[PATCH] mtd: spi-nor-ids: Add support for flashes tested by xilinx
Add support for various flashes from below manufacturers which are tested by xilinx for years.
EON: en25q128b GIGA: gd25lx256e ISSI: is25lp008 is25lp016 is25lp01g is25wp008 is25wp016 is25wp01g is25wx256 MACRONIX: mx25u51245f mx66u1g45g mx66l2g45g MICRON: mt35xl512aba mt35xu01g SPANSION: s70fs01gs_256k SST: sst26wf016b WINBOND: w25q16dw w25q16jv w25q512jv w25q32bv w25h02jv
Signed-off-by: Ashok Reddy Soma ashok.reddy.soma@xilinx.com ---
drivers/mtd/spi/spi-nor-ids.c | 37 +++++++++++++++++++++++++++++++++++ 1 file changed, 37 insertions(+)
diff --git a/drivers/mtd/spi/spi-nor-ids.c b/drivers/mtd/spi/spi-nor-ids.c index 7050ddc397..5d8bf05ff8 100644 --- a/drivers/mtd/spi/spi-nor-ids.c +++ b/drivers/mtd/spi/spi-nor-ids.c @@ -82,6 +82,7 @@ const struct flash_info spi_nor_ids[] = { /* EON -- en25xxx */ { INFO("en25q32b", 0x1c3016, 0, 64 * 1024, 64, 0) }, { INFO("en25q64", 0x1c3017, 0, 64 * 1024, 128, SECT_4K) }, + { INFO("en25q128b", 0x1c3018, 0, 64 * 1024, 256, 0) }, { INFO("en25qh128", 0x1c7018, 0, 64 * 1024, 256, 0) }, { INFO("en25s64", 0x1c3817, 0, 64 * 1024, 128, SECT_4K) }, #endif @@ -127,11 +128,17 @@ const struct flash_info spi_nor_ids[] = { SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) }, + { + INFO("gd25lx256e", 0xc86819, 0, 64 * 1024, 512, + SECT_4K | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES) + }, #endif #ifdef CONFIG_SPI_FLASH_ISSI /* ISSI */ /* ISSI */ { INFO("is25lq040b", 0x9d4013, 0, 64 * 1024, 8, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("is25lp008", 0x9d6014, 0, 64 * 1024, 16, SPI_NOR_QUAD_READ) }, + { INFO("is25lp016", 0x9d6015, 0, 64 * 1024, 32, SPI_NOR_QUAD_READ) }, { INFO("is25lp032", 0x9d6016, 0, 64 * 1024, 64, 0) }, { INFO("is25lp064", 0x9d6017, 0, 64 * 1024, 128, 0) }, { INFO("is25lp128", 0x9d6018, 0, 64 * 1024, 256, @@ -140,6 +147,10 @@ const struct flash_info spi_nor_ids[] = { SECT_4K | SPI_NOR_DUAL_READ) }, { INFO("is25lp512", 0x9d601a, 0, 64 * 1024, 1024, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("is25lp01g", 0x9d601b, 0, 64 * 1024, 2048, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("is25wp008", 0x9d7014, 0, 64 * 1024, 16, SPI_NOR_QUAD_READ) }, + { INFO("is25wp016", 0x9d7015, 0, 64 * 1024, 32, SPI_NOR_QUAD_READ) }, { INFO("is25wp032", 0x9d7016, 0, 64 * 1024, 64, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("is25wp064", 0x9d7017, 0, 64 * 1024, 128, @@ -151,6 +162,10 @@ const struct flash_info spi_nor_ids[] = { SPI_NOR_4B_OPCODES) }, { INFO("is25wp512", 0x9d701a, 0, 64 * 1024, 1024, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("is25wp01g", 0x9d701b, 0, 64 * 1024, 2048, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("is25wx256", 0x9d5b19, 0, 128 * 1024, 256, + SECT_4K | USE_FSR | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES) }, #endif #ifdef CONFIG_SPI_FLASH_MACRONIX /* MACRONIX */ /* Macronix */ @@ -176,8 +191,11 @@ const struct flash_info spi_nor_ids[] = { { INFO("mx25l25655e", 0xc22619, 0, 64 * 1024, 512, 0) }, { INFO("mx66l51235l", 0xc2201a, 0, 64 * 1024, 1024, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, { INFO("mx66u51235f", 0xc2253a, 0, 64 * 1024, 