[U-Boot] Please pull u-boot-dm
Hi Tom,
The following changes since commit a3e1653ddeb02f39481eba572275016171e9670c:
Merge git://git.denx.de/u-boot-marvell (2018-11-20 12:39:16 -0500)
git://git.denx.de/u-boot-dm.git tags/pull-tg18
for you to fetch changes up to a58986ca8b53d8c7a441397082f84edc7f47d19f:
sf: Add a method to obtain the block-protect setting (2018-11-20 19:14:22 -0700)
https://travis-ci.org/sglass68/u-boot/builds/457752510
---------------------------------------------------------------- Various minor sandbox improvements Better buildman warning handling Misc other things
---------------------------------------------------------------- Baruch Siach (1): fdt: restore board_fdt_blob_setup() declaration
Heinrich Schuchardt (3): sandbox: remove stray DEBUG sandbox: README: setting environment variables sandbox: README: use setenv ethrotate no
Hiroyuki Yokoyama (1): cmd: fdt: Fix fdt address information after the movement
Hou Zhiqiang (1): dm/pci: Change the first CFG read to Vendor ID in enumeration
Liviu Dudau (1): dm: core: Widen the dump tree to show more of the driver's name.
Marek Vasut (1): fdt: Fix uncompress_blob() for U-Boot proper
Simon Glass (24): buildman: Only print toolchain probing with -v buildman: Detect dtc warnings buildman: Rename the good, better, worse variables buildman: Show boards with warning with w+ cros_ec: Use uint instead of u8 for parameters cros_ec: Add error logging on a few commands cros_ec: Fail if we cannot determine the flash burst size cros_ec: Align uclass data to a cache boundary cros_ec: Add new features for events and power sandbox: tpm: Allow debugging of data packages sandbox: log: Add a category for sandbox sandbox: Add a function to read a host file sandbox: cros_ec: exynos: Drop use of cros_ec_get_error() sandbox: Update some drivers to work in SPL/TPL spl: Support bootstage, log, hash and early malloc in TPL spl: lz4: Allow use of lz4 compression in SPL binman: Add a way to enable debugging from the build binman: Drop an unnecessary comma in blob handling binman: Set the pathname correctly for ELF files video: Update video_set_default_colors() to support invert string: Include the config header misc: Update read() and write() methods to return bytes xfered test: sf: Add a simple SPI flash test sf: Add a method to obtain the block-protect setting
Simon Goldschmidt (1): dm: spi: prevent setting a speed of 0 Hz
Makefile | 6 +- arch/arm/mach-stm32mp/cpu.c | 4 +- arch/sandbox/cpu/cpu.c | 8 +- arch/sandbox/cpu/os.c | 44 ++++++- arch/sandbox/dts/sandbox.dts | 15 +++ arch/sandbox/include/asm/test.h | 8 ++ board/samsung/common/board.c | 10 +- board/sandbox/README.sandbox | 20 +-- board/sandbox/sandbox.c | 9 +- cmd/fdt.c | 2 +- common/Kconfig | 35 ++++++ common/Makefile | 10 +- common/cros_ec.c | 12 -- drivers/clk/clk_vexpress_osc.c | 4 +- drivers/core/dump.c | 8 +- drivers/misc/altera_sysid.c | 2 +- drivers/misc/cros_ec.c | 370 ++++++++++++++++++++++++++++++++++++++++++++++++++++--- drivers/misc/cros_ec_sandbox.c | 2 +- drivers/misc/misc_sandbox.c | 4 +- drivers/misc/rockchip-efuse.c | 2 +- drivers/misc/stm32mp_fuse.c | 12 ++ drivers/mtd/spi/sandbox.c | 10 ++ drivers/mtd/spi/sf-uclass.c | 9 ++ drivers/mtd/spi/sf_internal.h | 3 + drivers/mtd/spi/sf_probe.c | 8 ++ drivers/mtd/spi/spi_flash.c | 12 ++ drivers/pci/pci-uclass.c | 11 +- drivers/spi/spi-uclass.c | 15 ++- drivers/tpm/tpm_tis_sandbox.c | 6 + drivers/video/vidconsole-uclass.c | 2 +- drivers/video/video-uclass.c | 27 ++-- include/cros_ec.h | 89 +++++++++++++ include/fdtdec.h | 1 + include/log.h | 1 + include/misc.h | 8 +- include/os.h | 14 +++ include/spi_flash.h | 27 ++++ include/video.h | 5 +- lib/Kconfig | 8 ++ lib/Makefile | 2 +- lib/fdtdec.c | 3 +- lib/string.c | 1 + test/dm/misc.c | 6 +- test/dm/sf.c | 55 ++++++++- test/py/tests/test_bind.py | 28 ++--- tools/binman/README | 6 + tools/binman/etype/blob.py | 2 +- tools/binman/etype/u_boot_elf.py | 5 +- tools/buildman/builder.py | 41 +++--- tools/buildman/cmdline.py | 2 +- tools/buildman/control.py | 2 +- tools/buildman/test.py | 61 ++++++--- 52 files changed, 909 insertions(+), 148 deletions(-)
On Wed, Nov 21, 2018 at 05:25:59PM -0700, Simon Glass wrote:
Hi Tom,
