[U-Boot] [PATCH 0/7] Migrate SPI defines to Kconfig
This serie is a proposal to convert all SPI configuration settings in Kconfig : + parameters for SF command - CONFIG_SF_DEFAULT_BUS - CONFIG_SF_DEFAULT_CS - CONFIG_SF_DEFAULT_MODE - CONFIG_SF_DEFAULT_SPEED + parameters for SSPI command - CONFIG_DEFAULT_SPI_BUS - CONFIG_DEFAULT_SPI_MODE + parameters for ENV in SPI - CONFIG_ENV_SPI_BUS - CONFIG_ENV_SPI_CS - CONFIG_ENV_SPI_MAX_HZ - CONFIG_ENV_SPI_MODE
I make this work after the remarks of Jagan Teki. on http://patchwork.ozlabs.org/patch/1031768/ [U-Boot,v3] dm: spi: Read default speed and mode values from DT
So it is a preliminary for v4 on this patch.
This commit includes a full migration using moveconfig.py to ensure that each commit compiles.
To allow compilation, I also move CMD in Kconfig for some board.
I introduce CONFIG_USE_ENV_SPI* to handle absent value (CONFIG_SF_DEFAULT_* is used) and use some post-processing to solve the remaining issue and remove the unnecessary configuration in defconfig (when default value can be used). I make manual check at the end.
Compilation is OK on Travis: https://travis-ci.org/patrickdelaunay/u-boot/builds/498044826
This v1 can be see as a starting point based on v2019.04-rc2. Any feedback or test is welcome.
Patrick Delaunay (7): bcm7445: move some configuration in defconfig file controlcenterdc: move some configuration in defconfig file exynos: replace CONFIG_ENV_SPI_BASE by CONFIG_SYS_SPI_BASE tqma6s_wru4_mmc: manage board_spi_cs_gpio correctly Convert CONFIG_SF_DEFAULT_* to Kconfig Convert CONFIG_DEFAULT_SPI_* to Kconfig Convert CONFIG_ENV_SPI_* to Kconfig
README | 15 ------ arch/arm/mach-exynos/spl_boot.c | 2 +- arch/arm/mach-kirkwood/include/mach/config.h | 15 ------ arch/arm/mach-mvebu/include/mach/config.h | 15 ------ board/Arcturus/ucp1020/cmd_arc.c | 13 ------ board/tqc/tqma6/tqma6.c | 2 + cmd/Kconfig | 12 ++++- cmd/spi.c | 7 --- configs/B4420QDS_NAND_defconfig | 2 + configs/B4420QDS_SPIFLASH_defconfig | 2 + configs/B4420QDS_defconfig | 2 + configs/B4860QDS_NAND_defconfig | 2 + configs/B4860QDS_SECURE_BOOT_defconfig | 2 + configs/B4860QDS_SPIFLASH_defconfig | 2 + configs/B4860QDS_SRIO_PCIE_BOOT_defconfig | 2 + configs/B4860QDS_defconfig | 2 + configs/BSC9131RDB_NAND_SYSCLK100_defconfig | 2 + configs/BSC9131RDB_NAND_defconfig | 2 + configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig | 2 + configs/BSC9131RDB_SPIFLASH_defconfig | 2 + configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig | 2 + configs/BSC9132QDS_NAND_DDRCLK100_defconfig | 2 + configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig | 2 + configs/BSC9132QDS_NAND_DDRCLK133_defconfig | 2 + configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig | 2 + configs/BSC9132QDS_NOR_DDRCLK100_defconfig | 2 + configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig | 2 + configs/BSC9132QDS_NOR_DDRCLK133_defconfig | 2 + .../BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig | 2 + configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig | 2 + .../BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig | 2 + configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig | 2 + .../BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig | 2 + configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig | 2 + .../BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig | 2 + configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig | 2 + configs/C29XPCIE_NAND_defconfig | 2 + configs/C29XPCIE_NOR_SECBOOT_defconfig | 2 + configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig | 2 + configs/C29XPCIE_SPIFLASH_defconfig | 2 + configs/C29XPCIE_defconfig | 2 + configs/M52277EVB_stmicro_defconfig | 2 + configs/M54418TWR_defconfig | 2 + configs/M54418TWR_serial_mii_defconfig | 2 + configs/M54418TWR_serial_rmii_defconfig | 2 + configs/M54451EVB_stmicro_defconfig | 2 + configs/M54455EVB_stm33_defconfig | 2 + configs/MPC8536DS_36BIT_defconfig | 2 + configs/MPC8536DS_SDCARD_defconfig | 2 + configs/MPC8536DS_SPIFLASH_defconfig | 2 + configs/MPC8536DS_defconfig | 2 + configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig | 2 + configs/P1010RDB-PA_36BIT_NAND_defconfig | 2 + configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig | 2 + configs/P1010RDB-PA_36BIT_NOR_defconfig | 2 + configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 2 + .../P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig | 2 + configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 2 + configs/P1010RDB-PA_NAND_SECBOOT_defconfig | 2 + configs/P1010RDB-PA_NAND_defconfig | 2 + configs/P1010RDB-PA_NOR_SECBOOT_defconfig | 2 + configs/P1010RDB-PA_NOR_defconfig | 2 + configs/P1010RDB-PA_SDCARD_defconfig | 2 + configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig | 2 + configs/P1010RDB-PA_SPIFLASH_defconfig | 2 + configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig | 2 + configs/P1010RDB-PB_36BIT_NAND_defconfig | 2 + configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig | 2 + configs/P1010RDB-PB_36BIT_NOR_defconfig | 2 + configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 2 + .../P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig | 2 + configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 2 + configs/P1010RDB-PB_NAND_SECBOOT_defconfig | 2 + configs/P1010RDB-PB_NAND_defconfig | 2 + configs/P1010RDB-PB_NOR_SECBOOT_defconfig | 2 + configs/P1010RDB-PB_NOR_defconfig | 2 + configs/P1010RDB-PB_SDCARD_defconfig | 2 + configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig | 2 + configs/P1010RDB-PB_SPIFLASH_defconfig | 2 + configs/P1020RDB-PC_36BIT_NAND_defconfig | 2 + configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 2 + configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 2 + configs/P1020RDB-PC_36BIT_defconfig | 2 + configs/P1020RDB-PC_NAND_defconfig | 2 + configs/P1020RDB-PC_SDCARD_defconfig | 2 + configs/P1020RDB-PC_SPIFLASH_defconfig | 2 + configs/P1020RDB-PC_defconfig | 2 + configs/P1020RDB-PD_NAND_defconfig | 2 + configs/P1020RDB-PD_SDCARD_defconfig | 2 + configs/P1020RDB-PD_SPIFLASH_defconfig | 2 + configs/P1020RDB-PD_defconfig | 2 + configs/P1021RDB-PC_36BIT_NAND_defconfig | 2 + configs/P1021RDB-PC_36BIT_SDCARD_defconfig | 2 + configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig | 2 + configs/P1021RDB-PC_36BIT_defconfig | 2 + configs/P1021RDB-PC_NAND_defconfig | 2 + configs/P1021RDB-PC_SDCARD_defconfig | 2 + configs/P1021RDB-PC_SPIFLASH_defconfig | 2 + configs/P1021RDB-PC_defconfig | 2 + configs/P1022DS_36BIT_NAND_defconfig | 2 + configs/P1022DS_36BIT_SDCARD_defconfig | 2 + configs/P1022DS_36BIT_SPIFLASH_defconfig | 2 + configs/P1022DS_36BIT_defconfig | 2 + configs/P1022DS_NAND_defconfig | 2 + configs/P1022DS_SDCARD_defconfig | 2 + configs/P1022DS_SPIFLASH_defconfig | 2 + configs/P1022DS_defconfig | 2 + configs/P1024RDB_36BIT_defconfig | 2 + configs/P1024RDB_NAND_defconfig | 2 + configs/P1024RDB_SDCARD_defconfig | 2 + configs/P1024RDB_SPIFLASH_defconfig | 2 + configs/P1024RDB_defconfig | 2 + configs/P1025RDB_36BIT_defconfig | 2 + configs/P1025RDB_NAND_defconfig | 2 + configs/P1025RDB_SDCARD_defconfig | 2 + configs/P1025RDB_SPIFLASH_defconfig | 2 + configs/P1025RDB_defconfig | 2 + configs/P2020RDB-PC_36BIT_NAND_defconfig | 2 + configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 2 + configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 2 + configs/P2020RDB-PC_36BIT_defconfig | 2 + configs/P2020RDB-PC_NAND_defconfig | 2 + configs/P2020RDB-PC_SDCARD_defconfig | 2 + configs/P2020RDB-PC_SPIFLASH_defconfig | 2 + configs/P2020RDB-PC_defconfig | 2 + configs/P2041RDB_NAND_defconfig | 2 + configs/P2041RDB_SDCARD_defconfig | 2 + configs/P2041RDB_SECURE_BOOT_defconfig | 2 + configs/P2041RDB_SPIFLASH_defconfig | 2 + configs/P2041RDB_SRIO_PCIE_BOOT_defconfig | 2 + configs/P2041RDB_defconfig | 2 + configs/P3041DS_NAND_SECURE_BOOT_defconfig | 2 + configs/P3041DS_NAND_defconfig | 2 + configs/P3041DS_SDCARD_defconfig | 2 + configs/P3041DS_SECURE_BOOT_defconfig | 2 + configs/P3041DS_SPIFLASH_defconfig | 2 + configs/P3041DS_SRIO_PCIE_BOOT_defconfig | 2 + configs/P3041DS_defconfig | 2 + configs/P4080DS_SDCARD_defconfig | 2 + configs/P4080DS_SECURE_BOOT_defconfig | 2 + configs/P4080DS_SPIFLASH_defconfig | 2 + configs/P4080DS_SRIO_PCIE_BOOT_defconfig | 2 + configs/P4080DS_defconfig | 2 + configs/P5020DS_NAND_SECURE_BOOT_defconfig | 2 + configs/P5020DS_NAND_defconfig | 2 + configs/P5020DS_SDCARD_defconfig | 2 + configs/P5020DS_SECURE_BOOT_defconfig | 2 + configs/P5020DS_SPIFLASH_defconfig | 2 + configs/P5020DS_SRIO_PCIE_BOOT_defconfig | 2 + configs/P5020DS_defconfig | 2 + configs/P5040DS_NAND_SECURE_BOOT_defconfig | 2 + configs/P5040DS_NAND_defconfig | 2 + configs/P5040DS_SDCARD_defconfig | 2 + configs/P5040DS_SECURE_BOOT_defconfig | 2 + configs/P5040DS_SPIFLASH_defconfig | 2 + configs/P5040DS_defconfig | 2 + configs/SBx81LIFKW_defconfig | 2 + configs/SBx81LIFXCAT_defconfig | 2 + configs/T1023RDB_NAND_defconfig | 2 + configs/T1023RDB_SDCARD_defconfig | 2 + configs/T1023RDB_SECURE_BOOT_defconfig | 2 + configs/T1023RDB_SPIFLASH_defconfig | 2 + configs/T1023RDB_defconfig | 2 + configs/T1024QDS_DDR4_SECURE_BOOT_defconfig | 2 + configs/T1024QDS_DDR4_defconfig | 2 + configs/T1024QDS_NAND_defconfig | 2 + configs/T1024QDS_SDCARD_defconfig | 2 + configs/T1024QDS_SECURE_BOOT_defconfig | 2 + configs/T1024QDS_SPIFLASH_defconfig | 2 + configs/T1024QDS_defconfig | 2 + configs/T1024RDB_NAND_defconfig | 2 + configs/T1024RDB_SDCARD_defconfig | 2 + configs/T1024RDB_SECURE_BOOT_defconfig | 2 + configs/T1024RDB_SPIFLASH_defconfig | 2 + configs/T1024RDB_defconfig | 2 + configs/T1040D4RDB_NAND_defconfig | 2 + configs/T1040D4RDB_SDCARD_defconfig | 2 + configs/T1040D4RDB_SECURE_BOOT_defconfig | 2 + configs/T1040D4RDB_SPIFLASH_defconfig | 2 + configs/T1040D4RDB_defconfig | 2 + configs/T1040QDS_DDR4_defconfig | 2 + configs/T1040QDS_SECURE_BOOT_defconfig | 2 + configs/T1040QDS_defconfig | 2 + configs/T1040RDB_NAND_defconfig | 2 + configs/T1040RDB_SDCARD_defconfig | 2 + configs/T1040RDB_SECURE_BOOT_defconfig | 2 + configs/T1040RDB_SPIFLASH_defconfig | 2 + configs/T1040RDB_defconfig | 2 + configs/T1042D4RDB_NAND_defconfig | 2 + configs/T1042D4RDB_SDCARD_defconfig | 2 + configs/T1042D4RDB_SECURE_BOOT_defconfig | 2 + configs/T1042D4RDB_SPIFLASH_defconfig | 2 + configs/T1042D4RDB_defconfig | 2 + configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig | 2 + configs/T1042RDB_PI_NAND_defconfig | 2 + configs/T1042RDB_PI_SDCARD_defconfig | 2 + configs/T1042RDB_PI_SPIFLASH_defconfig | 2 + configs/T1042RDB_PI_defconfig | 2 + configs/T1042RDB_SECURE_BOOT_defconfig | 2 + configs/T1042RDB_defconfig | 2 + configs/T2080QDS_NAND_defconfig | 2 + configs/T2080QDS_SDCARD_defconfig | 2 + configs/T2080QDS_SECURE_BOOT_defconfig | 2 + configs/T2080QDS_SPIFLASH_defconfig | 2 + configs/T2080QDS_SRIO_PCIE_BOOT_defconfig | 2 + configs/T2080QDS_defconfig | 2 + configs/T2080RDB_NAND_defconfig | 2 + configs/T2080RDB_SDCARD_defconfig | 2 + configs/T2080RDB_SECURE_BOOT_defconfig | 2 + configs/T2080RDB_SPIFLASH_defconfig | 2 + configs/T2080RDB_SRIO_PCIE_BOOT_defconfig | 2 + configs/T2080RDB_defconfig | 2 + configs/T2081QDS_NAND_defconfig | 2 + configs/T2081QDS_SDCARD_defconfig | 2 + configs/T2081QDS_SPIFLASH_defconfig | 2 + configs/T2081QDS_SRIO_PCIE_BOOT_defconfig | 2 + configs/T2081QDS_defconfig | 2 + configs/T4160QDS_NAND_defconfig | 2 + configs/T4160QDS_SDCARD_defconfig | 2 + configs/T4160QDS_SECURE_BOOT_defconfig | 2 + configs/T4160QDS_defconfig | 2 + configs/T4160RDB_defconfig | 2 + configs/T4240QDS_NAND_defconfig | 2 + configs/T4240QDS_SDCARD_defconfig | 2 + configs/T4240QDS_SECURE_BOOT_defconfig | 2 + configs/T4240QDS_SRIO_PCIE_BOOT_defconfig | 2 + configs/T4240QDS_defconfig | 2 + configs/T4240RDB_SDCARD_defconfig | 2 + configs/T4240RDB_defconfig | 2 + configs/UCP1020_SPIFLASH_defconfig | 2 + configs/UCP1020_defconfig | 2 + configs/ae350_rv32_defconfig | 1 + configs/ae350_rv64_defconfig | 1 + configs/am335x_boneblack_vboot_defconfig | 1 + configs/am335x_evm_defconfig | 1 + configs/am335x_hs_evm_defconfig | 1 + configs/am335x_hs_evm_uart_defconfig | 1 + configs/am43xx_evm_defconfig | 1 + configs/am43xx_evm_qspiboot_defconfig | 1 + configs/am43xx_evm_rtconly_defconfig | 1 + configs/am43xx_evm_usbhost_boot_defconfig | 1 + configs/am43xx_hs_evm_defconfig | 1 + configs/am57xx_evm_defconfig | 2 + configs/am57xx_hs_evm_defconfig | 2 + configs/am57xx_hs_evm_usb_defconfig | 2 + configs/ap121_defconfig | 2 + configs/ap143_defconfig | 2 + configs/aristainetos2_defconfig | 4 ++ configs/aristainetos2b_defconfig | 2 + configs/aristainetos_defconfig | 3 ++ configs/at91sam9260ek_dataflash_cs0_defconfig | 2 + configs/at91sam9260ek_dataflash_cs1_defconfig | 2 + configs/at91sam9261ek_dataflash_cs0_defconfig | 2 + configs/at91sam9261ek_dataflash_cs3_defconfig | 2 + configs/at91sam9263ek_dataflash_cs0_defconfig | 2 + configs/at91sam9263ek_dataflash_defconfig | 2 + configs/at91sam9g10ek_dataflash_cs0_defconfig | 2 + configs/at91sam9g10ek_dataflash_cs3_defconfig | 2 + configs/at91sam9g20ek_dataflash_cs0_defconfig | 2 + configs/at91sam9g20ek_dataflash_cs1_defconfig | 2 + configs/at91sam9n12ek_mmc_defconfig | 1 + configs/at91sam9n12ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_spiflash_defconfig | 1 + configs/at91sam9rlek_dataflash_defconfig | 2 + configs/at91sam9x5ek_dataflash_defconfig | 1 + configs/at91sam9x5ek_mmc_defconfig | 1 + configs/at91sam9x5ek_nandflash_defconfig | 1 + configs/at91sam9x5ek_spiflash_defconfig | 1 + configs/at91sam9xeek_dataflash_cs0_defconfig | 2 + configs/at91sam9xeek_dataflash_cs1_defconfig | 2 + configs/bcm7445_defconfig | 3 ++ configs/beaver_defconfig | 2 + configs/bg0900_defconfig | 4 ++ configs/birdland_bav335a_defconfig | 1 + configs/birdland_bav335b_defconfig | 1 + configs/brppt1_spi_defconfig | 1 + configs/cardhu_defconfig | 2 + configs/cei-tk1-som_defconfig | 2 + configs/cgtqmx6eval_defconfig | 2 + configs/chromebit_mickey_defconfig | 1 + configs/chromebook_bob_defconfig | 1 + configs/chromebook_jerry_defconfig | 1 + configs/chromebook_minnie_defconfig | 1 + configs/chromebook_speedy_defconfig | 1 + configs/cl-som-am57x_defconfig | 1 + configs/cl-som-imx7_defconfig | 2 + configs/clearfog_defconfig | 1 + configs/clearfog_gt_8k_defconfig | 1 + configs/cm_fx6_defconfig | 2 + configs/cm_t43_defconfig | 1 + .../controlcenterd_36BIT_SDCARD_DEVELOP_defconfig | 2 + configs/controlcenterd_36BIT_SDCARD_defconfig | 2 + configs/controlcenterdc_defconfig | 5 ++ configs/d2net_v2_defconfig | 2 + configs/da850_am18xxevm_defconfig | 4 ++ configs/da850evm_defconfig | 4 ++ configs/dalmore_defconfig | 2 + configs/db-88f6720_defconfig | 2 + configs/db-88f6820-amc_defconfig | 3 ++ configs/db-88f6820-gp_defconfig | 2 + configs/db-mv784mp-gp_defconfig | 2 + configs/dh_imx6_defconfig | 2 + configs/display5_defconfig | 3 ++ configs/display5_factory_defconfig | 3 ++ configs/dms-ba16-1g_defconfig | 2 + configs/dms-ba16_defconfig | 2 + configs/dra7xx_evm_defconfig | 2 + configs/dra7xx_hs_evm_defconfig | 2 + configs/dra7xx_hs_evm_usb_defconfig | 2 + configs/dreamplug_defconfig | 2 + configs/ds109_defconfig | 2 + configs/ds414_defconfig | 2 + configs/e2220-1170_defconfig | 2 + configs/ea20_defconfig | 1 + configs/ethernut5_defconfig | 2 + configs/evb-rk3036_defconfig | 1 + configs/evb-rk3128_defconfig | 1 + configs/evb-rk3288_defconfig | 1 + configs/evb-rk3328_defconfig | 1 + configs/evb-rk3399_defconfig | 1 + configs/fennec-rk3288_defconfig | 1 + configs/ficus-rk3399_defconfig | 1 + configs/firefly-rk3288_defconfig | 1 + configs/firefly-rk3399_defconfig | 1 + configs/ge_bx50v3_defconfig | 2 + configs/helios4_defconfig | 2 + configs/inetspace_v2_defconfig | 2 + configs/jetson-tk1_defconfig | 2 + configs/k2e_evm_defconfig | 1 + configs/k2e_hs_evm_defconfig | 1 + configs/k2g_evm_defconfig | 2 + configs/k2g_hs_evm_defconfig | 2 + configs/k2hk_evm_defconfig | 1 + configs/k2hk_hs_evm_defconfig | 1 + configs/k2l_evm_defconfig | 1 + configs/k2l_hs_evm_defconfig | 1 + configs/km_kirkwood_128m16_defconfig | 1 + configs/km_kirkwood_defconfig | 1 + configs/km_kirkwood_pci_defconfig | 1 + configs/kmcoge4_defconfig | 2 + configs/kmcoge5un_defconfig | 1 + configs/kmlion1_defconfig | 2 + configs/kmnusa_defconfig | 1 + configs/kmsugp1_defconfig | 1 + configs/kmsuv31_defconfig | 1 + configs/kylin-rk3036_defconfig | 1 + configs/legoev3_defconfig | 1 + configs/ls1012aqds_qspi_defconfig | 11 +++++ configs/ls1012aqds_tfa_SECURE_BOOT_defconfig | 5 ++ configs/ls1012aqds_tfa_defconfig | 11 +++++ configs/ls1043aqds_defconfig | 1 + configs/ls1043aqds_lpuart_defconfig | 1 + configs/ls1043aqds_nand_defconfig | 1 + configs/ls1043aqds_nor_ddr3_defconfig | 1 + configs/ls1043aqds_sdcard_ifc_defconfig | 1 + configs/ls1043aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1043aqds_tfa_defconfig | 3 ++ configs/ls1043ardb_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_defconfig | 1 + configs/ls1043ardb_nand_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_nand_defconfig | 1 + configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_sdcard_defconfig | 1 + configs/ls1043ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_tfa_defconfig | 1 + configs/ls1046aqds_SECURE_BOOT_defconfig | 1 + configs/ls1046aqds_defconfig | 1 + configs/ls1046aqds_lpuart_defconfig | 1 + configs/ls1046aqds_nand_defconfig | 1 + configs/ls1046aqds_sdcard_ifc_defconfig | 1 + configs/ls1046aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1046aqds_tfa_defconfig | 3 ++ configs/lschlv2_defconfig | 1 + configs/lsxhl_defconfig | 1 + configs/marsboard_defconfig | 2 + configs/maxbcm_defconfig | 2 + configs/mccmon6_nor_defconfig | 3 ++ configs/mccmon6_sd_defconfig | 3 ++ configs/meesc_dataflash_defconfig | 2 + configs/mgcoge3un_defconfig | 1 + configs/miqi-rk3288_defconfig | 1 + configs/mscc_jr2_defconfig | 4 ++ configs/mscc_luton_defconfig | 4 ++ configs/mscc_ocelot_defconfig | 4 ++ configs/mscc_serval_defconfig | 4 ++ configs/mscc_servalt_defconfig | 4 ++ configs/mvebu_db-88f3720_defconfig | 1 + configs/mvebu_db_armada8k_defconfig | 1 + configs/mvebu_espressobin-88f3720_defconfig | 1 + configs/mvebu_mcbin-88f8040_defconfig | 1 + configs/mx28evk_auart_console_defconfig | 4 ++ configs/mx28evk_defconfig | 4 ++ configs/mx28evk_nand_defconfig | 4 ++ configs/mx28evk_spi_defconfig | 4 ++ configs/mx31pdk_defconfig | 2 + configs/mx6qsabrelite_defconfig | 2 + configs/mx6sabreauto_defconfig | 2 + configs/mx6sabresd_defconfig | 2 + configs/mx6slevk_defconfig | 2 + configs/mx6slevk_spinor_defconfig | 2 + configs/mx6slevk_spl_defconfig | 2 + configs/mx6sxsabreauto_defconfig | 2 + configs/mx6sxsabresd_defconfig | 3 ++ configs/mx6ul_14x14_evk_defconfig | 2 + configs/mx6ul_9x9_evk_defconfig | 2 + configs/mx6ull_14x14_evk_defconfig | 2 + configs/mx6ull_14x14_evk_plugin_defconfig | 2 + configs/mx7dsabresd_qspi_defconfig | 2 + configs/net2big_v2_defconfig | 2 + configs/netspace_lite_v2_defconfig | 2 + configs/netspace_max_v2_defconfig | 2 + configs/netspace_mini_v2_defconfig | 2 + configs/netspace_v2_defconfig | 2 + configs/nitrogen6dl2g_defconfig | 2 + configs/nitrogen6dl_defconfig | 2 + configs/nitrogen6q2g_defconfig | 2 + configs/nitrogen6q_defconfig | 2 + configs/nitrogen6s1g_defconfig | 2 + configs/nitrogen6s_defconfig | 2 + configs/nyan-big_defconfig | 2 + configs/omapl138_lcdk_defconfig | 1 + configs/ot1200_defconfig | 3 ++ configs/ot1200_spl_defconfig | 3 ++ configs/p2371-0000_defconfig | 2 + configs/p2371-2180_defconfig | 2 + configs/p2571_defconfig | 2 + configs/pcm051_rev1_defconfig | 1 + configs/pcm051_rev3_defconfig | 1 + configs/pcm058_defconfig | 2 + configs/peach-pi_defconfig | 4 ++ configs/peach-pit_defconfig | 4 ++ configs/pfla02_defconfig | 3 ++ configs/phycore-rk3288_defconfig | 1 + configs/popmetal-rk3288_defconfig | 1 + configs/portl2_defconfig | 1 + configs/puma-rk3399_defconfig | 1 + configs/riotboard_defconfig | 2 + configs/riotboard_spl_defconfig | 2 + configs/rock2_defconfig | 1 + configs/rock960-rk3399_defconfig | 1 + configs/rock_defconfig | 1 + configs/sama5d27_som1_ek_mmc1_defconfig | 1 + configs/sama5d27_som1_ek_mmc_defconfig | 1 + configs/sama5d2_xplained_emmc_defconfig | 1 + configs/sama5d2_xplained_mmc_defconfig | 1 + configs/sama5d2_xplained_spiflash_defconfig | 1 + configs/sama5d36ek_cmp_mmc_defconfig | 1 + configs/sama5d36ek_cmp_nandflash_defconfig | 1 + configs/sama5d36ek_cmp_spiflash_defconfig | 1 + configs/sama5d3xek_mmc_defconfig | 1 + configs/sama5d3xek_nandflash_defconfig | 1 + configs/sama5d3xek_spiflash_defconfig | 1 + configs/sama5d4_xplained_mmc_defconfig | 1 + configs/sama5d4_xplained_nandflash_defconfig | 1 + configs/sama5d4_xplained_spiflash_defconfig | 1 + configs/sama5d4ek_mmc_defconfig | 1 + configs/sama5d4ek_nandflash_defconfig | 1 + configs/sama5d4ek_spiflash_defconfig | 1 + configs/smdk5250_defconfig | 4 ++ configs/smdk5420_defconfig | 4 ++ configs/snow_defconfig | 4 ++ configs/socfpga_sr1500_defconfig | 1 + configs/socfpga_stratix10_defconfig | 1 + configs/spring_defconfig | 4 ++ configs/stmark2_defconfig | 3 ++ configs/tec-ng_defconfig | 2 + configs/theadorable_debug_defconfig | 3 ++ configs/tinker-rk3288_defconfig | 1 + configs/topic_miami_defconfig | 3 +- configs/topic_miamilite_defconfig | 3 +- configs/topic_miamiplus_defconfig | 2 + configs/tqma6dl_mba6_mmc_defconfig | 2 + configs/tqma6dl_mba6_spi_defconfig | 2 + configs/tqma6q_mba6_mmc_defconfig | 2 + configs/tqma6q_mba6_spi_defconfig | 2 + configs/tqma6s_mba6_mmc_defconfig | 2 + configs/tqma6s_mba6_spi_defconfig | 2 + configs/trimslice_defconfig | 3 ++ configs/turris_mox_defconfig | 2 + configs/turris_omnia_defconfig | 2 + configs/uDPU_defconfig | 1 + configs/usb_a9263_dataflash_defconfig | 2 + configs/venice2_defconfig | 2 + configs/vinco_defconfig | 2 + configs/vyasa-rk3288_defconfig | 1 + configs/x530_defconfig | 2 + configs/zc5202_defconfig | 3 ++ configs/zc5601_defconfig | 3 ++ configs/zynq_cc108_defconfig | 1 + configs/zynq_cse_qspi_defconfig | 1 + configs/zynq_dlc20_rev1_0_defconfig | 1 + configs/zynq_microzed_defconfig | 1 + configs/zynq_minized_defconfig | 1 + configs/zynq_z_turn_defconfig | 1 + configs/zynq_zc702_defconfig | 1 + configs/zynq_zc706_defconfig | 1 + configs/zynq_zc770_xm010_defconfig | 1 + configs/zynq_zc770_xm013_defconfig | 1 + configs/zynq_zed_defconfig | 1 + configs/zynq_zybo_defconfig | 1 + configs/zynq_zybo_z7_defconfig | 1 + drivers/mtd/spi/Kconfig | 36 +++++++++++++++ env/Kconfig | 53 +++++++++++++++++++--- env/sf.c | 13 ------ include/configs/B4860QDS.h | 6 --- include/configs/BSC9131RDB.h | 8 ---- include/configs/BSC9132QDS.h | 8 ---- include/configs/C29XPCIE.h | 6 --- include/configs/M52277EVB.h | 3 -- include/configs/M54418TWR.h | 1 - include/configs/M54451EVB.h | 1 - include/configs/M54455EVB.h | 3 -- include/configs/MPC8536DS.h | 9 ---- include/configs/P1010RDB.h | 6 --- include/configs/P1022DS.h | 7 --- include/configs/P2041RDB.h | 6 --- include/configs/SBx81LIFKW.h | 4 -- include/configs/SBx81LIFXCAT.h | 4 -- include/configs/T102xQDS.h | 6 --- include/configs/T102xRDB.h | 6 --- include/configs/T1040QDS.h | 6 --- include/configs/T104xRDB.h | 6 --- include/configs/T208xQDS.h | 9 ---- include/configs/T208xRDB.h | 8 ---- include/configs/T4240QDS.h | 6 --- include/configs/T4240RDB.h | 6 --- include/configs/UCP1020.h | 7 --- include/configs/adp-ae3xx.h | 8 ---- include/configs/advantech_dms-ba16.h | 10 ---- include/configs/am335x_evm.h | 2 - include/configs/am43xx_evm.h | 3 -- include/configs/am57xx_evm.h | 2 - include/configs/ap121.h | 1 - include/configs/ap143.h | 1 - include/configs/aristainetos-common.h | 6 --- include/configs/aristainetos.h | 3 -- include/configs/aristainetos2.h | 3 -- include/configs/aristainetos2b.h | 3 -- include/configs/at91sam9260ek.h | 2 - include/configs/at91sam9261ek.h | 2 - include/configs/at91sam9263ek.h | 1 - include/configs/at91sam9n12ek.h | 3 -- include/configs/at91sam9rlek.h | 1 - include/configs/at91sam9x5ek.h | 5 -- include/configs/ax25-ae350.h | 8 ---- include/configs/bav335x.h | 2 - include/configs/bcm7445.h | 4 -- include/configs/beaver.h | 2 - include/configs/bg0900.h | 16 ------- include/configs/brppt1.h | 2 - include/configs/cardhu.h | 2 - include/configs/cei-tk1-som.h | 2 - include/configs/cgtqmx6eval.h | 7 --- include/configs/cl-som-am57x.h | 3 -- include/configs/cl-som-imx7.h | 8 ---- include/configs/clearfog.h | 1 - include/configs/cm_fx6.h | 8 ---- include/configs/cm_t43.h | 3 -- include/configs/controlcenterd.h | 10 ---- include/configs/controlcenterdc.h | 12 ----- include/configs/corenet_ds.h | 6 --- include/configs/da850evm.h | 3 -- include/configs/dalmore.h | 2 - include/configs/db-88f6720.h | 2 - include/configs/db-88f6820-amc.h | 4 -- include/configs/db-88f6820-gp.h | 4 -- include/configs/db-mv784mp-gp.h | 2 - include/configs/dh_imx6.h | 10 ---- include/configs/display5.h | 11 ----- include/configs/dra7xx_evm.h | 3 -- include/configs/dreamplug.h | 3 -- include/configs/ds109.h | 3 -- include/configs/ds414.h | 2 - include/configs/e2220-1170.h | 2 - include/configs/ea20.h | 2 - include/configs/el6x_common.h | 4 -- include/configs/embestmx6boards.h | 11 ----- include/configs/ethernut5.h | 1 - include/configs/exynos5-common.h | 7 --- include/configs/exynos5-dt-common.h | 2 +- include/configs/ge_bx50v3.h | 10 ---- include/configs/gw_ventana.h | 8 ---- include/configs/helios4.h | 11 ----- include/configs/jetson-tk1.h | 2 - include/configs/k2g_evm.h | 3 -- include/configs/km/km_arm.h | 6 --- include/configs/km/kmp204x-common.h | 6 --- include/configs/lacie_kw.h | 2 - include/configs/legoev3.h | 2 - include/configs/ls1012a_common.h | 4 -- include/configs/ls1012aqds.h | 7 --- include/configs/ls1043a_common.h | 12 ----- include/configs/ls1046a_common.h | 8 ---- include/configs/ls1046aqds.h | 4 -- include/configs/ls1088aqds.h | 2 - include/configs/lsxl.h | 6 --- include/configs/maxbcm.h | 2 - include/configs/mccmon6.h | 5 -- include/configs/meesc.h | 1 - include/configs/microblaze-generic.h | 7 --- include/configs/mvebu_armada-37xx.h | 6 --- include/configs/mvebu_armada-8k.h | 7 --- include/configs/mx28evk.h | 20 -------- include/configs/mx31pdk.h | 3 -- include/configs/mx6sabre_common.h | 7 --- include/configs/mx6slevk.h | 11 ----- include/configs/mx6sxsabreauto.h | 4 -- include/configs/mx6sxsabresd.h | 4 -- include/configs/mx6ul_14x14_evk.h | 4 -- include/configs/mx6ullevk.h | 4 -- include/configs/mx7dsabresd.h | 4 -- include/configs/nitrogen6x.h | 11 ----- include/configs/nyan-big.h | 2 - include/configs/omapl138_lcdk.h | 2 - include/configs/ot1200.h | 8 ---- include/configs/p1_p2_rdb_pc.h | 9 ---- include/configs/p2371-0000.h | 2 - include/configs/p2371-2180.h | 2 - include/configs/p2571.h | 2 - include/configs/pcm051.h | 2 - include/configs/pcm058.h | 8 ---- include/configs/pfla02.h | 8 ---- include/configs/pm9261.h | 1 - include/configs/pm9263.h | 1 - include/configs/puma_rk3399.h | 4 -- include/configs/rk3036_common.h | 1 - include/configs/rk3128_common.h | 1 - include/configs/rk3188_common.h | 2 - include/configs/rk3288_common.h | 2 - include/configs/rk3328_common.h | 2 - include/configs/rk3399_common.h | 2 - include/configs/sama5d27_som1_ek.h | 1 - include/configs/sama5d2_xplained.h | 5 -- include/configs/sama5d3xek.h | 4 -- include/configs/sama5d4_xplained.h | 4 -- include/configs/sama5d4ek.h | 4 -- include/configs/siemens-am33x-common.h | 3 -- include/configs/socfpga_common.h | 1 - include/configs/socfpga_sr1500.h | 5 -- include/configs/socfpga_stratix10_socdk.h | 4 -- include/configs/stmark2.h | 4 -- include/configs/taurus.h | 4 -- include/configs/tec-ng.h | 2 - include/configs/theadorable.h | 2 - include/configs/ti_armv7_keystone2.h | 2 - include/configs/topic_miami.h | 4 -- include/configs/tqma6.h | 10 ---- include/configs/trimslice.h | 3 -- include/configs/turris_mox.h | 7 --- include/configs/turris_omnia.h | 2 - include/configs/usb_a9263.h | 1 - include/configs/vcoreiii.h | 2 - include/configs/venice2.h | 2 - include/configs/vinco.h | 8 ---- include/configs/x530.h | 5 -- include/configs/zynq-common.h | 3 -- include/spi_flash.h | 17 +++---- scripts/config_whitelist.txt | 7 --- 658 files changed, 1044 insertions(+), 811 deletions(-)
Move some configurations in defconfig file - CONFIG_DM_SPI (removed by syncing defconfigs ) - CONFIG_CMD_SF - CONFIG_CMD_SPI - CONFIG_CMD_SF_TEST
This allow correct dependency handling in Kconfig.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
configs/bcm7445_defconfig | 3 +++ include/configs/bcm7445.h | 4 ---- 2 files changed, 3 insertions(+), 4 deletions(-)
diff --git a/configs/bcm7445_defconfig b/configs/bcm7445_defconfig index a09ac5c..97098bf 100644 --- a/configs/bcm7445_defconfig +++ b/configs/bcm7445_defconfig @@ -8,6 +8,9 @@ CONFIG_FIT_SIGNATURE=y CONFIG_BOOTDELAY=1 CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot>" +CONFIG_CMD_SF=y +CONFIG_CMD_SF_TEST=y +CONFIG_CMD_SPI=y CONFIG_OF_PRIOR_STAGE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MMC_SDHCI=y diff --git a/include/configs/bcm7445.h b/include/configs/bcm7445.h index 8c675f7..6984edd 100644 --- a/include/configs/bcm7445.h +++ b/include/configs/bcm7445.h @@ -34,10 +34,6 @@ #define CONFIG_ENV_OFFSET 0x1e0000 #define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE
-#define CONFIG_DM_SPI 1 #define CONFIG_SYS_MAX_FLASH_BANKS 1 -#define CONFIG_CMD_SF -#define CONFIG_CMD_SPI -#define CONFIG_CMD_SF_TEST
#endif /* __CONFIG_H */
- CONFIG_CMD_SF
- CONFIG_CMD_SPI
Move some configurations in defconfig file - CONFIG_CMD_I2C - CONFIG_CMD_SPI
configs/controlcenterdc_defconfig | 2 ++ include/configs/controlcenterdc.h | 6 ------ 2 files changed, 2 insertions(+), 6 deletions(-)
diff --git a/configs/controlcenterdc_defconfig b/configs/controlcenterdc_defconfig index f22a3ab..b4b5732 100644 --- a/configs/controlcenterdc_defconfig +++ b/configs/controlcenterdc_defconfig @@ -26,9 +26,11 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_GO is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y diff --git a/include/configs/controlcenterdc.h b/include/configs/controlcenterdc.h index 06c93c3..2433815 100644 --- a/include/configs/controlcenterdc.h +++ b/include/configs/controlcenterdc.h @@ -25,12 +25,6 @@
#define CONFIG_LOADADDR 1000000
-/* - * Commands configuration - */ -#define CONFIG_CMD_I2C -#define CONFIG_CMD_SPI - /* SPI NOR flash default params, used by sf commands */ #define CONFIG_SF_DEFAULT_BUS 1 #define CONFIG_SF_DEFAULT_SPEED 1000000
- CONFIG_CMD_I2C
- CONFIG_CMD_SPI
Replace CONFIG_ENV_SPI_BASE by the better CONFIG_SYS_SPI_BASE (it is not the location for environment but the location for U-Boot) and, as it is the only platform with use this define, remove it from whitelist.
arch/arm/mach-exynos/spl_boot.c | 2 +- include/configs/exynos5-dt-common.h | 2 +- scripts/config_whitelist.txt | 1 - 3 files changed, 2 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-exynos/spl_boot.c b/arch/arm/mach-exynos/spl_boot.c index b4945bd..103bb38 100644 --- a/arch/arm/mach-exynos/spl_boot.c +++ b/arch/arm/mach-exynos/spl_boot.c @@ -107,7 +107,7 @@ static void exynos_spi_copy(unsigned int uboot_size, unsigned int uboot_addr) { int upto, todo; int i, timeout = 100; - struct exynos_spi *regs = (struct exynos_spi *)CONFIG_ENV_SPI_BASE; + struct exynos_spi *regs = (struct exynos_spi *)CONFIG_SYS_SPI_BASE;
set_spi_clk(PERIPH_ID_SPI1, 50000000); /* set spi clock to 50Mhz */ /* set the spi1 GPIO */ diff --git a/include/configs/exynos5-dt-common.h b/include/configs/exynos5-dt-common.h index 696f009..a87182a 100644 --- a/include/configs/exynos5-dt-common.h +++ b/include/configs/exynos5-dt-common.h @@ -17,7 +17,7 @@
#define CONFIG_EXYNOS5_DT
-#define CONFIG_ENV_SPI_BASE 0x12D30000 +#define CONFIG_SYS_SPI_BASE 0x12D30000 #define FLASH_SIZE (4 << 20) #define CONFIG_ENV_OFFSET (FLASH_SIZE - CONFIG_ENV_SECT_SIZE) #define CONFIG_SPI_BOOTING diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 2b35725..3e01f84 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -498,7 +498,6 @@ CONFIG_ENV_SETTINGS_V1 CONFIG_ENV_SETTINGS_V2 CONFIG_ENV_SIZE_FLEX CONFIG_ENV_SIZE_REDUND -CONFIG_ENV_SPI_BASE CONFIG_ENV_SPI_BUS CONFIG_ENV_SPI_CS CONFIG_ENV_SPI_MAX_HZ
Define the function board_spi_cs_gpio only when needed, only called in drivers/spi/mxc_spi.c. That avoid compilation issue for tqma6s_wru4_mmc_defconfig when CONFIG_SF_DEFAULT_BUS and CONFIG_SF_DEFAULT_CS are not defined (CMD_SF not defined) after migration in KConfig.
board/tqc/tqma6/tqma6.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/board/tqc/tqma6/tqma6.c b/board/tqc/tqma6/tqma6.c index 816672e..372a17c 100644 --- a/board/tqc/tqma6/tqma6.c +++ b/board/tqc/tqma6/tqma6.c @@ -155,11 +155,13 @@ __weak void tqma6_iomuxc_spi(void) ARRAY_SIZE(tqma6_ecspi1_pads)); }
+#if defined(CONFIG_SF_DEFAULT_BUS) && defined(CONFIG_SF_DEFAULT_CS) int board_spi_cs_gpio(unsigned bus, unsigned cs) { return ((bus == CONFIG_SF_DEFAULT_BUS) && (cs == CONFIG_SF_DEFAULT_CS)) ? TQMA6_SF_CS_GPIO : -1; } +#endif
static struct i2c_pads_info tqma6_i2c3_pads = { /* I2C3: on board LM75, M24C64, */
This converts the following to Kconfig: CONFIG_SF_DEFAULT_BUS CONFIG_SF_DEFAULT_CS CONFIG_SF_DEFAULT_MODE CONFIG_SF_DEFAULT_SPEED
I use moveconfig script and then manual check on generated u-boot.cfg to solve the remaining issue.
