[PATCH] board: rockchip: Add Hardkernel ODROID-M1S
Hardkernel ODROID-M1S is a single board computer with a RK3566 SoC, a slightly modified version of the RK3566 SoC.
Features tested on a ODROID-M1S 8GB v1.0 2023-08-10: - SD-card boot - eMMC boot - PCIe/NVMe
Signed-off-by: Dongjin Kim tobetter@gmail.com --- arch/arm/dts/rk3566-odroid-m1s-u-boot.dtsi | 28 + arch/arm/dts/rk3566-odroid-m1s.dts | 665 +++++++++++++++++++++ arch/arm/mach-rockchip/rk3568/Kconfig | 6 + board/hardkernel/odroid_m1s/Kconfig | 15 + board/hardkernel/odroid_m1s/MAINTAINERS | 9 + board/hardkernel/odroid_m1s/Makefile | 7 + board/hardkernel/odroid_m1s/board.c | 80 +++ configs/odroid-m1s-rk3566_defconfig | 109 ++++ doc/board/rockchip/rockchip.rst | 1 + include/configs/odroid_m1s.h | 12 + 10 files changed, 932 insertions(+) create mode 100644 arch/arm/dts/rk3566-odroid-m1s-u-boot.dtsi create mode 100644 arch/arm/dts/rk3566-odroid-m1s.dts create mode 100644 board/hardkernel/odroid_m1s/Kconfig create mode 100644 board/hardkernel/odroid_m1s/MAINTAINERS create mode 100644 board/hardkernel/odroid_m1s/Makefile create mode 100644 board/hardkernel/odroid_m1s/board.c create mode 100644 configs/odroid-m1s-rk3566_defconfig create mode 100644 include/configs/odroid_m1s.h
diff --git a/arch/arm/dts/rk3566-odroid-m1s-u-boot.dtsi b/arch/arm/dts/rk3566-odroid-m1s-u-boot.dtsi new file mode 100644 index 00000000000..33a1d142b8c --- /dev/null +++ b/arch/arm/dts/rk3566-odroid-m1s-u-boot.dtsi @@ -0,0 +1,28 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +#include "rk356x-u-boot.dtsi" + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/leds/common.h> + +/ { + chosen { + stdout-path = &uart2; + u-boot,spl-boot-order = &sdmmc0, &sdhci; + }; +}; + +&sdhci { + cap-mmc-highspeed; + mmc-ddr-1_8v; + mmc-hs200-1_8v; + mmc-hs400-1_8v; + mmc-hs400-enhanced-strobe; + pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd &emmc_datastrobe>; +}; + +&uart2 { + bootph-all; + clock-frequency = <24000000>; + status = "okay"; +}; diff --git a/arch/arm/dts/rk3566-odroid-m1s.dts b/arch/arm/dts/rk3566-odroid-m1s.dts new file mode 100644 index 00000000000..73e29d80c71 --- /dev/null +++ b/arch/arm/dts/rk3566-odroid-m1s.dts @@ -0,0 +1,665 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2024 Hardkernel Co., Ltd. + * + */ + +/dts-v1/; +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/leds/common.h> +#include <dt-bindings/pinctrl/rockchip.h> +#include <dt-bindings/soc/rockchip,vop2.h> +#include "rk3566.dtsi" + +/ { + model = "Hardkernel ODROID-M1S"; + compatible = "hardkernel,rk3568-odroid-m1s", "rockchip,rk3568"; + + aliases { + ethernet0 = &gmac1; + i2c0 = &i2c3; + i2c3 = &i2c0; + mmc0 = &sdhci; + mmc1 = &sdmmc0; + serial0 = &uart1; + serial1 = &uart0; + }; + + chosen { + stdout-path = "serial2:1500000n8"; + }; + + gmac1_clkin: external-gmac1-clock { + compatible = "fixed-clock"; + clock-frequency = <125000000>; + clock-output-names = "gmac1_clkin"; + #clock-cells = <0>; + }; + + hdmi-con { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&hdmi_out_con>; + }; + }; + }; + + leds { + compatible = "gpio-leds"; + + led_power: led-0 { + gpios = <&gpio0 RK_PC6 GPIO_ACTIVE_HIGH>; + function = LED_FUNCTION_POWER; + color = <LED_COLOR_ID_RED>; + default-state = "keep"; + linux,default-trigger = "default-on"; + pinctrl-names = "default"; + pinctrl-0 = <&led_power_pin>; + }; + led_work: led-1 { + gpios = <&gpio0 RK_PB7 GPIO_ACTIVE_HIGH>; + function = LED_FUNCTION_HEARTBEAT; + color = <LED_COLOR_ID_BLUE>; + linux,default-trigger = "heartbeat"; + pinctrl-names = "default"; + pinctrl-0 = <&led_work_pin>; + }; + }; + + pcie20_3v3: pcie20-3v3-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpios = <&gpio2 RK_PC2 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc3v3_pcie20_en_pin>; + regulator-name = "pcie20_3v3"; + regulator-always-on; + regulator-boot-on; + }; + + rk809-sound { + compatible = "simple-audio-card"; + simple-audio-card,name = "Analog RK817"; + simple-audio-card,format = "i2s"; + simple-audio-card,mclk-fs = <256>; + simple-audio-card,widgets = + "Headphone", "Headphones", + "Speaker", "Speaker"; + simple-audio-card,routing = + "Headphones", "HPOL", + "Headphones", "HPOR", + "Speaker", "SPKO"; + + simple-audio-card,cpu { + sound-dai = <&i2s1_8ch>; + }; + + simple-audio-card,codec { + sound-dai = <&rk809>; + }; + }; + + spdif_dit: spdif-dit { + compatible = "linux,spdif-dit"; + #sound-dai-cells = <0>; + status = "disabled"; + }; + + spdif_sound: spdif-sound { + compatible = "simple-audio-card"; + status = "disabled"; + + simple-audio-card,cpu { + sound-dai = <&spdif>; + }; + + simple-audio-card,codec { + sound-dai = <&spdif_dit>; + }; + }; + + vcc3v3_sys: vcc3v3-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc5v0_sys>; + }; + + vcc5v0_sys: vcc5v0-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc5v_dcin>; + }; + + vcc5v_dcin: vcc5v0-dcin { + compatible = "regulator-fixed"; + regulator-name = "vcc-5v0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + vcc5v0_usb_host: vcc5v0-usb-host-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 RK_PA5 GPIO_ACTIVE_HIGH>; + pinctrl-0 = <&vcc5v0_usb_host_en_pin>; + pinctrl-names = "default"; + regulator-max-microvolt = <5000000>; + regulator-min-microvolt = <5000000>; + regulator-name = "vcc5v0_usb_host"; + vin-supply = <&vcc5v0_sys>; + }; + + vcc5v0_usb_otg: vcc5v0-usb-otg-regulator { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>; + pinctrl-0 = <&vcc5v0_usb_otg_en_pin>; + pinctrl-names = "default"; + regulator-max-microvolt = <5000000>; + regulator-min-microvolt = <5000000>; + regulator-name = "vcc5v0_usb_otg"; + vin-supply = <&vcc5v0_sys>; + }; +}; + +&combphy1 { + phy-supply = <&vcc5v0_usb_host>; + status = "okay"; +}; + +&combphy2 { + status = "okay"; +}; + +&cpu0 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu1 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu2 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu3 { + cpu-supply = <&vdd_cpu>; +}; + +&gmac1 { + assigned-clock-parents = <&cru SCLK_GMAC1_RGMII_SPEED>; + assigned-clock-rates = <0>, <125000000>; + assigned-clocks = <&cru SCLK_GMAC1_RX_TX>, <&cru SCLK_GMAC1>; + clock_in_out = "output"; + phy-handle = <&rgmii_phy1>; + phy-mode = "rgmii"; + phy-supply = <&vcc3v3_sys>; + pinctrl-names = "default"; + pinctrl-0 = <&gmac1m1_miim + &gmac1m1_tx_bus2 + &gmac1m1_rx_bus2 + &gmac1m1_rgmii_clk + &gmac1m1_rgmii_bus + &gmac1m1_clkinout>; + status = "okay"; + + tx_delay = <0x4f>; + rx_delay = <0x2d>; +}; + +&gpu { + mali-supply = <&vdd_gpu>; + status = "okay"; +}; + +&hdmi { + avdd-0v9-supply = <&vdda0v9_image>; + avdd-1v8-supply = <&vcca1v8_image>; + status = "okay"; +}; + +&hdmi_in { + hdmi_in_vp0: endpoint { + remote-endpoint = <&vp0_out_hdmi>; + }; +}; + +&hdmi_out { + hdmi_out_con: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; +}; + +&hdmi_sound { + status = "okay"; +}; + +&i2c0 { + status = "okay"; + + vdd_cpu: regulator@1c { + compatible = "tcs,tcs4525"; + reg = <0x1c>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1150000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc3v3_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + rk809: pmic@20 { + compatible = "rockchip,rk809"; + reg = <0x20>; + interrupt-parent = <&gpio0>; + interrupts = <RK_PA3 IRQ_TYPE_LEVEL_LOW>; + assigned-clocks = <&cru I2S1_MCLKOUT_TX>; + assigned-clock-parents = <&cru CLK_I2S1_8CH_TX>; + #clock-cells = <1>; + clock-names = "mclk"; + clocks = <&cru I2S1_MCLKOUT_TX>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int_l>, <&i2s1m0_mclk>; + rockchip,system-power-controller; + #sound-dai-cells = <0>; + vcc1-supply = <&vcc3v3_sys>; + vcc2-supply = <&vcc3v3_sys>; + vcc3-supply = <&vcc3v3_sys>; + vcc4-supply = <&vcc3v3_sys>; + vcc5-supply = <&vcc3v3_sys>; + vcc6-supply = <&vcc3v3_sys>; + vcc7-supply = <&vcc3v3_sys>; + vcc8-supply = <&vcc3v3_sys>; + vcc9-supply = <&vcc3v3_sys>; + wakeup-source; + + regulators { + vdd_logic: DCDC_REG1 { + regulator-name = "vdd_logic"; + regulator-always-on; + regulator-boot-on; + regulator-init-microvolt = <900000>; + regulator-initial-mode = <0x2>; + regulator-min-microvolt = <500000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_gpu: DCDC_REG2 { + regulator-name = "vdd_gpu"; + regulator-always-on; + regulator-init-microvolt = <900000>; + regulator-initial-mode = <0x2>; + regulator-min-microvolt = <500000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-always-on; + regulator-boot-on; + regulator-initial-mode = <0x2>; + + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vdd_npu: DCDC_REG4 { + regulator-name = "vdd_npu"; + regulator-init-microvolt = <900000>; + regulator-initial-mode = <0x2>; + regulator-min-microvolt = <500000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v8: DCDC_REG5 { + regulator-name = "vcc_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdda0v9_image: LDO_REG1 { + regulator-name = "vdda0v9_image"; + regulator-always-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdda_0v9: LDO_REG2 { + regulator-name = "vdda_0v9"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdda0v9_pmu: LDO_REG3 { + regulator-name = "vdda0v9_pmu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <900000>; + }; + }; + + vccio_acodec: LDO_REG4 { + regulator-name = "vccio_acodec"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vccio_sd: LDO_REG5 { + regulator-name = "vccio_sd"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v3_pmu: LDO_REG6 { + regulator-name = "vcc3v3_pmu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vcca_1v8: LDO_REG7 { + regulator-name = "vcca_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcca1v8_pmu: LDO_REG8 { + regulator-name = "vcca1v8_pmu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcca1v8_image: LDO_REG9 { + regulator-name = "vcca1v8_image"; + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_3v3: SWITCH_REG1 { + regulator-name = "vcc_3v3"; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v3_sd: SWITCH_REG2 { + regulator-name = "vcc3v3_sd"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; + }; +}; + +&i2s0_8ch { + status = "okay"; +}; + +&i2s1_8ch { + rockchip,trcm-sync-tx-only; + status = "okay"; +}; + +&mdio1 { + rgmii_phy1: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0x0>; + }; +}; + +&pcie2x1 { + pinctrl-0 = <&pcie20m2_pins>; + reset-gpios = <&gpio1 RK_PB2 GPIO_ACTIVE_HIGH>; + status = "okay"; + vpcie3v3-supply = <&pcie20_3v3>; +}; + +&pinctrl { + leds { + led_power_pin: led-power-pin { + rockchip,pins = <0 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + led_work_pin: led-work-pin { + rockchip,pins = <0 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + pcie { + vcc3v3_pcie20_en_pin: vcc3v3-pcie20-en-pin { + rockchip,pins = <2 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + pmic { + pmic_int_l: pmic-int-l { + rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + usb { + vcc5v0_usb_host_en_pin: vcc5v0-usb-host-en-pin { + rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + vcc5v0_usb_otg_en_pin: vcc5v0-usb-dr-en-pin { + rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&pmu_io_domains { + pmuio1-supply = <&vcc3v3_pmu>; + pmuio2-supply = <&vcc3v3_pmu>; + vccio1-supply = <&vccio_acodec>; + vccio2-supply = <&vcc_1v8>; + vccio3-supply = <&vccio_sd>; + vccio4-supply = <&vcc_3v3>; + vccio5-supply = <&vcc_3v3>; + vccio6-supply = <&vcc_3v3>; + vccio7-supply = <&vcc_3v3>; + status = "okay"; +}; + +&saradc { + vref-supply = <&vcca_1v8>; + status = "okay"; +}; + +&sdhci { + bus-width = <8>; + max-frequency = <200000000>; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd &emmc_datastrobe &emmc_rstnout>; + vmmc-supply = <&vcc_3v3>; + vqmmc-supply = <&vcc_1v8>; + status = "okay"; +}; + +&sdmmc0 { + bus-width = <4>; + cap-sd-highspeed; + cd-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_LOW>; + disable-wp; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc0_bus4 &sdmmc0_clk &sdmmc0_cmd &sdmmc0_det>; + sd-uhs-sdr50; + vmmc-supply = <&vcc3v3_sd>; + vqmmc-supply = <&vccio_sd>; + status = "okay"; +}; + +&tsadc { + rockchip,hw-tshut-mode = <1>; + rockchip,hw-tshut-polarity = <0>; + status = "okay"; +}; + +&uart2 { + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&usb_host0_xhci { + dr_mode = "otg"; + status = "okay"; +}; + +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +}; + +&usb_host1_xhci { + status = "okay"; +}; + +&usb2phy0 { + status = "okay"; +}; + +&usb2phy0_host { + phy-supply = <&vcc5v0_usb_host>; + status = "okay"; +}; + +&usb2phy0_otg { + phy-supply = <&vcc5v0_usb_otg>; + status = "okay"; +}; + +&usb2phy1 { + status = "okay"; +}; + +&usb2phy1_host { + phy-supply = <&vcc5v0_usb_host>; + status = "okay"; +}; + +&usb2phy1_otg { + phy-supply = <&vcc5v0_usb_host>; + status = "okay"; +}; + +&vop { + assigned-clocks = <&cru DCLK_VOP0>, <&cru DCLK_VOP1>; + assigned-clock-parents = <&pmucru PLL_HPLL>, <&cru PLL_VPLL>; + status = "okay"; +}; + +&vop_mmu { + status = "okay"; +}; + +&vp0 { + vp0_out_hdmi: endpoint@ROCKCHIP_VOP2_EP_HDMI0 { + reg = <ROCKCHIP_VOP2_EP_HDMI0>; + remote-endpoint = <&hdmi_in_vp0>; + }; +}; diff --git a/arch/arm/mach-rockchip/rk3568/Kconfig b/arch/arm/mach-rockchip/rk3568/Kconfig index baa51349f4b..2f03b983ee5 100644 --- a/arch/arm/mach-rockchip/rk3568/Kconfig +++ b/arch/arm/mach-rockchip/rk3568/Kconfig @@ -22,6 +22,11 @@ config TARGET_ODROID_M1_RK3568 help Hardkernel ODROID-M1 single board computer with a RK3568B2 SoC.
