[U-Boot] [PATCH v3 0/8] dm: pci: tegra: Convert Tegra PCI to driver model
This series converts all Tegra boards to use driver model for PCI. The net effect should be no change in functionality.
A few additional features are added to make this possible: - Helper functions to support accessing 8- and 16-bit values within a 32-bit word - Fixing a build error for CONFIG_CMD_PCI_ENUM - Decoding the PCI ranges property such that configuration ranges are ignored - Supporting bus-master devices on boards where RAM does not start at 0
This series is tested on beaver. It is available at u-boot-dm/tegra-working.
Changes in v3: - Rebase onto tegra/master
Changes in v2: - Update commit message to explain that the feature is not important - Drop the feature from tegra boards - Rename 'addr' to 'size' - Correct logic for use of gd->pci_ram_top - Update commit message to mention future work - Use the device_is_on_pci_bus() API - Leave pci_skip_dev() at the bottom of the file to reduce the diff size
Simon Glass (8): dm: tegra: pci: Move CONFIG_PCI_TEGRA to Kconfig dm: pci: Avoid a driver model build error with CONFIG_CMD_PCI_ENUM dm: pci: Set up the SDRAM mapping correctly dm: pci: Support decoding ranges with duplicate entries dm: pci: Add functions to emulate 8- and 16-bit access dm: pci: Add a function to get the controller for a bus dm: pci: Add a function to find the regions for a PCI bus dm: tegra: pci: Convert tegra boards to driver model for PCI
arch/arm/mach-tegra/Kconfig | 2 + common/cmd_pci.c | 4 + configs/apalis_t30_defconfig | 1 + configs/beaver_defconfig | 1 + configs/cardhu_defconfig | 1 + configs/jetson-tk1_defconfig | 1 + configs/trimslice_defconfig | 1 + drivers/pci/Kconfig | 10 + drivers/pci/pci-uclass.c | 105 +++++++++- drivers/pci/pci_tegra.c | 468 ++++++++++++++----------------------------- include/configs/apalis_t30.h | 2 - include/configs/beaver.h | 2 - include/configs/cardhu.h | 2 - include/configs/jetson-tk1.h | 2 - include/configs/trimslice.h | 2 - include/fdtdec.h | 4 - include/pci.h | 51 +++++ lib/fdtdec.c | 4 - 18 files changed, 317 insertions(+), 346 deletions(-)
I applied this series on top of current u-boot/master.
On Jetson TK1 (T124), I see the following errors when U-Boot starts:
Net: ERROR: tegra-pcie: failed to power on PHY: -110
at /home/swarren/shared/git_wa/tegra-uboot-flasher/u-boot/drivers/pci/pci_tegra.c:685/tegra_pcie_enable_controller() ERROR: tegra-pcie: failed to enable controller at /home/swarren/shared/git_wa/tegra-uboot-flasher/u-boot/drivers/pci/pci_tegra.c:997/pci_tegra_probe() No ethernet found.
I assume you can investigate that without issue, since you have that board.
On Jetson TX1 (T210), you need to squash the following into the final commit of the series:
diff --git a/drivers/pci/pci_tegra.c b/drivers/pci/pci_tegra.c index ecd4313501c4..f88bd0d2858b 100644 --- a/drivers/pci/pci_tegra.c +++ b/drivers/pci/pci_tegra.c @@ -1022,6 +1022,7 @@ static const struct udevice_id pci_tegra_ids[] = { { .compatible = "nvidia,tegra20-pcie", .data = TEGRA20_PCIE }, { .compatible = "nvidia,tegra30-pcie", .data = TEGRA30_PCIE }, { .compatible = "nvidia,tegra124-pcie", .data = TEGRA124_PCIE },
- { .compatible = "nvidia,tegra210-pcie", .data = TEGRA210_PCIE }, { }
and even with that fix, PCIe now doesn't work:
Net: RTL8169#0 Warning: RTL8169#0 using MAC address from net device
Hit any key to stop autoboot: 0 Tegra210 (P2371-2180) # dhcp zImage pci_hose_bus_to_phys: invalid physical address pci_hose_bus_to_phys: invalid physical address pci_hose_bus_to_phys: invalid physical address pci_hose_bus_to_phys: invalid physical address pci_hose_bus_to_phys: invalid physical address pci_hose_bus_to_phys: invalid physical address BOOTP broadcast 1 pci_hose_bus_to_phys: invalid physical address BOOTP broadcast 2 pci_hose_bus_to_phys: invalid physical address BOOTP broadcast 3 pci_hose_bus_to_phys: invalid physical address
Perhaps there's some obvious mistake somewhere you can find by code inspection. Otherwise, let me know if you need me to debug that.
Hi Stephen,
It had a problem with the PMIC (I overwrote the contents) so I suspect I get that error always. But I'll try it.
I'll take a look and let you know if I get stuck.
Hi Stephen,
On 13 November 2015 at 11:14, Simon Glass sjg@chromium.org wrote:
Hi Stephen,
Yes, Jetson doesn't work for me, but I found the problem and tested it on Beaver. It was a merge conflict. I'll send v4 when I finish build testing.
Stephen Warren
