[PATCH v1] board: toradex: imx: Remove not needed env variables
From: Francesco Dolcini francesco.dolcini@toradex.com
Remove not needed variables from environment and include config files.
- setup variable used to be executed from some bootscript, however it's not required and there is no point on having this small helper here - boot_file, kernel_file, ip_dyn variables are not used anywhere - fdt_fixup variable is just set empty - defargs, vidargs variables used to be used from some bootscript, however there is no point on having it here and even old legacy bootscript can work without them - removed CONFIG_ENABLE_DDR_TRAINING_DEBUG, this is a leftover from some copy/paste
On colibri imx6ull/imx7 NAND module, remove consoleblank=0, this is already the Linux kernel default therefore useless.
Various Linux Kernel command line options removed are not-existing left-over that applied to some old NXP i.MX downstream branch
Signed-off-by: Francesco Dolcini francesco.dolcini@toradex.com --- include/configs/apalis-imx8.h | 2 -- include/configs/apalis_imx6.h | 9 +-------- include/configs/colibri-imx6ull.h | 10 +++------- include/configs/colibri-imx8x.h | 2 -- include/configs/colibri_imx6.h | 9 +-------- include/configs/colibri_imx7.h | 11 +++-------- include/configs/verdin-imx8mm.h | 3 --- include/configs/verdin-imx8mp.h | 5 ----- 8 files changed, 8 insertions(+), 43 deletions(-)
diff --git a/include/configs/apalis-imx8.h b/include/configs/apalis-imx8.h index 845705c86db2..c8ec034fc979 100644 --- a/include/configs/apalis-imx8.h +++ b/include/configs/apalis-imx8.h @@ -46,8 +46,6 @@ "fdt_board=eval\0" \ "initrd_addr=0x83800000\0" \ "initrd_high=0xffffffffffffffff\0" \ - "setup=setenv setupargs console=tty1 console=${console},${baudrate} " \ - "consoleblank=0 earlycon\0" \ "update_uboot=askenv confirm Did you load flash.bin resp. u-boot-dtb.imx (y/N)?; " \ "if test "$confirm" = "y"; then " \ "setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt " \ diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index 8a9f3ef75a7d..0df3917e2009 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -64,12 +64,9 @@
#define CFG_EXTRA_ENV_SETTINGS \ BOOTENV \ - "boot_file=zImage\0" \ "boot_script_dhcp=boot.scr\0" \ "console=ttymxc0\0" \ - "defargs=enable_wait_mode=off vmalloc=400M\0" \ "fdt_board=eval\0" \ - "fdt_fixup=;\0" \ MEM_LAYOUT_ENV_SETTINGS \ UBOOT_UPDATE \ "setethupdate=if env exists ethaddr; then; else setenv ethaddr " \ @@ -80,16 +77,12 @@ "|| setenv drive 2; mmc rescan; load ${interface} ${drive}:1" \ " ${loadaddr} flash_blk.img && " \ "source ${loadaddr}\0" \ - "setup=setenv setupargs fec_mac=${ethaddr} " \ - "consoleblank=0 no_console_suspend=1 console=tty1 " \ - "console=${console},${baudrate}n8\0 " \ "setupdate=run setsdupdate || run setusbupdate || run setethupdate\0" \ "setusbupdate=usb start && setenv interface usb; setenv drive 0; " \ "load ${interface} ${drive}:1 ${loadaddr} flash_blk.img && " \ "source ${loadaddr}\0" \ "splashpos=m,m\0" \ - "splashimage=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ - "vidargs=mxc_hdmi.only_cea=1 fbmem=32M\0" + "splashimage=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0"
/* Miscellaneous configurable options */
