[U-Boot] [PATCH 00/30] dm: sound: Convert to driver model
The sound subsystem has never been converted to driver model. It is not widely used and is a little bit complicating since it needs an audio codec, an i2s device and a sound device to bring them together.
Sound is the main subsystem holding back removal of CONFIG_DM_I2C_COMPAT.
This series takes a stab at doing the conversion. So far this is only tested on snow. I intend to test also on spring and pit/pi when I can. I do not have smdk5250/5420 or arndale to test with.
Simon Glass (30): sandbox: Increase the pre-relocation memory snow: Expand U-Boot size dm: sound: samsung: Make local function static dm: sound: Rename en_sound_codec to sound_codec dm: sound: Drop unused pre-device-tree code dm: sound: samsung: Rename i2stx_info to samsung_i2s_priv dm: sound: Drop codec_type dm: sound: wm8994: Pass private data to internal functions dm: sound: max98095: Pass private data to internal functions dm: sound: wm8994: Create a new common init function dm: sound: wm899c: Split out interface setup code dm: sound: max98095: Split out interface setup code dm: sound: wm8994: Drop global i2c-address variable dm: sound: max98095: Drop global i2c-address variable dm: sound: wm8994: Drop g_codec_info and g_wm8994_info dm: sound: max98095: Drop g_codec_info and g_max98095_info dm: sound: wm8994: Drop wm8994_i2c_init() dm: sound: Fix up header ordering dm: sound: exynos: Correct codec bus address dm: sound: Create an option to use driver model for sound dm: sound: Rename samsung_i2s_priv to i2s_uc_priv dm: sound: Create a uclass for audio codecs dm: sound: Create a uclass for i2s dm: sound: Create a uclass for sound dm: core: Add a function to read into a unsigned int dm: sound: Start i2c IDs from 0 dm: sound: Add conversion to driver model dm: exynos: sound: Convert to use driver model dm: exynos: Drop CONFIG_DM_I2C_COMPAT dm: sound: Complete migration to driver model
Kconfig | 2 + arch/arm/dts/exynos5250-smdk5250.dts | 21 +- arch/arm/dts/exynos5250-snow.dts | 25 +- arch/arm/dts/exynos5250-spring.dts | 24 +- arch/arm/dts/exynos5250.dtsi | 15 +- arch/arm/dts/exynos5420-peach-pit.dts | 24 +- arch/arm/dts/exynos5420-smdk5420.dts | 21 +- arch/arm/dts/exynos54xx.dtsi | 7 + arch/sandbox/dts/test.dts | 23 ++ arch/sandbox/include/asm/test.h | 40 +++ cmd/sound.c | 13 +- configs/arndale_defconfig | 1 + configs/peach-pi_defconfig | 2 +- configs/peach-pit_defconfig | 2 +- configs/sandbox64_defconfig | 1 - configs/sandbox_defconfig | 2 +- configs/sandbox_flattree_defconfig | 1 - configs/sandbox_noblk_defconfig | 1 - configs/sandbox_spl_defconfig | 1 - configs/smdk5250_defconfig | 2 +- configs/smdk5420_defconfig | 1 - configs/snow_defconfig | 2 +- configs/spring_defconfig | 2 +- drivers/core/read.c | 23 ++ drivers/sound/Makefile | 5 +- drivers/sound/codec-uclass.c | 26 ++ drivers/sound/i2s-uclass.c | 25 ++ drivers/sound/max98095.c | 316 ++++++++--------- drivers/sound/max98095.h | 2 +- drivers/sound/samsung-i2s.c | 139 ++++++-- drivers/sound/samsung_sound.c | 104 ++++++ drivers/sound/sandbox.c | 177 +++++++++- drivers/sound/sound-i2s.c | 208 ----------- drivers/sound/sound-uclass.c | 129 +++++++ drivers/sound/wm8994.c | 475 ++++++++++++-------------- drivers/sound/wm8994.h | 2 +- include/audio_codec.h | 48 +++ include/dm/read.h | 58 ++++ include/dm/uclass-id.h | 3 + include/i2s.h | 33 +- include/sound.h | 72 +++- test/dm/Makefile | 3 + test/dm/audio.c | 34 ++ test/dm/i2s.c | 32 ++ test/dm/sound.c | 34 ++ test/dm/test-fdt.c | 35 ++ 46 files changed, 1483 insertions(+), 733 deletions(-) create mode 100644 drivers/sound/codec-uclass.c create mode 100644 drivers/sound/i2s-uclass.c create mode 100644 drivers/sound/samsung_sound.c delete mode 100644 drivers/sound/sound-i2s.c create mode 100644 drivers/sound/sound-uclass.c create mode 100644 include/audio_codec.h create mode 100644 test/dm/audio.c create mode 100644 test/dm/i2s.c create mode 100644 test/dm/sound.c
This is close to full now, so increase it to avoid problems with adding more devices.
