Re: [U-Boot-Users] Boot direct on SATA drive
I have a Intel 31244 (PCI-X to SATA). This component supports 2 modes : IDE or DPA (Direct Port Access) and we use it in DPA. It's work fine in DPA mode under Linux with driver Vitesse (sata_vsc.c). DPA mode seems to be like IDE unlike : - access type (memory instead of i/o) - registers offsets (4 independents ports instead of Master/Slave config).
To boot with SII3112 in IDE mode, did you need to patch cmd_ide or standard code works ?
Depends on the SATA disk controller. I've booted a SII3112
directly
using the ATA driver sice that chip happens to have a IDE (PATA) compatability layer. Newer controllers use AHCI standard for the interface, and
needs a
completely different driver. I ended up just booting the kernel image from FLASH instead....
Accédez au courrier électronique de La Poste sur www.laposte.net ou sur 3615 LAPOSTENET (0,34 TTC /mn) 1 Giga de stockage gratuit Antispam et antivirus intégrés
-----Original Message----- From: sebastien.douheret [mailto:sebastien.douheret@laposte.net] Sent: Tuesday, October 03, 2006 10:57 To boot with SII3112 in IDE mode, did you need to patch cmd_ide or standard code works ?
No, only thing I had to do was setting the CFG_ATA_BASE_ADDR to point to BAR5 of the controller.
Rune Torgersen
sebastien.douheret
