[PATCH 00/10] ECC Series
This series is to: 1. Enable ECC priming with BIST engine (Patch 1) 2. Add a function to store base address and size of RAM's banks in a 64 bit device private data (Patch 2) 3. Setup the ECC region start and range (Patch 3) 4. Enable ECC 1 bit error, 2 bit error and multiple bit error interrupts (Patch 4) 5. Add CONFIG_K3_INLINE_ECC (Patch 5) 6. Pull the redundant DDR functions to a common location (Patch 6) 7. Remove redundant DDR functions (Patch 7, 8) 8. Fixup DDR size when ECC is enabled (Patch 9) 9. Add ss_cfg reg entry (Patch 10)
Tested on AM62X and AM62A, results: AM62X: https://gist.github.com/santhosh21/c5f07cd921bd2b12d12385f22c698ee6 AM62A: https://gist.github.com/santhosh21/e5fa684d890d65b4034346435213ec8b
Things to look in the test log: 1. Time-taken for priming 2. Fixed up DDR size (RAM size =- ECC reserved space).
Thanks and Regards, Santhosh.
Georgi Vlaev (1): ram: k3-ddrss: Use the DDR controller BIST engine for ECC priming
Neha Malcom Francis (1): drivers: ram: Kconfig: Add CONFIG_K3_INLINE_ECC
Santhosh Kumar K (8): ram: k3-ddrss: Add k3_ddrss_ddr_bank_base_size_calc() to solve 'calculations restricted to 32 bits' issue ram: k3-ddrss: Setup ECC region start and range ram: k3-ddrss: Enable ECC interrupts board: ti: common: k3-ddr-init: Pull redundant DDR functions to a common location board: ti: am64x: evm: Remove redundant DDR functions board: ti: am62x: evm: Remove redundant DDR functions board: ti: am62ax: evm: Fixup DDR size when ECC is enabled arm: dts: k3-am62a-ddr: Add ss_cfg reg entry
arch/arm/dts/k3-am62a-ddr.dtsi | 7 +- board/ti/am62ax/evm.c | 16 +-- board/ti/am62x/evm.c | 61 +--------- board/ti/am64x/evm.c | 71 +---------- board/ti/common/k3-ddr-init.c | 75 ++++++++++++ board/ti/common/k3-ddr-init.h | 15 +++ drivers/ram/Kconfig | 11 ++ drivers/ram/k3-ddrss/k3-ddrss.c | 209 +++++++++++++++++++++++++++----- 8 files changed, 307 insertions(+), 158 deletions(-) create mode 100644 board/ti/common/k3-ddr-init.c create mode 100644 board/ti/common/k3-ddr-init.h
The 1-bit inline ECC support in TI's DDRSS bridge requires the configured memory regions to be preloaded with a pattern before use. This is done by the k3-ddrss driver from the R5 SPL in a 'for' loop. It takes around 10 seconds to fill 2GB of memory on AM64x and AM62x. Memset can cut the time in half and using DMA currently yields a similar result.
The BIST engine of DDR controller provides support for initializing any memory region with a pattern. This bypasses the DDRSS bridge, so the required inline ECC data is not computed and populated in the memory. For some values like zero, the computed ECC syndrome is also zero and we can use these values to preload the memory from the DDR controller, without the assistance of the bridge.
The registers involved in the process are described in the 'DDR controller registers' topic in [1] AM62 and [2] J721E reference manuals.
The patch replaces the 'for' loop memory fill function with the BIST memory initialization procedure. This cuts the time to preload the 2GB memory on am625-sk from 10 seconds down to 1 second. The bist preload function uses the lpddr4 APIs in the k3-ddrss, so this is compatible with devices with both 16-bit LPDDR4 and 32-bit LPDDR4 interfaces (e.g J721E).
Note: The inline 1-bit ECC feature of the DDRSS is currently enabled only for AM64x and AM62x.
