TARGET_MICROCHIP_ICICLE bool "Support Microchip PolarFire-SoC Icicle Board"
@@ -53,6 +56,7 @@ source "board/AndesTech/ax25-ae350/Kconfig" source "board/emulation/qemu-riscv/Kconfig" source "board/microchip/mpfs_icicle/Kconfig" source "board/sifive/fu540/Kconfig" +source "board/nuclei/hbird/Kconfig"
# platform-specific options below source "arch/riscv/cpu/ax25/Kconfig" diff --git a/arch/riscv/dts/Makefile b/arch/riscv/dts/Makefile index 4f30e6936f..da86846f11 100644 --- a/arch/riscv/dts/Makefile +++ b/arch/riscv/dts/Makefile @@ -2,6 +2,7 @@
dtb-$(CONFIG_TARGET_AX25_AE350) += ae350_32.dtb ae350_64.dtb dtb-$(CONFIG_TARGET_SIFIVE_FU540) += hifive-unleashed-a00.dtb +dtb-$(CONFIG_TARGET_NUCLEI_HBIRD) += nuclei-hbird.dtb
targets += $(dtb-y)
diff --git a/arch/riscv/dts/nuclei-hbird.dts b/arch/riscv/dts/nuclei-hbird.dts new file mode 100644 index 0000000000..39d76b63ba --- /dev/null +++ b/arch/riscv/dts/nuclei-hbird.dts @@ -0,0 +1,132 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +/* Copyright (c) 22020 Nuclei System Technologies */ + +/* Clock frequency (in Hz) of the PCB crystal for rtcclk */ +#define RTCCLK_FREQ 32768 + +/dts-v1/; + +/ { + #address-cells = <2>; + #size-cells = <2>; + compatible = "nuclei,ux600"; + model = "nuclei,ux600"; + + chosen { + bootargs = "earlycon=sbi"; + stdout-path = "serial0"; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + timebase-frequency = <RTCCLK_FREQ>; + cpu0: cpu@0 { + device_type = "cpu"; + reg = <0>; + status = "okay"; + compatible = "riscv"; + riscv,isa = "rv64imac"; + mmu-type = "riscv,sv39"; + clock-frequency = <8000000>; + cpu0_intc: interrupt-controller { + #interrupt-cells = <1>; + interrupt-controller; + compatible = "riscv,cpu-intc"; + }; + }; + }; + + memory@A0000000 { + device_type = "memory"; + reg = <0x0 0xA0000000 0x0 0x10000000>; + }; + + soc { + #address-cells = <2>; + #size-cells = <2>; + compatible = "nuclei,ux600", "simple-bus"; + ranges; + }; + + hfclk: hfclk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <8000000>; + clock-output-names = "hfclk"; + }; + + console { + u-boot,dm-pre-reloc; + compatible = "sbi,console"; + }; + + plic0: interrupt-controller@8000000 { + #interrupt-cells = <1>; + compatible = "riscv,plic0"; + interrupt-controller; + riscv,ndev = <53>; + interrupts-extended = + <&cpu0_intc 11 &cpu0_intc 9>; + reg = <0x0 0x8000000 0x0 0x4000000>; + }; + + uart0: serial@10013000 { + compatible = "sifive,uart0"; + reg = <0x0 0x10013000 0x0 0x1000>; + interrupt-parent = <&plic0>; + interrupts = <4>; + status = "disabled"; + }; + + uart1: serial@10023000 { + compatible = "sifive,uart0"; + reg = <0x0 0x10023000 0x0 0x1000>; + interrupt-parent = <&plic0>; + interrupts = <5>; + status = "okay"; + }; + + qspi0: spi@10014000 { + compatible = "sifive,spi0"; + reg = <0x0 0x10014000 0x0 0x1000>; + #interrupt-parent = <&plic0>; + #interrupts = <51>; + clocks = <&hfclk>; + num-cs = <1>; + #address-cells = <1>; + #size-cells = <0>; + status = "okay"; + + flash@0 { + compatible = "gd25q32", "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <1000000>; + // m25p,fast-read; + #spi-tx-bus-width = <1>; + #spi-rx-bus-width = <1>; + }; + }; + + qspi2: spi@10034000 { + compatible = "sifive,spi0"; + reg = <0x0 0x10034000 0x0 0x1000>; + #interrupt-parent = <&plic0>; + #interrupts = <6>; + clocks = <&hfclk>; + num-cs = <1>; + #address-cells = <1>; + #size-cells = <0>; + status = "okay"; + + mmc@0 { + compatible = "mmc-spi-slot"; + reg = <0>; + spi-max-frequency = <8000000>; + voltage-ranges = <3300 3300>; + disable-wp; + }; + }; + + +}; diff --git a/board/nuclei/hbird/Kconfig b/board/nuclei/hbird/Kconfig new file mode 100644 index 0000000000..697182ba02 --- /dev/null +++ b/board/nuclei/hbird/Kconfig @@ -0,0 +1,53 @@ +if TARGET_NUCLEI_HBIRD + +config SYS_BOARD + default "hbird" + +config SYS_VENDOR + default "nuclei" + +config SYS_CPU + default "generic" + +config SYS_CONFIG_NAME + default "nuclei-hbird" + +config SYS_TEXT_BASE + default 0xA0000000 if !RISCV_SMODE + default 0xA0200000 if RISCV_SMODE + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + select