[U-Boot] [PATCH v7] spi: Add support SH Quad SPI driver
This patch adds a driver for Renesas SoC's Quad SPI bus. This supports with 8 bits per transfer to use with SPI flash.
Signed-off-by: Kouei Abe kouei.abe.cp@renesas.com Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com ---
Changes for v7: - Add comments on each initialization steps and others. - Change to using clrbits_* and setbits_*. - Add documet file for test. Changes for v6: - Update Makefile to new style. Changes for v5: - Add print abort when call ctrlc(). - Move source code in spi_xfer() which should be processed by spi_cs_activate(). - Move source code in spi_xfer() which should be processed by spi_cs_deactivate(). - Remove sh_qspi_xfer, move to spi_xfer(). Changes for v4: - Added tabs - Added comments - Added sh_qspi_init() Changes for v3: - Change Queued to Quad. - Remove path of file from file header. - Use read* and write* directly instead of sh_qspi_write* sh_qspi_read*. - Change driver format. Changes for v2: - "SH QSPI" to "SH QSPI (Queued SPI)". - Remove magic number.
doc/SPI/README.sh_qspi_test | 38 ++++++ drivers/spi/Makefile | 1 + drivers/spi/sh_qspi.c | 277 ++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 316 insertions(+) create mode 100644 doc/SPI/README.sh_qspi_test create mode 100644 drivers/spi/sh_qspi.c
diff --git a/doc/SPI/README.sh_qspi_test b/doc/SPI/README.sh_qspi_test new file mode 100644 index 0000000..8a33fec --- /dev/null +++ b/doc/SPI/README.sh_qspi_test @@ -0,0 +1,38 @@ +------------------------------------------------- + Simple steps used to test the SH-QSPI at U-Boot +------------------------------------------------- + +#0, Currently, SH-QSPI is used by lager board (Renesas ARM SoC R8A7790) + and koelsch board (Renesas ARM SoC R8A7791). These boot from SPI ROM + basically. Thus, U-Boot start, SH-QSPI will is operating normally. + +#1, build U-Boot and load u-boot.bin + + => tftpboot 40000000 u-boot.bin + sh_eth Waiting for PHY auto negotiation to complete.. done + sh_eth: 100Base/Half + Using sh_eth device + TFTP from server 192.168.169.1; our IP address is 192.168.169.79 + Filename 'u-boot.bin'. + Load address: 0x40000000 + Loading: ############ + 2.5 MiB/s + done + Bytes transferred = 175364 (2ad04 hex) + +#2, Commands to erase/write u-boot to flash device + + Note: This method is description of the lager board. If you want to use the + other boards, please change the value according to each environment. + + => sf probe 0 + SF: Detected S25FL512S_256K with page size 512 Bytes, erase size 64 KiB, total 64 MiB + => sf erase 80000 40000 + SF: 262144 bytes @ 0x80000 Erased: OK + => sf write 40000000 80000 175364 + SF: 1528676 bytes @ 0x80000 Written: OK + => + +#3, Push reset button. + + If you're written correctly and driver works properly, U-Boot starts. diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 27902fe..914e71f 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -29,6 +29,7 @@ obj-$(CONFIG_OC_TINY_SPI) += oc_tiny_spi.o obj-$(CONFIG_OMAP3_SPI) += omap3_spi.o obj-$(CONFIG_SOFT_SPI) += soft_spi.o obj-$(CONFIG_SH_SPI) += sh_spi.o +obj-$(CONFIG_SH_QSPI) += sh_qspi.o obj-$(CONFIG_FSL_ESPI) += fsl_espi.o obj-$(CONFIG_FDT_SPI) += fdt_spi.o obj-$(CONFIG_TEGRA20_SFLASH) += tegra20_sflash.o diff --git a/drivers/spi/sh_qspi.c b/drivers/spi/sh_qspi.c new file mode 100644 index 0000000..edeb42d --- /dev/null +++ b/drivers/spi/sh_qspi.c @@ -0,0 +1,277 @@ +/* + * SH QSPI (Quad SPI) driver + * + * Copyright (C) 2013 Renesas Electronics Corporation + * Copyright (C) 2013 Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <malloc.h> +#include <spi.h> +#include <asm/io.h> + +/* SH QSPI register bit masks <REG>_<BIT> */ +#define SPCR_MSTR 0x08 +#define SPCR_SPE 0x40 +#define SPSR_SPRFF 0x80 +#define SPSR_SPTEF 0x20 +#define SPPCR_IO3FV 0x04 +#define SPPCR_IO2FV 0x02 +#define SPPCR_IO1FV 0x01 +#define SPBDCR_RXBC0 (1 << 0) +#define SPCMD_SCKDEN (1 << 15) +#define