[PATCH 00/10] meson: enable USB Gadget support fot GXL/GXM SoCs
Thit patchset adds support for OTG Gadget mode on the GXL/GXM SoCs.
It adds a new API generic_phy_get_by_node() to get the PHY by it's node.
It enabled Gadget and USB Mass Storage for libretech-cc, libretech-ac, khadas-vim, khadas-vim2, libretech-s905d-pc and libretech-s912-pc boards.
Neil Armstrong (10): generic-phy: add generic_phy_get_by_node() phy: meson-gxl-usb: add set_mode call to force switch to peripheral mode arm: meson-gx: add board_usb_init()/cleanup() for USB gadget arm: dts: meson-gxl: Add USB Gadget nodes for U-Boot configs: libretech-cc: Enable USB gadget with Mass Storage function configs: libretech-ac: Enable USB gadget with Mass Storage function configs: khadas-vim2: Enable USB gadget with Mass Storage function configs: khadas-vim: Enable USB gadget with Mass Storage function configs: libretech-s905d-pc: Enable USB gadget with Mass Storage function configs: libretech-s912-pc: Enable USB gadget with Mass Storage function
.../meson-gxl-s905x-khadas-vim-u-boot.dtsi | 2 +- .../meson-gxl-s905x-libretech-cc-u-boot.dtsi | 6 +- arch/arm/dts/meson-gxl-s905x-p212-u-boot.dtsi | 2 +- arch/arm/dts/meson-gxl-u-boot.dtsi | 23 ++++ arch/arm/include/asm/arch-meson/usb-gx.h | 16 +++ arch/arm/mach-meson/board-gx.c | 118 ++++++++++++++++++ configs/khadas-vim2_defconfig | 7 ++ configs/khadas-vim_defconfig | 7 ++ configs/libretech-ac_defconfig | 7 ++ configs/libretech-cc_defconfig | 7 ++ configs/libretech-s905d-pc_defconfig | 7 ++ configs/libretech-s912-pc_defconfig | 7 ++ drivers/phy/meson-gxl-usb2.c | 30 ++++- drivers/phy/meson-gxl-usb3.c | 44 +++++-- drivers/phy/phy-uclass.c | 17 ++- include/generic-phy.h | 27 ++++ 16 files changed, 301 insertions(+), 26 deletions(-) create mode 100644 arch/arm/dts/meson-gxl-u-boot.dtsi create mode 100644 arch/arm/include/asm/arch-meson/usb-gx.h
Add generic_phy_get_by_node() to get a PHY phandle from a node instead of a udevice.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- drivers/phy/phy-uclass.c | 17 ++++++++++++----- include/generic-phy.h | 27 +++++++++++++++++++++++++++ 2 files changed, 39 insertions(+), 5 deletions(-)
diff --git a/drivers/phy/phy-uclass.c b/drivers/phy/phy-uclass.c index e201a90c8c..de2c3d2b8e 100644 --- a/drivers/phy/phy-uclass.c +++ b/drivers/phy/phy-uclass.c @@ -31,20 +31,20 @@ static int generic_phy_xlate_offs_flags(struct phy *phy, return 0; }
-int generic_phy_get_by_index(struct udevice *dev, int index, - struct phy *phy) +int generic_phy_get_by_node(ofnode node, int index, struct phy *phy) { struct ofnode_phandle_args args; struct phy_ops *ops; struct udevice *phydev; int i, ret;