[1] AM62x: https://www.ti.com/lit/pdf/spruiv7 [2] DRA829/TDA4VM: https://www.ti.com/lit/zip/spruil1
Signed-off-by: Georgi Vlaev g-vlaev@ti.com Signed-off-by: Santhosh Kumar K s-k6@ti.com Reviewed-by: Neha Malcom Francis n-francis@ti.com --- drivers/ram/k3-ddrss/k3-ddrss.c | 122 +++++++++++++++++++++++++++++--- 1 file changed, 114 insertions(+), 8 deletions(-)
diff --git a/drivers/ram/k3-ddrss/k3-ddrss.c b/drivers/ram/k3-ddrss/k3-ddrss.c index a5c9b82cf1da..b656721e8e5b 100644 --- a/drivers/ram/k3-ddrss/k3-ddrss.c +++ b/drivers/ram/k3-ddrss/k3-ddrss.c @@ -7,6 +7,7 @@
#include <common.h> #include <config.h> +#include <time.h> #include <clk.h> #include <div64.h> #include <dm.h> @@ -554,14 +555,118 @@ static void k3_ddrss_set_ecc_range_r0(u32 base, u32 start_address, u32 size) writel((start_address + size - 1) >> 16, base + DDRSS_ECC_R0_END_ADDR_REG); }
-static void k3_ddrss_preload_ecc_mem_region(u32 *addr, u32 size, u32 word) +#define BIST_MODE_MEM_INIT 4 +#define BIST_MEM_INIT_TIMEOUT 10000 /* 1msec loops per block = 10s */ +static void k3_lpddr4_bist_init_mem_region(struct k3_ddrss_desc *ddrss, + u64 addr, u64 size, + u32 pattern) { - int i; + lpddr4_obj *driverdt = ddrss->driverdt; + lpddr4_privatedata *pd = &ddrss->pd; + u32 status, offset, regval; + bool int_status; + int i = 0; + + /* Set BIST_START_ADDR_0 [31:0] */ + regval = (u32)(addr & TH_FLD_MASK(LPDDR4__BIST_START_ADDRESS_0__FLD)); + TH_OFFSET_FROM_REG(LPDDR4__BIST_START_ADDRESS_0__REG, CTL_SHIFT, offset); + driverdt->writereg(pd, LPDDR4_CTL_REGS, offset, regval); + + /* Set BIST_START_ADDR_1 [32 or 34:32] */ + regval = (u32)(addr >> TH_FLD_WIDTH(LPDDR4__BIST_START_ADDRESS_0__FLD)); + regval &= TH_FLD_MASK(LPDDR4__BIST_START_ADDRESS_1__FLD); + TH_OFFSET_FROM_REG(LPDDR4__BIST_START_ADDRESS_1__REG, CTL_SHIFT, offset); + driverdt->writereg(pd, LPDDR4_CTL_REGS, offset, regval); + + /* Set ADDR_SPACE = log2(size) */ + regval = (u32)(ilog2(size) << TH_FLD_SHIFT(LPDDR4__ADDR_SPACE__FLD)); + TH_OFFSET_FROM_REG(LPDDR4__ADDR_SPACE__REG, CTL_SHIFT, offset); + driverdt->writereg(pd, LPDDR4_CTL_REGS, offset, regval); + + /* Enable the BIST data check. On 32bit lpddr4 (e.g J7) this shares a + * register with ADDR_SPACE and BIST_GO. + */ + TH_OFFSET_FROM_REG(LPDDR4__BIST_DATA_CHECK__REG, CTL_SHIFT, offset); + driverdt->readreg(pd, LPDDR4_CTL_REGS, offset, ®val); + regval |= TH_FLD_MASK(LPDDR4__BIST_DATA_CHECK__FLD); + driverdt->writereg(pd, LPDDR4_CTL_REGS, offset, regval); + /* Clear the address check bit */ + TH_OFFSET_FROM_REG(LPDDR4__BIST_ADDR_CHECK__REG, CTL_SHIFT, offset); + driverdt->readreg(pd, LPDDR4_CTL_REGS, offset, ®val); + regval &= ~TH_FLD_MASK(LPDDR4__BIST_ADDR_CHECK__FLD); + driverdt->writereg(pd, LPDDR4_CTL_REGS, offset, regval); + + /* Set BIST_TEST_MODE[2:0] to memory initialize (4) */ + regval = BIST_MODE_MEM_INIT; + TH_OFFSET_FROM_REG(LPDDR4__BIST_TEST_MODE__REG, CTL_SHIFT, offset); + driverdt->writereg(pd, LPDDR4_CTL_REGS, offset, regval); + + /* Set BIST_DATA_PATTERN[31:0] */ + TH_OFFSET_FROM_REG(LPDDR4__BIST_DATA_PATTERN_0__REG, CTL_SHIFT, offset); + driverdt->writereg(pd, LPDDR4_CTL_REGS, offset, pattern); + + /* Set BIST_DATA_PATTERN[63:32] */ + TH_OFFSET_FROM_REG(LPDDR4__BIST_DATA_PATTERN_1__REG, CTL_SHIFT, offset); + driverdt->writereg(pd, LPDDR4_CTL_REGS, offset, pattern); + + udelay(1000); + + /* Enable