GENERIC_RISCV + imply CMD_DHCP + imply CMD_EXT2 + imply CMD_EXT4 + imply CMD_FAT + imply CMD_FS_GENERIC + imply CMD_NET + imply CMD_PING + imply CMD_SF + imply CLK_SIFIVE + imply CLK_SIFIVE_FU540_PRCI + imply DOS_PARTITION + imply IP_DYN + imply MACB + imply MII + imply NET_RANDOM_ETHADDR + imply PHY_LIB + imply PHY_MSCC + imply SIFIVE_SERIAL + imply SPI + imply SPI_SIFIVE + imply SPI_FLASH + imply SPI_FLASH_ISSI + imply MMC + imply MMC_SPI + imply MMC_BROKEN_CD + imply CMD_MMC + imply DM_GPIO + imply SIFIVE_GPIO + imply CMD_GPIO + imply SMP + +endif diff --git a/board/nuclei/hbird/MAINTAINERS b/board/nuclei/hbird/MAINTAINERS new file mode 100644 index 0000000000..c88e1286f0 --- /dev/null +++ b/board/nuclei/hbird/MAINTAINERS @@ -0,0 +1,6 @@ +Nuclei HBird Platform +M: Ruigang Wan rgwan@nucleisys.com +S: Maintained +F: board/nuclei/hbird/ +F: include/configs/nuclei-hbird.h +F: configs/hbird_defconfig diff --git a/board/nuclei/hbird/Makefile b/board/nuclei/hbird/Makefile new file mode 100644 index 0000000000..aa76c44da5 --- /dev/null +++ b/board/nuclei/hbird/Makefile @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (c) 2020 Nuclei System Technologies + +obj-y += hbird.o diff --git a/board/nuclei/hbird/hbird.c b/board/nuclei/hbird/hbird.c new file mode 100644 index 0000000000..7c8250b474 --- /dev/null +++ b/board/nuclei/hbird/hbird.c @@ -0,0 +1,27 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2019 Nuclei System Technologies + * + * Authors: + * Ruigang Wan rgwan@nucleisys.com + */ + +#include <common.h> +#include <dm.h> +#include <linux/delay.h> +#include <linux/io.h> + + +int board_init(void) +{ + /* Set Pinmux to enable QSPI2 for SD boot */ + writel (0x01, (void *)0x10034000); + writel (0xec000000, (void *)0x10012008); + writel (0x10000000, (void *)0x10012004); + writel (0xfc030000, (void *)0x10012038); + writel (0x00, (void *)0x10034000); /* NUSPI Prescaler = 4 */ + __asm__ __volatile__ ("fence w,o" : : : "memory"); + + printf ("Board: Initialized\n"); + return 0; +} diff --git a/configs/nuclei_hbird_defconfig b/configs/nuclei_hbird_defconfig new file mode 100644 index 0000000000..2c4607aaae --- /dev/null +++ b/configs/nuclei_hbird_defconfig @@ -0,0 +1,20 @@ +CONFIG_RISCV=y +CONFIG_ENV_SIZE=0x20000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_TARGET_NUCLEI_HBIRD=y +CONFIG_ARCH_RV64I=y +CONFIG_RISCV_SMODE=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_MISC_INIT_R=n +CONFIG_RISCV_SBI_CONSOLE=y +CONFIG_SBI_V01=y +CONFIG_DISPLAY_CPUINFO=y +CONFIG_DISPLAY_BOARDINFO=y +CONFIG_OF_BOARD_FIXUP=y +CONFIG_DEFAULT_DEVICE_TREE="nuclei-hbird" +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_DM_MTD=y +CONFIG_CMD_SPI=y +CONFIG_FAT_WRITE=y + diff --git a/include/configs/nuclei-hbird.h b/include/configs/nuclei-hbird.h new file mode 100644 index 0000000000..51134adaf9 --- /dev/null +++ b/include/configs/nuclei-hbird.h @@ -0,0 +1,46 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2020 Nuclei System Technology + * + * Authors: + * Ruigang Wan rgwan@nucleisys.com + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <linux/sizes.h> + +#define CONFIG_SYS_SDRAM_BASE 0xA0000000 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + SZ_2M) + +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + SZ_2M) + +#define CONFIG_SYS_MALLOC_LEN SZ_8M + +#define CONFIG_SYS_BOOTM_LEN SZ_64M + +#define CONFIG_STANDALONE_LOAD_ADDR 0xA0200000 + +/* Environment options */ + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) + +#include <config_distro_bootcmd.h> + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "fdt_high=0xffffffffffffffff\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "kernel_addr_r=0xA4000000\0" \ + "fdt_addr_r=0xA8000000\0" \ + "scriptaddr=0xA8100000\0" \ + "pxefile_addr_r=0xA8200000\0" \ + "ramdisk_addr_r=0xA8300000\0" \ + BOOTENV + +#define CONFIG_PREBOOT \ + "setenv fdt_addr ${fdtcontroladdr};" \ + "fdt addr ${fdtcontroladdr};" + +#endif /* __CONFIG_H */
On Wed, May 20, 2020 at 7:15 PM Kongou Hikari hikari@nucleisys.com wrote:
Please add commit message to have a brief introduction of this new board.
