[PATCH 0/5] clk: mediatek: mt7623: clk migration for OF_UPSTREAM
These are all the required patches to migrate clk and correctly support OF_UPSTREAM. This will align the clk index to upstream to support the same clk implementation with downstream and upstream DTS.
Christian Marangi (5): clk: mediatek: mt7623: fix broken peri_cgs clk with XTAL parents clk: mediatek: mt7623: split clk tree to dedicated topckgen and apmixed clk: mediatek: mt7623: define id_offs_map and import clk ID from upstream clk: mediatek: mt7623: remap apmixedsys clock ID clk: mediatek: mt7623: remap peri clock ID and add MUX
drivers/clk/mediatek/clk-mt7623.c | 326 +++++++++- include/dt-bindings/clock/mt7623-clk.h | 832 ++++++++++++++----------- 2 files changed, 757 insertions(+), 401 deletions(-)
Fix broken peri_cgs and infra_cgs clock with XTAL parents as they have wrong definition of the parent type.
Correctly fix them and use CLK_PARENT_XTAL for them.
Signed-off-by: Christian Marangi ansuelsmth@gmail.com --- drivers/clk/mediatek/clk-mt7623.c | 27 ++++++++++++++++++--------- 1 file changed, 18 insertions(+), 9 deletions(-)
diff --git a/drivers/clk/mediatek/clk-mt7623.c b/drivers/clk/mediatek/clk-mt7623.c index 5072c9983c1..4be914c8297 100644 --- a/drivers/clk/mediatek/clk-mt7623.c +++ b/drivers/clk/mediatek/clk-mt7623.c @@ -586,21 +586,26 @@ static const struct mtk_gate_regs infra_cg_regs = { .sta_ofs = 0x48, };
-#define GATE_INFRA(_id, _parent, _shift) { \ +#define GATE_INFRA_FLAGS(_id, _parent, _shift, _flags) { \ .id = _id, \ .parent = _parent, \ .regs = &infra_cg_regs, \ .shift = _shift, \ - .flags = CLK_GATE_SETCLR | CLK_PARENT_TOPCKGEN, \ + .flags = _flags, \ } +#define GATE_INFRA(_id, _parent, _shift) \ + GATE_INFRA_FLAGS(_id, _parent, _shift, CLK_GATE_SETCLR | CLK_PARENT_TOPCKGEN) +#define GATE_INFRA_XTAL(_id, _parent, _shift) \ + GATE_INFRA_FLAGS(_id, _parent, _shift, CLK_GATE_SETCLR | CLK_PARENT_XTAL) +
static const struct mtk_gate infra_cgs[] = { GATE_INFRA(CLK_INFRA_DBG, CLK_TOP_AXI_SEL, 0), GATE_INFRA(CLK_INFRA_SMI, CLK_TOP_MM_SEL, 1), GATE_INFRA(CLK_INFRA_QAXI_CM4, CLK_TOP_AXI_SEL, 2), GATE_INFRA(CLK_INFRA_AUD_SPLIN_B, CLK_TOP_HADDS2PLL_294M, 4), - GATE_INFRA(CLK_INFRA_AUDIO, CLK_XTAL, 5), - GATE_INFRA(CLK_INFRA_EFUSE, CLK_XTAL, 6), + GATE_INFRA_XTAL(CLK_INFRA_AUDIO, CLK_XTAL, 5), + GATE_INFRA_XTAL(CLK_INFRA_EFUSE, CLK_XTAL, 6), GATE_INFRA(CLK_INFRA_L2C_SRAM, CLK_TOP_MM_SEL, 7), GATE_INFRA(CLK_INFRA_M4U, CLK_TOP_MEM_SEL, 8), GATE_INFRA(CLK_INFRA_CONNMCU, CLK_TOP_WBG_DIG_416M, 12), @@ -628,13 +633,17 @@ static const struct mtk_gate_regs peri1_cg_regs = { .sta_ofs = 0x1C, };
-#define GATE_PERI0(_id, _parent, _shift) { \ +#define GATE_PERI0_FLAGS(_id, _parent, _shift, _flags) { \ .id = _id, \ .parent = _parent, \ .regs = &peri0_cg_regs, \ .shift = _shift, \ - .flags = CLK_GATE_SETCLR | CLK_PARENT_TOPCKGEN, \ + .flags = _flags, \ } +#define GATE_PERI0(_id, _parent, _shift) \ + GATE_PERI0_FLAGS(_id, _parent, _shift, CLK_GATE_SETCLR | CLK_PARENT_TOPCKGEN) +#define GATE_PERI0_XTAL(_id, _parent, _shift) \ + GATE_PERI0_FLAGS(_id, _parent, _shift, CLK_GATE_SETCLR | CLK_PARENT_XTAL)
#define GATE_PERI1(_id, _parent, _shift) { \ .id = _id, \ @@ -672,10 +681,10 @@ static const struct mtk_gate peri_cgs[] = { GATE_PERI0(CLK_PERI_I2C0, CLK_TOP_AXI_SEL, 24), GATE_PERI0(CLK_PERI_I2C1, CLK_TOP_AXI_SEL, 25), GATE_PERI0(CLK_PERI_I2C2, CLK_TOP_AXI_SEL, 26), - GATE_PERI0(CLK_PERI_I2C3, CLK_XTAL, 27), - GATE_PERI0(CLK_PERI_AUXADC, CLK_XTAL, 28), + GATE_PERI0_XTAL(CLK_PERI_I2C3, CLK_XTAL, 27), + GATE_PERI0_XTAL(CLK_PERI_AUXADC, CLK_XTAL, 28), GATE_PERI0(CLK_PERI_SPI0, CLK_TOP_SPI0_SEL, 29), - GATE_PERI0(CLK_PERI_ETH, CLK_XTAL, 30), + GATE_PERI0_XTAL(CLK_PERI_ETH, CLK_XTAL, 30), GATE_PERI0(CLK_PERI_USB0_MCU, CLK_TOP_AXI_SEL, 31),
GATE_PERI1(CLK_PERI_USB1_MCU, CLK_TOP_AXI_SEL, 0),
Split clk tree to dedicated topckgen and apmixed in preparation for remap table.
Signed-off-by: Christian Marangi ansuelsmth@gmail.com --- drivers/clk/mediatek/clk-mt7623.c | 25 ++++++++++++++++--------- 1 file changed, 16 insertions(+), 9 deletions(-)
diff --git a/drivers/clk/mediatek/clk-mt7623.c b/drivers/clk/mediatek/clk-mt7623.c index 4be914c8297..79936f1803d 100644 --- a/drivers/clk/mediatek/clk-mt7623.c +++ b/drivers/clk/mediatek/clk-mt7623.c @@ -739,12 +739,15 @@ static const struct mtk_gate hif_cgs[] = { GATE_ETH_HIF1(CLK_HIFSYS_PCIE2, CLK_TOP_ETHPLL_500M, 26), };
-static const struct mtk_clk_tree mt7623_clk_tree = { - .xtal_rate = 26 * MHZ, +static const struct mtk_clk_tree mt7623_apmixedsys_clk_tree = { .xtal2_rate = 26 * MHZ, + .plls = apmixed_plls, +}; + +static const struct mtk_clk_tree mt7623_topckgen_clk_tree = { + .xtal_rate = 26 * MHZ, .fdivs_offs = CLK_TOP_SYSPLL, .muxes_offs = CLK_TOP_AXI_SEL, - .plls = apmixed_plls, .fclks = top_fixed_clks, .fdivs = top_fixed_divs, .muxes = top_muxes, @@ -769,7 +772,7 @@ static int mt7623_apmixedsys_probe(struct udevice *dev) struct mtk_clk_priv *priv = dev_get_priv(dev); int ret;
- ret = mtk_common_clk_init(dev, &mt7623_clk_tree); + ret = mtk_common_clk_init(dev, &mt7623_apmixedsys_clk_tree); if (ret) return ret;
@@ -783,27 +786,31 @@ static int mt7623_apmixedsys_probe(struct udevice *dev)
static int mt7623_topckgen_probe(struct udevice *dev) { - return mtk_common_clk_init(dev, &mt7623_clk_tree); + return mtk_common_clk_init(dev, &mt7623_topckgen_clk_tree); }
static int mt7623_infracfg_probe(struct udevice *dev) { - return mtk_common_clk_gate_init(dev, &mt7623_clk_tree, infra_cgs); + return mtk_common_clk_gate_init(dev, &mt7623_topckgen_clk_tree, + infra_cgs); }
static int mt7623_pericfg_probe(struct udevice *dev) { - return mtk_common_clk_gate_init(dev, &mt7623_clk_tree, peri_cgs); + return mtk_common_clk_gate_init(dev, &mt7623_topckgen_clk_tree, + peri_cgs); }
static int mt7623_hifsys_probe(struct udevice *dev) { - return mtk_common_clk_gate_init(dev, &mt7623_clk_tree, hif_cgs); + return mtk_common_clk_gate_init(dev, &mt7623_topckgen_clk_tree, + hif_cgs); }
static int mt7623_ethsys_probe(struct udevice *dev) { - return mtk_common_clk_gate_init(dev, &mt7623_clk_tree, eth_cgs); + return mtk_common_clk_gate_init(dev, &mt7623_topckgen_clk_tree, + eth_cgs); }
static int mt7623_ethsys_hifsys_bind(struct udevice *dev)
Define id_offs_map and use clk ID form upstream linux kernel to have a 1:1 match for the TOPCKGEN clock and permit usage of OF_UPSTREAM with upstream dtsi.
For all the gate clock, the clk ID starts from 1 instead of zero. Define an additional clock tree for them and set the .gates_offs to 1 to account for this.