Kconfig | 2 ++ configs/sandbox64_defconfig | 1 - configs/sandbox_defconfig | 1 - configs/sandbox_flattree_defconfig | 1 - configs/sandbox_noblk_defconfig | 1 - configs/sandbox_spl_defconfig | 1 - 6 files changed, 2 insertions(+), 5 deletions(-)
diff --git a/Kconfig b/Kconfig index dca9bb4e432..477a3c4ae03 100644 --- a/Kconfig +++ b/Kconfig @@ -125,6 +125,7 @@ config SYS_BOOT_GET_KBD config SYS_MALLOC_F bool "Enable malloc() pool before relocation" default y if DM + help Before relocation, memory is very limited on many platforms. Still, we can provide a small malloc() pool if needed. Driver model in @@ -135,6 +136,7 @@ config SYS_MALLOC_F_LEN hex "Size of malloc() pool before relocation" depends on SYS_MALLOC_F default 0x1000 if AM33XX + default 0x2800 if SANDBOX default 0x400 help Before relocation, memory is very limited on many platforms. Still, diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index e6680d9a594..aede14569df 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -1,5 +1,4 @@ CONFIG_SYS_TEXT_BASE=0 -CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_SANDBOX64=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 5a744f47917..4d65a01dc5b 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -1,5 +1,4 @@ CONFIG_SYS_TEXT_BASE=0 -CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_DEBUG_UART=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=1 diff --git a/configs/sandbox_flattree_defconfig b/configs/sandbox_flattree_defconfig index 756b839b081..4f3757c8bc5 100644 --- a/configs/sandbox_flattree_defconfig +++ b/configs/sandbox_flattree_defconfig @@ -1,5 +1,4 @@ CONFIG_SYS_TEXT_BASE=0 -CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y diff --git a/configs/sandbox_noblk_defconfig b/configs/sandbox_noblk_defconfig index e71e2d3860c..6c7d08e42e1 100644 --- a/configs/sandbox_noblk_defconfig +++ b/configs/sandbox_noblk_defconfig @@ -1,5 +1,4 @@ CONFIG_SYS_TEXT_BASE=0 -CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index 452a2ef4a50..2f838125289 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -1,7 +1,6 @@ CONFIG_SYS_TEXT_BASE=0 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y
Applied to u-boot-dm/master
Now that we have EFI, etc. enabled, U-Boot is larger than it was. Expand the region allocated for it.
arch/arm/dts/exynos5250-snow.dts | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/exynos5250-snow.dts b/arch/arm/dts/exynos5250-snow.dts index 29c13c1257e..e99f6e72bf6 100644 --- a/arch/arm/dts/exynos5250-snow.dts +++ b/arch/arm/dts/exynos5250-snow.dts @@ -88,7 +88,7 @@
ro-boot { label = "u-boot"; - reg = <0x6000 0x9a000>; + reg = <0x6000 0xb0000>; read-only; type = "blob boot,dtb"; required;
Several functions are not exported from this file. Make them static so this is clear.
drivers/sound/samsung-i2s.c | 8 ++++---- drivers/sound/wm8994.c | 2 +- 2 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/sound/samsung-i2s.c b/drivers/sound/samsung-i2s.c index f39abf5e2a9..8f5cd191a2b 100644 --- a/drivers/sound/samsung-i2s.c +++ b/drivers/sound/samsung-i2s.c @@ -111,7 +111,7 @@ static void i2s_set_bitclk_framesize(struct i2s_reg *i2s_reg, unsigned bfs) * @param flush Tx fifo flush command (0x00 - do not flush * 0x80 - flush tx fifo) */ -void i2s_fifo(struct i2s_reg *i2s_reg, unsigned int flush) +static void i2s_fifo(struct i2s_reg *i2s_reg, unsigned int flush) { /* Flush the FIFO */ setbits_le32(&i2s_reg->fic, flush); @@ -126,7 +126,7 @@ void i2s_fifo(struct i2s_reg *i2s_reg, unsigned int flush) * * @return int value 0 for success, -1 in case of error */ -int i2s_set_sysclk_dir(struct i2s_reg *i2s_reg, int dir) +static int i2s_set_sysclk_dir(struct i2s_reg *i2s_reg, int dir) { unsigned int mod = readl(&i2s_reg->mod);
@@ -148,7 +148,7 @@ int i2s_set_sysclk_dir(struct i2s_reg *i2s_reg, int dir) * * @return int value 0 for success, -1 in case of error */ -int i2s_set_fmt(struct i2s_reg *i2s_reg, unsigned int fmt) +static int i2s_set_fmt(struct i2s_reg *i2s_reg, unsigned int fmt) { unsigned int mod = readl(&i2s_reg->mod); unsigned int tmp = 0; @@ -225,7 +225,7 @@ int i2s_set_fmt(struct i2s_reg *i2s_reg, unsigned int fmt) * * @return int value 0 for success, -1 in case of error */ -int i2s_set_samplesize(struct i2s_reg *i2s_reg, unsigned int blc) +static int i2s_set_samplesize(struct i2s_reg *i2s_reg, unsigned int blc) { unsigned int mod = readl(&i2s_reg->mod);
diff --git a/drivers/sound/wm8994.c b/drivers/sound/wm8994.c index aaaa3241aa1..e671f6b85ec 100644 --- a/drivers/sound/wm8994.c +++ b/drivers/sound/wm8994.c @@ -156,7 +156,7 @@ static int wm8994_update_bits(unsigned int reg, unsigned short mask, * * @return -1 for error and 0 Success. */ -int wm8994_set_fmt(int aif_id, unsigned int fmt) +static int wm8994_set_fmt(int aif_id, unsigned int fmt) { int ms_reg; int aif_reg;
The en_ prefix is confusing and not needed. Drop it.
include/sound.h | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/sound.h b/include/sound.h index 77bfe6a93b2..149e12dbc60 100644 --- a/include/sound.h +++ b/include/sound.h @@ -8,7 +8,7 @@ #define __SOUND_H__
/* sound codec enum */ -enum en_sound_codec { +enum sound_codec { CODEC_WM_8994, CODEC_WM_8995, CODEC_MAX_98095, @@ -25,7 +25,7 @@ enum sound_compat { struct sound_codec_info { int i2c_bus; int i2c_dev_addr; - enum en_sound_codec codec_type; + enum sound_codec codec_type; };
CONFIG_OF_CONTROL is enabled for all boards that use sound, so remove the dead code.