+config TARGET_ODROID_M1S_RK3566 + bool "ODROID-M1S" + help + Hardkernel ODROID-M1S single board computer with a RK3566 SoC. + config TARGET_QUARTZ64_RK3566 bool "Pine64 Quartz64" help @@ -44,6 +49,7 @@ config SYS_MALLOC_F_LEN source "board/rockchip/evb_rk3568/Kconfig" source "board/anbernic/rgxx3_rk3566/Kconfig" source "board/hardkernel/odroid_m1/Kconfig" +source "board/hardkernel/odroid_m1s/Kconfig" source "board/pine64/quartz64_rk3566/Kconfig"
endif diff --git a/board/hardkernel/odroid_m1s/Kconfig b/board/hardkernel/odroid_m1s/Kconfig new file mode 100644 index 00000000000..0acea61dac4 --- /dev/null +++ b/board/hardkernel/odroid_m1s/Kconfig @@ -0,0 +1,15 @@ +if TARGET_ODROID_M1S_RK3566 + +config SYS_BOARD + default "odroid_m1s" + +config SYS_VENDOR + default "hardkernel" + +config SYS_CONFIG_NAME + default "odroid_m1s" + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + +endif diff --git a/board/hardkernel/odroid_m1s/MAINTAINERS b/board/hardkernel/odroid_m1s/MAINTAINERS new file mode 100644 index 00000000000..20fc277ccc6 --- /dev/null +++ b/board/hardkernel/odroid_m1s/MAINTAINERS @@ -0,0 +1,9 @@ +ODROID-M1S +M: Dongjin Kim tobetter@gmail.com +S: Maintained +F: arch/arm/dts/rk3566-odroid-m1s-u-boot.dtsi +F: arch/arm/dts/rk3566-odroid-m1s.dts +F: board/hardkernel/odroid_m1s/ +F: board/hardkernel/odroid_m1s/board.c +F: configs/odroid-m1s-rk3566_defconfig +F: include/configs/odroid_m1s.h diff --git a/board/hardkernel/odroid_m1s/Makefile b/board/hardkernel/odroid_m1s/Makefile new file mode 100644 index 00000000000..6ca49c49b71 --- /dev/null +++ b/board/hardkernel/odroid_m1s/Makefile @@ -0,0 +1,7 @@ +# +# Copyright (c) 2024 Hardkernel Co,. Ltd +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += board.o diff --git a/board/hardkernel/odroid_m1s/board.c b/board/hardkernel/odroid_m1s/board.c new file mode 100644 index 00000000000..de7b160a51a --- /dev/null +++ b/board/hardkernel/odroid_m1s/board.c @@ -0,0 +1,80 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2024 Hardkernel Co., Ltd + */ + +#include <asm/unaligned.h> +#include <mmc.h> +#include <net.h> +#include <asm/arch-rockchip/misc.h> + +#ifdef CONFIG_MISC_INIT_R + +/* Read first block 512 bytes from the first BOOT partition of eMMC + * that stores device identifcation sting in UUID type 1, this string + * is written in factory to give device seranl number and MAC address. + */ +static int odroid_setup_macaddr(void) +{ + struct mmc *mmc; + struct blk_desc *desc; + unsigned long mac_addr; + unsigned long count; + int ret; + u8 buf[512]; + + mmc = find_mmc_device(0); + if (!mmc) + return -ENODEV; + + desc = mmc_get_blk_desc(mmc); + + // Switch to the first BOOT partition + ret = blk_select_hwpart_devnum(UCLASS_MMC, 0, 1); + if (ret) + return -EIO; + + count = blk_dread(desc, 0, 1, (void *)buf); + + // Switch back to USER partition + ret = blk_dselect_hwpart(desc, 0); + if (ret || count != 1) + return -EIO; + + *(char *)(buf + 36) = 0; + + // Serial number + env_set("serial#", (char *)buf); + + // MAC address + mac_addr = cpu_to_be64(simple_strtoul((char *)buf + 24, NULL, 16)) >> 16; + + eth_env_set_enetaddr("ethaddr", (unsigned char *)&mac_addr); + eth_env_set_enetaddr("eth1addr", (unsigned char *)&mac_addr); + + return 