[U-Boot] [PATCH][v2] driver: net: fsl-mc: Memset MC reserve ram memory before usage
It is required to clean Management Complex reserve memory before any usage. So memset MC reserve memory.
Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com --- Changes for v2: - updated patch subject - Consider case of dpl apply and mc_boot failure
drivers/net/fsl-mc/mc.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/drivers/net/fsl-mc/mc.c b/drivers/net/fsl-mc/mc.c index 940025a467..16ee0b34b9 100644 --- a/drivers/net/fsl-mc/mc.c +++ b/drivers/net/fsl-mc/mc.c @@ -2,6 +2,7 @@ /* * Copyright 2014 Freescale Semiconductor, Inc. * Copyright 2017 NXP + * Copyright 2017-2018 NXP */ #include <common.h> #include <errno.h> @@ -29,6 +30,7 @@ #define MC_BOOT_ENV_VAR "mcinitcmd"
DECLARE_GLOBAL_DATA_PTR; +static int mc_memset_resv_ram; static int mc_boot_status = -1; static int mc_dpl_applied = -1; #ifdef CONFIG_SYS_LS_MC_DRAM_AIOP_IMG_OFFSET @@ -810,6 +812,11 @@ u64 mc_get_dram_addr(void) { size_t mc_ram_size = mc_get_dram_block_size();
+ if (!mc_memset_resv_ram || get_mc_boot_status()) { + mc_memset_resv_ram = 1; + memset((void *)gd->arch.resv_ram, 0, mc_ram_size); + } + return (gd->arch.resv_ram + mc_ram_size - 1) & MC_RAM_BASE_ADDR_ALIGNMENT_MASK; }
Prabhakar Kushwaha