drivers/sound/max98095.c | 6 ------ drivers/sound/wm8994.c | 6 ------ 2 files changed, 12 deletions(-)
diff --git a/drivers/sound/max98095.c b/drivers/sound/max98095.c index 7c37bd07015..d05c261a399 100644 --- a/drivers/sound/max98095.c +++ b/drivers/sound/max98095.c @@ -522,7 +522,6 @@ static int get_max98095_codec_values(struct sound_codec_info *pcodec_info, const void *blob) { int error = 0; -#if CONFIG_IS_ENABLED(OF_CONTROL) enum fdt_compat_id compat; int node; int parent; @@ -556,11 +555,6 @@ static int get_max98095_codec_values(struct sound_codec_info *pcodec_info, debug("%s: Unknown compat id %d\n", __func__, compat); return -1; } -#else - pcodec_info->i2c_bus = AUDIO_I2C_BUS; - pcodec_info->i2c_dev_addr = AUDIO_I2C_REG; - debug("i2c dev addr = %d\n", pcodec_info->i2c_dev_addr); -#endif pcodec_info->codec_type = CODEC_MAX_98095; if (error == -1) { debug("fail to get max98095 codec node properties\n"); diff --git a/drivers/sound/wm8994.c b/drivers/sound/wm8994.c index e671f6b85ec..34bc4eb516f 100644 --- a/drivers/sound/wm8994.c +++ b/drivers/sound/wm8994.c @@ -813,7 +813,6 @@ static int get_codec_values(struct sound_codec_info *pcodec_info, const void *blob) { int error = 0; -#if CONFIG_IS_ENABLED(OF_CONTROL) enum fdt_compat_id compat; int node; int parent; @@ -847,11 +846,6 @@ static int get_codec_values(struct sound_codec_info *pcodec_info, debug("%s: Unknown compat id %d\n", __func__, compat); return -1; } -#else - pcodec_info->i2c_bus = AUDIO_I2C_BUS; - pcodec_info->i2c_dev_addr = AUDIO_I2C_REG; - debug("i2c dev addr = %d\n", pcodec_info->i2c_dev_addr); -#endif
pcodec_info->codec_type = CODEC_WM_8994;
This struct is only used by the Samsung I2C driver and should move into that driver. For now, rename it so it is clear that is driver-private info.
drivers/sound/samsung-i2s.c | 6 +++--- drivers/sound/sound-i2s.c | 10 +++++----- include/i2s.h | 8 ++++---- 3 files changed, 12 insertions(+), 12 deletions(-)
diff --git a/drivers/sound/samsung-i2s.c b/drivers/sound/samsung-i2s.c index 8f5cd191a2b..7f4388137a5 100644 --- a/drivers/sound/samsung-i2s.c +++ b/drivers/sound/samsung-i2s.c @@ -255,8 +255,8 @@ static int i2s_set_samplesize(struct i2s_reg *i2s_reg, unsigned int blc) return 0; }
-int i2s_transfer_tx_data(struct i2stx_info *pi2s_tx, unsigned int *data, - unsigned long data_size) +int i2s_transfer_tx_data(struct samsung_i2s_priv *pi2s_tx, unsigned int *data, + unsigned long data_size) { int i; int start; @@ -293,7 +293,7 @@ int i2s_transfer_tx_data(struct i2stx_info *pi2s_tx, unsigned int *data, return 0; }
-int i2s_tx_init(struct i2stx_info *pi2s_tx) +int i2s_tx_init(struct samsung_i2s_priv *pi2s_tx) { int ret; struct i2s_reg *i2s_reg = diff --git a/drivers/sound/sound-i2s.c b/drivers/sound/sound-i2s.c index f0f0b79bc52..106842a23db 100644 --- a/drivers/sound/sound-i2s.c +++ b/drivers/sound/sound-i2s.c @@ -20,15 +20,15 @@ #define SOUND_400_HZ 400 #define SOUND_BITS_IN_BYTE 8
-static struct i2stx_info g_i2stx_pri; +static struct samsung_i2s_priv g_i2stx_pri;
/* * get_sound_i2s_values gets values for i2s parameters * - * @param i2stx_info i2s transmitter transfer param structure + * @param samsung_i2s_priv i2s transmitter transfer param structure * @param blob FDT blob if enabled else NULL */ -static int get_sound_i2s_values(struct i2stx_info *i2s, const void *blob) +static int get_sound_i2s_values(struct samsung_i2s_priv *i2s, const void *blob) { int node; int error = 0; @@ -97,7 +97,7 @@ static int get_sound_i2s_values(struct i2stx_info *i2s, const void *blob) * @param pi2s_tx i2s parameters required by codec * @return int value, 0 for success */ -static int codec_init(const void *blob, struct i2stx_info *pi2s_tx) +static int codec_init(const void *blob, struct samsung_i2s_priv *pi2s_tx) { int ret; const char *codectype; @@ -145,7 +145,7 @@ static int codec_init(const void *blob, struct i2stx_info *pi2s_tx) int sound_init(const void *blob) { int ret; - struct i2stx_info *pi2s_tx = &g_i2stx_pri; + struct samsung_i2s_priv *pi2s_tx = &g_i2stx_pri;
/* Get the I2S Values */ if (get_sound_i2s_values(pi2s_tx, blob) < 0) { diff --git a/include/i2s.h b/include/i2s.h index e6d45ec26d7..800473abd9c 100644 --- a/include/i2s.h +++ b/include/i2s.h @@ -76,7 +76,7 @@ struct i2s_reg { };
/* This structure stores the i2s related information */ -struct i2stx_info { +struct samsung_i2s_priv { unsigned int rfs; /* LR clock frame size */ unsigned int bfs; /* Bit slock frame size */ unsigned int audio_pll_clk; /* Audio pll frequency in Hz */ @@ -96,8 +96,8 @@ struct i2stx_info { * * @return int value 0 for success, -1 in case of error */ -int i2s_transfer_tx_data(struct i2stx_info *pi2s_tx, unsigned *data, - unsigned long data_size); +int i2s_transfer_tx_data(struct samsung_i2s_priv *pi2s_tx, uint *data, + unsigned long data_size);
/* * Initialise i2s transmiter @@ -106,6 +106,6 @@ int i2s_transfer_tx_data(struct i2stx_info *pi2s_tx, unsigned *data, * * @return int value 0 for success, -1 in case of error */ -int i2s_tx_init(struct i2stx_info *pi2s_tx); +int i2s_tx_init(struct samsung_i2s_priv *pi2s_tx);
#endif /* __I2S_H__ */
This field is not really used. It is always set to a known value. Drop it to simplify the code.