1024, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25u51245f", 0xc2953a, 0, 64 * 1024, 1024, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx66u1g45g", 0xc2253b, 0, 64 * 1024, 2048, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, { INFO("mx66u2g45g", 0xc2253c, 0, 64 * 1024, 4096, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, { INFO("mx66l1g45g", 0xc2201b, 0, 64 * 1024, 2048, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("mx66l2g45g", 0xc2201c, 0, 64 * 1024, 4096, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, { INFO("mx25l1633e", 0xc22415, 0, 64 * 1024, 32, SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES | SECT_4K) }, { INFO("mx25r6435f", 0xc22817, 0, 64 * 1024, 128, SECT_4K) }, { INFO("mx66uw2g345g", 0xc2943c, 0, 64 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES) }, @@ -208,8 +226,10 @@ const struct flash_info spi_nor_ids[] = { { INFO("mt25qu02g", 0x20bb22, 0, 64 * 1024, 4096, SECT_4K | USE_FSR | SPI_NOR_QUAD_READ | NO_CHIP_ERASE) }, { INFO("mt25ql02g", 0x20ba22, 0, 64 * 1024, 4096, SECT_4K | USE_FSR | SPI_NOR_QUAD_READ | NO_CHIP_ERASE | SPI_NOR_4B_OPCODES) }, #ifdef CONFIG_SPI_FLASH_MT35XU + { INFO("mt35xl512aba", 0x2c5a1a, 0, 128 * 1024, 512, USE_FSR | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES | SPI_NOR_OCTAL_DTR_READ) }, { INFO("mt35xu512aba", 0x2c5b1a, 0, 128 * 1024, 512, USE_FSR | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES | SPI_NOR_OCTAL_DTR_READ) }, #endif /* CONFIG_SPI_FLASH_MT35XU */ + { INFO6("mt35xu01g", 0x2c5b1b, 0x104100, 128 * 1024, 1024, USE_FSR | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES) }, { INFO("mt35xu02g", 0x2c5b1c, 0, 128 * 1024, 2048, USE_FSR | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES) }, #endif #ifdef CONFIG_SPI_FLASH_SPANSION /* SPANSION */ @@ -225,6 +245,7 @@ const struct flash_info spi_nor_ids[] = { { INFO("s25fl512s_256k", 0x010220, 0x4d00, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, { INFO("s25fl512s_64k", 0x010220, 0x4d01, 64 * 1024, 1024, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, { INFO("s25fl512s_512k", 0x010220, 0x4f00, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, + { INFO("s70fs01gs_256k", 0x010221, 0x4d00, 256 * 1024, 512, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("s25sl12800", 0x012018, 0x0300, 256 * 1024, 64, 0) }, { INFO("s25sl12801", 0x012018, 0x0301, 64 * 1024, 256, 0) }, { INFO6("s25fl128s", 0x012018, 0x4d0180, 64 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, @@ -275,6 +296,7 @@ const struct flash_info spi_nor_ids[] = { { INFO("sst25wf040", 0xbf2504, 0, 64 * 1024, 8, SECT_4K | SST_WRITE) }, { INFO("sst25wf080", 0xbf2505, 0, 64 * 1024, 16, SECT_4K | SST_WRITE) }, { INFO("sst26vf064b", 0xbf2643, 0, 64 * 1024, 128, SECT_4K | SPI_NOR_HAS_SST26LOCK | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("sst26wf016b", 0xbf2641, 0, 64 * 1024, 32, SECT_4K) }, { INFO("sst26wf016", 0xbf2651, 0, 64 * 1024, 32, SECT_4K | SPI_NOR_HAS_SST26LOCK) }, { INFO("sst26wf032", 0xbf2622, 0, 64 * 1024, 64, SECT_4K | SPI_NOR_HAS_SST26LOCK) }, { INFO("sst26wf064", 0xbf2643, 0, 64 * 1024, 128, SECT_4K | SPI_NOR_HAS_SST26LOCK) }, @@ -311,11 +333,19 @@ const struct