the programmed BIST operation - BIST_GO = 1 */ + TH_OFFSET_FROM_REG(LPDDR4__BIST_GO__REG, CTL_SHIFT, offset); + driverdt->readreg(pd, LPDDR4_CTL_REGS, offset, ®val); + regval |= TH_FLD_MASK(LPDDR4__BIST_GO__FLD); + driverdt->writereg(pd, LPDDR4_CTL_REGS, offset, regval); + + /* Wait for the BIST_DONE interrupt */ + while (i < BIST_MEM_INIT_TIMEOUT) { + status = driverdt->checkctlinterrupt(pd, LPDDR4_INTR_BIST_DONE, + &int_status); + if (!status & int_status) { + /* Clear LPDDR4_INTR_BIST_DONE */ + driverdt->ackctlinterrupt(pd, LPDDR4_INTR_BIST_DONE); + break; + } + udelay(1000); + i++; + }
- printf("ECC is enabled, priming DDR which will take several seconds.\n"); + /* Before continuing we have to stop BIST - BIST_GO = 0 */ + TH_OFFSET_FROM_REG(LPDDR4__BIST_GO__REG, CTL_SHIFT, offset); + driverdt->writereg(pd, LPDDR4_CTL_REGS, offset, 0); + + /* Timeout hit while priming the memory. We can't continue, + * since the memory is not fully initialized and we most + * likely get an uncorrectable error exception while booting. + */ + if (i == BIST_MEM_INIT_TIMEOUT) { + printf("ERROR: Timeout while priming the memory.\n"); + hang(); + } +}
- for (i = 0; i < (size / 4); i++) - addr[i] = word; +static void k3_ddrss_lpddr4_preload_full_mem(struct k3_ddrss_desc *ddrss, + u64 total_size, u32 pattern) +{ + u32 done, max_size2; + + /* Get the max size (log2) supported in this config (16/32 lpddr4) + * from the start_addess width - 16bit: 8G, 32bit: 32G + */ + max_size2 = TH_FLD_WIDTH(LPDDR4__BIST_START_ADDRESS_0__FLD) + + TH_FLD_WIDTH(LPDDR4__BIST_START_ADDRESS_1__FLD) + 1; + + /* ECC is enabled in dt but we can't preload the memory if + * the memory configuration is recognized and supported. + */ + if (!total_size || total_size > (1ull << max_size2) || + total_size & (total_size - 1)) { + printf("ECC: the memory configuration is not supported\n"); + hang(); + } + printf("ECC is enabled, priming DDR which will take several seconds.\n"); + done = get_timer(0); + k3_lpddr4_bist_init_mem_region(ddrss, 0, total_size, pattern); + printf("ECC: priming DDR completed in %lu msec\n", get_timer(done)); }
static void k3_ddrss_lpddr4_ecc_calc_reserved_mem(struct k3_ddrss_desc *ddrss) @@ -589,9 +694,10 @@ static void k3_ddrss_lpddr4_ecc_init(struct k3_ddrss_desc *ddrss) writel(DDRSS_ECC_CTRL_REG_ECC_EN | DDRSS_ECC_CTRL_REG_RMW_EN | DDRSS_ECC_CTRL_REG_WR_ALLOC, base + DDRSS_ECC_CTRL_REG);
- /* Preload ECC Mem region with 0's */ - k3_ddrss_preload_ecc_mem_region((u32 *)ecc_region_start, ecc_range, - 0x00000000); + /* Preload the full memory with 0's using the BIST engine of + * the LPDDR4 controller. + */ + k3_ddrss_lpddr4_preload_full_mem(ddrss, gd->ram_size, 0);
/* Clear Error Count Register */ writel(0x1, base + DDRSS_ECC_1B_ERR_CNT_REG);
As R5 is a 32 bit processor, the RAM banks' base and size calculation is restricted to 32 bits, which results in wrong values if bank's base is greater than 32 bits or bank's size is greater than or equal to 4GB.
So, add k3_ddrss_ddr_bank_base_size_calc() to get the base address and size of RAM's banks from the device tree memory node, and store in a 64 bit device private data which can be used for ECC reserved memory calculation, Setting ECC range and Fixing up bank size in device tree when ECC is enabled.