drivers/sound/max98095.c | 14 -------------- drivers/sound/wm8994.c | 10 ---------- include/sound.h | 9 --------- 3 files changed, 33 deletions(-)
diff --git a/drivers/sound/max98095.c b/drivers/sound/max98095.c index d05c261a399..efaaeb8f3b8 100644 --- a/drivers/sound/max98095.c +++ b/drivers/sound/max98095.c @@ -24,12 +24,7 @@ #include "i2s.h" #include "max98095.h"
-enum max98095_type { - MAX98095, -}; - struct max98095_priv { - enum max98095_type devtype; unsigned int sysclk; unsigned int rate; unsigned int fmt; @@ -484,14 +479,6 @@ static int max98095_do_init(struct sound_codec_info *pcodec_info, /* shift the device address by 1 for 7 bit addressing */ g_max98095_i2c_dev_addr = pcodec_info->i2c_dev_addr >> 1;
- if (pcodec_info->codec_type == CODEC_MAX_98095) { - g_max98095_info.devtype = MAX98095; - } else { - debug("%s: Codec id [%d] not defined\n", __func__, - pcodec_info->codec_type); - return -1; - } - ret = max98095_device_init(&g_max98095_info, aif_id); if (ret < 0) { debug("%s: max98095 codec chip init failed\n", __func__); @@ -555,7 +542,6 @@ static int get_max98095_codec_values(struct sound_codec_info *pcodec_info, debug("%s: Unknown compat id %d\n", __func__, compat); return -1; } - pcodec_info->codec_type = CODEC_MAX_98095; if (error == -1) { debug("fail to get max98095 codec node properties\n"); return -1; diff --git a/drivers/sound/wm8994.c b/drivers/sound/wm8994.c index 34bc4eb516f..2e84e92a2e0 100644 --- a/drivers/sound/wm8994.c +++ b/drivers/sound/wm8994.c @@ -847,8 +847,6 @@ static int get_codec_values(struct sound_codec_info *pcodec_info, return -1; }
- pcodec_info->codec_type = CODEC_WM_8994; - if (error == -1) { debug("fail to get wm8994 codec node properties\n"); return -1; @@ -875,14 +873,6 @@ int wm8994_init(const void *blob, enum en_audio_interface aif_id, g_wm8994_i2c_dev_addr = pcodec_info->i2c_dev_addr; wm8994_i2c_init(pcodec_info->i2c_bus);
- if (pcodec_info->codec_type == CODEC_WM_8994) { - g_wm8994_info.type = WM8994; - } else { - debug("%s: Codec id [%d] not defined\n", __func__, - pcodec_info->codec_type); - return -1; - } - ret = wm8994_device_init(&g_wm8994_info, aif_id); if (ret < 0) { debug("%s: wm8994 codec chip init failed\n", __func__); diff --git a/include/sound.h b/include/sound.h index 149e12dbc60..c4ac3193fe7 100644 --- a/include/sound.h +++ b/include/sound.h @@ -7,14 +7,6 @@ #ifndef __SOUND_H__ #define __SOUND_H__
-/* sound codec enum */ -enum sound_codec { - CODEC_WM_8994, - CODEC_WM_8995, - CODEC_MAX_98095, - CODEC_MAX -}; - /* sound codec enum */ enum sound_compat { AUDIO_COMPAT_SPI, @@ -25,7 +17,6 @@ enum sound_compat { struct sound_codec_info { int i2c_bus; int i2c_dev_addr; - enum sound_codec codec_type; };
At present the driver-private data is global. To allow this code to be used with driver model, change it to pass the data down to each function. Use the name 'priv' consistently throughout.
