[U-Boot-Users] question of codes in \cpu\74xx_7xx\cache.S
intercepted from \cpu\74xx_7xx\cache.S
/* * Enable L1 Instruction cache */ _GLOBAL(icache_enable) mfspr r3, HID0 li r5, HID0_ICFI|HID0_ILOCK andc r3, r3, r5 ori r3, r3, HID0_ICE ori r5, r3, HID0_ICFI mtspr HID0, r5 // this instruction is redundant, mtspr HID0, r3 // or this one? isync blr
-lxg
- Enable L1 Instruction cache
-lxg
Most likely neither are redundant. To say for sure, you need to read the User's Manual for the 74xx family where it specifies how to change the HID0 register.
Changing the HID0 register (and other processor control registers) require certain "magic" sequences that the chip designers specify. If the software doesn't do the specified sequence *exactly,* there is no guarantee that the processor will run properly (indeed, it likely will crash).
The above code was written by very smart engineers who read and re-read the User's Manual. The sequence has been working for several years now. Odds are really good that it is exactly what is needed.
HTH, gvb
gvb.uboot
