Re: [U-Boot-Users] the ppc405ep u-boot (with jffs2 configure) failed
In message 20040928171537.6055.qmail@web53410.mail.yahoo.com you wrote:
How big is your U-Boot image?
no jffs2 with jffs2
u-boot.bin = 131071 131071
so sorry , 131072 131072
Arghh... <It's really difficult to help when you come up with random numbers.
U-boot will not fit in this image). Check your u-boot.map file and/or the output of objdump -h to make sure you don;t have any overlapping sections defined in your linker script.
with jffs2 u-boot.map info: ............ .bss.NetArpWaitPacketBuf 0xfffffb5c 0x620 net/libnet.a(net.o) 0xfffffb5c NetArpWaitPacketBuf
.sbss.NetArpWaitTimerStart 0x0000017c 0x4 .sbss.NetArpWaitTimerStart 0x0000017c 0x4
Gotcha!!!
it seems jffs2 u-boot go out of size.
Indeed. As I mentioned before: 128 kB seems too small to me.
I need redefine the size of u-boot.bin and the env-offset, env-addr in configure file /include/configs/PPC405EPVV.h, could you give me some info to do this correct?
Reduce TEXT_BASE in your config.mk file.
And please keep the list Cc:ed.
sorry, Cc:ed ?
Add a "Cc: U-Boot-Users@lists.sourceforge.net" header line, probably by using "reply to all" or whatever your MUA names this function.
thanks!!! thanks!!!
as your said,
After add 128k to size of u-boot.bin, the u-boot with JFFS2 configure comes up serial port. I could run setenv and saveenv command.
in ../board/ppc405epvv/config.mk, changed from TEXT_BASE = 0xFFFE0000 to 0xFFFC0000 add 128k.
also: in ../include/configs/PPC405EPVV.h changed from: #define CFG_MONITOR_BASE 0xFFFE0000 /* last 128 kB */ to 0xFFFC0000, /*last 256K */.
changed from #define CFG_MONITOR_LEN (128 * 1024) to 256*1024
Tyler Jia
no jffs2 with jffs2
have
Gotcha!!!
sorry, Cc:ed ?
-- Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-4596-87 Fax: (+49)-8142-4596-88 Email: wd@denx.de The price of curiosity is a terminal experience. - Terry Pratchett, _The Dark Side of the Sun_
_______________________________ Do you Yahoo!? Declare Yourself - Register online to vote today! http://vote.yahoo.com
Tyler Jia