Signed-off-by: Christian Marangi ansuelsmth@gmail.com --- drivers/clk/mediatek/clk-mt7623.c | 188 +++++- include/dt-bindings/clock/mt7623-clk.h | 832 ++++++++++++++----------- 2 files changed, 633 insertions(+), 387 deletions(-)
diff --git a/drivers/clk/mediatek/clk-mt7623.c b/drivers/clk/mediatek/clk-mt7623.c index 79936f1803d..6af6f9f11bd 100644 --- a/drivers/clk/mediatek/clk-mt7623.c +++ b/drivers/clk/mediatek/clk-mt7623.c @@ -71,6 +71,176 @@ static const struct mtk_pll_data apmixed_plls[] = { };
/* topckgen */ + +/* Fixed CLK exposed upstream by the hdmi PHY driver */ +#define CLK_TOP_HDMITX_CLKDIG_CTS CLK_TOP_NR + +static const int top_id_offs_map[CLK_TOP_NR + 1] = { + /* Fixed CLK */ + [CLK_TOP_DPI] = 0, + [CLK_TOP_DMPLL] = 1, + [CLK_TOP_VENCPLL] = 2, + [CLK_TOP_HDMI_0_PIX340M] = 3, + [CLK_TOP_HDMI_0_DEEP340M] = 4, + [CLK_TOP_HDMI_0_PLL340M] = 5, + [CLK_TOP_HADDS2_FB] = 6, + [CLK_TOP_WBG_DIG_416M] = 7, + [CLK_TOP_DSI0_LNTC_DSI] = 8, + [CLK_TOP_HDMI_SCL_RX] = 9, + [CLK_TOP_32K_EXTERNAL] = 10, + [CLK_TOP_HDMITX_CLKDIG_CTS] = 11, + [CLK_TOP_AUD_EXT1] = 12, + [CLK_TOP_AUD_EXT2] = 13, + [CLK_TOP_NFI1X_PAD] = 14, + /* Factor CLK */ + [CLK_TOP_SYSPLL] = 15, + [CLK_TOP_SYSPLL_D2] = 16, + [CLK_TOP_SYSPLL_D3] = 17, + [CLK_TOP_SYSPLL_D5] = 18, + [CLK_TOP_SYSPLL_D7] = 19, + [CLK_TOP_SYSPLL1_D2] = 20, + [CLK_TOP_SYSPLL1_D4] = 21, + [CLK_TOP_SYSPLL1_D8] = 22, + [CLK_TOP_SYSPLL1_D16] = 23, + [CLK_TOP_SYSPLL2_D2] = 24, + [CLK_TOP_SYSPLL2_D4] = 25, + [CLK_TOP_SYSPLL2_D8] = 26, + [CLK_TOP_SYSPLL3_D2] = 27, + [CLK_TOP_SYSPLL3_D4] = 28, + [CLK_TOP_SYSPLL4_D2] = 29, + [CLK_TOP_SYSPLL4_D4] = 30, + [CLK_TOP_UNIVPLL] = 31, + [CLK_TOP_UNIVPLL_D2] = 32, + [CLK_TOP_UNIVPLL_D3] = 33, + [CLK_TOP_UNIVPLL_D5] = 34, + [CLK_TOP_UNIVPLL_D7] = 35, + [CLK_TOP_UNIVPLL_D26] = 36, + [CLK_TOP_UNIVPLL_D52] = 37, + [CLK_TOP_UNIVPLL_D108] = 38, + [CLK_TOP_USB_PHY48M] = 39, + [CLK_TOP_UNIVPLL1_D2] = 40, + [CLK_TOP_UNIVPLL1_D4] = 41, + [CLK_TOP_UNIVPLL1_D8] = 42, + [CLK_TOP_UNIVPLL2_D2] = 43, + [CLK_TOP_UNIVPLL2_D4] = 44, + [CLK_TOP_UNIVPLL2_D8] = 45, + [CLK_TOP_UNIVPLL2_D16] = 46, + [CLK_TOP_UNIVPLL2_D32] = 47, + [CLK_TOP_UNIVPLL3_D2] = 48, + [CLK_TOP_UNIVPLL3_D4] = 49, + [CLK_TOP_UNIVPLL3_D8] = 50, + [CLK_TOP_MSDCPLL] = 51, + [CLK_TOP_MSDCPLL_D2] = 52, + [CLK_TOP_MSDCPLL_D4] = 53, + [CLK_TOP_MSDCPLL_D8] = 54, + [CLK_TOP_MMPLL] = 55, + [CLK_TOP_MMPLL_D2] = 56, + [CLK_TOP_DMPLL_D2] = 57, + [CLK_TOP_DMPLL_D4] = 58, + [CLK_TOP_DMPLL_X2] = 59, + [CLK_TOP_TVDPLL] = 60, + [CLK_TOP_TVDPLL_D2] = 61, + [CLK_TOP_TVDPLL_D4] = 62, + [CLK_TOP_VDECPLL] = 63, + [CLK_TOP_TVD2PLL] = 64, + [CLK_TOP_TVD2PLL_D2] = 65, + [CLK_TOP_MIPIPLL] = 66, + [CLK_TOP_MIPIPLL_D2] = 67, + [CLK_TOP_MIPIPLL_D4] = 68, + [CLK_TOP_HDMIPLL] = 69, + [CLK_TOP_HDMIPLL_D2] = 70, + [CLK_TOP_HDMIPLL_D3] = 71, + [CLK_TOP_ARMPLL_1P3G] = 72, + [CLK_TOP_AUDPLL] = 73, + [CLK_TOP_AUDPLL_D4] = 74, + [CLK_TOP_AUDPLL_D8] = 75, + [CLK_TOP_AUDPLL_D16] = 76, + [CLK_TOP_AUDPLL_D24] = 77, + [CLK_TOP_AUD1PLL_98M] = 78, + [CLK_TOP_AUD2PLL_90M] = 79, + [CLK_TOP_HADDS2PLL_98M] = 80, + [CLK_TOP_HADDS2PLL_294M] = 81, + [CLK_TOP_ETHPLL_500M] = 82, + [CLK_TOP_CLK26M_D8] = 83, + [CLK_TOP_32K_INTERNAL] = 84, + [CLK_TOP_AXISEL_D4] = 85, + [CLK_TOP_8BDAC] = 86, + /* MUX CLK */ + [CLK_TOP_AXI_SEL] = 87, + [CLK_TOP_MEM_SEL] = 88, + [CLK_TOP_DDRPHYCFG_SEL] = 89, + [CLK_TOP_MM_SEL] = 90, + [CLK_TOP_PWM_SEL] = 91, + [CLK_TOP_VDEC_SEL] = 92, + [CLK_TOP_MFG_SEL] = 93, + [CLK_TOP_CAMTG_SEL] = 94, + [CLK_TOP_UART_SEL] = 95, + [CLK_TOP_SPI0_SEL] = 96, + [CLK_TOP_USB20_SEL] = 97, + [CLK_TOP_MSDC30_0_SEL] = 98, + [CLK_TOP_MSDC30_1_SEL] = 99, + [CLK_TOP_MSDC30_2_SEL] = 100, + [CLK_TOP_AUDIO_SEL] = 101, + [CLK_TOP_AUDINTBUS_SEL] = 102, + [CLK_TOP_PMICSPI_SEL] = 103, + [CLK_TOP_SCP_SEL] = 104, + [CLK_TOP_DPI0_SEL] = 105, + [CLK_TOP_DPI1_SEL] = 106, + [CLK_TOP_TVE_SEL] = 107, + [CLK_TOP_HDMI_SEL] = 108, + [CLK_TOP_APLL_SEL] = 109, + [CLK_TOP_RTC_SEL] = 110, + [CLK_TOP_NFI2X_SEL] = 111, + [CLK_TOP_EMMC_HCLK_SEL] = 112, + [CLK_TOP_FLASH_SEL] = 113, + [CLK_TOP_DI_SEL] = 114, + [CLK_TOP_NR_SEL] = 115, + [CLK_TOP_OSD_SEL] = 116, + [CLK_TOP_HDMIRX_BIST_SEL] = 117, + [CLK_TOP_INTDIR_SEL] = 118, + [CLK_TOP_ASM_I_SEL] = 119, + [CLK_TOP_ASM_M_SEL] = 120, + [CLK_TOP_ASM_H_SEL] = 121, + [CLK_TOP_MS_CARD_SEL] = 122, + [CLK_TOP_ETHIF_SEL] = 123, + [CLK_TOP_HDMIRX26_24_SEL] = 124, + [CLK_TOP_MSDC30_3_SEL] = 125, + [CLK_TOP_CMSYS_SEL] = 126, + [CLK_TOP_SPI1_SEL] = 127, + [CLK_TOP_SPI2_SEL] = 128, + [CLK_TOP_8BDAC_SEL] = 129, + [CLK_TOP_AUD2DVD_SEL] = 130, + [CLK_TOP_PADMCLK_SEL] = 131, + [CLK_TOP_AUD_MUX1_SEL] = 132, + [CLK_TOP_AUD_MUX2_SEL] = 133, + [CLK_TOP_AUDPLL_MUX_SEL] = 134, + [CLK_TOP_AUD_K1_SRC_SEL] = 135, + [CLK_TOP_AUD_K2_SRC_SEL] = 136, + [CLK_TOP_AUD_K3_SRC_SEL] = 137, + [CLK_TOP_AUD_K4_SRC_SEL] = 138, + [CLK_TOP_AUD_K5_SRC_SEL] = 139, + [CLK_TOP_AUD_K6_SRC_SEL] = 140, + /* Misc CLK only used as parents */ + [CLK_TOP_AUD_EXTCK1_DIV] = 141, + [CLK_TOP_AUD_EXTCK2_DIV] = 142, + [CLK_TOP_AUD_MUX1_DIV] = 143, + [CLK_TOP_AUD_MUX2_DIV] = 144, + [CLK_TOP_AUD_K1_SRC_DIV] = 145, + [CLK_TOP_AUD_K2_SRC_DIV] = 146, + [CLK_TOP_AUD_K3_SRC_DIV] = 147, + [CLK_TOP_AUD_K4_SRC_DIV] = 148, + [CLK_TOP_AUD_K5_SRC_DIV] = 149, + [CLK_TOP_AUD_K6_SRC_DIV] = 150, + [CLK_TOP_AUD_48K_TIMING] = 151, + [CLK_TOP_AUD_44K_TIMING] = 152, + [CLK_TOP_AUD_I2S1_MCLK] = 153, + [CLK_TOP_AUD_I2S2_MCLK] = 154, + [CLK_TOP_AUD_I2S3_MCLK] = 155, + [CLK_TOP_AUD_I2S4_MCLK] = 156, + [CLK_TOP_AUD_I2S5_MCLK] = 157, + [CLK_TOP_AUD_I2S6_MCLK] = 158, +}; + #define FACTOR0(_id, _parent, _mult, _div) \ FACTOR(_id, _parent, _mult, _div, CLK_PARENT_APMIXED)