Signed-off-by: Santhosh Kumar K s-k6@ti.com Reviewed-by: Neha Malcom Francis n-francis@ti.com --- drivers/ram/k3-ddrss/k3-ddrss.c | 69 ++++++++++++++++++++++++++------- 1 file changed, 55 insertions(+), 14 deletions(-)
diff --git a/drivers/ram/k3-ddrss/k3-ddrss.c b/drivers/ram/k3-ddrss/k3-ddrss.c index b656721e8e5b..0e77b58edf4d 100644 --- a/drivers/ram/k3-ddrss/k3-ddrss.c +++ b/drivers/ram/k3-ddrss/k3-ddrss.c @@ -148,6 +148,9 @@ struct k3_ddrss_desc { struct k3_ddrss_ecc_region ecc_regions[K3_DDRSS_MAX_ECC_REGIONS]; u64 ecc_reserved_space; bool ti_ecc_enabled; + unsigned long long ddr_bank_base[CONFIG_NR_DRAM_BANKS]; + unsigned long long ddr_bank_size[CONFIG_NR_DRAM_BANKS]; + unsigned long long ddr_ram_size; };
struct reginitdata { @@ -669,11 +672,53 @@ static void k3_ddrss_lpddr4_preload_full_mem(struct k3_ddrss_desc *ddrss, printf("ECC: priming DDR completed in %lu msec\n", get_timer(done)); }
+static void k3_ddrss_ddr_bank_base_size_calc(struct k3_ddrss_desc *ddrss) +{ + int bank, na, ns, len, parent; + const fdt32_t *ptr, *end; + + for (bank = 0; bank < CONFIG_NR_DRAM_BANKS; bank++) { + ddrss->ddr_bank_base[bank] = 0; + ddrss->ddr_bank_size[bank] = 0; + } + + ofnode mem = ofnode_null(); + + do { + mem = ofnode_by_prop_value(mem, "device_type", "memory", 7); + } while (!ofnode_is_enabled(mem)); + + const void *fdt = ofnode_to_fdt(mem); + int node = ofnode_to_offset(mem); + const char *property = "reg"; + + parent = fdt_parent_offset(fdt, node); + na = fdt_address_cells(fdt, parent); + ns = fdt_size_cells(fdt, parent); + ptr = fdt_getprop(fdt, node, property, &len); + end = ptr + len / sizeof(*ptr); + + for (bank = 0; bank < CONFIG_NR_DRAM_BANKS; bank++) { + if (ptr + na + ns <= end) { + if (CONFIG_IS_ENABLED(OF_TRANSLATE)) + ddrss->ddr_bank_base[bank] = fdt_translate_address(fdt, node, ptr); + else + ddrss->ddr_bank_base[bank] = fdtdec_get_number(ptr, na); + + ddrss->ddr_bank_size[bank] = fdtdec_get_number(&ptr[na], ns); + } + ptr += na + ns; + } + + for (bank = 0; bank < CONFIG_NR_DRAM_BANKS; bank++) + ddrss->ddr_ram_size += ddrss->ddr_bank_size[bank]; +} + static void k3_ddrss_lpddr4_ecc_calc_reserved_mem(struct k3_ddrss_desc *ddrss) { fdtdec_setup_mem_size_base_lowest();
- ddrss->ecc_reserved_space = gd->ram_size; + ddrss->ecc_reserved_space = ddrss->ddr_ram_size; do_div(ddrss->ecc_reserved_space, 9);
/* Round to clean number */ @@ -697,7 +742,7 @@ static void k3_ddrss_lpddr4_ecc_init(struct k3_ddrss_desc *ddrss) /* Preload the full memory with 0's using the BIST engine of * the LPDDR4 controller. */ - k3_ddrss_lpddr4_preload_full_mem(ddrss, gd->ram_size, 0); + k3_ddrss_lpddr4_preload_full_mem(ddrss, ddrss->ddr_ram_size, 0);
/* Clear Error Count Register */ writel(0x1, base + DDRSS_ECC_1B_ERR_CNT_REG); @@ -742,6 +787,8 @@ static int k3_ddrss_probe(struct udevice *dev)
k3_lpddr4_start(ddrss);
+ k3_ddrss_ddr_bank_base_size_calc(ddrss); + if (ddrss->ti_ecc_enabled) { if (!ddrss->ddrss_ss_cfg) { printf("%s: ss_cfg is required if ecc is enabled but not provided.", @@ -763,29 +810,23 @@ static int k3_ddrss_probe(struct udevice *dev) int k3_ddrss_ddr_fdt_fixup(struct udevice *dev, void *blob, struct bd_info *bd) { struct k3_ddrss_desc *ddrss = dev_get_priv(dev); - u64 start[CONFIG_NR_DRAM_BANKS]; - u64 size[CONFIG_NR_DRAM_BANKS]; int bank;
if (ddrss->ecc_reserved_space == 0) return 0;
for (bank = CONFIG_NR_DRAM_BANKS - 1; bank >= 0; bank--) { - if (ddrss->ecc_reserved_space > bd->bi_dram[bank].size) { - ddrss->ecc_reserved_space -= bd->bi_dram[bank].size; - bd->bi_dram[bank].size = 0; + if (ddrss->ecc_reserved_space > ddrss->ddr_bank_size[bank]) { + ddrss->ecc_reserved_space -= ddrss->ddr_bank_size[bank]; + ddrss->ddr_bank_size[bank] = 0; } else { - bd->bi_dram[bank].size -= ddrss->ecc_reserved_space; + ddrss->ddr_bank_size[bank] -= ddrss->ecc_reserved_space; break; } }
- for (bank = 0; bank < CONFIG_NR_DRAM_BANKS; bank++) { - start[bank] = bd->bi_dram[bank].start; - size[bank] = bd->bi_dram[bank].size; - } - - return fdt_fixup_memory_banks(blob, start, size, CONFIG_NR_DRAM_BANKS); + return fdt_fixup_memory_banks(blob, ddrss->ddr_bank_base, + ddrss->ddr_bank_size, CONFIG_NR_DRAM_BANKS); }
static int k3_ddrss_get_info(struct udevice *dev, struct ram_info *info)
Setup the ECC region's start and range using the device private data, ddrss->ddr_bank_base[0] and ddrss->ddr_ram_size. Also, move start and range of ECC regions from 32 bits to 64 bits to accommodate for DDR greater than or equal to 4GB.