flash_info spi_nor_ids[] = { { INFO("w25q20bw", 0xef5012, 0, 64 * 1024, 4, SECT_4K) }, { INFO("w25q20ew", 0xef6012, 0, 64 * 1024, 4, SECT_4K) }, { INFO("w25q32", 0xef4016, 0, 64 * 1024, 64, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { + INFO("w25q16dw", 0xef6015, 0, 64 * 1024, 32, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) + }, { INFO("w25q32dw", 0xef6016, 0, 64 * 1024, 64, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) }, + { + INFO("w25q16jv", 0xef7015, 0, 64 * 1024, 32, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) + }, { INFO("w25q32jv", 0xef7016, 0, 64 * 1024, 64, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | @@ -362,6 +392,11 @@ const struct flash_info spi_nor_ids[] = { SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) }, + { + INFO("w25q512jv", 0xef7119, 0, 64 * 1024, 512, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) + }, { INFO("w25q01jv", 0xef4021, 0, 64 * 1024, 2048, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | @@ -370,6 +405,7 @@ const struct flash_info spi_nor_ids[] = { { INFO("w25q80", 0xef5014, 0, 64 * 1024, 16, SECT_4K) }, { INFO("w25q80bl", 0xef4014, 0, 64 * 1024, 16, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("w25q16cl", 0xef4015, 0, 64 * 1024, 32, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("w25q32bv", 0xef4016, 0, 64 * 1024, 64, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("w25q64cv", 0xef4017, 0, 64 * 1024, 128, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("w25q128", 0xef4018, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | @@ -378,6 +414,7 @@ const struct flash_info spi_nor_ids[] = { { INFO("w25q256", 0xef4019, 0, 64 * 1024, 512, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("w25m512jw", 0xef6119, 0, 64 * 1024, 1024, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("w25m512jv", 0xef7119, 0, 64 * 1024, 1024, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + { INFO("w25h02jv", 0xef9022, 0, 64 * 1024, 4096, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, #endif #ifdef CONFIG_SPI_FLASH_XMC /* XMC (Wuhan Xinxin Semiconductor Manufacturing Corp.) */
- { INFO("en25q128b", 0x1c3018, 0, 64 * 1024, 256, 0) }, { INFO("en25qh128", 0x1c7018, 0, 64 * 1024, 256, 0) }, { INFO("en25s64", 0x1c3817, 0, 64 * 1024, 128, SECT_4K) }, #endif
- }, #endif #ifdef CONFIG_SPI_FLASH_ISSI /* ISSI */ /* ISSI */ { INFO("is25lq040b", 0x9d4013, 0, 64 * 1024, 8, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) },
- { INFO("is25lp008", 0x9d6014, 0, 64 * 1024, 16, SPI_NOR_QUAD_READ) },
- { INFO("is25lp016", 0x9d6015, 0, 64 * 1024, 32, SPI_NOR_QUAD_READ) }, { INFO("is25lp032", 0x9d6016, 0, 64 * 1024, 64, 0) }, { INFO("is25lp064", 0x9d6017, 0, 64 * 1024, 128, 0) }, { INFO("is25lp128", 0x9d6018, 0, 64 * 1024, 256,
- { INFO("is25lp01g", 0x9d601b, 0, 64 * 1024, 2048,
- { INFO("is25wp008", 0x9d7014, 0, 64 * 1024, 16, SPI_NOR_QUAD_READ) },
- { INFO("is25wp016", 0x9d7015, 0, 64 * 1024, 32, SPI_NOR_QUAD_READ) }, { INFO("is25wp032", 0x9d7016, 0, 64 * 1024, 64, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("is25wp064", 0x9d7017, 0, 64 * 1024, 128,
- { INFO("is25wp01g", 0x9d701b, 0, 64 * 1024, 2048,
- { INFO("is25wx256", 0x9d5b19, 0, 128 * 1024, 256,