- debug("%s(dev=%p, index=%d, phy=%p)\n", __func__, dev, index, phy); + debug("%s(node=%s, index=%d, phy=%p)\n", + __func__, ofnode_get_name(node), index, phy);
assert(phy); phy->dev = NULL; - ret = dev_read_phandle_with_args(dev, "phys", "#phy-cells", 0, index, - &args); + ret = ofnode_parse_phandle_with_args(node, "phys", "#phy-cells", 0, + index, &args); if (ret) { debug("%s: dev_read_phandle_with_args failed: err=%d\n", __func__, ret); @@ -88,6 +88,12 @@ int generic_phy_get_by_index(struct udevice *dev, int index,
err: return ret; +} + +int generic_phy_get_by_index(struct udevice *dev, int index, + struct phy *phy) +{ + return generic_phy_get_by_node(dev_ofnode(dev), index, phy); }
int generic_phy_get_by_name(struct udevice *dev, const char *phy_name, diff --git a/include/generic-phy.h b/include/generic-phy.h index 95caf58341..5873ffb2e0 100644 --- a/include/generic-phy.h +++ b/include/generic-phy.h @@ -193,6 +193,33 @@ int generic_phy_power_off(struct phy *phy); int generic_phy_get_by_index(struct udevice *user, int index, struct phy *phy);
+/** + * generic_phy_get_by_node() - Get a PHY device by integer index on ofnode + * + * @node: the device node + * @index: The index in the list of available PHYs + * @phy: A pointer to the PHY port + * + * This looks up a PHY device for a client device based on its ofnode and on + * its position in the list of the possible PHYs. + * + * example: + * usb1: usb_otg_ss@xxx { + * compatible = "xxx"; + * reg = <xxx>; + * . + * . + * phys = <&usb2_phy>, <&usb3_phy>; + * . + * . + * }; + * the USB2 phy can be accessed by passing index '0' and the USB3 phy can + * be accessed by passing index '1' + * + * @return 0 if OK, or a negative error code + */ +int generic_phy_get_by_node(ofnode node, int index, struct phy *phy); + /** * generic_phy_get_by_name() - Get a PHY device by its name. *
Tom, Marek,
Are you ok with this change ?
Neil
struct phy *phy)
&args);
- ret = ofnode_parse_phandle_with_args(node, "phys", "#phy-cells", 0,
if (ret) { debug("%s: dev_read_phandle_with_args failed: err=%d\n", __func__, ret);index, &args);
err: return ret; +}
struct phy *phy)
- return generic_phy_get_by_node(dev_ofnode(dev), index, phy);
- generic_phy_get_by_node() - Get a PHY device by integer index on ofnode
- @node: the device node
- @index: The index in the list of available PHYs
- @phy: A pointer to the PHY port
- This looks up a PHY device for a client device based on its ofnode and on
- its position in the list of the possible PHYs.
- example:
- usb1: usb_otg_ss@xxx {
compatible = "xxx";
reg = <xxx>;
- phys = <&usb2_phy>, <&usb3_phy>;
- the USB2 phy can be accessed by passing index '0' and the USB3 phy can
- be accessed by passing index '1'
- @return 0 if OK, or a negative error code
- generic_phy_get_by_name() - Get a PHY device by its name.