README | 15 --------- board/Arcturus/ucp1020/cmd_arc.c | 13 -------- configs/B4420QDS_NAND_defconfig | 2 ++ configs/B4420QDS_SPIFLASH_defconfig | 2 ++ configs/B4420QDS_defconfig | 2 ++ configs/B4860QDS_NAND_defconfig | 2 ++ configs/B4860QDS_SECURE_BOOT_defconfig | 2 ++ configs/B4860QDS_SPIFLASH_defconfig | 2 ++ configs/B4860QDS_SRIO_PCIE_BOOT_defconfig | 2 ++ configs/B4860QDS_defconfig | 2 ++ configs/BSC9131RDB_NAND_SYSCLK100_defconfig | 2 ++ configs/BSC9131RDB_NAND_defconfig | 2 ++ configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig | 2 ++ configs/BSC9131RDB_SPIFLASH_defconfig | 2 ++ configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig | 2 ++ configs/BSC9132QDS_NAND_DDRCLK100_defconfig | 2 ++ configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig | 2 ++ configs/BSC9132QDS_NAND_DDRCLK133_defconfig | 2 ++ configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig | 2 ++ configs/BSC9132QDS_NOR_DDRCLK100_defconfig | 2 ++ configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig | 2 ++ configs/BSC9132QDS_NOR_DDRCLK133_defconfig | 2 ++ .../BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig | 2 ++ configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig | 2 ++ .../BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig | 2 ++ configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig | 2 ++ .../BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig | 2 ++ configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig | 2 ++ .../BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig | 2 ++ configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig | 2 ++ configs/C29XPCIE_NAND_defconfig | 2 ++ configs/C29XPCIE_NOR_SECBOOT_defconfig | 2 ++ configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig | 2 ++ configs/C29XPCIE_SPIFLASH_defconfig | 2 ++ configs/C29XPCIE_defconfig | 2 ++ configs/MPC8536DS_36BIT_defconfig | 2 ++ configs/MPC8536DS_SDCARD_defconfig | 2 ++ configs/MPC8536DS_SPIFLASH_defconfig | 2 ++ configs/MPC8536DS_defconfig | 2 ++ configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig | 2 ++ configs/P1010RDB-PA_36BIT_NAND_defconfig | 2 ++ configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig | 2 ++ configs/P1010RDB-PA_36BIT_NOR_defconfig | 2 ++ configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 2 ++ .../P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig | 2 ++ configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 2 ++ configs/P1010RDB-PA_NAND_SECBOOT_defconfig | 2 ++ configs/P1010RDB-PA_NAND_defconfig | 2 ++ configs/P1010RDB-PA_NOR_SECBOOT_defconfig | 2 ++ configs/P1010RDB-PA_NOR_defconfig | 2 ++ configs/P1010RDB-PA_SDCARD_defconfig | 2 ++ configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig | 2 ++ configs/P1010RDB-PA_SPIFLASH_defconfig | 2 ++ configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig | 2 ++ configs/P1010RDB-PB_36BIT_NAND_defconfig | 2 ++ configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig | 2 ++ configs/P1010RDB-PB_36BIT_NOR_defconfig | 2 ++ configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 2 ++ .../P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig | 2 ++ configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 2 ++ configs/P1010RDB-PB_NAND_SECBOOT_defconfig | 2 ++ configs/P1010RDB-PB_NAND_defconfig | 2 ++ configs/P1010RDB-PB_NOR_SECBOOT_defconfig | 2 ++ configs/P1010RDB-PB_NOR_defconfig | 2 ++ configs/P1010RDB-PB_SDCARD_defconfig | 2 ++ configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig | 2 ++ configs/P1010RDB-PB_SPIFLASH_defconfig | 2 ++ configs/P1020RDB-PC_36BIT_NAND_defconfig | 2 ++ configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 2 ++ configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 2 ++ configs/P1020RDB-PC_36BIT_defconfig | 2 ++ configs/P1020RDB-PC_NAND_defconfig | 2 ++ configs/P1020RDB-PC_SDCARD_defconfig | 2 ++ configs/P1020RDB-PC_SPIFLASH_defconfig | 2 ++ configs/P1020RDB-PC_defconfig | 2 ++ configs/P1020RDB-PD_NAND_defconfig | 2 ++ configs/P1020RDB-PD_SDCARD_defconfig | 2 ++ configs/P1020RDB-PD_SPIFLASH_defconfig | 2 ++ configs/P1020RDB-PD_defconfig | 2 ++ configs/P1021RDB-PC_36BIT_NAND_defconfig | 2 ++ configs/P1021RDB-PC_36BIT_SDCARD_defconfig | 2 ++ configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig | 2 ++ configs/P1021RDB-PC_36BIT_defconfig | 2 ++ configs/P1021RDB-PC_NAND_defconfig | 2 ++ configs/P1021RDB-PC_SDCARD_defconfig | 2 ++ configs/P1021RDB-PC_SPIFLASH_defconfig | 2 ++ configs/P1021RDB-PC_defconfig | 2 ++ configs/P1022DS_36BIT_NAND_defconfig | 2 ++ configs/P1022DS_36BIT_SDCARD_defconfig | 2 ++ configs/P1022DS_36BIT_SPIFLASH_defconfig | 2 ++ configs/P1022DS_36BIT_defconfig | 2 ++ configs/P1022DS_NAND_defconfig | 2 ++ configs/P1022DS_SDCARD_defconfig | 2 ++ configs/P1022DS_SPIFLASH_defconfig | 2 ++ configs/P1022DS_defconfig | 2 ++ configs/P1024RDB_36BIT_defconfig | 2 ++ configs/P1024RDB_NAND_defconfig | 2 ++ configs/P1024RDB_SDCARD_defconfig | 2 ++ configs/P1024RDB_SPIFLASH_defconfig | 2 ++ configs/P1024RDB_defconfig | 2 ++ configs/P1025RDB_36BIT_defconfig | 2 ++ configs/P1025RDB_NAND_defconfig | 2 ++ configs/P1025RDB_SDCARD_defconfig | 2 ++ configs/P1025RDB_SPIFLASH_defconfig | 2 ++ configs/P1025RDB_defconfig | 2 ++ configs/P2020RDB-PC_36BIT_NAND_defconfig | 2 ++ configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 2 ++ configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 2 ++ configs/P2020RDB-PC_36BIT_defconfig | 2 ++ configs/P2020RDB-PC_NAND_defconfig | 2 ++ configs/P2020RDB-PC_SDCARD_defconfig | 2 ++ configs/P2020RDB-PC_SPIFLASH_defconfig | 2 ++ configs/P2020RDB-PC_defconfig | 2 ++ configs/P2041RDB_NAND_defconfig | 2 ++ configs/P2041RDB_SDCARD_defconfig | 2 ++ configs/P2041RDB_SECURE_BOOT_defconfig | 2 ++ configs/P2041RDB_SPIFLASH_defconfig | 2 ++ configs/P2041RDB_SRIO_PCIE_BOOT_defconfig | 2 ++ configs/P2041RDB_defconfig | 2 ++ configs/P3041DS_NAND_SECURE_BOOT_defconfig | 2 ++ configs/P3041DS_NAND_defconfig | 2 ++ configs/P3041DS_SDCARD_defconfig | 2 ++ configs/P3041DS_SECURE_BOOT_defconfig | 2 ++ configs/P3041DS_SPIFLASH_defconfig | 2 ++ configs/P3041DS_SRIO_PCIE_BOOT_defconfig | 2 ++ configs/P3041DS_defconfig | 2 ++ configs/P4080DS_SDCARD_defconfig | 2 ++ configs/P4080DS_SECURE_BOOT_defconfig | 2 ++ configs/P4080DS_SPIFLASH_defconfig | 2 ++ configs/P4080DS_SRIO_PCIE_BOOT_defconfig | 2 ++ configs/P4080DS_defconfig | 2 ++ configs/P5020DS_NAND_SECURE_BOOT_defconfig | 2 ++ configs/P5020DS_NAND_defconfig | 2 ++ configs/P5020DS_SDCARD_defconfig | 2 ++ configs/P5020DS_SECURE_BOOT_defconfig | 2 ++ configs/P5020DS_SPIFLASH_defconfig | 2 ++ configs/P5020DS_SRIO_PCIE_BOOT_defconfig | 2 ++ configs/P5020DS_defconfig | 2 ++ configs/P5040DS_NAND_SECURE_BOOT_defconfig | 2 ++ configs/P5040DS_NAND_defconfig | 2 ++ configs/P5040DS_SDCARD_defconfig | 2 ++ configs/P5040DS_SECURE_BOOT_defconfig | 2 ++ configs/P5040DS_SPIFLASH_defconfig | 2 ++ configs/P5040DS_defconfig | 2 ++ configs/T1023RDB_NAND_defconfig | 2 ++ configs/T1023RDB_SDCARD_defconfig | 2 ++ configs/T1023RDB_SECURE_BOOT_defconfig | 2 ++ configs/T1023RDB_SPIFLASH_defconfig | 2 ++ configs/T1023RDB_defconfig | 2 ++ configs/T1024QDS_DDR4_SECURE_BOOT_defconfig | 2 ++ configs/T1024QDS_DDR4_defconfig | 2 ++ configs/T1024QDS_NAND_defconfig | 2 ++ configs/T1024QDS_SDCARD_defconfig | 2 ++ configs/T1024QDS_SECURE_BOOT_defconfig | 2 ++ configs/T1024QDS_SPIFLASH_defconfig | 2 ++ configs/T1024QDS_defconfig | 2 ++ configs/T1024RDB_NAND_defconfig | 2 ++ configs/T1024RDB_SDCARD_defconfig | 2 ++ configs/T1024RDB_SECURE_BOOT_defconfig | 2 ++ configs/T1024RDB_SPIFLASH_defconfig | 2 ++ configs/T1024RDB_defconfig | 2 ++ configs/T1040D4RDB_NAND_defconfig | 2 ++ configs/T1040D4RDB_SDCARD_defconfig | 2 ++ configs/T1040D4RDB_SECURE_BOOT_defconfig | 2 ++ configs/T1040D4RDB_SPIFLASH_defconfig | 2 ++ configs/T1040D4RDB_defconfig | 2 ++ configs/T1040QDS_DDR4_defconfig | 2 ++ configs/T1040QDS_SECURE_BOOT_defconfig | 2 ++ configs/T1040QDS_defconfig | 2 ++ configs/T1040RDB_NAND_defconfig | 2 ++ configs/T1040RDB_SDCARD_defconfig | 2 ++ configs/T1040RDB_SECURE_BOOT_defconfig | 2 ++ configs/T1040RDB_SPIFLASH_defconfig | 2 ++ configs/T1040RDB_defconfig | 2 ++ configs/T1042D4RDB_NAND_defconfig | 2 ++ configs/T1042D4RDB_SDCARD_defconfig | 2 ++ configs/T1042D4RDB_SECURE_BOOT_defconfig | 2 ++ configs/T1042D4RDB_SPIFLASH_defconfig | 2 ++ configs/T1042D4RDB_defconfig | 2 ++ configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig | 2 ++ configs/T1042RDB_PI_NAND_defconfig | 2 ++ configs/T1042RDB_PI_SDCARD_defconfig | 2 ++ configs/T1042RDB_PI_SPIFLASH_defconfig | 2 ++ configs/T1042RDB_PI_defconfig | 2 ++ configs/T1042RDB_SECURE_BOOT_defconfig | 2 ++ configs/T1042RDB_defconfig | 2 ++ configs/T2080QDS_NAND_defconfig | 2 ++ configs/T2080QDS_SDCARD_defconfig | 2 ++ configs/T2080QDS_SECURE_BOOT_defconfig | 2 ++ configs/T2080QDS_SPIFLASH_defconfig | 2 ++ configs/T2080QDS_SRIO_PCIE_BOOT_defconfig | 2 ++ configs/T2080QDS_defconfig | 2 ++ configs/T2080RDB_NAND_defconfig | 2 ++ configs/T2080RDB_SDCARD_defconfig | 2 ++ configs/T2080RDB_SECURE_BOOT_defconfig | 2 ++ configs/T2080RDB_SPIFLASH_defconfig | 2 ++ configs/T2080RDB_SRIO_PCIE_BOOT_defconfig | 2 ++ configs/T2080RDB_defconfig | 2 ++ configs/T2081QDS_NAND_defconfig | 2 ++ configs/T2081QDS_SDCARD_defconfig | 2 ++ configs/T2081QDS_SPIFLASH_defconfig | 2 ++ configs/T2081QDS_SRIO_PCIE_BOOT_defconfig | 2 ++ configs/T2081QDS_defconfig | 2 ++ configs/T4160QDS_NAND_defconfig | 2 ++ configs/T4160QDS_SDCARD_defconfig | 2 ++ configs/T4160QDS_SECURE_BOOT_defconfig | 2 ++ configs/T4160QDS_defconfig | 2 ++ configs/T4160RDB_defconfig | 2 ++ configs/T4240QDS_NAND_defconfig | 2 ++ configs/T4240QDS_SDCARD_defconfig | 2 ++ configs/T4240QDS_SECURE_BOOT_defconfig | 2 ++ configs/T4240QDS_SRIO_PCIE_BOOT_defconfig | 2 ++ configs/T4240QDS_defconfig | 2 ++ configs/T4240RDB_SDCARD_defconfig | 2 ++ configs/T4240RDB_defconfig | 2 ++ configs/UCP1020_SPIFLASH_defconfig | 2 ++ configs/UCP1020_defconfig | 2 ++ configs/ae350_rv32_defconfig | 1 + configs/ae350_rv64_defconfig | 1 + configs/am335x_boneblack_vboot_defconfig | 1 + configs/am335x_evm_defconfig | 1 + configs/am335x_hs_evm_defconfig | 1 + configs/am335x_hs_evm_uart_defconfig | 1 + configs/am43xx_evm_defconfig | 1 + configs/am43xx_evm_qspiboot_defconfig | 1 + configs/am43xx_evm_rtconly_defconfig | 1 + configs/am43xx_evm_usbhost_boot_defconfig | 1 + configs/am43xx_hs_evm_defconfig | 1 + configs/am57xx_evm_defconfig | 2 ++ configs/am57xx_hs_evm_defconfig | 2 ++ configs/am57xx_hs_evm_usb_defconfig | 2 ++ configs/aristainetos2_defconfig | 4 +++ configs/aristainetos2b_defconfig | 2 ++ configs/aristainetos_defconfig | 3 ++ configs/at91sam9n12ek_mmc_defconfig | 1 + configs/at91sam9n12ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_spiflash_defconfig | 1 + configs/at91sam9x5ek_dataflash_defconfig | 1 + configs/at91sam9x5ek_mmc_defconfig | 1 + configs/at91sam9x5ek_nandflash_defconfig | 1 + configs/at91sam9x5ek_spiflash_defconfig | 1 + configs/beaver_defconfig | 2 ++ configs/bg0900_defconfig | 3 ++ configs/birdland_bav335a_defconfig | 1 + configs/birdland_bav335b_defconfig | 1 + configs/brppt1_spi_defconfig | 1 + configs/cardhu_defconfig | 2 ++ configs/cei-tk1-som_defconfig | 2 ++ configs/cgtqmx6eval_defconfig | 2 ++ configs/chromebit_mickey_defconfig | 1 + configs/chromebook_bob_defconfig | 1 + configs/chromebook_jerry_defconfig | 1 + configs/chromebook_minnie_defconfig | 1 + configs/chromebook_speedy_defconfig | 1 + configs/cl-som-am57x_defconfig | 1 + configs/cl-som-imx7_defconfig | 2 ++ configs/clearfog_defconfig | 1 + configs/clearfog_gt_8k_defconfig | 1 + configs/cm_fx6_defconfig | 2 ++ configs/cm_t43_defconfig | 1 + .../controlcenterd_36BIT_SDCARD_DEVELOP_defconfig | 2 ++ configs/controlcenterd_36BIT_SDCARD_defconfig | 2 ++ configs/controlcenterdc_defconfig | 1 + configs/dalmore_defconfig | 2 ++ configs/db-88f6820-amc_defconfig | 1 + configs/dh_imx6_defconfig | 2 ++ configs/display5_defconfig | 3 ++ configs/display5_factory_defconfig | 3 ++ configs/dms-ba16-1g_defconfig | 2 ++ configs/dms-ba16_defconfig | 2 ++ configs/dra7xx_evm_defconfig | 2 ++ configs/dra7xx_hs_evm_defconfig | 2 ++ configs/dra7xx_hs_evm_usb_defconfig | 2 ++ configs/e2220-1170_defconfig | 2 ++ configs/ea20_defconfig | 1 + configs/evb-rk3036_defconfig | 1 + configs/evb-rk3128_defconfig | 1 + configs/evb-rk3288_defconfig | 1 + configs/evb-rk3328_defconfig | 1 + configs/evb-rk3399_defconfig | 1 + configs/fennec-rk3288_defconfig | 1 + configs/ficus-rk3399_defconfig | 1 + configs/firefly-rk3288_defconfig | 1 + configs/firefly-rk3399_defconfig | 1 + configs/ge_bx50v3_defconfig | 2 ++ configs/helios4_defconfig | 2 ++ configs/jetson-tk1_defconfig | 2 ++ configs/k2e_evm_defconfig | 1 + configs/k2e_hs_evm_defconfig | 1 + configs/k2g_evm_defconfig | 2 ++ configs/k2g_hs_evm_defconfig | 2 ++ configs/k2hk_evm_defconfig | 1 + configs/k2hk_hs_evm_defconfig | 1 + configs/k2l_evm_defconfig | 1 + configs/k2l_hs_evm_defconfig | 1 + configs/km_kirkwood_128m16_defconfig | 1 + configs/km_kirkwood_defconfig | 1 + configs/km_kirkwood_pci_defconfig | 1 + configs/kmcoge4_defconfig | 2 ++ configs/kmcoge5un_defconfig | 1 + configs/kmlion1_defconfig | 2 ++ configs/kmnusa_defconfig | 1 + configs/kmsugp1_defconfig | 1 + configs/kmsuv31_defconfig | 1 + configs/kylin-rk3036_defconfig | 1 + configs/legoev3_defconfig | 1 + configs/ls1012aqds_qspi_defconfig | 3 ++ configs/ls1012aqds_tfa_SECURE_BOOT_defconfig | 3 ++ configs/ls1012aqds_tfa_defconfig | 3 ++ configs/ls1043aqds_defconfig | 1 + configs/ls1043aqds_lpuart_defconfig | 1 + configs/ls1043aqds_nand_defconfig | 1 + configs/ls1043aqds_nor_ddr3_defconfig | 1 + configs/ls1043aqds_sdcard_ifc_defconfig | 1 + configs/ls1043aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1043aqds_tfa_defconfig | 1 + configs/ls1043ardb_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_defconfig | 1 + configs/ls1043ardb_nand_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_nand_defconfig | 1 + configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_sdcard_defconfig | 1 + configs/ls1043ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_tfa_defconfig | 1 + configs/ls1046aqds_SECURE_BOOT_defconfig | 1 + configs/ls1046aqds_defconfig | 1 + configs/ls1046aqds_lpuart_defconfig | 1 + configs/ls1046aqds_nand_defconfig | 1 + configs/ls1046aqds_sdcard_ifc_defconfig | 1 + configs/ls1046aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1046aqds_tfa_defconfig | 1 + configs/lschlv2_defconfig | 1 + configs/lsxhl_defconfig | 1 + configs/marsboard_defconfig | 2 ++ configs/mccmon6_nor_defconfig | 3 ++ configs/mccmon6_sd_defconfig | 3 ++ configs/mgcoge3un_defconfig | 1 + configs/miqi-rk3288_defconfig | 1 + configs/mvebu_db-88f3720_defconfig | 1 + configs/mvebu_db_armada8k_defconfig | 1 + configs/mvebu_espressobin-88f3720_defconfig | 1 + configs/mvebu_mcbin-88f8040_defconfig | 1 + configs/mx28evk_auart_console_defconfig | 3 ++ configs/mx28evk_defconfig | 3 ++ configs/mx28evk_nand_defconfig | 3 ++ configs/mx28evk_spi_defconfig | 3 ++ configs/mx6qsabrelite_defconfig | 2 ++ configs/mx6sabreauto_defconfig | 2 ++ configs/mx6sabresd_defconfig | 2 ++ configs/mx6slevk_defconfig | 2 ++ configs/mx6slevk_spinor_defconfig | 2 ++ configs/mx6slevk_spl_defconfig | 2 ++ configs/mx6sxsabreauto_defconfig | 2 ++ configs/mx6sxsabresd_defconfig | 3 ++ configs/mx6ul_14x14_evk_defconfig | 2 ++ configs/mx6ul_9x9_evk_defconfig | 2 ++ configs/mx6ull_14x14_evk_defconfig | 2 ++ configs/mx6ull_14x14_evk_plugin_defconfig | 2 ++ configs/mx7dsabresd_qspi_defconfig | 2 ++ configs/nitrogen6dl2g_defconfig | 2 ++ configs/nitrogen6dl_defconfig | 2 ++ configs/nitrogen6q2g_defconfig | 2 ++ configs/nitrogen6q_defconfig | 2 ++ configs/nitrogen6s1g_defconfig | 2 ++ configs/nitrogen6s_defconfig | 2 ++ configs/nyan-big_defconfig | 2 ++ configs/omapl138_lcdk_defconfig | 1 + configs/ot1200_defconfig | 3 ++ configs/ot1200_spl_defconfig | 3 ++ configs/p2371-0000_defconfig | 2 ++ configs/p2371-2180_defconfig | 2 ++ configs/p2571_defconfig | 2 ++ configs/pcm051_rev1_defconfig | 1 + configs/pcm051_rev3_defconfig | 1 + configs/pcm058_defconfig | 2 ++ configs/peach-pi_defconfig | 2 ++ configs/peach-pit_defconfig | 2 ++ configs/pfla02_defconfig | 3 ++ configs/phycore-rk3288_defconfig | 1 + configs/popmetal-rk3288_defconfig | 1 + configs/portl2_defconfig | 1 + configs/puma-rk3399_defconfig | 1 + configs/riotboard_defconfig | 2 ++ configs/riotboard_spl_defconfig | 2 ++ configs/rock2_defconfig | 1 + configs/rock960-rk3399_defconfig | 1 + configs/rock_defconfig | 1 + configs/sama5d27_som1_ek_mmc1_defconfig | 1 + configs/sama5d27_som1_ek_mmc_defconfig | 1 + configs/sama5d2_xplained_emmc_defconfig | 1 + configs/sama5d2_xplained_mmc_defconfig | 1 + configs/sama5d2_xplained_spiflash_defconfig | 1 + configs/sama5d36ek_cmp_mmc_defconfig | 1 + configs/sama5d36ek_cmp_nandflash_defconfig | 1 + configs/sama5d36ek_cmp_spiflash_defconfig | 1 + configs/sama5d3xek_mmc_defconfig | 1 + configs/sama5d3xek_nandflash_defconfig | 1 + configs/sama5d3xek_spiflash_defconfig | 1 + configs/sama5d4_xplained_mmc_defconfig | 1 + configs/sama5d4_xplained_nandflash_defconfig | 1 + configs/sama5d4_xplained_spiflash_defconfig | 1 + configs/sama5d4ek_mmc_defconfig | 1 + configs/sama5d4ek_nandflash_defconfig | 1 + configs/sama5d4ek_spiflash_defconfig | 1 + configs/smdk5250_defconfig | 2 ++ configs/smdk5420_defconfig | 2 ++ configs/snow_defconfig | 2 ++ configs/socfpga_sr1500_defconfig | 1 + configs/socfpga_stratix10_defconfig | 1 + configs/spring_defconfig | 2 ++ configs/stmark2_defconfig | 1 + configs/tec-ng_defconfig | 2 ++ configs/theadorable_debug_defconfig | 1 + configs/tinker-rk3288_defconfig | 1 + configs/topic_miami_defconfig | 3 +- configs/topic_miamilite_defconfig | 3 +- configs/topic_miamiplus_defconfig | 2 ++ configs/tqma6dl_mba6_mmc_defconfig | 2 ++ configs/tqma6dl_mba6_spi_defconfig | 2 ++ configs/tqma6q_mba6_mmc_defconfig | 2 ++ configs/tqma6q_mba6_spi_defconfig | 2 ++ configs/tqma6s_mba6_mmc_defconfig | 2 ++ configs/tqma6s_mba6_spi_defconfig | 2 ++ configs/trimslice_defconfig | 1 + configs/turris_mox_defconfig | 2 ++ configs/uDPU_defconfig | 1 + configs/venice2_defconfig | 2 ++ configs/vinco_defconfig | 2 ++ configs/vyasa-rk3288_defconfig | 1 + configs/x530_defconfig | 2 ++ configs/zc5202_defconfig | 3 ++ configs/zc5601_defconfig | 3 ++ configs/zynq_cc108_defconfig | 1 + configs/zynq_cse_qspi_defconfig | 1 + configs/zynq_dlc20_rev1_0_defconfig | 1 + configs/zynq_microzed_defconfig | 1 + configs/zynq_minized_defconfig | 1 + configs/zynq_z_turn_defconfig | 1 + configs/zynq_zc702_defconfig | 1 + configs/zynq_zc706_defconfig | 1 + configs/zynq_zc770_xm010_defconfig | 1 + configs/zynq_zc770_xm013_defconfig | 1 + configs/zynq_zed_defconfig | 1 + configs/zynq_zybo_defconfig | 1 + configs/zynq_zybo_z7_defconfig | 1 + drivers/mtd/spi/Kconfig | 36 ++++++++++++++++++++++ include/configs/B4860QDS.h | 2 -- include/configs/BSC9131RDB.h | 4 --- include/configs/BSC9132QDS.h | 4 --- include/configs/C29XPCIE.h | 2 -- include/configs/MPC8536DS.h | 5 --- include/configs/P1010RDB.h | 2 -- include/configs/P1022DS.h | 3 -- include/configs/P2041RDB.h | 2 -- include/configs/T102xQDS.h | 2 -- include/configs/T102xRDB.h | 2 -- include/configs/T1040QDS.h | 2 -- include/configs/T104xRDB.h | 2 -- include/configs/T208xQDS.h | 5 --- include/configs/T208xRDB.h | 4 --- include/configs/T4240QDS.h | 2 -- include/configs/T4240RDB.h | 2 -- include/configs/UCP1020.h | 3 -- include/configs/adp-ae3xx.h | 4 --- include/configs/advantech_dms-ba16.h | 6 ---- include/configs/am335x_evm.h | 1 - include/configs/am43xx_evm.h | 2 -- include/configs/am57xx_evm.h | 2 -- include/configs/aristainetos-common.h | 2 -- include/configs/aristainetos.h | 3 -- include/configs/aristainetos2.h | 3 -- include/configs/aristainetos2b.h | 3 -- include/configs/at91sam9n12ek.h | 3 -- include/configs/at91sam9x5ek.h | 3 -- include/configs/ax25-ae350.h | 4 --- include/configs/bav335x.h | 1 - include/configs/beaver.h | 2 -- include/configs/bg0900.h | 5 --- include/configs/brppt1.h | 1 - include/configs/cardhu.h | 2 -- include/configs/cei-tk1-som.h | 2 -- include/configs/cgtqmx6eval.h | 3 -- include/configs/cl-som-am57x.h | 1 - include/configs/cl-som-imx7.h | 4 --- include/configs/clearfog.h | 1 - include/configs/cm_fx6.h | 4 --- include/configs/cm_t43.h | 2 -- include/configs/controlcenterd.h | 6 ---- include/configs/controlcenterdc.h | 5 --- include/configs/corenet_ds.h | 2 -- include/configs/da850evm.h | 1 - include/configs/dalmore.h | 2 -- include/configs/db-88f6720.h | 2 -- include/configs/db-88f6820-amc.h | 3 -- include/configs/db-88f6820-gp.h | 2 -- include/configs/db-mv784mp-gp.h | 2 -- include/configs/dh_imx6.h | 6 ---- include/configs/display5.h | 6 ---- include/configs/dra7xx_evm.h | 2 -- include/configs/ds414.h | 2 -- include/configs/e2220-1170.h | 2 -- include/configs/ea20.h | 1 - include/configs/el6x_common.h | 4 --- include/configs/embestmx6boards.h | 7 ----- include/configs/exynos5-common.h | 4 --- include/configs/ge_bx50v3.h | 6 ---- include/configs/gw_ventana.h | 4 --- include/configs/helios4.h | 4 --- include/configs/jetson-tk1.h | 2 -- include/configs/k2g_evm.h | 3 -- include/configs/km/km_arm.h | 2 -- include/configs/km/kmp204x-common.h | 2 -- include/configs/legoev3.h | 1 - include/configs/ls1012aqds.h | 5 --- include/configs/ls1043a_common.h | 4 --- include/configs/ls1046aqds.h | 4 --- include/configs/ls1088aqds.h | 2 -- include/configs/lsxl.h | 2 -- include/configs/maxbcm.h | 2 -- include/configs/mccmon6.h | 5 --- include/configs/microblaze-generic.h | 4 --- include/configs/mvebu_armada-37xx.h | 2 -- include/configs/mvebu_armada-8k.h | 2 -- include/configs/mx28evk.h | 10 ------ include/configs/mx6sabre_common.h | 7 ----- include/configs/mx6slevk.h | 7 ----- include/configs/mx6sxsabreauto.h | 4 --- include/configs/mx6sxsabresd.h | 4 --- include/configs/mx6ul_14x14_evk.h | 4 --- include/configs/mx6ullevk.h | 4 --- include/configs/mx7dsabresd.h | 4 --- include/configs/nitrogen6x.h | 7 ----- include/configs/nyan-big.h | 2 -- include/configs/omapl138_lcdk.h | 1 - include/configs/ot1200.h | 4 --- include/configs/p1_p2_rdb_pc.h | 5 --- include/configs/p2371-0000.h | 2 -- include/configs/p2371-2180.h | 2 -- include/configs/p2571.h | 2 -- include/configs/pcm051.h | 2 -- include/configs/pcm058.h | 4 --- include/configs/pfla02.h | 4 --- include/configs/rk3036_common.h | 1 - include/configs/rk3128_common.h | 1 - include/configs/rk3188_common.h | 2 -- include/configs/rk3288_common.h | 2 -- include/configs/rk3328_common.h | 2 -- include/configs/rk3399_common.h | 2 -- include/configs/sama5d27_som1_ek.h | 1 - include/configs/sama5d2_xplained.h | 5 --- include/configs/sama5d3xek.h | 4 --- include/configs/sama5d4_xplained.h | 4 --- include/configs/sama5d4ek.h | 4 --- include/configs/siemens-am33x-common.h | 2 -- include/configs/socfpga_common.h | 1 - include/configs/socfpga_sr1500.h | 1 - include/configs/socfpga_stratix10_socdk.h | 4 --- include/configs/stmark2.h | 1 - include/configs/taurus.h | 4 --- include/configs/tec-ng.h | 2 -- include/configs/theadorable.h | 2 -- include/configs/ti_armv7_keystone2.h | 1 - include/configs/topic_miami.h | 3 -- include/configs/tqma6.h | 5 --- include/configs/trimslice.h | 1 - include/configs/turris_mox.h | 2 -- include/configs/turris_omnia.h | 2 -- include/configs/venice2.h | 2 -- include/configs/vinco.h | 4 --- include/configs/x530.h | 3 -- include/configs/zynq-common.h | 3 -- include/spi_flash.h | 13 -------- scripts/config_whitelist.txt | 4 --- 573 files changed, 808 insertions(+), 424 deletions(-)
diff --git a/README b/README index 1287341..319bf9f 100644 --- a/README +++ b/README @@ -2146,21 +2146,6 @@ The following options need to be configured: this is instead controlled by the value of /config/load-environment.
-- Serial Flash support - Usage requires an initial 'sf probe' to define the serial - flash parameters, followed by read/write/erase/update - commands. - - The following defaults may be provided by the platform - to handle the common case when only a single serial - flash is present on the system. - - CONFIG_SF_DEFAULT_BUS Bus identifier - CONFIG_SF_DEFAULT_CS Chip-select - CONFIG_SF_DEFAULT_MODE (see include/spi.h) - CONFIG_SF_DEFAULT_SPEED in Hz - - - TFTP Fixed UDP Port: CONFIG_TFTP_PORT
diff --git a/board/Arcturus/ucp1020/cmd_arc.c b/board/Arcturus/ucp1020/cmd_arc.c index 1c42fee..9579d52 100644 --- a/board/Arcturus/ucp1020/cmd_arc.c +++ b/board/Arcturus/ucp1020/cmd_arc.c @@ -15,19 +15,6 @@
#include <asm/io.h>
-#ifndef CONFIG_SF_DEFAULT_SPEED -# define CONFIG_SF_DEFAULT_SPEED 1000000 -#endif -#ifndef CONFIG_SF_DEFAULT_MODE -# define CONFIG_SF_DEFAULT_MODE SPI_MODE0 -#endif -#ifndef CONFIG_SF_DEFAULT_CS -# define CONFIG_SF_DEFAULT_CS 0 -#endif -#ifndef CONFIG_SF_DEFAULT_BUS -# define CONFIG_SF_DEFAULT_BUS 0 -#endif - #define MAX_SERIAL_SIZE 15 #define MAX_HWADDR_SIZE 17
diff --git a/configs/B4420QDS_NAND_defconfig b/configs/B4420QDS_NAND_defconfig index fd74888..d48bc77 100644 --- a/configs/B4420QDS_NAND_defconfig +++ b/configs/B4420QDS_NAND_defconfig @@ -41,6 +41,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/B4420QDS_SPIFLASH_defconfig b/configs/B4420QDS_SPIFLASH_defconfig index 8e3b0a7..e576a87 100644 --- a/configs/B4420QDS_SPIFLASH_defconfig +++ b/configs/B4420QDS_SPIFLASH_defconfig @@ -30,6 +30,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/B4420QDS_defconfig b/configs/B4420QDS_defconfig index 29b351a..896df53 100644 --- a/configs/B4420QDS_defconfig +++ b/configs/B4420QDS_defconfig @@ -29,6 +29,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/B4860QDS_NAND_defconfig b/configs/B4860QDS_NAND_defconfig index bfd1bcf..5b15b9c 100644 --- a/configs/B4860QDS_NAND_defconfig +++ b/configs/B4860QDS_NAND_defconfig @@ -41,6 +41,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/B4860QDS_SECURE_BOOT_defconfig b/configs/B4860QDS_SECURE_BOOT_defconfig index 26ad411..e376a19 100644 --- a/configs/B4860QDS_SECURE_BOOT_defconfig +++ b/configs/B4860QDS_SECURE_BOOT_defconfig @@ -30,6 +30,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/B4860QDS_SPIFLASH_defconfig b/configs/B4860QDS_SPIFLASH_defconfig index 612cb7e..90e19bd 100644 --- a/configs/B4860QDS_SPIFLASH_defconfig +++ b/configs/B4860QDS_SPIFLASH_defconfig @@ -30,6 +30,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig b/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig index 9bfed3c..c35c752 100644 --- a/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig @@ -26,6 +26,8 @@ CONFIG_ENV_IS_IN_REMOTE=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/B4860QDS_defconfig b/configs/B4860QDS_defconfig index 3232530..03b925f 100644 --- a/configs/B4860QDS_defconfig +++ b/configs/B4860QDS_defconfig @@ -29,6 +29,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/BSC9131RDB_NAND_SYSCLK100_defconfig b/configs/BSC9131RDB_NAND_SYSCLK100_defconfig index 3f271cc..55906fa 100644 --- a/configs/BSC9131RDB_NAND_SYSCLK100_defconfig +++ b/configs/BSC9131RDB_NAND_SYSCLK100_defconfig @@ -32,6 +32,8 @@ CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_MII=y diff --git a/configs/BSC9131RDB_NAND_defconfig b/configs/BSC9131RDB_NAND_defconfig index 51dc152..e26ad53 100644 --- a/configs/BSC9131RDB_NAND_defconfig +++ b/configs/BSC9131RDB_NAND_defconfig @@ -31,6 +31,8 @@ CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_MII=y diff --git a/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig b/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig index 2d3c3d6..2324158 100644 --- a/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig +++ b/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig @@ -27,6 +27,8 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_MII=y diff --git a/configs/BSC9131RDB_SPIFLASH_defconfig b/configs/BSC9131RDB_SPIFLASH_defconfig index 5a9f10d..0e5a2da 100644 --- a/configs/BSC9131RDB_SPIFLASH_defconfig +++ b/configs/BSC9131RDB_SPIFLASH_defconfig @@ -27,6 +27,8 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_MII=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig index 1e26861..af1bc88 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig @@ -35,6 +35,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK100_defconfig b/configs/BSC9132QDS_NAND_DDRCLK100_defconfig index 0db36b0..a0c697a 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK100_defconfig @@ -39,6 +39,8 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig index 005087e..abc0886 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig @@ -35,6 +35,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK133_defconfig b/configs/BSC9132QDS_NAND_DDRCLK133_defconfig index a37a8a2..d688029 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK133_defconfig @@ -39,6 +39,8 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig index d88b6d4..81c3b3b 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig @@ -35,6 +35,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK100_defconfig b/configs/BSC9132QDS_NOR_DDRCLK100_defconfig index 09751ed..a16838c 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK100_defconfig @@ -34,6 +34,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig index 94d099b..dca1260 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig @@ -35,6 +35,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK133_defconfig b/configs/BSC9132QDS_NOR_DDRCLK133_defconfig index 7b4ecee..e56be3f 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK133_defconfig @@ -34,6 +34,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig index 4a53c72..1e5c762 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig @@ -35,6 +35,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig index ea2e040..f55cb61 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig @@ -34,6 +34,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig index fc41568..1203bdb 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig @@ -35,6 +35,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig index 622f5ca..407c2e6 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig @@ -34,6 +34,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig index 5eca1f1..a0e9cd8 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig @@ -35,6 +35,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig index b6f2e69..309159e 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig @@ -34,6 +34,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig index fc89a74..f086438 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig @@ -35,6 +35,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig index 18f40bb..1af0223 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig @@ -34,6 +34,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/C29XPCIE_NAND_defconfig b/configs/C29XPCIE_NAND_defconfig index aef42ac..94f04d7 100644 --- a/configs/C29XPCIE_NAND_defconfig +++ b/configs/C29XPCIE_NAND_defconfig @@ -40,6 +40,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y diff --git a/configs/C29XPCIE_NOR_SECBOOT_defconfig b/configs/C29XPCIE_NOR_SECBOOT_defconfig index efc8dd9..a256315 100644 --- a/configs/C29XPCIE_NOR_SECBOOT_defconfig +++ b/configs/C29XPCIE_NOR_SECBOOT_defconfig @@ -27,6 +27,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y diff --git a/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig b/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig index dcf793b..8629f8a 100644 --- a/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig +++ b/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig @@ -28,6 +28,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y diff --git a/configs/C29XPCIE_SPIFLASH_defconfig b/configs/C29XPCIE_SPIFLASH_defconfig index aaecadb..031ab2c 100644 --- a/configs/C29XPCIE_SPIFLASH_defconfig +++ b/configs/C29XPCIE_SPIFLASH_defconfig @@ -27,6 +27,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y diff --git a/configs/C29XPCIE_defconfig b/configs/C29XPCIE_defconfig index a487dca..ac525e8 100644 --- a/configs/C29XPCIE_defconfig +++ b/configs/C29XPCIE_defconfig @@ -26,6 +26,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y diff --git a/configs/MPC8536DS_36BIT_defconfig b/configs/MPC8536DS_36BIT_defconfig index 654a517..428586a 100644 --- a/configs/MPC8536DS_36BIT_defconfig +++ b/configs/MPC8536DS_36BIT_defconfig @@ -31,6 +31,8 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/MPC8536DS_SDCARD_defconfig b/configs/MPC8536DS_SDCARD_defconfig index eebc003..1a02f26 100644 --- a/configs/MPC8536DS_SDCARD_defconfig +++ b/configs/MPC8536DS_SDCARD_defconfig @@ -30,6 +30,8 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/MPC8536DS_SPIFLASH_defconfig b/configs/MPC8536DS_SPIFLASH_defconfig index c376abe..155f227 100644 --- a/configs/MPC8536DS_SPIFLASH_defconfig +++ b/configs/MPC8536DS_SPIFLASH_defconfig @@ -30,6 +30,8 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/MPC8536DS_defconfig b/configs/MPC8536DS_defconfig index 7501488..01863a4 100644 --- a/configs/MPC8536DS_defconfig +++ b/configs/MPC8536DS_defconfig @@ -30,6 +30,8 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig b/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig index 568d886..51b6488 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig @@ -34,6 +34,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1010RDB-PA_36BIT_NAND_defconfig b/configs/P1010RDB-PA_36BIT_NAND_defconfig index 2399330..9e938b2 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_defconfig @@ -47,6 +47,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig b/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig index e565b41..b14e7de 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig @@ -33,6 +33,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1010RDB-PA_36BIT_NOR_defconfig b/configs/P1010RDB-PA_36BIT_NOR_defconfig index 1723d8d..10a2eff 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_defconfig @@ -32,6 +32,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig index 798a0dc..2e38575 100644 --- a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig @@ -43,6 +43,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig index d8482a3..b24f704 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig @@ -34,6 +34,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig index 3b4992f..9bdbac0 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig @@ -44,6 +44,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1010RDB-PA_NAND_SECBOOT_defconfig b/configs/P1010RDB-PA_NAND_SECBOOT_defconfig index b2f000a..036f8e8 100644 --- a/configs/P1010RDB-PA_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_NAND_SECBOOT_defconfig @@ -33,6 +33,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1010RDB-PA_NAND_defconfig b/configs/P1010RDB-PA_NAND_defconfig index 0dd4d4a..aea4529 100644 --- a/configs/P1010RDB-PA_NAND_defconfig +++ b/configs/P1010RDB-PA_NAND_defconfig @@ -46,6 +46,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1010RDB-PA_NOR_SECBOOT_defconfig b/configs/P1010RDB-PA_NOR_SECBOOT_defconfig index 806bf88..349fc95 100644 --- a/configs/P1010RDB-PA_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_NOR_SECBOOT_defconfig @@ -32,6 +32,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1010RDB-PA_NOR_defconfig b/configs/P1010RDB-PA_NOR_defconfig index f1429ab..47c5cca 100644 --- a/configs/P1010RDB-PA_NOR_defconfig +++ b/configs/P1010RDB-PA_NOR_defconfig @@ -31,6 +31,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1010RDB-PA_SDCARD_defconfig b/configs/P1010RDB-PA_SDCARD_defconfig index eb3151c..1455291 100644 --- a/configs/P1010RDB-PA_SDCARD_defconfig +++ b/configs/P1010RDB-PA_SDCARD_defconfig @@ -42,6 +42,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig index 9c759db..0fa105c 100644 --- a/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig @@ -33,6 +33,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1010RDB-PA_SPIFLASH_defconfig b/configs/P1010RDB-PA_SPIFLASH_defconfig index 5513446..bb38e71 100644 --- a/configs/P1010RDB-PA_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_defconfig @@ -43,6 +43,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig b/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig index aee9edf..dcc7d11 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig @@ -34,6 +34,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index 0f7e989..ce80bad 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -47,6 +47,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig b/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig index f41e050..6ed4467 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig @@ -33,6 +33,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1010RDB-PB_36BIT_NOR_defconfig b/configs/P1010RDB-PB_36BIT_NOR_defconfig index a7e7ecf..9ea5d83 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_defconfig @@ -32,6 +32,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig index aca0441..69a933c 100644 --- a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig @@ -43,6 +43,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig index 9a0332d..6f43d69 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig @@ -34,6 +34,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig index 7041356..4ec77b8 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig @@ -44,6 +44,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1010RDB-PB_NAND_SECBOOT_defconfig b/configs/P1010RDB-PB_NAND_SECBOOT_defconfig index 39b62bb..8e76629 100644 --- a/configs/P1010RDB-PB_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_NAND_SECBOOT_defconfig @@ -33,6 +33,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index cdf51c8..1873c131 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -46,6 +46,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1010RDB-PB_NOR_SECBOOT_defconfig b/configs/P1010RDB-PB_NOR_SECBOOT_defconfig index 45c7d3c..cc2a04f 100644 --- a/configs/P1010RDB-PB_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_NOR_SECBOOT_defconfig @@ -32,6 +32,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1010RDB-PB_NOR_defconfig b/configs/P1010RDB-PB_NOR_defconfig index f1753a3..4178800 100644 --- a/configs/P1010RDB-PB_NOR_defconfig +++ b/configs/P1010RDB-PB_NOR_defconfig @@ -31,6 +31,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1010RDB-PB_SDCARD_defconfig b/configs/P1010RDB-PB_SDCARD_defconfig index 56200bb..be6ca00 100644 --- a/configs/P1010RDB-PB_SDCARD_defconfig +++ b/configs/P1010RDB-PB_SDCARD_defconfig @@ -42,6 +42,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig index 60e2e1b..78aef83 100644 --- a/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig @@ -33,6 +33,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1010RDB-PB_SPIFLASH_defconfig b/configs/P1010RDB-PB_SPIFLASH_defconfig index f44d36c..6efe1aa 100644 --- a/configs/P1010RDB-PB_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_defconfig @@ -43,6 +43,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1020RDB-PC_36BIT_NAND_defconfig b/configs/P1020RDB-PC_36BIT_NAND_defconfig index 09fc7d9..13a47f8 100644 --- a/configs/P1020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1020RDB-PC_36BIT_NAND_defconfig @@ -46,6 +46,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig index 778a258..96c9f3c 100644 --- a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig @@ -43,6 +43,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig index 3157256..a28913e 100644 --- a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig @@ -44,6 +44,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1020RDB-PC_36BIT_defconfig b/configs/P1020RDB-PC_36BIT_defconfig index 3dbefd3..8ada9bb 100644 --- a/configs/P1020RDB-PC_36BIT_defconfig +++ b/configs/P1020RDB-PC_36BIT_defconfig @@ -33,6 +33,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1020RDB-PC_NAND_defconfig b/configs/P1020RDB-PC_NAND_defconfig index 2cc48c6..6b5c7a5 100644 --- a/configs/P1020RDB-PC_NAND_defconfig +++ b/configs/P1020RDB-PC_NAND_defconfig @@ -45,6 +45,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1020RDB-PC_SDCARD_defconfig