[U-Boot] [PATCH] arm: zynq: Enable SPL_CLK only if SPL is enabled
Setup proper dependency in Kconfig for SPL_CLK. If SPL is not enabled, SPL_CLK shouldn't be selected.
Cc: Michal Simek michal.simek@xilinx.com Signed-off-by: Ezequiel Garcia ezequiel@vanguardiasur.com.ar --- arch/arm/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index de323bf4b96e..4ff369c32524 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -760,7 +760,7 @@ config ARCH_ZYNQ select DM_USB if USB select BLK select CLK - select SPL_CLK + select SPL_CLK if SPL select CLK_ZYNQ imply CMD_CLK imply FAT_WRITE
- select SPL_CLK
- select SPL_CLK if SPL select CLK_ZYNQ imply CMD_CLK imply FAT_WRITE
Make sense. Applied.
Thanks, Michal
Ezequiel Garcia
Michal Simek