On Wed, Apr 15, 2020 at 06:14:18PM +0200, Neil Armstrong wrote:
Tom, Marek,
Neil
struct phy *phy)
&args);
err: return ret; +}
struct phy *phy)
- example:
compatible = "xxx";
reg = <xxx>;
Add set_mode function in the Amlogic GXL PHYs that will be called by the arch code to switch PHYs from/to gadget mode.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- arch/arm/include/asm/arch-meson/usb-gx.h | 16 +++++++++ drivers/phy/meson-gxl-usb2.c | 30 ++++++++++++---- drivers/phy/meson-gxl-usb3.c | 44 +++++++++++++++++------- 3 files changed, 72 insertions(+), 18 deletions(-) create mode 100644 arch/arm/include/asm/arch-meson/usb-gx.h
diff --git a/arch/arm/include/asm/arch-meson/usb-gx.h b/arch/arm/include/asm/arch-meson/usb-gx.h new file mode 100644 index 0000000000..aeb8e0c673 --- /dev/null +++ b/arch/arm/include/asm/arch-meson/usb-gx.h @@ -0,0 +1,16 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2019 BayLibre SAS + * Author: Neil Armstrong narmstrong@baylibre.com + */ +#ifndef _ARCH_MESON_USB_GX_H_ +#define _ARCH_MESON_USB_GX_H_ + +#include <generic-phy.h> +#include <linux/usb/otg.h> + +/* TOFIX add set_mode to struct phy_ops */ +void phy_meson_gxl_usb2_set_mode(struct phy *phy, enum usb_dr_mode mode); +void phy_meson_gxl_usb3_set_mode(struct phy *phy, enum usb_dr_mode mode); + +#endif diff --git a/drivers/phy/meson-gxl-usb2.c b/drivers/phy/meson-gxl-usb2.c index c98d12b627..b4f4c3c76b 100644 --- a/drivers/phy/meson-gxl-usb2.c +++ b/drivers/phy/meson-gxl-usb2.c @@ -17,6 +17,9 @@ #include <regmap.h> #include <power/regulator.h> #include <clk.h> +#include <linux/usb/otg.h> + +#include <asm/arch/usb-gx.h>
#include <linux/bitops.h> #include <linux/compat.h> @@ -121,15 +124,30 @@ static void phy_meson_gxl_usb2_reset(struct phy_meson_gxl_usb2_priv *priv) udelay(RESET_COMPLETE_TIME); }
-static void -phy_meson_gxl_usb2_set_host_mode(struct phy_meson_gxl_usb2_priv *priv) +void phy_meson_gxl_usb2_set_mode(struct phy *phy, enum usb_dr_mode mode) { + struct udevice *dev = phy->dev; + struct phy_meson_gxl_usb2_priv *priv = dev_get_priv(dev); uint val;
regmap_read(priv->regmap, U2P_R0, &val); - val |= U2P_R0_DM_PULLDOWN; - val |= U2P_R0_DP_PULLDOWN; - val &= ~U2P_R0_ID_PULLUP; + + switch (mode) { + case USB_DR_MODE_UNKNOWN: + case USB_DR_MODE_HOST: + case USB_DR_MODE_OTG: + val |= U2P_R0_DM_PULLDOWN; + val |= U2P_R0_DP_PULLDOWN; + val &= ~U2P_R0_ID_PULLUP; + break; + + case USB_DR_MODE_PERIPHERAL: + val &= ~U2P_R0_DM_PULLDOWN; + val &= ~U2P_R0_DP_PULLDOWN; + val |= U2P_R0_ID_PULLUP; + break; + } + regmap_write(priv->regmap, U2P_R0, val);
phy_meson_gxl_usb2_reset(priv); @@ -146,7 +164,7 @@ static int phy_meson_gxl_usb2_power_on(struct phy *phy) val &= ~U2P_R0_POWER_ON_RESET; regmap_write(priv->regmap, U2P_R0, val);
- phy_meson_gxl_usb2_set_host_mode(priv); + phy_meson_gxl_usb2_set_mode(phy, USB_DR_MODE_HOST);
#if CONFIG_IS_ENABLED(DM_REGULATOR) if (priv->phy_supply) { diff --git a/drivers/phy/meson-gxl-usb3.c b/drivers/phy/meson-gxl-usb3.c index c2a8593b39..227efa7a17 100644 --- a/drivers/phy/meson-gxl-usb3.c +++ b/drivers/phy/meson-gxl-usb3.c @@ -16,6 +16,9 @@ #include <generic-phy.h> #include <regmap.h> #include <clk.h> +#include <linux/usb/otg.h> + +#include <asm/arch/usb-gx.h>