b/configs/P1020RDB-PC_SDCARD_defconfig index 983fbc7..6ab5929 100644 --- a/configs/P1020RDB-PC_SDCARD_defconfig +++ b/configs/P1020RDB-PC_SDCARD_defconfig @@ -42,6 +42,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1020RDB-PC_SPIFLASH_defconfig b/configs/P1020RDB-PC_SPIFLASH_defconfig index 0f49a81..afc789b 100644 --- a/configs/P1020RDB-PC_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_SPIFLASH_defconfig @@ -43,6 +43,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1020RDB-PC_defconfig b/configs/P1020RDB-PC_defconfig index 2dadfa9..dec97c4 100644 --- a/configs/P1020RDB-PC_defconfig +++ b/configs/P1020RDB-PC_defconfig @@ -32,6 +32,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1020RDB-PD_NAND_defconfig b/configs/P1020RDB-PD_NAND_defconfig index 58f2571..324881d 100644 --- a/configs/P1020RDB-PD_NAND_defconfig +++ b/configs/P1020RDB-PD_NAND_defconfig @@ -49,6 +49,8 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1020RDB-PD_SDCARD_defconfig b/configs/P1020RDB-PD_SDCARD_defconfig index c6cb7a5..4c72120 100644 --- a/configs/P1020RDB-PD_SDCARD_defconfig +++ b/configs/P1020RDB-PD_SDCARD_defconfig @@ -46,6 +46,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1020RDB-PD_SPIFLASH_defconfig b/configs/P1020RDB-PD_SPIFLASH_defconfig index 848ca27..243456c 100644 --- a/configs/P1020RDB-PD_SPIFLASH_defconfig +++ b/configs/P1020RDB-PD_SPIFLASH_defconfig @@ -47,6 +47,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1020RDB-PD_defconfig b/configs/P1020RDB-PD_defconfig index 5377df3..0f25faf 100644 --- a/configs/P1020RDB-PD_defconfig +++ b/configs/P1020RDB-PD_defconfig @@ -36,6 +36,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1021RDB-PC_36BIT_NAND_defconfig b/configs/P1021RDB-PC_36BIT_NAND_defconfig index d03cfc0..c0524e7 100644 --- a/configs/P1021RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1021RDB-PC_36BIT_NAND_defconfig @@ -51,6 +51,8 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1021RDB-PC_36BIT_SDCARD_defconfig b/configs/P1021RDB-PC_36BIT_SDCARD_defconfig index a086c52..a5bcf76 100644 --- a/configs/P1021RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1021RDB-PC_36BIT_SDCARD_defconfig @@ -48,6 +48,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig index 2ff094c..c4160b4 100644 --- a/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig @@ -49,6 +49,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1021RDB-PC_36BIT_defconfig b/configs/P1021RDB-PC_36BIT_defconfig index 72c79d7..ae7752b 100644 --- a/configs/P1021RDB-PC_36BIT_defconfig +++ b/configs/P1021RDB-PC_36BIT_defconfig @@ -38,6 +38,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1021RDB-PC_NAND_defconfig b/configs/P1021RDB-PC_NAND_defconfig index 0ee7a35..4221812 100644 --- a/configs/P1021RDB-PC_NAND_defconfig +++ b/configs/P1021RDB-PC_NAND_defconfig @@ -50,6 +50,8 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1021RDB-PC_SDCARD_defconfig b/configs/P1021RDB-PC_SDCARD_defconfig index 4c49da3..ebd6b4c 100644 --- a/configs/P1021RDB-PC_SDCARD_defconfig +++ b/configs/P1021RDB-PC_SDCARD_defconfig @@ -47,6 +47,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1021RDB-PC_SPIFLASH_defconfig b/configs/P1021RDB-PC_SPIFLASH_defconfig index ac8c9b2..5ce4384 100644 --- a/configs/P1021RDB-PC_SPIFLASH_defconfig +++ b/configs/P1021RDB-PC_SPIFLASH_defconfig @@ -48,6 +48,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1021RDB-PC_defconfig b/configs/P1021RDB-PC_defconfig index c831333..093c0ae 100644 --- a/configs/P1021RDB-PC_defconfig +++ b/configs/P1021RDB-PC_defconfig @@ -37,6 +37,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1022DS_36BIT_NAND_defconfig b/configs/P1022DS_36BIT_NAND_defconfig index a28d506..e73c54a 100644 --- a/configs/P1022DS_36BIT_NAND_defconfig +++ b/configs/P1022DS_36BIT_NAND_defconfig @@ -48,6 +48,8 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1022DS_36BIT_SDCARD_defconfig b/configs/P1022DS_36BIT_SDCARD_defconfig index 5e49b03..6a03645 100644 --- a/configs/P1022DS_36BIT_SDCARD_defconfig +++ b/configs/P1022DS_36BIT_SDCARD_defconfig @@ -45,6 +45,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1022DS_36BIT_SPIFLASH_defconfig b/configs/P1022DS_36BIT_SPIFLASH_defconfig index cf1b6a0..aa6640c 100644 --- a/configs/P1022DS_36BIT_SPIFLASH_defconfig +++ b/configs/P1022DS_36BIT_SPIFLASH_defconfig @@ -46,6 +46,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1022DS_36BIT_defconfig b/configs/P1022DS_36BIT_defconfig index e1fb283..44c950e 100644 --- a/configs/P1022DS_36BIT_defconfig +++ b/configs/P1022DS_36BIT_defconfig @@ -35,6 +35,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1022DS_NAND_defconfig b/configs/P1022DS_NAND_defconfig index c69ae01..7d25d55 100644 --- a/configs/P1022DS_NAND_defconfig +++ b/configs/P1022DS_NAND_defconfig @@ -47,6 +47,8 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1022DS_SDCARD_defconfig b/configs/P1022DS_SDCARD_defconfig index dbf1872..cf90121 100644 --- a/configs/P1022DS_SDCARD_defconfig +++ b/configs/P1022DS_SDCARD_defconfig @@ -44,6 +44,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1022DS_SPIFLASH_defconfig b/configs/P1022DS_SPIFLASH_defconfig index 2c05461..81421c9 100644 --- a/configs/P1022DS_SPIFLASH_defconfig +++ b/configs/P1022DS_SPIFLASH_defconfig @@ -45,6 +45,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1022DS_defconfig b/configs/P1022DS_defconfig index 3449838..42c47f7 100644 --- a/configs/P1022DS_defconfig +++ b/configs/P1022DS_defconfig @@ -34,6 +34,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1024RDB_36BIT_defconfig b/configs/P1024RDB_36BIT_defconfig index b34dc74..577d9e8 100644 --- a/configs/P1024RDB_36BIT_defconfig +++ b/configs/P1024RDB_36BIT_defconfig @@ -33,6 +33,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1024RDB_NAND_defconfig b/configs/P1024RDB_NAND_defconfig index ed1b5e5..4eabadf 100644 --- a/configs/P1024RDB_NAND_defconfig +++ b/configs/P1024RDB_NAND_defconfig @@ -45,6 +45,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1024RDB_SDCARD_defconfig b/configs/P1024RDB_SDCARD_defconfig index 0925c2c..3e35df0 100644 --- a/configs/P1024RDB_SDCARD_defconfig +++ b/configs/P1024RDB_SDCARD_defconfig @@ -42,6 +42,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1024RDB_SPIFLASH_defconfig b/configs/P1024RDB_SPIFLASH_defconfig index 398112f..5e92ce1 100644 --- a/configs/P1024RDB_SPIFLASH_defconfig +++ b/configs/P1024RDB_SPIFLASH_defconfig @@ -43,6 +43,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1024RDB_defconfig b/configs/P1024RDB_defconfig index 2f21e2a..694a2e9 100644 --- a/configs/P1024RDB_defconfig +++ b/configs/P1024RDB_defconfig @@ -32,6 +32,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1025RDB_36BIT_defconfig b/configs/P1025RDB_36BIT_defconfig index 30cef8e..703b8d7 100644 --- a/configs/P1025RDB_36BIT_defconfig +++ b/configs/P1025RDB_36BIT_defconfig @@ -35,6 +35,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1025RDB_NAND_defconfig b/configs/P1025RDB_NAND_defconfig index 9e5bf25..2670cf1 100644 --- a/configs/P1025RDB_NAND_defconfig +++ b/configs/P1025RDB_NAND_defconfig @@ -47,6 +47,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1025RDB_SDCARD_defconfig b/configs/P1025RDB_SDCARD_defconfig index 5ca059c..fec3ac8 100644 --- a/configs/P1025RDB_SDCARD_defconfig +++ b/configs/P1025RDB_SDCARD_defconfig @@ -44,6 +44,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1025RDB_SPIFLASH_defconfig b/configs/P1025RDB_SPIFLASH_defconfig index ebb0475..f8c6486 100644 --- a/configs/P1025RDB_SPIFLASH_defconfig +++ b/configs/P1025RDB_SPIFLASH_defconfig @@ -45,6 +45,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P1025RDB_defconfig b/configs/P1025RDB_defconfig index 2feb9cca..19ac763 100644 --- a/configs/P1025RDB_defconfig +++ b/configs/P1025RDB_defconfig @@ -34,6 +34,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index e16c385..ea80231 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -51,6 +51,8 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig index fb78b20..7f0d3f8 100644 --- a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig @@ -48,6 +48,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig index e453814..ad0c7cc 100644 --- a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig @@ -49,6 +49,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P2020RDB-PC_36BIT_defconfig b/configs/P2020RDB-PC_36BIT_defconfig index 2d7b823..a9c21fb 100644 --- a/configs/P2020RDB-PC_36BIT_defconfig +++ b/configs/P2020RDB-PC_36BIT_defconfig @@ -38,6 +38,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index 964f21d..aeb14c8 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -50,6 +50,8 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P2020RDB-PC_SDCARD_defconfig b/configs/P2020RDB-PC_SDCARD_defconfig index 784262e..a2bdcc2 100644 --- a/configs/P2020RDB-PC_SDCARD_defconfig +++ b/configs/P2020RDB-PC_SDCARD_defconfig @@ -47,6 +47,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P2020RDB-PC_SPIFLASH_defconfig b/configs/P2020RDB-PC_SPIFLASH_defconfig index 6470097..df72a7d 100644 --- a/configs/P2020RDB-PC_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_SPIFLASH_defconfig @@ -48,6 +48,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P2020RDB-PC_defconfig b/configs/P2020RDB-PC_defconfig index 7e905dc..706a27d 100644 --- a/configs/P2020RDB-PC_defconfig +++ b/configs/P2020RDB-PC_defconfig @@ -37,6 +37,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/P2041RDB_NAND_defconfig b/configs/P2041RDB_NAND_defconfig index 96c388b..44966d8 100644 --- a/configs/P2041RDB_NAND_defconfig +++ b/configs/P2041RDB_NAND_defconfig @@ -32,6 +32,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/P2041RDB_SDCARD_defconfig b/configs/P2041RDB_SDCARD_defconfig index 3d5d96e..3d558c5 100644 --- a/configs/P2041RDB_SDCARD_defconfig +++ b/configs/P2041RDB_SDCARD_defconfig @@ -31,6 +31,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/P2041RDB_SECURE_BOOT_defconfig b/configs/P2041RDB_SECURE_BOOT_defconfig index 098f40f..f42c141 100644 --- a/configs/P2041RDB_SECURE_BOOT_defconfig +++ b/configs/P2041RDB_SECURE_BOOT_defconfig @@ -31,6 +31,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/P2041RDB_SPIFLASH_defconfig b/configs/P2041RDB_SPIFLASH_defconfig index e8698e8..4fb3794 100644 --- a/configs/P2041RDB_SPIFLASH_defconfig +++ b/configs/P2041RDB_SPIFLASH_defconfig @@ -31,6 +31,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/P2041RDB_SRIO_PCIE_BOOT_defconfig b/configs/P2041RDB_SRIO_PCIE_BOOT_defconfig index 75dedf3..ac74a25 100644 --- a/configs/P2041RDB_SRIO_PCIE_BOOT_defconfig +++ b/configs/P2041RDB_SRIO_PCIE_BOOT_defconfig @@ -27,6 +27,8 @@ CONFIG_ENV_IS_IN_REMOTE=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/P2041RDB_defconfig b/configs/P2041RDB_defconfig index 07c212b..2a70296 100644 --- a/configs/P2041RDB_defconfig +++ b/configs/P2041RDB_defconfig @@ -30,6 +30,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/P3041DS_NAND_SECURE_BOOT_defconfig b/configs/P3041DS_NAND_SECURE_BOOT_defconfig index 0f38a46..b1bc659 100644 --- a/configs/P3041DS_NAND_SECURE_BOOT_defconfig +++ b/configs/P3041DS_NAND_SECURE_BOOT_defconfig @@ -33,6 +33,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/P3041DS_NAND_defconfig b/configs/P3041DS_NAND_defconfig index a8dea7d..81ce703 100644 --- a/configs/P3041DS_NAND_defconfig +++ b/configs/P3041DS_NAND_defconfig @@ -32,6 +32,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/P3041DS_SDCARD_defconfig b/configs/P3041DS_SDCARD_defconfig index 40b40fc..7392948 100644 --- a/configs/P3041DS_SDCARD_defconfig +++ b/configs/P3041DS_SDCARD_defconfig @@ -31,6 +31,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/P3041DS_SECURE_BOOT_defconfig b/configs/P3041DS_SECURE_BOOT_defconfig index 06555e8..f7ed963 100644 --- a/configs/P3041DS_SECURE_BOOT_defconfig +++ b/configs/P3041DS_SECURE_BOOT_defconfig @@ -31,6 +31,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/P3041DS_SPIFLASH_defconfig b/configs/P3041DS_SPIFLASH_defconfig index 84b5d76..c89ee84 100644 --- a/configs/P3041DS_SPIFLASH_defconfig +++ b/configs/P3041DS_SPIFLASH_defconfig @@ -31,6 +31,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/P3041DS_SRIO_PCIE_BOOT_defconfig b/configs/P3041DS_SRIO_PCIE_BOOT_defconfig index 8e39410..2bc3f81 100644 --- a/configs/P3041DS_SRIO_PCIE_BOOT_defconfig +++ b/configs/P3041DS_SRIO_PCIE_BOOT_defconfig @@ -27,6 +27,8 @@ CONFIG_ENV_IS_IN_REMOTE=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/P3041DS_defconfig b/configs/P3041DS_defconfig index 2d72e76..6bae5a5 100644 --- a/configs/P3041DS_defconfig +++ b/configs/P3041DS_defconfig @@ -30,6 +30,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/P4080DS_SDCARD_defconfig b/configs/P4080DS_SDCARD_defconfig index 1a617b2..b67e12a 100644 --- a/configs/P4080DS_SDCARD_defconfig +++ b/configs/P4080DS_SDCARD_defconfig @@ -31,6 +31,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/P4080DS_SECURE_BOOT_defconfig b/configs/P4080DS_SECURE_BOOT_defconfig index 517a3af..0e47d70 100644 --- a/configs/P4080DS_SECURE_BOOT_defconfig +++ b/configs/P4080DS_SECURE_BOOT_defconfig @@ -31,6 +31,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/P4080DS_SPIFLASH_defconfig b/configs/P4080DS_SPIFLASH_defconfig index b90d65e..b108367 100644 --- a/configs/P4080DS_SPIFLASH_defconfig +++ b/configs/P4080DS_SPIFLASH_defconfig @@ -31,6 +31,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/P4080DS_SRIO_PCIE_BOOT_defconfig b/configs/P4080DS_SRIO_PCIE_BOOT_defconfig index 9b3ba81..a011c8c 100644 --- a/configs/P4080DS_SRIO_PCIE_BOOT_defconfig +++ b/configs/P4080DS_SRIO_PCIE_BOOT_defconfig @@ -27,6 +27,8 @@ CONFIG_ENV_IS_IN_REMOTE=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/P4080DS_defconfig b/configs/P4080DS_defconfig index 83a925b..ee4f51d 100644 --- a/configs/P4080DS_defconfig +++ b/configs/P4080DS_defconfig @@ -30,6 +30,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/P5020DS_NAND_SECURE_BOOT_defconfig b/configs/P5020DS_NAND_SECURE_BOOT_defconfig index 7d420a3..078d70b 100644 --- a/configs/P5020DS_NAND_SECURE_BOOT_defconfig +++ b/configs/P5020DS_NAND_SECURE_BOOT_defconfig @@ -34,6 +34,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/P5020DS_NAND_defconfig b/configs/P5020DS_NAND_defconfig index 8c89cca..7cbd790 100644 --- a/configs/P5020DS_NAND_defconfig +++ b/configs/P5020DS_NAND_defconfig @@ -33,6 +33,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/P5020DS_SDCARD_defconfig b/configs/P5020DS_SDCARD_defconfig index 0116c2d..c5438e2 100644 --- a/configs/P5020DS_SDCARD_defconfig +++ b/configs/P5020DS_SDCARD_defconfig @@ -32,6 +32,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/P5020DS_SECURE_BOOT_defconfig b/configs/P5020DS_SECURE_BOOT_defconfig index ce172a9..16607ae 100644 --- a/configs/P5020DS_SECURE_BOOT_defconfig +++ b/configs/P5020DS_SECURE_BOOT_defconfig @@ -32,6 +32,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/P5020DS_SPIFLASH_defconfig b/configs/P5020DS_SPIFLASH_defconfig index 28ac033..0ac8813 100644 --- a/configs/P5020DS_SPIFLASH_defconfig +++ b/configs/P5020DS_SPIFLASH_defconfig @@ -32,6 +32,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/P5020DS_SRIO_PCIE_BOOT_defconfig b/configs/P5020DS_SRIO_PCIE_BOOT_defconfig index e81af0e..487ad27 100644 --- a/configs/P5020DS_SRIO_PCIE_BOOT_defconfig +++ b/configs/P5020DS_SRIO_PCIE_BOOT_defconfig @@ -28,6 +28,8 @@ CONFIG_ENV_IS_IN_REMOTE=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/P5020DS_defconfig b/configs/P5020DS_defconfig index 7177716..6ef6de9 100644 --- a/configs/P5020DS_defconfig +++ b/configs/P5020DS_defconfig @@ -31,6 +31,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/P5040DS_NAND_SECURE_BOOT_defconfig b/configs/P5040DS_NAND_SECURE_BOOT_defconfig index 19c41ea..fd277ce 100644 --- a/configs/P5040DS_NAND_SECURE_BOOT_defconfig +++ b/configs/P5040DS_NAND_SECURE_BOOT_defconfig @@ -34,6 +34,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/P5040DS_NAND_defconfig b/configs/P5040DS_NAND_defconfig index 3e7c1f7..b2c61d7 100644 --- a/configs/P5040DS_NAND_defconfig +++ b/configs/P5040DS_NAND_defconfig @@ -33,6 +33,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/P5040DS_SDCARD_defconfig b/configs/P5040DS_SDCARD_defconfig index b12bb8f..dbff8f7 100644 --- a/configs/P5040DS_SDCARD_defconfig +++ b/configs/P5040DS_SDCARD_defconfig @@ -32,6 +32,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/P5040DS_SECURE_BOOT_defconfig b/configs/P5040DS_SECURE_BOOT_defconfig index 66c116f..2469443 100644 --- a/configs/P5040DS_SECURE_BOOT_defconfig +++ b/configs/P5040DS_SECURE_BOOT_defconfig @@ -32,6 +32,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/P5040DS_SPIFLASH_defconfig b/configs/P5040DS_SPIFLASH_defconfig index 1c34959..1552f84 100644 --- a/configs/P5040DS_SPIFLASH_defconfig +++ b/configs/P5040DS_SPIFLASH_defconfig @@ -32,6 +32,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/P5040DS_defconfig b/configs/P5040DS_defconfig index 314d05b..e8ff36e 100644 --- a/configs/P5040DS_defconfig +++ b/configs/P5040DS_defconfig @@ -31,6 +31,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T1023RDB_NAND_defconfig b/configs/T1023RDB_NAND_defconfig index 22feb6f..767458e 100644 --- a/configs/T1023RDB_NAND_defconfig +++ b/configs/T1023RDB_NAND_defconfig @@ -49,6 +49,8 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/configs/T1023RDB_SDCARD_defconfig b/configs/T1023RDB_SDCARD_defconfig index de99d16..f3b09d0 100644 --- a/configs/T1023RDB_SDCARD_defconfig +++ b/configs/T1023RDB_SDCARD_defconfig @@ -48,6 +48,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/configs/T1023RDB_SECURE_BOOT_defconfig b/configs/T1023RDB_SECURE_BOOT_defconfig index 60c8a47..ebb5ce3 100644 --- a/configs/T1023RDB_SECURE_BOOT_defconfig +++ b/configs/T1023RDB_SECURE_BOOT_defconfig @@ -38,6 +38,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/configs/T1023RDB_SPIFLASH_defconfig b/configs/T1023RDB_SPIFLASH_defconfig index b0434ea..dfbc755 100644 --- a/configs/T1023RDB_SPIFLASH_defconfig +++ b/configs/T1023RDB_SPIFLASH_defconfig @@ -49,6 +49,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/configs/T1023RDB_defconfig b/configs/T1023RDB_defconfig index 7a57a75..b334490 100644 --- a/configs/T1023RDB_defconfig +++ b/configs/T1023RDB_defconfig @@ -37,6 +37,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig b/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig index c38fee0..dd5c006 100644 --- a/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig +++ b/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig @@ -39,6 +39,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/T1024QDS_DDR4_defconfig b/configs/T1024QDS_DDR4_defconfig index 9a9a25b..9d887f1 100644 --- a/configs/T1024QDS_DDR4_defconfig +++ b/configs/T1024QDS_DDR4_defconfig @@ -38,6 +38,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/T1024QDS_NAND_defconfig b/configs/T1024QDS_NAND_defconfig index fa031a9..612c63f 100644 --- a/configs/T1024QDS_NAND_defconfig +++ b/configs/T1024QDS_NAND_defconfig @@ -51,6 +51,8 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/T1024QDS_SDCARD_defconfig b/configs/T1024QDS_SDCARD_defconfig index be461fc..392a180 100644 --- a/configs/T1024QDS_SDCARD_defconfig +++ b/configs/T1024QDS_SDCARD_defconfig @@ -50,6 +50,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/T1024QDS_SECURE_BOOT_defconfig b/configs/T1024QDS_SECURE_BOOT_defconfig index ecebd48..5d8a919 100644 --- a/configs/T1024QDS_SECURE_BOOT_defconfig +++ b/configs/T1024QDS_SECURE_BOOT_defconfig @@ -40,6 +40,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/T1024QDS_SPIFLASH_defconfig b/configs/T1024QDS_SPIFLASH_defconfig index 8ad4d35..7769acf 100644 --- a/configs/T1024QDS_SPIFLASH_defconfig +++ b/configs/T1024QDS_SPIFLASH_defconfig @@ -51,6 +51,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/T1024QDS_defconfig b/configs/T1024QDS_defconfig index 23ed39e..fbba22c 100644 --- a/configs/T1024QDS_defconfig +++ b/configs/T1024QDS_defconfig @@ -39,6 +39,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/T1024RDB_NAND_defconfig b/configs/T1024RDB_NAND_defconfig index 294d126..88eb858 100644 --- a/configs/T1024RDB_NAND_defconfig +++ b/configs/T1024RDB_NAND_defconfig @@ -51,6 +51,8 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/configs/T1024RDB_SDCARD_defconfig b/configs/T1024RDB_SDCARD_defconfig index e31578c..7078b3d 100644 --- a/configs/T1024RDB_SDCARD_defconfig +++ b/configs/T1024RDB_SDCARD_defconfig @@ -50,6 +50,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/configs/T1024RDB_SECURE_BOOT_defconfig b/configs/T1024RDB_SECURE_BOOT_defconfig index 4269133..76e959f 100644 --- a/configs/T1024RDB_SECURE_BOOT_defconfig +++ b/configs/T1024RDB_SECURE_BOOT_defconfig @@ -40,6 +40,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/configs/T1024RDB_SPIFLASH_defconfig b/configs/T1024RDB_SPIFLASH_defconfig index 148eef0..de60091 100644 --- a/configs/T1024RDB_SPIFLASH_defconfig +++ b/configs/T1024RDB_SPIFLASH_defconfig @@ -51,6 +51,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/configs/T1024RDB_defconfig b/configs/T1024RDB_defconfig index cb1f264..683a619 100644 --- a/configs/T1024RDB_defconfig +++ b/configs/T1024RDB_defconfig @@ -39,6 +39,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/configs/T1040D4RDB_NAND_defconfig b/configs/T1040D4RDB_NAND_defconfig index 637fa07..61ab715 100644 --- a/configs/T1040D4RDB_NAND_defconfig +++ b/configs/T1040D4RDB_NAND_defconfig @@ -48,6 +48,8 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T1040D4RDB_SDCARD_defconfig b/configs/T1040D4RDB_SDCARD_defconfig index 88f3c28..e07c1e6 100644 --- a/configs/T1040D4RDB_SDCARD_defconfig +++ b/configs/T1040D4RDB_SDCARD_defconfig @@ -47,6 +47,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T1040D4RDB_SECURE_BOOT_defconfig b/configs/T1040D4RDB_SECURE_BOOT_defconfig index 030f72a..d1b3c1a 100644 --- a/configs/T1040D4RDB_SECURE_BOOT_defconfig +++ b/configs/T1040D4RDB_SECURE_BOOT_defconfig @@ -37,6 +37,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T1040D4RDB_SPIFLASH_defconfig b/configs/T1040D4RDB_SPIFLASH_defconfig index 7adf65c..76b3792 100644 --- a/configs/T1040D4RDB_SPIFLASH_defconfig +++ b/configs/T1040D4RDB_SPIFLASH_defconfig @@ -48,6 +48,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T1040D4RDB_defconfig b/configs/T1040D4RDB_defconfig index c9032c2..17c47de 100644 --- a/configs/T1040D4RDB_defconfig +++ b/configs/T1040D4RDB_defconfig @@ -36,6 +36,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T1040QDS_DDR4_defconfig b/configs/T1040QDS_DDR4_defconfig index fd2c74f..fad61d4 100644 --- a/configs/T1040QDS_DDR4_defconfig +++ b/configs/T1040QDS_DDR4_defconfig @@ -39,6 +39,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/T1040QDS_SECURE_BOOT_defconfig b/configs/T1040QDS_SECURE_BOOT_defconfig index 719a1e4..a86936a 100644 --- a/configs/T1040QDS_SECURE_BOOT_defconfig +++ b/configs/T1040QDS_SECURE_BOOT_defconfig @@ -41,6 +41,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/T1040QDS_defconfig b/configs/T1040QDS_defconfig index 81454ab..e3ae3d7 100644 --- a/configs/T1040QDS_defconfig +++ b/configs/T1040QDS_defconfig @@ -40,6 +40,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/T1040RDB_NAND_defconfig b/configs/T1040RDB_NAND_defconfig index 3287d1b..353feba 100644 --- a/configs/T1040RDB_NAND_defconfig +++ b/configs/T1040RDB_NAND_defconfig @@ -49,6 +49,8 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T1040RDB_SDCARD_defconfig b/configs/T1040RDB_SDCARD_defconfig index 57d214d..93fd667 100644 --- a/configs/T1040RDB_SDCARD_defconfig +++ b/configs/T1040RDB_SDCARD_defconfig @@ -48,6 +48,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T1040RDB_SECURE_BOOT_defconfig b/configs/T1040RDB_SECURE_BOOT_defconfig index 62d1c30..ea400b2 100644 --- a/configs/T1040RDB_SECURE_BOOT_defconfig +++ b/configs/T1040RDB_SECURE_BOOT_defconfig @@ -38,6 +38,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T1040RDB_SPIFLASH_defconfig b/configs/T1040RDB_SPIFLASH_defconfig index c086a9f..beb8b8c 100644 --- a/configs/T1040RDB_SPIFLASH_defconfig +++ b/configs/T1040RDB_SPIFLASH_defconfig @@ -49,6 +49,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T1040RDB_defconfig b/configs/T1040RDB_defconfig index 0209fb8..3e7b3e8 100644 --- a/configs/T1040RDB_defconfig +++ b/configs/T1040RDB_defconfig @@ -37,6 +37,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index 0bb15cc..73fc6ae 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -49,6 +49,8 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index 1f7cf60..248136d 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -48,6 +48,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T1042D4RDB_SECURE_BOOT_defconfig b/configs/T1042D4RDB_SECURE_BOOT_defconfig index ef9b243..9d40088 100644 --- a/configs/T1042D4RDB_SECURE_BOOT_defconfig +++ b/configs/T1042D4RDB_SECURE_BOOT_defconfig @@ -38,6 +38,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index a2a7d67..abf29ef 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -49,6 +49,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T1042D4RDB_defconfig b/configs/T1042D4RDB_defconfig index 5d60022..466aea2 100644 --- a/configs/T1042D4RDB_defconfig +++ b/configs/T1042D4RDB_defconfig @@ -37,6 +37,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig index 245abd2..e1ad125 100644 --- a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig +++ b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig @@ -54,6 +54,8 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T1042RDB_PI_NAND_defconfig b/configs/T1042RDB_PI_NAND_defconfig index 0d72714..1c5f6b5 100644 --- a/configs/T1042RDB_PI_NAND_defconfig +++ b/configs/T1042RDB_PI_NAND_defconfig @@ -51,6 +51,8 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T1042RDB_PI_SDCARD_defconfig b/configs/T1042RDB_PI_SDCARD_defconfig index 4b2d182..d8688aa 100644 --- a/configs/T1042RDB_PI_SDCARD_defconfig +++ b/configs/T1042RDB_PI_SDCARD_defconfig @@ -50,6 +50,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T1042RDB_PI_SPIFLASH_defconfig b/configs/T1042RDB_PI_SPIFLASH_defconfig index 8c36654..6ab4091 100644 --- a/configs/T1042RDB_PI_SPIFLASH_defconfig +++ b/configs/T1042RDB_PI_SPIFLASH_defconfig @@ -51,6 +51,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T1042RDB_PI_defconfig b/configs/T1042RDB_PI_defconfig index ec816e7..d968324 100644 --- a/configs/T1042RDB_PI_defconfig +++ b/configs/T1042RDB_PI_defconfig @@ -39,6 +39,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T1042RDB_SECURE_BOOT_defconfig b/configs/T1042RDB_SECURE_BOOT_defconfig index 2e40362..5072f2a 100644 --- a/configs/T1042RDB_SECURE_BOOT_defconfig +++ b/configs/T1042RDB_SECURE_BOOT_defconfig @@ -37,6 +37,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T1042RDB_defconfig b/configs/T1042RDB_defconfig index 515dec4..2bf2647 100644 --- a/configs/T1042RDB_defconfig +++ b/configs/T1042RDB_defconfig @@ -36,6 +36,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T2080QDS_NAND_defconfig b/configs/T2080QDS_NAND_defconfig index 948a05a..f5609ed 100644 --- a/configs/T2080QDS_NAND_defconfig +++ b/configs/T2080QDS_NAND_defconfig @@ -47,6 +47,8 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/T2080QDS_SDCARD_defconfig b/configs/T2080QDS_SDCARD_defconfig index 30e87df..8af628b 100644 --- a/configs/T2080QDS_SDCARD_defconfig +++ b/configs/T2080QDS_SDCARD_defconfig @@ -46,6 +46,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/T2080QDS_SECURE_BOOT_defconfig b/configs/T2080QDS_SECURE_BOOT_defconfig index 9e155ee..dd71811 100644 --- a/configs/T2080QDS_SECURE_BOOT_defconfig +++ b/configs/T2080QDS_SECURE_BOOT_defconfig @@ -34,6 +34,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/T2080QDS_SPIFLASH_defconfig b/configs/T2080QDS_SPIFLASH_defconfig index 0cccb3a..d0b7d38 100644 --- a/configs/T2080QDS_SPIFLASH_defconfig +++ b/configs/T2080QDS_SPIFLASH_defconfig @@ -47,6 +47,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig index 9c9a436..133dc7d 100644 --- a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig @@ -26,6 +26,8 @@ CONFIG_ENV_IS_IN_REMOTE=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/T2080QDS_defconfig b/configs/T2080QDS_defconfig index 79cf442..7f5a26f 100644 --- a/configs/T2080QDS_defconfig +++ b/configs/T2080QDS_defconfig @@ -36,6 +36,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/T2080RDB_NAND_defconfig b/configs/T2080RDB_NAND_defconfig index 4a5a56e..5731a1f 100644 --- a/configs/T2080RDB_NAND_defconfig +++ b/configs/T2080RDB_NAND_defconfig @@ -47,6 +47,8 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/configs/T2080RDB_SDCARD_defconfig b/configs/T2080RDB_SDCARD_defconfig index dfe5e8b..66a1a11 100644 --- a/configs/T2080RDB_SDCARD_defconfig +++ b/configs/T2080RDB_SDCARD_defconfig @@ -46,6 +46,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/configs/T2080RDB_SECURE_BOOT_defconfig b/configs/T2080RDB_SECURE_BOOT_defconfig index 5ec495a..0166821 100644 --- a/configs/T2080RDB_SECURE_BOOT_defconfig +++ b/configs/T2080RDB_SECURE_BOOT_defconfig @@ -36,6 +36,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/configs/T2080RDB_SPIFLASH_defconfig b/configs/T2080RDB_SPIFLASH_defconfig index 6d6d640..58abfbd 100644 --- a/configs/T2080RDB_SPIFLASH_defconfig +++ b/configs/T2080RDB_SPIFLASH_defconfig @@ -47,6 +47,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig b/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig index 297c31f..a5d83bc 100644 --- a/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig @@ -28,6 +28,8 @@ CONFIG_ENV_IS_IN_REMOTE=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/configs/T2080RDB_defconfig b/configs/T2080RDB_defconfig index 4f155de..e782ba0 100644 --- a/configs/T2080RDB_defconfig +++ b/configs/T2080RDB_defconfig @@ -35,6 +35,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/configs/T2081QDS_NAND_defconfig b/configs/T2081QDS_NAND_defconfig index d38a1e3..a2c4953 100644 --- a/configs/T2081QDS_NAND_defconfig +++ b/configs/T2081QDS_NAND_defconfig @@ -45,6 +45,8 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/T2081QDS_SDCARD_defconfig b/configs/T2081QDS_SDCARD_defconfig index 4dd0e90..1e9686a 100644 --- a/configs/T2081QDS_SDCARD_defconfig +++ b/configs/T2081QDS_SDCARD_defconfig @@ -44,6 +44,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/T2081QDS_SPIFLASH_defconfig b/configs/T2081QDS_SPIFLASH_defconfig index 6dc7d6d..9b55633 100644 --- a/configs/T2081QDS_SPIFLASH_defconfig +++ b/configs/T2081QDS_SPIFLASH_defconfig @@ -45,6 +45,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/T2081QDS_SRIO_PCIE_BOOT_defconfig b/configs/T2081QDS_SRIO_PCIE_BOOT_defconfig index 43fe470..83d5e50 100644 --- a/configs/T2081QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2081QDS_SRIO_PCIE_BOOT_defconfig @@ -26,6 +26,8 @@ CONFIG_ENV_IS_IN_REMOTE=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/T2081QDS_defconfig b/configs/T2081QDS_defconfig index 24b616b..e785b58 100644 --- a/configs/T2081QDS_defconfig +++ b/configs/T2081QDS_defconfig @@ -33,6 +33,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/T4160QDS_NAND_defconfig b/configs/T4160QDS_NAND_defconfig index af529b2..3bc51e5 100644 --- a/configs/T4160QDS_NAND_defconfig +++ b/configs/T4160QDS_NAND_defconfig @@ -41,6 +41,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T4160QDS_SDCARD_defconfig b/configs/T4160QDS_SDCARD_defconfig index b29c0691..8afa322 100644 --- a/configs/T4160QDS_SDCARD_defconfig +++ b/configs/T4160QDS_SDCARD_defconfig @@ -40,6 +40,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T4160QDS_SECURE_BOOT_defconfig b/configs/T4160QDS_SECURE_BOOT_defconfig index 4463386..bf7b701 100644 --- a/configs/T4160QDS_SECURE_BOOT_defconfig +++ b/configs/T4160QDS_SECURE_BOOT_defconfig @@ -30,6 +30,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T4160QDS_defconfig b/configs/T4160QDS_defconfig index 4f45229..7834ebf 100644 --- a/configs/T4160QDS_defconfig +++ b/configs/T4160QDS_defconfig @@ -29,6 +29,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T4160RDB_defconfig b/configs/T4160RDB_defconfig index 06c8038..c5a8bb0 100644 --- a/configs/T4160RDB_defconfig +++ b/configs/T4160RDB_defconfig @@ -29,6 +29,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T4240QDS_NAND_defconfig b/configs/T4240QDS_NAND_defconfig index caeeacb..8efb924 100644 --- a/configs/T4240QDS_NAND_defconfig +++ b/configs/T4240QDS_NAND_defconfig @@ -41,6 +41,8 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T4240QDS_SDCARD_defconfig b/configs/T4240QDS_SDCARD_defconfig index b461e08..07bda33 100644 --- a/configs/T4240QDS_SDCARD_defconfig +++ b/configs/T4240QDS_SDCARD_defconfig @@ -40,6 +40,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T4240QDS_SECURE_BOOT_defconfig b/configs/T4240QDS_SECURE_BOOT_defconfig index 416b415..2535ea3 100644 --- a/configs/T4240QDS_SECURE_BOOT_defconfig +++ b/configs/T4240QDS_SECURE_BOOT_defconfig @@ -30,6 +30,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T4240QDS_SRIO_PCIE_BOOT_defconfig b/configs/T4240QDS_SRIO_PCIE_BOOT_defconfig index 1169b66..d360f3b 100644 --- a/configs/T4240QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T4240QDS_SRIO_PCIE_BOOT_defconfig @@ -26,6 +26,8 @@ CONFIG_ENV_IS_IN_REMOTE=y CONFIG_FSL_CAAM=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T4240QDS_defconfig b/configs/T4240QDS_defconfig index d1f33d7..89cd173 100644 --- a/configs/T4240QDS_defconfig +++ b/configs/T4240QDS_defconfig @@ -29,6 +29,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T4240RDB_SDCARD_defconfig b/configs/T4240RDB_SDCARD_defconfig index 8bde983..ae9d663 100644 --- a/configs/T4240RDB_SDCARD_defconfig +++ b/configs/T4240RDB_SDCARD_defconfig @@ -40,6 +40,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/T4240RDB_defconfig b/configs/T4240RDB_defconfig index d9f5845..ef26e7c 100644 --- a/configs/T4240RDB_defconfig +++ b/configs/T4240RDB_defconfig @@ -29,6 +29,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y diff --git a/configs/UCP1020_SPIFLASH_defconfig b/configs/UCP1020_SPIFLASH_defconfig index d75c1f3..a2d7e66 100644 --- a/configs/UCP1020_SPIFLASH_defconfig +++ b/configs/UCP1020_SPIFLASH_defconfig @@ -41,6 +41,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/UCP1020_defconfig b/configs/UCP1020_defconfig index 7fc6acc..0a676d4 100644 --- a/configs/UCP1020_defconfig +++ b/configs/UCP1020_defconfig @@ -41,6 +41,8 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/ae350_rv32_defconfig b/configs/ae350_rv32_defconfig index 5837b48..6e0be88 100644 --- a/configs/ae350_rv32_defconfig +++ b/configs/ae350_rv32_defconfig @@ -27,6 +27,7 @@ CONFIG_CFI_FLASH=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0x0 CONFIG_SPI_FLASH_MACRONIX=y CONFIG_FTMAC100=y CONFIG_BAUDRATE=38400 diff --git a/configs/ae350_rv64_defconfig b/configs/ae350_rv64_defconfig index b250d3f..b472a76 100644 --- a/configs/ae350_rv64_defconfig +++ b/configs/ae350_rv64_defconfig @@ -28,6 +28,7 @@ CONFIG_CFI_FLASH=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0x0 CONFIG_SPI_FLASH_MACRONIX=y CONFIG_FTMAC100=y CONFIG_BAUDRATE=38400 diff --git a/configs/am335x_boneblack_vboot_defconfig b/configs/am335x_boneblack_vboot_defconfig index f455b01..6afda72 100644 --- a/configs/am335x_boneblack_vboot_defconfig +++ b/configs/am335x_boneblack_vboot_defconfig @@ -39,6 +39,7 @@ CONFIG_MISC=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y CONFIG_DM_ETH=y CONFIG_PHY_GIGE=y diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index 9241168..4fddb78 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -44,6 +44,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y CONFIG_DM_ETH=y CONFIG_PHY_GIGE=y diff --git a/configs/am335x_hs_evm_defconfig b/configs/am335x_hs_evm_defconfig index faa6c2b..92cfdd6 100644 --- a/configs/am335x_hs_evm_defconfig +++ b/configs/am335x_hs_evm_defconfig @@ -45,6 +45,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y CONFIG_DM_ETH=y CONFIG_PHY_GIGE=y diff --git a/configs/am335x_hs_evm_uart_defconfig b/configs/am335x_hs_evm_uart_defconfig index 02332db..c12179d 100644 --- a/configs/am335x_hs_evm_uart_defconfig +++ b/configs/am335x_hs_evm_uart_defconfig @@ -47,6 +47,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y CONFIG_DM_ETH=y CONFIG_PHY_GIGE=y diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index e346414..526dda2 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -46,6 +46,7 @@ CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=48000000 CONFIG_SPI_FLASH_MACRONIX=y CONFIG_PHY_GIGE=y CONFIG_MII=y diff --git a/configs/am43xx_evm_qspiboot_defconfig b/configs/am43xx_evm_qspiboot_defconfig index 0d7bd72..b644273 100644 --- a/configs/am43xx_evm_qspiboot_defconfig +++ b/configs/am43xx_evm_qspiboot_defconfig @@ -39,6 +39,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=48000000 CONFIG_SPI_FLASH_MACRONIX=y CONFIG_MII=y CONFIG_DRIVER_TI_CPSW=y diff --git a/configs/am43xx_evm_rtconly_defconfig b/configs/am43xx_evm_rtconly_defconfig index 7d56db4..c855705 100644 --- a/configs/am43xx_evm_rtconly_defconfig +++ b/configs/am43xx_evm_rtconly_defconfig @@ -37,6 +37,7 @@ CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=48000000 CONFIG_SPI_FLASH_MACRONIX=y CONFIG_PHY_GIGE=y CONFIG_MII=y diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index 5bd919b..e0580b9 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -49,6 +49,7 @@ CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=48000000 CONFIG_SPI_FLASH_MACRONIX=y CONFIG_PHY_GIGE=y CONFIG_MII=y diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index c01fda9..76224c6 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -47,6 +47,7 @@ CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=48000000 CONFIG_SPI_FLASH_MACRONIX=y CONFIG_PHY_GIGE=y CONFIG_MII=y diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index 7486820..e96cd4c 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -57,6 +57,8 @@ CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=76800000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index 9124ada..4c9b4a0 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -60,6 +60,8 @@ CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=76800000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y diff --git a/configs/am57xx_hs_evm_usb_defconfig b/configs/am57xx_hs_evm_usb_defconfig index 6e4580a..c49140e 100644 --- a/configs/am57xx_hs_evm_usb_defconfig +++ b/configs/am57xx_hs_evm_usb_defconfig @@ -65,6 +65,8 @@ CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=76800000 CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MICREL=y diff --git a/configs/aristainetos2_defconfig b/configs/aristainetos2_defconfig index f7de4e3..b852b4d 100644 --- a/configs/aristainetos2_defconfig +++ b/configs/aristainetos2_defconfig @@ -39,6 +39,10 @@ CONFIG_FSL_ESDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=3 +CONFIG_SF_DEFAULT_CS=1 +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_MTD_UBI_FASTMAP_AUTOCONVERT=1 diff --git a/configs/aristainetos2b_defconfig b/configs/aristainetos2b_defconfig index ff21f1f..7806d0a 100644 --- a/configs/aristainetos2b_defconfig +++ b/configs/aristainetos2b_defconfig @@ -39,6 +39,8 @@ CONFIG_FSL_ESDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_MTD_UBI_FASTMAP_AUTOCONVERT=1 diff --git a/configs/aristainetos_defconfig b/configs/aristainetos_defconfig index 950f9f6..bad6aeb 100644 --- a/configs/aristainetos_defconfig +++ b/configs/aristainetos_defconfig @@ -39,6 +39,9 @@ CONFIG_FSL_ESDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=3 +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_MTD_UBI_FASTMAP_AUTOCONVERT=1 diff --git a/configs/at91sam9n12ek_mmc_defconfig b/configs/at91sam9n12ek_mmc_defconfig index 853a264..04e251b 100644 --- a/configs/at91sam9n12ek_mmc_defconfig +++ b/configs/at91sam9n12ek_mmc_defconfig @@ -44,6 +44,7 @@ CONFIG_NAND_ATMEL=y CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_PINCTRL=y CONFIG_PINCTRL_AT91=y diff --git a/configs/at91sam9n12ek_nandflash_defconfig