ddr: Rework errata A008109, A008378, 009942 workaround
Move errata A008109, A008378, 009942 workaround implementation from compute_fsl_memctl_config_regs() to fsl_ddr_set_memctl_regs() and add register write after each workaround implementation.
Signed-off-by: Jaiprakash Singh Jaiprakash.singh@nxp.com Signed-off-by: Priyanka Jain priyanka.jain@nxp.com --- Tested on T1040D4RDB, T1023RDB and T1024RDB. Depends on https://patchwork.ozlabs.org/project/uboot/patch/20191120160734.11300-1-joak... --- arch/powerpc/cpu/mpc85xx/Kconfig | 4 +++ drivers/ddr/fsl/ctrl_regs.c | 64 +------------------------------------- drivers/ddr/fsl/fsl_ddr_gen4.c | 54 +++++++++++++++++++++++++++++++- drivers/ddr/fsl/mpc85xx_ddr_gen3.c | 54 +++++++++++++++++++++++++++++++- 4 files changed, 111 insertions(+), 65 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/Kconfig b/arch/powerpc/cpu/mpc85xx/Kconfig index 5bd69d5..285cc56 100644 --- a/arch/powerpc/cpu/mpc85xx/Kconfig +++ b/arch/powerpc/cpu/mpc85xx/Kconfig @@ -996,6 +996,7 @@ config ARCH_T1023 select FSL_LAW select SYS_FSL_DDR_VER_50 select SYS_FSL_ERRATUM_A008378 + select SYS_FSL_ERRATUM_A008109 select SYS_FSL_ERRATUM_A009663 select SYS_FSL_ERRATUM_A009942 select SYS_FSL_ERRATUM_ESDHC111 @@ -1016,6 +1017,7 @@ config ARCH_T1024 select FSL_LAW select SYS_FSL_DDR_VER_50 select SYS_FSL_ERRATUM_A008378 + select SYS_FSL_ERRATUM_A008109 select SYS_FSL_ERRATUM_A009663 select SYS_FSL_ERRATUM_A009942 select SYS_FSL_ERRATUM_ESDHC111 @@ -1091,6 +1093,7 @@ config ARCH_T2080 select SYS_FSL_ERRATUM_A007212 select SYS_FSL_ERRATUM_A007815 select SYS_FSL_ERRATUM_A007907 + select SYS_FSL_ERRATUM_A008109 select SYS_FSL_ERRATUM_A009942 select SYS_FSL_ERRATUM_ESDHC111 select FSL_PCIE_RESET @@ -1169,6 +1172,7 @@ config ARCH_T4240 select SYS_FSL_ERRATUM_A007798 select SYS_FSL_ERRATUM_A007815 select SYS_FSL_ERRATUM_A007907 + select SYS_FSL_ERRATUM_A008109 select SYS_FSL_ERRATUM_A009942 select SYS_FSL_HAS_DDR3 select SYS_FSL_HAS_SEC diff --git a/drivers/ddr/fsl/ctrl_regs.c b/drivers/ddr/fsl/ctrl_regs.c index 0e98ba4..c849ef3 100644 --- a/drivers/ddr/fsl/ctrl_regs.c +++ b/drivers/ddr/fsl/ctrl_regs.c @@ -1,7 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2008-2016 Freescale Semiconductor, Inc. - * Copyright 2017-2018 NXP Semiconductor + * Copyright 2017-2020 NXP Semiconductor */
/* @@ -2363,38 +2363,6 @@ compute_fsl_memctl_config_regs(const unsigned int ctrl_num, unsigned int ip_rev = 0; unsigned int unq_mrs_en = 0; int cs_en = 1; -#ifdef CONFIG_SYS_FSL_ERRATUM_A009942 - unsigned int ddr_freq; -#endif -#if (defined(CONFIG_SYS_FSL_ERRATUM_A008378) && \ - defined(CONFIG_SYS_FSL_DDRC_GEN4)) || \ - defined(CONFIG_SYS_FSL_ERRATUM_A009942) - struct ccsr_ddr __iomem *ddrc; - - switch (ctrl_num) { - case 0: - ddrc = (void *)CONFIG_SYS_FSL_DDR_ADDR; - break; -#if defined(CONFIG_SYS_FSL_DDR2_ADDR) && (CONFIG_SYS_NUM_DDR_CTLRS > 1) - case 1: - ddrc = (void *)CONFIG_SYS_FSL_DDR2_ADDR; - break; -#endif -#if defined(CONFIG_SYS_FSL_DDR3_ADDR) && (CONFIG_SYS_NUM_DDR_CTLRS > 2) - case 2: - ddrc = (void *)CONFIG_SYS_FSL_DDR3_ADDR; - break; -#endif -#if defined(CONFIG_SYS_FSL_DDR4_ADDR) && (CONFIG_SYS_NUM_DDR_CTLRS > 3) - case 3: - ddrc = (void *)CONFIG_SYS_FSL_DDR4_ADDR; - break; -#endif - default: - printf("%s unexpected ctrl_num = %u\n", __func__, ctrl_num); - return 1; - } -#endif