#include <linux/bitops.h> #include <linux/compat.h> @@ -93,20 +96,35 @@ struct phy_meson_gxl_usb3_priv { #endif };
-static int -phy_meson_gxl_usb3_set_host_mode(struct phy_meson_gxl_usb3_priv *priv) +void phy_meson_gxl_usb3_set_mode(struct phy *phy, enum usb_dr_mode mode) { + struct udevice *dev = phy->dev; + struct phy_meson_gxl_usb3_priv *priv = dev_get_priv(dev); uint val;
- regmap_read(priv->regmap, USB_R0, &val); - val &= ~USB_R0_U2D_ACT; - regmap_write(priv->regmap, USB_R0, val); - - regmap_read(priv->regmap, USB_R4, &val); - val &= ~USB_R4_P21_SLEEP_M0; - regmap_write(priv->regmap, USB_R4, val); - - return 0; + switch (mode) { + case USB_DR_MODE_UNKNOWN: + case USB_DR_MODE_HOST: + case USB_DR_MODE_OTG: + regmap_read(priv->regmap, USB_R0, &val); + val &= ~USB_R0_U2D_ACT; + regmap_write(priv->regmap, USB_R0, val); + + regmap_read(priv->regmap, USB_R4, &val); + val &= ~USB_R4_P21_SLEEP_M0; + regmap_write(priv->regmap, USB_R4, val); + break; + + case USB_DR_MODE_PERIPHERAL: + regmap_read(priv->regmap, USB_R0, &val); + val |= USB_R0_U2D_ACT; + regmap_write(priv->regmap, USB_R0, val); + + regmap_read(priv->regmap, USB_R4, &val); + val |= USB_R4_P21_SLEEP_M0; + regmap_write(priv->regmap, USB_R4, val); + break; + } }
static int phy_meson_gxl_usb3_power_on(struct phy *phy) @@ -122,7 +140,9 @@ static int phy_meson_gxl_usb3_power_on(struct phy *phy) val |= FIELD_PREP(USB_R5_ID_DIG_TH_MASK, 0xff); regmap_write(priv->regmap, USB_R5, val);
- return phy_meson_gxl_usb3_set_host_mode(priv); + phy_meson_gxl_usb3_set_mode(phy, USB_DR_MODE_HOST); + + return 0; }
static int phy_meson_gxl_usb3_power_off(struct phy *phy)
Add arch code to initialize USB Gadget mode using the DWC2 controller, and using the previously added set_mode() phy functions.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- arch/arm/mach-meson/board-gx.c | 118 +++++++++++++++++++++++++++++++++ 1 file changed, 118 insertions(+)
diff --git a/arch/arm/mach-meson/board-gx.c b/arch/arm/mach-meson/board-gx.c index 191fd49005..1a7e102c38 100644 --- a/arch/arm/mach-meson/board-gx.c +++ b/arch/arm/mach-meson/board-gx.c @@ -14,6 +14,11 @@ #include <asm/io.h> #include <asm/armv8/mmu.h> #include <linux/sizes.h> +#include <usb.h> +#include <linux/usb/otg.h> +#include <asm/arch/usb-gx.h> +#include <usb/dwc2_udc.h> +#include <clk.h> #include <phy.h>
DECLARE_GLOBAL_DATA_PTR; @@ -149,3 +154,116 @@ void meson_eth_init(phy_interface_t mode, unsigned int flags) /* Enable power gate */ clrbits_le32(GX_MEM_PD_REG_0, GX_MEM_PD_REG_0_ETH_MASK); } + +#if CONFIG_IS_ENABLED(USB_XHCI_DWC3_OF_SIMPLE) && \ + CONFIG_IS_ENABLED(USB_GADGET_DWC2_OTG) +static struct dwc2_plat_otg_data meson_gx_dwc2_data; +static struct phy usb_phys[2]; + +int board_usb_init(int index, enum usb_init_type init) +{ + struct ofnode_phandle_args args; + struct udevice *clk_dev; + ofnode dwc2_node; + struct clk clk; + int ret, i; + u32 val; + + /* find the dwc2 node */ + dwc2_node = ofnode_by_compatible(ofnode_null(), "snps,dwc2"); + if (!ofnode_valid(dwc2_node)) { + debug("Not found dwc2 node\n"); + return -ENODEV; + } + + if (!ofnode_is_available(dwc2_node)) { + debug("dwc2 is disabled in the device tree\n"); + return -ENODEV; + } + + /* get the PHYs */ + for (i = 0; i < 2; i++) { + ret = generic_phy_get_by_node(dwc2_node, i, &usb_phys[i]); + if (ret && ret != -ENOENT) { + pr_err("Failed to get USB PHY%d for %s\n", + i, ofnode_get_name(dwc2_node)); + return ret; + } + } + + for (i = 0; i < 2; i++) { + ret = generic_phy_init(&usb_phys[i]); + if (ret) { + pr_err("Can't init USB PHY%d for %s\n", + i, ofnode_get_name(dwc2_node)); + return ret; + } + } + + for (i = 0; i < 2; i++) { + ret = generic_phy_power_on(&usb_phys[i]); + if (ret) { + pr_err("Can't power USB PHY%d for %s\n", + i, ofnode_get_name(dwc2_node)); + return ret; + } + } + + phy_meson_gxl_usb3_set_mode(&usb_phys[0], USB_DR_MODE_PERIPHERAL); + phy_meson_gxl_usb2_set_mode(&usb_phys[1], USB_DR_MODE_PERIPHERAL); + + meson_gx_dwc2_data.regs_otg = ofnode_get_addr(dwc2_node); + if (meson_gx_dwc2_data.regs_otg == FDT_ADDR_T_NONE) { + debug("usbotg: can't get base address\n"); + return -ENODATA; + } + + /* Enable clock */ + ret = ofnode_parse_phandle_with_args(dwc2_node, "clocks", + "#clock-cells", 0, 0, &args); + if (ret) { + debug("usbotg has no clocks defined in the device tree\n"); + return ret; + } + + ret = uclass_get_device_by_ofnode(UCLASS_CLK, args.node, &clk_dev); + if (ret) + return ret; + + if (args.args_count != 1) { + debug("Can't find clock ID in the device tree\n"); + return -ENODATA; + } + + clk.dev = clk_dev; + clk.id = args.args[0]; + + ret = clk_enable(&clk); + if (ret) { + debug("Failed to enable usbotg clock\n"); + return ret; + } + + ofnode_read_u32(dwc2_node, "g-rx-fifo-size", &val); + meson_gx_dwc2_data.rx_fifo_sz = val; + ofnode_read_u32(dwc2_node, "g-np-tx-fifo-size", &val); + meson_gx_dwc2_data.np_tx_fifo_sz = val; + ofnode_read_u32(dwc2_node, "g-tx-fifo-size", &val); + meson_gx_dwc2_data.tx_fifo_sz = val; + + return dwc2_udc_probe(&meson_gx_dwc2_data); +} + +int board_usb_cleanup(int index, enum usb_init_type init) +{ + int i; + + phy_meson_gxl_usb3_set_mode(&usb_phys[0], USB_DR_MODE_HOST); + phy_meson_gxl_usb3_set_mode(&usb_phys[1], USB_DR_MODE_HOST); + + for (i = 0; i < 2; i++) + usb_phys[i].dev = NULL; + + return 0; +} +#endif
Add the USB DWC2 node to u-boot specific dtsi files since Gadget support is not (yet) available in upstream Linux yet.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- .../meson-gxl-s905x-khadas-vim-u-boot.dtsi | 2 +- .../meson-gxl-s905x-libretech-cc-u-boot.dtsi | 6 ++++- arch/arm/dts/meson-gxl-s905x-p212-u-boot.dtsi | 2 +- arch/arm/dts/meson-gxl-u-boot.dtsi | 23 +++++++++++++++++++ 4 files changed, 30 insertions(+), 3 deletions(-) create mode 100644 arch/arm/dts/meson-gxl-u-boot.dtsi
diff --git a/arch/arm/dts/meson-gxl-s905x-khadas-vim-u-boot.dtsi b/arch/arm/dts/meson-gxl-s905x-khadas-vim-u-boot.dtsi index c35158d7e9..39270ea71c 100644 --- a/arch/arm/dts/meson-gxl-s905x-khadas-vim-u-boot.dtsi +++ b/arch/arm/dts/meson-gxl-s905x-khadas-vim-u-boot.dtsi @@ -4,4 +4,4 @@ * Author: Neil Armstrong narmstrong@baylibre.com */