b/configs/at91sam9n12ek_nandflash_defconfig index fd83ba0..b04d95b 100644 --- a/configs/at91sam9n12ek_nandflash_defconfig +++ b/configs/at91sam9n12ek_nandflash_defconfig @@ -43,6 +43,7 @@ CONFIG_NAND_ATMEL=y CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_PINCTRL=y CONFIG_PINCTRL_AT91=y diff --git a/configs/at91sam9n12ek_spiflash_defconfig b/configs/at91sam9n12ek_spiflash_defconfig index 273f91c..7260e0c 100644 --- a/configs/at91sam9n12ek_spiflash_defconfig +++ b/configs/at91sam9n12ek_spiflash_defconfig @@ -44,6 +44,7 @@ CONFIG_NAND_ATMEL=y CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_PINCTRL=y CONFIG_PINCTRL_AT91=y diff --git a/configs/at91sam9x5ek_dataflash_defconfig b/configs/at91sam9x5ek_dataflash_defconfig index 010d731..1330207 100644 --- a/configs/at91sam9x5ek_dataflash_defconfig +++ b/configs/at91sam9x5ek_dataflash_defconfig @@ -46,6 +46,7 @@ CONFIG_NAND_ATMEL=y CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_DM_ETH=y CONFIG_MACB=y diff --git a/configs/at91sam9x5ek_mmc_defconfig b/configs/at91sam9x5ek_mmc_defconfig index 5deabaf..39e3eee 100644 --- a/configs/at91sam9x5ek_mmc_defconfig +++ b/configs/at91sam9x5ek_mmc_defconfig @@ -46,6 +46,7 @@ CONFIG_NAND_ATMEL=y CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_DM_ETH=y CONFIG_MACB=y diff --git a/configs/at91sam9x5ek_nandflash_defconfig b/configs/at91sam9x5ek_nandflash_defconfig index bdb2b9a..842047f 100644 --- a/configs/at91sam9x5ek_nandflash_defconfig +++ b/configs/at91sam9x5ek_nandflash_defconfig @@ -45,6 +45,7 @@ CONFIG_NAND_ATMEL=y CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_DM_ETH=y CONFIG_MACB=y diff --git a/configs/at91sam9x5ek_spiflash_defconfig b/configs/at91sam9x5ek_spiflash_defconfig index 5f06231..85ad78a 100644 --- a/configs/at91sam9x5ek_spiflash_defconfig +++ b/configs/at91sam9x5ek_spiflash_defconfig @@ -46,6 +46,7 @@ CONFIG_NAND_ATMEL=y CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_DM_ETH=y CONFIG_MACB=y diff --git a/configs/beaver_defconfig b/configs/beaver_defconfig index 77d1ad5..36abe26 100644 --- a/configs/beaver_defconfig +++ b/configs/beaver_defconfig @@ -31,6 +31,8 @@ CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y CONFIG_RTL8169=y CONFIG_PCI=y diff --git a/configs/bg0900_defconfig b/configs/bg0900_defconfig index 2bafc79..a8b5f86 100644 --- a/configs/bg0900_defconfig +++ b/configs/bg0900_defconfig @@ -32,6 +32,9 @@ CONFIG_DOS_PARTITION=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=2 +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=40000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_MII=y CONFIG_CONS_INDEX=0 diff --git a/configs/birdland_bav335a_defconfig b/configs/birdland_bav335a_defconfig index 17015b9..eea1223 100644 --- a/configs/birdland_bav335a_defconfig +++ b/configs/birdland_bav335a_defconfig @@ -48,6 +48,7 @@ CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_MMC_OMAP_HS=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y CONFIG_MII=y CONFIG_DRIVER_TI_CPSW=y diff --git a/configs/birdland_bav335b_defconfig b/configs/birdland_bav335b_defconfig index af3dbcf..7358fe5 100644 --- a/configs/birdland_bav335b_defconfig +++ b/configs/birdland_bav335b_defconfig @@ -48,6 +48,7 @@ CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_MMC_OMAP_HS=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y CONFIG_MII=y CONFIG_DRIVER_TI_CPSW=y diff --git a/configs/brppt1_spi_defconfig b/configs/brppt1_spi_defconfig index 12bb8cd..739b078 100644 --- a/configs/brppt1_spi_defconfig +++ b/configs/brppt1_spi_defconfig @@ -83,6 +83,7 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD_DEVICE=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set diff --git a/configs/cardhu_defconfig b/configs/cardhu_defconfig index be55728..666ce5f 100644 --- a/configs/cardhu_defconfig +++ b/configs/cardhu_defconfig @@ -25,6 +25,8 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_DEFAULT_DEVICE_TREE="tegra30-cardhu" CONFIG_SPL_DM=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y CONFIG_RTL8169=y CONFIG_PCI=y diff --git a/configs/cei-tk1-som_defconfig b/configs/cei-tk1-som_defconfig index 74b17ef..f0b8eb8 100644 --- a/configs/cei-tk1-som_defconfig +++ b/configs/cei-tk1-som_defconfig @@ -30,6 +30,8 @@ CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y CONFIG_RTL8169=y CONFIG_PCI=y diff --git a/configs/cgtqmx6eval_defconfig b/configs/cgtqmx6eval_defconfig index 99c581b..2311c4f 100644 --- a/configs/cgtqmx6eval_defconfig +++ b/configs/cgtqmx6eval_defconfig @@ -56,6 +56,8 @@ CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_SPI=y diff --git a/configs/chromebit_mickey_defconfig b/configs/chromebit_mickey_defconfig index ea19c69..d7c343b 100644 --- a/configs/chromebit_mickey_defconfig +++ b/configs/chromebit_mickey_defconfig @@ -60,6 +60,7 @@ CONFIG_PWRSEQ=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y CONFIG_DM_PMIC=y diff --git a/configs/chromebook_bob_defconfig b/configs/chromebook_bob_defconfig index 92c65b1..ce3decc 100644 --- a/configs/chromebook_bob_defconfig +++ b/configs/chromebook_bob_defconfig @@ -66,6 +66,7 @@ CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ROCKCHIP=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_GIGADEVICE=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/chromebook_jerry_defconfig b/configs/chromebook_jerry_defconfig index 617c706..5943db0 100644 --- a/configs/chromebook_jerry_defconfig +++ b/configs/chromebook_jerry_defconfig @@ -64,6 +64,7 @@ CONFIG_PWRSEQ=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y CONFIG_DM_PMIC=y diff --git a/configs/chromebook_minnie_defconfig b/configs/chromebook_minnie_defconfig index 297d0e4..2a1f1c1 100644 --- a/configs/chromebook_minnie_defconfig +++ b/configs/chromebook_minnie_defconfig @@ -61,6 +61,7 @@ CONFIG_PWRSEQ=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y CONFIG_DM_PMIC=y diff --git a/configs/chromebook_speedy_defconfig b/configs/chromebook_speedy_defconfig index 624b8f8..aeaee38 100644 --- a/configs/chromebook_speedy_defconfig +++ b/configs/chromebook_speedy_defconfig @@ -62,6 +62,7 @@ CONFIG_CROS_EC_SPI=y CONFIG_PWRSEQ=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y # CONFIG_SPL_PINCTRL_FULL is not set diff --git a/configs/cl-som-am57x_defconfig b/configs/cl-som-am57x_defconfig index cd780cd..fd8353e 100644 --- a/configs/cl-som-am57x_defconfig +++ b/configs/cl-som-am57x_defconfig @@ -37,6 +37,7 @@ CONFIG_LED_STATUS_BIT=37 CONFIG_LED_STATUS_STATE=2 CONFIG_MMC_OMAP_HS=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=48000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_GIGADEVICE=y diff --git a/configs/cl-som-imx7_defconfig b/configs/cl-som-imx7_defconfig index 3501e2b..2b26e66 100644 --- a/configs/cl-som-imx7_defconfig +++ b/configs/cl-som-imx7_defconfig @@ -51,6 +51,8 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_GIGADEVICE=y diff --git a/configs/clearfog_defconfig b/configs/clearfog_defconfig index c90600e..0429071 100644 --- a/configs/clearfog_defconfig +++ b/configs/clearfog_defconfig @@ -48,6 +48,7 @@ CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_MV=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 CONFIG_SPI_FLASH_WINBOND=y CONFIG_SPI_FLASH_MTD=y CONFIG_PHY_MARVELL=y diff --git a/configs/clearfog_gt_8k_defconfig b/configs/clearfog_gt_8k_defconfig index ee84877..f8e0850 100644 --- a/configs/clearfog_gt_8k_defconfig +++ b/configs/clearfog_gt_8k_defconfig @@ -44,6 +44,7 @@ CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_XENON=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index c8d1e83..6156ac2 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -57,6 +57,8 @@ CONFIG_FSL_ESDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=25000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_GIGADEVICE=y diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index ea0cafa..4338629 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -49,6 +49,7 @@ CONFIG_DM_GPIO=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=48000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_GIGADEVICE=y diff --git a/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig b/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig index 966d321..c4d7488 100644 --- a/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig +++ b/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig @@ -39,6 +39,8 @@ CONFIG_DM=y CONFIG_FSL_SATA=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHY_MARVELL=y CONFIG_MII=y diff --git a/configs/controlcenterd_36BIT_SDCARD_defconfig b/configs/controlcenterd_36BIT_SDCARD_defconfig index 752015c..113dc33 100644 --- a/configs/controlcenterd_36BIT_SDCARD_defconfig +++ b/configs/controlcenterd_36BIT_SDCARD_defconfig @@ -39,6 +39,8 @@ CONFIG_DM=y CONFIG_FSL_SATA=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHY_MARVELL=y CONFIG_MII=y diff --git a/configs/controlcenterdc_defconfig b/configs/controlcenterdc_defconfig index b4b5732..b2b61b2 100644 --- a/configs/controlcenterdc_defconfig +++ b/configs/controlcenterdc_defconfig @@ -55,6 +55,7 @@ CONFIG_LED_GPIO=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_MV=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y diff --git a/configs/dalmore_defconfig b/configs/dalmore_defconfig index c2ee3d8..e6cdaff 100644 --- a/configs/dalmore_defconfig +++ b/configs/dalmore_defconfig @@ -30,6 +30,8 @@ CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y CONFIG_TEGRA114_SPI=y diff --git a/configs/db-88f6820-amc_defconfig b/configs/db-88f6820-amc_defconfig index 3e1b404..7fd1d50 100644 --- a/configs/db-88f6820-amc_defconfig +++ b/configs/db-88f6820-amc_defconfig @@ -52,6 +52,7 @@ CONFIG_SYS_I2C_MVTWSI=y CONFIG_NAND=y CONFIG_NAND_PXA3XX=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHY_MARVELL=y diff --git a/configs/dh_imx6_defconfig b/configs/dh_imx6_defconfig index a14c5f2..b2faf1c 100644 --- a/configs/dh_imx6_defconfig +++ b/configs/dh_imx6_defconfig @@ -41,6 +41,8 @@ CONFIG_BOOTCOUNT_LIMIT=y CONFIG_SYS_BOOTCOUNT_ADDR=0x00900000 CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=25000000 CONFIG_SPI_FLASH_GIGADEVICE=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/display5_defconfig b/configs/display5_defconfig index cdf3642..077a451 100644 --- a/configs/display5_defconfig +++ b/configs/display5_defconfig @@ -65,6 +65,9 @@ CONFIG_SYS_BOOTCOUNT_ADDR=0x020CC068 CONFIG_FSL_ESDHC=y CONFIG_MTD_DEVICE=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=50000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y diff --git a/configs/display5_factory_defconfig b/configs/display5_factory_defconfig index 6b9febf..983ea72 100644 --- a/configs/display5_factory_defconfig +++ b/configs/display5_factory_defconfig @@ -66,6 +66,9 @@ CONFIG_DFU_SF=y CONFIG_FSL_ESDHC=y CONFIG_MTD_DEVICE=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=50000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y diff --git a/configs/dms-ba16-1g_defconfig b/configs/dms-ba16-1g_defconfig index a2f4395..6ca5d2b 100644 --- a/configs/dms-ba16-1g_defconfig +++ b/configs/dms-ba16-1g_defconfig @@ -34,6 +34,8 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DWC_AHSATA=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_PHYLIB=y diff --git a/configs/dms-ba16_defconfig b/configs/dms-ba16_defconfig index 2784c12..4ad3df6 100644 --- a/configs/dms-ba16_defconfig +++ b/configs/dms-ba16_defconfig @@ -33,6 +33,8 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DWC_AHSATA=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_PHYLIB=y diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index ef06150..0bc8012 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -67,6 +67,8 @@ CONFIG_SPL_MMC_HS200_SUPPORT=y CONFIG_MMC_OMAP_HS=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=76800000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_DM_ETH=y CONFIG_PHY_GIGE=y diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index 3cf7659..fb25818 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -71,6 +71,8 @@ CONFIG_SPL_MMC_HS200_SUPPORT=y CONFIG_MMC_OMAP_HS=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=76800000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_DM_ETH=y CONFIG_PHY_GIGE=y diff --git a/configs/dra7xx_hs_evm_usb_defconfig b/configs/dra7xx_hs_evm_usb_defconfig index 378b3d7..aa4b826 100644 --- a/configs/dra7xx_hs_evm_usb_defconfig +++ b/configs/dra7xx_hs_evm_usb_defconfig @@ -76,6 +76,8 @@ CONFIG_SPL_MMC_HS200_SUPPORT=y CONFIG_MMC_OMAP_HS=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=76800000 CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_DM_ETH=y diff --git a/configs/e2220-1170_defconfig b/configs/e2220-1170_defconfig index afa08a0..4c847bd 100644 --- a/configs/e2220-1170_defconfig +++ b/configs/e2220-1170_defconfig @@ -25,6 +25,8 @@ CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y CONFIG_TEGRA114_SPI=y diff --git a/configs/ea20_defconfig b/configs/ea20_defconfig index fae7ff9..ceab73d 100644 --- a/configs/ea20_defconfig +++ b/configs/ea20_defconfig @@ -37,6 +37,7 @@ CONFIG_SYS_I2C_DAVINCI=y CONFIG_NAND=y CONFIG_NAND_DAVINCI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_MII=y CONFIG_DRIVER_TI_EMAC=y diff --git a/configs/evb-rk3036_defconfig b/configs/evb-rk3036_defconfig index eb7b3a4..a0ca4e1 100644 --- a/configs/evb-rk3036_defconfig +++ b/configs/evb-rk3036_defconfig @@ -43,6 +43,7 @@ CONFIG_LED=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_PINCTRL=y # CONFIG_SPL_DM_SERIAL is not set CONFIG_DEBUG_UART_SHIFT=2 diff --git a/configs/evb-rk3128_defconfig b/configs/evb-rk3128_defconfig index d2c0fb0..de85f5a 100644 --- a/configs/evb-rk3128_defconfig +++ b/configs/evb-rk3128_defconfig @@ -30,6 +30,7 @@ CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_PHY=y CONFIG_PINCTRL=y CONFIG_REGULATOR_PWM=y diff --git a/configs/evb-rk3288_defconfig b/configs/evb-rk3288_defconfig index d0eba8a..8635fd9 100644 --- a/configs/evb-rk3288_defconfig +++ b/configs/evb-rk3288_defconfig @@ -53,6 +53,7 @@ CONFIG_LED_GPIO=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y diff --git a/configs/evb-rk3328_defconfig b/configs/evb-rk3328_defconfig index 6783d5a..fffd293 100644 --- a/configs/evb-rk3328_defconfig +++ b/configs/evb-rk3328_defconfig @@ -33,6 +33,7 @@ CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig index 3a0ed18..d985353 100644 --- a/configs/evb-rk3399_defconfig +++ b/configs/evb-rk3399_defconfig @@ -44,6 +44,7 @@ CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MMC_DW=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y diff --git a/configs/fennec-rk3288_defconfig b/configs/fennec-rk3288_defconfig index 4e0898d..668323f 100644 --- a/configs/fennec-rk3288_defconfig +++ b/configs/fennec-rk3288_defconfig @@ -52,6 +52,7 @@ CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y diff --git a/configs/ficus-rk3399_defconfig b/configs/ficus-rk3399_defconfig index 4e4e7dd..94c565e 100644 --- a/configs/ficus-rk3399_defconfig +++ b/configs/ficus-rk3399_defconfig @@ -44,6 +44,7 @@ CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_RGMII=y diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index b8eae0f..ba5b3ba 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -55,6 +55,7 @@ CONFIG_LED_GPIO=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y diff --git a/configs/firefly-rk3399_defconfig b/configs/firefly-rk3399_defconfig index 3b3be22..6725b48 100644 --- a/configs/firefly-rk3399_defconfig +++ b/configs/firefly-rk3399_defconfig @@ -44,6 +44,7 @@ CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y diff --git a/configs/ge_bx50v3_defconfig b/configs/ge_bx50v3_defconfig index a250719..7319919 100644 --- a/configs/ge_bx50v3_defconfig +++ b/configs/ge_bx50v3_defconfig @@ -38,6 +38,8 @@ CONFIG_SYS_BOOTCOUNT_EXT_DEVPART="1:5" CONFIG_SYS_BOOTCOUNT_ADDR=0x7000A000 CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_E1000=y diff --git a/configs/helios4_defconfig b/configs/helios4_defconfig index 6ef40b0..699ce06 100644 --- a/configs/helios4_defconfig +++ b/configs/helios4_defconfig @@ -47,6 +47,8 @@ CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_MV=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 +CONFIG_SF_DEFAULT_SPEED=104000000 CONFIG_SPI_FLASH_WINBOND=y CONFIG_PHY_GIGE=y CONFIG_MVNETA=y diff --git a/configs/jetson-tk1_defconfig b/configs/jetson-tk1_defconfig index c39c424..cee01a3 100644 --- a/configs/jetson-tk1_defconfig +++ b/configs/jetson-tk1_defconfig @@ -31,6 +31,8 @@ CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y CONFIG_RTL8169=y CONFIG_PCI=y diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index a108f88..6123dad 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -43,6 +43,7 @@ CONFIG_NAND=y CONFIG_NAND_DAVINCI=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_MARVELL=y diff --git a/configs/k2e_hs_evm_defconfig b/configs/k2e_hs_evm_defconfig index 67f6fb1..11c9fda 100644 --- a/configs/k2e_hs_evm_defconfig +++ b/configs/k2e_hs_evm_defconfig @@ -36,6 +36,7 @@ CONFIG_NAND=y CONFIG_NAND_DAVINCI=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_MARVELL=y diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index 838b6f1..4ff9c13 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -43,6 +43,8 @@ CONFIG_NAND=y CONFIG_NAND_DAVINCI=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y diff --git a/configs/k2g_hs_evm_defconfig b/configs/k2g_hs_evm_defconfig index 93fa236..990c7f6 100644 --- a/configs/k2g_hs_evm_defconfig +++ b/configs/k2g_hs_evm_defconfig @@ -37,6 +37,8 @@ CONFIG_NAND=y CONFIG_NAND_DAVINCI=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index ce139d1..6835874 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -43,6 +43,7 @@ CONFIG_NAND=y CONFIG_NAND_DAVINCI=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_MARVELL=y diff --git a/configs/k2hk_hs_evm_defconfig b/configs/k2hk_hs_evm_defconfig index db61557..e14f901 100644 --- a/configs/k2hk_hs_evm_defconfig +++ b/configs/k2hk_hs_evm_defconfig @@ -36,6 +36,7 @@ CONFIG_NAND=y CONFIG_NAND_DAVINCI=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_MARVELL=y diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index 368171d..0e2f73a 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -43,6 +43,7 @@ CONFIG_NAND=y CONFIG_NAND_DAVINCI=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_MARVELL=y diff --git a/configs/k2l_hs_evm_defconfig b/configs/k2l_hs_evm_defconfig index 7bb672f..1f7a93e 100644 --- a/configs/k2l_hs_evm_defconfig +++ b/configs/k2l_hs_evm_defconfig @@ -35,6 +35,7 @@ CONFIG_NAND=y CONFIG_NAND_DAVINCI=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_MARVELL=y diff --git a/configs/km_kirkwood_128m16_defconfig b/configs/km_kirkwood_128m16_defconfig index b55b8b0..92fb248 100644 --- a/configs/km_kirkwood_128m16_defconfig +++ b/configs/km_kirkwood_128m16_defconfig @@ -35,6 +35,7 @@ CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=8100000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_MVGBE=y CONFIG_MII=y diff --git a/configs/km_kirkwood_defconfig b/configs/km_kirkwood_defconfig index b47b9e3..b1a95cb 100644 --- a/configs/km_kirkwood_defconfig +++ b/configs/km_kirkwood_defconfig @@ -35,6 +35,7 @@ CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=8100000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_MVGBE=y CONFIG_MII=y diff --git a/configs/km_kirkwood_pci_defconfig b/configs/km_kirkwood_pci_defconfig index fb18630..443399d 100644 --- a/configs/km_kirkwood_pci_defconfig +++ b/configs/km_kirkwood_pci_defconfig @@ -35,6 +35,7 @@ CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=8100000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_MVGBE=y CONFIG_MII=y diff --git a/configs/kmcoge4_defconfig b/configs/kmcoge4_defconfig index a3cc06b..4243933 100644 --- a/configs/kmcoge4_defconfig +++ b/configs/kmcoge4_defconfig @@ -40,6 +40,8 @@ CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_SYS_BOOTCOUNT_ADDR=0xFB000020 # CONFIG_MMC is not set CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y diff --git a/configs/kmcoge5un_defconfig b/configs/kmcoge5un_defconfig index 598af88..7ec7281 100644 --- a/configs/kmcoge5un_defconfig +++ b/configs/kmcoge5un_defconfig @@ -35,6 +35,7 @@ CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=8100000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_MVGBE=y CONFIG_MII=y diff --git a/configs/kmlion1_defconfig b/configs/kmlion1_defconfig index 75e5204..8f02b85 100644 --- a/configs/kmlion1_defconfig +++ b/configs/kmlion1_defconfig @@ -40,6 +40,8 @@ CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_SYS_BOOTCOUNT_ADDR=0xFB000020 # CONFIG_MMC is not set CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y diff --git a/configs/kmnusa_defconfig b/configs/kmnusa_defconfig index 8b3fa7e..34ece18 100644 --- a/configs/kmnusa_defconfig +++ b/configs/kmnusa_defconfig @@ -35,6 +35,7 @@ CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=8100000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_MVGBE=y CONFIG_MII=y diff --git a/configs/kmsugp1_defconfig b/configs/kmsugp1_defconfig index d2206b4..63c5925 100644 --- a/configs/kmsugp1_defconfig +++ b/configs/kmsugp1_defconfig @@ -35,6 +35,7 @@ CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=8100000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_MVGBE=y CONFIG_MII=y diff --git a/configs/kmsuv31_defconfig b/configs/kmsuv31_defconfig index 62d3a0a..b2d6232 100644 --- a/configs/kmsuv31_defconfig +++ b/configs/kmsuv31_defconfig @@ -35,6 +35,7 @@ CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=8100000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_MVGBE=y CONFIG_MII=y diff --git a/configs/kylin-rk3036_defconfig b/configs/kylin-rk3036_defconfig index d6d5abb..29113f9 100644 --- a/configs/kylin-rk3036_defconfig +++ b/configs/kylin-rk3036_defconfig @@ -41,6 +41,7 @@ CONFIG_LED=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_PINCTRL=y CONFIG_DM_REGULATOR_FIXED=y # CONFIG_SPL_DM_SERIAL is not set diff --git a/configs/legoev3_defconfig b/configs/legoev3_defconfig index 7b8f169..32cd52c 100644 --- a/configs/legoev3_defconfig +++ b/configs/legoev3_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_DIAG=y CONFIG_SYS_I2C_DAVINCI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=50000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/ls1012aqds_qspi_defconfig b/configs/ls1012aqds_qspi_defconfig index 3a1121c..1bf9343 100644 --- a/configs/ls1012aqds_qspi_defconfig +++ b/configs/ls1012aqds_qspi_defconfig @@ -42,6 +42,9 @@ CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_FSL_PFE=y CONFIG_DM_ETH=y diff --git a/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig index 7d0d690..747fa3d 100644 --- a/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig @@ -40,6 +40,9 @@ CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_FSL_PFE=y CONFIG_DM_ETH=y diff --git a/configs/ls1012aqds_tfa_defconfig b/configs/ls1012aqds_tfa_defconfig index 30f2343..a41757d 100644 --- a/configs/ls1012aqds_tfa_defconfig +++ b/configs/ls1012aqds_tfa_defconfig @@ -42,6 +42,9 @@ CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=10000000 # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_FSL_PFE=y CONFIG_DM_ETH=y diff --git a/configs/ls1043aqds_defconfig b/configs/ls1043aqds_defconfig index 8bde83d..349600e 100644 --- a/configs/ls1043aqds_defconfig +++ b/configs/ls1043aqds_defconfig @@ -39,6 +39,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_E1000=y CONFIG_PCI=y diff --git a/configs/ls1043aqds_lpuart_defconfig b/configs/ls1043aqds_lpuart_defconfig index 7944812..f67f584 100644 --- a/configs/ls1043aqds_lpuart_defconfig +++ b/configs/ls1043aqds_lpuart_defconfig @@ -38,6 +38,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_E1000=y CONFIG_PCI=y diff --git a/configs/ls1043aqds_nand_defconfig b/configs/ls1043aqds_nand_defconfig index ada225c..326f07d 100644 --- a/configs/ls1043aqds_nand_defconfig +++ b/configs/ls1043aqds_nand_defconfig @@ -52,6 +52,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_E1000=y CONFIG_PCI=y diff --git a/configs/ls1043aqds_nor_ddr3_defconfig b/configs/ls1043aqds_nor_ddr3_defconfig index e86d419..b47a21f 100644 --- a/configs/ls1043aqds_nor_ddr3_defconfig +++ b/configs/ls1043aqds_nor_ddr3_defconfig @@ -38,6 +38,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_E1000=y CONFIG_PCI=y diff --git a/configs/ls1043aqds_sdcard_ifc_defconfig b/configs/ls1043aqds_sdcard_ifc_defconfig index afa91e8..fed4fda 100644 --- a/configs/ls1043aqds_sdcard_ifc_defconfig +++ b/configs/ls1043aqds_sdcard_ifc_defconfig @@ -52,6 +52,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_E1000=y CONFIG_PCI=y diff --git a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig index ce6f1ef..92dde7c 100644 --- a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig @@ -38,6 +38,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_E1000=y CONFIG_PCI=y diff --git a/configs/ls1043aqds_tfa_defconfig b/configs/ls1043aqds_tfa_defconfig index dfd70b5..f17820d 100644 --- a/configs/ls1043aqds_tfa_defconfig +++ b/configs/ls1043aqds_tfa_defconfig @@ -42,6 +42,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_E1000=y CONFIG_PCI=y diff --git a/configs/ls1043ardb_SECURE_BOOT_defconfig b/configs/ls1043ardb_SECURE_BOOT_defconfig index 0a51540..b9ce10c 100644 --- a/configs/ls1043ardb_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_SECURE_BOOT_defconfig @@ -31,6 +31,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y CONFIG_E1000=y diff --git a/configs/ls1043ardb_defconfig b/configs/ls1043ardb_defconfig index 1462a44..063f8c2 100644 --- a/configs/ls1043ardb_defconfig +++ b/configs/ls1043ardb_defconfig @@ -32,6 +32,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_E1000=y diff --git a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig index 8a45f7c..6db8d55 100644 --- a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig @@ -49,6 +49,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_E1000=y diff --git a/configs/ls1043ardb_nand_defconfig b/configs/ls1043ardb_nand_defconfig index 509f2f1..1abd4be 100644 --- a/configs/ls1043ardb_nand_defconfig +++ b/configs/ls1043ardb_nand_defconfig @@ -49,6 +49,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_E1000=y diff --git a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig index 33ce8ac..3008690 100644 --- a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig @@ -47,6 +47,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y CONFIG_E1000=y diff --git a/configs/ls1043ardb_sdcard_defconfig b/configs/ls1043ardb_sdcard_defconfig index 91dac81..3ca4046 100644 --- a/configs/ls1043ardb_sdcard_defconfig +++ b/configs/ls1043ardb_sdcard_defconfig @@ -47,6 +47,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_E1000=y diff --git a/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig index 0af2594..8e5ade3 100644 --- a/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig @@ -33,6 +33,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHY_GIGE=y CONFIG_E1000=y diff --git a/configs/ls1043ardb_tfa_defconfig b/configs/ls1043ardb_tfa_defconfig index 93cd545..623a4b4 100644 --- a/configs/ls1043ardb_tfa_defconfig +++ b/configs/ls1043ardb_tfa_defconfig @@ -36,6 +36,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_E1000=y diff --git a/configs/ls1046aqds_SECURE_BOOT_defconfig b/configs/ls1046aqds_SECURE_BOOT_defconfig index ae05dd1..7959144 100644 --- a/configs/ls1046aqds_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_SECURE_BOOT_defconfig @@ -37,6 +37,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_E1000=y CONFIG_PCI=y diff --git a/configs/ls1046aqds_defconfig b/configs/ls1046aqds_defconfig index f7a35df..fc6e838 100644 --- a/configs/ls1046aqds_defconfig +++ b/configs/ls1046aqds_defconfig @@ -40,6 +40,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_E1000=y CONFIG_PCI=y diff --git a/configs/ls1046aqds_lpuart_defconfig b/configs/ls1046aqds_lpuart_defconfig index 0a8d51e..5ba6f5a 100644 --- a/configs/ls1046aqds_lpuart_defconfig +++ b/configs/ls1046aqds_lpuart_defconfig @@ -39,6 +39,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_E1000=y CONFIG_PCI=y diff --git a/configs/ls1046aqds_nand_defconfig b/configs/ls1046aqds_nand_defconfig index 9e11db7..c0d330e 100644 --- a/configs/ls1046aqds_nand_defconfig +++ b/configs/ls1046aqds_nand_defconfig @@ -45,6 +45,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_E1000=y CONFIG_PCI=y diff --git a/configs/ls1046aqds_sdcard_ifc_defconfig b/configs/ls1046aqds_sdcard_ifc_defconfig index edf915f..3989339 100644 --- a/configs/ls1046aqds_sdcard_ifc_defconfig +++ b/configs/ls1046aqds_sdcard_ifc_defconfig @@ -54,6 +54,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_E1000=y CONFIG_PCI=y diff --git a/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig index f57dda5..0e1be75 100644 --- a/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig @@ -41,6 +41,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_E1000=y CONFIG_PCI=y diff --git a/configs/ls1046aqds_tfa_defconfig b/configs/ls1046aqds_tfa_defconfig index f77aa23..f73d5fe 100644 --- a/configs/ls1046aqds_tfa_defconfig +++ b/configs/ls1046aqds_tfa_defconfig @@ -45,6 +45,7 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 CONFIG_PHYLIB=y CONFIG_E1000=y CONFIG_PCI=y diff --git a/configs/lschlv2_defconfig b/configs/lschlv2_defconfig index 8563abc..16d9c92 100644 --- a/configs/lschlv2_defconfig +++ b/configs/lschlv2_defconfig @@ -30,6 +30,7 @@ CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=25000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_MVGBE=y CONFIG_MII=y diff --git a/configs/lsxhl_defconfig b/configs/lsxhl_defconfig index c363606..b6eba4a 100644 --- a/configs/lsxhl_defconfig +++ b/configs/lsxhl_defconfig @@ -30,6 +30,7 @@ CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=25000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_MVGBE=y CONFIG_MII=y diff --git a/configs/marsboard_defconfig b/configs/marsboard_defconfig index 48bec11..320e14e 100644 --- a/configs/marsboard_defconfig +++ b/configs/marsboard_defconfig @@ -23,6 +23,8 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_MII=y diff --git a/configs/mccmon6_nor_defconfig b/configs/mccmon6_nor_defconfig index 1ab29c1..245dc15 100644 --- a/configs/mccmon6_nor_defconfig +++ b/configs/mccmon6_nor_defconfig @@ -38,6 +38,9 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=2 +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=25000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/mccmon6_sd_defconfig b/configs/mccmon6_sd_defconfig index 6d47db5..9bb5e26 100644 --- a/configs/mccmon6_sd_defconfig +++ b/configs/mccmon6_sd_defconfig @@ -39,6 +39,9 @@ CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=2 +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=25000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/mgcoge3un_defconfig b/configs/mgcoge3un_defconfig index 0c2785c..d85a216 100644 --- a/configs/mgcoge3un_defconfig +++ b/configs/mgcoge3un_defconfig @@ -35,6 +35,7 @@ CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=8100000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_MVGBE=y CONFIG_MII=y diff --git a/configs/miqi-rk3288_defconfig b/configs/miqi-rk3288_defconfig index b26bd1e..abc46d0 100644 --- a/configs/miqi-rk3288_defconfig +++ b/configs/miqi-rk3288_defconfig @@ -52,6 +52,7 @@ CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y diff --git a/configs/mvebu_db-88f3720_defconfig b/configs/mvebu_db-88f3720_defconfig index da51868..ecbcf95 100644 --- a/configs/mvebu_db-88f3720_defconfig +++ b/configs/mvebu_db-88f3720_defconfig @@ -45,6 +45,7 @@ CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_XENON=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/mvebu_db_armada8k_defconfig b/configs/mvebu_db_armada8k_defconfig index 271875f..e1514b3 100644 --- a/configs/mvebu_db_armada8k_defconfig +++ b/configs/mvebu_db_armada8k_defconfig @@ -41,6 +41,7 @@ CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_XENON=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/mvebu_espressobin-88f3720_defconfig b/configs/mvebu_espressobin-88f3720_defconfig index 8701d1f..0d7fafe 100644 --- a/configs/mvebu_espressobin-88f3720_defconfig +++ b/configs/mvebu_espressobin-88f3720_defconfig @@ -44,6 +44,7 @@ CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_XENON=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/mvebu_mcbin-88f8040_defconfig b/configs/mvebu_mcbin-88f8040_defconfig index eb019c9..8c38722 100644 --- a/configs/mvebu_mcbin-88f8040_defconfig +++ b/configs/mvebu_mcbin-88f8040_defconfig @@ -44,6 +44,7 @@ CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_XENON=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/mx28evk_auart_console_defconfig b/configs/mx28evk_auart_console_defconfig index d057221..beb10c4 100644 --- a/configs/mx28evk_auart_console_defconfig +++ b/configs/mx28evk_auart_console_defconfig @@ -43,6 +43,9 @@ CONFIG_MMC_MXS=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=2 +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_SST=y CONFIG_MII=y CONFIG_CONS_INDEX=0 diff --git a/configs/mx28evk_defconfig b/configs/mx28evk_defconfig index ab59d75..be1feb3 100644 --- a/configs/mx28evk_defconfig +++ b/configs/mx28evk_defconfig @@ -43,6 +43,9 @@ CONFIG_MMC_MXS=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=2 +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_SST=y CONFIG_MII=y CONFIG_CONS_INDEX=0 diff --git a/configs/mx28evk_nand_defconfig b/configs/mx28evk_nand_defconfig index 6b774cf..61e3586 100644 --- a/configs/mx28evk_nand_defconfig +++ b/configs/mx28evk_nand_defconfig @@ -42,6 +42,9 @@ CONFIG_MMC_MXS=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=2 +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_SST=y CONFIG_MII=y CONFIG_CONS_INDEX=0 diff --git a/configs/mx28evk_spi_defconfig b/configs/mx28evk_spi_defconfig index 0a77e6e..3198baf 100644 --- a/configs/mx28evk_spi_defconfig +++ b/configs/mx28evk_spi_defconfig @@ -42,6 +42,9 @@ CONFIG_MMC_MXS=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=2 +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_SST=y CONFIG_MII=y CONFIG_CONS_INDEX=0 diff --git a/configs/mx6qsabrelite_defconfig b/configs/mx6qsabrelite_defconfig index 2666340..3989352 100644 --- a/configs/mx6qsabrelite_defconfig +++ b/configs/mx6qsabrelite_defconfig @@ -36,6 +36,8 @@ CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=25000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index f51b5af..d0f950b 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -64,6 +64,8 @@ CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_MII=y diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index bd2d4ee..d5475bc 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -75,6 +75,8 @@ CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_MII=y diff --git a/configs/mx6slevk_defconfig b/configs/mx6slevk_defconfig index 44cd50b..d93a4df 100644 --- a/configs/mx6slevk_defconfig +++ b/configs/mx6slevk_defconfig @@ -36,6 +36,8 @@ CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_MII=y diff --git a/configs/mx6slevk_spinor_defconfig b/configs/mx6slevk_spinor_defconfig index 72212fb..76f6101 100644 --- a/configs/mx6slevk_spinor_defconfig +++ b/configs/mx6slevk_spinor_defconfig @@ -36,6 +36,8 @@ CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_MII=y diff --git a/configs/mx6slevk_spl_defconfig b/configs/mx6slevk_spl_defconfig index bcfeb30..936c152 100644 --- a/configs/mx6slevk_spl_defconfig +++ b/configs/mx6slevk_spl_defconfig @@ -44,6 +44,8 @@ CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_MII=y diff --git a/configs/mx6sxsabreauto_defconfig b/configs/mx6sxsabreauto_defconfig index b60e9b6..b2247c4 100644 --- a/configs/mx6sxsabreauto_defconfig +++ b/configs/mx6sxsabreauto_defconfig @@ -39,6 +39,8 @@ CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=40000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_MII=y diff --git a/configs/mx6sxsabresd_defconfig b/configs/mx6sxsabresd_defconfig index 5c0aa63..3982115 100644 --- a/configs/mx6sxsabresd_defconfig +++ b/configs/mx6sxsabresd_defconfig @@ -41,6 +41,9 @@ CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=40000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y diff --git a/configs/mx6ul_14x14_evk_defconfig b/configs/mx6ul_14x14_evk_defconfig index 4a3c56f..3ef781e 100644 --- a/configs/mx6ul_14x14_evk_defconfig +++ b/configs/mx6ul_14x14_evk_defconfig @@ -46,6 +46,8 @@ CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=40000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/mx6ul_9x9_evk_defconfig b/configs/mx6ul_9x9_evk_defconfig index 185f543..69160f7 100644 --- a/configs/mx6ul_9x9_evk_defconfig +++ b/configs/mx6ul_9x9_evk_defconfig @@ -46,6 +46,8 @@ CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=40000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/mx6ull_14x14_evk_defconfig b/configs/mx6ull_14x14_evk_defconfig index a5a1cb5..7902465 100644 --- a/configs/mx6ull_14x14_evk_defconfig +++ b/configs/mx6ull_14x14_evk_defconfig @@ -33,6 +33,8 @@ CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=40000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y diff --git a/configs/mx6ull_14x14_evk_plugin_defconfig b/configs/mx6ull_14x14_evk_plugin_defconfig index 831b8cc..990ea71 100644 --- a/configs/mx6ull_14x14_evk_plugin_defconfig +++ b/configs/mx6ull_14x14_evk_plugin_defconfig @@ -34,6 +34,8 @@ CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=40000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y diff --git a/configs/mx7dsabresd_qspi_defconfig b/configs/mx7dsabresd_qspi_defconfig index 81f4538..3d74967 100644 --- a/configs/mx7dsabresd_qspi_defconfig +++ b/configs/mx7dsabresd_qspi_defconfig @@ -50,6 +50,8 @@ CONFIG_MMC_HS200_SUPPORT=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=40000000 CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_PHYLIB=y diff --git a/configs/nitrogen6dl2g_defconfig b/configs/nitrogen6dl2g_defconfig index af59a71..debe60b 100644 --- a/configs/nitrogen6dl2g_defconfig +++ b/configs/nitrogen6dl2g_defconfig @@ -38,6 +38,8 @@ CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=25000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/nitrogen6dl_defconfig b/configs/nitrogen6dl_defconfig index 9072c04..96d9c02 100644 --- a/configs/nitrogen6dl_defconfig +++ b/configs/nitrogen6dl_defconfig @@ -38,6 +38,8 @@ CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=25000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index b92d27a..5bc4219 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -40,6 +40,8 @@ CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=25000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index 3b8cc6a..37fa405 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -40,6 +40,8 @@ CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=25000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/nitrogen6s1g_defconfig b/configs/nitrogen6s1g_defconfig index 36cfe21..1d3f015 100644 --- a/configs/nitrogen6s1g_defconfig +++ b/configs/nitrogen6s1g_defconfig @@ -38,6 +38,8 @@ CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=25000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/nitrogen6s_defconfig b/configs/nitrogen6s_defconfig index 40c09d7..5bf2b3a 100644 --- a/configs/nitrogen6s_defconfig +++ b/configs/nitrogen6s_defconfig @@ -38,6 +38,8 @@ CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=25000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/nyan-big_defconfig b/configs/nyan-big_defconfig index 13d8f99..4102ae7 100644 --- a/configs/nyan-big_defconfig +++ b/configs/nyan-big_defconfig @@ -49,6 +49,8 @@ CONFIG_CROS_EC_KEYB=y CONFIG_CROS_EC=y CONFIG_CROS_EC_SPI=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y CONFIG_DM_PMIC=y CONFIG_PMIC_AS3722=y diff --git a/configs/omapl138_lcdk_defconfig b/configs/omapl138_lcdk_defconfig index d66af98..e282099 100644 --- a/configs/omapl138_lcdk_defconfig +++ b/configs/omapl138_lcdk_defconfig @@ -46,6 +46,7 @@ CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x28000 