[U-Boot] [PATCH] hwconfig: Fix dummy initialization of {board, cpu}_hwconfig
Since board_hwconfig & cpu_hwconfig are defined as weak and dont have a default value they will get put into the BSS if they aren't defined elsewhere. This is problematic as we try to utilize hwconfig before we've relocated and thus BSS isn't setup.
Instead of giving dummy values in the board files that utilize this feature, we can just initialize the variables to an empty string and thus move them out of the BSS if they aren't defined elsewhere.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/freescale/mpc8641hpcn/mpc8641hpcn.c | 3 --- board/freescale/p2020ds/p2020ds.c | 3 --- common/hwconfig.c | 4 ++-- 3 files changed, 2 insertions(+), 8 deletions(-)
diff --git a/board/freescale/mpc8641hpcn/mpc8641hpcn.c b/board/freescale/mpc8641hpcn/mpc8641hpcn.c index 812111d..882ff0b 100644 --- a/board/freescale/mpc8641hpcn/mpc8641hpcn.c +++ b/board/freescale/mpc8641hpcn/mpc8641hpcn.c @@ -60,9 +60,6 @@ int checkboard(void) return 0; }
-const char *board_hwconfig = "foo:bar=baz"; -const char *cpu_hwconfig = "foo:bar=baz"; - phys_size_t initdram(int board_type) { diff --git a/board/freescale/p2020ds/p2020ds.c b/board/freescale/p2020ds/p2020ds.c index b507677..b05ef98 100644 --- a/board/freescale/p2020ds/p2020ds.c +++ b/board/freescale/p2020ds/p2020ds.c @@ -69,9 +69,6 @@ int checkboard(void) return 0; }
-const char *board_hwconfig = "foo:bar=baz"; -const char *cpu_hwconfig = "foo:bar=baz"; - phys_size_t initdram(int board_type) { phys_size_t dram_size = 0; diff --git a/common/hwconfig.c b/common/hwconfig.c index 3c9759f..1127239 100644 --- a/common/hwconfig.c +++ b/common/hwconfig.c @@ -68,8 +68,8 @@ next: return NULL; }
-const char *cpu_hwconfig __attribute__((weak)); -const char *board_hwconfig __attribute__((weak)); +const char *cpu_hwconfig __attribute__((weak)) = ""; +const char *board_hwconfig __attribute__((weak)) = "";
#define HWCONFIG_PRE_RELOC_BUF_SIZE 128
Kumar Gala