-#include "meson-gx-u-boot.dtsi" +#include "meson-gxl-u-boot.dtsi" diff --git a/arch/arm/dts/meson-gxl-s905x-libretech-cc-u-boot.dtsi b/arch/arm/dts/meson-gxl-s905x-libretech-cc-u-boot.dtsi index c35158d7e9..474a3e1604 100644 --- a/arch/arm/dts/meson-gxl-s905x-libretech-cc-u-boot.dtsi +++ b/arch/arm/dts/meson-gxl-s905x-libretech-cc-u-boot.dtsi @@ -4,4 +4,8 @@ * Author: Neil Armstrong narmstrong@baylibre.com */
-#include "meson-gx-u-boot.dtsi" +#include "meson-gxl-u-boot.dtsi" + +&dwc2 { + status = "okay"; +}; diff --git a/arch/arm/dts/meson-gxl-s905x-p212-u-boot.dtsi b/arch/arm/dts/meson-gxl-s905x-p212-u-boot.dtsi index c35158d7e9..39270ea71c 100644 --- a/arch/arm/dts/meson-gxl-s905x-p212-u-boot.dtsi +++ b/arch/arm/dts/meson-gxl-s905x-p212-u-boot.dtsi @@ -4,4 +4,4 @@ * Author: Neil Armstrong narmstrong@baylibre.com */
-#include "meson-gx-u-boot.dtsi" +#include "meson-gxl-u-boot.dtsi" diff --git a/arch/arm/dts/meson-gxl-u-boot.dtsi b/arch/arm/dts/meson-gxl-u-boot.dtsi new file mode 100644 index 0000000000..9e88afd30e --- /dev/null +++ b/arch/arm/dts/meson-gxl-u-boot.dtsi @@ -0,0 +1,23 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 BayLibre, SAS. + * Author: Neil Armstrong narmstrong@baylibre.com + */ + +#include "meson-gx-u-boot.dtsi" + +&usb0 { + dwc2: usb@c9100000 { + compatible = "snps,dwc2"; + reg = <0x0 0xc9100000 0x0 0x40000>; + interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clkc CLKID_USB1_DDR_BRIDGE>; + clock-names = "ddr"; + phys = <&usb3_phy>, <&usb2_phy1>; + dr_mode = "peripheral"; + g-rx-fifo-size = <192>; + g-np-tx-fifo-size = <128>; + g-tx-fifo-size = <128 128 16 16 16>; + status = "disabled"; + }; +};
Enable configs to support USB gadget and Mass Storage
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- configs/libretech-cc_defconfig | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/configs/libretech-cc_defconfig b/configs/libretech-cc_defconfig index 7c257b33b3..2c512ebc1e 100644 --- a/configs/libretech-cc_defconfig +++ b/configs/libretech-cc_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_REGULATOR=y CONFIG_OF_CONTROL=y @@ -51,6 +52,12 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_XHCI_DWC3_OF_SIMPLE=y CONFIG_USB_DWC3=y +# CONFIG_USB_DWC3_GADGET is not set +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_VENDOR_NUM=0x1b8e +CONFIG_USB_GADGET_PRODUCT_NUM=0xfada +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set # CONFIG_VIDEO_BPP16 is not set
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- configs/libretech-ac_defconfig | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/configs/libretech-ac_defconfig b/configs/libretech-ac_defconfig index 09b87c54d5..7e486757a2 100644 --- a/configs/libretech-ac_defconfig +++ b/configs/libretech-ac_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF_TEST=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_REGULATOR=y CONFIG_OF_CONTROL=y @@ -69,6 +70,12 @@ CONFIG_USB_XHCI_DWC3=y CONFIG_USB_XHCI_DWC3_OF_SIMPLE=y CONFIG_USB_DWC3=y CONFIG_USB_KEYBOARD=y +# CONFIG_USB_DWC3_GADGET is not set +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_VENDOR_NUM=0x1b8e +CONFIG_USB_GADGET_PRODUCT_NUM=0xfada +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set # CONFIG_VIDEO_BPP16 is not set
