[U-Boot] [PATCH] ARM: uniphier: set DRAM_SPARSE flag for LD21 boards
Commit 04cd4e7215d3 ("ARM: uniphier: remove DRAM base address from board parameters") accidentally unset the DRAM_SPARSE flag, and changed the physical map of the DRAM channels. Revive the original behavior.
Fixes: 04cd4e7215d3 ("ARM: uniphier: remove DRAM base address from board parameters") Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Reported-by: Shunji Sato sato.shunji@socionext.com ---
arch/arm/mach-uniphier/boards.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-uniphier/boards.c b/arch/arm/mach-uniphier/boards.c index db7d192..e3b9335 100644 --- a/arch/arm/mach-uniphier/boards.c +++ b/arch/arm/mach-uniphier/boards.c @@ -199,7 +199,7 @@ static const struct uniphier_board_data uniphier_ld21_data = { .size = 0x40000000, .width = 32, }, - .flags = UNIPHIER_BD_BOARD_LD21_GLOBAL, + .flags = UNIPHIER_BD_DRAM_SPARSE | UNIPHIER_BD_BOARD_LD21_GLOBAL, }; #endif
2017-03-07 5:28 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Applied to u-boot-uniphier/master.
Masahiro Yamada