@@ -746,8 +916,9 @@ static const struct mtk_clk_tree mt7623_apmixedsys_clk_tree = {
static const struct mtk_clk_tree mt7623_topckgen_clk_tree = { .xtal_rate = 26 * MHZ, - .fdivs_offs = CLK_TOP_SYSPLL, - .muxes_offs = CLK_TOP_AXI_SEL, + .id_offs_map = top_id_offs_map, + .fdivs_offs = top_id_offs_map[CLK_TOP_SYSPLL], + .muxes_offs = top_id_offs_map[CLK_TOP_AXI_SEL], .fclks = top_fixed_clks, .fdivs = top_fixed_divs, .muxes = top_muxes, @@ -789,27 +960,32 @@ static int mt7623_topckgen_probe(struct udevice *dev) return mtk_common_clk_init(dev, &mt7623_topckgen_clk_tree); }
+static const struct mtk_clk_tree mt7623_clk_gate_tree = { + /* Each CLK ID for gates clock starts at index 1 */ + .gates_offs = 1, +}; + static int mt7623_infracfg_probe(struct udevice *dev) { - return mtk_common_clk_gate_init(dev, &mt7623_topckgen_clk_tree, + return mtk_common_clk_gate_init(dev, &mt7623_clk_gate_tree, infra_cgs); }
static int mt7623_pericfg_probe(struct udevice *dev) { - return mtk_common_clk_gate_init(dev, &mt7623_topckgen_clk_tree, + return mtk_common_clk_gate_init(dev, &mt7623_clk_gate_tree, peri_cgs); }
static int mt7623_hifsys_probe(struct udevice *dev) { - return mtk_common_clk_gate_init(dev, &mt7623_topckgen_clk_tree, + return mtk_common_clk_gate_init(dev, &mt7623_clk_gate_tree, hif_cgs); }
static int mt7623_ethsys_probe(struct udevice *dev) { - return mtk_common_clk_gate_init(dev, &mt7623_topckgen_clk_tree, + return mtk_common_clk_gate_init(dev, &mt7623_clk_gate_tree, eth_cgs); }
diff --git a/include/dt-bindings/clock/mt7623-clk.h b/include/dt-bindings/clock/mt7623-clk.h index 71ced1593af..0caeb65c3d2 100644 --- a/include/dt-bindings/clock/mt7623-clk.h +++ b/include/dt-bindings/clock/mt7623-clk.h @@ -7,407 +7,477 @@ #define _DT_BINDINGS_CLK_MT2701_H
/* TOPCKGEN */ -#define CLK_TOP_FCLKS_OFF 0 - -#define CLK_TOP_DPI 0 -#define CLK_TOP_DMPLL 1 -#define CLK_TOP_VENCPLL 2 -#define CLK_TOP_HDMI_0_PIX340M 3 -#define CLK_TOP_HDMI_0_DEEP340M 4 -#define CLK_TOP_HDMI_0_PLL340M 5 -#define CLK_TOP_HADDS2_FB 6 -#define CLK_TOP_WBG_DIG_416M 7 -#define CLK_TOP_DSI0_LNTC_DSI 8 -#define CLK_TOP_HDMI_SCL_RX 9 -#define CLK_TOP_32K_EXTERNAL 10 -#define CLK_TOP_HDMITX_CLKDIG_CTS 11 -#define CLK_TOP_AUD_EXT1 12 -#define CLK_TOP_AUD_EXT2 13 -#define CLK_TOP_NFI1X_PAD 14 - -#define CLK_TOP_SYSPLL 15 -#define CLK_TOP_SYSPLL_D2 16 -#define CLK_TOP_SYSPLL_D3 17 -#define CLK_TOP_SYSPLL_D5 18 -#define CLK_TOP_SYSPLL_D7 19 -#define CLK_TOP_SYSPLL1_D2 20 -#define CLK_TOP_SYSPLL1_D4 21 -#define CLK_TOP_SYSPLL1_D8 22 -#define CLK_TOP_SYSPLL1_D16 23 -#define CLK_TOP_SYSPLL2_D2 24 -#define CLK_TOP_SYSPLL2_D4 25 -#define CLK_TOP_SYSPLL2_D8 26 -#define CLK_TOP_SYSPLL3_D2 27 -#define CLK_TOP_SYSPLL3_D4 28 -#define CLK_TOP_SYSPLL4_D2 29 -#define CLK_TOP_SYSPLL4_D4 30 -#define CLK_TOP_UNIVPLL 31 -#define CLK_TOP_UNIVPLL_D2 32 -#define CLK_TOP_UNIVPLL_D3 33 -#define CLK_TOP_UNIVPLL_D5 34 -#define CLK_TOP_UNIVPLL_D7 35 -#define CLK_TOP_UNIVPLL_D26 36 -#define CLK_TOP_UNIVPLL_D52 37 -#define CLK_TOP_UNIVPLL_D108 38 -#define CLK_TOP_USB_PHY48M 39 -#define CLK_TOP_UNIVPLL1_D2 40 -#define CLK_TOP_UNIVPLL1_D4 41 -#define CLK_TOP_UNIVPLL1_D8 42 -#define CLK_TOP_UNIVPLL2_D2 43 -#define CLK_TOP_UNIVPLL2_D4 44 -#define CLK_TOP_UNIVPLL2_D8 45 -#define CLK_TOP_UNIVPLL2_D16 46 -#define CLK_TOP_UNIVPLL2_D32 47 -#define CLK_TOP_UNIVPLL3_D2 48 -#define CLK_TOP_UNIVPLL3_D4 49 -#define CLK_TOP_UNIVPLL3_D8 50 -#define CLK_TOP_MSDCPLL 51 -#define CLK_TOP_MSDCPLL_D2 52 -#define CLK_TOP_MSDCPLL_D4 53 -#define CLK_TOP_MSDCPLL_D8 54 -#define CLK_TOP_MMPLL 55 -#define CLK_TOP_MMPLL_D2 56 -#define CLK_TOP_DMPLL_D2 57 -#define CLK_TOP_DMPLL_D4 58 -#define CLK_TOP_DMPLL_X2 59 -#define CLK_TOP_TVDPLL 60 -#define CLK_TOP_TVDPLL_D2 61 -#define CLK_TOP_TVDPLL_D4 62 -#define CLK_TOP_VDECPLL 63 -#define CLK_TOP_TVD2PLL 64 -#define CLK_TOP_TVD2PLL_D2 65 -#define CLK_TOP_MIPIPLL 66 -#define CLK_TOP_MIPIPLL_D2 67 -#define CLK_TOP_MIPIPLL_D4 68 -#define CLK_TOP_HDMIPLL 69 -#define CLK_TOP_HDMIPLL_D2 70 -#define CLK_TOP_HDMIPLL_D3 71 -#define CLK_TOP_ARMPLL_1P3G 72 -#define CLK_TOP_AUDPLL 73 -#define CLK_TOP_AUDPLL_D4 74 -#define CLK_TOP_AUDPLL_D8 75 -#define CLK_TOP_AUDPLL_D16 76 -#define CLK_TOP_AUDPLL_D24 77 -#define CLK_TOP_AUD1PLL_98M 78 -#define CLK_TOP_AUD2PLL_90M 79 -#define CLK_TOP_HADDS2PLL_98M 80 -#define CLK_TOP_HADDS2PLL_294M 81 -#define CLK_TOP_ETHPLL_500M 82 -#define CLK_TOP_CLK26M_D8 83 -#define CLK_TOP_32K_INTERNAL 84 -#define CLK_TOP_AXISEL_D4 85 -#define CLK_TOP_8BDAC 86 - -#define CLK_TOP_AXI_SEL 87 -#define CLK_TOP_MEM_SEL 88 -#define CLK_TOP_DDRPHYCFG_SEL 89 -#define CLK_TOP_MM_SEL 90 -#define CLK_TOP_PWM_SEL 91 -#define CLK_TOP_VDEC_SEL 92 -#define CLK_TOP_MFG_SEL 93 -#define CLK_TOP_CAMTG_SEL 94 -#define CLK_TOP_UART_SEL 95 -#define CLK_TOP_SPI0_SEL 96 -#define CLK_TOP_USB20_SEL 97 -#define CLK_TOP_MSDC30_0_SEL 98 -#define CLK_TOP_MSDC30_1_SEL 99 -#define CLK_TOP_MSDC30_2_SEL 100 -#define CLK_TOP_AUDIO_SEL 101 -#define CLK_TOP_AUDINTBUS_SEL 102 -#define CLK_TOP_PMICSPI_SEL 103 -#define CLK_TOP_SCP_SEL 104 -#define CLK_TOP_DPI0_SEL 105 -#define CLK_TOP_DPI1_SEL 106 -#define CLK_TOP_TVE_SEL 107 -#define CLK_TOP_HDMI_SEL 108 -#define CLK_TOP_APLL_SEL 109 -#define CLK_TOP_RTC_SEL 110 -#define CLK_TOP_NFI2X_SEL 111 -#define CLK_TOP_EMMC_HCLK_SEL 112 -#define