[U-Boot] [PATCH 5/7 v4] 83xx, kmeter1: updates for 2009.03
- HRCW update HRCWH_BOOTSEQ_DISABLE not HRCWH_BOOTSEQ_NORMAL HRCWH_LALE_EARLY added - DDR-SDRAM settings modified. This solves sporadically problems with this memory. - CS1 now 128 MB window size - CS3 now 512 MB window size - PRAM activated - MTDPARTS_DEFAULT defined - CONFIG_HOSTNAME added - MONITOR_LEN now 384 KB
Signed-off-by: Heiko Schocher hs@denx.de --- include/configs/kmeter1.h | 81 +++++++++++++++++++++++++++----------------- 1 files changed, 50 insertions(+), 31 deletions(-)
diff --git a/include/configs/kmeter1.h b/include/configs/kmeter1.h index ef3faa5..49a801f 100644 --- a/include/configs/kmeter1.h +++ b/include/configs/kmeter1.h @@ -28,6 +28,7 @@ #define CONFIG_MPC83XX 1 /* MPC83XX family */ #define CONFIG_MPC8360 1 /* MPC8360 CPU specific */ #define CONFIG_KMETER1 1 /* KMETER1 board specific */ +#define CONFIG_HOSTNAME kmeter1
/* include common defines/options for all Keymile boards */ #include "keymile-common.h" @@ -52,10 +53,11 @@ #define CONFIG_SYS_HRCW_HIGH (\ HRCWH_CORE_ENABLE | \ HRCWH_FROM_0X00000100 | \ - HRCWH_BOOTSEQ_NORMAL | \ + HRCWH_BOOTSEQ_DISABLE | \ HRCWH_SW_WATCHDOG_DISABLE | \ HRCWH_ROM_LOC_LOCAL_16BIT | \ HRCWH_BIG_ENDIAN | \ + HRCWH_LALE_EARLY | \ HRCWH_LDP_CLEAR )
/* @@ -102,11 +104,12 @@ SDRAM_CFG_SREN) #define CONFIG_SYS_DDR_SDRAM_CFG2 0x00401000 #define CONFIG_SYS_DDR_CLK_CNTL (DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05) -#define CONFIG_SYS_DDR_INTERVAL ((0x100 << SDRAM_INTERVAL_BSTOPRE_SHIFT) | \ - (0x406 << SDRAM_INTERVAL_REFINT_SHIFT)) +#define CONFIG_SYS_DDR_INTERVAL ((0x080 << SDRAM_INTERVAL_BSTOPRE_SHIFT) | \ + (0x3cf << SDRAM_INTERVAL_REFINT_SHIFT))
-#define CONFIG_SYS_DDR_MODE 0x04440242 -#define CONFIG_SYS_DDR_MODE2 0x00800000 +#define CONFIG_SYS_DDRCDR 0x40000001 +#define CONFIG_SYS_DDR_MODE 0x47860452 +#define CONFIG_SYS_DDR_MODE2 0x8080c000
#define CONFIG_SYS_DDR_TIMING_0 ((2 << TIMING_CFG0_MRS_CYC_SHIFT) | \ (8 << TIMING_CFG0_ODT_PD_EXIT_SHIFT) | \ @@ -117,22 +120,22 @@ (0 << TIMING_CFG0_WRT_SHIFT) | \ (0 << TIMING_CFG0_RWT_SHIFT))
-#define CONFIG_SYS_DDR_TIMING_1 (( TIMING_CFG1_CASLAT_40) | \ +#define CONFIG_SYS_DDR_TIMING_1 (( TIMING_CFG1_CASLAT_50) | \ ( 2 << TIMING_CFG1_WRTORD_SHIFT) | \ - ( 1 << TIMING_CFG1_ACTTOACT_SHIFT) | \ - ( 2 << TIMING_CFG1_WRREC_SHIFT) | \ - ( 2 << TIMING_CFG1_REFREC_SHIFT) | \ - ( 2 << TIMING_CFG1_ACTTORW_SHIFT) | \ - ( 6 << TIMING_CFG1_ACTTOPRE_SHIFT) | \ - ( 2 << TIMING_CFG1_PRETOACT_SHIFT)) - -#define CONFIG_SYS_DDR_TIMING_2 ((5 << TIMING_CFG2_FOUR_ACT_SHIFT) | \ + ( 2 << TIMING_CFG1_ACTTOACT_SHIFT) | \ + ( 3 << TIMING_CFG1_WRREC_SHIFT) | \ + ( 7 << TIMING_CFG1_REFREC_SHIFT) | \ + ( 3 << TIMING_CFG1_ACTTORW_SHIFT) | \ + ( 8 << TIMING_CFG1_ACTTOPRE_SHIFT) | \ + ( 3 << TIMING_CFG1_PRETOACT_SHIFT)) + +#define CONFIG_SYS_DDR_TIMING_2 ((8 << TIMING_CFG2_FOUR_ACT_SHIFT) | \ (3 << TIMING_CFG2_CKE_PLS_SHIFT) | \ (2 << TIMING_CFG2_WR_DATA_DELAY_SHIFT) | \ - (1 << TIMING_CFG2_RD_TO_PRE_SHIFT) | \ - (3 << TIMING_CFG2_WR_LAT_DELAY_SHIFT) | \ + (2 << TIMING_CFG2_RD_TO_PRE_SHIFT) | \ + (4 << TIMING_CFG2_WR_LAT_DELAY_SHIFT) | \ (0 << TIMING_CFG2_ADD_LAT_SHIFT) | \ - (4 << TIMING_CFG2_CPO_SHIFT)) + (5 << TIMING_CFG2_CPO_SHIFT))
#define CONFIG_SYS_DDR_TIMING_3 0x00000000
@@ -142,9 +145,10 @@ #define CONFIG_SYS_MONITOR_BASE TEXT_BASE /* start of monitor */ #define CONFIG_SYS_FLASH_BASE 0xF0000000 #define CONFIG_SYS_FLASH_BASE_1 0xF2000000 -#define CONFIG_SYS_PIGGY_BASE 0x80000000 +#define CONFIG_SYS_PIGGY_BASE 0xE8000000 +#define CONFIG_SYS_PIGGY_SIZE 128 #define CONFIG_SYS_PAXE_BASE 0xA0000000 -#define CONFIG_SYS_PAXE_SIZE 256 +#define CONFIG_SYS_PAXE_SIZE 512
#if (CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE) #define CONFIG_SYS_RAMBOOT @@ -152,7 +156,7 @@ #undef CONFIG_SYS_RAMBOOT #endif
-#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ +#define CONFIG_SYS_MONITOR_LEN (384 * 1024) /* Reserve 256 kB for Mon */ #define CONFIG_SYS_MALLOC_LEN (128 * 1024) /* Reserved for malloc */
/* @@ -175,8 +179,8 @@ * Bank Bus Machine PortSz Size Device * ---- --- ------- ------ ----- ------ * 0 Local GPCM 16 bit 256MB FLASH - * 1 Local GPCM 8 bit 256KB GPIO/PIGGY - * 3 Local GPCM 8 bit 256MB PAXE + * 1 Local GPCM 8 bit 128MB GPIO/PIGGY + * 3 Local GPCM 8 bit 512MB PAXE * */ /* @@ -210,12 +214,12 @@ * PRIO1/PIGGY on the local bus CS1 */ #define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_PIGGY_BASE /* Window base at flash base */ -#define CONFIG_SYS_LBLAWAR1_PRELIM 0x80000011 /* 256KB window size */ +#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000001A /* 128MB window size */
#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_PIGGY_BASE | \ (1 << BR_PS_SHIFT) | /* 8 bit port size */ \ BR_V) -#define CONFIG_SYS_OR1_PRELIM (0xfffc0000 | /* 256KB */ \ +#define CONFIG_SYS_OR1_PRELIM (MEG_TO_AM(CONFIG_SYS_PIGGY_SIZE) | /* 128MB */ \ OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | \ OR_GPCM_SCY_2 | \ OR_GPCM_TRLX | OR_GPCM_EAD) @@ -224,7 +228,7 @@ * PAXE on the local bus CS3 */ #define CONFIG_SYS_LBLAWBAR3_PRELIM CONFIG_SYS_PAXE_BASE /* Window base at flash base */ -#define CONFIG_SYS_LBLAWAR3_PRELIM 0x8000001b /* 256MB window size */ +#define CONFIG_SYS_LBLAWAR3_PRELIM 0x8000001C /* 512MB window size */