CONFIG_SPL_NAND_SIMPLE=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_MII=y diff --git a/configs/ot1200_defconfig b/configs/ot1200_defconfig index 2825e44..f0fe375 100644 --- a/configs/ot1200_defconfig +++ b/configs/ot1200_defconfig @@ -33,6 +33,9 @@ CONFIG_DWC_AHSATA=y CONFIG_CMD_PCA953X=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=2 +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=25000000 CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/ot1200_spl_defconfig b/configs/ot1200_spl_defconfig index c8c53e8..d3960e4 100644 --- a/configs/ot1200_spl_defconfig +++ b/configs/ot1200_spl_defconfig @@ -42,6 +42,9 @@ CONFIG_DWC_AHSATA=y CONFIG_CMD_PCA953X=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=2 +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=25000000 CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/p2371-0000_defconfig b/configs/p2371-0000_defconfig index 015ac05..9a6578a 100644 --- a/configs/p2371-0000_defconfig +++ b/configs/p2371-0000_defconfig @@ -26,6 +26,8 @@ CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y CONFIG_TEGRA114_SPI=y diff --git a/configs/p2371-2180_defconfig b/configs/p2371-2180_defconfig index 81ce9a2..03c23dd 100644 --- a/configs/p2371-2180_defconfig +++ b/configs/p2371-2180_defconfig @@ -28,6 +28,8 @@ CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y CONFIG_RTL8169=y CONFIG_PCI=y diff --git a/configs/p2571_defconfig b/configs/p2571_defconfig index 5482ac2..caeac30 100644 --- a/configs/p2571_defconfig +++ b/configs/p2571_defconfig @@ -26,6 +26,8 @@ CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y CONFIG_TEGRA114_SPI=y diff --git a/configs/pcm051_rev1_defconfig b/configs/pcm051_rev1_defconfig index 1780307..718c33f 100644 --- a/configs/pcm051_rev1_defconfig +++ b/configs/pcm051_rev1_defconfig @@ -42,6 +42,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_MMC_OMAP_HS=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y CONFIG_MII=y CONFIG_DRIVER_TI_CPSW=y diff --git a/configs/pcm051_rev3_defconfig b/configs/pcm051_rev3_defconfig index 27431ee..05ebe66 100644 --- a/configs/pcm051_rev3_defconfig +++ b/configs/pcm051_rev3_defconfig @@ -42,6 +42,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_MMC_OMAP_HS=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y CONFIG_MII=y CONFIG_DRIVER_TI_CPSW=y diff --git a/configs/pcm058_defconfig b/configs/pcm058_defconfig index af4768f..9bb6dd6 100644 --- a/configs/pcm058_defconfig +++ b/configs/pcm058_defconfig @@ -47,6 +47,8 @@ CONFIG_MTD=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/peach-pi_defconfig b/configs/peach-pi_defconfig index 96ec8fd..cb818c5 100644 --- a/configs/peach-pi_defconfig +++ b/configs/peach-pi_defconfig @@ -39,6 +39,8 @@ CONFIG_MMC_DW=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_S5P=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=50000000 CONFIG_SPI_FLASH_GIGADEVICE=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SMC911X=y diff --git a/configs/peach-pit_defconfig b/configs/peach-pit_defconfig index 792f22f..bb1558b 100644 --- a/configs/peach-pit_defconfig +++ b/configs/peach-pit_defconfig @@ -38,6 +38,8 @@ CONFIG_MMC_DW=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_S5P=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=50000000 CONFIG_SPI_FLASH_GIGADEVICE=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SMC911X=y diff --git a/configs/pfla02_defconfig b/configs/pfla02_defconfig index 2eb59e4..799d54d 100644 --- a/configs/pfla02_defconfig +++ b/configs/pfla02_defconfig @@ -46,6 +46,9 @@ CONFIG_MTD=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=2 +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/phycore-rk3288_defconfig b/configs/phycore-rk3288_defconfig index 1e54035..7503417 100644 --- a/configs/phycore-rk3288_defconfig +++ b/configs/phycore-rk3288_defconfig @@ -56,6 +56,7 @@ CONFIG_I2C_EEPROM=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y diff --git a/configs/popmetal-rk3288_defconfig b/configs/popmetal-rk3288_defconfig index ca194fd..ac50729 100644 --- a/configs/popmetal-rk3288_defconfig +++ b/configs/popmetal-rk3288_defconfig @@ -52,6 +52,7 @@ CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y diff --git a/configs/portl2_defconfig b/configs/portl2_defconfig index 7d2e97a..7e0abaa 100644 --- a/configs/portl2_defconfig +++ b/configs/portl2_defconfig @@ -33,6 +33,7 @@ CONFIG_BOOTCOUNT_RAM=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 # CONFIG_MMC is not set CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=8100000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_MVGBE=y CONFIG_MII=y diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index 3fcff25..3547ec6 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -67,6 +67,7 @@ CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_ROCKCHIP=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_WINBOND=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y diff --git a/configs/riotboard_defconfig b/configs/riotboard_defconfig index a9191ad..e3d16df 100644 --- a/configs/riotboard_defconfig +++ b/configs/riotboard_defconfig @@ -23,6 +23,8 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_MII=y diff --git a/configs/riotboard_spl_defconfig b/configs/riotboard_spl_defconfig index 2298d5b..51fa98d 100644 --- a/configs/riotboard_spl_defconfig +++ b/configs/riotboard_spl_defconfig @@ -32,6 +32,8 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_MII=y diff --git a/configs/rock2_defconfig b/configs/rock2_defconfig index 746c0bf..24ad3e9 100644 --- a/configs/rock2_defconfig +++ b/configs/rock2_defconfig @@ -52,6 +52,7 @@ CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y diff --git a/configs/rock960-rk3399_defconfig b/configs/rock960-rk3399_defconfig index 17311e6..cb5a35f 100644 --- a/configs/rock960-rk3399_defconfig +++ b/configs/rock960-rk3399_defconfig @@ -45,6 +45,7 @@ CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y CONFIG_DM_PMIC=y diff --git a/configs/rock_defconfig b/configs/rock_defconfig index 2de51e8..19c3858 100644 --- a/configs/rock_defconfig +++ b/configs/rock_defconfig @@ -41,6 +41,7 @@ CONFIG_LED=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_PINCTRL=y CONFIG_DM_PMIC=y # CONFIG_SPL_PMIC_CHILDREN is not set diff --git a/configs/sama5d27_som1_ek_mmc1_defconfig b/configs/sama5d27_som1_ek_mmc1_defconfig index 5f4abe8..c523384 100644 --- a/configs/sama5d27_som1_ek_mmc1_defconfig +++ b/configs/sama5d27_som1_ek_mmc1_defconfig @@ -62,6 +62,7 @@ CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ATMEL=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=66000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/sama5d27_som1_ek_mmc_defconfig b/configs/sama5d27_som1_ek_mmc_defconfig index 5dcd80c..447dd23 100644 --- a/configs/sama5d27_som1_ek_mmc_defconfig +++ b/configs/sama5d27_som1_ek_mmc_defconfig @@ -63,6 +63,7 @@ CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ATMEL=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=66000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/sama5d2_xplained_emmc_defconfig b/configs/sama5d2_xplained_emmc_defconfig index d6c30e2..5259dff 100644 --- a/configs/sama5d2_xplained_emmc_defconfig +++ b/configs/sama5d2_xplained_emmc_defconfig @@ -62,6 +62,7 @@ CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ATMEL=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_DM_ETH=y CONFIG_MACB=y diff --git a/configs/sama5d2_xplained_mmc_defconfig b/configs/sama5d2_xplained_mmc_defconfig index 49e2a73..e291127 100644 --- a/configs/sama5d2_xplained_mmc_defconfig +++ b/configs/sama5d2_xplained_mmc_defconfig @@ -64,6 +64,7 @@ CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ATMEL=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_DM_ETH=y CONFIG_MACB=y diff --git a/configs/sama5d2_xplained_spiflash_defconfig b/configs/sama5d2_xplained_spiflash_defconfig index 9bb4a07..b1e010c 100644 --- a/configs/sama5d2_xplained_spiflash_defconfig +++ b/configs/sama5d2_xplained_spiflash_defconfig @@ -61,6 +61,7 @@ CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ATMEL=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_DM_ETH=y CONFIG_MACB=y diff --git a/configs/sama5d36ek_cmp_mmc_defconfig b/configs/sama5d36ek_cmp_mmc_defconfig index ced445f..bb4578a 100644 --- a/configs/sama5d36ek_cmp_mmc_defconfig +++ b/configs/sama5d36ek_cmp_mmc_defconfig @@ -46,6 +46,7 @@ CONFIG_NAND_ATMEL=y CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_DM_ETH=y CONFIG_MACB=y diff --git a/configs/sama5d36ek_cmp_nandflash_defconfig b/configs/sama5d36ek_cmp_nandflash_defconfig index 2967036..ed9d65c 100644 --- a/configs/sama5d36ek_cmp_nandflash_defconfig +++ b/configs/sama5d36ek_cmp_nandflash_defconfig @@ -45,6 +45,7 @@ CONFIG_NAND_ATMEL=y CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_DM_ETH=y CONFIG_MACB=y diff --git a/configs/sama5d36ek_cmp_spiflash_defconfig b/configs/sama5d36ek_cmp_spiflash_defconfig index 1f1fc8e..0514138 100644 --- a/configs/sama5d36ek_cmp_spiflash_defconfig +++ b/configs/sama5d36ek_cmp_spiflash_defconfig @@ -46,6 +46,7 @@ CONFIG_NAND_ATMEL=y CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_DM_ETH=y CONFIG_MACB=y diff --git a/configs/sama5d3xek_mmc_defconfig b/configs/sama5d3xek_mmc_defconfig index 404af1f..98e0539 100644 --- a/configs/sama5d3xek_mmc_defconfig +++ b/configs/sama5d3xek_mmc_defconfig @@ -71,6 +71,7 @@ CONFIG_PMECC_CAP=4 CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_DM_ETH=y CONFIG_MACB=y diff --git a/configs/sama5d3xek_nandflash_defconfig b/configs/sama5d3xek_nandflash_defconfig index 0e36665..ddae1c8 100644 --- a/configs/sama5d3xek_nandflash_defconfig +++ b/configs/sama5d3xek_nandflash_defconfig @@ -65,6 +65,7 @@ CONFIG_PMECC_CAP=4 CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_DM_ETH=y CONFIG_MACB=y diff --git a/configs/sama5d3xek_spiflash_defconfig b/configs/sama5d3xek_spiflash_defconfig index 43db387..6724bea 100644 --- a/configs/sama5d3xek_spiflash_defconfig +++ b/configs/sama5d3xek_spiflash_defconfig @@ -66,6 +66,7 @@ CONFIG_PMECC_CAP=4 CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_DM_ETH=y CONFIG_MACB=y diff --git a/configs/sama5d4_xplained_mmc_defconfig b/configs/sama5d4_xplained_mmc_defconfig index cbfb645..e3f69dd 100644 --- a/configs/sama5d4_xplained_mmc_defconfig +++ b/configs/sama5d4_xplained_mmc_defconfig @@ -61,6 +61,7 @@ CONFIG_NAND_ATMEL=y CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_DM_ETH=y CONFIG_MACB=y diff --git a/configs/sama5d4_xplained_nandflash_defconfig b/configs/sama5d4_xplained_nandflash_defconfig index 38a8b1c..14a1b14 100644 --- a/configs/sama5d4_xplained_nandflash_defconfig +++ b/configs/sama5d4_xplained_nandflash_defconfig @@ -58,6 +58,7 @@ CONFIG_PMECC_CAP=8 CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_DM_ETH=y CONFIG_MACB=y diff --git a/configs/sama5d4_xplained_spiflash_defconfig b/configs/sama5d4_xplained_spiflash_defconfig index ef08339..829c530 100644 --- a/configs/sama5d4_xplained_spiflash_defconfig +++ b/configs/sama5d4_xplained_spiflash_defconfig @@ -62,6 +62,7 @@ CONFIG_PMECC_CAP=8 CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_DM_ETH=y CONFIG_MACB=y diff --git a/configs/sama5d4ek_mmc_defconfig b/configs/sama5d4ek_mmc_defconfig index a121af4..09cda6d 100644 --- a/configs/sama5d4ek_mmc_defconfig +++ b/configs/sama5d4ek_mmc_defconfig @@ -61,6 +61,7 @@ CONFIG_NAND_ATMEL=y CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_DM_ETH=y CONFIG_MACB=y diff --git a/configs/sama5d4ek_nandflash_defconfig b/configs/sama5d4ek_nandflash_defconfig index b830b8f..6ea0078 100644 --- a/configs/sama5d4ek_nandflash_defconfig +++ b/configs/sama5d4ek_nandflash_defconfig @@ -58,6 +58,7 @@ CONFIG_PMECC_CAP=8 CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_DM_ETH=y CONFIG_MACB=y diff --git a/configs/sama5d4ek_spiflash_defconfig b/configs/sama5d4ek_spiflash_defconfig index 87052d5..1d7de20 100644 --- a/configs/sama5d4ek_spiflash_defconfig +++ b/configs/sama5d4ek_spiflash_defconfig @@ -59,6 +59,7 @@ CONFIG_PMECC_CAP=8 CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ATMEL=y CONFIG_DM_ETH=y CONFIG_MACB=y diff --git a/configs/smdk5250_defconfig b/configs/smdk5250_defconfig index c86fde7..d24e9e2 100644 --- a/configs/smdk5250_defconfig +++ b/configs/smdk5250_defconfig @@ -34,6 +34,8 @@ CONFIG_MMC_DW=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_S5P=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=50000000 CONFIG_SPI_FLASH_GIGADEVICE=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SMC911X=y diff --git a/configs/smdk5420_defconfig b/configs/smdk5420_defconfig index e92472e..704786a 100644 --- a/configs/smdk5420_defconfig +++ b/configs/smdk5420_defconfig @@ -29,6 +29,8 @@ CONFIG_MMC_DW=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_S5P=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=50000000 CONFIG_SPI_FLASH_GIGADEVICE=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SMC911X=y diff --git a/configs/snow_defconfig b/configs/snow_defconfig index 86a668f..6179a64 100644 --- a/configs/snow_defconfig +++ b/configs/snow_defconfig @@ -44,6 +44,8 @@ CONFIG_MMC_DW=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_S5P=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=50000000 CONFIG_SPI_FLASH_GIGADEVICE=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SMC911X=y diff --git a/configs/socfpga_sr1500_defconfig b/configs/socfpga_sr1500_defconfig index d984047..b8de47a 100644 --- a/configs/socfpga_sr1500_defconfig +++ b/configs/socfpga_sr1500_defconfig @@ -53,6 +53,7 @@ CONFIG_DM_MMC=y CONFIG_MMC_DW=y CONFIG_MTD_DEVICE=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=100000000 CONFIG_SPI_FLASH_STMICRO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_PHY_MARVELL=y diff --git a/configs/socfpga_stratix10_defconfig b/configs/socfpga_stratix10_defconfig index 9e6d582..f0671dd 100644 --- a/configs/socfpga_stratix10_defconfig +++ b/configs/socfpga_stratix10_defconfig @@ -39,6 +39,7 @@ CONFIG_SYS_I2C_DW=y CONFIG_DM_MMC=y CONFIG_MMC_DW=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0x2003 CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set diff --git a/configs/spring_defconfig b/configs/spring_defconfig index c008428..2bbfa6d 100644 --- a/configs/spring_defconfig +++ b/configs/spring_defconfig @@ -44,6 +44,8 @@ CONFIG_MMC_DW=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_S5P=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=50000000 CONFIG_SPI_FLASH_GIGADEVICE=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SMC911X=y diff --git a/configs/stmark2_defconfig b/configs/stmark2_defconfig index 48e851d..d74ba67 100644 --- a/configs/stmark2_defconfig +++ b/configs/stmark2_defconfig @@ -23,6 +23,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y # CONFIG_NET is not set CONFIG_MTD_DEVICE=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=50000000 CONFIG_SPI_FLASH_ISSI=y CONFIG_SPI_FLASH_MTD=y CONFIG_SPI=y diff --git a/configs/tec-ng_defconfig b/configs/tec-ng_defconfig index 250d7f0..8839c7d 100644 --- a/configs/tec-ng_defconfig +++ b/configs/tec-ng_defconfig @@ -25,6 +25,8 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_DEFAULT_DEVICE_TREE="tegra30-tec-ng" CONFIG_SPL_DM=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y CONFIG_TEGRA20_SLINK=y diff --git a/configs/theadorable_debug_defconfig b/configs/theadorable_debug_defconfig index a7d02e9..cd52220 100644 --- a/configs/theadorable_debug_defconfig +++ b/configs/theadorable_debug_defconfig @@ -55,6 +55,7 @@ CONFIG_FPGA_ALTERA=y CONFIG_DM_GPIO=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=27777777 CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHY_MARVELL=y diff --git a/configs/tinker-rk3288_defconfig b/configs/tinker-rk3288_defconfig index 68adf76..85ef9da 100644 --- a/configs/tinker-rk3288_defconfig +++ b/configs/tinker-rk3288_defconfig @@ -55,6 +55,7 @@ CONFIG_I2C_EEPROM=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y diff --git a/configs/topic_miami_defconfig b/configs/topic_miami_defconfig index 352976b..5cfbbf8 100644 --- a/configs/topic_miami_defconfig +++ b/configs/topic_miami_defconfig @@ -38,6 +38,8 @@ CONFIG_SYS_I2C_CADENCE=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=108000000 CONFIG_SPI_FLASH_STMICRO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_DEBUG_UART_ZYNQ=y @@ -54,4 +56,3 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_FUNCTION_THOR=y -# CONFIG_REGEX is not set diff --git a/configs/topic_miamilite_defconfig b/configs/topic_miamilite_defconfig index 9b004ac..91d8499 100644 --- a/configs/topic_miamilite_defconfig +++ b/configs/topic_miamilite_defconfig @@ -38,6 +38,8 @@ CONFIG_SYS_I2C_CADENCE=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=108000000 CONFIG_SPI_FLASH_STMICRO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_DEBUG_UART_ZYNQ=y @@ -54,4 +56,3 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_FUNCTION_THOR=y -# CONFIG_REGEX is not set diff --git a/configs/topic_miamiplus_defconfig b/configs/topic_miamiplus_defconfig index e450557..bcfca5d 100644 --- a/configs/topic_miamiplus_defconfig +++ b/configs/topic_miamiplus_defconfig @@ -37,6 +37,8 @@ CONFIG_SYS_I2C_CADENCE=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=108000000 CONFIG_SPI_FLASH_STMICRO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set # CONFIG_NETDEVICES is not set diff --git a/configs/tqma6dl_mba6_mmc_defconfig b/configs/tqma6dl_mba6_mmc_defconfig index af72877..bc54005 100644 --- a/configs/tqma6dl_mba6_mmc_defconfig +++ b/configs/tqma6dl_mba6_mmc_defconfig @@ -34,6 +34,8 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=50000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/tqma6dl_mba6_spi_defconfig b/configs/tqma6dl_mba6_spi_defconfig index f69189b..58d08bf 100644 --- a/configs/tqma6dl_mba6_spi_defconfig +++ b/configs/tqma6dl_mba6_spi_defconfig @@ -35,6 +35,8 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=50000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/tqma6q_mba6_mmc_defconfig b/configs/tqma6q_mba6_mmc_defconfig index 744547b..b57cb81 100644 --- a/configs/tqma6q_mba6_mmc_defconfig +++ b/configs/tqma6q_mba6_mmc_defconfig @@ -33,6 +33,8 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=50000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/tqma6q_mba6_spi_defconfig b/configs/tqma6q_mba6_spi_defconfig index c99301e..c713fac 100644 --- a/configs/tqma6q_mba6_spi_defconfig +++ b/configs/tqma6q_mba6_spi_defconfig @@ -34,6 +34,8 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=50000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/tqma6s_mba6_mmc_defconfig b/configs/tqma6s_mba6_mmc_defconfig index 8d5f54c..d9d3ce9 100644 --- a/configs/tqma6s_mba6_mmc_defconfig +++ b/configs/tqma6s_mba6_mmc_defconfig @@ -34,6 +34,8 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=50000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/tqma6s_mba6_spi_defconfig b/configs/tqma6s_mba6_spi_defconfig index 3470a78..f793658 100644 --- a/configs/tqma6s_mba6_spi_defconfig +++ b/configs/tqma6s_mba6_spi_defconfig @@ -35,6 +35,8 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=50000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/configs/trimslice_defconfig b/configs/trimslice_defconfig index 71bfbfc..be6be27 100644 --- a/configs/trimslice_defconfig +++ b/configs/trimslice_defconfig @@ -26,6 +26,7 @@ CONFIG_DEFAULT_DEVICE_TREE="tegra20-trimslice" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPL_DM=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 CONFIG_SPI_FLASH_WINBOND=y CONFIG_RTL8169=y CONFIG_PCI=y diff --git a/configs/turris_mox_defconfig b/configs/turris_mox_defconfig index 165f0ca..5b168df 100644 --- a/configs/turris_mox_defconfig +++ b/configs/turris_mox_defconfig @@ -45,6 +45,8 @@ CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_XENON=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/uDPU_defconfig b/configs/uDPU_defconfig index 53f2b6e..2209330 100644 --- a/configs/uDPU_defconfig +++ b/configs/uDPU_defconfig @@ -56,6 +56,7 @@ CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_XENON=y CONFIG_MTD=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/venice2_defconfig b/configs/venice2_defconfig index 856398b..1b6118a 100644 --- a/configs/venice2_defconfig +++ b/configs/venice2_defconfig @@ -29,6 +29,8 @@ CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y CONFIG_TEGRA114_SPI=y diff --git a/configs/vinco_defconfig b/configs/vinco_defconfig index 0130ad4..5abc87e 100644 --- a/configs/vinco_defconfig +++ b/configs/vinco_defconfig @@ -28,6 +28,8 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91-vinco" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=50000000 CONFIG_ETH_DESIGNWARE=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/vyasa-rk3288_defconfig b/configs/vyasa-rk3288_defconfig index c4779c0..ab9bda0 100644 --- a/configs/vyasa-rk3288_defconfig +++ b/configs/vyasa-rk3288_defconfig @@ -50,6 +50,7 @@ CONFIG_LED_GPIO=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y diff --git a/configs/x530_defconfig b/configs/x530_defconfig index 25b9e88..cd18e9e 100644 --- a/configs/x530_defconfig +++ b/configs/x530_defconfig @@ -50,6 +50,8 @@ CONFIG_I2C_MUX_PCA954x=y CONFIG_NAND=y CONFIG_NAND_PXA3XX=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 +CONFIG_SF_DEFAULT_SPEED=50000000 CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/zc5202_defconfig b/configs/zc5202_defconfig index cca1f2d..c9b1255 100644 --- a/configs/zc5202_defconfig +++ b/configs/zc5202_defconfig @@ -35,6 +35,9 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=3 +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_MII=y CONFIG_PCI=y diff --git a/configs/zc5601_defconfig b/configs/zc5601_defconfig index cfe80b3..4b764bc 100644 --- a/configs/zc5601_defconfig +++ b/configs/zc5601_defconfig @@ -34,6 +34,9 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=3 +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_MII=y diff --git a/configs/zynq_cc108_defconfig b/configs/zynq_cc108_defconfig index 5f15d42..637fae5 100644 --- a/configs/zynq_cc108_defconfig +++ b/configs/zynq_cc108_defconfig @@ -33,6 +33,7 @@ CONFIG_DM_GPIO=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ISSI=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/zynq_cse_qspi_defconfig b/configs/zynq_cse_qspi_defconfig index 1f8aa6e..c58d649 100644 --- a/configs/zynq_cse_qspi_defconfig +++ b/configs/zynq_cse_qspi_defconfig @@ -56,6 +56,7 @@ CONFIG_DEFAULT_DEVICE_TREE="zynq-cse-qspi-single" CONFIG_SPL_DM_SEQ_ALIAS=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ISSI=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/zynq_dlc20_rev1_0_defconfig b/configs/zynq_dlc20_rev1_0_defconfig index c61010f..37c5f35 100644 --- a/configs/zynq_dlc20_rev1_0_defconfig +++ b/configs/zynq_dlc20_rev1_0_defconfig @@ -51,6 +51,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW=0x0 CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_PHY_REALTEK=y diff --git a/configs/zynq_microzed_defconfig b/configs/zynq_microzed_defconfig index bbf9fc0..0af0f23 100644 --- a/configs/zynq_microzed_defconfig +++ b/configs/zynq_microzed_defconfig @@ -39,6 +39,7 @@ CONFIG_DM_GPIO=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/zynq_minized_defconfig b/configs/zynq_minized_defconfig index b64f91f..d61659f 100644 --- a/configs/zynq_minized_defconfig +++ b/configs/zynq_minized_defconfig @@ -40,6 +40,7 @@ CONFIG_DM_GPIO=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/zynq_z_turn_defconfig b/configs/zynq_z_turn_defconfig index 9704b81..c896880 100644 --- a/configs/zynq_z_turn_defconfig +++ b/configs/zynq_z_turn_defconfig @@ -39,6 +39,7 @@ CONFIG_LED_GPIO=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/zynq_zc702_defconfig b/configs/zynq_zc702_defconfig index c9eb4d3..7b1b92d 100644 --- a/configs/zynq_zc702_defconfig +++ b/configs/zynq_zc702_defconfig @@ -53,6 +53,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW=0x0 CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ISSI=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/zynq_zc706_defconfig b/configs/zynq_zc706_defconfig index 9da1d54..f2ecdac 100644 --- a/configs/zynq_zc706_defconfig +++ b/configs/zynq_zc706_defconfig @@ -53,6 +53,7 @@ CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW=0x0 CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ISSI=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/zynq_zc770_xm010_defconfig b/configs/zynq_zc770_xm010_defconfig index bfff8af..8f74105 100644 --- a/configs/zynq_zc770_xm010_defconfig +++ b/configs/zynq_zc770_xm010_defconfig @@ -40,6 +40,7 @@ CONFIG_DM_GPIO=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ISSI=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/zynq_zc770_xm013_defconfig b/configs/zynq_zc770_xm013_defconfig index 996f46b..d43869c 100644 --- a/configs/zynq_zc770_xm013_defconfig +++ b/configs/zynq_zc770_xm013_defconfig @@ -34,6 +34,7 @@ CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_ISSI=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/zynq_zed_defconfig b/configs/zynq_zed_defconfig index fdaa5bb..cc21557 100644 --- a/configs/zynq_zed_defconfig +++ b/configs/zynq_zed_defconfig @@ -42,6 +42,7 @@ CONFIG_DM_GPIO=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/zynq_zybo_defconfig b/configs/zynq_zybo_defconfig index 9a4ac2d..496da8f 100644 --- a/configs/zynq_zybo_defconfig +++ b/configs/zynq_zybo_defconfig @@ -42,6 +42,7 @@ CONFIG_DM_GPIO=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_MARVELL=y CONFIG_PHY_REALTEK=y diff --git a/configs/zynq_zybo_z7_defconfig b/configs/zynq_zybo_z7_defconfig index 8cabaf1..e8437b4 100644 --- a/configs/zynq_zybo_z7_defconfig +++ b/configs/zynq_zybo_z7_defconfig @@ -42,6 +42,7 @@ CONFIG_DM_GPIO=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHY_REALTEK=y CONFIG_MII=y diff --git a/drivers/mtd/spi/Kconfig b/drivers/mtd/spi/Kconfig index e3b40fc..5671bca 100644 --- a/drivers/mtd/spi/Kconfig +++ b/drivers/mtd/spi/Kconfig @@ -36,6 +36,42 @@ config SPI_FLASH
If unsure, say N
+config SF_DEFAULT_BUS + int "SPI Flash default bus identifier" + depends on SPI_FLASH || DM_SPI_FLASH + default 0 + help + The default bus may be provided by the platform + to handle the common case when only a single serial + flash is present on the system. + +config SF_DEFAULT_CS + int "SPI Flash default Chip-select" + depends on SPI_FLASH || DM_SPI_FLASH + default 0 + help + The default chip select may be provided by the platform + to handle the common case when only a single serial + flash is present on the system. + +config SF_DEFAULT_MODE + hex "SPI Flash default mode (see include/spi.h)" + depends on SPI_FLASH || DM_SPI_FLASH + default 3 + help + The default mode may be provided by the platform + to handle the common case when only a single serial + flash is present on the system. + +config SF_DEFAULT_SPEED + int "SPI Flash default speed in Hz" + depends on SPI_FLASH || DM_SPI_FLASH + default 1000000 + help + The default speed may be provided by the platform + to handle the common case when only a single serial + flash is present on the system. + if SPI_FLASH
config SPI_FLASH_SFDP_SUPPORT diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index 252e127..3239696 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -509,8 +509,6 @@ unsigned long get_board_ddr_clk(void); /* * eSPI - Enhanced SPI */ -#define CONFIG_SF_DEFAULT_SPEED 10000000 -#define CONFIG_SF_DEFAULT_MODE 0
/* * MAPLE diff --git a/include/configs/BSC9131RDB.h b/include/configs/BSC9131RDB.h index 71e840a..49bea98 100644 --- a/include/configs/BSC9131RDB.h +++ b/include/configs/BSC9131RDB.h @@ -226,10 +226,6 @@ extern unsigned long get_sdram_size(void); #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5
/* eSPI - Enhanced SPI */ -#ifdef CONFIG_FSL_ESPI -#define CONFIG_SF_DEFAULT_SPEED 10000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 -#endif
#if defined(CONFIG_TSEC_ENET)
diff --git a/include/configs/BSC9132QDS.h b/include/configs/BSC9132QDS.h index 49bb382..45264c4 100644 --- a/include/configs/BSC9132QDS.h +++ b/include/configs/BSC9132QDS.h @@ -407,10 +407,6 @@ combinations. this should be removed later * used for SLIC */ /* eSPI - Enhanced SPI */ -#ifdef CONFIG_FSL_ESPI -#define CONFIG_SF_DEFAULT_SPEED 10000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 -#endif
diff --git a/include/configs/C29XPCIE.h b/include/configs/C29XPCIE.h index ebf44b5..a18d041 100644 --- a/include/configs/C29XPCIE.h +++ b/include/configs/C29XPCIE.h @@ -357,8 +357,6 @@ #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5
/* eSPI - Enhanced SPI */ -#define CONFIG_SF_DEFAULT_SPEED 10000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0
#ifdef CONFIG_TSEC_ENET #define CONFIG_MII_DEFAULT_TSEC 1 /* Allow unregistered phys */ diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 86a1233..fedd151 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -370,11 +370,6 @@ #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 #define CONFIG_SYS_EEPROM_BUS_NUM 1
-#if defined(CONFIG_SPI_FLASH) -#define CONFIG_SF_DEFAULT_SPEED 10000000 -#define CONFIG_SF_DEFAULT_MODE 0 -#endif - /* * General PCI * Memory space is mapped 1-1, but I/O space must start from 0. diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 134ffe5..cefa598 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -573,8 +573,6 @@ extern unsigned long get_sdram_size(void); */ #if !defined(CONFIG_NAND) || !defined(CONFIG_NAND_SECBOOT) /* eSPI - Enhanced SPI */ -#define CONFIG_SF_DEFAULT_SPEED 10000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 #endif
#if defined(CONFIG_TSEC_ENET) diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index 3ccfeca..8bdbabe 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -388,9 +388,6 @@ #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 #define CONFIG_SYS_EEPROM_BUS_NUM 1
-#define CONFIG_SF_DEFAULT_SPEED 10000000 -#define CONFIG_SF_DEFAULT_MODE 0 - /* * General PCI * Memory space is mapped 1-1, but I/O space must start from 0. diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index bd2913e..da43320 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -350,8 +350,6 @@ unsigned long get_board_sys_clk(unsigned long dummy); /* * eSPI - Enhanced SPI */ -#define CONFIG_SF_DEFAULT_SPEED 10000000 -#define CONFIG_SF_DEFAULT_MODE 0
/* * General PCI diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index c63dfd3..73b70fa 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -501,8 +501,6 @@ unsigned long get_board_ddr_clk(void); /* * eSPI - Enhanced SPI */ -#define CONFIG_SF_DEFAULT_SPEED 10000000 -#define CONFIG_SF_DEFAULT_MODE 0
/* * General PCIe diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index c72be9f..078df7f 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -498,8 +498,6 @@ unsigned long get_board_ddr_clk(void); /* * eSPI - Enhanced SPI */ -#define CONFIG_SF_DEFAULT_SPEED 10000000 -#define CONFIG_SF_DEFAULT_MODE 0
/* * General PCIe diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index 2d5c96f..c886fe2 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -416,8 +416,6 @@ unsigned long get_board_ddr_clk(void); /* * eSPI - Enhanced SPI */ -#define CONFIG_SF_DEFAULT_SPEED 10000000 -#define CONFIG_SF_DEFAULT_MODE 0
/* * General PCI diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 4cecab3..0d92f27 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -521,8 +521,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg /* * eSPI - Enhanced SPI */ -#define CONFIG_SF_DEFAULT_SPEED 10000000 -#define CONFIG_SF_DEFAULT_MODE 0 #define CONFIG_ENV_SPI_BUS 0 #define CONFIG_ENV_SPI_CS 0 #define CONFIG_ENV_SPI_MAX_HZ 10000000 diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 69ec109..9864064 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -495,11 +495,6 @@ unsigned long get_board_ddr_clk(void); /* * eSPI - Enhanced SPI */ -#ifdef CONFIG_SPI_FLASH - -#define CONFIG_SF_DEFAULT_SPEED 10000000 -#define CONFIG_SF_DEFAULT_MODE 0 -#endif
/* * General PCI diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 1d6a390..95e9ed3 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -436,10 +436,6 @@ unsigned long get_board_ddr_clk(void); /* * eSPI - Enhanced SPI */ -#ifdef CONFIG_SPI_FLASH -#define CONFIG_SF_DEFAULT_SPEED 10000000 -#define CONFIG_SF_DEFAULT_MODE 0 -#endif
/* * General PCI diff --git a/include/configs/T4240QDS.h b/include/configs/T4240QDS.h index 0693901..80a4b13 100644 --- a/include/configs/T4240QDS.h +++ b/include/configs/T4240QDS.h @@ -362,8 +362,6 @@ unsigned long get_board_ddr_clk(void); /* * eSPI - Enhanced SPI */ -#define CONFIG_SF_DEFAULT_SPEED 10000000 -#define CONFIG_SF_DEFAULT_MODE 0
/* Qman/Bman */ #ifndef CONFIG_NOBQFMAN diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index 42252c7..066e8dd 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -508,8 +508,6 @@ unsigned long get_board_ddr_clk(void); /* * eSPI - Enhanced SPI */ -#define CONFIG_SF_DEFAULT_SPEED 10000000 -#define CONFIG_SF_DEFAULT_MODE 0
/* Qman/Bman */ #ifndef CONFIG_NOBQFMAN diff --git a/include/configs/UCP1020.h b/include/configs/UCP1020.h index 1bbe9d9..69d43c4 100644 --- a/include/configs/UCP1020.h +++ b/include/configs/UCP1020.h @@ -287,9 +287,6 @@ #define CONFIG_SYS_I2C_NCT72_ADDR 0x4C #define CONFIG_SYS_I2C_IDT6V49205B 0x69
-#define CONFIG_SF_DEFAULT_SPEED 10000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 - #if defined(CONFIG_PCI) /* * General PCI diff --git a/include/configs/adp-ae3xx.h b/include/configs/adp-ae3xx.h index 915f416..f2268dc 100644 --- a/include/configs/adp-ae3xx.h +++ b/include/configs/adp-ae3xx.h @@ -212,10 +212,6 @@
/* SPI FLASH */ -#define CONFIG_SF_DEFAULT_BUS 0 -#define CONFIG_SF_DEFAULT_CS 0 -#define CONFIG_SF_DEFAULT_SPEED 1000000 -#define CONFIG_SF_DEFAULT_MODE 0
/* * For booting Linux, the board info and command line data diff --git a/include/configs/advantech_dms-ba16.h b/include/configs/advantech_dms-ba16.h index 0c9de61..a08f62b 100644 --- a/include/configs/advantech_dms-ba16.h +++ b/include/configs/advantech_dms-ba16.h @@ -63,12 +63,6 @@ #define CONFIG_PHY_ATHEROS
/* Serial Flash */ -#ifdef CONFIG_CMD_SF -#define CONFIG_SF_DEFAULT_BUS 0 -#define CONFIG_SF_DEFAULT_CS 0 -#define CONFIG_SF_DEFAULT_SPEED 20000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 -#endif
/* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 3bd96b9..d8f0583 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -306,7 +306,6 @@ #endif
/* SPI flash. */ -#define CONFIG_SF_DEFAULT_SPEED 24000000
/* Network. */ #define CONFIG_PHY_SMSC diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index ed71f4c..55faa7b 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -124,8 +124,6 @@ /* SPI */ #define CONFIG_TI_SPI_MMAP #define CONFIG_QSPI_SEL_GPIO 48 -#define CONFIG_SF_DEFAULT_SPEED 48000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_3 #define CONFIG_QSPI_QUAD_SUPPORT #define CONFIG_TI_EDMA3
diff --git a/include/configs/am57xx_evm.h b/include/configs/am57xx_evm.h index d61fdf9..24e2d7e 100644 --- a/include/configs/am57xx_evm.h +++ b/include/configs/am57xx_evm.h @@ -86,8 +86,6 @@
/* SPI */ #define CONFIG_TI_SPI_MMAP -#define CONFIG_SF_DEFAULT_SPEED 76800000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 #define CONFIG_QSPI_QUAD_SUPPORT
#endif /* __CONFIG_AM57XX_EVM_H */ diff --git a/include/configs/aristainetos-common.h b/include/configs/aristainetos-common.h index ca974c0..eecc021 100644 --- a/include/configs/aristainetos-common.h +++ b/include/configs/aristainetos-common.h @@ -31,8 +31,6 @@ #define CONFIG_FEC_MXC_PHYADDR 0
#define CONFIG_SPI_FLASH_MTD -#define CONFIG_SF_DEFAULT_SPEED 20000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 #define CONFIG_SYS_SPI_ST_ENABLE_WP_PIN
#define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/aristainetos.h b/include/configs/aristainetos.h index c53ba89..03e2a2b 100644 --- a/include/configs/aristainetos.h +++ b/include/configs/aristainetos.h @@ -21,9 +21,6 @@
#define CONFIG_FEC_XCV_TYPE RMII
-#define CONFIG_SF_DEFAULT_BUS 3 -#define CONFIG_SF_DEFAULT_CS 0 - #define CONFIG_EXTRA_ENV_BOARD_SETTINGS \ "board_type=aristainetos7@1\0" \ "mtdids=nand0=gpmi-nand,nor0=spi3.0\0" \ diff --git a/include/configs/aristainetos2.h b/include/configs/aristainetos2.h index 67b2e58..00e5667 100644 --- a/include/configs/aristainetos2.h +++ b/include/configs/aristainetos2.h @@ -20,9 +20,6 @@
#define CONFIG_FEC_XCV_TYPE RGMII
-#define CONFIG_SF_DEFAULT_BUS 3 -#define CONFIG_SF_DEFAULT_CS 1 - #define CONFIG_EXTRA_ENV_BOARD_SETTINGS \ "board_type=aristainetos2_7@1\0" \ "nor_bootdelay=-2\0" \ diff --git a/include/configs/aristainetos2b.h b/include/configs/aristainetos2b.h index 91069a2..cfe0e05 100644 --- a/include/configs/aristainetos2b.h +++ b/include/configs/aristainetos2b.h @@ -20,9 +20,6 @@
-#define CONFIG_SF_DEFAULT_BUS 0 -#define CONFIG_SF_DEFAULT_CS 0 - #define CONFIG_EXTRA_ENV_BOARD_SETTINGS \ "board_type=aristainetos2_7@1\0" \ "nor_bootdelay=-2\0" \ diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index 777a99b..d83546d 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -45,9 +45,6 @@ (0x00300000 + 16 * 1024 - GENERATED_GBL_DATA_SIZE)
/* DataFlash */ -#ifdef CONFIG_CMD_SF -#define CONFIG_SF_DEFAULT_SPEED 30000000 -#endif
/* NAND flash */ #ifdef CONFIG_CMD_NAND diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index 6adb965..d43d408 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -38,9 +38,6 @@ (CONFIG_SYS_SDRAM_BASE + 16 * 1024 - GENERATED_GBL_DATA_SIZE)
/* NAND flash */ #ifdef CONFIG_CMD_NAND diff --git a/include/configs/ax25-ae350.h b/include/configs/ax25-ae350.h index e3eb928..cd07212 100644 --- a/include/configs/ax25-ae350.h +++ b/include/configs/ax25-ae350.h @@ -121,10 +121,6 @@ #define CONFIG_ENV_OVERWRITE
/* * For booting Linux, the board info and command line data diff --git a/include/configs/bav335x.h b/include/configs/bav335x.h index df5d5bd..8936222 100644 --- a/include/configs/bav335x.h +++ b/include/configs/bav335x.h @@ -466,7 +466,6 @@ DEFAULT_LINUX_BOOT_ENV \ #endif
/* Network. */ #define CONFIG_PHY_SMSC diff --git a/include/configs/beaver.h b/include/configs/beaver.h index 73629dd..6c6f11b 100644 --- a/include/configs/beaver.h +++ b/include/configs/beaver.h @@ -32,8 +32,6 @@
/* SPI */ #define CONFIG_TEGRA_SLINK_CTRLS 6 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 -#define CONFIG_SF_DEFAULT_SPEED 24000000 #define CONFIG_SPI_FLASH_SIZE (4 << 20)
/* USB Host support */ diff --git a/include/configs/bg0900.h b/include/configs/bg0900.h index ec6b01f..32b975f 100644 --- a/include/configs/bg0900.h +++ b/include/configs/bg0900.h @@ -26,11 +26,6 @@
/* SPI FLASH */ #ifdef CONFIG_CMD_SF -#define CONFIG_SF_DEFAULT_BUS 2 -#define CONFIG_SF_DEFAULT_CS 0 -#define CONFIG_SF_DEFAULT_SPEED 40000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 - #define CONFIG_ENV_SPI_BUS 2 #define CONFIG_ENV_SPI_CS 0 #define CONFIG_ENV_SPI_MAX_HZ 40000000 diff --git a/include/configs/brppt1.h b/include/configs/brppt1.h index 5badd2d..2219663 100644 --- a/include/configs/brppt1.h +++ b/include/configs/brppt1.h @@ -187,7 +187,6 @@ NANDTGTS \
#if defined(CONFIG_SPI) /* SPI Flash */ -#define CONFIG_SF_DEFAULT_SPEED 24000000 #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x40000 /* Environment */ #define CONFIG_SYS_REDUNDAND_ENVIRONMENT diff --git a/include/configs/cardhu.h b/include/configs/cardhu.h index dcb66a6..93fa2c2 100644 --- a/include/configs/cardhu.h +++ b/include/configs/cardhu.h @@ -36,8 +36,6 @@
/* USB Host support */ diff --git a/include/configs/cei-tk1-som.h b/include/configs/cei-tk1-som.h index 1400844..edd4df8 100644 --- a/include/configs/cei-tk1-som.h +++ b/include/configs/cei-tk1-som.h @@ -31,8 +31,6 @@ #define CONFIG_SYS_MMC_ENV_PART 2
/* SPI */ -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 -#define CONFIG_SF_DEFAULT_SPEED 24000000 #define CONFIG_SPI_FLASH_SIZE (4 << 20)
