[U-Boot] [PATCH] blackfin: make name_to_gpio be a weak symbol
This required moving it into a C file from the header.
The only user of a non-default name_to_gpio is blackfin, therefore build tested with the blackfin bct-brettl2 build, which is one I picked at random. Also tested with a build for the ARM tec board which uses the default/fallback implementation. Inspection with objdump shows that both have done the right thing.
This change was requested by Marek during review of the sunxi patch series.
Signed-off-by: Ian Campbell ijc@hellion.org.uk Cc: Marek Vasut marex@denx.de Cc: Wolfgang Denk wd@denx.de Cc: Sonic Zhang sonic.adi@gmail.com --- arch/blackfin/cpu/gpio.c | 48 +++++++++++++++++++++++++++++++++++++++ arch/blackfin/include/asm/gpio.h | 49 ---------------------------------------- common/cmd_gpio.c | 7 +++--- 3 files changed, 52 insertions(+), 52 deletions(-)
diff --git a/arch/blackfin/cpu/gpio.c b/arch/blackfin/cpu/gpio.c index 86da706..4b4cf93 100644 --- a/arch/blackfin/cpu/gpio.c +++ b/arch/blackfin/cpu/gpio.c @@ -759,6 +759,54 @@ void bfin_reset_boot_spi_cs(unsigned short pin) udelay(1); }
+int name_to_gpio(const char *name) +{ + int port_base; + + if (tolower(*name) == 'p') { + ++name; + + switch (tolower(*name)) { +#ifdef GPIO_PA0 + case 'a': port_base = GPIO_PA0; break; +#endif +#ifdef GPIO_PB0 + case 'b': port_base = GPIO_PB0; break; +#endif +#ifdef GPIO_PC0 + case 'c': port_base = GPIO_PC0; break; +#endif +#ifdef GPIO_PD0 + case 'd': port_base = GPIO_PD0; break; +#endif +#ifdef GPIO_PE0 + case 'e': port_base = GPIO_PE0; break; +#endif +#ifdef GPIO_PF0 + case 'f': port_base = GPIO_PF0; break; +#endif +#ifdef GPIO_PG0 + case 'g': port_base = GPIO_PG0; break; +#endif +#ifdef GPIO_PH0 + case 'h': port_base = GPIO_PH0; break; +#endif +#ifdef GPIO_PI0 + case 'i': port_base = GPIO_PI0; break; +#endif +#ifdef GPIO_PJ + case 'j': port_base = GPIO_PJ0; break; +#endif + default: return -1; + } + + ++name; + } else + port_base = 0; + + return port_base + simple_strtoul(name, NULL, 10); +} + void gpio_labels(void) { int c, gpio; diff --git a/arch/blackfin/include/asm/gpio.h b/arch/blackfin/include/asm/gpio.h index 6ebcf01..1fa1a8e 100644 --- a/arch/blackfin/include/asm/gpio.h +++ b/arch/blackfin/include/asm/gpio.h @@ -160,55 +160,6 @@ static inline int gpio_is_valid(int number)
#include <linux/ctype.h>
-static inline int name_to_gpio(const char *name) -{ - int port_base; - - if (tolower(*name) == 'p') { - ++name; - - switch (tolower(*name)) { -#ifdef GPIO_PA0 - case 'a': port_base = GPIO_PA0; break; -#endif -#ifdef GPIO_PB0 - case 'b': port_base = GPIO_PB0; break; -#endif -#ifdef GPIO_PC0 - case 'c': port_base = GPIO_PC0; break; -#endif -#ifdef GPIO_PD0 - case 'd': port_base = GPIO_PD0; break; -#endif -#ifdef GPIO_PE0 - case 'e': port_base = GPIO_PE0; break; -#endif -#ifdef GPIO_PF0 - case 'f': port_base = GPIO_PF0; break; -#endif -#ifdef GPIO_PG0 - case 'g': port_base = GPIO_PG0; break; -#endif -#ifdef GPIO_PH0 - case 'h': port_base = GPIO_PH0; break; -#endif -#ifdef GPIO_PI0 - case 'i': port_base = GPIO_PI0; break; -#endif -#ifdef GPIO_PJ - case 'j': port_base = GPIO_PJ0; break; -#endif - default: return -1; - } - - ++name; - } else - port_base = 0; - - return port_base + simple_strtoul(name, NULL, 10); -} -#define name_to_gpio(n) name_to_gpio(n) - #define gpio_status() gpio_labels()
#endif /* __ASSEMBLY__ */ diff --git a/common/cmd_gpio.c b/common/cmd_gpio.c index 778aa5f..aff0445 100644 --- a/common/cmd_gpio.c +++ b/common/cmd_gpio.c @@ -11,9 +11,10 @@ #include <dm.h> #include <asm/gpio.h>
-#ifndef name_to_gpio -#define name_to_gpio(name) simple_strtoul(name, NULL, 10) -#endif +int __weak name_to_gpio(const char *name) +{ + return simple_strtoul(name, NULL, 10); +}
enum gpio_cmd { GPIO_INPUT,
Ian Campbell