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- configs/khadas-vim2_defconfig | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/configs/khadas-vim2_defconfig b/configs/khadas-vim2_defconfig index 9cb377e55e..a533566410 100644 --- a/configs/khadas-vim2_defconfig +++ b/configs/khadas-vim2_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_REGULATOR=y CONFIG_OF_CONTROL=y @@ -49,4 +50,10 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_XHCI_DWC3_OF_SIMPLE=y CONFIG_USB_DWC3=y +# CONFIG_USB_DWC3_GADGET is not set +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_VENDOR_NUM=0x1b8e +CONFIG_USB_GADGET_PRODUCT_NUM=0xfada +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_OF_LIBFDT_OVERLAY=y
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- configs/khadas-vim_defconfig | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/configs/khadas-vim_defconfig b/configs/khadas-vim_defconfig index e18a5e62bb..8a0af5cebb 100644 --- a/configs/khadas-vim_defconfig +++ b/configs/khadas-vim_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_REGULATOR=y CONFIG_OF_CONTROL=y @@ -50,4 +51,10 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_XHCI_DWC3_OF_SIMPLE=y CONFIG_USB_DWC3=y +# CONFIG_USB_DWC3_GADGET is not set +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_VENDOR_NUM=0x1b8e +CONFIG_USB_GADGET_PRODUCT_NUM=0xfada +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_OF_LIBFDT_OVERLAY=y
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- configs/libretech-s905d-pc_defconfig | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/configs/libretech-s905d-pc_defconfig b/configs/libretech-s905d-pc_defconfig index 7e0c95872a..531d519a7c 100644 --- a/configs/libretech-s905d-pc_defconfig +++ b/configs/libretech-s905d-pc_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SF_TEST=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_REGULATOR=y CONFIG_OF_CONTROL=y @@ -65,6 +66,12 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_XHCI_DWC3_OF_SIMPLE=y CONFIG_USB_DWC3=y +# CONFIG_USB_DWC3_GADGET is not set +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_VENDOR_NUM=0x1b8e +CONFIG_USB_GADGET_PRODUCT_NUM=0xfada +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_KEYBOARD=y CONFIG_DM_VIDEO=y CONFIG_SYS_WHITE_ON_BLACK=y
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- configs/libretech-s912-pc_defconfig | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/configs/libretech-s912-pc_defconfig b/configs/libretech-s912-pc_defconfig index 5f4ee329e2..595ec21da7 100644 --- a/configs/libretech-s912-pc_defconfig +++ b/configs/libretech-s912-pc_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SF_TEST=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_REGULATOR=y CONFIG_OF_CONTROL=y @@ -65,6 +66,12 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_XHCI_DWC3_OF_SIMPLE=y CONFIG_USB_DWC3=y +# CONFIG_USB_DWC3_GADGET is not set +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_VENDOR_NUM=0x1b8e +CONFIG_USB_GADGET_PRODUCT_NUM=0xfada +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_KEYBOARD=y CONFIG_DM_VIDEO=y CONFIG_SYS_WHITE_ON_BLACK=y
Applied to u-boot-amlogic with tom's review tag on patch 1
Neil Armstrong