/* USB Host support */ diff --git a/include/configs/cgtqmx6eval.h b/include/configs/cgtqmx6eval.h index e01bf5b..ab8d1c6 100644 --- a/include/configs/cgtqmx6eval.h +++ b/include/configs/cgtqmx6eval.h @@ -33,9 +33,6 @@ /* SPI NOR */ #define CONFIG_SPI_FLASH_STMICRO #define CONFIG_SPI_FLASH_SST -#define CONFIG_SF_DEFAULT_BUS 0 -#define CONFIG_SF_DEFAULT_SPEED 20000000 -#define CONFIG_SF_DEFAULT_MODE (SPI_MODE_0)
/* Thermal support */ #define CONFIG_IMX_THERMAL diff --git a/include/configs/cl-som-am57x.h b/include/configs/cl-som-am57x.h index 80f0b4f..c9e80c2 100644 --- a/include/configs/cl-som-am57x.h +++ b/include/configs/cl-som-am57x.h @@ -27,7 +27,6 @@
/* SPI Flash support */ #define CONFIG_TI_SPI_MMAP -#define CONFIG_SF_DEFAULT_SPEED 48000000 #define CONFIG_DEFAULT_SPI_MODE SPI_MODE_3
/* SPI SPL defines */ diff --git a/include/configs/cl-som-imx7.h b/include/configs/cl-som-imx7.h index f84a112..d895f89 100644 --- a/include/configs/cl-som-imx7.h +++ b/include/configs/cl-som-imx7.h @@ -140,10 +140,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* SPI Flash support */ -#define CONFIG_SF_DEFAULT_BUS 0 -#define CONFIG_SF_DEFAULT_CS 0 -#define CONFIG_SF_DEFAULT_SPEED 20000000 -#define CONFIG_SF_DEFAULT_MODE (SPI_MODE_0)
/* FLASH and environment organization */ #define CONFIG_ENV_SIZE SZ_8K diff --git a/include/configs/clearfog.h b/include/configs/clearfog.h index f951082..c51cf28 100644 --- a/include/configs/clearfog.h +++ b/include/configs/clearfog.h @@ -22,7 +22,6 @@ */
/* SPI NOR flash default params, used by sf commands */ -#define CONFIG_SF_DEFAULT_BUS 1
/* * SDIO/MMC Card Configuration diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index f7e82df..2ac888f 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -39,10 +39,6 @@ #define CONFIG_SYS_BAUDRATE_TABLE {9600, 19200, 38400, 57600, 115200}
/* SPI flash */ -#define CONFIG_SF_DEFAULT_BUS 0 -#define CONFIG_SF_DEFAULT_CS 0 -#define CONFIG_SF_DEFAULT_SPEED 25000000 -#define CONFIG_SF_DEFAULT_MODE (SPI_MODE_0)
/* MTD support */ #ifndef CONFIG_SPL_BUILD diff --git a/include/configs/cm_t43.h b/include/configs/cm_t43.h index 79eb865..6df8b8b 100644 --- a/include/configs/cm_t43.h +++ b/include/configs/cm_t43.h @@ -55,8 +55,6 @@
/* SPI Flash support */ #define CONFIG_TI_SPI_MMAP -#define CONFIG_SF_DEFAULT_SPEED 48000000 -#define CONFIG_DEFAULT_SPI_MODE SPI_MODE_3
/* Power */ #define CONFIG_POWER diff --git a/include/configs/controlcenterd.h b/include/configs/controlcenterd.h index 1908d35..69c65f1 100644 --- a/include/configs/controlcenterd.h +++ b/include/configs/controlcenterd.h @@ -181,12 +181,6 @@ #define CONFIG_SYS_I2C_EEPROM_ADDR 0x52 #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2
-#ifndef CONFIG_TRAILBLAZER - -#define CONFIG_SF_DEFAULT_SPEED 10000000 -#define CONFIG_SF_DEFAULT_MODE 0 -#endif - /* * MMC */ diff --git a/include/configs/controlcenterdc.h b/include/configs/controlcenterdc.h index 2433815..edd8749 100644 --- a/include/configs/controlcenterdc.h +++ b/include/configs/controlcenterdc.h @@ -25,11 +25,6 @@
#define CONFIG_LOADADDR 1000000
-/* SPI NOR flash default params, used by sf commands */ -#define CONFIG_SF_DEFAULT_BUS 1 -#define CONFIG_SF_DEFAULT_SPEED 1000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_3 - /* * SDIO/MMC Card Configuration */ diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index cd79150..a3963db 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -358,8 +358,6 @@ /* * eSPI - Enhanced SPI */ -#define CONFIG_SF_DEFAULT_SPEED 10000000 -#define CONFIG_SF_DEFAULT_MODE 0
/* * General PCI diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 14a3046..7b1e53f 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -123,7 +123,6 @@ #define CONFIG_SYS_SPI_CLK clk_get(DAVINCI_SPI1_CLKID) #ifdef CONFIG_SPL_BUILD #define CONFIG_SYS_SPI_BASE DAVINCI_SPI1_BASE -#define CONFIG_SF_DEFAULT_SPEED 30000000 #endif #define CONFIG_ENV_SPI_MAX_HZ 0 #define CONFIG_ENV_SPI_MODE 0 diff --git a/include/configs/dalmore.h b/include/configs/dalmore.h index 9a8b5a7..bd68d52 100644 --- a/include/configs/dalmore.h +++ b/include/configs/dalmore.h @@ -28,8 +28,6 @@ #define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE)
/* USB Host support */ diff --git a/include/configs/db-88f6720.h b/include/configs/db-88f6720.h index 4c30077..55968c2 100644 --- a/include/configs/db-88f6720.h +++ b/include/configs/db-88f6720.h @@ -33,8 +33,6 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 3
/* SPI NOR flash default params, used by sf commands */ -#define CONFIG_SF_DEFAULT_SPEED 1000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_3
/* Environment in SPI NOR flash */ #define CONFIG_ENV_OFFSET (1 << 20) /* 1MiB in */ diff --git a/include/configs/db-88f6820-amc.h b/include/configs/db-88f6820-amc.h index 626a406..222bdf8 100644 --- a/include/configs/db-88f6820-amc.h +++ b/include/configs/db-88f6820-amc.h @@ -17,9 +17,6 @@ */
/* USB/EHCI configuration */ #define CONFIG_EHCI_IS_TDI diff --git a/include/configs/db-88f6820-gp.h b/include/configs/db-88f6820-gp.h index 1f328e9..967b133 100644 --- a/include/configs/db-88f6820-gp.h +++ b/include/configs/db-88f6820-gp.h @@ -30,8 +30,6 @@ #define CONFIG_ENV_SPI_CS 0
/* * SDIO/MMC Card Configuration diff --git a/include/configs/db-mv784mp-gp.h b/include/configs/db-mv784mp-gp.h index 6cba326..b78dbcb 100644 --- a/include/configs/db-mv784mp-gp.h +++ b/include/configs/db-mv784mp-gp.h @@ -30,8 +30,6 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 3
/* Environment in SPI NOR flash */ #define CONFIG_ENV_OFFSET (1 << 20) /* 1MiB in */ diff --git a/include/configs/dh_imx6.h b/include/configs/dh_imx6.h index 9231bd8..1c1178c3 100644 --- a/include/configs/dh_imx6.h +++ b/include/configs/dh_imx6.h @@ -76,12 +76,6 @@ #endif
/* SPI Flash Configs */ -#ifdef CONFIG_CMD_SF -#define CONFIG_SF_DEFAULT_BUS 0 -#define CONFIG_SF_DEFAULT_CS 0 -#define CONFIG_SF_DEFAULT_SPEED 25000000 -#define CONFIG_SF_DEFAULT_MODE (SPI_MODE_0) -#endif
/* UART */ #define CONFIG_MXC_UART diff --git a/include/configs/display5.h b/include/configs/display5.h index 1fb7469..d729054 100644 --- a/include/configs/display5.h +++ b/include/configs/display5.h @@ -59,12 +59,6 @@ #define CONFIG_MXC_UART_BASE UART5_BASE
/* SPI NOR Flash */ -#ifdef CONFIG_CMD_SF -#define CONFIG_SF_DEFAULT_BUS 1 -#define CONFIG_SF_DEFAULT_CS (0 | (IMX_GPIO_NR(5, 29) << 8)) -#define CONFIG_SF_DEFAULT_SPEED 50000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 -#endif
/* I2C Configs */ #define CONFIG_SYS_I2C diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index f36a9c3..36e1582 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -74,8 +74,6 @@
/* diff --git a/include/configs/ds414.h b/include/configs/ds414.h index 4ba0505..275a2b4 100644 --- a/include/configs/ds414.h +++ b/include/configs/ds414.h @@ -29,8 +29,6 @@ #define CONFIG_SYS_I2C_SPEED 100000
/* Environment in SPI NOR flash */ #define CONFIG_ENV_OFFSET 0x7E0000 /* RedBoot config partition in DTS */ diff --git a/include/configs/e2220-1170.h b/include/configs/e2220-1170.h index dd7a012..097199d 100644 --- a/include/configs/e2220-1170.h +++ b/include/configs/e2220-1170.h @@ -26,8 +26,6 @@ #define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE)
/* USB2.0 Host support */ diff --git a/include/configs/ea20.h b/include/configs/ea20.h index a644e67..800ce03 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -52,7 +52,6 @@
#define CONFIG_SYS_SPI_BASE DAVINCI_SPI1_BASE #define CONFIG_SYS_SPI_CLK clk_get(DAVINCI_SPI1_CLKID) -#define CONFIG_SF_DEFAULT_SPEED 30000000 #define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED
/* diff --git a/include/configs/el6x_common.h b/include/configs/el6x_common.h index b472a6c..bf70ea0 100644 --- a/include/configs/el6x_common.h +++ b/include/configs/el6x_common.h @@ -43,10 +43,6 @@ #define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08
/* Commands */ -#define CONFIG_SF_DEFAULT_BUS 3 -#define CONFIG_SF_DEFAULT_CS 0 -#define CONFIG_SF_DEFAULT_SPEED 20000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0
/* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE diff --git a/include/configs/embestmx6boards.h b/include/configs/embestmx6boards.h index 7e7de4d..f984540 100644 --- a/include/configs/embestmx6boards.h +++ b/include/configs/embestmx6boards.h @@ -49,13 +49,6 @@
-#ifdef CONFIG_CMD_SF -#define CONFIG_SF_DEFAULT_BUS 0 -#define CONFIG_SF_DEFAULT_CS 0 -#define CONFIG_SF_DEFAULT_SPEED 20000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 -#endif - #define CONFIG_ARP_TIMEOUT 200UL
#define CONFIG_SYS_MEMTEST_START 0x10000000 diff --git a/include/configs/exynos5-common.h b/include/configs/exynos5-common.h index cd2a904..5641f09 100644 --- a/include/configs/exynos5-common.h +++ b/include/configs/exynos5-common.h @@ -108,10 +108,6 @@ #define CONFIG_SYS_I2C_S3C24X0_SLAVE 0x0
/* SPI */ -#ifdef CONFIG_SPI_FLASH -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 -#define CONFIG_SF_DEFAULT_SPEED 50000000 -#endif
#ifdef CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SPI_MODE SPI_MODE_0 diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index e0e1f71..9ca3ee3 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -71,12 +71,6 @@ #endif
/* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index 6e23fa2..a4215c8 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -52,11 +52,7 @@ /* SPI */ #ifdef CONFIG_CMD_SF #define CONFIG_SPI_FLASH_MTD - #define CONFIG_SF_DEFAULT_BUS 0 - #define CONFIG_SF_DEFAULT_CS 0 /* GPIO 3-19 (21248) */ - #define CONFIG_SF_DEFAULT_SPEED 30000000 - #define CONFIG_SF_DEFAULT_MODE (SPI_MODE_0) #endif
#elif defined(CONFIG_SPL_NAND_SUPPORT) diff --git a/include/configs/helios4.h b/include/configs/helios4.h index 4e98f19..5a11641 100644 --- a/include/configs/helios4.h +++ b/include/configs/helios4.h @@ -24,10 +24,6 @@ */
/* SPI NOR flash default params, used by sf commands */ -#define CONFIG_SF_DEFAULT_BUS 1 -#define CONFIG_SF_DEFAULT_CS 0 -#define CONFIG_SF_DEFAULT_SPEED 104000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_3
/* * SDIO/MMC Card Configuration diff --git a/include/configs/jetson-tk1.h b/include/configs/jetson-tk1.h index 93fcdd6..69f519e 100644 --- a/include/configs/jetson-tk1.h +++ b/include/configs/jetson-tk1.h @@ -27,8 +27,6 @@ #define CONFIG_SYS_MMC_ENV_PART 2
/* USB Host support */ diff --git a/include/configs/k2g_evm.h b/include/configs/k2g_evm.h index 90f9a99..b1aec98 100644 --- a/include/configs/k2g_evm.h +++ b/include/configs/k2g_evm.h @@ -86,9 +86,6 @@
#define CONFIG_ENV_SIZE (256 << 10) /* 256 KiB */
-#define CONFIG_SF_DEFAULT_BUS 1 -#define CONFIG_SF_DEFAULT_CS 0 - #ifndef CONFIG_SPL_BUILD #define CONFIG_CADENCE_QSPI #define CONFIG_CQSPI_REF_CLK 384000000 diff --git a/include/configs/km/km_arm.h b/include/configs/km/km_arm.h index 0de83f6..f93629e 100644 --- a/include/configs/km/km_arm.h +++ b/include/configs/km/km_arm.h @@ -33,8 +33,6 @@ #include "keymile-common.h"
/* SPI NOR Flash default params, used by sf commands */ -#define CONFIG_SF_DEFAULT_SPEED 8100000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_3
#if defined CONFIG_KM_ENV_IS_IN_SPI_NOR #define CONFIG_ENV_SPI_BUS 0 diff --git a/include/configs/km/kmp204x-common.h b/include/configs/km/kmp204x-common.h index c762c93..810d66a 100644 --- a/include/configs/km/kmp204x-common.h +++ b/include/configs/km/kmp204x-common.h @@ -253,8 +253,6 @@ int get_scl(void); /* * eSPI - Enhanced SPI */ -#define CONFIG_SF_DEFAULT_SPEED 20000000 -#define CONFIG_SF_DEFAULT_MODE 0
/* * General PCI diff --git a/include/configs/legoev3.h b/include/configs/legoev3.h index c631e26..ce806d1 100644 --- a/include/configs/legoev3.h +++ b/include/configs/legoev3.h @@ -47,7 +47,6 @@
#define CONFIG_SYS_SPI_BASE DAVINCI_SPI0_BASE #define CONFIG_SYS_SPI_CLK clk_get(DAVINCI_SPI0_CLKID) -#define CONFIG_SF_DEFAULT_SPEED 50000000 #define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED
/* diff --git a/include/configs/ls1012aqds.h b/include/configs/ls1012aqds.h index c76bfdc..aac782d 100644 --- a/include/configs/ls1012aqds.h +++ b/include/configs/ls1012aqds.h @@ -99,11 +99,6 @@ DSPI_CTAR_DT(0)) #define CONFIG_SPI_FLASH_EON /* cs3 */
-#define CONFIG_SF_DEFAULT_SPEED 10000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 -#define CONFIG_SF_DEFAULT_BUS 1 -#define CONFIG_SF_DEFAULT_CS 0 - /* MMC */ #ifdef CONFIG_MMC #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 49b0141..b34c765 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -174,10 +174,6 @@ #define CONFIG_SPI_FLASH_STMICRO /* cs0 */ #define CONFIG_SPI_FLASH_SST /* cs1 */ #define CONFIG_SPI_FLASH_EON /* cs2 */ -#if !defined(CONFIG_QSPI_BOOT) && !defined(CONFIG_SD_BOOT_QSPI) -#define CONFIG_SF_DEFAULT_BUS 1 -#define CONFIG_SF_DEFAULT_CS 0 -#endif #endif #endif
diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index 886fe72..92159fe 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -43,10 +43,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SPI_FLASH_STMICRO /* cs0 */ #define CONFIG_SPI_FLASH_SST /* cs1 */ #define CONFIG_SPI_FLASH_EON /* cs2 */ -#if !defined(CONFIG_QSPI_BOOT) && !defined(CONFIG_SD_BOOT_QSPI) -#define CONFIG_SF_DEFAULT_BUS 1 -#define CONFIG_SF_DEFAULT_CS 0 -#endif #endif
/* QSPI */ diff --git a/include/configs/ls1088aqds.h b/include/configs/ls1088aqds.h index 17d543d..4387862 100644 --- a/include/configs/ls1088aqds.h +++ b/include/configs/ls1088aqds.h @@ -384,8 +384,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SPI_FLASH_EON #if !defined(CONFIG_TFABOOT) && \ !defined(CONFIG_QSPI_BOOT) && !defined(CONFIG_SD_BOOT_QSPI) -#define CONFIG_SF_DEFAULT_BUS 1 -#define CONFIG_SF_DEFAULT_CS 0 #endif #endif
diff --git a/include/configs/lsxl.h b/include/configs/lsxl.h index 9d4be18..bcad8a0 100644 --- a/include/configs/lsxl.h +++ b/include/configs/lsxl.h @@ -48,8 +48,6 @@ /* ST M25P40 */ #undef CONFIG_ENV_SPI_MAX_HZ #define CONFIG_ENV_SPI_MAX_HZ 25000000 -#undef CONFIG_SF_DEFAULT_SPEED -#define CONFIG_SF_DEFAULT_SPEED 25000000
/* * Environment variables configurations diff --git a/include/configs/maxbcm.h b/include/configs/maxbcm.h index d378333..fada0ca 100644 --- a/include/configs/maxbcm.h +++ b/include/configs/maxbcm.h @@ -29,8 +29,6 @@ #define CONFIG_SYS_I2C_SPEED 100000
/* Environment in SPI NOR flash */ #define CONFIG_ENV_OFFSET (1 << 20) /* 1MiB in */ diff --git a/include/configs/mccmon6.h b/include/configs/mccmon6.h index 644f339..a1774c0 100644 --- a/include/configs/mccmon6.h +++ b/include/configs/mccmon6.h @@ -43,11 +43,6 @@ #define CONFIG_SYS_MEMTEST_START 0x10000000 #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 500 * SZ_1M)
-#define CONFIG_SF_DEFAULT_BUS 2 -#define CONFIG_SF_DEFAULT_CS 0 -#define CONFIG_SF_DEFAULT_SPEED 25000000 -#define CONFIG_SF_DEFAULT_MODE (SPI_MODE_0) - /* I2C Configs */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index ba0952c..d81194b 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -81,10 +81,6 @@ #else /* !FLASH */
#ifdef SPIFLASH -# define CONFIG_SF_DEFAULT_MODE SPI_MODE_3 -# define CONFIG_SF_DEFAULT_SPEED XILINX_SPI_FLASH_MAX_FREQ -# define CONFIG_SF_DEFAULT_CS XILINX_SPI_FLASH_CS - # ifdef RAMENV # define CONFIG_ENV_SIZE 0x1000 # define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SIZE) diff --git a/include/configs/mvebu_armada-37xx.h b/include/configs/mvebu_armada-37xx.h index cf9440f..e898133 100644 --- a/include/configs/mvebu_armada-37xx.h +++ b/include/configs/mvebu_armada-37xx.h @@ -61,8 +61,6 @@ #define CONFIG_ENV_SPI_CS 0
/* SPI NOR flash default params, used by sf commands */ -#define CONFIG_SF_DEFAULT_SPEED 1000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 #define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE #define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ #define CONFIG_MTD_PARTITIONS /* required for UBI partition support */ diff --git a/include/configs/mvebu_armada-8k.h b/include/configs/mvebu_armada-8k.h index a6636e1..51f484d 100644 --- a/include/configs/mvebu_armada-8k.h +++ b/include/configs/mvebu_armada-8k.h @@ -56,8 +56,6 @@ #define CONFIG_ENV_SPI_CS 0
#define CONFIG_ENV_OFFSET 0x180000 /* as Marvell U-Boot version */ diff --git a/include/configs/mx28evk.h b/include/configs/mx28evk.h index 1117139..82ac6cc 100644 --- a/include/configs/mx28evk.h +++ b/include/configs/mx28evk.h @@ -78,16 +78,6 @@ #ifdef CONFIG_CMD_SPI #define CONFIG_DEFAULT_SPI_BUS 2 #define CONFIG_DEFAULT_SPI_MODE SPI_MODE_0 - -/* SPI Flash */ -#ifdef CONFIG_CMD_SF -#define CONFIG_SF_DEFAULT_BUS 2 -#define CONFIG_SF_DEFAULT_CS 0 -/* this may vary and depends on the installed chip */ -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 -#define CONFIG_SF_DEFAULT_SPEED 24000000 -#endif - #endif
/* Framebuffer support */ diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index 711aa82..6fe0467 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -28,13 +28,6 @@
-#ifdef CONFIG_CMD_SF -#define CONFIG_SF_DEFAULT_BUS 0 -#define CONFIG_SF_DEFAULT_CS 0 -#define CONFIG_SF_DEFAULT_SPEED 20000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 -#endif - #ifdef CONFIG_SUPPORT_EMMC_BOOT #define EMMC_ENV \ "emmcdev=2\0" \ diff --git a/include/configs/mx6slevk.h b/include/configs/mx6slevk.h index a80a656..2cce3d5 100644 --- a/include/configs/mx6slevk.h +++ b/include/configs/mx6slevk.h @@ -144,13 +144,6 @@ #define CONFIG_ENV_OFFSET (8 * SZ_64K) #endif
-#ifdef CONFIG_CMD_SF -#define CONFIG_SF_DEFAULT_BUS 0 -#define CONFIG_SF_DEFAULT_CS 0 -#define CONFIG_SF_DEFAULT_SPEED 20000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 -#endif - /* USB Configs */ #ifdef CONFIG_CMD_USB #define CONFIG_EHCI_HCD_INIT_AFTER_RESET diff --git a/include/configs/mx6sxsabreauto.h b/include/configs/mx6sxsabreauto.h index 058856a..c4d8a89 100644 --- a/include/configs/mx6sxsabreauto.h +++ b/include/configs/mx6sxsabreauto.h @@ -147,10 +147,6 @@
#ifdef CONFIG_FSL_QSPI #define CONFIG_SYS_FSL_QSPI_AHB -#define CONFIG_SF_DEFAULT_BUS 0 -#define CONFIG_SF_DEFAULT_CS 0 -#define CONFIG_SF_DEFAULT_SPEED 40000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 #define FSL_QSPI_FLASH_SIZE SZ_32M #define FSL_QSPI_FLASH_NUM 2 #endif diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index 2a7eb22..dc4181d 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -184,10 +184,6 @@ #define FSL_QSPI_FLASH_SIZE SZ_32M #endif #define FSL_QSPI_FLASH_NUM 2 -#define CONFIG_SF_DEFAULT_BUS 1 -#define CONFIG_SF_DEFAULT_CS 0 -#define CONFIG_SF_DEFAULT_SPEED 40000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 #endif
#ifndef CONFIG_SPL_BUILD diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index c8c088e..42e5115 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -164,10 +164,6 @@
#ifdef CONFIG_FSL_QSPI #define CONFIG_SYS_FSL_QSPI_AHB -#define CONFIG_SF_DEFAULT_BUS 0 -#define CONFIG_SF_DEFAULT_CS 0 -#define CONFIG_SF_DEFAULT_SPEED 40000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 #define FSL_QSPI_FLASH_NUM 1 #define FSL_QSPI_FLASH_SIZE SZ_32M #endif diff --git a/include/configs/mx6ullevk.h b/include/configs/mx6ullevk.h index c64d092..1fc5c24 100644 --- a/include/configs/mx6ullevk.h +++ b/include/configs/mx6ullevk.h @@ -160,10 +160,6 @@
#ifdef CONFIG_FSL_QSPI #define CONFIG_SYS_FSL_QSPI_AHB -#define CONFIG_SF_DEFAULT_BUS 0 -#define CONFIG_SF_DEFAULT_CS 0 -#define CONFIG_SF_DEFAULT_SPEED 40000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 #define FSL_QSPI_FLASH_NUM 1 #define FSL_QSPI_FLASH_SIZE SZ_32M #endif diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index ad919a6..39d29de 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -225,10 +225,6 @@
#ifdef CONFIG_FSL_QSPI #define CONFIG_SYS_FSL_QSPI_AHB -#define CONFIG_SF_DEFAULT_BUS 0 -#define CONFIG_SF_DEFAULT_CS 0 -#define CONFIG_SF_DEFAULT_SPEED 40000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 #define FSL_QSPI_FLASH_NUM 1 #define FSL_QSPI_FLASH_SIZE SZ_64M #define QSPI0_BASE_ADDR QSPI1_IPS_BASE_ADDR diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index c364442..c37a766 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -22,13 +22,6 @@ #define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART2_BASE
-#ifdef CONFIG_CMD_SF -#define CONFIG_SF_DEFAULT_BUS 0 -#define CONFIG_SF_DEFAULT_CS 0 -#define CONFIG_SF_DEFAULT_SPEED 25000000 -#define CONFIG_SF_DEFAULT_MODE (SPI_MODE_0) -#endif - /* I2C Configs */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC diff --git a/include/configs/nyan-big.h b/include/configs/nyan-big.h index dd76829..dd5a62f 100644 --- a/include/configs/nyan-big.h +++ b/include/configs/nyan-big.h @@ -30,8 +30,6 @@ #define CONFIG_LCD_ALIGNMENT MMU_SECTION_SIZE
/* USB Host support */ diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index 2002444..5f5aa57 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -119,7 +119,6 @@
#ifdef CONFIG_USE_SPIFLASH diff --git a/include/configs/ot1200.h b/include/configs/ot1200.h index 776835a..6754181 100644 --- a/include/configs/ot1200.h +++ b/include/configs/ot1200.h @@ -17,10 +17,6 @@ #define CONFIG_MXC_UART_BASE UART1_BASE
/* SF Configs */ -#define CONFIG_SF_DEFAULT_BUS 2 -#define CONFIG_SF_DEFAULT_CS 0 -#define CONFIG_SF_DEFAULT_SPEED 25000000 -#define CONFIG_SF_DEFAULT_MODE (SPI_MODE_0)
/* IO expander */ #define CONFIG_PCA953X diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 0e1f983..e20125c 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -578,11 +578,6 @@ #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5
-#if defined(CONFIG_SPI_FLASH) -#define CONFIG_SF_DEFAULT_SPEED 10000000 -#define CONFIG_SF_DEFAULT_MODE 0 -#endif - #if defined(CONFIG_PCI) /* * General PCI diff --git a/include/configs/p2371-0000.h b/include/configs/p2371-0000.h index 6654a1b..c74dd74 100644 --- a/include/configs/p2371-0000.h +++ b/include/configs/p2371-0000.h @@ -26,8 +26,6 @@ #define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE)
/* USB2.0 Host support */ diff --git a/include/configs/p2371-2180.h b/include/configs/p2371-2180.h index 0e37511..9fa37ae 100644 --- a/include/configs/p2371-2180.h +++ b/include/configs/p2371-2180.h @@ -26,8 +26,6 @@ #define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE)
/* USB2.0 Host support */ diff --git a/include/configs/p2571.h b/include/configs/p2571.h index 1daf49a..83f29f8 100644 --- a/include/configs/p2571.h +++ b/include/configs/p2571.h @@ -27,8 +27,6 @@ #define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE)
/* USB2.0 Host support */ diff --git a/include/configs/pcm051.h b/include/configs/pcm051.h index 5381ed1..8cde12e 100644 --- a/include/configs/pcm051.h +++ b/include/configs/pcm051.h @@ -99,8 +99,6 @@ #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START \ + (8 * 1024 * 1024))
-#define CONFIG_SF_DEFAULT_SPEED 24000000 - /* NS16550 Configuration */ #define CONFIG_SYS_NS16550_COM1 0x44e09000 /* Base EVM has UART0 */ #define CONFIG_SYS_NS16550_COM2 0x48022000 /* UART1 */ diff --git a/include/configs/pcm058.h b/include/configs/pcm058.h index b9bc08b..15dc1b2 100644 --- a/include/configs/pcm058.h +++ b/include/configs/pcm058.h @@ -38,10 +38,6 @@ #define CONFIG_FEC_MXC_PHYADDR 3
/* SPI Flash */ -#define CONFIG_SF_DEFAULT_BUS 0 -#define CONFIG_SF_DEFAULT_CS 0 -#define CONFIG_SF_DEFAULT_SPEED 20000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0
/* I2C Configs */ #define CONFIG_SYS_I2C diff --git a/include/configs/pfla02.h b/include/configs/pfla02.h index e2aae19..fe54e54 100644 --- a/include/configs/pfla02.h +++ b/include/configs/pfla02.h @@ -35,10 +35,6 @@ #define CONFIG_FEC_MXC_PHYADDR 3
/* SPI Flash */ -#define CONFIG_SF_DEFAULT_BUS 2 -#define CONFIG_SF_DEFAULT_CS 0 -#define CONFIG_SF_DEFAULT_SPEED 20000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0
/* I2C Configs */ #define CONFIG_SYS_I2C diff --git a/include/configs/rk3036_common.h b/include/configs/rk3036_common.h index 4fc9226..50c6b56 100644 --- a/include/configs/rk3036_common.h +++ b/include/configs/rk3036_common.h @@ -29,7 +29,6 @@ #define SDRAM_MAX_SIZE (CONFIG_NR_DRAM_BANKS * SDRAM_BANK_SIZE)
#define CONFIG_SPI_FLASH_GIGADEVICE -#define CONFIG_SF_DEFAULT_SPEED 20000000
#ifndef CONFIG_SPL_BUILD /* usb otg */ diff --git a/include/configs/rk3128_common.h b/include/configs/rk3128_common.h index 9451715..0c08d7a 100644 --- a/include/configs/rk3128_common.h +++ b/include/configs/rk3128_common.h @@ -30,7 +30,6 @@ #define CONFIG_SYS_SDRAM_BASE 0x60000000 #define SDRAM_MAX_SIZE 0x80000000
-#define CONFIG_SF_DEFAULT_SPEED 20000000 #define CONFIG_USB_OHCI_NEW #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 1
diff --git a/include/configs/rk3188_common.h b/include/configs/rk3188_common.h index 36e494e..208ca5a 100644 --- a/include/configs/rk3188_common.h +++ b/include/configs/rk3188_common.h @@ -37,8 +37,6 @@ #define SDRAM_BANK_SIZE (2UL << 30) #define SDRAM_MAX_SIZE 0x80000000
-#define CONFIG_SF_DEFAULT_SPEED 20000000 - #ifndef CONFIG_SPL_BUILD /* usb otg */
diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index c59f5ef..72a54bc 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -40,8 +40,6 @@ #define SDRAM_BANK_SIZE (2UL << 30) #define SDRAM_MAX_SIZE 0xfe000000
diff --git a/include/configs/rk3328_common.h b/include/configs/rk3328_common.h index 02233d6..71aad70 100644 --- a/include/configs/rk3328_common.h +++ b/include/configs/rk3328_common.h @@ -26,8 +26,6 @@ #define CONFIG_SYS_SDRAM_BASE 0 #define SDRAM_MAX_SIZE 0xff000000
#define ENV_MEM_LAYOUT_SETTINGS \ diff --git a/include/configs/rk3399_common.h b/include/configs/rk3399_common.h index b977b1f..b412012 100644 --- a/include/configs/rk3399_common.h +++ b/include/configs/rk3399_common.h @@ -38,8 +38,6 @@ #define CONFIG_SYS_SDRAM_BASE 0 #define SDRAM_MAX_SIZE 0xf8000000
#define ENV_MEM_LAYOUT_SETTINGS \ diff --git a/include/configs/sama5d27_som1_ek.h b/include/configs/sama5d27_som1_ek.h index 7c7479b..ae51aea 100644 --- a/include/configs/sama5d27_som1_ek.h +++ b/include/configs/sama5d27_som1_ek.h @@ -31,7 +31,6 @@ #undef CONFIG_CMD_NAND
/* SPI flash */ -#define CONFIG_SF_DEFAULT_SPEED 66000000
#undef CONFIG_BOOTCOMMAND #ifdef CONFIG_SD_BOOT diff --git a/include/configs/sama5d2_xplained.h b/include/configs/sama5d2_xplained.h index 2cec1c7..a3df404 100644 --- a/include/configs/sama5d2_xplained.h +++ b/include/configs/sama5d2_xplained.h @@ -25,11 +25,6 @@ #define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */
/* SerialFlash */ -#ifdef CONFIG_CMD_SF -#define CONFIG_SF_DEFAULT_BUS 0 -#define CONFIG_SF_DEFAULT_CS 0 -#define CONFIG_SF_DEFAULT_SPEED 30000000 -#endif
diff --git a/include/configs/sama5d3xek.h b/include/configs/sama5d3xek.h index ca1c2b0..3870671 100644 --- a/include/configs/sama5d3xek.h +++ b/include/configs/sama5d3xek.h @@ -48,10 +48,6 @@
/* SerialFlash */
-#ifdef CONFIG_CMD_SF -#define CONFIG_SF_DEFAULT_SPEED 30000000 -#endif - /* NAND flash */ #ifdef CONFIG_CMD_NAND #define CONFIG_SYS_MAX_NAND_DEVICE 1 diff --git a/include/configs/sama5d4_xplained.h b/include/configs/sama5d4_xplained.h index bbb1699..d8b61a6 100644 --- a/include/configs/sama5d4_xplained.h +++ b/include/configs/sama5d4_xplained.h @@ -24,10 +24,6 @@
-#ifdef CONFIG_CMD_SF -#define CONFIG_SF_DEFAULT_SPEED 30000000 -#endif - /* NAND flash */ #ifdef CONFIG_CMD_NAND #define CONFIG_SYS_MAX_NAND_DEVICE 1 diff --git a/include/configs/sama5d4ek.h b/include/configs/sama5d4ek.h index d580416..8bfda3f 100644 --- a/include/configs/sama5d4ek.h +++ b/include/configs/sama5d4ek.h @@ -24,10 +24,6 @@
-#ifdef CONFIG_CMD_SF -#define CONFIG_SF_DEFAULT_SPEED 30000000 -#endif - /* NAND flash */ #ifdef CONFIG_CMD_NAND #define CONFIG_SYS_MAX_NAND_DEVICE 1 diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index d8ed02b..8f2dd5f 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -61,8 +61,6 @@
#define CONFIG_SYS_LOAD_ADDR 0x81000000 /* Default load address */
-#define CONFIG_SF_DEFAULT_SPEED (75000000) - /* Physical Memory Map */ #define PHYS_DRAM_1 0x80000000 /* DRAM Bank #1 */
diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index c9cbf8f..394e107 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -69,7 +69,6 @@ * EPCS/EPCQx1 Serial Flash Controller */ #ifdef CONFIG_ALTERA_SPI -#define CONFIG_SF_DEFAULT_SPEED 30000000 /* * The base address is configurable in QSys, each board must specify the * base address based on it's particular FPGA configuration. Please note diff --git a/include/configs/socfpga_sr1500.h b/include/configs/socfpga_sr1500.h index 984f118..d9de075 100644 --- a/include/configs/socfpga_sr1500.h +++ b/include/configs/socfpga_sr1500.h @@ -39,7 +39,6 @@ #define CONFIG_ENV_SPI_CS 0 #define CONFIG_ENV_SPI_MODE SPI_MODE_3 #define CONFIG_ENV_SPI_MAX_HZ 100000000 /* Use max of 100MHz */ -#define CONFIG_SF_DEFAULT_SPEED 100000000
/* * The QSPI NOR flash layout on SR1500: diff --git a/include/configs/socfpga_stratix10_socdk.h b/include/configs/socfpga_stratix10_socdk.h index 0e73239..31c267f 100644 --- a/include/configs/socfpga_stratix10_socdk.h +++ b/include/configs/socfpga_stratix10_socdk.h @@ -60,10 +60,6 @@ /*#define CONFIG_QSPI_RBF_ADDR 0x720000*/
/* Flash device info */ -#define CONFIG_SF_DEFAULT_SPEED (50000000) -#define CONFIG_SF_DEFAULT_MODE (SPI_MODE_3 | SPI_RX_QUAD) -#define CONFIG_SF_DEFAULT_BUS 0 -#define CONFIG_SF_DEFAULT_CS 0
/*#define CONFIG_ENV_IS_IN_SPI_FLASH*/ #ifdef CONFIG_ENV_IS_IN_SPI_FLASH diff --git a/include/configs/stmark2.h b/include/configs/stmark2.h index 33ddc67..fa3d6b8 100644 --- a/include/configs/stmark2.h +++ b/include/configs/stmark2.h @@ -64,7 +64,6 @@
/* DSPI and Serial Flash */ #define CONFIG_CF_DSPI -#define CONFIG_SF_DEFAULT_SPEED 50000000 #define CONFIG_SERIAL_FLASH #define CONFIG_ENV_SPI_BUS 0 #define CONFIG_ENV_SPI_CS 1 diff --git a/include/configs/taurus.h b/include/configs/taurus.h index f283ab7..1d24577 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -111,10 +111,6 @@ #if defined(CONFIG_SPL_BUILD) /* SPL related */ #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000 - -#define CONFIG_SF_DEFAULT_BUS 0 -#define CONFIG_SF_DEFAULT_SPEED 1000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_3 #endif
/* load address */ diff --git a/include/configs/tec-ng.h b/include/configs/tec-ng.h index dd3e026..b5f0481 100644 --- a/include/configs/tec-ng.h +++ b/include/configs/tec-ng.h @@ -26,8 +26,6 @@
/* USB Host support */ diff --git a/include/configs/theadorable.h b/include/configs/theadorable.h index 886456e..59b2546 100644 --- a/include/configs/theadorable.h +++ b/include/configs/theadorable.h @@ -40,8 +40,6 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 3
/* SPI NOR flash default params, used by sf commands */ -#define CONFIG_SF_DEFAULT_SPEED 27777777 /* for fast SPL booting */ -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_3
/* Environment in SPI NOR flash */ #define CONFIG_ENV_OFFSET (1 << 20) /* 1MiB in */ diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index 0c7d664..767615a 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -71,7 +71,6 @@
/* SPI Configuration */ #define CONFIG_SYS_SPI_CLK ks_clk_get_rate(KS2_CLK1_6) -#define CONFIG_SF_DEFAULT_SPEED 30000000 #define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED #define CONFIG_SYS_SPI0 #define CONFIG_SYS_SPI_BASE KS2_SPI0_BASE diff --git a/include/configs/topic_miami.h b/include/configs/topic_miami.h index f14c4ee..c4f01aa 100644 --- a/include/configs/topic_miami.h +++ b/include/configs/topic_miami.h @@ -48,9 +48,6 @@ #define CONFIG_SYS_MEMTEST_END 0x18000000
/* Faster flash, ours may run at 108 MHz */ -#undef CONFIG_SF_DEFAULT_SPEED -#define CONFIG_SF_DEFAULT_SPEED 108000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 #define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED #undef CONFIG_SPI_FLASH_WINBOND
diff --git a/include/configs/tqma6.h b/include/configs/tqma6.h index 65cc12f..6c0d4f2 100644 --- a/include/configs/tqma6.h +++ b/include/configs/tqma6.h @@ -34,11 +34,6 @@
#define TQMA6_SPI_FLASH_SECTOR_SIZE SZ_64K
-#define CONFIG_SF_DEFAULT_BUS 0 -#define CONFIG_SF_DEFAULT_CS 0 -#define CONFIG_SF_DEFAULT_SPEED 50000000 -#define CONFIG_SF_DEFAULT_MODE (SPI_MODE_0) - /* I2C Configs */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC diff --git a/include/configs/trimslice.h b/include/configs/trimslice.h index 427da1c..f543521 100644 --- a/include/configs/trimslice.h +++ b/include/configs/trimslice.h @@ -21,7 +21,6 @@ #define CONFIG_MACH_TYPE MACH_TYPE_TRIMSLICE
/* I2C */ #define CONFIG_SYS_I2C_TEGRA diff --git a/include/configs/turris_mox.h b/include/configs/turris_mox.h index 82cdcce..648c87d 100644 --- a/include/configs/turris_mox.h +++ b/include/configs/turris_mox.h @@ -70,8 +70,6 @@ #define CONFIG_ENV_SPI_CS 0
/* SPI NOR flash default params, used by sf commands */ -#define CONFIG_SF_DEFAULT_SPEED 20000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 #define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE
/* Environment in SPI NOR flash */ diff --git a/include/configs/turris_omnia.h b/include/configs/turris_omnia.h index b90be65..038f639 100644 --- a/include/configs/turris_omnia.h +++ b/include/configs/turris_omnia.h @@ -35,8 +35,6 @@ #endif
/* SPI NOR flash default params, used by sf commands */ -#define CONFIG_SF_DEFAULT_SPEED 1000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_3 #define CONFIG_SPI_FLASH_SPANSION
/* diff --git a/include/configs/venice2.h b/include/configs/venice2.h index e542187..7c567cf 100644 --- a/include/configs/venice2.h +++ b/include/configs/venice2.h @@ -27,8 +27,6 @@ #define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE)
/* USB Host support */ diff --git a/include/configs/vinco.h b/include/configs/vinco.h index 9d6001f..715ef2a 100644 --- a/include/configs/vinco.h +++ b/include/configs/vinco.h @@ -38,11 +38,7 @@ #ifdef CONFIG_CMD_SF #define CONFIG_ATMEL_SPI0 #define CONFIG_SPI_FLASH_STMICRO -#define CONFIG_SF_DEFAULT_BUS 0 -#define CONFIG_SF_DEFAULT_CS 0 -#define CONFIG_SF_DEFAULT_SPEED 50000000 #define CONFIG_ENV_SPI_MAX_HZ 50000000 -#define CONFIG_SF_DEFAULT_MODE (SPI_MODE_0) #define CONFIG_ENV_SPI_MODE (SPI_MODE_0) #endif
diff --git a/include/configs/x530.h b/include/configs/x530.h index a83d49b..d9c1eff 100644 --- a/include/configs/x530.h +++ b/include/configs/x530.h @@ -47,9 +47,6 @@ #define BBT_CUSTOM_SCAN_POSITION 2048
/* SPI NOR flash default params, used by sf commands */ -#define CONFIG_SF_DEFAULT_BUS 1 -#define CONFIG_SF_DEFAULT_SPEED 50000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_3
#define MTDIDS_DEFAULT "nand0=nand" #define MTDPARTS_DEFAULT "mtdparts=nand:240M(user),8M(errlog),8M(nand-bbt)" diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index a285fcd..94177c6 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -42,9 +42,6 @@ #endif
/* QSPI */ -#ifdef CONFIG_ZYNQ_QSPI -# define CONFIG_SF_DEFAULT_SPEED 30000000 -#endif
/* NOR */ #ifdef CONFIG_MTD_NOR_FLASH diff --git a/include/spi_flash.h b/include/spi_flash.h index 7f691e8..97ec2b3 100644 --- a/include/spi_flash.h +++ b/include/spi_flash.h @@ -13,19 +13,6 @@ #include <linux/types.h> #include <linux/mtd/spi-nor.h>
-#ifndef CONFIG_SF_DEFAULT_SPEED -# define CONFIG_SF_DEFAULT_SPEED 1000000 -#endif -#ifndef CONFIG_SF_DEFAULT_MODE -# define CONFIG_SF_DEFAULT_MODE SPI_MODE_3 -#endif -#ifndef CONFIG_SF_DEFAULT_CS -# define CONFIG_SF_DEFAULT_CS 0 -#endif -#ifndef CONFIG_SF_DEFAULT_BUS -# define CONFIG_SF_DEFAULT_BUS 0 -#endif - struct spi_slave;
struct dm_spi_flash_ops { diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 3e01f84..c2cc6fc 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1707,10 +1707,6 @@ CONFIG_SET_DFU_ALT_BUF_LEN CONFIG_SET_DFU_ALT_INFO CONFIG_SFIO CONFIG_SF_DATAFLASH -CONFIG_SF_DEFAULT_BUS -CONFIG_SF_DEFAULT_CS -CONFIG_SF_DEFAULT_MODE -CONFIG_SF_DEFAULT_SPEED CONFIG_SGI_IP28 CONFIG_SH4_PCI CONFIG_SH73A0
[reducing the CC list as gmail won't let me send otherwise]
On 27.02.2019 15:20, Patrick Delaunay wrote:
This converts the following to Kconfig: CONFIG_SF_DEFAULT_BUS CONFIG_SF_DEFAULT_CS CONFIG_SF_DEFAULT_MODE CONFIG_SF_DEFAULT_SPEED
I use moveconfig script and then manual check on generated u-boot.cfg to solve the remaining issue.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com
I admit I haven't followed the patches regarding these defines completely, but isn't moving these to Kconfig the opposite of what we want?
I always thought the goal would be to move U-Boot to DM and devicetree completely sooner or later (where these defines aren't used). Adding them to Kconfig does not make them optional but makes them *always* present (but probably with default values if not used).
Hi Simon,
From: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Sent: mercredi 27 février 2019 15:50
Yes it was my first plan in the series:
http://patchwork.ozlabs.org/project/uboot/list/?series=76834&state=* http://patchwork.ozlabs.org/project/uboot/list/?series=80769&state=*
But it is not possible too many dependency with board using platdata for SPI initialization and regression after my v3.
Migration to Kconfig was requested by Jagan in http://patchwork.ozlabs.org/patch/1031768/
The define need to be always define, as they are used in cmd/sf.c They could dependent on CONFIG_CMD_SF when they are no more used is other part of code (for other purpose).
./board/Arcturus/ucp1020/cmd_arc.c ./board/aristainetos/aristainetos-v1.c ./board/aristainetos/aristainetos-v2.c ./board/davinci/da8xxevm/da850evm.c ./board/davinci/da8xxevm/omapl138_lcdk.c ./board/el/el6x/el6x.c ./board/siemens/taurus/taurus.c ./board/Synology/ds414/cmd_syno.c ./board/tqc/tqma6/tqma6.c ./cmd/mvebu/bubt.c ./common/splash_source.c ./common/spl/spl_spi.c ./drivers/dfu/dfu_sf.c
And yes, 0 is the "default" value, so defines are present in .config.
Why it is disturbing if these defines are requested by command sf ?
Jagan: can you tell me what is the right direction.for you...
Regards
Patrick
On Mon, Mar 4, 2019 at 11:44 AM Patrick DELAUNAY patrick.delaunay@st.com wrote:
Hi Simon,
Oh, ok. That's sad. But I wouldn't have time to work on this, either...
Well, defaults for that command are not necessarily defaults for use at driver level?
Because I would have thought with DM, defaults would come from dts, not from some defines.
Anyway, I guess I now understand why you have done it like that. I'm not the SPI maintainer, so I won't interfere. I was only a little bit surprised that this took a different direction as the first things we discussed in that area...
And as long as this define doesn't interfere with my SPL + U-Boot using the settings from dts, this looks good, I guess.
Regards
Patrick
Hi Simon,
From: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Sent: lundi 4 mars 2019 11:51
Hi Simon,
Yes, but today it is the case for some fallback when DT information is not available (dfu_sf / spl_spi). And I don't know solve this issue.
This serie is only a step, I hope in the good direction.
In fact, I am also waiting feedback to be sure that is the good direction.
Yes, no interference: they are used only when DT is not available (tested on my board stm32mp1 ev1 which use only device tree, and it is OK).
Regards
Patrick
Patrick
This converts the following to Kconfig: CONFIG_DEFAULT_SPI_BUS CONFIG_DEFAULT_SPI_MODE
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
cmd/Kconfig | 12 +++++++++++- cmd/spi.c | 7 ------- configs/bg0900_defconfig | 1 + configs/ls1012aqds_qspi_defconfig | 3 +++ configs/ls1012aqds_tfa_SECURE_BOOT_defconfig | 2 ++ configs/ls1012aqds_tfa_defconfig | 2 ++ configs/mx28evk_auart_console_defconfig | 1 + configs/mx28evk_defconfig | 1 + configs/mx28evk_nand_defconfig | 1 + configs/mx28evk_spi_defconfig | 1 + configs/mx31pdk_defconfig | 2 ++ include/configs/bg0900.h | 7 ------- include/configs/cl-som-am57x.h | 1 - include/configs/ls1012aqds.h | 2 -- include/configs/mx28evk.h | 6 ------ include/configs/mx31pdk.h | 3 --- scripts/config_whitelist.txt | 2 -- 17 files changed, 25 insertions(+), 29 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 3ea42e4..fbc1b6f 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1030,10 +1030,20 @@ config CMD_SF_TEST everything is working properly.
config CMD_SPI - bool "sspi" + bool "sspi - Command to access spi device" help SPI utility command.