Also rename wm8994_update_bits() to wm8994_bic_or() which is more descriptive and shorter, thus breaking fewer lines with the parameter addition.
drivers/sound/wm8994.c | 296 +++++++++++++++++++++-------------------- 1 file changed, 154 insertions(+), 142 deletions(-)
diff --git a/drivers/sound/wm8994.c b/drivers/sound/wm8994.c index 2e84e92a2e0..3f56af9db4b 100644 --- a/drivers/sound/wm8994.c +++ b/drivers/sound/wm8994.c @@ -77,12 +77,14 @@ static void wm8994_i2c_init(int bus_no) /* * Writes value to a device register through i2c * + * @param priv Private data for driver * @param reg reg number to be write * @param data data to be writen to the above registor * * @return int value 1 for change, 0 for no change or negative error code. */ -static int wm8994_i2c_write(unsigned int reg, unsigned short data) +static int wm8994_i2c_write(struct wm8994_priv *priv, unsigned int reg, + unsigned short data) { unsigned char val[2];
@@ -96,12 +98,14 @@ static int wm8994_i2c_write(unsigned int reg, unsigned short data) /* * Read a value from a device register through i2c * + * @param priv Private data for driver * @param reg reg number to be read * @param data address of read data to be stored * * @return int value 0 for success, -1 in case of error. */ -static unsigned int wm8994_i2c_read(unsigned int reg , unsigned short *data) +static unsigned int wm8994_i2c_read(struct wm8994_priv *priv, unsigned int reg, + unsigned short *data) { unsigned char val[2]; int ret; @@ -123,6 +127,7 @@ static unsigned int wm8994_i2c_read(unsigned int reg , unsigned short *data) /* * update device register bits through i2c * + * @param priv Private data for driver * @param reg codec register * @param mask register mask * @param value new value @@ -130,18 +135,18 @@ static unsigned int wm8994_i2c_read(unsigned int reg , unsigned short *data) * @return int value 1 if change in the register value, * 0 for no change or negative error code. */ -static int wm8994_update_bits(unsigned int reg, unsigned short mask, - unsigned short value) +static int wm8994_bic_or(struct wm8994_priv *priv, unsigned int reg, + unsigned short mask, unsigned short value) { int change , ret = 0; unsigned short old, new;
- if (wm8994_i2c_read(reg, &old) != 0) + if (wm8994_i2c_read(priv, reg, &old) != 0) return -1; new = (old & ~mask) | (value & mask); change = (old != new) ? 1 : 0; if (change) - ret = wm8994_i2c_write(reg, new); + ret = wm8994_i2c_write(priv, reg, new); if (ret < 0) return ret;
@@ -151,12 +156,13 @@ static int wm8994_update_bits(unsigned int reg, unsigned short mask, /* * Sets i2s set format * + * @param priv wm8994 information * @param aif_id Interface ID * @param fmt i2S format * * @return -1 for error and 0 Success. */ -static int wm8994_set_fmt(int aif_id, unsigned int fmt) +static int wm8994_set_fmt(struct wm8994_priv *priv, int aif_id, uint fmt) { int ms_reg; int aif_reg; @@ -254,12 +260,13 @@ static int wm8994_set_fmt(int aif_id, unsigned int fmt) return -1; }
- error = wm8994_update_bits(aif_reg, WM8994_AIF1_BCLK_INV | - WM8994_AIF1_LRCLK_INV_MASK | WM8994_AIF1_FMT_MASK, aif); + error = wm8994_bic_or(priv, aif_reg, WM8994_AIF1_BCLK_INV | + WM8994_AIF1_LRCLK_INV_MASK | + WM8994_AIF1_FMT_MASK, aif);
- error |= wm8994_update_bits(ms_reg, WM8994_AIF1_MSTR_MASK, ms); - error |= wm8994_update_bits(aif_clk, WM8994_AIF1CLK_ENA_MASK, - WM8994_AIF1CLK_ENA); + error |= wm8994_bic_or(priv, ms_reg, WM8994_AIF1_MSTR_MASK, ms); + error |= wm8994_bic_or(priv, aif_clk, WM8994_AIF1CLK_ENA_MASK, + WM8994_AIF1CLK_ENA); if (error < 0) { debug("%s: codec register access error\n", __func__); return -1; @@ -271,7 +278,7 @@ static int wm8994_set_fmt(int aif_id, unsigned int fmt) /* * Sets hw params FOR WM8994 * - * @param wm8994 wm8994 information pointer + * @param priv wm8994 information pointer * @param aif_id Audio interface ID * @param sampling_rate Sampling rate * @param bits_per_sample Bits per sample @@ -279,9 +286,9 @@ static int wm8994_set_fmt(int aif_id, unsigned int fmt) * * @return -1 for error and 0 Success. */ -static int wm8994_hw_params(struct wm8994_priv *wm8994, int aif_id, - unsigned int sampling_rate, unsigned int bits_per_sample, - unsigned int channels) +static int wm8994_hw_params(struct wm8994_priv *priv, int aif_id, + uint sampling_rate, uint bits_per_sample, + uint channels) { int aif1_reg; int aif2_reg; @@ -349,12 +356,10 @@ static int wm8994_hw_params(struct wm8994_priv *wm8994, int aif_id,