diff --git a/include/configs/colibri-imx6ull.h b/include/configs/colibri-imx6ull.h index 561a61ebc03c..7c9d633b68d9 100644 --- a/include/configs/colibri-imx6ull.h +++ b/include/configs/colibri-imx6ull.h @@ -48,8 +48,8 @@ "ubiargs=ubi.mtd=ubi root=ubi0:rootfs rw rootfstype=ubifs " \ "ubi.fm_autoconvert=1\0" \ "ubiboot=run setup; " \ - "setenv bootargs ${defargs} ${ubiargs} " \ - "${setupargs} ${vidargs} ${tdxargs}; echo Booting from NAND...; " \ + "setenv bootargs ${ubiargs} " \ + "${setupargs} ${tdxargs}; echo Booting from NAND...; " \ "ubi part ubi &&" \ "ubi read ${kernel_addr_r} kernel && " \ "ubi read ${fdt_addr_r} dtb && " \ @@ -86,11 +86,7 @@ UBOOT_UPDATE \ "boot_script_dhcp=boot.scr\0" \ "console=ttymxc0\0" \ - "defargs=user_debug=30\0" \ "fdt_board=eval-v3\0" \ - "fdt_fixup=;\0" \ - "ip_dyn=yes\0" \ - "kernel_file=zImage\0" \ "setethupdate=if env exists ethaddr; then; else setenv ethaddr " \ "00:14:2d:00:00:00; fi; tftpboot ${loadaddr} " \ "${board}/flash_eth.img && source ${loadaddr}\0" \ @@ -99,7 +95,7 @@ "${board}/flash_blk.img && source ${loadaddr}\0" \ "setup=setenv setupargs " \ "console=tty1 console=${console}" \ - ",${baudrate}n8 ${memargs} ${mtdparts} consoleblank=0\0" \ + ",${baudrate}n8 ${memargs} ${mtdparts}\0" \ "setupdate=run setsdupdate || run setusbupdate || run setethupdate\0" \ "setusbupdate=usb start && setenv interface usb && " \ "fatload ${interface} 0:1 ${loadaddr} " \ diff --git a/include/configs/colibri-imx8x.h b/include/configs/colibri-imx8x.h index 042fcb8757ff..2b7fea30116f 100644 --- a/include/configs/colibri-imx8x.h +++ b/include/configs/colibri-imx8x.h @@ -40,8 +40,6 @@ "fdt_board=eval-v3\0" \ "initrd_addr=0x83800000\0" \ "initrd_high=0xffffffffffffffff\0" \ - "setup=setenv setupargs console=tty1 console=${console},${baudrate} " \ - "consoleblank=0 earlycon\0" \ "update_uboot=askenv confirm Did you load flash.bin resp. u-boot-dtb.imx (y/N)?; " \ "if test "$confirm" = "y"; then " \ "setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt " \ diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h index 4b2841833b5a..79e5b870b812 100644 --- a/include/configs/colibri_imx6.h +++ b/include/configs/colibri_imx6.h @@ -58,12 +58,9 @@
#define CFG_EXTRA_ENV_SETTINGS \ BOOTENV \ - "boot_file=zImage\0" \ "boot_script_dhcp=boot.scr\0" \ "console=ttymxc0\0" \ - "defargs=enable_wait_mode=off galcore.contiguousSize=50331648\0" \ "fdt_board=eval-v3\0" \ - "fdt_fixup=;\0" \ MEM_LAYOUT_ENV_SETTINGS \ UBOOT_UPDATE \ "setethupdate=if env exists ethaddr; then; else setenv ethaddr " \ @@ -72,16 +69,12 @@ "setsdupdate=setenv interface mmc; setenv drive 1; mmc rescan; load " \ "${interface} ${drive}:1 ${loadaddr} flash_blk.img && " \ "source ${loadaddr}\0" \ - "setup=setenv setupargs fec_mac=${ethaddr} " \ - "consoleblank=0 no_console_suspend=1 console=tty1 " \ - "console=${console},${baudrate}n8\0 " \ "setupdate=run setsdupdate || run setusbupdate || run setethupdate\0" \ "setusbupdate=usb start && setenv interface usb; setenv drive 0; " \ "load ${interface} ${drive}:1 ${loadaddr} flash_blk.img && " \ "source ${loadaddr}\0" \ "splashpos=m,m\0" \ - "splashimage=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ - "vidargs=fbmem=8M\0" + "splashimage=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0"
diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index 7a9f4afe7d17..c34f1f903df6 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -89,8 +89,8 @@ "ubiargs=ubi.mtd=ubi root=ubi0:rootfs rootfstype=ubifs " \ "ubi.fm_autoconvert=1\0" \ "ubiboot=run setup; " \ - "setenv bootargs ${defargs} ${ubiargs} " \ - "${setupargs} ${vidargs} ${tdxargs}; echo Booting from NAND...; " \ + "setenv bootargs ${ubiargs} " \ + "${setupargs} ${tdxargs}; echo Booting from NAND...; " \ "ubi part ubi && run m4boot && " \ "ubi read ${kernel_addr_r} kernel && " \ "ubi read ${fdt_addr_r} dtb && " \ @@ -123,15 +123,10 @@ MEM_LAYOUT_ENV_SETTINGS \ MODULE_EXTRA_ENV_SETTINGS \ UBOOT_UPDATE \ - "boot_file=zImage\0" \ "boot_script_dhcp=boot.scr\0" \ "console=ttymxc0\0" \ - "defargs=\0" \ "fdt_board=eval-v3\0" \ - "fdt_fixup=;\0" \ "m4boot=;\0" \ - "ip_dyn=yes\0" \ - "kernel_file=zImage\0" \ "setethupdate=if env exists ethaddr; then; else setenv ethaddr " \ "00:14:2d:00:00:00; fi; tftpboot ${loadaddr} " \ "${board}/flash_eth.img && source ${loadaddr}\0" \ @@ -140,7 +135,7 @@ "${board}/flash_blk.img && source ${loadaddr}\0" \ "setup=setenv setupargs " \ "console=tty1 console=${console}" \ - ",${baudrate}n8 ${memargs} ${mtdparts} consoleblank=0\0" \ + ",${baudrate}n8 ${memargs} ${mtdparts}\0" \ "setupdate=run setsdupdate || run setusbupdate || run setethupdate\0" \ "setusbupdate=usb start && setenv interface usb && " \ "fatload ${interface} 0:1 ${loadaddr} " \ diff --git a/include/configs/verdin-imx8mm.h b/include/configs/verdin-imx8mm.h index a7ea02807ddf..34238d3b505c 100644 --- a/include/configs/verdin-imx8mm.h +++ b/include/configs/verdin-imx8mm.h @@ -37,14 +37,11 @@ #define CFG_EXTRA_ENV_SETTINGS \ BOOTENV \ MEM_LAYOUT_ENV_SETTINGS \ - "boot_file=Image\0" \ "boot_script_dhcp=boot.scr\0" \ "console=ttymxc0\0" \ "fdt_board=dev\0" \ "initrd_addr=0x43800000\0" \ "initrd_high=0xffffffffffffffff\0" \ - "setup=setenv setupargs console=tty1 console=${console},${baudrate} " \ - "consoleblank=0 earlycon\0" \ "update_uboot=askenv confirm Did you load flash.bin (y/N)?; " \ "if test "$confirm" = "y"; then " \ "setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt " \ diff --git a/include/configs/verdin-imx8mp.h b/include/configs/verdin-imx8mp.h index 256bab089ffc..0b88e95603d5 100644 --- a/include/configs/verdin-imx8mp.h +++ b/include/configs/verdin-imx8mp.h @@ -13,7 +13,6 @@ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
#ifdef CONFIG_SPL_BUILD -/*#define CONFIG_ENABLE_DDR_TRAINING_DEBUG*/
/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CFG_MALLOC_F_ADDR 0x184000 @@ -40,15 +39,11 @@ #define CFG_EXTRA_ENV_SETTINGS \ BOOTENV \ MEM_LAYOUT_ENV_SETTINGS \ - "boot_file=Image\0" \ - "boot_scripts=boot.scr\0" \ "boot_script_dhcp=boot.scr\0" \ "console=ttymxc2\0" \ "fdt_board=dev\0" \ "initrd_addr=0x43800000\0" \ "initrd_high=0xffffffffffffffff\0" \ - "setup=setenv setupargs console=tty1 console=${console},${baudrate} " \ - "consoleblank=0 earlycon\0" \ "update_uboot=askenv confirm Did you load flash.bin (y/N)?; " \ "if test "$confirm" = "y"; then " \ "setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt " \
On Thu, Apr 18, 2024 at 10:12 AM Francesco Dolcini francesco@dolcini.it wrote:
Applied, thanks.
Fabio Estevam
Francesco Dolcini
