[U-Boot] Please pull u-boot-fsl-qoriq master
Tom,
The following changes since commit 38dac81b3d0e777f301ca98100bfbcab01d616c2:
Merge branch 'master' of git://git.denx.de/u-boot-mmc (2015-02-23 16:18:06 -0500)
git://git.denx.de/u-boot-fsl-qoriq.git master
for you to fetch changes up to 94e3c8c4fd7bfe395fa467973cd647551d6d98c7:
crypto/fsl - Add progressive hashing support using hardware acceleration. (2015-02-25 13:20:02 -0800)
---------------------------------------------------------------- Alison Wang (2): arm: ls102xa: Define default values for some CCSR macros arm: ls1021x: Add support for initializing CAAM's stream id
Arnab Basu (2): ARMv8/fsl-lsch3: Patch cpu node properties in DT for online cores ARMv8/ls2085a: Switch to passing earlycon to kernel
Bhupesh Sharma (3): fsl-ch3/lowlevel: TZPC and TZASC programming to configure non-secure accesses armv8/fsl-lsch3: Add fdt-fixup for clock frequency of the DUART nodes ls2085/configs: Ensure right banners are printed for EMU and SIMU
J. German Rivera (1): drivers/mc: Migrated MC Flibs to 0.5.2
Kuldip Giroh (1): ARMv8/LS2085A: HugeTLB support is required by default in LS NADK
Minghuan Lian (4): arm/ls102xa: create TLB to map PCIe region arm/ls102xa: use a array to define pexmscportsr arm/ls1021a: add PCIe settings driver/pci: add Layerscape PCIe driver
Stuart Yoder (1): ARMv8/ls2085a: Move kernel image load address
Volodymyr Riazantsev (1): mmc: fsl_esdhc: Add support for DDR mode
York Sun (15): armv8/fsl-lsch3: Change normal memory shareability armv8/fsl-lsch3: Convert flushing L3 to assembly to avoid using stack armv8/ls2085a: Enable cluster timebase for all clusters driver/ddr/fsl: Adjust CAS to preamble override for emulator driver/ddr/fsl: Add workaround for A008336 driver/ddr/fsl: Add workround for erratumn A008514 armv8/fsl-lsch3: Add support for second DDR clock driver/ddr/fsl: Add support for multiple DDR clocks ARMv8/LS2085A: Enable auto precharge for DP-DDR driver/ddr/fsl: Fix a typo in timing_cfg_8 calculation ARMv8/LS2085A: Adjust system clock and DDR clock driver/ddr/fsl: Add sync of refresh armv8/fsl-lsch3: Enable workaround for A008336 armv8/fsl-lsch3: Enable erratum workround for A008514 armv8/ls2085a_emu: Enable sync of refresh
chenhui zhao (1): arm: ls102xa: workaround for cache coherency problem
gaurav rana (2): crypto/fsl: Make function names consistent for blob encapsulation/decapsulation. crypto/fsl - Add progressive hashing support using hardware acceleration.