memset(ddr, 0, sizeof(fsl_ddr_cfg_regs_t));
@@ -2615,37 +2583,7 @@ compute_fsl_memctl_config_regs(const unsigned int ctrl_num, ddr->debug[2] |= 0x00000200; /* set bit 22 */ #endif
-#if defined(CONFIG_SYS_FSL_ERRATUM_A008378) && defined(CONFIG_SYS_FSL_DDRC_GEN4) - /* Erratum applies when accumulated ECC is used, or DBI is enabled */ -#define IS_ACC_ECC_EN(v) ((v) & 0x4) -#define IS_DBI(v) ((((v) >> 12) & 0x3) == 0x2) - if (has_erratum_a008378()) { - if (IS_ACC_ECC_EN(ddr->ddr_sdram_cfg) || - IS_DBI(ddr->ddr_sdram_cfg_3)) { - ddr->debug[28] = ddr_in32(&ddrc->debug[28]); - ddr->debug[28] |= (0x9 << 20); - } - } -#endif - -#ifdef CONFIG_SYS_FSL_ERRATUM_A008109 - ddr->ddr_sdram_cfg_2 = ddr_in32(&ddr->ddr_sdram_cfg_2) | 0x800; /* DDR_SLOW */ - ddr->debug[18] = ddr_in32(&ddrc->debug[18]) | 0x2; - ddr->debug[28] = 0x30000000; -#endif - #ifdef CONFIG_SYS_FSL_ERRATUM_A009942 - ddr_freq = get_ddr_freq(ctrl_num) / 1000000; - ddr->debug[28] |= ddr_in32(&ddrc->debug[28]); - ddr->debug[28] &= 0xff0fff00; - if (ddr_freq <= 1333) - ddr->debug[28] |= 0x0080006a; - else if (ddr_freq <= 1600) - ddr->debug[28] |= 0x0070006f; - else if (ddr_freq <= 1867) - ddr->debug[28] |= 0x00700076; - else if (ddr_freq <= 2133) - ddr->debug[28] |= 0x0060007b; if (popts->cpo_sample) ddr->debug[28] = (ddr->debug[28] & 0xffffff00) | popts->cpo_sample; diff --git a/drivers/ddr/fsl/fsl_ddr_gen4.c b/drivers/ddr/fsl/fsl_ddr_gen4.c index eab5b82..e43c680 100644 --- a/drivers/ddr/fsl/fsl_ddr_gen4.c +++ b/drivers/ddr/fsl/fsl_ddr_gen4.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2014-2015 Freescale Semiconductor, Inc. + * Copyright 2014-2020 Freescale Semiconductor, Inc. */
#include <common.h> @@ -73,6 +73,15 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, #ifdef CONFIG_FSL_DDR_BIST char buffer[CONFIG_SYS_CBSIZE]; #endif +#if defined(CONFIG_SYS_FSL_ERRATUM_A009942) || \ + (defined(CONFIG_SYS_FSL_ERRATUM_A008378) && \ + defined(CONFIG_SYS_FSL_DDRC_GEN4)) || \ + defined(CONFIG_SYS_FSL_ERRATUM_A008109) + u32 val32; +#endif +#ifdef CONFIG_SYS_FSL_ERRATUM_A009942 + unsigned int ddr_freq; +#endif switch (ctrl_num) { case 0: ddr = (void *)CONFIG_SYS_FSL_DDR_ADDR; @@ -437,6 +446,49 @@ step2: ddr_out32(&ddr->sdram_cfg_2, regs->ddr_sdram_cfg_2); #endif
+#if defined(CONFIG_SYS_FSL_ERRATUM_A008378) && defined(CONFIG_SYS_FSL_DDRC_GEN4) + /* Erratum applies when accumulated ECC is used, or DBI is enabled */ +#define IS_ACC_ECC_EN(v) ((v) & 0x4) +#define IS_DBI(v) ((((v) >> 12) & 0x3) == 0x2) + if (has_erratum_a008378()) { + if (IS_ACC_ECC_EN(regs->ddr_sdram_cfg) || + IS_DBI(regs->ddr_sdram_cfg_3)) { + val32 = ddr_in32(&ddr->debug[28]); + val32 |= (0x9 << 20); + ddr_out32(&ddr->debug[28], val32); + } + debug("Applied errata CONFIG_SYS_FSL_ERRATUM_A008378\n"); + } +#endif + +#if defined(CONFIG_SYS_FSL_ERRATUM_A008109) + val32 = ddr_in32(&ddr->sdram_cfg_2) | 0x800; /* DDR_SLOW */ + ddr_out32(&ddr->sdram_cfg_2, val32); + + val32 = ddr_in32(&ddr->debug[18]) | 0x2; + ddr_out32(&ddr->debug[18], val32); + + ddr_out32(&ddr->debug[28], 0x30000000); + debug("Applied errta CONFIG_SYS_FSL_ERRATUM_A008109\n"); +#endif + +#ifdef CONFIG_SYS_FSL_ERRATUM_A009942 + ddr_freq = get_ddr_freq(ctrl_num) / 1000000; + val32 = ddr_in32(&ddr->debug[28]); + val32 &= 0xff0fff00; + if (ddr_freq <= 1333) + val32 |= 0x0080006a; + else if (ddr_freq <= 1600) + val32 |= 0x0070006f; + else if (ddr_freq <= 1867) + val32 |= 0x00700076; + else if (ddr_freq <= 2133) + val32 |= 0x0060007b; + + ddr_out32(&ddr->debug[28], val32); + debug("Applied errata CONFIG_SYS_FSL_ERRATUM_A009942\n"); +#endif + total_gb_size_per_controller = 0; for (i = 0; i < CONFIG_CHIP_SELECTS_PER_CTRL; i++) { if (!(regs->cs[i].config & 0x80000000)) diff --git a/drivers/ddr/fsl/mpc85xx_ddr_gen3.c b/drivers/ddr/fsl/mpc85xx_ddr_gen3.c index ab8d2de..1ed4d50 100644 --- a/drivers/ddr/fsl/mpc85xx_ddr_gen3.c +++ b/drivers/ddr/fsl/mpc85xx_ddr_gen3.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright 2008-2012 Freescale Semiconductor, Inc. + * Copyright 2008-2020 Freescale Semiconductor, Inc. */
#include <common.h> @@ -40,6 +40,15 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, #ifdef CONFIG_SYS_FSL_ERRATUM_DDR_A003 u32 save1, save2; #endif +#if defined(CONFIG_SYS_FSL_ERRATUM_A009942) || \ + (defined(CONFIG_SYS_FSL_ERRATUM_A008378) && \ + defined(CONFIG_SYS_FSL_DDRC_GEN4)) || \ + defined(CONFIG_SYS_FSL_ERRATUM_A008109) + u32 val32; +#endif +#ifdef CONFIG_SYS_FSL_ERRATUM_A009942 + unsigned int ddr_freq; +#endif
switch (ctrl_num) { case 0: @@ -338,6 +347,49 @@ step2:
} #endif + +#if defined(CONFIG_SYS_FSL_ERRATUM_A008378) && defined(CONFIG_SYS_FSL_DDRC_GEN4) + /* Erratum applies when accumulated ECC is used, or DBI is enabled */ +#define IS_ACC_ECC_EN(v) ((v) & 0x4) +#define IS_DBI(v) ((((v) >> 12) & 0x3) == 0x2) + if (has_erratum_a008378()) { + if (IS_ACC_ECC_EN(regs->ddr_sdram_cfg) || + IS_DBI(regs->ddr_sdram_cfg_3)) { + val32 = ddr_in32(&ddr->debug[28]); + val32 |= (0x9 << 20); + ddr_out32(&ddr->debug[28], val32); + } + debug("Applied errata CONFIG_SYS_FSL_ERRATUM_A008378\n"); + } +#endif + +#if defined(CONFIG_SYS_FSL_ERRATUM_A008109) + val32 = in_be32(&ddr->sdram_cfg_2) | 0x800; /* DDR_SLOW */ + out_be32(&ddr->sdram_cfg_2, val32); + + val32 = in_be32(&ddr->debug[18]) | 0x2; + out_be32(&ddr->debug[18], val32); + + out_be32(&ddr->debug[28], 0x30000000); + debug("Applied errta CONFIG_SYS_FSL_ERRATUM_A008109\n"); +#endif + +#ifdef CONFIG_SYS_FSL_ERRATUM_A009942 + ddr_freq = get_ddr_freq(ctrl_num) / 1000000; + val32 = in_be32(&ddr->debug[28]); + val32 &= 0xff0fff00; + if (ddr_freq <= 1333) + val32 |= 0x0080006a; + else if (ddr_freq <= 1600) + val32 |= 0x0070006f; + else if (ddr_freq <= 1867) + val32 |= 0x00700076; + else if (ddr_freq <= 2133) + val32 |= 0x0060007b; + + out_be32(&ddr->debug[28], val32); + debug("Applied errata CONFIG_SYS_FSL_ERRATUM_A009942\n"); +#endif /* * For 8572 DDR1 erratum - DDR controller may enter illegal state * when operatiing in 32-bit bus mode with 4-beat bursts,
Priyanka Jain