CLK_TOP_FLASH_SEL 113 -#define CLK_TOP_DI_SEL 114 -#define CLK_TOP_NR_SEL 115 -#define CLK_TOP_OSD_SEL 116 -#define CLK_TOP_HDMIRX_BIST_SEL 117 -#define CLK_TOP_INTDIR_SEL 118 -#define CLK_TOP_ASM_I_SEL 119 -#define CLK_TOP_ASM_M_SEL 120 -#define CLK_TOP_ASM_H_SEL 121 -#define CLK_TOP_MS_CARD_SEL 122 -#define CLK_TOP_ETHIF_SEL 123 -#define CLK_TOP_HDMIRX26_24_SEL 124 -#define CLK_TOP_MSDC30_3_SEL 125 -#define CLK_TOP_CMSYS_SEL 126 -#define CLK_TOP_SPI1_SEL 127 -#define CLK_TOP_SPI2_SEL 128 -#define CLK_TOP_8BDAC_SEL 129 -#define CLK_TOP_AUD2DVD_SEL 130 -#define CLK_TOP_PADMCLK_SEL 131 -#define CLK_TOP_AUD_MUX1_SEL 132 -#define CLK_TOP_AUD_MUX2_SEL 133 -#define CLK_TOP_AUDPLL_MUX_SEL 134 -#define CLK_TOP_AUD_K1_SRC_SEL 135 -#define CLK_TOP_AUD_K2_SRC_SEL 136 -#define CLK_TOP_AUD_K3_SRC_SEL 137 -#define CLK_TOP_AUD_K4_SRC_SEL 138 -#define CLK_TOP_AUD_K5_SRC_SEL 139 -#define CLK_TOP_AUD_K6_SRC_SEL 140 - -#define CLK_TOP_AUD_EXTCK1_DIV 141 -#define CLK_TOP_AUD_EXTCK2_DIV 142 -#define CLK_TOP_AUD_MUX1_DIV 143 -#define CLK_TOP_AUD_MUX2_DIV 144 -#define CLK_TOP_AUD_K1_SRC_DIV 145 -#define CLK_TOP_AUD_K2_SRC_DIV 146 -#define CLK_TOP_AUD_K3_SRC_DIV 147 -#define CLK_TOP_AUD_K4_SRC_DIV 148 -#define CLK_TOP_AUD_K5_SRC_DIV 149 -#define CLK_TOP_AUD_K6_SRC_DIV 150 -#define CLK_TOP_AUD_48K_TIMING 151 -#define CLK_TOP_AUD_44K_TIMING 152 -#define CLK_TOP_AUD_I2S1_MCLK 153 -#define CLK_TOP_AUD_I2S2_MCLK 154 -#define CLK_TOP_AUD_I2S3_MCLK 155 -#define CLK_TOP_AUD_I2S4_MCLK 156 -#define CLK_TOP_AUD_I2S5_MCLK 157 -#define CLK_TOP_AUD_I2S6_MCLK 158 +#define CLK_TOP_SYSPLL 1 +#define CLK_TOP_SYSPLL_D2 2 +#define CLK_TOP_SYSPLL_D3 3 +#define CLK_TOP_SYSPLL_D5 4 +#define CLK_TOP_SYSPLL_D7 5 +#define CLK_TOP_SYSPLL1_D2 6 +#define CLK_TOP_SYSPLL1_D4 7 +#define CLK_TOP_SYSPLL1_D8 8 +#define CLK_TOP_SYSPLL1_D16 9 +#define CLK_TOP_SYSPLL2_D2 10 +#define CLK_TOP_SYSPLL2_D4 11 +#define CLK_TOP_SYSPLL2_D8 12 +#define CLK_TOP_SYSPLL3_D2 13 +#define CLK_TOP_SYSPLL3_D4 14 +#define CLK_TOP_SYSPLL4_D2 15 +#define CLK_TOP_SYSPLL4_D4 16 +#define CLK_TOP_UNIVPLL 17 +#define CLK_TOP_UNIVPLL_D2 18 +#define CLK_TOP_UNIVPLL_D3 19 +#define CLK_TOP_UNIVPLL_D5 20 +#define CLK_TOP_UNIVPLL_D7 21 +#define CLK_TOP_UNIVPLL_D26 22 +#define CLK_TOP_UNIVPLL_D52 23 +#define CLK_TOP_UNIVPLL_D108 24 +#define CLK_TOP_USB_PHY48M 25 +#define CLK_TOP_UNIVPLL1_D2 26 +#define CLK_TOP_UNIVPLL1_D4 27 +#define CLK_TOP_UNIVPLL1_D8 28 +#define CLK_TOP_UNIVPLL2_D2 29 +#define CLK_TOP_UNIVPLL2_D4 30 +#define CLK_TOP_UNIVPLL2_D8 31 +#define CLK_TOP_UNIVPLL2_D16 32 +#define CLK_TOP_UNIVPLL2_D32 33 +#define CLK_TOP_UNIVPLL3_D2 34 +#define CLK_TOP_UNIVPLL3_D4 35 +#define CLK_TOP_UNIVPLL3_D8 36 +#define CLK_TOP_MSDCPLL 37 +#define CLK_TOP_MSDCPLL_D2 38 +#define CLK_TOP_MSDCPLL_D4 39 +#define CLK_TOP_MSDCPLL_D8 40 +#define CLK_TOP_MMPLL 41 +#define CLK_TOP_MMPLL_D2 42 +#define CLK_TOP_DMPLL 43 +#define CLK_TOP_DMPLL_D2 44 +#define CLK_TOP_DMPLL_D4 45 +#define CLK_TOP_DMPLL_X2 46 +#define CLK_TOP_TVDPLL 47 +#define CLK_TOP_TVDPLL_D2 48 +#define CLK_TOP_TVDPLL_D4 49 +#define CLK_TOP_TVD2PLL 50 +#define CLK_TOP_TVD2PLL_D2 51 +#define CLK_TOP_HADDS2PLL_98M 52 +#define CLK_TOP_HADDS2PLL_294M 53 +#define CLK_TOP_HADDS2_FB 54 +#define CLK_TOP_MIPIPLL_D2 55 +#define CLK_TOP_MIPIPLL_D4 56 +#define CLK_TOP_HDMIPLL 57 +#define CLK_TOP_HDMIPLL_D2 58 +#define CLK_TOP_HDMIPLL_D3 59 +#define CLK_TOP_HDMI_SCL_RX 60 +#define CLK_TOP_HDMI_0_PIX340M 61 +#define CLK_TOP_HDMI_0_DEEP340M 62 +#define CLK_TOP_HDMI_0_PLL340M 63 +#define CLK_TOP_AUD1PLL_98M 64 +#define CLK_TOP_AUD2PLL_90M 65 +#define CLK_TOP_AUDPLL 66 +#define CLK_TOP_AUDPLL_D4 67 +#define CLK_TOP_AUDPLL_D8 68 +#define CLK_TOP_AUDPLL_D16 69 +#define CLK_TOP_AUDPLL_D24 70 +#define CLK_TOP_ETHPLL_500M 71 +#define CLK_TOP_VDECPLL 72 +#define CLK_TOP_VENCPLL 73 +#define CLK_TOP_MIPIPLL 74 +#define CLK_TOP_ARMPLL_1P3G 75 + +#define CLK_TOP_MM_SEL 76 +#define CLK_TOP_DDRPHYCFG_SEL 77 +#define CLK_TOP_MEM_SEL 78 +#define CLK_TOP_AXI_SEL 79 +#define CLK_TOP_CAMTG_SEL 80 +#define CLK_TOP_MFG_SEL 81 +#define CLK_TOP_VDEC_SEL 82 +#define CLK_TOP_PWM_SEL 83 +#define CLK_TOP_MSDC30_0_SEL 84 +#define CLK_TOP_USB20_SEL 85 +#define CLK_TOP_SPI0_SEL 86 +#define CLK_TOP_UART_SEL 87 +#define CLK_TOP_AUDINTBUS_SEL 88 +#define CLK_TOP_AUDIO_SEL 89 +#define CLK_TOP_MSDC30_2_SEL 90 +#define CLK_TOP_MSDC30_1_SEL 91 +#define CLK_TOP_DPI1_SEL 92 +#define CLK_TOP_DPI0_SEL 93 +#define CLK_TOP_SCP_SEL 94 +#define CLK_TOP_PMICSPI_SEL 95 +#define CLK_TOP_APLL_SEL 96 +#define CLK_TOP_HDMI_SEL 97 +#define CLK_TOP_TVE_SEL 98 +#define CLK_TOP_EMMC_HCLK_SEL 99 +#define CLK_TOP_NFI2X_SEL 100 +#define CLK_TOP_RTC_SEL 101 +#define CLK_TOP_OSD_SEL 102 +#define CLK_TOP_NR_SEL 103 +#define CLK_TOP_DI_SEL 104 +#define CLK_TOP_FLASH_SEL 105 +#define CLK_TOP_ASM_M_SEL 106 +#define CLK_TOP_ASM_I_SEL 107 +#define CLK_TOP_INTDIR_SEL 108 +#define CLK_TOP_HDMIRX_BIST_SEL 109 +#define CLK_TOP_ETHIF_SEL 110 +#define CLK_TOP_MS_CARD_SEL 111 +#define CLK_TOP_ASM_H_SEL 112 +#define CLK_TOP_SPI1_SEL 113 +#define CLK_TOP_CMSYS_SEL 114 +#define CLK_TOP_MSDC30_3_SEL 115 +#define CLK_TOP_HDMIRX26_24_SEL 116 +#define CLK_TOP_AUD2DVD_SEL 117 +#define CLK_TOP_8BDAC_SEL 118 +#define CLK_TOP_SPI2_SEL 119 +#define CLK_TOP_AUD_MUX1_SEL 120 +#define CLK_TOP_AUD_MUX2_SEL 121 +#define CLK_TOP_AUDPLL_MUX_SEL 122 +#define CLK_TOP_AUD_K1_SRC_SEL 123 +#define CLK_TOP_AUD_K2_SRC_SEL 124 +#define CLK_TOP_AUD_K3_SRC_SEL 125 +#define