/* AIFCLK/fs ratio; look for a close match in either direction */ best = 0; - best_val = abs((fs_ratios[0] * sampling_rate) - - wm8994->aifclk[id]); + best_val = abs((fs_ratios[0] * sampling_rate) - priv->aifclk[id]);
for (i = 1; i < ARRAY_SIZE(fs_ratios); i++) { - cur_val = abs((fs_ratios[i] * sampling_rate) - - wm8994->aifclk[id]); + cur_val = abs(fs_ratios[i] * sampling_rate - priv->aifclk[id]); if (cur_val >= best_val) continue; best = i; @@ -371,7 +376,7 @@ static int wm8994_hw_params(struct wm8994_priv *wm8994, int aif_id, */ best = 0; for (i = 0; i < ARRAY_SIZE(bclk_divs); i++) { - cur_val = (wm8994->aifclk[id] * 10 / bclk_divs[i]) - bclk_rate; + cur_val = (priv->aifclk[id] * 10 / bclk_divs[i]) - bclk_rate; if (cur_val < 0) /* BCLK table is sorted */ break; best = i; @@ -383,10 +388,10 @@ static int wm8994_hw_params(struct wm8994_priv *wm8994, int aif_id, return -1; }
- bclk_rate = wm8994->aifclk[id] * 10 / bclk_divs[best]; + bclk_rate = priv->aifclk[id] * 10 / bclk_divs[best]; bclk |= best << WM8994_AIF1_BCLK_DIV_SHIFT;
- if (wm8994_i2c_read(aif1_reg, ®_data) != 0) { + if (wm8994_i2c_read(priv, aif1_reg, ®_data) != 0) { debug("%s: AIF1 register read Failed\n", __func__); return -1; } @@ -394,16 +399,17 @@ static int wm8994_hw_params(struct wm8994_priv *wm8994, int aif_id, if ((channels == 1) && ((reg_data & 0x18) == 0x18)) aif2 |= WM8994_AIF1_MONO;
- if (wm8994->aifclk[id] == 0) { + if (priv->aifclk[id] == 0) { debug("%s:Audio interface clock not set\n", __func__); return -1; }
- ret = wm8994_update_bits(aif1_reg, WM8994_AIF1_WL_MASK, aif1); - ret |= wm8994_update_bits(aif2_reg, WM8994_AIF1_MONO, aif2); - ret |= wm8994_update_bits(bclk_reg, WM8994_AIF1_BCLK_DIV_MASK, bclk); - ret |= wm8994_update_bits(rate_reg, WM8994_AIF1_SR_MASK | - WM8994_AIF1CLK_RATE_MASK, rate_val); + ret = wm8994_bic_or(priv, aif1_reg, WM8994_AIF1_WL_MASK, aif1); + ret |= wm8994_bic_or(priv, aif2_reg, WM8994_AIF1_MONO, aif2); + ret |= wm8994_bic_or(priv, bclk_reg, WM8994_AIF1_BCLK_DIV_MASK, + bclk); + ret |= wm8994_bic_or(priv, rate_reg, WM8994_AIF1_SR_MASK | + WM8994_AIF1CLK_RATE_MASK, rate_val);
debug("rate vale = %x , bclk val= %x\n", rate_val, bclk);
@@ -418,12 +424,12 @@ static int wm8994_hw_params(struct wm8994_priv *wm8994, int aif_id, /* * Configures Audio interface Clock * - * @param wm8994 wm8994 information pointer + * @param priv wm8994 information pointer * @param aif Audio Interface ID * * @return -1 for error and 0 Success. */ -static int configure_aif_clock(struct wm8994_priv *wm8994, int aif) +static int configure_aif_clock(struct wm8994_priv *priv, int aif) { int rate; int reg1 = 0; @@ -436,30 +442,30 @@ static int configure_aif_clock(struct wm8994_priv *wm8994, int aif) else offset = 0;
- switch (wm8994->sysclk[aif-1]) { + switch (priv->sysclk[aif - 1]) { case WM8994_SYSCLK_MCLK1: reg1 |= SEL_MCLK1; - rate = wm8994->mclk[0]; + rate = priv->mclk[0]; break;
case WM8994_SYSCLK_MCLK2: reg1 |= SEL_MCLK2; - rate = wm8994->mclk[1]; + rate = priv->mclk[1]; break;
case WM8994_SYSCLK_FLL1: reg1 |= SEL_FLL1; - rate = wm8994->fll[0].out; + rate = priv->fll[0].out; break;
case WM8994_SYSCLK_FLL2: reg1 |= SEL_FLL2; - rate = wm8994->fll[1].out; + rate = priv->fll[1].out; break;
default: debug("%s: Invalid input clock selection [%d]\n", - __func__, wm8994->sysclk[aif-1]); + __func__, priv->sysclk[aif - 1]); return -1; }
@@ -469,18 +475,18 @@ static int configure_aif_clock(struct wm8994_priv *wm8994, int aif) reg1 |= WM8994_AIF1CLK_DIV; }
- wm8994->aifclk[aif-1] = rate; + priv->aifclk[aif - 1] = rate;
