[U-Boot-Users] [PATCH]resubmit: ppc4xx: Remove sequoia/sequioa.h. Cleanup ppc440.h for PPC440EPX
Signed-off-by: Niklaus Giger niklaus.giger@nestal.com --- board/amcc/sequoia/sequoia.c | 9 ++--- board/amcc/sequoia/sequoia.h | 67 ------------------------------------------ include/ppc440.h | 6 ++- 3 files changed, 8 insertions(+), 74 deletions(-) delete mode 100644 board/amcc/sequoia/sequoia.h
diff --git a/board/amcc/sequoia/sequoia.c b/board/amcc/sequoia/sequoia.c index ba365ae..748abef 100644 --- a/board/amcc/sequoia/sequoia.c +++ b/board/amcc/sequoia/sequoia.c @@ -25,7 +25,6 @@ #include <common.h> #include <asm/processor.h> #include <ppc440.h> -#include "sequoia.h"
DECLARE_GLOBAL_DATA_PTR;
@@ -226,7 +225,7 @@ int misc_init_r(void) if (act == NULL || strcmp(act, "hostdev") == 0) { /* SDR Setting */ mfsdr(SDR0_PFC1, sdr0_pfc1); - mfsdr(SDR0_USB0, usb2d0cr); + mfsdr(SDR0_USB2D0CR, usb2d0cr); mfsdr(SDR0_USB2PHY0CR, usb2phy0cr); mfsdr(SDR0_USB2H0CR, usb2h0cr);
@@ -254,7 +253,7 @@ int misc_init_r(void) sdr0_pfc1 = sdr0_pfc1 | SDR0_PFC1_UES_USB2D_SEL; /*0*/
mtsdr(SDR0_PFC1, sdr0_pfc1); - mtsdr(SDR0_USB0, usb2d0cr); + mtsdr(SDR0_USB2D0CR, usb2d0cr); mtsdr(SDR0_USB2PHY0CR, usb2phy0cr); mtsdr(SDR0_USB2H0CR, usb2h0cr);
@@ -298,7 +297,7 @@ int misc_init_r(void) /* SDR Setting */ mfsdr(SDR0_USB2PHY0CR, usb2phy0cr); mfsdr(SDR0_USB2H0CR, usb2h0cr); - mfsdr(SDR0_USB0, usb2d0cr); + mfsdr(SDR0_USB2D0CR, usb2d0cr); mfsdr(SDR0_PFC1, sdr0_pfc1);
usb2phy0cr = usb2phy0cr &~SDR0_USB2PHY0CR_XOCLK_MASK; @@ -323,7 +322,7 @@ int misc_init_r(void)
mtsdr(SDR0_USB2H0CR, usb2h0cr); mtsdr(SDR0_USB2PHY0CR, usb2phy0cr); - mtsdr(SDR0_USB0, usb2d0cr); + mtsdr(SDR0_USB2D0CR, usb2d0cr); mtsdr(SDR0_PFC1, sdr0_pfc1);
/*clear resets*/ diff --git a/board/amcc/sequoia/sequoia.h b/board/amcc/sequoia/sequoia.h deleted file mode 100644 index 1d44b16..0000000 --- a/board/amcc/sequoia/sequoia.h +++ /dev/null @@ -1,67 +0,0 @@ -/* - * (C) Copyright 2006 - * Stefan Roese, DENX Software Engineering, sr@denx.de. - * - * (C) Copyright 2006 - * Jacqueline Pira-Ferriol, AMCC/IBM, jpira-ferriol@fr.ibm.com - * Alain Saurel, AMCC/IBM, alain.saurel@fr.ibm.com - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - - -/*----------------------------------------------------------------------------+ - | EBC Configuration Register - EBC0_CFG - +----------------------------------------------------------------------------*/ -/* External Bus Three-State Control */ -#define EBC0_CFG_EBTC_DRIVEN 0x80000000 -/* Device-Paced Time-out Disable */ -#define EBC0_CFG_PTD_ENABLED 0x00000000 -/* Ready Timeout Count */ -#define EBC0_CFG_RTC_MASK 0x38000000 -#define EBC0_CFG_RTC_16PERCLK 0x00000000 -#define EBC0_CFG_RTC_32PERCLK 0x08000000 -#define EBC0_CFG_RTC_64PERCLK 0x10000000 -#define EBC0_CFG_RTC_128PERCLK 0x18000000 -#define EBC0_CFG_RTC_256PERCLK 0x20000000 -#define EBC0_CFG_RTC_512PERCLK 0x28000000 -#define EBC0_CFG_RTC_1024PERCLK 0x30000000 -#define EBC0_CFG_RTC_2048PERCLK 0x38000000 -/* External Master Priority Low */ -#define EBC0_CFG_EMPL_LOW 0x00000000 -#define EBC0_CFG_EMPL_MEDIUM_LOW 0x02000000 -#define EBC0_CFG_EMPL_MEDIUM_HIGH 0x04000000 -#define EBC0_CFG_EMPL_HIGH 0x06000000 -/* External Master Priority High */ -#define EBC0_CFG_EMPH_LOW 0x00000000 -#define EBC0_CFG_EMPH_MEDIUM_LOW 0x00800000 -#define EBC0_CFG_EMPH_MEDIUM_HIGH 0x01000000 -#define EBC0_CFG_EMPH_HIGH 0x01800000 -/* Chip Select Three-State Control */ -#define EBC0_CFG_CSTC_DRIVEN 0x00400000 -/* Burst Prefetch */ -#define EBC0_CFG_BPF_ONEDW 0x00000000 -#define EBC0_CFG_BPF_TWODW 0x00100000 -#define EBC0_CFG_BPF_FOURDW 0x00200000 -/* External Master Size */ -#define EBC0_CFG_EMS_8BIT 0x00000000 -/* Power Management Enable */ -#define EBC0_CFG_PME_DISABLED 0x00000000 -#define EBC0_CFG_PME_ENABLED 0x00020000 -/* Power Management Timer */ -#define EBC0_CFG_PMT_ENCODE(n) ((((unsigned long)(n))&0x1F)<<12) - -#define SDR0_USB0 0x0320 /* USB Control Register */ diff --git a/include/ppc440.h b/include/ppc440.h index 09f8430..8d7781d 100644 --- a/include/ppc440.h +++ b/include/ppc440.h @@ -1023,7 +1023,7 @@ #endif /* defined(CONFIG_440EP) || defined(CONFIG_440GR) */
#if defined(CONFIG_440EPX) || defined(CONFIG_440GRX) -#define SDR_USB2D0CR 0x0320 +#define SDR0_USB2D0CR 0x0320 #define SDR0_USB2D0CR_USB2DEV_EBC_SEL_MASK 0x00000004 /* USB 2.0 Device/EBC Master Selection */ #define SDR0_USB2D0CR_USB2DEV_SELECTION 0x00000004 /* USB 2.0 Device Selection */ #define SDR0_USB2D0CR_EBC_SELECTION 0x00000000 /* EBC Selection */ @@ -1421,7 +1421,7 @@ #define uicvr uic0vr #define uicvcr uic0vcr
-#if defined(CONFIG_440SPE) +#if defined(CONFIG_440SPE) || defined(CONFIG_440EPX) /*----------------------------------------------------------------------------+ | Clock / Power-on-reset DCR's. +----------------------------------------------------------------------------*/ @@ -1490,9 +1490,11 @@ #define CPR0_OPBD_OPBDV0_DECODE(n) ((((((unsigned long)(n))>>24)-1)&0x03)+1)
#define CPR0_PERD 0xE0 +#if !defined(CONFIG_440EPX) #define CPR0_PERD_PERDV0_MASK 0x03000000 #define CPR0_PERD_PERDV0_ENCODE(n) ((((unsigned long)(n))&0x03)<<24) #define CPR0_PERD_PERDV0_DECODE(n) ((((((unsigned long)(n))>>24)-1)&0x03)+1) +#endif
#define CPR0_MALD 0x100 #define CPR0_MALD_MALDV0_MASK 0x03000000
Niklaus Giger