#endif #ifdef CONFIG_SPI_FLASH_MACRONIX /* MACRONIX */ /* Macronix */SECT_4K | USE_FSR | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES) },
- { INFO("mx25u51245f", 0xc2953a, 0, 64 * 1024, 1024, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) },
- { INFO("mx66u1g45g", 0xc2253b, 0, 64 * 1024, 2048, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, { INFO("mx66u2g45g", 0xc2253c, 0, 64 * 1024, 4096, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, { INFO("mx66l1g45g", 0xc2201b, 0, 64 * 1024, 2048, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) },
- { INFO("mx66l2g45g", 0xc2201c, 0, 64 * 1024, 4096, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES) }, { INFO("mx25l1633e", 0xc22415, 0, 64 * 1024, 32, SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES | SECT_4K) }, { INFO("mx25r6435f", 0xc22817, 0, 64 * 1024, 128, SECT_4K) }, { INFO("mx66uw2g345g", 0xc2943c, 0, 64 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES) },
- { INFO("mt35xl512aba", 0x2c5a1a, 0, 128 * 1024, 512, USE_FSR | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES | SPI_NOR_OCTAL_DTR_READ) }, { INFO("mt35xu512aba", 0x2c5b1a, 0, 128 * 1024, 512, USE_FSR | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES | SPI_NOR_OCTAL_DTR_READ) }, #endif /* CONFIG_SPI_FLASH_MT35XU */
- { INFO6("mt35xu01g", 0x2c5b1b, 0x104100, 128 * 1024, 1024, USE_FSR | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES) }, { INFO("mt35xu02g", 0x2c5b1c, 0, 128 * 1024, 2048, USE_FSR | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES) }, #endif #ifdef CONFIG_SPI_FLASH_SPANSION /* SPANSION */
- { INFO("s70fs01gs_256k", 0x010221, 0x4d00, 256 * 1024, 512, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("s25sl12800", 0x012018, 0x0300, 256 * 1024, 64, 0) }, { INFO("s25sl12801", 0x012018, 0x0301, 64 * 1024, 256, 0) }, { INFO6("s25fl128s", 0x012018, 0x4d0180, 64 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) },
- { INFO("sst26wf016b", 0xbf2641, 0, 64 * 1024, 32, SECT_4K) }, { INFO("sst26wf016", 0xbf2651, 0, 64 * 1024, 32, SECT_4K | SPI_NOR_HAS_SST26LOCK) }, { INFO("sst26wf032", 0xbf2622, 0, 64 * 1024, 64, SECT_4K | SPI_NOR_HAS_SST26LOCK) }, { INFO("sst26wf064", 0xbf2643, 0, 64 * 1024, 128, SECT_4K | SPI_NOR_HAS_SST26LOCK) },
- }, { INFO("w25q32dw", 0xef6016, 0, 64 * 1024, 64, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | SPI_NOR_HAS_LOCK | SPI_NOR_HAS_TB) },
- }, { INFO("w25q32jv", 0xef7016, 0, 64 * 1024, 64, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ |
- }, { INFO("w25q01jv", 0xef4021, 0, 64 * 1024, 2048, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ |
- { INFO("w25q32bv", 0xef4016, 0, 64 * 1024, 64, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("w25q64cv", 0xef4017, 0, 64 * 1024, 128, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("w25q128", 0xef4018, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ |
- { INFO("w25h02jv", 0xef9022, 0, 64 * 1024, 4096, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, #endif #ifdef CONFIG_SPI_FLASH_XMC /* XMC (Wuhan Xinxin Semiconductor Manufacturing Corp.) */
fyi: This has been merged to next by Tom.
M
Ashok Reddy Soma
Michal Simek