Please insert this by following the alphabetical order
ditto
targets += $(dtb-y)
+/dts-v1/;
- #address-cells = <2>;
- #size-cells = <2>;
- compatible = "nuclei,ux600";
- model = "nuclei,ux600";
The indentation looks wrong. Needs to have tab for a level of indentation.
- chosen {
- cpus {
- #address-cells = <1>;
- #size-cells = <0>;
- timebase-frequency = <RTCCLK_FREQ>;
- cpu0: cpu@0 {
reg = <0>;
status = "okay";
- memory@A0000000 {
- device_type = "memory";
- reg = <0x0 0xA0000000 0x0 0x10000000>;
- soc {
- compatible = "nuclei,ux600", "simple-bus";
- ranges;
hfclk: hfclk {
#clock-cells = <0>;
- console {
- plic0: interrupt-controller@8000000 {
riscv,ndev = <53>;
interrupts = <4>;
interrupts = <5>;
status = "okay";
#interrupts = <51>;
clocks = <&hfclk>;
num-cs = <1>;
#size-cells = <0>;
status = "okay";
flash@0 {
reg = <0>;
// m25p,fast-read;
Why is this commented out?
#interrupts = <6>;
clocks = <&hfclk>;
num-cs = <1>;
#size-cells = <0>;
status = "okay";
mmc@0 {
reg = <0>;
disable-wp;
+config SYS_BOARD
default "hbird"
+config SYS_VENDOR
default "nuclei"
+config SYS_CPU
default "generic"
Does this board run U-Boot under which mode? Or both modes?
def_bool y
imply CMD_DHCP
imply CMD_EXT2
imply CMD_EXT4
imply CMD_FAT
imply CMD_NET
imply CMD_PING
imply CMD_SF
imply CLK_SIFIVE
imply DOS_PARTITION
imply IP_DYN
imply MACB
imply MII
imply PHY_LIB
imply PHY_MSCC
imply SIFIVE_SERIAL
imply SPI
imply SPI_SIFIVE
imply SPI_FLASH
imply MMC
imply MMC_SPI
imply MMC_BROKEN_CD
imply CMD_MMC
imply DM_GPIO
imply SIFIVE_GPIO
imply CMD_GPIO
imply SMP
- Copyright (c) 2019 Nuclei System Technologies
- Authors:
- Ruigang Wan rgwan@nucleisys.com
Please do not use hardcoded magic numbers.
This should probably be turned to a debug output.
Can we switch to SBI_V02?
- Copyright (c) 2020 Nuclei System Technology
- Authors:
func(MMC, mmc, 0)
BOOTENV
Regards, Bin
The SBI calls sbi_console_getchar & sbi_console_putchar are marked as legacy calls, and in U-Boot we default to use SBI v0.2
There is not a big value of adding that to the mainline IMHO.
Regards, Bin
There are a couple instances where your code is not formatted in the correct style [1]. You can use tools/checkpatch.pl to help you fix these.
[1] https://www.denx.de/wiki/U-Boot/CodingStyle
- bool "RISC-V SBI CONSOLE"
- depends on RISCV_SBI_CONSOLE
- help
endchoice
- default 0 if DEBUG_UART_RISCV_SBI help This is the base address of your UART for memory-mapped UARTs.
- default 0 if DEBUG_UART_RISCV_SBI help The UART input clock determines the speed of the internal UART circuitry. The baud rate is derived from this by dividing the input
- bool "RISC-V SBI console support"
- depends on RISCV
- help
- Copyright (C) 2008 David Gibson, IBM Corporation
- Copyright (C) 2012 Regents of the University of California
- Copyright (C) 2020 Nuclei System Technologies
- Copyright (C) 2020 Ruigang Wan rgwan@nucleisys.com
The following includes should be sorted alphabetially
I believe it's conventional to put the debug uart at the end of a file.
This include should probably be at the top and outside of this ifdef.
Don't use C++-style comments, except in SPDX identifiers.
- //Nothing
- sbi_console_putchar(ch);
+DEBUG_UART_FUNCS
- int c;
There should be a blank line here.
- if (sbi_tty_pending_char != -1)
Opening braces go on the same line as statement; the only exception are functions. For example,
if (foo) {
} else {
- else
if (c < 0)
return -EAGAIN;
- return c;
- int c;
- if (input)
return 1;
if(c < 0)
return 1;
- { .compatible = "sbi,console" },
This should also be static.
- .putc = sbi_tty_put,
- .pending = sbi_tty_pending,
- .getc = sbi_tty_get,
- .setbrg = sbi_tty_setbrg,
- .name = "serial_riscv_sbi",
- .id = UCLASS_SERIAL,
- .of_match = serial_riscv_sbi_ids,
- .ops = &serial_riscv_sbi_ops,
--Sean
Bin Meng
Kongou Hikari
Sean Anderson