- ret = wm8994_update_bits(WM8994_AIF1_CLOCKING_1 + offset, - WM8994_AIF1CLK_SRC_MASK | WM8994_AIF1CLK_DIV, - reg1); + ret = wm8994_bic_or(priv, WM8994_AIF1_CLOCKING_1 + offset, + WM8994_AIF1CLK_SRC_MASK | WM8994_AIF1CLK_DIV, + reg1);
if (aif == WM8994_AIF1) - ret |= wm8994_update_bits(WM8994_CLOCKING_1, + ret |= wm8994_bic_or(priv, WM8994_CLOCKING_1, WM8994_AIF1DSPCLK_ENA_MASK | WM8994_SYSDSPCLK_ENA_MASK, WM8994_AIF1DSPCLK_ENA | WM8994_SYSDSPCLK_ENA); else if (aif == WM8994_AIF2) - ret |= wm8994_update_bits(WM8994_CLOCKING_1, + ret |= wm8994_bic_or(priv, WM8994_CLOCKING_1, WM8994_SYSCLK_SRC | WM8994_AIF2DSPCLK_ENA_MASK | WM8994_SYSDSPCLK_ENA_MASK, WM8994_SYSCLK_SRC | WM8994_AIF2DSPCLK_ENA | WM8994_SYSDSPCLK_ENA); @@ -496,33 +502,33 @@ static int configure_aif_clock(struct wm8994_priv *wm8994, int aif) /* * Configures Audio interface for the given frequency * - * @param wm8994 wm8994 information + * @param priv wm8994 information * @param aif_id Audio Interface * @param clk_id Input Clock ID * @param freq Sampling frequency in Hz * * @return -1 for error and 0 success. */ -static int wm8994_set_sysclk(struct wm8994_priv *wm8994, int aif_id, - int clk_id, unsigned int freq) +static int wm8994_set_sysclk(struct wm8994_priv *priv, int aif_id, int clk_id, + unsigned int freq) { int i; int ret = 0;
- wm8994->sysclk[aif_id - 1] = clk_id; + priv->sysclk[aif_id - 1] = clk_id;
switch (clk_id) { case WM8994_SYSCLK_MCLK1: - wm8994->mclk[0] = freq; + priv->mclk[0] = freq; if (aif_id == 2) { - ret = wm8994_update_bits(WM8994_AIF1_CLOCKING_2 , - WM8994_AIF2DAC_DIV_MASK , 0); + ret = wm8994_bic_or(priv, WM8994_AIF1_CLOCKING_2, + WM8994_AIF2DAC_DIV_MASK, 0); } break;
case WM8994_SYSCLK_MCLK2: /* TODO: Set GPIO AF */ - wm8994->mclk[1] = freq; + priv->mclk[1] = freq; break;
case WM8994_SYSCLK_FLL1: @@ -543,13 +549,14 @@ static int wm8994_set_sysclk(struct wm8994_priv *wm8994, int aif_id, __func__); return -1; } - ret = wm8994_update_bits(WM8994_CLOCKING_2, + ret = wm8994_bic_or(priv, WM8994_CLOCKING_2, WM8994_OPCLK_DIV_MASK, i); - ret |= wm8994_update_bits(WM8994_POWER_MANAGEMENT_2, - WM8994_OPCLK_ENA, WM8994_OPCLK_ENA); + ret |= wm8994_bic_or(priv, WM8994_POWER_MANAGEMENT_2, + WM8994_OPCLK_ENA, + WM8994_OPCLK_ENA); } else { - ret |= wm8994_update_bits(WM8994_POWER_MANAGEMENT_2, - WM8994_OPCLK_ENA, 0); + ret |= wm8994_bic_or(priv, WM8994_POWER_MANAGEMENT_2, + WM8994_OPCLK_ENA, 0); }
default: @@ -558,7 +565,7 @@ static int wm8994_set_sysclk(struct wm8994_priv *wm8994, int aif_id, return -1; }
- ret |= configure_aif_clock(wm8994, aif_id); + ret |= configure_aif_clock(priv, aif_id);
if (ret < 0) { debug("%s: codec register access error\n", __func__); @@ -571,37 +578,38 @@ static int wm8994_set_sysclk(struct wm8994_priv *wm8994, int aif_id, /* * Initializes Volume for AIF2 to HP path * + * @param priv wm8994 information * @returns -1 for error and 0 Success. * */ -static int wm8994_init_volume_aif2_dac1(void) +static int wm8994_init_volume_aif2_dac1(struct wm8994_priv *priv) { int ret;
/* Unmute AIF2DAC */ - ret = wm8994_update_bits(WM8994_AIF2_DAC_FILTERS_1, - WM8994_AIF2DAC_MUTE_MASK, 0); + ret = wm8994_bic_or(priv, WM8994_AIF2_DAC_FILTERS_1, + WM8994_AIF2DAC_MUTE_MASK, 0);
- ret |= wm8994_update_bits(WM8994_AIF2_DAC_LEFT_VOLUME, - WM8994_AIF2DAC_VU_MASK | WM8994_AIF2DACL_VOL_MASK, - WM8994_AIF2DAC_VU | 0xff); + ret |= wm8994_bic_or(priv, WM8994_AIF2_DAC_LEFT_VOLUME, + WM8994_AIF2DAC_VU_MASK | WM8994_AIF2DACL_VOL_MASK, + WM8994_AIF2DAC_VU | 0xff);
- ret |= wm8994_update_bits(WM8994_AIF2_DAC_RIGHT_VOLUME, - WM8994_AIF2DAC_VU_MASK | WM8994_AIF2DACR_VOL_MASK, - WM8994_AIF2DAC_VU | 0xff); + ret |= wm8994_bic_or(priv, WM8994_AIF2_DAC_RIGHT_VOLUME, + WM8994_AIF2DAC_VU_MASK | WM8994_AIF2DACR_VOL_MASK, + WM8994_AIF2DAC_VU | 0xff);
- ret |= wm8994_update_bits(WM8994_DAC1_LEFT_VOLUME, - WM8994_DAC1_VU_MASK | WM8994_DAC1L_VOL_MASK | - WM8994_DAC1L_MUTE_MASK, WM8994_DAC1_VU | 0xc0); + ret |= wm8994_bic_or(priv, WM8994_DAC1_LEFT_VOLUME, + WM8994_DAC1_VU_MASK | WM8994_DAC1L_VOL_MASK | + WM8994_DAC1L_MUTE_MASK, WM8994_DAC1_VU | 0xc0);