0; +} + +int misc_init_r(void) +{ + const u32 cpuid_offset = CFG_CPUID_OFFSET; + const u32 cpuid_length = 0x10; + u8 cpuid[cpuid_length]; + int ret; + + ret = odroid_setup_macaddr(); + if (ret) { + ret = rockchip_setup_macaddr(); + if (ret) + return ret; + } + + ret = rockchip_cpuid_from_efuse(cpuid_offset, cpuid_length, cpuid); + if (ret) + return ret; + + ret = rockchip_cpuid_set(cpuid, cpuid_length); + + return ret; +} +#endif diff --git a/configs/odroid-m1s-rk3566_defconfig b/configs/odroid-m1s-rk3566_defconfig new file mode 100644 index 00000000000..d70a10dc080 --- /dev/null +++ b/configs/odroid-m1s-rk3566_defconfig @@ -0,0 +1,109 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_TEXT_BASE=0x00a00000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc00000 +CONFIG_SF_DEFAULT_SPEED=24000000 +CONFIG_SF_DEFAULT_MODE=0x1000 +CONFIG_DEFAULT_DEVICE_TREE="rk3566-odroid-m1s" +CONFIG_ROCKCHIP_RK3568=y +CONFIG_SPL_ROCKCHIP_COMMON_BOARD=y +CONFIG_ROCKCHIP_SPI_IMAGE=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_STACK_R_ADDR=0x600000 +CONFIG_TARGET_ODROID_M1S_RK3566=y +CONFIG_SPL_STACK=0x400000 +CONFIG_DEBUG_UART_BASE=0xFE660000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI=y +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_PCI=y +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3566-odroid-m1s.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x4000000 +CONFIG_SPL_BSS_MAX_SIZE=0x4000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x100000 +CONFIG_SPL_ATF=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_INI=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_CRAMFS=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_AHCI_PCI=y +CONFIG_DWC_AHCI=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_SF_DEFAULT_BUS=4 +CONFIG_PHY_REALTEK=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y +CONFIG_NVME_PCI=y +CONFIG_PCIE_DW_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y +CONFIG_PHY_ROCKCHIP_PCIE=y +CONFIG_SPL_PINCTRL=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_SPL_RAM=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_FS_CRAMFS=y +CONFIG_ERRNO_STR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x0800 diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index 18d0b6f0891..3ce9966fc13 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -93,6 +93,7 @@ List of mainline supported Rockchip boards:
* rk3566 - Anbernic RGxx3 (anbernic-rgxx3-rk3566) + - Hardkernel ODROID-M1S (odroid-m1s-rk3566) - Pine64 Quartz64-A Board (quartz64-a-rk3566) - Pine64 Quartz64-B Board (quartz64-b-rk3566) - Pine64 SOQuartz on Blade (soquartz-blade-rk3566) diff --git a/include/configs/odroid_m1s.h b/include/configs/odroid_m1s.h new file mode 100644 index 00000000000..b2718613886 --- /dev/null +++ b/include/configs/odroid_m1s.h @@ -0,0 +1,12 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ + +#ifndef __ODROID_M1S_H +#define __ODROID_M1S_H + +#include <configs/rk3568_common.h> + +#define ROCKCHIP_DEVICE_SETTINGS \ + "stdout=serial\0" \ + "stderr=serial\0" + +#endif
Hi Dongjin,
This board does not yet have a device tree in the linux maintainer tree. Please first submit the device tree to linux before adding the board to U-Boot.
