[PATCH v1] configs: pico-imx6: convert ethernet function to DM_ETH
Before enable _DM_ETH: Net: FEC [PRIME]
After enable DM_ETH: Net: eth0: ethernet@2188000
Here is the test commands: => dhcp BOOTP broadcast 1 DHCP client bound to address 10.88.88.152 (146 ms) *** ERROR: `serverip' not set Cannot autoload with TFTPGET => ping 8.8.8.8 Using ethernet@2188000 device host 8.8.8.8 is alive
Signed-off-by: Wig Cheng wig.cheng@technexion.com --- configs/pico-imx6_defconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/configs/pico-imx6_defconfig b/configs/pico-imx6_defconfig index 04c132b474..5fe2850086 100644 --- a/configs/pico-imx6_defconfig +++ b/configs/pico-imx6_defconfig @@ -64,6 +64,9 @@ CONFIG_DM_MMC=y CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_ATHEROS=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_RGMII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_MXC_UART=y
From: Wig Cheng wig.cheng@technexion.com Before enable _DM_ETH: Net: FEC [PRIME] After enable DM_ETH: Net: eth0: ethernet@2188000 Here is the test commands: => dhcp BOOTP broadcast 1 DHCP client bound to address 10.88.88.152 (146 ms) *** ERROR: `serverip' not set Cannot autoload with TFTPGET => ping 8.8.8.8 Using ethernet@2188000 device host 8.8.8.8 is alive Signed-off-by: Wig Cheng wig.cheng@technexion.com
Best regards, Stefano Babic
sbabic@denx.de