Signed-off-by: Santhosh Kumar K s-k6@ti.com Reviewed-by: Neha Malcom Francis n-francis@ti.com --- drivers/ram/k3-ddrss/k3-ddrss.c | 14 +++++++------- 1 file changed, 7 insertions(+), 7 deletions(-)
diff --git a/drivers/ram/k3-ddrss/k3-ddrss.c b/drivers/ram/k3-ddrss/k3-ddrss.c index 0e77b58edf4d..de1441f94a87 100644 --- a/drivers/ram/k3-ddrss/k3-ddrss.c +++ b/drivers/ram/k3-ddrss/k3-ddrss.c @@ -122,8 +122,8 @@ struct k3_msmc { #define K3_DDRSS_MAX_ECC_REGIONS 3
struct k3_ddrss_ecc_region { - u32 start; - u32 range; + u64 start; + u64 range; };
struct k3_ddrss_desc { @@ -727,13 +727,13 @@ static void k3_ddrss_lpddr4_ecc_calc_reserved_mem(struct k3_ddrss_desc *ddrss)
static void k3_ddrss_lpddr4_ecc_init(struct k3_ddrss_desc *ddrss) { - u32 ecc_region_start = ddrss->ecc_regions[0].start; - u32 ecc_range = ddrss->ecc_regions[0].range; + u64 ecc_region_start = ddrss->ecc_regions[0].start; + u64 ecc_range = ddrss->ecc_regions[0].range; u32 base = (u32)ddrss->ddrss_ss_cfg; u32 val;
/* Only Program region 0 which covers full ddr space */ - k3_ddrss_set_ecc_range_r0(base, ecc_region_start - gd->ram_base, ecc_range); + k3_ddrss_set_ecc_range_r0(base, ecc_region_start - ddrss->ddr_bank_base[0], ecc_range);
/* Enable ECC, RMW, WR_ALLOC */ writel(DDRSS_ECC_CTRL_REG_ECC_EN | DDRSS_ECC_CTRL_REG_RMW_EN | @@ -799,8 +799,8 @@ static int k3_ddrss_probe(struct udevice *dev) k3_ddrss_lpddr4_ecc_calc_reserved_mem(ddrss);
/* Always configure one region that covers full DDR space */ - ddrss->ecc_regions[0].start = gd->ram_base; - ddrss->ecc_regions[0].range = gd->ram_size - ddrss->ecc_reserved_space; + ddrss->ecc_regions[0].start = ddrss->ddr_bank_base[0]; + ddrss->ecc_regions[0].range = ddrss->ddr_ram_size - ddrss->ecc_reserved_space; k3_ddrss_lpddr4_ecc_init(ddrss); }
Enable ECC 1-bit error, 2-bit error, multiple 1-bit error interrupts by setting the respective bits in the DDRSS_V2A_INT_SET_REG register.
Signed-off-by: Santhosh Kumar K s-k6@ti.com --- drivers/ram/k3-ddrss/k3-ddrss.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/drivers/ram/k3-ddrss/k3-ddrss.c b/drivers/ram/k3-ddrss/k3-ddrss.c index de1441f94a87..37cc15dcfd07 100644 --- a/drivers/ram/k3-ddrss/k3-ddrss.c +++ b/drivers/ram/k3-ddrss/k3-ddrss.c @@ -46,6 +46,11 @@ #define DDRSS_ECC_R2_STR_ADDR_REG 0x0140 #define DDRSS_ECC_R2_END_ADDR_REG 0x0144 #define DDRSS_ECC_1B_ERR_CNT_REG 0x0150 +#define DDRSS_V2A_INT_SET_REG 0x00a8 + +#define DDRSS_V2A_INT_SET_REG_ECC1BERR_EN BIT(3) +#define DDRSS_V2A_INT_SET_REG_ECC2BERR_EN BIT(4) +#define DDRSS_V2A_INT_SET_REG_ECCM1BERR_EN BIT(5)
#define SINGLE_DDR_SUBSYSTEM 0x1 #define MULTI_DDR_SUBSYSTEM 0x2 @@ -747,6 +752,9 @@ static void k3_ddrss_lpddr4_ecc_init(struct k3_ddrss_desc *ddrss) /* Clear Error Count Register */ writel(0x1, base + DDRSS_ECC_1B_ERR_CNT_REG);
+ writel(DDRSS_V2A_INT_SET_REG_ECC1BERR_EN | DDRSS_V2A_INT_SET_REG_ECC2BERR_EN | + DDRSS_V2A_INT_SET_REG_ECCM1BERR_EN, base + DDRSS_V2A_INT_SET_REG); + /* Enable ECC Check */ val = readl(base + DDRSS_ECC_CTRL_REG); val |= DDRSS_ECC_CTRL_REG_ECC_CK;
Add CONFIG_K3_INLINE_ECC so that ECC functions can be compiled into R5 SPL only when the config has been enabled.