The generic-rk3568_defconfig can be used to boot this board from SD-card and eMMC until a fully reviewed device tree can be picked from linux.
These includes is not in use in this file, please remove.
- chosen {
Is there a reason why this differ from other rk356x boards and the default from rk356x-u-boot.dtsi cannot be used?
+&sdhci {
- cap-mmc-highspeed;
- mmc-ddr-1_8v;
This mode cause eMMC write issues, please drop it, I have an incoming series that drop this prop for supported rk35xx boards.
- mmc-hs200-1_8v;
- mmc-hs400-1_8v;
- mmc-hs400-enhanced-strobe;
Based on my testing HS400 modes is only supported by RK3568 not the RK3566 variant.
- pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd &emmc_datastrobe>;
Because this device tree is not yet in linux, hopefully correct props can be applied to device tree and u-boot do not need any overrides.
+&uart2 {
- bootph-all;
- clock-frequency = <24000000>;
- status = "okay";
[snip]
- bool "ODROID-M1S"
- help
+config SYS_BOARD
- default "odroid_m1s"
+config SYS_VENDOR
- default "hardkernel"
- def_bool y
I have this board so feel free to add me as a reviewer :-)
R: Jonas Karlman jonas@kwiboo.se
- (C) Copyright 2024 Hardkernel Co., Ltd
- that stores device identifcation sting in UUID type 1, this string
- is written in factory to give device seranl number and MAC address.
- struct mmc *mmc;
- struct blk_desc *desc;
- unsigned long mac_addr;
- unsigned long count;
- int ret;
- u8 buf[512];
- mmc = find_mmc_device(0);
- if (!mmc)
return -ENODEV;
- desc = mmc_get_blk_desc(mmc);
- // Switch to the first BOOT partition
- ret = blk_select_hwpart_devnum(UCLASS_MMC, 0, 1);
- if (ret)
return -EIO;
- count = blk_dread(desc, 0, 1, (void *)buf);
- // Switch back to USER partition
- ret = blk_dselect_hwpart(desc, 0);
- if (ret || count != 1)
return -EIO;
- *(char *)(buf + 36) = 0;
- // Serial number
- env_set("serial#", (char *)buf);
- // MAC address
- mac_addr = cpu_to_be64(simple_strtoul((char *)buf + 24, NULL, 16)) >> 16;
- eth_env_set_enetaddr("ethaddr", (unsigned char *)&mac_addr);
- eth_env_set_enetaddr("eth1addr", (unsigned char *)&mac_addr);
- const u32 cpuid_offset = CFG_CPUID_OFFSET;
- const u32 cpuid_length = 0x10;
- u8 cpuid[cpuid_length];
- int ret;
- ret = odroid_setup_macaddr();
- if (ret) {
if (ret)
return ret;
- ret = rockchip_cpuid_from_efuse(cpuid_offset, cpuid_length, cpuid);
- if (ret)
return ret;
- ret = rockchip_cpuid_set(cpuid, cpuid_length);
- return ret;
+} +#endif
I get build errors without "#include <common.h>":
In file included from include/linux/byteorder/little_endian.h:14, from ./arch/arm/include/asm/byteorder.h:29, from include/asm-generic/unaligned.h:5, from ./arch/arm/include/asm/unaligned.h:2, from board/hardkernel/odroid_m1s/board.c:6: board/hardkernel/odroid_m1s/board.c: In function ‘odroid_setup_macaddr’: CC drivers/adc/adc-uclass.o board/hardkernel/odroid_m1s/board.c:50:32: warning: implicit declaration of function ‘simple_strtoul’ [-Wimplicit-function-declaration] 50 | mac_addr = cpu_to_be64(simple_strtoul((char *)buf + 24, NULL, 16)) >> 16; | ^~~~~~~~~~~~~~ include/linux/byteorder/swab.h:93:31: note: in definition of macro ‘__swab64’ 