CLK_TOP_AUD_K4_SRC_SEL 126 +#define CLK_TOP_AUD_K5_SRC_SEL 127 +#define CLK_TOP_AUD_K6_SRC_SEL 128 +#define CLK_TOP_PADMCLK_SEL 129 +#define CLK_TOP_AUD_EXTCK1_DIV 130 +#define CLK_TOP_AUD_EXTCK2_DIV 131 +#define CLK_TOP_AUD_MUX1_DIV 132 +#define CLK_TOP_AUD_MUX2_DIV 133 +#define CLK_TOP_AUD_K1_SRC_DIV 134 +#define CLK_TOP_AUD_K2_SRC_DIV 135 +#define CLK_TOP_AUD_K3_SRC_DIV 136 +#define CLK_TOP_AUD_K4_SRC_DIV 137 +#define CLK_TOP_AUD_K5_SRC_DIV 138 +#define CLK_TOP_AUD_K6_SRC_DIV 139 +#define CLK_TOP_AUD_I2S1_MCLK 140 +#define CLK_TOP_AUD_I2S2_MCLK 141 +#define CLK_TOP_AUD_I2S3_MCLK 142 +#define CLK_TOP_AUD_I2S4_MCLK 143 +#define CLK_TOP_AUD_I2S5_MCLK 144 +#define CLK_TOP_AUD_I2S6_MCLK 145 +#define CLK_TOP_AUD_48K_TIMING 146 +#define CLK_TOP_AUD_44K_TIMING 147 + +#define CLK_TOP_32K_INTERNAL 148 +#define CLK_TOP_32K_EXTERNAL 149 +#define CLK_TOP_CLK26M_D8 150 +#define CLK_TOP_8BDAC 151 +#define CLK_TOP_WBG_DIG_416M 152 +#define CLK_TOP_DPI 153 +#define CLK_TOP_DSI0_LNTC_DSI 154 +#define CLK_TOP_AUD_EXT1 155 +#define CLK_TOP_AUD_EXT2 156 +#define CLK_TOP_NFI1X_PAD 157 +#define CLK_TOP_AXISEL_D4 158 #define CLK_TOP_NR 159
/* APMIXEDSYS */ -#define CLK_APMIXED_ARMPLL 0 -#define CLK_APMIXED_MAINPLL 1 -#define CLK_APMIXED_UNIVPLL 2 -#define CLK_APMIXED_MMPLL 3 -#define CLK_APMIXED_MSDCPLL 4 -#define CLK_APMIXED_TVDPLL 5 -#define CLK_APMIXED_AUD1PLL 6 -#define CLK_APMIXED_TRGPLL 7 -#define CLK_APMIXED_ETHPLL 8 -#define CLK_APMIXED_VDECPLL 9 -#define CLK_APMIXED_HADDS2PLL 10 -#define CLK_APMIXED_AUD2PLL 11 -#define CLK_APMIXED_TVD2PLL 12 -#define CLK_APMIXED_NR 13 + +#define CLK_APMIXED_ARMPLL 1 +#define CLK_APMIXED_MAINPLL 2 +#define CLK_APMIXED_UNIVPLL 3 +#define CLK_APMIXED_MMPLL 4 +#define CLK_APMIXED_MSDCPLL 5 +#define CLK_APMIXED_TVDPLL 6 +#define CLK_APMIXED_AUD1PLL 7 +#define CLK_APMIXED_TRGPLL 8 +#define CLK_APMIXED_ETHPLL 9 +#define CLK_APMIXED_VDECPLL 10 +#define CLK_APMIXED_HADDS2PLL 11 +#define CLK_APMIXED_AUD2PLL 12 +#define CLK_APMIXED_TVD2PLL 13 +#define CLK_APMIXED_HDMI_REF 14 +#define CLK_APMIXED_NR 15 + +/* DDRPHY */ + +#define CLK_DDRPHY_VENCPLL 1 +#define CLK_DDRPHY_NR 2
/* INFRACFG */ -#define CLK_INFRA_DBG 0 -#define CLK_INFRA_SMI 1 -#define CLK_INFRA_QAXI_CM4 2 -#define CLK_INFRA_AUD_SPLIN_B 3 -#define CLK_INFRA_AUDIO 4 -#define CLK_INFRA_EFUSE 5 -#define CLK_INFRA_L2C_SRAM 6 -#define CLK_INFRA_M4U 7 -#define CLK_INFRA_CONNMCU 8 -#define CLK_INFRA_TRNG 9 -#define CLK_INFRA_RAMBUFIF 10 -#define CLK_INFRA_CPUM 11 -#define CLK_INFRA_KP 12 -#define CLK_INFRA_CEC 13 -#define CLK_INFRA_IRRX 14 -#define CLK_INFRA_PMICSPI 15 -#define CLK_INFRA_PMICWRAP 16 -#define CLK_INFRA_DDCCI 17 -#define CLK_INFRA_CPUSEL 18 -#define CLK_INFRA_NR 19 + +#define CLK_INFRA_DBG 1 +#define CLK_INFRA_SMI 2 +#define CLK_INFRA_QAXI_CM4 3 +#define CLK_INFRA_AUD_SPLIN_B 4 +#define CLK_INFRA_AUDIO 5 +#define CLK_INFRA_EFUSE 6 +#define CLK_INFRA_L2C_SRAM 7 +#define CLK_INFRA_M4U 8 +#define CLK_INFRA_CONNMCU 9 +#define CLK_INFRA_TRNG 10 +#define CLK_INFRA_RAMBUFIF 11 +#define CLK_INFRA_CPUM 12 +#define CLK_INFRA_KP 13 +#define CLK_INFRA_CEC 14 +#define CLK_INFRA_IRRX 15 +#define CLK_INFRA_PMICSPI 16 +#define CLK_INFRA_PMICWRAP 17 +#define CLK_INFRA_DDCCI 18 +#define CLK_INFRA_CLK_13M 19 +#define CLK_INFRA_CPUSEL 20 +#define CLK_INFRA_NR 21
/* PERICFG */ -#define CLK_PERI_NFI 0 -#define CLK_PERI_THERM 1 -#define CLK_PERI_PWM1 2 -#define CLK_PERI_PWM2 3 -#define CLK_PERI_PWM3 4 -#define CLK_PERI_PWM4 5 -#define CLK_PERI_PWM5 6 -#define CLK_PERI_PWM6 7 -#define CLK_PERI_PWM7 8 -#define CLK_PERI_PWM 9 -#define CLK_PERI_USB0 10 -#define CLK_PERI_USB1 11 -#define CLK_PERI_AP_DMA 12 -#define CLK_PERI_MSDC30_0 13 -#define CLK_PERI_MSDC30_1 14 -#define CLK_PERI_MSDC30_2 15 -#define CLK_PERI_MSDC30_3 16 -#define CLK_PERI_MSDC50_3 17 -#define CLK_PERI_NLI 18 -#define CLK_PERI_UART0 19 -#define CLK_PERI_UART1 20 -#define CLK_PERI_UART2 21 -#define CLK_PERI_UART3 22 -#define CLK_PERI_BTIF 23 -#define CLK_PERI_I2C0 24 -#define CLK_PERI_I2C1 25 -#define CLK_PERI_I2C2 26 -#define CLK_PERI_I2C3 27 -#define CLK_PERI_AUXADC 28 -#define CLK_PERI_SPI0 39 -#define CLK_PERI_ETH 30 -#define CLK_PERI_USB0_MCU 31 - -#define CLK_PERI_USB1_MCU 32 -#define CLK_PERI_USB_SLV 33 -#define CLK_PERI_GCPU 34 -#define CLK_PERI_NFI_ECC 35 -#define CLK_PERI_NFI_PAD 36 -#define CLK_PERI_FLASH 37 -#define CLK_PERI_HOST89_INT 38 -#define CLK_PERI_HOST89_SPI 39 -#define CLK_PERI_HOST89_DVD 40 -#define CLK_PERI_SPI1 41 -#define CLK_PERI_SPI2 42 -#define CLK_PERI_FCI 43 -#define CLK_PERI_NR 44 + +#define CLK_PERI_NFI 1 +#define CLK_PERI_THERM 2 +#define CLK_PERI_PWM1 3 +#define CLK_PERI_PWM2 4 +#define CLK_PERI_PWM3 5 +#define CLK_PERI_PWM4 6 +#define CLK_PERI_PWM5 7 +#define CLK_PERI_PWM6 8 +#define CLK_PERI_PWM7 9 +#define CLK_PERI_PWM 10 +#define CLK_PERI_USB0 11 +#define CLK_PERI_USB1 12 +#define CLK_PERI_AP_DMA 13 +#define CLK_PERI_MSDC30_0 14 +#define CLK_PERI_MSDC30_1 15 +#define CLK_PERI_MSDC30_2 16 +#define CLK_PERI_MSDC30_3 17 +#define CLK_PERI_MSDC50_3 18 +#define CLK_PERI_NLI 19 +#define CLK_PERI_UART0 20 +#define CLK_PERI_UART1 21 +#define CLK_PERI_UART2 22 +#define CLK_PERI_UART3 23 +#define CLK_PERI_BTIF 24 +#define CLK_PERI_I2C0 25 +#define CLK_PERI_I2C1 26 +#define CLK_PERI_I2C2 27 +#define CLK_PERI_I2C3 28 +#define CLK_PERI_AUXADC 29 +#define CLK_PERI_SPI0 30 +#define CLK_PERI_ETH 31 +#define CLK_PERI_USB0_MCU 32 + +#define CLK_PERI_USB1_MCU 33 +#define CLK_PERI_USB_SLV 34 +#define CLK_PERI_GCPU 35 +#define CLK_PERI_NFI_ECC 36 +#define CLK_PERI_NFI_PAD 37 +#define CLK_PERI_FLASH 38 +#define CLK_PERI_HOST89_INT 39 +#define CLK_PERI_HOST89_SPI 40 +#define CLK_PERI_HOST89_DVD 41 +#define CLK_PERI_SPI1 42 +#define CLK_PERI_SPI2 43 +#define CLK_PERI_FCI 44 + +#define CLK_PERI_UART0_SEL 45 +#define CLK_PERI_UART1_SEL 46 +#define CLK_PERI_UART2_SEL 47 +#define CLK_PERI_UART3_SEL 48 +#define CLK_PERI_NR 49
