[PATCH] socfpga: enable EFI partition support for de0-nano-soc
This fixes boot problems with distributions that use EFI boot like opensuse.
Signed-off-by: Frank Kunz mailinglists@kunz-im-inter.net --- configs/socfpga_de0_nano_soc_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/socfpga_de0_nano_soc_defconfig b/configs/socfpga_de0_nano_soc_defconfig index 17c160dd2a..3068f5615a 100644 --- a/configs/socfpga_de0_nano_soc_defconfig +++ b/configs/socfpga_de0_nano_soc_defconfig @@ -35,7 +35,7 @@ CONFIG_MTDIDS_DEFAULT="nor0=ff705000.spi.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=ff705000.spi.0:1m(u-boot),256k(env1),256k(env2),14848k(boot),16m(rootfs),-@1536k(UBI)" CONFIG_CMD_UBI=y # CONFIG_ISO_PARTITION is not set -# CONFIG_EFI_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_VERSION_VARIABLE=y
Reviewed-by: Matthias Brugger mbrugger@suse.com
Hi Simon,
I can see that this patched got delegated to you in patchwork. Is there anything blocking it from being accepted?
Regards, Matthias
From Received: from DB8PR04MB7148.eurprd04.prod.outlook.com (2603:10a6:10:12d::17) by AM6PR04MB5366.eurprd04.prod.outlook.com with HTTPS; Fri, 22 Oct 2021 17:59:43 +0000 Received: from AM6PR0502CA0064.eurprd05.prod.outloo
Frank Kunz
Matthias Brugger