93 | (__builtin_constant_p((__u64)(x)) ? \ | ^ include/linux/byteorder/generic.h:92:21: note: in expansion of macro ‘__cpu_to_be64’ 92 | #define cpu_to_be64 __cpu_to_be64 | ^~~~~~~~~~~~~ board/hardkernel/odroid_m1s/board.c:50:20: note: in expansion of macro ‘cpu_to_be64’ 50 | mac_addr = cpu_to_be64(simple_strtoul((char *)buf + 24, NULL, 16)) >> 16; | ^~~~~~~~~~~ board/hardkernel/odroid_m1s/board.c: In function ‘misc_init_r’: board/hardkernel/odroid_m1s/board.c:60:34: error: ‘CFG_CPUID_OFFSET’ undeclared (first use in this function) 60 | const u32 cpuid_offset = CFG_CPUID_OFFSET; | ^~~~~~~~~~~~~~~~ board/hardkernel/odroid_m1s/board.c:60:34: note: each undeclared identifier is reported only once for each function it appears in make[2]: *** [scripts/Makefile.build:257: board/hardkernel/odroid_m1s/board.o] Error 1 make[1]: *** [Makefile:1859: board/hardkernel/odroid_m1s] Error 2
DM_SCSI have been migrated to SCSI and can be dropped.
This does not correspont to SPL_PAD_TO, so the generated u-boot-rockchip.bin have FIT at wrong offset and I get the following error on my board:
U-Boot SPL 2024.01 (Jan 25 2024 - 11:43:22 +0000) Trying to boot from MMC2 mmc_load_image_raw_sector: mmc block read error Trying to boot from MMC1 mmc_load_image_raw_sector: mmc block read error SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ###
Please drop this and accept the default 0x4000 value.
Regards, Jonas
- rk3566
"stdout=serial\0" \
"stderr=serial\0"
Hello Jans,
Thank you for reviewing.
On Thu, Jan 25, 2024 at 8:51 PM Jonas Karlman jonas@kwiboo.se wrote:
Hi Dongjin,
I realized that the linux kernel patch for ODROID-M1S was already submitted by someone else. https://patchwork.kernel.org/project/linux-rockchip/patch/20240112135004.289...
It's a slightly different version, so the next patch should be with the device tree when it's merged.
Ok.
chosen {
It is to give higher priority to SD cards that have vendor firmware for maintenance or another OS. In the worst case if U-Boot eMMC is corrupted for some reason and it is not able to boot any other OS, SD card is the most convenient method to recover.
+&sdhci {
cap-mmc-highspeed;
mmc-ddr-1_8v;
Ok.
mmc-hs200-1_8v;
mmc-hs400-1_8v;
Ok.
Understand.
+&uart2 {
bootph-all;
status = "okay";
[snip]
bool "ODROID-M1S"
help
+config SYS_BOARD
+config SYS_VENDOR
def_bool y
Thank you. :)
struct mmc *mmc;
int ret;
u8 buf[512];
if (!mmc)
return -ENODEV;
if (ret)
return -EIO;
return -EIO;
// Serial number
// MAC address
int ret;
if (ret) {
if (ret)
return ret;
if (ret)
return ret;
return ret;
+} +#endif
True. "#include <common.h>" is removed since "scripts/checkpatch.pl" asked me not to add it. So, I have to add "#include <vsprintf.h>" instead. :)
Ok.
0x0800 is from the partition layout for Hardkernel's OS image, but sure... 0x4000 can be acceptable for future.
Regards, Jonas
- rk3566
"stdout=serial\0" \
"stderr=serial\0"
Thank you, Dongjin Kim.
I suppose this pinctrl override was copied from Odroid-M1 where the emmc_rst pin is shared with SPI flash. That is not the case on Odroid-M1S which doesnt have SPI flash. So should be ok to drop this override.
Regards Tim
Dongjin Kim
Jonas Karlman
Tim Lunn