+config DEFAULT_SPI_BUS + int "default spi bus used by sspi command" + depends on CMD_SPI + default 0 + +config DEFAULT_SPI_MODE + hex "default spi mode used by sspi command (see include/spi.h)" + depends on CMD_SPI + default 0 + config CMD_TSI148 bool "tsi148 - Command to access tsi148 device" help diff --git a/cmd/spi.c b/cmd/spi.c index 9a2edcf..75226fd 100644 --- a/cmd/spi.c +++ b/cmd/spi.c @@ -22,13 +22,6 @@ # define MAX_SPI_BYTES 32 /* Maximum number of bytes we can handle */ #endif
-#ifndef CONFIG_DEFAULT_SPI_BUS -# define CONFIG_DEFAULT_SPI_BUS 0 -#endif -#ifndef CONFIG_DEFAULT_SPI_MODE -# define CONFIG_DEFAULT_SPI_MODE SPI_MODE_0 -#endif - /* * Values from last command. */ diff --git a/configs/bg0900_defconfig b/configs/bg0900_defconfig index a8b5f86..2c4d3e3 100644 --- a/configs/bg0900_defconfig +++ b/configs/bg0900_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y +CONFIG_DEFAULT_SPI_BUS=2 CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y diff --git a/configs/ls1012aqds_qspi_defconfig b/configs/ls1012aqds_qspi_defconfig index 1bf9343..d2c3eea 100644 --- a/configs/ls1012aqds_qspi_defconfig +++ b/configs/ls1012aqds_qspi_defconfig @@ -27,7 +27,10 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_DEFAULT_SPI_BUS=1 CONFIG_CMD_USB=y +CONFIG_DEFAULT_SPI_BUS=1 # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y diff --git a/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig index 747fa3d..9a6139e 100644 --- a/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig @@ -27,6 +27,8 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_DEFAULT_SPI_BUS=1 CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y diff --git a/configs/ls1012aqds_tfa_defconfig b/configs/ls1012aqds_tfa_defconfig index a41757d..d18d40a 100644 --- a/configs/ls1012aqds_tfa_defconfig +++ b/configs/ls1012aqds_tfa_defconfig @@ -27,6 +27,8 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_DEFAULT_SPI_BUS=1 CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y diff --git a/configs/mx28evk_auart_console_defconfig b/configs/mx28evk_auart_console_defconfig index beb10c4..c54b933 100644 --- a/configs/mx28evk_auart_console_defconfig +++ b/configs/mx28evk_auart_console_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y +CONFIG_DEFAULT_SPI_BUS=2 CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/mx28evk_defconfig b/configs/mx28evk_defconfig index be1feb3..187467d 100644 --- a/configs/mx28evk_defconfig +++ b/configs/mx28evk_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y +CONFIG_DEFAULT_SPI_BUS=2 CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/mx28evk_nand_defconfig b/configs/mx28evk_nand_defconfig index 61e3586..7d891e7 100644 --- a/configs/mx28evk_nand_defconfig +++ b/configs/mx28evk_nand_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y +CONFIG_DEFAULT_SPI_BUS=2 CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/mx28evk_spi_defconfig b/configs/mx28evk_spi_defconfig index 3198baf..cb5b1b3 100644 --- a/configs/mx28evk_spi_defconfig +++ b/configs/mx28evk_spi_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y +CONFIG_DEFAULT_SPI_BUS=2 CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/configs/mx31pdk_defconfig b/configs/mx31pdk_defconfig index c6dcb45..2267818 100644 --- a/configs/mx31pdk_defconfig +++ b/configs/mx31pdk_defconfig @@ -13,6 +13,8 @@ CONFIG_SPL_NAND_SUPPORT=y # CONFIG_AUTO_COMPLETE is not set CONFIG_CMD_BOOTZ=y CONFIG_CMD_SPI=y +CONFIG_DEFAULT_SPI_BUS=1 +CONFIG_DEFAULT_SPI_MODE=4 # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/include/configs/bg0900.h b/include/configs/bg0900.h index 32b975f..0c3d54a 100644 --- a/include/configs/bg0900.h +++ b/include/configs/bg0900.h @@ -19,11 +19,6 @@ #define CONFIG_FEC_MXC #endif
-/* SPI */ -#ifdef CONFIG_CMD_SPI -#define CONFIG_DEFAULT_SPI_BUS 2 -#define CONFIG_DEFAULT_SPI_MODE SPI_MODE_0 - /* SPI FLASH */ #ifdef CONFIG_CMD_SF #define CONFIG_ENV_SPI_BUS 2 @@ -32,8 +27,6 @@ #define CONFIG_ENV_SPI_MODE SPI_MODE_0 #endif
-#endif - /* Boot Linux */ #define CONFIG_BOOTFILE "uImage" #define CONFIG_BOOTCOMMAND "bootm" diff --git a/include/configs/cl-som-am57x.h b/include/configs/cl-som-am57x.h index c9e80c2..687a9e7 100644 --- a/include/configs/cl-som-am57x.h +++ b/include/configs/cl-som-am57x.h @@ -27,7 +27,6 @@
/* SPI Flash support */ #define CONFIG_TI_SPI_MMAP -#define CONFIG_DEFAULT_SPI_MODE SPI_MODE_3
/* SPI SPL defines */ /* Offsets: 0K - SPL1, 64K - SPL2, 128K - SPL3, 192K - SPL4, 256K - U-Boot */ diff --git a/include/configs/ls1012aqds.h b/include/configs/ls1012aqds.h index aac782d..fb0d1ba 100644 --- a/include/configs/ls1012aqds.h +++ b/include/configs/ls1012aqds.h @@ -74,9 +74,7 @@
/* DSPI */ #define CONFIG_FSL_DSPI1 -#define CONFIG_DEFAULT_SPI_BUS 1
-#define CONFIG_CMD_SPI #define MMAP_DSPI DSPI1_BASE_ADDR
#define CONFIG_SYS_DSPI_CTAR0 1 diff --git a/include/configs/mx28evk.h b/include/configs/mx28evk.h index 82ac6cc..a078e3a 100644 --- a/include/configs/mx28evk.h +++ b/include/configs/mx28evk.h @@ -74,12 +74,6 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 #endif
-/* SPI */ -#ifdef CONFIG_CMD_SPI -#define CONFIG_DEFAULT_SPI_BUS 2 -#define CONFIG_DEFAULT_SPI_MODE SPI_MODE_0 -#endif - /* Framebuffer support */ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_LOGO diff --git a/include/configs/mx31pdk.h b/include/configs/mx31pdk.h index 4765764..993d131 100644 --- a/include/configs/mx31pdk.h +++ b/include/configs/mx31pdk.h @@ -43,9 +43,6 @@ #define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART1_BASE
-#define CONFIG_DEFAULT_SPI_BUS 1 -#define CONFIG_DEFAULT_SPI_MODE (SPI_MODE_0 | SPI_CS_HIGH) - /* PMIC Controller */ #define CONFIG_POWER #define CONFIG_POWER_SPI diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index c2cc6fc..080bdf5 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -340,8 +340,6 @@ CONFIG_DEEP_SLEEP CONFIG_DEFAULT CONFIG_DEFAULT_CONSOLE CONFIG_DEFAULT_IMMR -CONFIG_DEFAULT_SPI_BUS -CONFIG_DEFAULT_SPI_MODE CONFIG_DEF_HWCONFIG CONFIG_DELAY_ENVIRONMENT CONFIG_DESIGNWARE_ETH
This converts the following to Kconfig: CONFIG_ENV_SPI_BUS CONFIG_ENV_SPI_CS CONFIG_ENV_SPI_MAX_HZ CONFIG_ENV_SPI_MODE
Most of time these value are not needed, CONFIG_SF_DEFAULT with same value is used, so I introduced CONFIG_USE_ENV_SPI_* to force the associated value for the environment.
arch/arm/mach-kirkwood/include/mach/config.h | 15 -------- arch/arm/mach-mvebu/include/mach/config.h | 15 -------- configs/M52277EVB_stmicro_defconfig | 2 + configs/M54418TWR_defconfig | 2 + configs/M54418TWR_serial_mii_defconfig | 2 + configs/M54418TWR_serial_rmii_defconfig | 2 + configs/M54451EVB_stmicro_defconfig | 2 + configs/M54455EVB_stm33_defconfig | 2 + configs/SBx81LIFKW_defconfig | 2 + configs/SBx81LIFXCAT_defconfig | 2 + configs/ap121_defconfig | 2 + configs/ap143_defconfig | 2 + configs/at91sam9260ek_dataflash_cs0_defconfig | 2 + configs/at91sam9260ek_dataflash_cs1_defconfig | 2 + configs/at91sam9261ek_dataflash_cs0_defconfig | 2 + configs/at91sam9261ek_dataflash_cs3_defconfig | 2 + configs/at91sam9263ek_dataflash_cs0_defconfig | 2 + configs/at91sam9263ek_dataflash_defconfig | 2 + configs/at91sam9g10ek_dataflash_cs0_defconfig | 2 + configs/at91sam9g10ek_dataflash_cs3_defconfig | 2 + configs/at91sam9g20ek_dataflash_cs0_defconfig | 2 + configs/at91sam9g20ek_dataflash_cs1_defconfig | 2 + configs/at91sam9rlek_dataflash_defconfig | 2 + configs/at91sam9xeek_dataflash_cs0_defconfig | 2 + configs/at91sam9xeek_dataflash_cs1_defconfig | 2 + configs/controlcenterdc_defconfig | 2 + configs/d2net_v2_defconfig | 2 + configs/da850_am18xxevm_defconfig | 4 ++ configs/da850evm_defconfig | 4 ++ configs/db-88f6720_defconfig | 2 + configs/db-88f6820-amc_defconfig | 2 + configs/db-88f6820-gp_defconfig | 2 + configs/db-mv784mp-gp_defconfig | 2 + configs/dreamplug_defconfig | 2 + configs/ds109_defconfig | 2 + configs/ds414_defconfig | 2 + configs/ethernut5_defconfig | 2 + configs/inetspace_v2_defconfig | 2 + configs/ls1012aqds_qspi_defconfig | 7 +++- configs/ls1012aqds_tfa_defconfig | 6 +++ configs/ls1043aqds_tfa_defconfig | 2 + configs/ls1046aqds_tfa_defconfig | 2 + configs/maxbcm_defconfig | 2 + configs/meesc_dataflash_defconfig | 2 + configs/mscc_jr2_defconfig | 4 ++ configs/mscc_luton_defconfig | 4 ++ configs/mscc_ocelot_defconfig | 4 ++ configs/mscc_serval_defconfig | 4 ++ configs/mscc_servalt_defconfig | 4 ++ configs/net2big_v2_defconfig | 2 + configs/netspace_lite_v2_defconfig | 2 + configs/netspace_max_v2_defconfig | 2 + configs/netspace_mini_v2_defconfig | 2 + configs/netspace_v2_defconfig | 2 + configs/peach-pi_defconfig | 2 + configs/peach-pit_defconfig | 2 + configs/smdk5250_defconfig | 2 + configs/smdk5420_defconfig | 2 + configs/snow_defconfig | 2 + configs/spring_defconfig | 2 + configs/stmark2_defconfig | 2 + configs/theadorable_debug_defconfig | 2 + configs/trimslice_defconfig | 2 + configs/turris_omnia_defconfig | 2 + configs/usb_a9263_dataflash_defconfig | 2 + env/Kconfig | 53 +++++++++++++++++++++++---- env/sf.c | 13 ------- include/configs/B4860QDS.h | 4 -- include/configs/BSC9131RDB.h | 4 -- include/configs/BSC9132QDS.h | 4 -- include/configs/C29XPCIE.h | 4 -- include/configs/M52277EVB.h | 3 -- include/configs/M54418TWR.h | 1 - include/configs/M54451EVB.h | 1 - include/configs/M54455EVB.h | 3 -- include/configs/MPC8536DS.h | 4 -- include/configs/P1010RDB.h | 4 -- include/configs/P1022DS.h | 4 -- include/configs/P2041RDB.h | 4 -- include/configs/SBx81LIFKW.h | 4 -- include/configs/SBx81LIFXCAT.h | 4 -- include/configs/T102xQDS.h | 4 -- include/configs/T102xRDB.h | 4 -- include/configs/T1040QDS.h | 4 -- include/configs/T104xRDB.h | 4 -- include/configs/T208xQDS.h | 4 -- include/configs/T208xRDB.h | 4 -- include/configs/T4240QDS.h | 4 -- include/configs/T4240RDB.h | 4 -- include/configs/UCP1020.h | 4 -- include/configs/adp-ae3xx.h | 4 -- include/configs/advantech_dms-ba16.h | 4 -- include/configs/am335x_evm.h | 1 - include/configs/am43xx_evm.h | 1 - include/configs/ap121.h | 1 - include/configs/ap143.h | 1 - include/configs/aristainetos-common.h | 4 -- include/configs/at91sam9260ek.h | 2 - include/configs/at91sam9261ek.h | 2 - include/configs/at91sam9263ek.h | 1 - include/configs/at91sam9rlek.h | 1 - include/configs/at91sam9x5ek.h | 2 - include/configs/ax25-ae350.h | 4 -- include/configs/bav335x.h | 1 - include/configs/bg0900.h | 4 -- include/configs/brppt1.h | 1 - include/configs/cgtqmx6eval.h | 4 -- include/configs/cl-som-am57x.h | 1 - include/configs/cl-som-imx7.h | 4 -- include/configs/cm_fx6.h | 4 -- include/configs/cm_t43.h | 1 - include/configs/controlcenterd.h | 4 -- include/configs/controlcenterdc.h | 1 - include/configs/corenet_ds.h | 4 -- include/configs/da850evm.h | 2 - include/configs/db-88f6820-amc.h | 1 - include/configs/db-88f6820-gp.h | 2 - include/configs/dh_imx6.h | 4 -- include/configs/display5.h | 5 --- include/configs/dra7xx_evm.h | 1 - include/configs/dreamplug.h | 3 -- include/configs/ds109.h | 3 -- include/configs/ea20.h | 1 - include/configs/embestmx6boards.h | 4 -- include/configs/ethernut5.h | 1 - include/configs/exynos5-common.h | 3 -- include/configs/ge_bx50v3.h | 4 -- include/configs/gw_ventana.h | 4 -- include/configs/helios4.h | 7 ---- include/configs/km/km_arm.h | 4 -- include/configs/km/kmp204x-common.h | 4 -- include/configs/lacie_kw.h | 2 - include/configs/legoev3.h | 1 - include/configs/ls1012a_common.h | 4 -- include/configs/ls1043a_common.h | 8 ---- include/configs/ls1046a_common.h | 8 ---- include/configs/lsxl.h | 4 -- include/configs/meesc.h | 1 - include/configs/microblaze-generic.h | 3 -- include/configs/mvebu_armada-37xx.h | 4 -- include/configs/mvebu_armada-8k.h | 5 --- include/configs/mx28evk.h | 4 -- include/configs/mx6slevk.h | 4 -- include/configs/nitrogen6x.h | 4 -- include/configs/omapl138_lcdk.h | 1 - include/configs/ot1200.h | 4 -- include/configs/p1_p2_rdb_pc.h | 4 -- include/configs/pcm058.h | 4 -- include/configs/pfla02.h | 4 -- include/configs/pm9261.h | 1 - include/configs/pm9263.h | 1 - include/configs/puma_rk3399.h | 4 -- include/configs/siemens-am33x-common.h | 1 - include/configs/socfpga_sr1500.h | 4 -- include/configs/stmark2.h | 3 -- include/configs/ti_armv7_keystone2.h | 1 - include/configs/topic_miami.h | 1 - include/configs/tqma6.h | 5 --- include/configs/trimslice.h | 2 - include/configs/turris_mox.h | 5 --- include/configs/usb_a9263.h | 1 - include/configs/vcoreiii.h | 2 - include/configs/vinco.h | 4 -- include/configs/x530.h | 2 - include/spi_flash.h | 14 +++++++ 165 files changed, 208 insertions(+), 351 deletions(-)
diff --git a/arch/arm/mach-kirkwood/include/mach/config.h b/arch/arm/mach-kirkwood/include/mach/config.h index fcd9038..b6cf629 100644 --- a/arch/arm/mach-kirkwood/include/mach/config.h +++ b/arch/arm/mach-kirkwood/include/mach/config.h @@ -55,21 +55,6 @@ #endif
/* - * SPI Flash configuration - */ -#ifdef CONFIG_CMD_SF -#ifndef CONFIG_ENV_SPI_BUS -# define CONFIG_ENV_SPI_BUS 0 -#endif -#ifndef CONFIG_ENV_SPI_CS -# define CONFIG_ENV_SPI_CS 0 -#endif -#ifndef CONFIG_ENV_SPI_MAX_HZ -# define CONFIG_ENV_SPI_MAX_HZ 50000000 -#endif -#endif - -/* * Ethernet Driver configuration */ #ifdef CONFIG_CMD_NET diff --git a/arch/arm/mach-mvebu/include/mach/config.h b/arch/arm/mach-mvebu/include/mach/config.h index e3235fc..71c4f70 100644 --- a/arch/arm/mach-mvebu/include/mach/config.h +++ b/arch/arm/mach-mvebu/include/mach/config.h @@ -45,21 +45,6 @@
#define MV_UART_CONSOLE_BASE MVEBU_UART0_BASE
-/* - * SPI Flash configuration - */ -#ifdef CONFIG_CMD_SF -#ifndef CONFIG_ENV_SPI_BUS -# define CONFIG_ENV_SPI_BUS 0 -#endif -#ifndef CONFIG_ENV_SPI_CS -# define CONFIG_ENV_SPI_CS 0 -#endif -#ifndef CONFIG_ENV_SPI_MAX_HZ -# define CONFIG_ENV_SPI_MAX_HZ 50000000 -#endif -#endif - /* Needed for SPI NOR booting in SPL */ #define CONFIG_DM_SEQ_ALIAS 1
diff --git a/configs/M52277EVB_stmicro_defconfig b/configs/M52277EVB_stmicro_defconfig index 3628729..cafc861 100644 --- a/configs/M52277EVB_stmicro_defconfig +++ b/configs/M52277EVB_stmicro_defconfig @@ -15,6 +15,8 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y CONFIG_CMD_JFFS2=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_CS=y +CONFIG_ENV_SPI_CS=2 # CONFIG_NET is not set CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y diff --git a/configs/M54418TWR_defconfig b/configs/M54418TWR_defconfig index f69f405..a239f4a 100644 --- a/configs/M54418TWR_defconfig +++ b/configs/M54418TWR_defconfig @@ -20,6 +20,8 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_CS=y +CONFIG_ENV_SPI_CS=1 CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_MII=y diff --git a/configs/M54418TWR_serial_mii_defconfig b/configs/M54418TWR_serial_mii_defconfig index b2266a0..8b72bd3 100644 --- a/configs/M54418TWR_serial_mii_defconfig +++ b/configs/M54418TWR_serial_mii_defconfig @@ -20,6 +20,8 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_CS=y +CONFIG_ENV_SPI_CS=1 CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_MII=y diff --git a/configs/M54418TWR_serial_rmii_defconfig b/configs/M54418TWR_serial_rmii_defconfig index f69f405..a239f4a 100644 --- a/configs/M54418TWR_serial_rmii_defconfig +++ b/configs/M54418TWR_serial_rmii_defconfig @@ -20,6 +20,8 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_CS=y +CONFIG_ENV_SPI_CS=1 CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_MII=y diff --git a/configs/M54451EVB_stmicro_defconfig b/configs/M54451EVB_stmicro_defconfig index ce5f656..b614ca7 100644 --- a/configs/M54451EVB_stmicro_defconfig +++ b/configs/M54451EVB_stmicro_defconfig @@ -20,6 +20,8 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_CS=y +CONFIG_ENV_SPI_CS=1 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/M54455EVB_stm33_defconfig b/configs/M54455EVB_stm33_defconfig index fc19de5..467bfae 100644 --- a/configs/M54455EVB_stm33_defconfig +++ b/configs/M54455EVB_stm33_defconfig @@ -25,6 +25,8 @@ CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_ISO_PARTITION=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_CS=y +CONFIG_ENV_SPI_CS=1 CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/SBx81LIFKW_defconfig b/configs/SBx81LIFKW_defconfig index e0ce159..afda7ed 100644 --- a/configs/SBx81LIFKW_defconfig +++ b/configs/SBx81LIFKW_defconfig @@ -20,6 +20,8 @@ CONFIG_CMD_SNTP=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-atl-sbx81lifkw" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=20000000 CONFIG_DM=y CONFIG_DM_GPIO=y CONFIG_DM_PCA953X=y diff --git a/configs/SBx81LIFXCAT_defconfig b/configs/SBx81LIFXCAT_defconfig index 4a6e058..4cb4797 100644 --- a/configs/SBx81LIFXCAT_defconfig +++ b/configs/SBx81LIFXCAT_defconfig @@ -22,6 +22,8 @@ CONFIG_CMD_SNTP=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-atl-sbx81lifxcat" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=20000000 CONFIG_DM=y CONFIG_DM_GPIO=y CONFIG_DM_PCA953X=y diff --git a/configs/ap121_defconfig b/configs/ap121_defconfig index c9dbe4d..eca24e9 100644 --- a/configs/ap121_defconfig +++ b/configs/ap121_defconfig @@ -32,6 +32,8 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=spi-flash.0:256k(u-boot),64k(u-boot-env),6144k # CONFIG_ISO_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="ap121" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=25000000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/ap143_defconfig b/configs/ap143_defconfig index 7c1a296..9a5a9f8 100644 --- a/configs/ap143_defconfig +++ b/configs/ap143_defconfig @@ -31,6 +31,8 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=spi-flash.0:256k(u-boot),64k(u-boot-env),6336k # CONFIG_ISO_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="ap143" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=25000000 # CONFIG_NET is not set CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/at91sam9260ek_dataflash_cs0_defconfig b/configs/at91sam9260ek_dataflash_cs0_defconfig index 7fd844c..9b0aa07 100644 --- a/configs/at91sam9260ek_dataflash_cs0_defconfig +++ b/configs/at91sam9260ek_dataflash_cs0_defconfig @@ -29,6 +29,8 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9260ek" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=15000000 CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9260ek_dataflash_cs1_defconfig b/configs/at91sam9260ek_dataflash_cs1_defconfig index c2fc77d..1e5d540 100644 --- a/configs/at91sam9260ek_dataflash_cs1_defconfig +++ b/configs/at91sam9260ek_dataflash_cs1_defconfig @@ -29,6 +29,8 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9260ek" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=15000000 CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9261ek_dataflash_cs0_defconfig b/configs/at91sam9261ek_dataflash_cs0_defconfig index 431cf28..e036ebc 100644 --- a/configs/at91sam9261ek_dataflash_cs0_defconfig +++ b/configs/at91sam9261ek_dataflash_cs0_defconfig @@ -30,6 +30,8 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9261ek" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=15000000 CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9261ek_dataflash_cs3_defconfig b/configs/at91sam9261ek_dataflash_cs3_defconfig index e5efad8..b67aa90 100644 --- a/configs/at91sam9261ek_dataflash_cs3_defconfig +++ b/configs/at91sam9261ek_dataflash_cs3_defconfig @@ -30,6 +30,8 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9261ek" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=15000000 CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9263ek_dataflash_cs0_defconfig b/configs/at91sam9263ek_dataflash_cs0_defconfig index a19f309..4f8694f 100644 --- a/configs/at91sam9263ek_dataflash_cs0_defconfig +++ b/configs/at91sam9263ek_dataflash_cs0_defconfig @@ -33,6 +33,8 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9263ek" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=15000000 CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9263ek_dataflash_defconfig b/configs/at91sam9263ek_dataflash_defconfig index a19f309..4f8694f 100644 --- a/configs/at91sam9263ek_dataflash_defconfig +++ b/configs/at91sam9263ek_dataflash_defconfig @@ -33,6 +33,8 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9263ek" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=15000000 CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9g10ek_dataflash_cs0_defconfig b/configs/at91sam9g10ek_dataflash_cs0_defconfig index 7bf0b79..6f71d34 100644 --- a/configs/at91sam9g10ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs0_defconfig @@ -30,6 +30,8 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9261ek" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=15000000 CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9g10ek_dataflash_cs3_defconfig b/configs/at91sam9g10ek_dataflash_cs3_defconfig index b4e8892..644d59d 100644 --- a/configs/at91sam9g10ek_dataflash_cs3_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs3_defconfig @@ -30,6 +30,8 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9261ek" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=15000000 CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9g20ek_dataflash_cs0_defconfig b/configs/at91sam9g20ek_dataflash_cs0_defconfig index 688c182..c064d01 100644 --- a/configs/at91sam9g20ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs0_defconfig @@ -29,6 +29,8 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20ek" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=15000000 CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9g20ek_dataflash_cs1_defconfig b/configs/at91sam9g20ek_dataflash_cs1_defconfig index 1eb4379..1e409ea 100644 --- a/configs/at91sam9g20ek_dataflash_cs1_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs1_defconfig @@ -29,6 +29,8 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9g20ek" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=15000000 CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9rlek_dataflash_defconfig b/configs/at91sam9rlek_dataflash_defconfig index 800a92c..88c0a43 100644 --- a/configs/at91sam9rlek_dataflash_defconfig +++ b/configs/at91sam9rlek_dataflash_defconfig @@ -30,6 +30,8 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9rlek" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=15000000 # CONFIG_NET is not set CONFIG_DM=y CONFIG_CLK=y diff --git a/configs/at91sam9xeek_dataflash_cs0_defconfig b/configs/at91sam9xeek_dataflash_cs0_defconfig index ac6d9de..b125182 100644 --- a/configs/at91sam9xeek_dataflash_cs0_defconfig +++ b/configs/at91sam9xeek_dataflash_cs0_defconfig @@ -29,6 +29,8 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9260ek" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=15000000 CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9xeek_dataflash_cs1_defconfig b/configs/at91sam9xeek_dataflash_cs1_defconfig index 56c6f12..c07008a 100644 --- a/configs/at91sam9xeek_dataflash_cs1_defconfig +++ b/configs/at91sam9xeek_dataflash_cs1_defconfig @@ -29,6 +29,8 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9260ek" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=15000000 CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/controlcenterdc_defconfig b/configs/controlcenterdc_defconfig index b2b61b2..08fdc55 100644 --- a/configs/controlcenterdc_defconfig +++ b/configs/controlcenterdc_defconfig @@ -44,6 +44,8 @@ CONFIG_EFI_PARTITION=y CONFIG_OF_BOARD_FIXUP=y CONFIG_DEFAULT_DEVICE_TREE="armada-38x-controlcenterdc" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=50000000 CONFIG_SPL_OF_TRANSLATE=y CONFIG_SCSI_AHCI=y CONFIG_DM_GPIO=y diff --git a/configs/d2net_v2_defconfig b/configs/d2net_v2_defconfig index 0b27bd7..28c5c83 100644 --- a/configs/d2net_v2_defconfig +++ b/configs/d2net_v2_defconfig @@ -31,6 +31,8 @@ CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-d2net" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=20000000 CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y diff --git a/configs/da850_am18xxevm_defconfig b/configs/da850_am18xxevm_defconfig index 58745fe..b1cf9bd 100644 --- a/configs/da850_am18xxevm_defconfig +++ b/configs/da850_am18xxevm_defconfig @@ -38,6 +38,10 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="da850-evm" CONFIG_SPL_OF_PLATDATA=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=0 +CONFIG_USE_ENV_SPI_MODE=y +CONFIG_ENV_SPI_MODE=0 CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_DA8XX_GPIO=y diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index 5100ee7..e6031b4 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -40,6 +40,10 @@ CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="da850-evm" CONFIG_SPL_OF_PLATDATA=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=0 +CONFIG_USE_ENV_SPI_MODE=y +CONFIG_ENV_SPI_MODE=0 CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_DM_GPIO=y diff --git a/configs/db-88f6720_defconfig b/configs/db-88f6720_defconfig index 2c9254b..3de9766 100644 --- a/configs/db-88f6720_defconfig +++ b/configs/db-88f6720_defconfig @@ -39,6 +39,8 @@ CONFIG_CMD_FS_GENERIC=y # CONFIG_DOS_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="armada-375-db" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=50000000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_MISC=y diff --git a/configs/db-88f6820-amc_defconfig b/configs/db-88f6820-amc_defconfig index 7fd1d50..2f8e31d 100644 --- a/configs/db-88f6820-amc_defconfig +++ b/configs/db-88f6820-amc_defconfig @@ -42,6 +42,8 @@ CONFIG_EFI_PARTITION=y # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_DEFAULT_DEVICE_TREE="armada-385-amc" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=50000000 CONFIG_SPL_OF_TRANSLATE=y CONFIG_BLK=y # CONFIG_SPL_BLK is not set diff --git a/configs/db-88f6820-gp_defconfig b/configs/db-88f6820-gp_defconfig index b36b7c3..a4c00e9 100644 --- a/configs/db-88f6820-gp_defconfig +++ b/configs/db-88f6820-gp_defconfig @@ -43,6 +43,8 @@ CONFIG_EFI_PARTITION=y # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_DEFAULT_DEVICE_TREE="armada-388-gp" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=50000000 CONFIG_SPL_OF_TRANSLATE=y CONFIG_SCSI_AHCI=y CONFIG_MMC_SDHCI=y diff --git a/configs/db-mv784mp-gp_defconfig b/configs/db-mv784mp-gp_defconfig index b6c61c3..98e47ee 100644 --- a/configs/db-mv784mp-gp_defconfig +++ b/configs/db-mv784mp-gp_defconfig @@ -42,6 +42,8 @@ CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_DEFAULT_DEVICE_TREE="armada-xp-gp" +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=50000000 CONFIG_SPL_OF_TRANSLATE=y CONFIG_SATA_MV=y # CONFIG_MMC is not set diff --git a/configs/dreamplug_defconfig b/configs/dreamplug_defconfig index d3263cf..8202848 100644 --- a/configs/dreamplug_defconfig +++ b/configs/dreamplug_defconfig @@ -23,6 +23,8 @@ CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-dreamplug" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=50000000 CONFIG_DM=y CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set diff --git a/configs/ds109_defconfig b/configs/ds109_defconfig index 3e4e71b..29d5f98 100644 --- a/configs/ds109_defconfig +++ b/configs/ds109_defconfig @@ -18,6 +18,8 @@ CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ds109" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=50000000 CONFIG_DM=y CONFIG_MVSATA_IDE=y CONFIG_DM_I2C=y diff --git a/configs/ds414_defconfig b/configs/ds414_defconfig index ce42f23..62cad53 100644 --- a/configs/ds414_defconfig +++ b/configs/ds414_defconfig @@ -39,6 +39,8 @@ CONFIG_CMD_MTDPARTS=y CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y CONFIG_DEFAULT_DEVICE_TREE="armada-xp-synology-ds414" +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=50000000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_OF_TRANSLATE=y # CONFIG_MMC is not set diff --git a/configs/ethernut5_defconfig b/configs/ethernut5_defconfig index b14cf6c..2ec3aae 100644 --- a/configs/ethernut5_defconfig +++ b/configs/ethernut5_defconfig @@ -45,6 +45,8 @@ CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="ethernut5" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=15000000 CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/inetspace_v2_defconfig b/configs/inetspace_v2_defconfig index cebe4a5..ca85973 100644 --- a/configs/inetspace_v2_defconfig +++ b/configs/inetspace_v2_defconfig @@ -31,6 +31,8 @@ CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-is2" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=20000000 CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y diff --git a/configs/ls1012aqds_qspi_defconfig b/configs/ls1012aqds_qspi_defconfig index d2c3eea..3212f37 100644 --- a/configs/ls1012aqds_qspi_defconfig +++ b/configs/ls1012aqds_qspi_defconfig @@ -28,7 +28,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y -CONFIG_DEFAULT_SPI_BUS=1 CONFIG_CMD_USB=y CONFIG_DEFAULT_SPI_BUS=1 # CONFIG_CMD_SETEXPR is not set @@ -37,6 +36,12 @@ CONFIG_CMD_DATE=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1012a-qds" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_BUS=y +CONFIG_ENV_SPI_BUS=0 +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=1000000 +CONFIG_USE_ENV_SPI_MODE=y +CONFIG_ENV_SPI_MODE=0x03 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SCSI_AHCI=y diff --git a/configs/ls1012aqds_tfa_defconfig b/configs/ls1012aqds_tfa_defconfig index d18d40a..99188d3 100644 --- a/configs/ls1012aqds_tfa_defconfig +++ b/configs/ls1012aqds_tfa_defconfig @@ -36,6 +36,12 @@ CONFIG_CMD_DATE=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1012a-qds" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_BUS=y +CONFIG_ENV_SPI_BUS=0 +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=1000000 +CONFIG_USE_ENV_SPI_MODE=y +CONFIG_ENV_SPI_MODE=0x03 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SCSI_AHCI=y diff --git a/configs/ls1043aqds_tfa_defconfig b/configs/ls1043aqds_tfa_defconfig index f17820d..ff5fcd6 100644 --- a/configs/ls1043aqds_tfa_defconfig +++ b/configs/ls1043aqds_tfa_defconfig @@ -33,6 +33,8 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_IS_IN_NAND=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_BUS=y +CONFIG_ENV_SPI_BUS=0 CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y diff --git a/configs/ls1046aqds_tfa_defconfig b/configs/ls1046aqds_tfa_defconfig index f73d5fe..bfef66f 100644 --- a/configs/ls1046aqds_tfa_defconfig +++ b/configs/ls1046aqds_tfa_defconfig @@ -35,6 +35,8 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_IS_IN_NAND=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_BUS=y +CONFIG_ENV_SPI_BUS=0 CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_FSL_CAAM=y diff --git a/configs/maxbcm_defconfig b/configs/maxbcm_defconfig index 5c716cd..1521392 100644 --- a/configs/maxbcm_defconfig +++ b/configs/maxbcm_defconfig @@ -30,6 +30,8 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_TIME=y CONFIG_DEFAULT_DEVICE_TREE="armada-xp-maxbcm" +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=50000000 CONFIG_SPL_OF_TRANSLATE=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y diff --git a/configs/meesc_dataflash_defconfig b/configs/meesc_dataflash_defconfig index 54adab9..476700c 100644 --- a/configs/meesc_dataflash_defconfig +++ b/configs/meesc_dataflash_defconfig @@ -20,6 +20,8 @@ CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="at91sam9263ek" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=15000000 CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/mscc_jr2_defconfig b/configs/mscc_jr2_defconfig index 9276df2..95562b7 100644 --- a/configs/mscc_jr2_defconfig +++ b/configs/mscc_jr2_defconfig @@ -38,6 +38,10 @@ CONFIG_OF_LIST="jr2_pcb110 jr2_pcb111 serval2_pcb112" CONFIG_DTB_RESELECT=y CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=0 +CONFIG_USE_ENV_SPI_MODE=y +CONFIG_ENV_SPI_MODE=0 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y CONFIG_DM_GPIO=y diff --git a/configs/mscc_luton_defconfig b/configs/mscc_luton_defconfig index 0fdd9b8..162a514 100644 --- a/configs/mscc_luton_defconfig +++ b/configs/mscc_luton_defconfig @@ -44,6 +44,10 @@ CONFIG_OF_LIST="luton_pcb090 luton_pcb091" CONFIG_DTB_RESELECT=y CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=0 +CONFIG_USE_ENV_SPI_MODE=y +CONFIG_ENV_SPI_MODE=0 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y CONFIG_DM_GPIO=y diff --git a/configs/mscc_ocelot_defconfig b/configs/mscc_ocelot_defconfig index edc476d..b0dcfaf 100644 --- a/configs/mscc_ocelot_defconfig +++ b/configs/mscc_ocelot_defconfig @@ -43,6 +43,10 @@ CONFIG_OF_LIST="ocelot_pcb120 ocelot_pcb123" CONFIG_DTB_RESELECT=y CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=0 +CONFIG_USE_ENV_SPI_MODE=y +CONFIG_ENV_SPI_MODE=0 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y CONFIG_DM_GPIO=y diff --git a/configs/mscc_serval_defconfig b/configs/mscc_serval_defconfig index 146188b..f2c9563 100644 --- a/configs/mscc_serval_defconfig +++ b/configs/mscc_serval_defconfig @@ -35,6 +35,10 @@ CONFIG_OF_LIST="serval_pcb106 serval_pcb105" CONFIG_DTB_RESELECT=y CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=0 +CONFIG_USE_ENV_SPI_MODE=y +CONFIG_ENV_SPI_MODE=0 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y CONFIG_DM_GPIO=y diff --git a/configs/mscc_servalt_defconfig b/configs/mscc_servalt_defconfig index a450f48..027aaa4 100644 --- a/configs/mscc_servalt_defconfig +++ b/configs/mscc_servalt_defconfig @@ -33,6 +33,10 @@ CONFIG_DEFAULT_DEVICE_TREE="servalt_pcb116" CONFIG_DTB_RESELECT=y CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=0 +CONFIG_USE_ENV_SPI_MODE=y +CONFIG_ENV_SPI_MODE=0 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y CONFIG_DM_GPIO=y diff --git a/configs/net2big_v2_defconfig b/configs/net2big_v2_defconfig index 8996d52..44c8d5b 100644 --- a/configs/net2big_v2_defconfig +++ b/configs/net2big_v2_defconfig @@ -31,6 +31,8 @@ CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-net2big" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=20000000 CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y diff --git a/configs/netspace_lite_v2_defconfig b/configs/netspace_lite_v2_defconfig index e6d7724..ac103c3 100644 --- a/configs/netspace_lite_v2_defconfig +++ b/configs/netspace_lite_v2_defconfig @@ -31,6 +31,8 @@ CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2lite" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=20000000 CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y diff --git a/configs/netspace_max_v2_defconfig b/configs/netspace_max_v2_defconfig index 89df1f3..9eded36 100644 --- a/configs/netspace_max_v2_defconfig +++ b/configs/netspace_max_v2_defconfig @@ -31,6 +31,8 @@ CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2max" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=20000000 CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y diff --git a/configs/netspace_mini_v2_defconfig b/configs/netspace_mini_v2_defconfig index 9a5cf19..4b0fff4 100644 --- a/configs/netspace_mini_v2_defconfig +++ b/configs/netspace_mini_v2_defconfig @@ -29,6 +29,8 @@ CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2mini" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=20000000 CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y diff --git a/configs/netspace_v2_defconfig b/configs/netspace_v2_defconfig index bd879ab..24749f8 100644 --- a/configs/netspace_v2_defconfig +++ b/configs/netspace_v2_defconfig @@ -31,6 +31,8 @@ CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=20000000 CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y diff --git a/configs/peach-pi_defconfig b/configs/peach-pi_defconfig index cb818c5..6fc89cd 100644 --- a/configs/peach-pi_defconfig +++ b/configs/peach-pi_defconfig @@ -29,6 +29,8 @@ CONFIG_CMD_TPM_TEST=y CONFIG_CMD_EXT4_WRITE=y CONFIG_DEFAULT_DEVICE_TREE="exynos5800-peach-pi" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_BUS=y +CONFIG_ENV_SPI_BUS=1 CONFIG_I2C_CROS_EC_TUNNEL=y CONFIG_I2C_MUX=y CONFIG_I2C_ARB_GPIO_CHALLENGE=y diff --git a/configs/peach-pit_defconfig b/configs/peach-pit_defconfig index bb1558b..f091d24 100644 --- a/configs/peach-pit_defconfig +++ b/configs/peach-pit_defconfig @@ -28,6 +28,8 @@ CONFIG_CMD_TPM_TEST=y CONFIG_CMD_EXT4_WRITE=y CONFIG_DEFAULT_DEVICE_TREE="exynos5420-peach-pit" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_BUS=y +CONFIG_ENV_SPI_BUS=1 CONFIG_I2C_CROS_EC_TUNNEL=y CONFIG_I2C_MUX=y CONFIG_I2C_ARB_GPIO_CHALLENGE=y diff --git a/configs/smdk5250_defconfig b/configs/smdk5250_defconfig index d24e9e2..6741387 100644 --- a/configs/smdk5250_defconfig +++ b/configs/smdk5250_defconfig @@ -30,6 +30,8 @@ CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y CONFIG_DEFAULT_DEVICE_TREE="exynos5250-smdk5250" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_BUS=y +CONFIG_ENV_SPI_BUS=1 CONFIG_MMC_DW=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_S5P=y diff --git a/configs/smdk5420_defconfig b/configs/smdk5420_defconfig index 704786a..6a91962 100644 --- a/configs/smdk5420_defconfig +++ b/configs/smdk5420_defconfig @@ -25,6 +25,8 @@ CONFIG_CMD_TIME=y CONFIG_CMD_EXT4_WRITE=y CONFIG_DEFAULT_DEVICE_TREE="exynos5420-smdk5420" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_BUS=y +CONFIG_ENV_SPI_BUS=1 CONFIG_MMC_DW=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_S5P=y diff --git a/configs/snow_defconfig b/configs/snow_defconfig index 6179a64..54bf740 100644 --- a/configs/snow_defconfig +++ b/configs/snow_defconfig @@ -34,6 +34,8 @@ CONFIG_CMD_TPM_TEST=y CONFIG_CMD_EXT4_WRITE=y CONFIG_DEFAULT_DEVICE_TREE="exynos5250-snow" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_BUS=y +CONFIG_ENV_SPI_BUS=1 CONFIG_I2C_CROS_EC_LDO=y CONFIG_I2C_MUX=y CONFIG_I2C_ARB_GPIO_CHALLENGE=y diff --git a/configs/spring_defconfig b/configs/spring_defconfig index 2bbfa6d..c24aa2e 100644 --- a/configs/spring_defconfig +++ b/configs/spring_defconfig @@ -34,6 +34,8 @@ CONFIG_CMD_TPM_TEST=y CONFIG_CMD_EXT4_WRITE=y CONFIG_DEFAULT_DEVICE_TREE="exynos5250-spring" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_BUS=y +CONFIG_ENV_SPI_BUS=1 CONFIG_I2C_CROS_EC_LDO=y CONFIG_I2C_MUX=y CONFIG_I2C_ARB_GPIO_CHALLENGE=y diff --git a/configs/stmark2_defconfig b/configs/stmark2_defconfig index d74ba67..630b01c 100644 --- a/configs/stmark2_defconfig +++ b/configs/stmark2_defconfig @@ -20,6 +20,8 @@ CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=spi-flash.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=spi-flash.0:1m(u-boot),7m(kernel),-(rootfs)" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_CS=y +CONFIG_ENV_SPI_CS=1 # CONFIG_NET is not set CONFIG_MTD_DEVICE=y CONFIG_SPI_FLASH=y diff --git a/configs/theadorable_debug_defconfig b/configs/theadorable_debug_defconfig index cd52220..fb9307a 100644 --- a/configs/theadorable_debug_defconfig +++ b/configs/theadorable_debug_defconfig @@ -46,6 +46,8 @@ CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_DEFAULT_DEVICE_TREE="armada-xp-theadorable" +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=50000000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_SATA_MV=y diff --git a/configs/trimslice_defconfig b/configs/trimslice_defconfig index be6be27..1c4f81a 100644 --- a/configs/trimslice_defconfig +++ b/configs/trimslice_defconfig @@ -24,6 +24,8 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="tegra20-trimslice" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=48000000 CONFIG_SPL_DM=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/turris_omnia_defconfig b/configs/turris_omnia_defconfig index 7e5943b..c406b25 100644 --- a/configs/turris_omnia_defconfig +++ b/configs/turris_omnia_defconfig @@ -35,6 +35,8 @@ CONFIG_CMD_BTRFS=y # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_DEFAULT_DEVICE_TREE="armada-385-turris-omnia" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=50000000 CONFIG_SPL_OF_TRANSLATE=y CONFIG_SCSI_AHCI=y CONFIG_ATSHA204A=y diff --git a/configs/usb_a9263_dataflash_defconfig b/configs/usb_a9263_dataflash_defconfig index 9f7506f..3b9e4a5 100644 --- a/configs/usb_a9263_dataflash_defconfig +++ b/configs/usb_a9263_dataflash_defconfig @@ -25,6 +25,8 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=atmel_nand:16m(kernel)ro,120m(root1),-(root2)" CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="usb_a9263" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_USE_ENV_SPI_MAX_HZ=y +CONFIG_ENV_SPI_MAX_HZ=15000000 CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/env/Kconfig b/env/Kconfig index c22cbbd..7830066 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -324,18 +324,57 @@ config ENV_IS_IN_SPI_FLASH during a "saveenv" operation. CONFIG_ENV_OFFSET_REDUND must be aligned to an erase sector boundary.
- - CONFIG_ENV_SPI_BUS (optional): - - CONFIG_ENV_SPI_CS (optional): +config USE_ENV_SPI_BUS + bool "SPI flash bus for environment" + depends on ENV_IS_IN_SPI_FLASH + help + Force the SPI bus for environment. + If not defined, use CONFIG_SF_DEFAULT_BUS. + +config ENV_SPI_BUS + int "Value of SPI flash bus for environment" + depends on USE_ENV_SPI_BUS + help + Value the SPI bus and chip select for environment. + +config USE_ENV_SPI_CS + bool "SPI flash chip select for environment" + depends on ENV_IS_IN_SPI_FLASH + help + Force the SPI chip select for environment. + If not defined, use CONFIG_SF_DEFAULT_CS.
- Define the SPI bus and chip select. If not defined they will be 0. +config ENV_SPI_CS + int "Value of SPI flash chip select for environment" + depends on USE_ENV_SPI_CS + help + Value of the SPI chip select for environment.
- - CONFIG_ENV_SPI_MAX_HZ (optional): +config USE_ENV_SPI_MAX_HZ + bool "SPI flash bus for environment" + depends on ENV_IS_IN_SPI_FLASH + help + Force the SPI max work clock for environment. + If not defined, use CONFIG_SF_DEFAULT_SPEED.
- Define the SPI max work clock. If not defined then use 1MHz. +config ENV_SPI_MAX_HZ + int "Value of SPI flash max work for environment" + depends on USE_ENV_SPI_MAX_HZ + help + Value of the SPI max work clock for environment.
- - CONFIG_ENV_SPI_MODE (optional): +config USE_ENV_SPI_MODE + bool "SPI flash mode for environment" + depends on ENV_IS_IN_SPI_FLASH + help + Force the SPI work mode for environment.
