[U-Boot] [PATCH] Origen: Correct equation to calculate PLL output frequency
EXYNOS4 user manual equation for calculating PLL output is FOUT= MDIV x FIN/(PDIV x 2^(SDIV -1)) hence updating accordingly.
Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- arch/arm/cpu/armv7/exynos/clock.c | 11 +++++++++-- 1 files changed, 9 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/clock.c b/arch/arm/cpu/armv7/exynos/clock.c index e1c4246..af0fa5b 100644 --- a/arch/arm/cpu/armv7/exynos/clock.c +++ b/arch/arm/cpu/armv7/exynos/clock.c @@ -116,8 +116,15 @@ static int exynos_get_pll_clk(int pllreg, unsigned int r, unsigned int k) /* FOUT = (MDIV + K / 1024) * FIN / (PDIV * 2^SDIV) */ fout = (m + k / 1024) * (freq / (p * (1 << s))); } else { - /* FOUT = MDIV * FIN / (PDIV * 2^SDIV) */ - fout = m * (freq / (p * (1 << s))); + if (cpu_is_exynos4()) { + if (s < 1) + s = 1; + /* FOUT = MDIV * FIN / (PDIV * 2^(SDIV - 1)) */ + fout = m * (freq / (p * (1 << (s - 1)))); + } else { + /* FOUT = MDIV * FIN / (PDIV * 2^SDIV) */ + fout = m * (freq / (p * (1 << s))); + } }
return fout;
if (s < 1)
s = 1;
} else {
return fout;
I checked about it. It was wrong, but your patch doesn't fit too.
exynos4210 FOUT = MDIV * FIN / (PDIV * 2^(SDIV - 1))
exynos4412 FOUT = MDIV * FIN / (PDIV * 2^SDIV)
exynos5250 FOUT = MDIV * FIN / (PDIV * 2^(SDIV - 1))
At past, our code was, FOUT = MDIV * FIN / (PDIV * 2^(SDIV - 1)) It was changed by Akshay's patch.
commit 234370cab4b2f096e095fe8f3284fd39740a4023 Author: Akshay Saraswat akshay.s@samsung.com Date: Fri Mar 22 02:26:36 2013 +0000
Exynos5: clock: Update the equation to calculate PLL output frequency
According to the latest exynos5 user manual, the equation for calculating PLL output was changed to FOUT= MDIV x FIN/(PDIV x 2^SDIV) earlier it was FOUT= MDIV x FIN/(PDIV x 2^(SDIV -1)) So updating the clock code accordingly.
Signed-off-by: Hatim Ali hatim.rv@samsung.com Signed-off-by: Akshay Saraswat akshay.s@samsung.com Acked-by: Simon Glass sjg@chromium.org
According to Akshay's patch. exynos5250 should be FOUT = MDIV * FIN / (PDIV * 2^SDIV) but my manual (I'm not sure that is latest version) shows FOUT = MDIV * FIN / (PDIV * 2^(SDIV - 1))
Akshay, please check this.
Rajeshwari, Thank you for raise this issue, I'll check it and resend the patch.
Thanks, Minkyu Kang.
Hi Minkyu Kang,
As per the user manual I have for EXYNOS5 it is FOUT = MDIV * FIN / (PDIV * 2^SDIV)
Regards, Rajeshwari Shinde.
if (s < 1)
s = 1;
} else {
} } return fout;
Exynos5: clock: Update the equation to calculate PLL output frequency According to the latest exynos5 user manual, the equation for calculating PLL output was changed to FOUT= MDIV x FIN/(PDIV x 2^SDIV) earlier it was FOUT= MDIV x FIN/(PDIV x 2^(SDIV -1)) So updating the clock code accordingly. Signed-off-by: Hatim Ali <hatim.rv@samsung.com> Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org>
Thanks, Minkyu Kang. _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
On 01/07/13 17:41, Rajeshwari Birje wrote:
Hi Minkyu Kang,
What is your version of manual? If possible, could you please send it to me?
if (s < 1)
s = 1;
} else {
} } return fout;
Minkyu Kang
Rajeshwari Birje
Rajeshwari Shinde
