[PATCH] xen: pvblock: fix the maximum io size in one operation
The current implementation may cause BUG_ON() in blkfront_aio() BUG_ON(n > BLKIF_MAX_SEGMENTS_PER_REQUEST);
In pvblock_iop(), a read/write operation will be split into smaller chunks of data so that the size in one access (aio_nbytes) is limited to, at the maximum, BLKIF_MAX_SEGMENTS_PER_REQUEST * PAGE_SIZE
But this works only if when the *buffer* passed in to pvblock_io() is page-aligned. If not, the given data region may stand across (BLKIF_MAX_SEGMENTS_PER_REQUEST + 1) pages. See the logic in blkfront_aio(): start = (uintptr_t)aiocbp->aio_buf & PAGE_MASK; end = ((uintptr_t)aiocbp->aio_buf + aiocbp->aio_nbytes + PAGE_SIZE - 1) & PAGE_MASK; Then this will lead to BUG_ON() above.
This can be fixed by decreasing the maximum size of aio_nbytes.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org Fixes: commit 3a739cc6c948 ("xen: pvblock: Implement front-back protocol and do IO") --- drivers/xen/pvblock.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/xen/pvblock.c b/drivers/xen/pvblock.c index 4ad548d599d5..1df04e239ad0 100644 --- a/drivers/xen/pvblock.c +++ b/drivers/xen/pvblock.c @@ -632,7 +632,8 @@ static ulong pvblock_iop(struct udevice *udev, lbaint_t blknr, memcpy(blk_dev->bounce_buffer, buffer, desc->blksz);
aiocb.aio_nbytes = unaligned ? desc->blksz : - min((size_t)(BLKIF_MAX_SEGMENTS_PER_REQUEST * PAGE_SIZE), + min((size_t)((BLKIF_MAX_SEGMENTS_PER_REQUEST - 1) + * PAGE_SIZE), (size_t)(blocks_todo * desc->blksz));
blkfront_io(&aiocb, write);
Reviewed-by <Anastasiia Lukianenko vicooodin@gmail.com>
Regards, Anastasiia
On Wed, Nov 15, 2023 at 2:53 AM AKASHI Takahiro takahiro.akashi@linaro.org wrote:
PAGE_SIZE),
* PAGE_SIZE), (size_t)(blocks_todo * desc->blksz)); blkfront_io(&aiocb, write);
-- 2.34.1
AKASHI Takahiro
Nastya Vicodin