/* AUDIO */ -#define CLK_AUD_AFE 0 -#define CLK_AUD_LRCK_DETECT 1 -#define CLK_AUD_I2S 2 -#define CLK_AUD_APLL_TUNER 3 -#define CLK_AUD_HDMI 4 -#define CLK_AUD_SPDF 5 -#define CLK_AUD_SPDF2 6 -#define CLK_AUD_APLL 7 -#define CLK_AUD_TML 8 -#define CLK_AUD_AHB_IDLE_EXT 9 -#define CLK_AUD_AHB_IDLE_INT 10 - -#define CLK_AUD_I2SIN1 11 -#define CLK_AUD_I2SIN2 12 -#define CLK_AUD_I2SIN3 13 -#define CLK_AUD_I2SIN4 14 -#define CLK_AUD_I2SIN5 15 -#define CLK_AUD_I2SIN6 16 -#define CLK_AUD_I2SO1 17 -#define CLK_AUD_I2SO2 18 -#define CLK_AUD_I2SO3 19 -#define CLK_AUD_I2SO4 20 -#define CLK_AUD_I2SO5 21 -#define CLK_AUD_I2SO6 22 -#define CLK_AUD_ASRCI1 23 -#define CLK_AUD_ASRCI2 24 -#define CLK_AUD_ASRCO1 25 -#define CLK_AUD_ASRCO2 26 -#define CLK_AUD_ASRC11 27 -#define CLK_AUD_ASRC12 28 -#define CLK_AUD_HDMIRX 29 -#define CLK_AUD_INTDIR 30 -#define CLK_AUD_A1SYS 31 -#define CLK_AUD_A2SYS 32 -#define CLK_AUD_AFE_CONN 33 -#define CLK_AUD_AFE_PCMIF 34 -#define CLK_AUD_AFE_MRGIF 35 - -#define CLK_AUD_MMIF_UL1 36 -#define CLK_AUD_MMIF_UL2 37 -#define CLK_AUD_MMIF_UL3 38 -#define CLK_AUD_MMIF_UL4 39 -#define CLK_AUD_MMIF_UL5 40 -#define CLK_AUD_MMIF_UL6 41 -#define CLK_AUD_MMIF_DL1 42 -#define CLK_AUD_MMIF_DL2 43 -#define CLK_AUD_MMIF_DL3 44 -#define CLK_AUD_MMIF_DL4 45 -#define CLK_AUD_MMIF_DL5 46 -#define CLK_AUD_MMIF_DL6 47 -#define CLK_AUD_MMIF_DLMCH 48 -#define CLK_AUD_MMIF_ARB1 49 -#define CLK_AUD_MMIF_AWB1 50 -#define CLK_AUD_MMIF_AWB2 51 -#define CLK_AUD_MMIF_DAI 52 - -#define CLK_AUD_DMIC1 53 -#define CLK_AUD_DMIC2 54 -#define CLK_AUD_ASRCI3 55 -#define CLK_AUD_ASRCI4 56 -#define CLK_AUD_ASRCI5 57 -#define CLK_AUD_ASRCI6 58 -#define CLK_AUD_ASRCO3 59 -#define CLK_AUD_ASRCO4 60 -#define CLK_AUD_ASRCO5 61 -#define CLK_AUD_ASRCO6 62 -#define CLK_AUD_MEM_ASRC1 63 -#define CLK_AUD_MEM_ASRC2 64 -#define CLK_AUD_MEM_ASRC3 65 -#define CLK_AUD_MEM_ASRC4 66 -#define CLK_AUD_MEM_ASRC5 67 -#define CLK_AUD_DSD_ENC 68 -#define CLK_AUD_ASRC_BRG 60 -#define CLK_AUD_NR 70 + +#define CLK_AUD_AFE 1 +#define CLK_AUD_LRCK_DETECT 2 +#define CLK_AUD_I2S 3 +#define CLK_AUD_APLL_TUNER 4 +#define CLK_AUD_HDMI 5 +#define CLK_AUD_SPDF 6 +#define CLK_AUD_SPDF2 7 +#define CLK_AUD_APLL 8 +#define CLK_AUD_TML 9 +#define CLK_AUD_AHB_IDLE_EXT 10 +#define CLK_AUD_AHB_IDLE_INT 11 + +#define CLK_AUD_I2SIN1 12 +#define CLK_AUD_I2SIN2 13 +#define CLK_AUD_I2SIN3 14 +#define CLK_AUD_I2SIN4 15 +#define CLK_AUD_I2SIN5 16 +#define CLK_AUD_I2SIN6 17 +#define CLK_AUD_I2SO1 18 +#define CLK_AUD_I2SO2 19 +#define CLK_AUD_I2SO3 20 +#define CLK_AUD_I2SO4 21 +#define CLK_AUD_I2SO5 22 +#define CLK_AUD_I2SO6 23 +#define CLK_AUD_ASRCI1 24 +#define CLK_AUD_ASRCI2 25 +#define CLK_AUD_ASRCO1 26 +#define CLK_AUD_ASRCO2 27 +#define CLK_AUD_ASRC11 28 +#define CLK_AUD_ASRC12 29 +#define CLK_AUD_HDMIRX 30 +#define CLK_AUD_INTDIR 31 +#define CLK_AUD_A1SYS 32 +#define CLK_AUD_A2SYS 33 +#define CLK_AUD_AFE_CONN 34 +#define CLK_AUD_AFE_PCMIF 35 +#define CLK_AUD_AFE_MRGIF 36 + +#define CLK_AUD_MMIF_UL1 37 +#define CLK_AUD_MMIF_UL2 38 +#define CLK_AUD_MMIF_UL3 39 +#define CLK_AUD_MMIF_UL4 40 +#define CLK_AUD_MMIF_UL5 41 +#define CLK_AUD_MMIF_UL6 42 +#define CLK_AUD_MMIF_DL1 43 +#define CLK_AUD_MMIF_DL2 44 +#define CLK_AUD_MMIF_DL3 45 +#define CLK_AUD_MMIF_DL4 46 +#define CLK_AUD_MMIF_DL5 47 +#define CLK_AUD_MMIF_DL6 48 +#define CLK_AUD_MMIF_DLMCH 49 +#define CLK_AUD_MMIF_ARB1 50 +#define CLK_AUD_MMIF_AWB1 51 +#define CLK_AUD_MMIF_AWB2 52 +#define CLK_AUD_MMIF_DAI 53 + +#define CLK_AUD_DMIC1 54 +#define CLK_AUD_DMIC2 55 +#define CLK_AUD_ASRCI3 56 +#define CLK_AUD_ASRCI4 57 +#define CLK_AUD_ASRCI5 58 +#define CLK_AUD_ASRCI6 59 +#define CLK_AUD_ASRCO3 60 +#define CLK_AUD_ASRCO4 61 +#define CLK_AUD_ASRCO5 62 +#define CLK_AUD_ASRCO6 63 +#define CLK_AUD_MEM_ASRC1 64 +#define CLK_AUD_MEM_ASRC2 65 +#define CLK_AUD_MEM_ASRC3 66 +#define CLK_AUD_MEM_ASRC4 67 +#define CLK_AUD_MEM_ASRC5 68 +#define CLK_AUD_DSD_ENC 69 +#define CLK_AUD_ASRC_BRG 70 +#define CLK_AUD_NR 71
/* MMSYS */ -#define CLK_MM_SMI_COMMON 0 -#define CLK_MM_SMI_LARB0 1 -#define CLK_MM_CMDQ 2 -#define CLK_MM_MUTEX 3 -#define CLK_MM_DISP_COLOR 4 -#define CLK_MM_DISP_BLS 5 -#define CLK_MM_DISP_WDMA 6 -#define CLK_MM_DISP_RDMA 7 -#define CLK_MM_DISP_OVL 8 -#define CLK_MM_MDP_TDSHP 9 -#define CLK_MM_MDP_WROT 10 -#define CLK_MM_MDP_WDMA 11 -#define CLK_MM_MDP_RSZ1 12 -#define CLK_MM_MDP_RSZ0 13 -#define CLK_MM_MDP_RDMA 14 -#define CLK_MM_MDP_BLS_26M 15 -#define CLK_MM_CAM_MDP 16 -#define CLK_MM_FAKE_ENG 17 -#define CLK_MM_MUTEX_32K 18 -#define CLK_MM_DISP_RDMA1 19 -#define CLK_MM_DISP_UFOE 20 - -#define CLK_MM_DSI_ENGINE 21 -#define CLK_MM_DSI_DIG 22 -#define CLK_MM_DPI_DIGL 23 -#define CLK_MM_DPI_ENGINE 24 -#define CLK_MM_DPI1_DIGL 25 -#define CLK_MM_DPI1_ENGINE 26 -#define CLK_MM_TVE_OUTPUT 27 -#define CLK_MM_TVE_INPUT 28 -#define CLK_MM_HDMI_PIXEL 29 -#define CLK_MM_HDMI_PLL 30 -#define CLK_MM_HDMI_AUDIO 31 -#define CLK_MM_HDMI_SPDIF 32 -#define CLK_MM_TVE_FMM 33 -#define CLK_MM_NR 34 + +#define CLK_MM_SMI_COMMON 1 +#define CLK_MM_SMI_LARB0 2 +#define CLK_MM_CMDQ 3 +#define CLK_MM_MUTEX 4 +#define CLK_MM_DISP_COLOR 5 +#define CLK_MM_DISP_BLS 6 +#define CLK_MM_DISP_WDMA 7 +#define CLK_MM_DISP_RDMA 8 +#define CLK_MM_DISP_OVL 9 +#define CLK_MM_MDP_TDSHP 10 +#define CLK_MM_MDP_WROT 11 +#define CLK_MM_MDP_WDMA 12 +#define CLK_MM_MDP_RSZ1 13 +#define CLK_MM_MDP_RSZ0 14 +#define CLK_MM_MDP_RDMA 15 +#define CLK_MM_MDP_BLS_26M 16 +#define CLK_MM_CAM_MDP 17 +#define CLK_MM_FAKE_ENG 18 +#define CLK_MM_MUTEX_32K 19 +#define CLK_MM_DISP_RDMA1 20 +#define CLK_MM_DISP_UFOE 21 + +#define CLK_MM_DSI_ENGINE 22 +#define CLK_MM_DSI_DIG 23 +#define CLK_MM_DPI_DIGL 24 +#define CLK_MM_DPI_ENGINE 25 +#define CLK_MM_DPI1_DIGL 26 +#define CLK_MM_DPI1_ENGINE 27 +#define CLK_MM_TVE_OUTPUT 28 +#define CLK_MM_TVE_INPUT 29 +#define CLK_MM_HDMI_PIXEL 30 +#define CLK_MM_HDMI_PLL 31 +#define CLK_MM_HDMI_AUDIO 32 +#define CLK_MM_HDMI_SPDIF 33 +#define CLK_MM_TVE_FMM 34 +#define CLK_MM_NR 35
/* IMGSYS */ -#define CLK_IMG_SMI_COMM 0 -#define CLK_IMG_RESZ 1 -#define CLK_IMG_JPGDEC_SMI 2 -#define CLK_IMG_JPGDEC 3 -#define CLK_IMG_VENC_LT 4 -#define CLK_IMG_VENC 5 -#define CLK_IMG_NR 6 + +#define CLK_IMG_SMI_COMM 1 +#define CLK_IMG_RESZ 2 +#define CLK_IMG_JPGDEC_SMI 3 +#define CLK_IMG_JPGDEC 4 +#define CLK_IMG_VENC_LT 5 +#define CLK_IMG_VENC 6 +#define CLK_IMG_NR 7
/* VDEC */ -#define CLK_VDEC_CKGEN 0 -#define CLK_VDEC_LARB 1 -#define CLK_VDEC_NR 2 + +#define CLK_VDEC_CKGEN 1 +#define CLK_VDEC_LARB 2 +#define CLK_VDEC_NR 3
/* HIFSYS */ -#define CLK_HIFSYS_USB0PHY 0 -#define CLK_HIFSYS_USB1PHY 1 -#define CLK_HIFSYS_PCIE0 2 -#define CLK_HIFSYS_PCIE1 3 -#define CLK_HIFSYS_PCIE2 4 -#define CLK_HIFSYS_NR 5 + +#define CLK_HIFSYS_USB0PHY 1 +#define CLK_HIFSYS_USB1PHY 2 +#define CLK_HIFSYS_PCIE0 3 +#define CLK_HIFSYS_PCIE1 4 +#define CLK_HIFSYS_PCIE2 5 +#define CLK_HIFSYS_NR 6
/* ETHSYS */ -#define CLK_ETHSYS_HSDMA 0 -#define CLK_ETHSYS_ESW 1 -#define CLK_ETHSYS_GP2 2 -#define CLK_ETHSYS_GP1 3 -#define CLK_ETHSYS_PCM 4 -#define CLK_ETHSYS_GDMA 5 -#define CLK_ETHSYS_I2S 6 -#define CLK_ETHSYS_CRYPTO 7 -#define CLK_ETHSYS_NR 8 +#define CLK_ETHSYS_HSDMA 1 +#define CLK_ETHSYS_ESW 2 +#define CLK_ETHSYS_GP2 3 +#define CLK_ETHSYS_GP1 4 +#define CLK_ETHSYS_PCM 5 +#define CLK_ETHSYS_GDMA 6 +#define CLK_ETHSYS_I2S 7 +#define CLK_ETHSYS_CRYPTO 8 +#define CLK_ETHSYS_NR 9
/* G3DSYS */ -#define CLK_G3DSYS_CORE 0 -#define CLK_G3DSYS_NR 1 +#define CLK_G3DSYS_CORE 1 +#define CLK_G3DSYS_NR 2 + +/* BDP */ + +#define CLK_BDP_BRG_BA 1 +#define CLK_BDP_BRG_DRAM 2 +#define CLK_BDP_LARB_DRAM 3 +#define CLK_BDP_WR_VDI_PXL 4 +#define CLK_BDP_WR_VDI_DRAM 5 +#define CLK_BDP_WR_B 6 +#define CLK_BDP_DGI_IN 7 +#define CLK_BDP_DGI_OUT 8 +#define CLK_BDP_FMT_MAST_27 9 +#define CLK_BDP_FMT_B 10 +#define CLK_BDP_OSD_B 11 +#define CLK_BDP_OSD_DRAM 12 +#define CLK_BDP_OSD_AGENT 13 +#define CLK_BDP_OSD_PXL 14 +#define CLK_BDP_RLE_B 15 +#define CLK_BDP_RLE_AGENT 16 +#define CLK_BDP_RLE_DRAM 17 +#define CLK_BDP_F27M 18 +#define CLK_BDP_F27M_VDOUT 19 +#define CLK_BDP_F27_74_74 20 +#define CLK_BDP_F2FS 21 +#define CLK_BDP_F2FS74_148 22 +#define CLK_BDP_FB 23 +#define CLK_BDP_VDO_DRAM 24 +#define CLK_BDP_VDO_2FS 25 +#define CLK_BDP_VDO_B 26 +#define CLK_BDP_WR_DI_PXL 27 +#define CLK_BDP_WR_DI_DRAM 28 +#define CLK_BDP_WR_DI_B 29 +#define CLK_BDP_NR_PXL 30 +#define CLK_BDP_NR_DRAM 31 +#define CLK_BDP_NR_B 32 + +#define CLK_BDP_RX_F 33 +#define CLK_BDP_RX_X 34 +#define CLK_BDP_RXPDT 35 +#define CLK_BDP_RX_CSCL_N 36 +#define CLK_BDP_RX_CSCL 37 +#define CLK_BDP_RX_DDCSCL_N 38 +#define CLK_BDP_RX_DDCSCL 39 +#define CLK_BDP_RX_VCO 40 +#define CLK_BDP_RX_DP 41 +#define CLK_BDP_RX_P 42 +#define CLK_BDP_RX_M 43 +#define CLK_BDP_RX_PLL 44 +#define CLK_BDP_BRG_RT_B 45 +#define CLK_BDP_BRG_RT_DRAM 46 +#define CLK_BDP_LARBRT_DRAM 47 +#define CLK_BDP_TMDS_SYN 48 +#define CLK_BDP_HDMI_MON 49 +#define CLK_BDP_NR 50
#endif /* _DT_BINDINGS_CLK_MT2701_H */
Define remap table also for apmixedsys clock ID. The clock ID starts from 1 instead of 0 in upstream kernel linux.
Signed-off-by: Christian Marangi ansuelsmth@gmail.com --- drivers/clk/mediatek/clk-mt7623.c | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/drivers/clk/mediatek/clk-mt7623.c b/drivers/clk/mediatek/clk-mt7623.c index 6af6f9f11bd..78e390d49f8 100644 --- a/drivers/clk/mediatek/clk-mt7623.c +++ b/drivers/clk/mediatek/clk-mt7623.c @@ -25,6 +25,22 @@ #define AXI_DIV_SEL(x) (x)
/* apmixedsys */ +static const int pll_id_offs_map[] = { + [CLK_APMIXED_ARMPLL] = 0, + [CLK_APMIXED_MAINPLL] = 1, + [CLK_APMIXED_UNIVPLL] = 2, + [CLK_APMIXED_MMPLL] = 3, + [CLK_APMIXED_MSDCPLL] = 4, + [CLK_APMIXED_TVDPLL] = 5, + [CLK_APMIXED_AUD1PLL] = 6, + [CLK_APMIXED_TRGPLL] = 7, + [CLK_APMIXED_ETHPLL] = 8, + [CLK_APMIXED_VDECPLL] = 9, + [CLK_APMIXED_HADDS2PLL] = 10, + [CLK_APMIXED_AUD2PLL] = 11, + [CLK_APMIXED_TVD2PLL] = 12, +}; + #define PLL(_id, _reg, _pwr_reg, _en_mask, _flags, _pcwbits, _pd_reg, \ _pd_shift, _pcw_reg, _pcw_shift) { \ .id = _id, \ @@ -911,6 +927,7 @@ static const struct mtk_gate hif_cgs[] = {
static const struct mtk_clk_tree mt7623_apmixedsys_clk_tree = { .xtal2_rate = 26 * MHZ, + .id_offs_map = pll_id_offs_map, .plls = apmixed_plls, };
Upstream kernel linux makes use of peri clock MUX to setup UART.
Add definition for these and add remap table as in the upstream clock ID order gates are before MUX but we require MUX first and then clocks in our downstream driver.
Convert the peri clk tree to MUX + GATE implementation.