- Define the SPI work mode. If not defined then use SPI_MODE_3. +config ENV_SPI_MODE + hex "Value of SPI flash work mode for environment" + depends on USE_ENV_SPI_MODE + help + Value of the SPI work mode for environment. + See include/spi.h for value.
config ENV_IS_IN_UBI bool "Environment in a UBI volume" diff --git a/env/sf.c b/env/sf.c index b3dec82..6300b16 100644 --- a/env/sf.c +++ b/env/sf.c @@ -18,19 +18,6 @@ #include <errno.h> #include <dm/device-internal.h>
-#ifndef CONFIG_ENV_SPI_BUS -# define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS -#endif -#ifndef CONFIG_ENV_SPI_CS -# define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS -#endif -#ifndef CONFIG_ENV_SPI_MAX_HZ -# define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED -#endif -#ifndef CONFIG_ENV_SPI_MODE -# define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE -#endif - #ifndef CONFIG_SPL_BUILD #define CMD_SAVEENV #define INITENV diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index 3239696..19d2ee1 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -99,10 +99,6 @@ #define CONFIG_ENV_OVERWRITE
#if defined(CONFIG_SPIFLASH) -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 10000000 -#define CONFIG_ENV_SPI_MODE 0 #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 diff --git a/include/configs/BSC9131RDB.h b/include/configs/BSC9131RDB.h index 49bea98..c01071e 100644 --- a/include/configs/BSC9131RDB.h +++ b/include/configs/BSC9131RDB.h @@ -253,10 +253,6 @@ extern unsigned long get_sdram_size(void); * Environment */ #if defined(CONFIG_RAMBOOT_SPIFLASH) -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 10000000 -#define CONFIG_ENV_SPI_MODE 0 #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 #define CONFIG_ENV_SIZE 0x2000 diff --git a/include/configs/BSC9132QDS.h b/include/configs/BSC9132QDS.h index 45264c4..3be4fbe 100644 --- a/include/configs/BSC9132QDS.h +++ b/include/configs/BSC9132QDS.h @@ -455,10 +455,6 @@ combinations. this should be removed later #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_RAMBOOT_SPIFLASH) -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 10000000 -#define CONFIG_ENV_SPI_MODE 0 #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 #define CONFIG_ENV_SIZE 0x2000 diff --git a/include/configs/C29XPCIE.h b/include/configs/C29XPCIE.h index a18d041..9b83a50 100644 --- a/include/configs/C29XPCIE.h +++ b/include/configs/C29XPCIE.h @@ -380,10 +380,6 @@ */ #if defined(CONFIG_SYS_RAMBOOT) #if defined(CONFIG_RAMBOOT_SPIFLASH) -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 10000000 -#define CONFIG_ENV_SPI_MODE 0 #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 #define CONFIG_ENV_SIZE 0x2000 diff --git a/include/configs/M52277EVB.h b/include/configs/M52277EVB.h index 83d7745..514733e 100644 --- a/include/configs/M52277EVB.h +++ b/include/configs/M52277EVB.h @@ -177,9 +177,6 @@ * Environment is not embedded in u-boot. First time runing may have env * crc error warning if there is no correct environment on the flash. */ -#ifdef CONFIG_CF_SBF -# define CONFIG_ENV_SPI_CS 2 -#endif #define CONFIG_ENV_OVERWRITE 1
/*----------------------------------------------------------------------- diff --git a/include/configs/M54418TWR.h b/include/configs/M54418TWR.h index 4b8ef38..f7b0669 100644 --- a/include/configs/M54418TWR.h +++ b/include/configs/M54418TWR.h @@ -238,7 +238,6 @@ #endif
#if defined(CONFIG_CF_SBF) -#define CONFIG_ENV_SPI_CS 1 #define CONFIG_ENV_OFFSET 0x40000 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x10000 diff --git a/include/configs/M54451EVB.h b/include/configs/M54451EVB.h index 87cdbae..57c8572 100644 --- a/include/configs/M54451EVB.h +++ b/include/configs/M54451EVB.h @@ -198,7 +198,6 @@ * crc error warning if there is no correct environment on the flash. */ #if defined(CONFIG_SYS_STMICRO_BOOT) -# define CONFIG_ENV_SPI_CS 1 # define CONFIG_ENV_OFFSET 0x20000 # define CONFIG_ENV_SIZE 0x2000 # define CONFIG_ENV_SECT_SIZE 0x10000 diff --git a/include/configs/M54455EVB.h b/include/configs/M54455EVB.h index d41b7c4..448dfc9 100644 --- a/include/configs/M54455EVB.h +++ b/include/configs/M54455EVB.h @@ -248,9 +248,6 @@ * Environment is not embedded in u-boot. First time runing may have env * crc error warning if there is no correct environment on the flash. */ -#ifdef CONFIG_CF_SBF -# define CONFIG_ENV_SPI_CS 1 -#endif #undef CONFIG_ENV_OVERWRITE
/*----------------------------------------------------------------------- diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index fedd151..0ad970b 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -525,10 +525,6 @@
#if defined(CONFIG_SYS_RAMBOOT) #if defined(CONFIG_RAMBOOT_SPIFLASH) -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 10000000 -#define CONFIG_ENV_SPI_MODE 0 #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #define CONFIG_ENV_OFFSET 0xF0000 #define CONFIG_ENV_SECT_SIZE 0x10000 diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index cefa598..4be40d0 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -644,10 +644,6 @@ extern unsigned long get_sdram_size(void); #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_SPIFLASH) -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 10000000 -#define CONFIG_ENV_SPI_MODE 0 #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 #define CONFIG_ENV_SIZE 0x2000 diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index 8bdbabe..bdbf119 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -503,10 +503,6 @@ * Environment */ #ifdef CONFIG_SPIFLASH -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 10000000 -#define CONFIG_ENV_SPI_MODE 0 #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index da43320..b433308 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -49,10 +49,6 @@ #define CONFIG_ENV_OVERWRITE
#if defined(CONFIG_SPIFLASH) - #define CONFIG_ENV_SPI_BUS 0 - #define CONFIG_ENV_SPI_CS 0 - #define CONFIG_ENV_SPI_MAX_HZ 10000000 - #define CONFIG_ENV_SPI_MODE 0 #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 diff --git a/include/configs/SBx81LIFKW.h b/include/configs/SBx81LIFKW.h index d62fd35..1539e8f 100644 --- a/include/configs/SBx81LIFKW.h +++ b/include/configs/SBx81LIFKW.h @@ -56,10 +56,6 @@ /* * Environment variables configurations */ -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 20000000 /* 20Mhz */ -#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE #define CONFIG_ENV_SECT_SIZE 0x40000 /* 256K */ #define CONFIG_ENV_SIZE 0x02000 #define CONFIG_ENV_OFFSET 0xc0000 /* env starts here - 768K */ diff --git a/include/configs/SBx81LIFXCAT.h b/include/configs/SBx81LIFXCAT.h index 3c8c216..af19193 100644 --- a/include/configs/SBx81LIFXCAT.h +++ b/include/configs/SBx81LIFXCAT.h @@ -56,10 +56,6 @@ /* * Environment variables configurations */ -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 20000000 /* 20Mhz */ -#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE #define CONFIG_ENV_SECT_SIZE 0x40000 /* 256K */ #define CONFIG_ENV_SIZE 0x02000 #define CONFIG_ENV_OFFSET 0xc0000 /* env starts here - 768K */ diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index 73b70fa..ef94097 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -129,10 +129,6 @@ #endif
#if defined(CONFIG_SPIFLASH) -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 10000000 -#define CONFIG_ENV_SPI_MODE 0 #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 078df7f..1c205a0 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -144,10 +144,6 @@ #endif
#if defined(CONFIG_SPIFLASH) -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 10000000 -#define CONFIG_ENV_SPI_MODE 0 #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ #if defined(CONFIG_TARGET_T1024RDB) diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index c886fe2..d2eb43f 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -59,10 +59,6 @@
#ifdef CONFIG_MTD_NOR_FLASH #if defined(CONFIG_SPIFLASH) -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 10000000 -#define CONFIG_ENV_SPI_MODE 0 #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 0d92f27..a7e0f8f 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -521,10 +521,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg /* * eSPI - Enhanced SPI */ -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 10000000 -#define CONFIG_ENV_SPI_MODE 0
/* * General PCI diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 9864064..0c8e6b4 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -125,10 +125,6 @@ #endif
#if defined(CONFIG_SPIFLASH) -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 10000000 -#define CONFIG_ENV_SPI_MODE 0 #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 95e9ed3..1a94535 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -110,10 +110,6 @@ #define CONFIG_SYS_MEMTEST_END 0x00400000
#if defined(CONFIG_SPIFLASH) -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 10000000 -#define CONFIG_ENV_SPI_MODE 0 #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 diff --git a/include/configs/T4240QDS.h b/include/configs/T4240QDS.h index 80a4b13..9e70412 100644 --- a/include/configs/T4240QDS.h +++ b/include/configs/T4240QDS.h @@ -74,10 +74,6 @@ #include "t4qds.h"
#if defined(CONFIG_SPIFLASH) -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 10000000 -#define CONFIG_ENV_SPI_MODE 0 #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index 066e8dd..0554c58 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -281,10 +281,6 @@ "bootm 0x01000000 - 0x00f00000"
#if defined(CONFIG_SPIFLASH) -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 10000000 -#define CONFIG_ENV_SPI_MODE 0 #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 diff --git a/include/configs/UCP1020.h b/include/configs/UCP1020.h index 69d43c4..1c888f0 100644 --- a/include/configs/UCP1020.h +++ b/include/configs/UCP1020.h @@ -329,10 +329,6 @@
#else
#ifdef CONFIG_RAMBOOT_SPIFLASH
diff --git a/include/configs/adp-ae3xx.h b/include/configs/adp-ae3xx.h index f2268dc..1fe3391 100644 --- a/include/configs/adp-ae3xx.h +++ b/include/configs/adp-ae3xx.h @@ -201,10 +201,6 @@ #define CONFIG_SYS_MAX_FLASH_SECT 512
/* environments */ -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 50000000 -#define CONFIG_ENV_SPI_MODE 0 #define CONFIG_ENV_SECT_SIZE 0x1000 #define CONFIG_ENV_OFFSET 0x140000 #define CONFIG_ENV_SIZE 8192 diff --git a/include/configs/advantech_dms-ba16.h b/include/configs/advantech_dms-ba16.h index a08f62b..e2c7060 100644 --- a/include/configs/advantech_dms-ba16.h +++ b/include/configs/advantech_dms-ba16.h @@ -212,10 +212,6 @@ #define CONFIG_ENV_SIZE (8 * 1024) #define CONFIG_ENV_OFFSET (768 * 1024) #define CONFIG_ENV_SECT_SIZE (64 * 1024) -#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS -#define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS -#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE -#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED
#define CONFIG_SYS_FSL_USDHC_NUM 3
diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index d8f0583..0834ff5 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -284,7 +284,6 @@ #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000
#define CONFIG_SYS_REDUNDAND_ENVIRONMENT -#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED #define CONFIG_ENV_SECT_SIZE (4 << 10) /* 4 KB sectors */ #define CONFIG_ENV_OFFSET (768 << 10) /* 768 KiB in */ #define CONFIG_ENV_OFFSET_REDUND (896 << 10) /* 896 KiB in */ diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 55faa7b..5a60806 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -115,7 +115,6 @@
#ifdef CONFIG_QSPI_BOOT #define CONFIG_SYS_REDUNDAND_ENVIRONMENT -#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED #define CONFIG_ENV_SECT_SIZE (64 << 10) /* 64 KB sectors */ #define CONFIG_ENV_OFFSET 0x110000 #define CONFIG_ENV_OFFSET_REDUND 0x120000 diff --git a/include/configs/ap121.h b/include/configs/ap121.h index 96850b5..0e8c3f7 100644 --- a/include/configs/ap121.h +++ b/include/configs/ap121.h @@ -30,7 +30,6 @@ "mtdparts default;" \ "bootm 0x9f650000"
-#define CONFIG_ENV_SPI_MAX_HZ 25000000 #define CONFIG_ENV_OFFSET 0x40000 #define CONFIG_ENV_SECT_SIZE 0x10000 #define CONFIG_ENV_SIZE 0x10000 diff --git a/include/configs/ap143.h b/include/configs/ap143.h index 4dbca91..fa69210 100644 --- a/include/configs/ap143.h +++ b/include/configs/ap143.h @@ -34,7 +34,6 @@ "mtdparts default;" \ "bootm 0x9f680000"
-#define CONFIG_ENV_SPI_MAX_HZ 25000000 #define CONFIG_ENV_OFFSET 0x40000 #define CONFIG_ENV_SECT_SIZE 0x10000 #define CONFIG_ENV_SIZE 0x10000 diff --git a/include/configs/aristainetos-common.h b/include/configs/aristainetos-common.h index eecc021..4f28f52 100644 --- a/include/configs/aristainetos-common.h +++ b/include/configs/aristainetos-common.h @@ -149,10 +149,6 @@ /* Environment organization */ #define CONFIG_ENV_SIZE (12 * 1024) #define CONFIG_SYS_REDUNDAND_ENVIRONMENT -#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS -#define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS -#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED -#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE #define CONFIG_ENV_SECT_SIZE (0x010000) #define CONFIG_ENV_OFFSET (0x0d0000) #define CONFIG_ENV_OFFSET_REDUND (0x0e0000) diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index 2177512..95710fb 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -118,7 +118,6 @@ #define CONFIG_ENV_OFFSET 0x4200 #define CONFIG_ENV_SIZE 0x4200 #define CONFIG_ENV_SECT_SIZE 0x210 -#define CONFIG_ENV_SPI_MAX_HZ 15000000 #define CONFIG_BOOTCOMMAND "sf probe 0:0; " \ "sf read 0x22000000 0x84000 0x294000; " \ "bootm 0x22000000" @@ -128,7 +127,6 @@ #define CONFIG_ENV_OFFSET 0x4200 #define CONFIG_ENV_SIZE 0x4200 #define CONFIG_ENV_SECT_SIZE 0x210 -#define CONFIG_ENV_SPI_MAX_HZ 15000000 #define CONFIG_BOOTCOMMAND "sf probe 0:1; " \ "sf read 0x22000000 0x84000 0x294000; " \ "bootm 0x22000000" diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index 1c7fbe1..599e262 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -104,7 +104,6 @@ #define CONFIG_ENV_OFFSET 0x4200 #define CONFIG_ENV_SIZE 0x4200 #define CONFIG_ENV_SECT_SIZE 0x210 -#define CONFIG_ENV_SPI_MAX_HZ 15000000 #define CONFIG_BOOTCOMMAND "sf probe 0; " \ "sf read 0x22000000 0x84000 0x294000; " \ "bootm 0x22000000" @@ -115,7 +114,6 @@ #define CONFIG_ENV_OFFSET 0x4200 #define CONFIG_ENV_SIZE 0x4200 #define CONFIG_ENV_SECT_SIZE 0x210 -#define CONFIG_ENV_SPI_MAX_HZ 15000000 #define CONFIG_BOOTCOMMAND "sf probe 0:3; " \ "sf read 0x22000000 0x84000 0x294000; " \ "bootm 0x22000000" diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index 856e032..6b1db9f 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -222,7 +222,6 @@ #define CONFIG_ENV_OFFSET 0x4200 #define CONFIG_ENV_SIZE 0x4200 #define CONFIG_ENV_SECT_SIZE 0x210 -#define CONFIG_ENV_SPI_MAX_HZ 15000000 #define CONFIG_BOOTCOMMAND "sf probe 0; " \ "sf read 0x22000000 0x84000 0x294000; " \ "bootm 0x22000000" diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index b052071..3e18716 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -76,7 +76,6 @@ #define CONFIG_ENV_OFFSET 0x4200 #define CONFIG_ENV_SIZE 0x4200 #define CONFIG_ENV_SECT_SIZE 0x210 -#define CONFIG_ENV_SPI_MAX_HZ 15000000 #define CONFIG_BOOTCOMMAND "sf probe 0; " \ "sf read 0x22000000 0x84000 0x294000; " \ "bootm 0x22000000" diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index d43d408..1abca55 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -84,7 +84,6 @@ #define CONFIG_ENV_OFFSET 0x5000 #define CONFIG_ENV_SIZE 0x3000 #define CONFIG_ENV_SECT_SIZE 0x1000 -#define CONFIG_ENV_SPI_MAX_HZ 30000000 #define CONFIG_BOOTCOMMAND "sf probe 0; " \ "sf read 0x22000000 0x100000 0x300000; " \ "bootm 0x22000000" @@ -93,7 +92,6 @@ #define CONFIG_ENV_OFFSET 0x4200 #define CONFIG_ENV_SIZE 0x4200 #define CONFIG_ENV_SECT_SIZE 0x210 -#define CONFIG_ENV_SPI_MAX_HZ 30000000 #define CONFIG_BOOTCOMMAND "sf probe 0; " \ "sf read 0x22000000 0x84000 0x294000; " \ "bootm 0x22000000" diff --git a/include/configs/ax25-ae350.h b/include/configs/ax25-ae350.h index cd07212..395f3a4 100644 --- a/include/configs/ax25-ae350.h +++ b/include/configs/ax25-ae350.h @@ -113,10 +113,6 @@ #define CONFIG_SYS_MAX_FLASH_SECT 512
/* environments */ -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 50000000 -#define CONFIG_ENV_SPI_MODE 0 #define CONFIG_ENV_SECT_SIZE 0x1000 #define CONFIG_ENV_OVERWRITE
diff --git a/include/configs/bav335x.h b/include/configs/bav335x.h index 8936222..fb9c2a6 100644 --- a/include/configs/bav335x.h +++ b/include/configs/bav335x.h @@ -453,7 +453,6 @@ DEFAULT_LINUX_BOOT_ENV \ #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000
#define CONFIG_SYS_REDUNDAND_ENVIRONMENT -#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED #define CONFIG_ENV_SECT_SIZE (4 << 10) /* 4 KB sectors */ #define CONFIG_ENV_OFFSET (768 << 10) /* 768 KiB in */ #define CONFIG_ENV_OFFSET_REDUND (896 << 10) /* 896 KiB in */ diff --git a/include/configs/bg0900.h b/include/configs/bg0900.h index 0c3d54a..832dbba 100644 --- a/include/configs/bg0900.h +++ b/include/configs/bg0900.h @@ -21,10 +21,6 @@
/* SPI FLASH */ #ifdef CONFIG_CMD_SF -#define CONFIG_ENV_SPI_BUS 2 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 40000000 -#define CONFIG_ENV_SPI_MODE SPI_MODE_0 #endif
/* Boot Linux */ diff --git a/include/configs/brppt1.h b/include/configs/brppt1.h index 2219663..ae9b75b 100644 --- a/include/configs/brppt1.h +++ b/include/configs/brppt1.h @@ -190,7 +190,6 @@ NANDTGTS \ #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x40000 /* Environment */ #define CONFIG_SYS_REDUNDAND_ENVIRONMENT -#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED #define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE #define CONFIG_ENV_OFFSET 0x20000 #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ diff --git a/include/configs/cgtqmx6eval.h b/include/configs/cgtqmx6eval.h index ab8d1c6..ad0a64a 100644 --- a/include/configs/cgtqmx6eval.h +++ b/include/configs/cgtqmx6eval.h @@ -217,10 +217,6 @@ #if defined(CONFIG_ENV_IS_IN_SPI_FLASH) #define CONFIG_ENV_OFFSET (768 * 1024) #define CONFIG_ENV_SECT_SIZE (64 * 1024) -#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS -#define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS -#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE -#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED #endif
#endif /* __CONFIG_CGTQMX6EVAL_H */ diff --git a/include/configs/cl-som-am57x.h b/include/configs/cl-som-am57x.h index 687a9e7..bf2bb44 100644 --- a/include/configs/cl-som-am57x.h +++ b/include/configs/cl-som-am57x.h @@ -42,7 +42,6 @@
#define CONFIG_ENV_SECT_SIZE (64 * 1024) #define CONFIG_ENV_OFFSET (768 * 1024) -#define CONFIG_ENV_SPI_MAX_HZ 48000000
/* EEPROM */ #define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 diff --git a/include/configs/cl-som-imx7.h b/include/configs/cl-som-imx7.h index d895f89..26d1a97 100644 --- a/include/configs/cl-som-imx7.h +++ b/include/configs/cl-som-imx7.h @@ -145,10 +145,6 @@ #define CONFIG_ENV_SIZE SZ_8K #define CONFIG_ENV_OFFSET (768 * 1024) #define CONFIG_ENV_SECT_SIZE (64 * 1024) -#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS -#define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS -#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE -#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED
/* MMC Config*/ #define CONFIG_FSL_USDHC diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index 2ac888f..dfd96ff 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -46,10 +46,6 @@ #endif
/* Environment */ -#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED -#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE -#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS -#define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS #define CONFIG_ENV_SECT_SIZE (64 * 1024) #define CONFIG_ENV_SIZE (8 * 1024) #define CONFIG_ENV_OFFSET (768 * 1024) diff --git a/include/configs/cm_t43.h b/include/configs/cm_t43.h index 6df8b8b..ffe4a44 100644 --- a/include/configs/cm_t43.h +++ b/include/configs/cm_t43.h @@ -85,7 +85,6 @@
#define CONFIG_EXTRA_ENV_SETTINGS \ "loadaddr=0x80200000\0" \ diff --git a/include/configs/controlcenterd.h b/include/configs/controlcenterd.h index 69c65f1..f1c3522 100644 --- a/include/configs/controlcenterd.h +++ b/include/configs/controlcenterd.h @@ -275,10 +275,6 @@ #if defined(CONFIG_TRAILBLAZER) #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #elif defined(CONFIG_RAMBOOT_SPIFLASH) -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 10000000 -#define CONFIG_ENV_SPI_MODE 0 #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 diff --git a/include/configs/controlcenterdc.h b/include/configs/controlcenterdc.h index edd8749..9130837 100644 --- a/include/configs/controlcenterdc.h +++ b/include/configs/controlcenterdc.h @@ -43,7 +43,6 @@ #define CONFIG_EHCI_IS_TDI
/* Environment in SPI NOR flash */ -#define CONFIG_ENV_SPI_BUS 1 #define CONFIG_ENV_OFFSET (1 << 20) /* 1MiB in */ #define CONFIG_ENV_SIZE (64 << 10) /* 64KiB */ #define CONFIG_ENV_SECT_SIZE (256 << 10) /* 256KiB sectors */ diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index a3963db..f974291 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -60,10 +60,6 @@ #define CONFIG_ENV_OVERWRITE
#if defined(CONFIG_SPIFLASH) -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 10000000 -#define CONFIG_ENV_SPI_MODE 0 #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 7b1e53f..583f994 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -124,8 +124,6 @@ #ifdef CONFIG_SPL_BUILD #define CONFIG_SYS_SPI_BASE DAVINCI_SPI1_BASE #endif -#define CONFIG_ENV_SPI_MAX_HZ 0 -#define CONFIG_ENV_SPI_MODE 0
#ifdef CONFIG_USE_SPIFLASH #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x8000 diff --git a/include/configs/db-88f6820-amc.h b/include/configs/db-88f6820-amc.h index 222bdf8..f1bdc2d 100644 --- a/include/configs/db-88f6820-amc.h +++ b/include/configs/db-88f6820-amc.h @@ -22,7 +22,6 @@ #define CONFIG_EHCI_IS_TDI
/* Environment in SPI NOR flash */ -#define CONFIG_ENV_SPI_BUS 1 #define CONFIG_ENV_OFFSET (1 << 20) /* 1MiB in */ #define CONFIG_ENV_SIZE (64 << 10) /* 64KiB */ #define CONFIG_ENV_SECT_SIZE (256 << 10) /* 256KiB sectors */ diff --git a/include/configs/db-88f6820-gp.h b/include/configs/db-88f6820-gp.h index 967b133..d378052 100644 --- a/include/configs/db-88f6820-gp.h +++ b/include/configs/db-88f6820-gp.h @@ -26,8 +26,6 @@ /* * SPI Flash configuration for the environemnt access */ -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0
/* SPI NOR flash default params, used by sf commands */
diff --git a/include/configs/dh_imx6.h b/include/configs/dh_imx6.h index 1c1178c3..48514ff 100644 --- a/include/configs/dh_imx6.h +++ b/include/configs/dh_imx6.h @@ -163,10 +163,6 @@ #define CONFIG_ENV_OFFSET_REDUND \ (CONFIG_ENV_OFFSET + CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE -#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS -#define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS -#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE -#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED #endif
#endif /* __DH_IMX6_CONFIG_H */ diff --git a/include/configs/display5.h b/include/configs/display5.h index d729054..8ab47ab 100644 --- a/include/configs/display5.h +++ b/include/configs/display5.h @@ -374,11 +374,6 @@ #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE - -#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS -#define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS -#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE -#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED #endif
#define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index 36e1582..10eac20 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -91,7 +91,6 @@ #define CONFIG_SYS_SPI_ARGS_SIZE 0x80000 #if defined(CONFIG_QSPI_BOOT) #define CONFIG_SYS_REDUNDAND_ENVIRONMENT -#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED #define CONFIG_ENV_SIZE (64 << 10) #define CONFIG_ENV_SECT_SIZE (64 << 10) /* 64 KB sectors */ #define CONFIG_ENV_OFFSET 0x1C0000 diff --git a/include/configs/dreamplug.h b/include/configs/dreamplug.h index f4d7172..28bda14 100644 --- a/include/configs/dreamplug.h +++ b/include/configs/dreamplug.h @@ -35,9 +35,6 @@ #endif
#ifdef CONFIG_CMD_SF -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 50000000 /* 50 MHz */ #endif
/* diff --git a/include/configs/ds109.h b/include/configs/ds109.h index 2c7928e..07367cf 100644 --- a/include/configs/ds109.h +++ b/include/configs/ds109.h @@ -38,9 +38,6 @@ #endif
/* diff --git a/include/configs/ea20.h b/include/configs/ea20.h index 800ce03..88f2e17 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -52,7 +52,6 @@
#define CONFIG_SYS_SPI_BASE DAVINCI_SPI1_BASE #define CONFIG_SYS_SPI_CLK clk_get(DAVINCI_SPI1_CLKID) -#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED
/* * I2C Configuration diff --git a/include/configs/embestmx6boards.h b/include/configs/embestmx6boards.h index f984540..5142680 100644 --- a/include/configs/embestmx6boards.h +++ b/include/configs/embestmx6boards.h @@ -83,10 +83,6 @@ #define CONFIG_SYS_FSL_USDHC_NUM 2 #define CONFIG_ENV_OFFSET (768 * 1024) #define CONFIG_ENV_SECT_SIZE (8 * 1024) -#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS -#define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS -#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE -#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED #endif
/* Framebuffer */ diff --git a/include/configs/ethernut5.h b/include/configs/ethernut5.h index 0d84c97..b86b542 100644 --- a/include/configs/ethernut5.h +++ b/include/configs/ethernut5.h @@ -54,7 +54,6 @@ #define CONFIG_ENV_OFFSET 0x3DE000 #define CONFIG_ENV_SIZE (132 << 10) #define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE -#define CONFIG_ENV_SPI_MAX_HZ 15000000
/* NAND flash */ #ifdef CONFIG_CMD_NAND diff --git a/include/configs/exynos5-common.h b/include/configs/exynos5-common.h index 5641f09..db1fc93 100644 --- a/include/configs/exynos5-common.h +++ b/include/configs/exynos5-common.h @@ -110,10 +110,7 @@ /* SPI */
#ifdef CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_ENV_SPI_MODE SPI_MODE_0 #define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE -#define CONFIG_ENV_SPI_BUS 1 -#define CONFIG_ENV_SPI_MAX_HZ 50000000 #endif
/* Ethernet Controllor Driver */ diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index 9ca3ee3..3336578 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -172,10 +172,6 @@ #define CONFIG_ENV_SIZE (8 * 1024) #define CONFIG_ENV_OFFSET (768 * 1024) #define CONFIG_ENV_SECT_SIZE (64 * 1024) -#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS -#define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS -#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE -#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED
diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index a4215c8..84ee44e 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -181,10 +181,6 @@ #define CONFIG_ENV_OFFSET (512 * SZ_1K) #define CONFIG_ENV_SECT_SIZE (64 * SZ_1K) #define CONFIG_ENV_SIZE (8 * SZ_1K) - #define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS - #define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS - #define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE - #define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED #endif
/* Environment */ diff --git a/include/configs/helios4.h b/include/configs/helios4.h index 5a11641..df4d8bc 100644 --- a/include/configs/helios4.h +++ b/include/configs/helios4.h @@ -45,13 +45,6 @@ CONFIG_SYS_SCSI_MAX_LUN)
#ifdef CONFIG_MVEBU_SPL_BOOT_DEVICE_SPI -/* - * SPI Flash configuration for the environment access - */ -#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS -#define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS -#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED - /* Environment in SPI NOR flash */ #define CONFIG_ENV_SECT_SIZE SZ_64K #define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE diff --git a/include/configs/km/km_arm.h b/include/configs/km/km_arm.h index f93629e..a2e9cf1 100644 --- a/include/configs/km/km_arm.h +++ b/include/configs/km/km_arm.h @@ -35,10 +35,6 @@ /* SPI NOR Flash default params, used by sf commands */
#if defined CONFIG_KM_ENV_IS_IN_SPI_NOR -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 8100000 -#define CONFIG_ENV_SPI_MODE SPI_MODE_3 #endif
/* Reserve 4 MB for malloc */ diff --git a/include/configs/km/kmp204x-common.h b/include/configs/km/kmp204x-common.h index 810d66a..7343f95 100644 --- a/include/configs/km/kmp204x-common.h +++ b/include/configs/km/kmp204x-common.h @@ -39,10 +39,6 @@ #define CONFIG_SYS_DPAA_RMAN /* RMan */
/* Environment in SPI Flash */ -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 20000000 -#define CONFIG_ENV_SPI_MODE 0 #define CONFIG_ENV_OFFSET 0x100000 /* 1MB for u-boot */ #define CONFIG_ENV_SIZE 0x004000 /* 16K env */ #define CONFIG_ENV_SECT_SIZE 0x010000 diff --git a/include/configs/lacie_kw.h b/include/configs/lacie_kw.h index 1f619a0..1ba28b5 100644 --- a/include/configs/lacie_kw.h +++ b/include/configs/lacie_kw.h @@ -65,10 +65,8 @@ #include "mv-common.h"
/* Remove or override few declarations from mv-common.h */ -#undef CONFIG_ENV_SPI_MAX_HZ #undef CONFIG_SYS_IDE_MAXBUS #undef CONFIG_SYS_IDE_MAXDEVICE -#define CONFIG_ENV_SPI_MAX_HZ 20000000 /* 20Mhz */
/* * Enable platform initialisation via misc_init_r() function diff --git a/include/configs/legoev3.h b/include/configs/legoev3.h index ce806d1..1e239ec 100644 --- a/include/configs/legoev3.h +++ b/include/configs/legoev3.h @@ -47,7 +47,6 @@
#define CONFIG_SYS_SPI_BASE DAVINCI_SPI0_BASE #define CONFIG_SYS_SPI_CLK clk_get(DAVINCI_SPI0_CLKID) -#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED
/* * I2C Configuration diff --git a/include/configs/ls1012a_common.h b/include/configs/ls1012a_common.h index 324dba2..9189773 100644 --- a/include/configs/ls1012a_common.h +++ b/include/configs/ls1012a_common.h @@ -41,10 +41,6 @@ #if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_TFABOOT) #define CONFIG_SYS_QE_FW_IN_SPIFLASH #define CONFIG_SYS_FMAN_FW_ADDR 0x400d0000 -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 1000000 -#define CONFIG_ENV_SPI_MODE 0x03 #define CONFIG_SPI_FLASH_SPANSION #define CONFIG_FSL_SPI_INTERFACE #define CONFIG_SF_DATAFLASH diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index b34c765..6fee15f 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -187,10 +187,6 @@ #define CONFIG_SYS_FMAN_FW_ADDR 0x900000 #define CONFIG_SYS_QE_FW_ADDR 0x940000
#else #ifdef CONFIG_NAND_BOOT @@ -209,10 +205,6 @@ #elif defined(CONFIG_QSPI_BOOT) #define CONFIG_SYS_QE_FW_IN_SPIFLASH #define CONFIG_SYS_FMAN_FW_ADDR 0x40900000 -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 1000000 -#define CONFIG_ENV_SPI_MODE 0x03 #else #define CONFIG_SYS_QE_FMAN_FW_IN_NOR /* FMan fireware Pre-load address */ diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index 6e36c93..7d913be 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -171,10 +171,6 @@
#ifdef CONFIG_TFABOOT #define CONFIG_SYS_FMAN_FW_ADDR 0x900000 -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 1000000 -#define CONFIG_ENV_SPI_MODE 0x03 #else #ifdef CONFIG_SD_BOOT /* @@ -187,10 +183,6 @@ #elif defined(CONFIG_QSPI_BOOT) #define CONFIG_SYS_QE_FW_IN_SPIFLASH #define CONFIG_SYS_FMAN_FW_ADDR 0x40900000 -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 1000000 -#define CONFIG_ENV_SPI_MODE 0x03 #elif defined(CONFIG_NAND_BOOT) #define CONFIG_SYS_QE_FMAN_FW_IN_NAND #define CONFIG_SYS_FMAN_FW_ADDR (36 * CONFIG_SYS_NAND_BLOCK_SIZE) diff --git a/include/configs/lsxl.h b/include/configs/lsxl.h index bcad8a0..72e6265 100644 --- a/include/configs/lsxl.h +++ b/include/configs/lsxl.h @@ -45,10 +45,6 @@
/* loading initramfs images without uimage header */
-/* ST M25P40 */ -#undef CONFIG_ENV_SPI_MAX_HZ -#define CONFIG_ENV_SPI_MAX_HZ 25000000 - /* * Environment variables configurations */ diff --git a/include/configs/meesc.h b/include/configs/meesc.h index 0a03a2f..a1fd5f6 100644 --- a/include/configs/meesc.h +++ b/include/configs/meesc.h @@ -99,7 +99,6 @@ #define CONFIG_ENV_OFFSET 0x4200 #define CONFIG_ENV_SIZE 0x4200 #define CONFIG_ENV_SECT_SIZE 0x210 -#define CONFIG_ENV_SPI_MAX_HZ 15000000
#elif CONFIG_SYS_USE_NANDFLASH
diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index d81194b..d1ab40e 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -86,9 +86,6 @@ # define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SIZE)
# else /* SPIFLASH && !RAMENV */ -# define CONFIG_ENV_SPI_MODE SPI_MODE_3 -# define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED -# define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS /* 128K(two sectors) for env */ # define CONFIG_ENV_SECT_SIZE 0x10000 # define CONFIG_ENV_SIZE (2 * CONFIG_ENV_SECT_SIZE) diff --git a/include/configs/mvebu_armada-37xx.h b/include/configs/mvebu_armada-37xx.h index e898133..10b94f4 100644 --- a/include/configs/mvebu_armada-37xx.h +++ b/include/configs/mvebu_armada-37xx.h @@ -57,11 +57,7 @@ /* * SPI Flash configuration */ -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0
-/* SPI NOR flash default params, used by sf commands */ -#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE #define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ #define CONFIG_MTD_PARTITIONS /* required for UBI partition support */
diff --git a/include/configs/mvebu_armada-8k.h b/include/configs/mvebu_armada-8k.h index 51f484d..f4972b6 100644 --- a/include/configs/mvebu_armada-8k.h +++ b/include/configs/mvebu_armada-8k.h @@ -52,11 +52,6 @@ /* * SPI Flash configuration */ -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 - -/* SPI NOR flash default params, used by sf commands */ -#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE
#define CONFIG_ENV_OFFSET 0x180000 /* as Marvell U-Boot version */ #define CONFIG_ENV_SIZE (64 << 10) /* 64KiB */ diff --git a/include/configs/mx28evk.h b/include/configs/mx28evk.h index a078e3a..dd04580 100644 --- a/include/configs/mx28evk.h +++ b/include/configs/mx28evk.h @@ -48,10 +48,6 @@ #define CONFIG_ENV_OFFSET 0x40000 /* 256K */ #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) #define CONFIG_ENV_SECT_SIZE 0x1000 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_BUS 2 -#define CONFIG_ENV_SPI_MAX_HZ 24000000 -#define CONFIG_ENV_SPI_MODE SPI_MODE_0 #endif
/* UBI and NAND partitioning */ diff --git a/include/configs/mx6slevk.h b/include/configs/mx6slevk.h index 2cce3d5..5d649f6 100644 --- a/include/configs/mx6slevk.h +++ b/include/configs/mx6slevk.h @@ -136,10 +136,6 @@ #if defined CONFIG_SPI_BOOT #define CONFIG_ENV_OFFSET (768 * 1024) #define CONFIG_ENV_SECT_SIZE (64 * 1024) -#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS -#define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS -#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE -#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED #else #define CONFIG_ENV_OFFSET (8 * SZ_64K) #endif diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index c37a766..d941caa 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -158,10 +158,6 @@ #elif defined(CONFIG_ENV_IS_IN_SPI_FLASH) #define CONFIG_ENV_OFFSET (768 * 1024) #define CONFIG_ENV_SECT_SIZE (8 * 1024) -#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS -#define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS -#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE -#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED #endif
/* diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index 5f5aa57..1786e09 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -119,7 +119,6 @@
#ifdef CONFIG_USE_SPIFLASH #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x8000 diff --git a/include/configs/ot1200.h b/include/configs/ot1200.h index 6754181..925e7ae 100644 --- a/include/configs/ot1200.h +++ b/include/configs/ot1200.h @@ -99,10 +99,6 @@ #define CONFIG_ENV_OFFSET (1024 * 1024) /* M25P16 has an erase size of 64 KiB */ #define CONFIG_ENV_SECT_SIZE (64 * 1024) -#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS -#define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS -#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE -#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED
#define CONFIG_BOOTP_SERVERIP #define CONFIG_BOOTP_BOOTFILE diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index e20125c..1b8305e 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -701,10 +701,6 @@ * Environment */ #ifdef CONFIG_SPIFLASH -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 10000000 -#define CONFIG_ENV_SPI_MODE 0 #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 diff --git a/include/configs/pcm058.h b/include/configs/pcm058.h index 15dc1b2..b0415b2 100644 --- a/include/configs/pcm058.h +++ b/include/configs/pcm058.h @@ -78,10 +78,6 @@ #define CONFIG_ENV_SIZE (16 * 1024) #define CONFIG_ENV_OFFSET (1024 * SZ_1K) #define CONFIG_ENV_SECT_SIZE (64 * SZ_1K) -#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS -#define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS -#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE -#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED #define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ CONFIG_ENV_SECT_SIZE) diff --git a/include/configs/pfla02.h b/include/configs/pfla02.h index fe54e54..3a9b85a 100644 --- a/include/configs/pfla02.h +++ b/include/configs/pfla02.h @@ -79,10 +79,6 @@ #define CONFIG_ENV_SIZE (16 * 1024) #define CONFIG_ENV_OFFSET (1024 * SZ_1K) #define CONFIG_ENV_SECT_SIZE (64 * SZ_1K) -#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS -#define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS -#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE -#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED #define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ CONFIG_ENV_SECT_SIZE) diff --git a/include/configs/pm9261.h b/include/configs/pm9261.h index e88948c..c1ce122 100644 --- a/include/configs/pm9261.h +++ b/include/configs/pm9261.h @@ -207,7 +207,6 @@ #define CONFIG_ENV_OFFSET 0x4200 #define CONFIG_ENV_SIZE 0x4200 #define CONFIG_ENV_SECT_SIZE 0x210 -#define CONFIG_ENV_SPI_MAX_HZ 15000000 #define CONFIG_BOOTCOMMAND "sf probe 0; " \ "sf read 0x22000000 0x84000 0x210000; " \ "bootm 0x22000000" diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index f11879b..b09d851 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -236,7 +236,6 @@ #define CONFIG_ENV_OFFSET 0x4200 #define CONFIG_ENV_SIZE 0x4200 #define CONFIG_ENV_SECT_SIZE 0x210 -#define CONFIG_ENV_SPI_MAX_HZ 15000000 #define CONFIG_BOOTCOMMAND "sf probe 0; " \ "sf read 0x22000000 0x84000 0x294000; " \ "bootm 0x22000000" diff --git a/include/configs/puma_rk3399.h b/include/configs/puma_rk3399.h index 45a4ccc..4d6085d 100644 --- a/include/configs/puma_rk3399.h +++ b/include/configs/puma_rk3399.h @@ -12,10 +12,6 @@ #define CONFIG_SYS_MMC_ENV_DEV 1 #elif defined(CONFIG_ENV_IS_IN_SPI_FLASH) #define CONFIG_ENV_SECT_SIZE (8 * 1024) -#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS -#define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS -#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE -#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED #endif
#define SDRAM_BANK_SIZE (2UL << 30) diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index 8f2dd5f..f44a428 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -179,7 +179,6 @@ * 0x442000 - 0x800000 : Userland */ #if defined(CONFIG_SPI_BOOT) -# define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED # define CONFIG_ENV_OFFSET (892 << 10) /* 892 KiB in */ # define CONFIG_ENV_SECT_SIZE (4 << 10) /* 4 KB sectors */ #endif /* SPI support */ diff --git a/include/configs/socfpga_sr1500.h b/include/configs/socfpga_sr1500.h index d9de075..b6a9861 100644 --- a/include/configs/socfpga_sr1500.h +++ b/include/configs/socfpga_sr1500.h @@ -35,10 +35,6 @@ #define CONFIG_ENV_SIZE (16 * 1024) #define CONFIG_ENV_OFFSET 0x000e0000 #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MODE SPI_MODE_3 -#define CONFIG_ENV_SPI_MAX_HZ 100000000 /* Use max of 100MHz */
/* * The QSPI NOR flash layout on SR1500: diff --git a/include/configs/stmark2.h b/include/configs/stmark2.h index fa3d6b8..17f92d8 100644 --- a/include/configs/stmark2.h +++ b/include/configs/stmark2.h @@ -65,8 +65,6 @@ /* DSPI and Serial Flash */ #define CONFIG_CF_DSPI #define CONFIG_SERIAL_FLASH -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 1
#define CONFIG_SYS_SBFHDR_SIZE 0x7
@@ -152,7 +150,6 @@
#if defined(CONFIG_CF_SBF) #define CONFIG_ENV_IS_IN_SPI_FLASH 1 -#define CONFIG_ENV_SPI_CS 1 #define CONFIG_ENV_OFFSET 0x40000 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x10000 diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index 767615a..fb8c082 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -71,7 +71,6 @@
/* SPI Configuration */ #define CONFIG_SYS_SPI_CLK ks_clk_get_rate(KS2_CLK1_6) -#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED #define CONFIG_SYS_SPI0 #define CONFIG_SYS_SPI_BASE KS2_SPI0_BASE #define CONFIG_SYS_SPI0_NUM_CS 4 diff --git a/include/configs/topic_miami.h b/include/configs/topic_miami.h index c4f01aa..69aa79b 100644 --- a/include/configs/topic_miami.h +++ b/include/configs/topic_miami.h @@ -48,7 +48,6 @@ #define CONFIG_SYS_MEMTEST_END 0x18000000
/* Faster flash, ours may run at 108 MHz */ -#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED #undef CONFIG_SPI_FLASH_WINBOND
/* Setup proper boot sequences for Miami boards */ diff --git a/include/configs/tqma6.h b/include/configs/tqma6.h index 6c0d4f2..13e3d60 100644 --- a/include/configs/tqma6.h +++ b/include/configs/tqma6.h @@ -154,11 +154,6 @@ #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ CONFIG_ENV_SECT_SIZE)
-#define CONFIG_ENV_SPI_BUS (CONFIG_SF_DEFAULT_BUS) -#define CONFIG_ENV_SPI_CS (CONFIG_SF_DEFAULT_CS) -#define CONFIG_ENV_SPI_MAX_HZ (CONFIG_SF_DEFAULT_SPEED) -#define CONFIG_ENV_SPI_MODE (CONFIG_SF_DEFAULT_MODE) - #define TQMA6_FDT_OFFSET (CONFIG_ENV_OFFSET_REDUND + \ CONFIG_ENV_SECT_SIZE) #define TQMA6_FDT_SECT_SIZE (TQMA6_SPI_FLASH_SECTOR_SIZE) diff --git a/include/configs/trimslice.h b/include/configs/trimslice.h index f543521..0378e8b 100644 --- a/include/configs/trimslice.h +++ b/include/configs/trimslice.h @@ -26,8 +26,6 @@ #define CONFIG_SYS_I2C_TEGRA
/* Environment in SPI */ -#define CONFIG_ENV_SPI_MAX_HZ 48000000 -#define CONFIG_ENV_SPI_MODE SPI_MODE_0 #define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE /* 1MiB flash, environment located as high as possible */ #define CONFIG_ENV_OFFSET (SZ_1M - CONFIG_ENV_SIZE) diff --git a/include/configs/turris_mox.h b/include/configs/turris_mox.h index 648c87d..5d5394e 100644 --- a/include/configs/turris_mox.h +++ b/include/configs/turris_mox.h @@ -66,11 +66,6 @@ /* * SPI Flash configuration */ -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 - -/* SPI NOR flash default params, used by sf commands */ -#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE
/* Environment in SPI NOR flash */ #define CONFIG_ENV_OFFSET 0x180000 /* as Marvell U-Boot version */ diff --git a/include/configs/usb_a9263.h b/include/configs/usb_a9263.h index aa8738f..fa38274 100644 --- a/include/configs/usb_a9263.h +++ b/include/configs/usb_a9263.h @@ -82,7 +82,6 @@ #define CONFIG_ENV_OFFSET 0x2000 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE -#define CONFIG_ENV_SPI_MAX_HZ 15000000 #define CONFIG_BOOTCOMMAND "nboot 21000000 0" #define CONFIG_EXTRA_ENV_SETTINGS \ "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \ diff --git a/include/configs/vcoreiii.h b/include/configs/vcoreiii.h index 8c30c6f..2840c7b 100644 --- a/include/configs/vcoreiii.h +++ b/include/configs/vcoreiii.h @@ -34,8 +34,6 @@ #define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SECT_SIZE)
-#define CONFIG_ENV_SPI_MAX_HZ 0 /* This force to read from DT */ -#define CONFIG_ENV_SPI_MODE 0 /* This force to read from DT */ #endif
#define CONFIG_SYS_SDRAM_BASE 0x80000000 diff --git a/include/configs/vinco.h b/include/configs/vinco.h index 715ef2a..ec22a30 100644 --- a/include/configs/vinco.h +++ b/include/configs/vinco.h @@ -38,8 +38,6 @@ #ifdef CONFIG_CMD_SF #define CONFIG_ATMEL_SPI0 #define CONFIG_SPI_FLASH_STMICRO -#define CONFIG_ENV_SPI_MAX_HZ 50000000 -#define CONFIG_ENV_SPI_MODE (SPI_MODE_0) #endif
/* MMC */ @@ -65,8 +63,6 @@
#ifdef CONFIG_SPI_BOOT /* bootstrap + u-boot + env + linux in serial flash */ -#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS -#define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS /* Use our own mapping for the VInCo platform */ #undef CONFIG_ENV_OFFSET #undef CONFIG_ENV_SIZE diff --git a/include/configs/x530.h b/include/configs/x530.h index d9c1eff..80c898e 100644 --- a/include/configs/x530.h +++ b/include/configs/x530.h @@ -60,8 +60,6 @@ #define CONFIG_EHCI_IS_TDI
/* Environment in SPI NOR flash */ -#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS -#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE #define CONFIG_ENV_OFFSET (1 << 20) /* 1MiB in */ #define CONFIG_ENV_SIZE (64 << 10) /* 64KiB */ #define CONFIG_ENV_SECT_SIZE (256 << 10) /* 256KiB sectors */ diff --git a/include/spi_flash.h b/include/spi_flash.h index 97ec2b3..55b4721 100644 --- a/include/spi_flash.h +++ b/include/spi_flash.h @@ -13,6 +13,20 @@ #include <linux/types.h> #include <linux/mtd/spi-nor.h>
+/* by default ENV use the same parameters than SF command */ +#ifndef CONFIG_ENV_SPI_BUS +# define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS +#endif +#ifndef CONFIG_ENV_SPI_CS +# define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS +#endif +#ifndef CONFIG_ENV_SPI_MAX_HZ +# define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED +#endif +#ifndef CONFIG_ENV_SPI_MODE +# define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE +#endif + struct spi_slave;
struct dm_spi_flash_ops {
On Wed, Feb 27, 2019 at 03:20:38PM +0100, Patrick Delaunay wrote:
This converts the following to Kconfig: CONFIG_ENV_SPI_BUS CONFIG_ENV_SPI_CS CONFIG_ENV_SPI_MAX_HZ CONFIG_ENV_SPI_MODE
Most of time these value are not needed, CONFIG_SF_DEFAULT with same value is used, so I introduced CONFIG_USE_ENV_SPI_* to force the associated value for the environment.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com
Patrick DELAUNAY
Patrick Delaunay
Simon Goldschmidt
