[U-Boot-Users] [PATCH] NAND: ifdef-protect most of nand.h when using legacy NAND.
Some macros such as NAND_CTL_SETALE conflict between current and legacy NAND, being defined by the subsystem in the former case and the board config file in the latter.
Signed-off-by: Scott Wood scottwood@freescale.com --- Applied to u-boot-nand-flash.
include/nand.h | 5 ++++- 1 files changed, 4 insertions(+), 1 deletions(-)
diff --git a/include/nand.h b/include/nand.h index 247d346..e1285cd 100644 --- a/include/nand.h +++ b/include/nand.h @@ -24,6 +24,9 @@ #ifndef _NAND_H_ #define _NAND_H_
+extern void nand_init(void); + +#ifndef CFG_NAND_LEGACY #include <linux/mtd/compat.h> #include <linux/mtd/mtd.h> #include <linux/mtd/nand.h> @@ -32,7 +35,6 @@ typedef struct mtd_info nand_info_t;
extern int nand_curr_device; extern nand_info_t nand_info[]; -extern void nand_init(void);
static inline int nand_read(nand_info_t *info, off_t ofs, size_t *len, u_char *buf) { @@ -122,4 +124,5 @@ int nand_get_lock_status(nand_info_t *meminfo, ulong offset); void board_nand_select_device(struct nand_chip *nand, int chip); #endif
+#endif /* !CFG_NAND_LEGACY */ #endif
Scott Wood