SPCMD_SLNDEN (1 << 14) +#define SPCMD_SPNDEN (1 << 13) +#define SPCMD_SSLKP (1 << 7) +#define SPCMD_BRDV0 (1 << 2) +#define SPCMD_INIT1 SPCMD_SCKDEN | SPCMD_SLNDEN | \ + SPCMD_SPNDEN | SPCMD_SSLKP | \ + SPCMD_BRDV0 +#define SPCMD_INIT2 SPCMD_SPNDEN | SPCMD_SSLKP | \ + SPCMD_BRDV0 +#define SPBFCR_TXRST (1 << 7) +#define SPBFCR_RXRST (1 << 6) + +/* SH QSPI register set */ +struct sh_qspi_regs { + unsigned char spcr; + unsigned char sslp; + unsigned char sppcr; + unsigned char spsr; + unsigned long spdr; + unsigned char spscr; + unsigned char spssr; + unsigned char spbr; + unsigned char spdcr; + unsigned char spckd; + unsigned char sslnd; + unsigned char spnd; + unsigned char dummy0; + unsigned short spcmd0; + unsigned short spcmd1; + unsigned short spcmd2; + unsigned short spcmd3; + unsigned char spbfcr; + unsigned char dummy1; + unsigned short spbdcr; + unsigned long spbmul0; + unsigned long spbmul1; + unsigned long spbmul2; + unsigned long spbmul3; +}; + +struct sh_qspi_slave { + struct spi_slave slave; + struct sh_qspi_regs *regs; +}; + +static inline struct sh_qspi_slave *to_sh_qspi(struct spi_slave *slave) +{ + return container_of(slave, struct sh_qspi_slave, slave); +} + +static void sh_qspi_init(struct sh_qspi_slave *ss) +{ + /* QSPI initialize */ + /* Set master mode only */ + writeb(SPCR_MSTR, &ss->regs->spcr); + + /* Set SSL signal level */ + writeb(0x00, &ss->regs->sslp); + + /* Set MOSI signal value when transfer is in idle state */ + writeb(SPPCR_IO3FV|SPPCR_IO2FV, &ss->regs->sppcr); + + /* Set bit rate. See 58.3.8 Quad Serial Peripheral Interface */ + writeb(0x01, &ss->regs->spbr); + + /* Disable Dummy Data Transmission */ + writeb(0x00, &ss->regs->spdcr); + + /* Set clock delay value */ + writeb(0x00, &ss->regs->spckd); + + /* Set SSL negation delay value */ + writeb(0x00, &ss->regs->sslnd); + + /* Set next-access delay value */ + writeb(0x00, &ss->regs->spnd); + + /* Set equence command */ + writew(SPCMD_INIT2, &ss->regs->spcmd0); + + /* Reset transfer and receive Buffer */ + setbits_8(&ss->regs->spbfcr, SPBFCR_TXRST|SPBFCR_RXRST); + + /* Clear transfer and receive Buffer control bit */ + clrbits_8(&ss->regs->spbfcr, SPBFCR_TXRST|SPBFCR_RXRST); + + /* Set equence control method. Use equence0 only */ + writeb(0x00, &ss->regs->spscr); + + /* Enable SPI function */ + setbits_8(&ss->regs->spcr, SPCR_SPE); +} + +int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + return 1; +} + +void spi_cs_activate(struct spi_slave *slave) +{ + struct sh_qspi_slave *ss = to_sh_qspi(slave); + + /* Set master mode only */ + writeb(SPCR_MSTR, &ss->regs->spcr); + + /* Set command */ + writew(SPCMD_INIT1, &ss->regs->spcmd0); + + /* Reset transfer and receive Buffer */ + setbits_8(&ss->regs->spbfcr, SPBFCR_TXRST|SPBFCR_RXRST); + + /* Clear transfer and receive Buffer control bit */ + clrbits_8(&ss->regs->spbfcr, SPBFCR_TXRST|SPBFCR_RXRST); + + /* Set equence control method. Use equence0 only */ + writeb(0x00, &ss->regs->spscr); + + /* Enable SPI function */ + setbits_8(&ss->regs->spcr, SPCR_SPE); +} + +void spi_cs_deactivate(struct spi_slave *slave) +{ + struct sh_qspi_slave *ss = to_sh_qspi(slave); + + /* Disable SPI Function */ + clrbits_8(&ss->regs->spcr, SPCR_SPE); +} + +void spi_init(void) +{ + /* nothing to do */ +} + +struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + struct sh_qspi_slave *ss; + + if (!spi_cs_is_valid(bus, cs)) + return NULL; + + ss = spi_alloc_slave(struct sh_qspi_slave, bus, cs); + if (!ss) { + printf("SPI_error: Fail to allocate sh_qspi_slave\n"); + return NULL; + } + + ss->regs = (struct sh_qspi_regs *)CONFIG_SH_QSPI_BASE; + + /* Init SH QSPI */ + sh_qspi_init(ss); + + return &ss->slave; +} + +void spi_free_slave(struct spi_slave *slave) +{ + struct sh_qspi_slave *spi = to_sh_qspi(slave); + + free(spi); +} + +int spi_claim_bus(struct spi_slave *slave) +{ + return 0; +} + +void spi_release_bus(struct spi_slave *slave) +{ +} + +int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, + void *din, unsigned long flags) +{ + struct sh_qspi_slave *ss = to_sh_qspi(slave); + unsigned long nbyte; + int ret = 0; + unsigned char dtdata = 0, drdata; + unsigned char *tdata = &dtdata, *rdata = &drdata; + unsigned long *spbmul0 = &ss->regs->spbmul0; + + if (dout == NULL && din == NULL) { + if (flags & SPI_XFER_END) + spi_cs_deactivate(slave); + return 0; + } + + if (bitlen % 8) { + printf("%s: bitlen is not 8bit alined %d", __func__, bitlen); + return 1; + } + + nbyte = bitlen / 8; + + if (flags & SPI_XFER_BEGIN) { + spi_cs_activate(slave); + + /* Set 1048576 byte */ + writel(0x100000, spbmul0); + } + + if (flags & SPI_XFER_END) + writel(nbyte, spbmul0); + + if (dout != NULL) + tdata = (unsigned char *)dout; + + if (din != NULL) + rdata = din; + + while (nbyte > 0) { + while (!(readb(&ss->regs->spsr) & SPSR_SPTEF)) { + if (ctrlc()) { + puts("abort\n"); + return 1; + } + udelay(10); + } + + writeb(*tdata, (unsigned char *)(&ss->regs->spdr)); + + while ((readw(&ss->regs->spbdcr) != SPBDCR_RXBC0)) { + if (ctrlc()) { + puts("abort\n"); + return 1; + } + udelay(1); + } + + while (!(readb(&ss->regs->spsr) & SPSR_SPRFF)) { + if (ctrlc()) { + puts("abort\n"); + return 1; + } + udelay(10); + } + + *rdata = readb((unsigned char *)(&ss->regs->spdr)); + + if (dout != NULL) + tdata++; + if (din != NULL) + rdata++; + + nbyte--; + } + + if (flags & SPI_XFER_END) + spi_cs_deactivate(slave); + + return ret; +}
Changes for v7:
Changes for v6:
Changes for v5:
Changes for v4:
- Added tabs
- Added comments
Changes for v3:
Changes for v2:
- Simple steps used to test the SH-QSPI at U-Boot
- and koelsch board (Renesas ARM SoC R8A7791). These boot from SPI ROM
- basically. Thus, U-Boot start, SH-QSPI will is operating normally.
- => tftpboot 40000000 u-boot.bin
- sh_eth Waiting for PHY auto negotiation to complete.. done
- sh_eth: 100Base/Half
- Using sh_eth device
- TFTP from server 192.168.169.1; our IP address is 192.168.169.79
- Filename 'u-boot.bin'.
- Load address: 0x40000000
- Loading: ############
- 2.5 MiB/s
- done
- Bytes transferred = 175364 (2ad04 hex)
- Note: This method is description of the lager board. If you want to use the
- other boards, please change the value according to each environment.
- => sf probe 0
- SF: Detected S25FL512S_256K with page size 512 Bytes, erase size 64 KiB, total 64 MiB
- => sf erase 80000 40000
- SF: 262144 bytes @ 0x80000 Erased: OK
- => sf write 40000000 80000 175364
- SF: 1528676 bytes @ 0x80000 Written: OK
- If you're written correctly and driver works properly, U-Boot starts.
- SH QSPI (Quad SPI) driver
- Copyright (C) 2013 Renesas Electronics Corporation
- Copyright (C) 2013 Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com
- SPDX-License-Identifier: GPL-2.0
SPCMD_BRDV0
SPCMD_BRDV0
unsigned char spcr;
unsigned char sslp;
unsigned char spsr;
unsigned long spdr;
unsigned char spbr;
unsigned char spnd;
return 1;
/* Set command */
/* nothing to do */
return NULL;
if (!ss) {
return NULL;
/* Init SH QSPI */
sh_qspi_init(ss);
return &ss->slave;
free(spi);
int ret = 0;
if (bitlen % 8) {
return 1;
nbyte = bitlen / 8;
if (dout != NULL)
if (din != NULL)
rdata = din;
while (nbyte > 0) {
if (ctrlc()) {
puts("abort\n");
return 1;
udelay(10);
if (ctrlc()) {
puts("abort\n");
return 1;
udelay(1);
if (ctrlc()) {
puts("abort\n");
return 1;
udelay(10);
if (dout != NULL)
tdata++;
if (din != NULL)
rdata++;
nbyte--;
return ret;
Fixed in driver/spi/Makefile changes.
Applied to u-boot-spi/master
-- Thanks, Jagan.
This email and any attachments are intended for the sole use of the named recipient(s) and contain(s) confidential information that may be proprietary, privileged or copyrighted under applicable law. If you are not the intended recipient, do not read, copy, or forward this email message or any attachments. Delete this email message and any attachments immediately.
Jagan Teki
Nobuhiro Iwamatsu