Signed-off-by: Christian Marangi ansuelsmth@gmail.com --- drivers/clk/mediatek/clk-mt7623.c | 83 +++++++++++++++++++++++++++++-- 1 file changed, 80 insertions(+), 3 deletions(-)
diff --git a/drivers/clk/mediatek/clk-mt7623.c b/drivers/clk/mediatek/clk-mt7623.c index 78e390d49f8..d0b80f48b0a 100644 --- a/drivers/clk/mediatek/clk-mt7623.c +++ b/drivers/clk/mediatek/clk-mt7623.c @@ -807,6 +807,74 @@ static const struct mtk_gate infra_cgs[] = { };
/* pericfg */ +static const int peri_id_offs_map[] = { + /* MUX CLK */ + [CLK_PERI_UART0_SEL] = 1, + [CLK_PERI_UART1_SEL] = 2, + [CLK_PERI_UART2_SEL] = 3, + [CLK_PERI_UART3_SEL] = 4, + /* GATE CLK */ + [CLK_PERI_NFI] = 5, + [CLK_PERI_THERM] = 6, + [CLK_PERI_PWM1] = 7, + [CLK_PERI_PWM2] = 8, + [CLK_PERI_PWM3] = 9, + [CLK_PERI_PWM4] = 10, + [CLK_PERI_PWM5] = 11, + [CLK_PERI_PWM6] = 12, + [CLK_PERI_PWM7] = 13, + [CLK_PERI_PWM] = 14, + [CLK_PERI_USB0] = 15, + [CLK_PERI_USB1] = 16, + [CLK_PERI_AP_DMA] = 17, + [CLK_PERI_MSDC30_0] = 18, + [CLK_PERI_MSDC30_1] = 19, + [CLK_PERI_MSDC30_2] = 20, + [CLK_PERI_MSDC30_3] = 21, + [CLK_PERI_MSDC50_3] = 22, + [CLK_PERI_NLI] = 23, + [CLK_PERI_UART0] = 24, + [CLK_PERI_UART1] = 25, + [CLK_PERI_UART2] = 26, + [CLK_PERI_UART3] = 27, + [CLK_PERI_BTIF] = 28, + [CLK_PERI_I2C0] = 29, + [CLK_PERI_I2C1] = 30, + [CLK_PERI_I2C2] = 31, + [CLK_PERI_I2C3] = 32, + [CLK_PERI_AUXADC] = 33, + [CLK_PERI_SPI0] = 34, + [CLK_PERI_ETH] = 35, + [CLK_PERI_USB0_MCU] = 36, + [CLK_PERI_USB1_MCU] = 37, + [CLK_PERI_USB_SLV] = 38, + [CLK_PERI_GCPU] = 39, + [CLK_PERI_NFI_ECC] = 40, + [CLK_PERI_NFI_PAD] = 41, + [CLK_PERI_FLASH] = 42, + [CLK_PERI_HOST89_INT] = 43, + [CLK_PERI_HOST89_SPI] = 44, + [CLK_PERI_HOST89_DVD] = 45, + [CLK_PERI_SPI1] = 46, + [CLK_PERI_SPI2] = 47, + [CLK_PERI_FCI] = 48, +}; + +#define TOP_PARENT(_id) PARENT(_id, CLK_PARENT_TOPCKGEN) +#define XTAL_PARENT(_id) PARENT(_id, CLK_PARENT_XTAL) + +static const struct mtk_parent uart_ck_sel_parents[] = { + XTAL_PARENT(CLK_XTAL), + TOP_PARENT(CLK_TOP_UART_SEL), +}; + +static const struct mtk_composite peri_muxes[] = { + MUX_MIXED(CLK_PERI_UART0_SEL, uart_ck_sel_parents, 0x40C, 0, 1), + MUX_MIXED(CLK_PERI_UART1_SEL, uart_ck_sel_parents, 0x40C, 1, 1), + MUX_MIXED(CLK_PERI_UART2_SEL, uart_ck_sel_parents, 0x40C, 2, 1), + MUX_MIXED(CLK_PERI_UART3_SEL, uart_ck_sel_parents, 0x40C, 3, 1), +}; + static const struct mtk_gate_regs peri0_cg_regs = { .set_ofs = 0x8, .clr_ofs = 0x10, @@ -980,6 +1048,7 @@ static int mt7623_topckgen_probe(struct udevice *dev) static const struct mtk_clk_tree mt7623_clk_gate_tree = { /* Each CLK ID for gates clock starts at index 1 */ .gates_offs = 1, + .xtal_rate = 26 * MHZ, };
static int mt7623_infracfg_probe(struct udevice *dev) @@ -988,10 +1057,18 @@ static int mt7623_infracfg_probe(struct udevice *dev) infra_cgs); }
+static const struct mtk_clk_tree mt7623_clk_peri_tree = { + .id_offs_map = peri_id_offs_map, + .muxes_offs = peri_id_offs_map[CLK_PERI_UART0_SEL], + .gates_offs = peri_id_offs_map[CLK_PERI_NFI], + .muxes = peri_muxes, + .gates = peri_cgs, + .xtal_rate = 26 * MHZ, +}; + static int mt7623_pericfg_probe(struct udevice *dev) { - return mtk_common_clk_gate_init(dev, &mt7623_clk_gate_tree, - peri_cgs); + return mtk_common_clk_infrasys_init(dev, &mt7623_clk_peri_tree); }
static int mt7623_hifsys_probe(struct udevice *dev) @@ -1098,7 +1175,7 @@ U_BOOT_DRIVER(mtk_clk_pericfg) = { .of_match = mt7623_pericfg_compat, .probe = mt7623_pericfg_probe, .priv_auto = sizeof(struct mtk_cg_priv), - .ops = &mtk_clk_gate_ops, + .ops = &mtk_clk_infrasys_ops, .flags = DM_FLAG_PRE_RELOC, };
does not break downstream dts (still have some issues with ethernet without the series, which i cannot nail down) so only tested: usb,mmc,pci,sata
also works with upstream dts and a bunch of modifications (i still need to clean)
Tested-by: Frank Wunderlich frank-w@public-files.de
regards Frank
Gesendet: Freitag, 02. August 2024 um 15:45 Uhr Von: "Christian Marangi" ansuelsmth@gmail.com An: "Lukasz Majewski" lukma@denx.de, "Sean Anderson" seanga2@gmail.com, "Ryder Lee" ryder.lee@mediatek.com, "Weijie Gao" weijie.gao@mediatek.com, "Chunfeng Yun" chunfeng.yun@mediatek.com, "GSS_MTK_Uboot_upstream" GSS_MTK_Uboot_upstream@mediatek.com, "Tom Rini" trini@konsulko.com, "Christian Marangi" ansuelsmth@gmail.com, u-boot@lists.denx.de Betreff: [PATCH 5/5] clk: mediatek: mt7623: remap peri clock ID and add MUX
- /* MUX CLK */
- [CLK_PERI_UART0_SEL] = 1,
- [CLK_PERI_UART1_SEL] = 2,
- [CLK_PERI_UART2_SEL] = 3,
- [CLK_PERI_UART3_SEL] = 4,
- /* GATE CLK */
- [CLK_PERI_NFI] = 5,
- [CLK_PERI_THERM] = 6,
- [CLK_PERI_PWM1] = 7,
- [CLK_PERI_PWM2] = 8,
- [CLK_PERI_PWM3] = 9,
- [CLK_PERI_PWM4] = 10,
- [CLK_PERI_PWM5] = 11,
- [CLK_PERI_PWM6] = 12,
- [CLK_PERI_PWM7] = 13,
- [CLK_PERI_PWM] = 14,
- [CLK_PERI_USB0] = 15,
- [CLK_PERI_USB1] = 16,
- [CLK_PERI_AP_DMA] = 17,
- [CLK_PERI_MSDC30_0] = 18,
- [CLK_PERI_MSDC30_1] = 19,
- [CLK_PERI_MSDC30_2] = 20,
- [CLK_PERI_MSDC30_3] = 21,
- [CLK_PERI_MSDC50_3] = 22,
- [CLK_PERI_NLI] = 23,
- [CLK_PERI_UART0] = 24,
- [CLK_PERI_UART1] = 25,
- [CLK_PERI_UART2] = 26,
- [CLK_PERI_UART3] = 27,
- [CLK_PERI_BTIF] = 28,
- [CLK_PERI_I2C0] = 29,
- [CLK_PERI_I2C1] = 30,
- [CLK_PERI_I2C2] = 31,
- [CLK_PERI_I2C3] = 32,
- [CLK_PERI_AUXADC] = 33,
- [CLK_PERI_SPI0] = 34,
- [CLK_PERI_ETH] = 35,
- [CLK_PERI_USB0_MCU] = 36,
- [CLK_PERI_USB1_MCU] = 37,
- [CLK_PERI_USB_SLV] = 38,
- [CLK_PERI_GCPU] = 39,
- [CLK_PERI_NFI_ECC] = 40,
- [CLK_PERI_NFI_PAD] = 41,
- [CLK_PERI_FLASH] = 42,
- [CLK_PERI_HOST89_INT] = 43,
- [CLK_PERI_HOST89_SPI] = 44,
- [CLK_PERI_HOST89_DVD] = 45,
- [CLK_PERI_SPI1] = 46,
- [CLK_PERI_SPI2] = 47,
- [CLK_PERI_FCI] = 48,
- XTAL_PARENT(CLK_XTAL),
- TOP_PARENT(CLK_TOP_UART_SEL),
- MUX_MIXED(CLK_PERI_UART0_SEL, uart_ck_sel_parents, 0x40C, 0, 1),
- MUX_MIXED(CLK_PERI_UART1_SEL, uart_ck_sel_parents, 0x40C, 1, 1),
- MUX_MIXED(CLK_PERI_UART2_SEL, uart_ck_sel_parents, 0x40C, 2, 1),
- MUX_MIXED(CLK_PERI_UART3_SEL, uart_ck_sel_parents, 0x40C, 3, 1),
- .id_offs_map = peri_id_offs_map,
- .muxes_offs = peri_id_offs_map[CLK_PERI_UART0_SEL],
- .gates_offs = peri_id_offs_map[CLK_PERI_NFI],
- .muxes = peri_muxes,
- .gates = peri_cgs,
peri_cgs);
- return mtk_common_clk_infrasys_init(dev, &mt7623_clk_peri_tree);
- .ops = &mtk_clk_infrasys_ops, .flags = DM_FLAG_PRE_RELOC,
-- 2.45.2
Christian Marangi
Frank Wunderlich