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- drivers/ram/Kconfig | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/drivers/ram/Kconfig b/drivers/ram/Kconfig index 5b07e9203014..dd034fa65281 100644 --- a/drivers/ram/Kconfig +++ b/drivers/ram/Kconfig @@ -107,6 +107,17 @@ config IMXRT_SDRAM to support external memories like sdram, psram & nand. This driver is for the sdram memory interface with the SEMC.
+config K3_INLINE_ECC + bool "Enable TI Inline ECC support" + depends on K3_DDRSS + default n + help + Enable Inline ECC support on K3 platforms. 1/9th of the SDRAM space + is used for ECC storage and the rest 8/9th is available for system + use. Enabling ECC increases boot time as the ECC protected regions + need to be primed with a predefined value prior to enabling ECC + check. + source "drivers/ram/aspeed/Kconfig" source "drivers/ram/cadence/Kconfig" source "drivers/ram/octeon/Kconfig"
As there are few redundant functions in board/ti/*/evm.c files, pull them to a common location of access to reuse.
Signed-off-by: Santhosh Kumar K s-k6@ti.com --- board/ti/common/k3-ddr-init.c | 75 +++++++++++++++++++++++++++++++++++ board/ti/common/k3-ddr-init.h | 15 +++++++ 2 files changed, 90 insertions(+) create mode 100644 board/ti/common/k3-ddr-init.c create mode 100644 board/ti/common/k3-ddr-init.h
diff --git a/board/ti/common/k3-ddr-init.c b/board/ti/common/k3-ddr-init.c new file mode 100644 index 000000000000..889db49982ac --- /dev/null +++ b/board/ti/common/k3-ddr-init.c @@ -0,0 +1,75 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2023, Texas Instruments Incorporated - https://www.ti.com/ + */ + +#include <fdt_support.h> +#include <dm/uclass.h> +#include <k3-ddrss.h> +#include <spl.h> + +#include "k3-ddr-init.h" + +int dram_init(void) +{ + s32 ret; + + ret = fdtdec_setup_mem_size_base_lowest(); + if (ret) + printf("Error setting up mem size and base. %d\n", ret); + + return ret; +} + +int dram_init_banksize(void) +{ + s32 ret; + + ret = fdtdec_setup_memory_banksize(); + if (ret) + printf("Error setting up memory banksize. %d\n", ret); + + return ret; +} + +#if defined(CONFIG_SPL_BUILD) + +void fixup_ddr_driver_for_ecc(struct spl_image_info *spl_image) +{ + struct udevice *dev; + int ret; + + dram_init_banksize(); + + ret = uclass_get_device(UCLASS_RAM, 0, &dev); + if (ret) + panic("Cannnot get RAM device for ddr size fixup: %d\n", ret); + + ret = k3_ddrss_ddr_fdt_fixup(dev, spl_image->fdt_addr, gd->bd); + if (ret) + printf("Error fixing up ddr node for ECC use! %d\n", ret); +} + +void fixup_memory_node(struct spl_image_info *spl_image) +{ + u64 start[CONFIG_NR_DRAM_BANKS]; + u64 size[CONFIG_NR_DRAM_BANKS]; + int bank; + int ret; + + dram_init(); + dram_init_banksize(); + + for (bank = 0; bank < CONFIG_NR_DRAM_BANKS; bank++) { + start[bank] = gd->bd->bi_dram[bank].start; + size[bank] = gd->bd->bi_dram[bank].size; + } + + ret = fdt_fixup_memory_banks(spl_image->fdt_addr, start, size, + CONFIG_NR_DRAM_BANKS); + + if (ret) + printf("Error fixing up memory node! %d\n", ret); +} + +#endif diff --git a/board/ti/common/k3-ddr-init.h b/board/ti/common/k3-ddr-init.h new file mode 100644 index 000000000000..6be6cb1e5b1f --- /dev/null +++ b/board/ti/common/k3-ddr-init.h @@ -0,0 +1,15 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2023, Texas Instruments Incorporated - https://www.ti.com/ + */ + +#ifndef __K3_DDR_INIT_H +#define __K3_DDR_INIT_H + +int dram_init(void); +int dram_init_banksize(void); + +void fixup_ddr_driver_for_ecc(struct spl_image_info *spl_image); +void fixup_memory_node(struct spl_image_info *spl_image); + +#endif /* __K3_DDR_INIT_H */
Remove the redundant DDR functions and include the common file to access the functions.
