[U-Boot] [PATCH] kbuild: Rename UIMAGE to MKIMAGE
U-Boot uses the 'mkimage' tool to produce various image types, not only uImage image type. Rename the invocation name from UIMAGE to MKIMAGE.
The following command was used to do the replacement: git grep 'quiet_cmd_mkimage.* = UIMAGE' | cut -d : -f 1 | \ xargs -i sed -i "s@(quiet_cmd_mkimage)(.*) = UIMAGE @\1\2 = MKIMAGE@" {}
Signed-off-by: Marek Vasut marex@denx.de Cc: Tom Rini trini@ti.com Cc: Masahiro Yamada yamada.m@jp.panasonic.com --- Makefile | 2 +- arch/arm/cpu/arm926ejs/mxs/Makefile | 2 +- arch/arm/imx-common/Makefile | 2 +- board/cray/L1/Makefile | 2 +- board/matrix_vision/mvblm7/Makefile | 2 +- board/matrix_vision/mvsmr/Makefile | 2 +- spl/Makefile | 2 +- 7 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/Makefile b/Makefile index 538c3bf..e723218 100644 --- a/Makefile +++ b/Makefile @@ -728,7 +728,7 @@ endif quiet_cmd_objcopy = OBJCOPY $@ cmd_objcopy = $(OBJCOPY) $(OBJCOPYFLAGS) $(OBJCOPYFLAGS_$(@F)) $< $@
-quiet_cmd_mkimage = UIMAGE $@ +quiet_cmd_mkimage = MKIMAGE $@ cmd_mkimage = $(objtree)/tools/mkimage $(MKIMAGEFLAGS_$(@F)) -d $< $@ \ $(if $(KBUILD_VERBOSE:1=), >/dev/null)
diff --git a/arch/arm/cpu/arm926ejs/mxs/Makefile b/arch/arm/cpu/arm926ejs/mxs/Makefile index 1eee661..209c73c 100644 --- a/arch/arm/cpu/arm926ejs/mxs/Makefile +++ b/arch/arm/cpu/arm926ejs/mxs/Makefile @@ -17,7 +17,7 @@ endif MKIMAGE_TARGET-$(CONFIG_MX23) = mxsimage.mx23.cfg MKIMAGE_TARGET-$(CONFIG_MX28) = mxsimage.mx28.cfg
-quiet_cmd_mkimage_mxs = UIMAGE $@ +quiet_cmd_mkimage_mxs = MKIMAGE $@ cmd_mkimage_mxs = $(objtree)/tools/mkimage -n $< -T mxsimage $@ \ $(if $(KBUILD_VERBOSE:1=), >/dev/null)
diff --git a/arch/arm/imx-common/Makefile b/arch/arm/imx-common/Makefile index 16809fe..7334e05 100644 --- a/arch/arm/imx-common/Makefile +++ b/arch/arm/imx-common/Makefile @@ -32,7 +32,7 @@ $(IMX_CONFIG): %.cfgtmp: % FORCE $(Q)mkdir -p $(dir $@) $(call if_changed_dep,cpp_cfg)
diff --git a/board/cray/L1/Makefile b/board/cray/L1/Makefile index 655f530..5540298 100644 --- a/board/cray/L1/Makefile +++ b/board/cray/L1/Makefile @@ -15,7 +15,7 @@ quiet_cmd_awk = AWK $@ $(obj)/bootscript.c: $(obj)/bootscript.image $(src)/x2c.awk $(call cmd,awk)
diff --git a/board/matrix_vision/mvblm7/Makefile b/board/matrix_vision/mvblm7/Makefile index b5987fd..9ed2837 100644 --- a/board/matrix_vision/mvblm7/Makefile +++ b/board/matrix_vision/mvblm7/Makefile @@ -8,7 +8,7 @@ obj-y := mvblm7.o pci.o fpga.o
extra-y := bootscript.img
diff --git a/board/matrix_vision/mvsmr/Makefile b/board/matrix_vision/mvsmr/Makefile index fae7ec2..a9c794e 100644 --- a/board/matrix_vision/mvsmr/Makefile +++ b/board/matrix_vision/mvsmr/Makefile @@ -12,7 +12,7 @@ obj-y := mvsmr.o fpga.o
diff --git a/spl/Makefile b/spl/Makefile index be5fd3b..9f5dbf4 100644 --- a/spl/Makefile +++ b/spl/Makefile @@ -171,7 +171,7 @@ LDPPFLAGS += \ $(shell $(LD) --version | \ sed -ne 's/GNU ld version ([0-9][0-9]*).([0-9][0-9]*).*/-DLD_MAJOR=\1 -DLD_MINOR=\2/p')
Hello Marek,
Acked-by: Masahiro Yamada yamada.m@jp.panasonic.com
Signed-off-by: Marek Vasut marex@denx.de Cc: Tom Rini trini@ti.com Cc: Masahiro Yamada yamada.m@jp.panasonic.com Acked-by: Masahiro Yamada yamada.m@jp.panasonic.com
Masahiro Yamada