#define CONFIG_SYS_BR3_PRELIM (CONFIG_SYS_PAXE_BASE | \ (1 << BR_PS_SHIFT) | /* 8 bit port size */ \ @@ -297,7 +301,7 @@ #else /* CFG_RAMBOOT */ #define CONFIG_SYS_NO_FLASH 1 /* Flash is not usable now */ #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ -#define CONFIG_ENV_ADDR (CFG_MONITOR_BASE - 0x1000) +#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 #endif /* CFG_RAMBOOT */
@@ -378,7 +382,7 @@
/* PRIO1, PIGGY: icache cacheable, but dcache-inhibit and guarded */ #define CONFIG_SYS_IBAT2L (CONFIG_SYS_PIGGY_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT2U (CONFIG_SYS_PIGGY_BASE | BATU_BL_256K | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT2U (CONFIG_SYS_PIGGY_BASE | BATU_BL_128M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT2L (CONFIG_SYS_PIGGY_BASE | BATL_PP_10 | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT2U CONFIG_SYS_IBAT2U @@ -398,7 +402,7 @@
/* PAXE: icache cacheable, but dcache-inhibit and guarded */ #define CONFIG_SYS_IBAT5L (CONFIG_SYS_PAXE_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT5U (CONFIG_SYS_PAXE_BASE | BATU_BL_256K | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT5U (CONFIG_SYS_PAXE_BASE | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT5L (CONFIG_SYS_PAXE_BASE | BATL_PP_10 | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U @@ -434,16 +438,25 @@ #define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ #define BOOTFLAG_WARM 0x02 /* Software reboot */
+#define BOOTFLASH_START F0000000 + +#define CONFIG_PRAM 512 /* protected RAM [KBytes] */ + +#define MTDIDS_DEFAULT "nor0=app" +#define MTDPARTS_DEFAULT \ + "mtdparts=app:256k(u-boot),128k(env),128k(envred)," \ + "1536k(esw0),8704k(rootfs0),1536k(esw1),2432k(rootfs1),640k(var),768k(cfg)" + /* * Environment Configuration */ #define CONFIG_ENV_OVERWRITE - -#if defined(CONFIG_UEC_ETH) -#define CONFIG_HAS_ETH0 +#ifndef CONFIG_KM_DEF_ENV /* if not set by keymile-common.h */ +#define CONFIG_KM_DEF_ENV "km-common=empty\0" #endif
#define CONFIG_EXTRA_ENV_SETTINGS \ + CONFIG_KM_DEF_ENV \ "netdev=eth0\0" \ "rootpath=/opt/eldk/ppc_82xx\0" \ "nfsargs=setenv bootargs root=/dev/nfs rw " \ @@ -487,6 +500,12 @@ "unlock=yes\0" \ "EEprom_ivm=pca9547:70:9\0" \ "dtt_bus=pca9547:70:a\0" \ + "mtdids=nor0=app \0" \ + "mtdparts=" MK_STR(MTDPARTS_DEFAULT) "\0" \ ""
+#if defined(CONFIG_UEC_ETH) +#define CONFIG_HAS_ETH0 +#endif + #endif /* __CONFIG_H */
Heiko Schocher