Signed-off-by: Santhosh Kumar K s-k6@ti.com --- board/ti/am64x/evm.c | 71 ++++---------------------------------------- 1 file changed, 5 insertions(+), 66 deletions(-)
diff --git a/board/ti/am64x/evm.c b/board/ti/am64x/evm.c index a7ca6be436eb..e3ba4bd70801 100644 --- a/board/ti/am64x/evm.c +++ b/board/ti/am64x/evm.c @@ -16,6 +16,7 @@ #include <env.h>
#include "../common/board_detect.h" +#include "../common/k3-ddr-init.h"
#define board_is_am64x_gpevm() (board_ti_k3_is("AM64-GPEVM") || \ board_ti_k3_is("AM64-EVM") || \ @@ -31,28 +32,6 @@ int board_init(void) return 0; }
-int dram_init(void) -{ - s32 ret; - - ret = fdtdec_setup_mem_size_base(); - if (ret) - printf("Error setting up mem size and base. %d\n", ret); - - return ret; -} - -int dram_init_banksize(void) -{ - s32 ret; - - ret = fdtdec_setup_memory_banksize(); - if (ret) - printf("Error setting up memory banksize. %d\n", ret); - - return ret; -} - #if defined(CONFIG_SPL_LOAD_FIT) int board_fit_config_name_match(const char *name) { @@ -97,52 +76,12 @@ static int fixup_usb_boot(const void *fdt_blob) } #endif
-#if defined(CONFIG_K3_AM64_DDRSS) -static void fixup_ddr_driver_for_ecc(struct spl_image_info *spl_image) -{ - struct udevice *dev; - int ret; - - dram_init_banksize(); - - ret = uclass_get_device(UCLASS_RAM, 0, &dev); - if (ret) - panic("Cannot get RAM device for ddr size fixup: %d\n", ret); - - ret = k3_ddrss_ddr_fdt_fixup(dev, spl_image->fdt_addr, gd->bd); - if (ret) - printf("Error fixing up ddr node for ECC use! %d\n", ret); -} -#else -static void fixup_memory_node(struct spl_image_info *spl_image) -{ - u64 start[CONFIG_NR_DRAM_BANKS]; - u64 size[CONFIG_NR_DRAM_BANKS]; - int bank; - int ret; - - dram_init(); - dram_init_banksize(); - - for (bank = 0; bank < CONFIG_NR_DRAM_BANKS; bank++) { - start[bank] = gd->bd->bi_dram[bank].start; - size[bank] = gd->bd->bi_dram[bank].size; - } - - /* dram_init functions use SPL fdt, and we must fixup u-boot fdt */ - ret = fdt_fixup_memory_banks(spl_image->fdt_addr, start, size, CONFIG_NR_DRAM_BANKS); - if (ret) - printf("Error fixing up memory node! %d\n", ret); -} -#endif - void spl_perform_fixups(struct spl_image_info *spl_image) { -#if defined(CONFIG_K3_AM64_DDRSS) - fixup_ddr_driver_for_ecc(spl_image); -#else - fixup_memory_node(spl_image); -#endif + if (IS_ENABLED(CONFIG_K3_INLINE_ECC)) + fixup_ddr_driver_for_ecc(spl_image); + else + fixup_memory_node(spl_image);
#if CONFIG_IS_ENABLED(USB_STORAGE) fixup_usb_boot(spl_image->fdt_addr);
Signed-off-by: Santhosh Kumar K s-k6@ti.com --- board/ti/am62x/evm.c | 61 +++++--------------------------------------- 1 file changed, 6 insertions(+), 55 deletions(-)
diff --git a/board/ti/am62x/evm.c b/board/ti/am62x/evm.c index ad939088402e..42396ad295e7 100644 --- a/board/ti/am62x/evm.c +++ b/board/ti/am62x/evm.c @@ -19,6 +19,8 @@ #include <asm/arch/hardware.h> #include <dm/uclass.h>
+#include "../common/k3-ddr-init.h" + DECLARE_GLOBAL_DATA_PTR;
#if CONFIG_IS_ENABLED(SPLASH_SCREEN) @@ -49,16 +51,6 @@ int board_init(void) return 0; }
-int dram_init(void) -{ - return fdtdec_setup_mem_size_base(); -} - -int dram_init_banksize(void) -{ - return fdtdec_setup_memory_banksize(); -} - #if defined(CONFIG_SPL_BUILD) static int video_setup(void) { @@ -87,52 +79,11 @@ void spl_board_init(void)
