Dear All,
I'm trying to do a firmware update on my BeagleBone Black using DFU and nearly getting there:
U-Boot# dfu 0 mmc 1 GADGET DRIVER: usb_dnl_dfu musb-hdrc: peripheral reset irq lost!
MMC write: dev # 0, block # 63, count 762 ... 762 blocks write: OK # DFU complete CRC32: 0xee7826ec DOWNLOAD ... OK Ctrl+C to exit ... U-Boot#
However, the problem is that I'm trying to write to MMC #1 (eMMC), but U-Boot updates MMC #0 (SD card) as it can be seen from the output above.
Is this a bug in U-Boot or I am doing something wrong?
I'm using U-Boot version: u-boot-2013.10-ti2013.12.01 (from TI Sitara SDK 07).
Thanks, -Tamás
Hi Tamás,
Dear All,
It is strange. I will look into this tomorrow.
BTW: Are you sure that the mmc dev points to correct mmc device? Could you check this for me?
Thanks, -Tamás _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi Lukasz,
I'm not sure what to check. Could you specify it more exactly? I'm quite sure that on the BeagleBone Black MMC0 is the SD card and MMC1 is the eMMC.
I'm not familiar with the U-Boot source code, but what I was trying to point out is that the <dev> parameter from the dfu command might be ignored by the writing routine:
1) This is the usage of the dfu command:
dfu <USB_controller> <interface> <dev> [list]
2) So, this command should write to MMC1:
U-Boot# dfu 0 mmc 1
3) But the output of the command above indicates writing to MMC0:
In accordance to the message above the SD card (MMC0) was overwritten. Let me know how I can help to sort this out.
Thanks, -Tamás
On 2014-08-18 15:53, Lukasz Majewski wrote:
Hi Tamás,
Dear All,
Hi Tamás,
Hi Lukasz,
- This is the usage of the dfu command:
- So, this command should write to MMC1:
U-Boot# dfu 0 mmc 1
This is strange since the "1" here specify the mmc device.
Could you type when SD and eMMC is inserted: "mmc list" and then
"mmc part" mmc dev 1 "mmc part" mmc dev 0
and paste the output?
As fair as I noticed on my board (TRATS2): MMC0 is eMMC and MMC2 = SD.
On beagle bone black it is the opposite: MMC0 is SD and MMC1 is eMMC.
- But the output of the command above indicates writing to MMC0:
Thanks, -Tamás
Hi Tamás,
Dear All,
Lukasz Majewski
Tamás Bondár
