[PATCH 1/1] net: disable MBEDTLS in SPL
Building SPL fails with MBEDTLS enabled. Currently we don't need it there.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- include/u-boot/md5.h | 6 ++++-- include/u-boot/sha1.h | 5 +++-- include/u-boot/sha256.h | 5 +++-- include/u-boot/sha512.h | 5 +++-- lib/Makefile | 2 +- lib/lwip/Makefile | 2 +- lib/lwip/u-boot/lwipopts.h | 4 +++- lib/md5.c | 6 ++++-- lib/sha1.c | 6 ++++-- lib/sha256.c | 6 ++++-- lib/sha512.c | 12 ++++++++---- 11 files changed, 38 insertions(+), 21 deletions(-)
diff --git a/include/u-boot/md5.h b/include/u-boot/md5.h index c98b1a58088..2a52e169051 100644 --- a/include/u-boot/md5.h +++ b/include/u-boot/md5.h @@ -6,7 +6,9 @@ #ifndef _MD5_H #define _MD5_H
-#if defined(CONFIG_MBEDTLS_LIB_CRYPTO) +#include <linux/kconfig.h> + +#if CONFIG_IS_ENABLED(MBEDTLS_LIB_CRYPTO) #include <mbedtls/md5.h> #endif #include "compiler.h" @@ -14,7 +16,7 @@ #define MD5_SUM_LEN 16 #define MD5_DEF_CHUNK_SZ 0x10000
-#if defined(CONFIG_MBEDTLS_LIB_CRYPTO) +#if CONFIG_IS_ENABLED(MBEDTLS_LIB_CRYPTO) typedef mbedtls_md5_context MD5Context; #else typedef struct MD5Context { diff --git a/include/u-boot/sha1.h b/include/u-boot/sha1.h index 2fca7f1be16..dd66258bbe9 100644 --- a/include/u-boot/sha1.h +++ b/include/u-boot/sha1.h @@ -14,9 +14,10 @@ #ifndef _SHA1_H #define _SHA1_H
+#include <linux/kconfig.h> #include <linux/types.h>
-#if defined(CONFIG_MBEDTLS_LIB_CRYPTO) +#if CONFIG_IS_ENABLED(MBEDTLS_LIB_CRYPTO) /* * FIXME: * MbedTLS define the members of "mbedtls_sha256_context" as private, @@ -47,7 +48,7 @@ extern "C" {
extern const uint8_t sha1_der_prefix[];
-#if defined(CONFIG_MBEDTLS_LIB_CRYPTO) +#if CONFIG_IS_ENABLED(MBEDTLS_LIB_CRYPTO) typedef mbedtls_sha1_context sha1_context; #else /** diff --git a/include/u-boot/sha256.h b/include/u-boot/sha256.h index b58d5b58d39..44a9b528b48 100644 --- a/include/u-boot/sha256.h +++ b/include/u-boot/sha256.h @@ -1,9 +1,10 @@ #ifndef _SHA256_H #define _SHA256_H
-#if defined(CONFIG_MBEDTLS_LIB_CRYPTO) +#if CONFIG_IS_ENABLED(MBEDTLS_LIB_CRYPTO) /* * FIXME: * MbedTLS define the members of "mbedtls_sha256_context" as private, @@ -27,7 +28,7 @@ extern const uint8_t sha256_der_prefix[]; /* Reset watchdog each time we process this many bytes */ #define CHUNKSZ_SHA256 (64 * 1024)
-#if defined(CONFIG_MBEDTLS_LIB_CRYPTO) +#if CONFIG_IS_ENABLED(MBEDTLS_LIB_CRYPTO) typedef mbedtls_sha256_context sha256_context; #else typedef struct { diff --git a/include/u-boot/sha512.h b/include/u-boot/sha512.h index 7e10f590a1d..92660d93357 100644 --- a/include/u-boot/sha512.h +++ b/include/u-boot/sha512.h @@ -1,9 +1,10 @@ #ifndef _SHA512_H #define _SHA512_H
-#if defined(CONFIG_MBEDTLS_LIB_CRYPTO) +#if CONFIG_IS_ENABLED(MBEDTLS_LIB_CRYPTO) #include <mbedtls/sha512.h> #endif
@@ -16,7 +17,7 @@ #define CHUNKSZ_SHA384 (16 * 1024) #define CHUNKSZ_SHA512 (16 * 1024)
-#if defined(CONFIG_MBEDTLS_LIB_CRYPTO) +#if CONFIG_IS_ENABLED(MBEDTLS_LIB_CRYPTO) typedef mbedtls_sha512_context sha384_context; typedef mbedtls_sha512_context sha512_context; #else diff --git a/lib/Makefile b/lib/Makefile index dbcfa87ebd6..d24ed629732 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -97,7 +97,7 @@ obj-$(CONFIG_LIBAVB) += libavb/ obj-$(CONFIG_$(PHASE_)OF_LIBFDT) += libfdt/ obj-$(CONFIG_$(PHASE_)OF_REAL) += fdtdec_common.o fdtdec.o
-obj-$(CONFIG_MBEDTLS_LIB) += mbedtls/ +obj-$(CONFIG_$(XPL_)MBEDTLS_LIB) += mbedtls/
obj-$(CONFIG_NET_LWIP) += lwip/
diff --git a/lib/lwip/Makefile b/lib/lwip/Makefile index 19e5c6897f5..fe2b64c9acc 100644 --- a/lib/lwip/Makefile +++ b/lib/lwip/Makefile @@ -54,5 +54,5 @@ obj-y += \ lwip/src/core/udp.o \ lwip/src/netif/ethernet.o
-obj-$(CONFIG_MBEDTLS_LIB_TLS) += lwip/src/apps/altcp_tls/altcp_tls_mbedtls.o \ +obj-$(CONFIG_$(XPL_)MBEDTLS_LIB_TLS) += lwip/src/apps/altcp_tls/altcp_tls_mbedtls.o \ lwip/src/apps/altcp_tls/altcp_tls_mbedtls_mem.o diff --git a/lib/lwip/u-boot/lwipopts.h b/lib/lwip/u-boot/lwipopts.h index 88d6faf327a..edac74ff7a2 100644 --- a/lib/lwip/u-boot/lwipopts.h +++ b/lib/lwip/u-boot/lwipopts.h @@ -5,6 +5,8 @@ #ifndef LWIP_UBOOT_LWIPOPTS_H #define LWIP_UBOOT_LWIPOPTS_H