Kconfig | 4 +- README | 23 +- arch/arm/cpu/armv7/ls102xa/cpu.c | 231 +++++++++- arch/arm/cpu/armv8/cache.S | 6 + arch/arm/cpu/armv8/cache_v8.c | 18 +- arch/arm/cpu/armv8/fsl-lsch3/cpu.c | 62 +-- arch/arm/cpu/armv8/fsl-lsch3/fdt.c | 28 +- arch/arm/cpu/armv8/fsl-lsch3/lowlevel.S | 132 ++++++ arch/arm/cpu/armv8/fsl-lsch3/mp.c | 8 + arch/arm/cpu/armv8/fsl-lsch3/mp.h | 1 + arch/arm/cpu/armv8/fsl-lsch3/speed.c | 16 +- arch/arm/include/asm/arch-fsl-lsch3/config.h | 38 ++ arch/arm/include/asm/arch-fsl-lsch3/immap_lsch3.h | 3 + arch/arm/include/asm/arch-ls102xa/config.h | 15 + arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h | 40 +- .../include/asm/arch-ls102xa/ls102xa_stream_id.h | 57 +++ arch/arm/include/asm/armv8/mmu.h | 3 +- arch/arm/include/asm/global_data.h | 3 + arch/arm/include/asm/system.h | 1 + arch/arm/lib/bootm.c | 2 +- board/freescale/common/ls102xa_stream_id.c | 15 + board/freescale/ls1021aqds/ls1021aqds.c | 21 + board/freescale/ls1021atwr/ls1021atwr.c | 21 + board/freescale/ls2085a/ddr.c | 1 + board/freescale/ls2085a/ls2085a.c | 29 +- common/cmd_blob.c | 18 +- common/hash.c | 10 + doc/README.fsl-trustzone-components | 25 ++ drivers/crypto/fsl/fsl_blob.c | 4 +- drivers/crypto/fsl/fsl_hash.c | 138 +++++- drivers/crypto/fsl/fsl_hash.h | 34 ++ drivers/ddr/fsl/arm_ddr_gen3.c | 2 +- drivers/ddr/fsl/ctrl_regs.c | 216 +++++---- drivers/ddr/fsl/ddr1_dimm_params.c | 18 +- drivers/ddr/fsl/ddr2_dimm_params.c | 12 +- drivers/ddr/fsl/ddr3_dimm_params.c | 8 +- drivers/ddr/fsl/ddr4_dimm_params.c | 8 +- drivers/ddr/fsl/fsl_ddr_gen4.c | 36 +- drivers/ddr/fsl/lc_common_dimm_params.c | 27 +- drivers/ddr/fsl/main.c | 29 +- drivers/ddr/fsl/mpc85xx_ddr_gen3.c | 4 +- drivers/ddr/fsl/options.c | 6 +- drivers/ddr/fsl/util.c | 67 ++- drivers/mmc/fsl_esdhc.c | 8 +- drivers/net/Makefile | 2 +- drivers/net/{fsl_mc => fsl-mc}/Makefile | 4 +- drivers/net/fsl-mc/dpmng.c | 91 ++++ drivers/net/fsl-mc/fsl_dpmng_cmd.h | 49 ++ drivers/net/{fsl_mc => fsl-mc}/mc.c | 132 ++++-- drivers/net/fsl-mc/mc_sys.c | 63 +++ drivers/pci/pcie_layerscape.c | 471 +++++++++++++++++++- include/configs/ls1021aqds.h | 24 + include/configs/ls1021atwr.h | 24 + include/configs/ls2085a_common.h | 19 +- include/configs/ls2085a_emu.h | 4 + include/configs/ls2085a_simu.h | 3 + include/configs/mx6_common.h | 2 + include/fsl-mc/fsl_dpmng.h | 121 +++++ include/{ => fsl-mc}/fsl_mc.h | 0 include/fsl-mc/fsl_mc_cmd.h | 132 ++++++ include/fsl-mc/fsl_mc_sys.h | 26 ++ include/fsl_ddr.h | 17 +- include/fsl_ddr_dimm_params.h | 2 +- include/fsl_esdhc.h | 1 + include/fsl_sec.h | 26 ++ include/hw_sha.h | 41 +- lib/Kconfig | 36 ++ 67 files changed, 2404 insertions(+), 334 deletions(-) create mode 100644 doc/README.fsl-trustzone-components create mode 100644 drivers/crypto/fsl/fsl_hash.h rename drivers/net/{fsl_mc => fsl-mc}/Makefile (75%) create mode 100644 drivers/net/fsl-mc/dpmng.c create mode 100644 drivers/net/fsl-mc/fsl_dpmng_cmd.h rename drivers/net/{fsl_mc => fsl-mc}/mc.c (67%) create mode 100644 drivers/net/fsl-mc/mc_sys.c create mode 100644 include/fsl-mc/fsl_dpmng.h rename include/{ => fsl-mc}/fsl_mc.h (100%) create mode 100644 include/fsl-mc/fsl_mc_cmd.h create mode 100644 include/fsl-mc/fsl_mc_sys.h
Thanks.
York
On Wed, Feb 25, 2015 at 01:29:17PM -0800, York Sun wrote:
Tom,
York Sun
