[U-Boot] [PATCHv4] arm: socfpga: Enable saveenv for SD/MMC
Enable the able to save the environment variables when SD/MMC is used.
Signed-off-by: Dinh Nguyen dinguyen@opensource.altera.com --- v4: Move ENV_IS_NOWHERE to the mcvevk board config file v3: Only define ENV_IS_NOWHERE if env is not in MMC, NAND, FAT, and SPI_FLASH v2: Move this option to be on a per-board basis Add config for socfpga_cyclone5 and socfpga_arria5 --- include/configs/socfpga_arria5_socdk.h | 4 ++++ include/configs/socfpga_common.h | 1 - include/configs/socfpga_cyclone5_socdk.h | 4 ++++ include/configs/socfpga_de0_nano_soc.h | 4 ++++ include/configs/socfpga_mcvevk.h | 2 ++ include/configs/socfpga_sockit.h | 4 ++++ 6 files changed, 18 insertions(+), 1 deletion(-)
diff --git a/include/configs/socfpga_arria5_socdk.h b/include/configs/socfpga_arria5_socdk.h index 3193684..b75b0a2 100644 --- a/include/configs/socfpga_arria5_socdk.h +++ b/include/configs/socfpga_arria5_socdk.h @@ -59,6 +59,10 @@
#endif
+#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 /* device 0 */ +#define CONFIG_ENV_OFFSET 512 /* just after the MBR */ + /* USB */ #ifdef CONFIG_CMD_USB #define CONFIG_USB_DWC2_REG_ADDR SOCFPGA_USB1_ADDRESS diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index a2811ba..cece095 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -281,7 +281,6 @@ unsigned int cm_get_qspi_controller_clk_hz(void); #define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_SYS_CONSOLE_ENV_OVERWRITE -#define CONFIG_ENV_IS_NOWHERE #define CONFIG_ENV_SIZE 4096
/* diff --git a/include/configs/socfpga_cyclone5_socdk.h b/include/configs/socfpga_cyclone5_socdk.h index 9e733e5..fa67b25 100644 --- a/include/configs/socfpga_cyclone5_socdk.h +++ b/include/configs/socfpga_cyclone5_socdk.h @@ -59,6 +59,10 @@
#endif
+#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 /* device 0 */ +#define CONFIG_ENV_OFFSET 512 /* just after the MBR */ + /* USB */ #ifdef CONFIG_CMD_USB #define CONFIG_USB_DWC2_REG_ADDR SOCFPGA_USB1_ADDRESS diff --git a/include/configs/socfpga_de0_nano_soc.h b/include/configs/socfpga_de0_nano_soc.h index 2508d03..191e1f7 100644 --- a/include/configs/socfpga_de0_nano_soc.h +++ b/include/configs/socfpga_de0_nano_soc.h @@ -55,6 +55,10 @@
#endif
+#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 /* device 0 */ +#define CONFIG_ENV_OFFSET 512 /* just after the MBR */ + /* USB */ #ifdef CONFIG_CMD_USB #define CONFIG_USB_DWC2_REG_ADDR SOCFPGA_USB1_ADDRESS diff --git a/include/configs/socfpga_mcvevk.h b/include/configs/socfpga_mcvevk.h index c5b4b4c..ed9b5cc 100644 --- a/include/configs/socfpga_mcvevk.h +++ b/include/configs/socfpga_mcvevk.h @@ -43,6 +43,8 @@ #define CONFIG_LOADADDR 0x01000000 #define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR
+#define CONFIG_ENV_IS_NOWHERE + /* USB */ #ifdef CONFIG_CMD_USB #define CONFIG_USB_DWC2_REG_ADDR SOCFPGA_USB1_ADDRESS diff --git a/include/configs/socfpga_sockit.h b/include/configs/socfpga_sockit.h index 747e988..6c71ef4 100644 --- a/include/configs/socfpga_sockit.h +++ b/include/configs/socfpga_sockit.h @@ -59,6 +59,10 @@
#endif
On Wednesday, September 23, 2015 at 10:38:01 PM, dinguyen@opensource.altera.com wrote:
Applied, thanks!
Best regards, Marek Vasut
dinguyenï¼ opensource.altera.com