+#include <linux/kconfig.h> + #if defined(CONFIG_LWIP_DEBUG) #define LWIP_DEBUG 1 #define LWIP_DBG_MIN_LEVEL LWIP_DBG_LEVEL_ALL @@ -154,7 +156,7 @@ #define MEMP_MEM_INIT 1 #define MEM_LIBC_MALLOC 1
-#if defined(CONFIG_MBEDTLS_LIB_TLS) +#if CONFIG_IS_ENABLED(MBEDTLS_LIB_TLS) #define LWIP_ALTCP 1 #define LWIP_ALTCP_TLS 1 #define LWIP_ALTCP_TLS_MBEDTLS 1 diff --git a/lib/md5.c b/lib/md5.c index 2d8977b2e85..e3eab8a9149 100644 --- a/lib/md5.c +++ b/lib/md5.c @@ -272,14 +272,16 @@ md5_wd(const unsigned char *input, unsigned int len, unsigned char output[16], unsigned int chunk_sz) { MD5Context context; -#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) +#if !defined(USE_HOSTCC) && \ + (defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG)) const unsigned char *end, *curr; int chunk; #endif
MD5Init(&context);
-#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) +#if !defined(USE_HOSTCC) && \ + (defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG)) curr = input; end = input + len; while (curr < end) { diff --git a/lib/sha1.c b/lib/sha1.c index a9d6497c4ce..be502c6126b 100644 --- a/lib/sha1.c +++ b/lib/sha1.c @@ -312,14 +312,16 @@ void sha1_csum_wd(const unsigned char *input, unsigned int ilen, unsigned char *output, unsigned int chunk_sz) { sha1_context ctx; -#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) +#if !defined(USE_HOSTCC) && \ + (defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG)) const unsigned char *end, *curr; int chunk; #endif
sha1_starts (&ctx);
-#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) +#if !defined(USE_HOSTCC) && \ + (defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG)) curr = input; end = input + ilen; while (curr < end) { diff --git a/lib/sha256.c b/lib/sha256.c index 329802fd827..fb195d988f1 100644 --- a/lib/sha256.c +++ b/lib/sha256.c @@ -273,7 +273,8 @@ void sha256_csum_wd(const unsigned char *input, unsigned int ilen, unsigned char *output, unsigned int chunk_sz) { sha256_context ctx; -#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) +#if !defined(USE_HOSTCC) && \ + (defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG)) const unsigned char *end; unsigned char *curr; int chunk; @@ -281,7 +282,8 @@ void sha256_csum_wd(const unsigned char *input, unsigned int ilen,
sha256_starts(&ctx);
-#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) +#if !defined(USE_HOSTCC) && \ + (defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG)) curr = (unsigned char *)input; end = input + ilen; while (curr < end) { diff --git a/lib/sha512.c b/lib/sha512.c index ea555ff33eb..0e75c1a943b 100644 --- a/lib/sha512.c +++ b/lib/sha512.c @@ -288,7 +288,8 @@ void sha384_csum_wd(const unsigned char *input, unsigned int ilen, unsigned char *output, unsigned int chunk_sz) { sha512_context ctx; -#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) +#if !defined(USE_HOSTCC) && \ + (defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG)) const unsigned char *end; unsigned char *curr; int chunk; @@ -296,7 +297,8 @@ void sha384_csum_wd(const unsigned char *input, unsigned int ilen,
sha384_starts(&ctx);
-#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) +#if !defined(USE_HOSTCC) && \ + (defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG)) curr = (unsigned char *)input; end = input + ilen; while (curr < end) { @@ -351,7 +353,8 @@ void sha512_csum_wd(const unsigned char *input, unsigned int ilen, unsigned char *output, unsigned int chunk_sz) { sha512_context ctx; -#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) +#if !defined(USE_HOSTCC) && \ + (defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG)) const unsigned char *end; unsigned char *curr; int chunk; @@ -359,7 +362,8 @@ void sha512_csum_wd(const unsigned char *input, unsigned int ilen,
sha512_starts(&ctx);
Acked-by: Jerome Forissier jerome.forissier@linaro.org (lwIP)
Thanks,
Jerome Forissier