-#if defined(CONFIG_K3_AM64_DDRSS) -static void fixup_ddr_driver_for_ecc(struct spl_image_info *spl_image) -{ - struct udevice *dev; - int ret; - - dram_init_banksize(); - - ret = uclass_get_device(UCLASS_RAM, 0, &dev); - if (ret) - panic("Cannot get RAM device for ddr size fixup: %d\n", ret); - - ret = k3_ddrss_ddr_fdt_fixup(dev, spl_image->fdt_addr, gd->bd); - if (ret) - printf("Error fixing up ddr node for ECC use! %d\n", ret); -} -#else -static void fixup_memory_node(struct spl_image_info *spl_image) -{ - u64 start[CONFIG_NR_DRAM_BANKS]; - u64 size[CONFIG_NR_DRAM_BANKS]; - int bank; - int ret; - - dram_init(); - dram_init_banksize(); - - for (bank = 0; bank < CONFIG_NR_DRAM_BANKS; bank++) { - start[bank] = gd->bd->bi_dram[bank].start; - size[bank] = gd->bd->bi_dram[bank].size; - } - - /* dram_init functions use SPL fdt, and we must fixup u-boot fdt */ - ret = fdt_fixup_memory_banks(spl_image->fdt_addr, start, size, - CONFIG_NR_DRAM_BANKS); - if (ret) - printf("Error fixing up memory node! %d\n", ret); -} -#endif - void spl_perform_fixups(struct spl_image_info *spl_image) { -#if defined(CONFIG_K3_AM64_DDRSS) - fixup_ddr_driver_for_ecc(spl_image); -#else - fixup_memory_node(spl_image); -#endif + if (IS_ENABLED(CONFIG_K3_INLINE_ECC)) + fixup_ddr_driver_for_ecc(spl_image); + else + fixup_memory_node(spl_image); } #endif
Call k3-ddrss driver through fixup_ddr_driver_for_ecc() to fixup the device tree and resize the available amount of DDR, if ECC is enabled. Otherwise, fixup the device tree using the regular fdt_fixup_memory_banks().
Signed-off-by: Santhosh Kumar K s-k6@ti.com --- board/ti/am62ax/evm.c | 16 +++++++++------- 1 file changed, 9 insertions(+), 7 deletions(-)
diff --git a/board/ti/am62ax/evm.c b/board/ti/am62ax/evm.c index cd3360a43029..5ed47bb86170 100644 --- a/board/ti/am62ax/evm.c +++ b/board/ti/am62ax/evm.c @@ -13,17 +13,19 @@ #include <fdt_support.h> #include <spl.h>
+#include "../common/k3-ddr-init.h" + int board_init(void) { return 0; }
-int dram_init(void) -{ - return fdtdec_setup_mem_size_base(); -} - -int dram_init_banksize(void) +#if defined(CONFIG_SPL_BUILD) +void spl_perform_fixups(struct spl_image_info *spl_image) { - return fdtdec_setup_memory_banksize(); + if (IS_ENABLED(CONFIG_K3_INLINE_ECC)) + fixup_ddr_driver_for_ecc(spl_image); + else + fixup_memory_node(spl_image); } +#endif
Add ss_cfg memory region which maps the DDRSS configuration region for the memory controller node.
Signed-off-by: Santhosh Kumar K s-k6@ti.com --- arch/arm/dts/k3-am62a-ddr.dtsi | 7 ++++--- 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/k3-am62a-ddr.dtsi b/arch/arm/dts/k3-am62a-ddr.dtsi index 8629ea45b847..42e41f78505a 100644 --- a/arch/arm/dts/k3-am62a-ddr.dtsi +++ b/arch/arm/dts/k3-am62a-ddr.dtsi @@ -4,11 +4,12 @@ */
/ { - memorycontroller: memory-controller@f308000 { + memorycontroller: memory-controller@f300000 { compatible = "ti,am62a-ddrss"; reg = <0x00 0x0f308000 0x00 0x4000>, - <0x00 0x43014000 0x00 0x100>; - reg-names = "cfg", "ctrl_mmr_lp4"; + <0x00 0x43014000 0x00 0x100>, + <0x00 0x0f300000 0x00 0x200>; + reg-names = "cfg", "ctrl_mmr_lp4", "ss_cfg"; ti,ddr-freq1 = <DDRSS_PLL_FREQUENCY_1>; ti,ddr-freq2 = <DDRSS_PLL_FREQUENCY_2>; ti,ddr-fhs-cnt = <DDRSS_PLL_FHS_CNT>;
On 31/01/24 11:32, Santhosh Kumar K wrote:
This series is to:
- Enable ECC priming with BIST engine (Patch 1)
- Add a function to store base address and size of RAM's banks in a 64 bit device private data (Patch 2)
- Setup the ECC region start and range (Patch 3)
- Enable ECC 1 bit error, 2 bit error and multiple bit error interrupts (Patch 4)
- Add CONFIG_K3_INLINE_ECC (Patch 5)
- Pull the redundant DDR functions to a common location (Patch 6)
- Remove redundant DDR functions (Patch 7, 8)
- Fixup DDR size when ECC is enabled (Patch 9)
- Add ss_cfg reg entry (Patch 10)
- Time-taken for priming
- Fixed up DDR size (RAM size =- ECC reserved space).
This patch seems to break compilation on J7* platforms, I'll post a v2. Please don't merge the series.
Santhosh Kumar K