- ret |= wm8994_update_bits(WM8994_DAC1_RIGHT_VOLUME, - WM8994_DAC1_VU_MASK | WM8994_DAC1R_VOL_MASK | - WM8994_DAC1R_MUTE_MASK, WM8994_DAC1_VU | 0xc0); + ret |= wm8994_bic_or(priv, WM8994_DAC1_RIGHT_VOLUME, + WM8994_DAC1_VU_MASK | WM8994_DAC1R_VOL_MASK | + WM8994_DAC1R_MUTE_MASK, WM8994_DAC1_VU | 0xc0); /* Head Phone Volume */ - ret |= wm8994_i2c_write(WM8994_LEFT_OUTPUT_VOLUME, 0x12D); - ret |= wm8994_i2c_write(WM8994_RIGHT_OUTPUT_VOLUME, 0x12D); + ret |= wm8994_i2c_write(priv, WM8994_LEFT_OUTPUT_VOLUME, 0x12D); + ret |= wm8994_i2c_write(priv, WM8994_RIGHT_OUTPUT_VOLUME, 0x12D);
if (ret < 0) { debug("%s: codec register access error\n", __func__); @@ -614,26 +622,27 @@ static int wm8994_init_volume_aif2_dac1(void) /* * Initializes Volume for AIF1 to HP path * + * @param priv wm8994 information * @returns -1 for error and 0 Success. * */ -static int wm8994_init_volume_aif1_dac1(void) +static int wm8994_init_volume_aif1_dac1(struct wm8994_priv *priv) { int ret = 0;
/* Unmute AIF1DAC */ - ret |= wm8994_i2c_write(WM8994_AIF1_DAC_FILTERS_1, 0x0000); + ret |= wm8994_i2c_write(priv, WM8994_AIF1_DAC_FILTERS_1, 0x0000);
if (ret < 0) { debug("%s: codec register access error\n", __func__); @@ -646,20 +655,20 @@ static int wm8994_init_volume_aif1_dac1(void) /* * Intialise wm8994 codec device * - * @param wm8994 wm8994 information + * @param priv wm8994 information * * @returns -1 for error and 0 Success. */ -static int wm8994_device_init(struct wm8994_priv *wm8994, +static int wm8994_device_init(struct wm8994_priv *priv, enum en_audio_interface aif_id) { const char *devname; unsigned short reg_data; int ret;
- wm8994_i2c_write(WM8994_SOFTWARE_RESET, WM8994_SW_RESET);/* Reset */ + wm8994_i2c_write(priv, WM8994_SOFTWARE_RESET, WM8994_SW_RESET);
- ret = wm8994_i2c_read(WM8994_SOFTWARE_RESET, ®_data); + ret = wm8994_i2c_read(priv, WM8994_SOFTWARE_RESET, ®_data); if (ret < 0) { debug("Failed to read ID register\n"); goto err; @@ -667,72 +676,72 @@ static int wm8994_device_init(struct wm8994_priv *wm8994,
if (reg_data == WM8994_ID) { devname = "WM8994"; - debug("Device registered as type %d\n", wm8994->type); - wm8994->type = WM8994; + debug("Device registered as type %d\n", priv->type); + priv->type = WM8994; } else { debug("Device is not a WM8994, ID is %x\n", ret); ret = -1; goto err; }
- ret = wm8994_i2c_read(WM8994_CHIP_REVISION, ®_data); + ret = wm8994_i2c_read(priv, WM8994_CHIP_REVISION, ®_data); if (ret < 0) { debug("Failed to read revision register: %d\n", ret); goto err; } - wm8994->revision = reg_data; - debug("%s revision %c\n", devname, 'A' + wm8994->revision); + priv->revision = reg_data; + debug("%s revision %c\n", devname, 'A' + priv->revision);
/* VMID Selection */ - ret |= wm8994_update_bits(WM8994_POWER_MANAGEMENT_1, - WM8994_VMID_SEL_MASK | WM8994_BIAS_ENA_MASK, 0x3); + ret |= wm8994_bic_or(priv, WM8994_POWER_MANAGEMENT_1, + WM8994_VMID_SEL_MASK | WM8994_BIAS_ENA_MASK, 0x3);
/* Charge Pump Enable */ - ret |= wm8994_update_bits(WM8994_CHARGE_PUMP_1, WM8994_CP_ENA_MASK, - WM8994_CP_ENA); + ret |= wm8994_bic_or(priv, WM8994_CHARGE_PUMP_1, WM8994_CP_ENA_MASK, + WM8994_CP_ENA);
/* Head Phone Power Enable */ - ret |= wm8994_update_bits(WM8994_POWER_MANAGEMENT_1, - WM8994_HPOUT1L_ENA_MASK, WM8994_HPOUT1L_ENA); + ret |= wm8994_bic_or(priv, WM8994_POWER_MANAGEMENT_1, + WM8994_HPOUT1L_ENA_MASK, WM8994_HPOUT1L_ENA);
- ret |= wm8994_update_bits(WM8994_POWER_MANAGEMENT_1, - WM8994_HPOUT1R_ENA_MASK, WM8994_HPOUT1R_ENA); + ret |= wm8994_bic_or(priv, WM8994_POWER_MANAGEMENT_1, + WM8994_HPOUT1R_ENA_MASK, WM8994_HPOUT1R_ENA);
if (aif_id == WM8994_AIF1) { - ret |= wm8994_i2c_write(WM8994_POWER_MANAGEMENT_2, + ret |= wm8994_i2c_write(priv, WM8994_POWER_MANAGEMENT_2, WM8994_TSHUT_ENA | WM8994_MIXINL_ENA | WM8994_MIXINR_ENA | WM8994_IN2L_ENA | WM8994_IN2R_ENA);
- ret |= wm8994_i2c_write(WM8994_POWER_MANAGEMENT_4, + ret |= wm8994_i2c_write(priv, WM8994_POWER_MANAGEMENT_4, WM8994_ADCL_ENA | WM8994_ADCR_ENA | WM8994_AIF1ADC1R_ENA | WM8994_AIF1ADC1L_ENA);
/* Power enable for AIF1 and DAC1 */ - ret |= wm8994_i2c_write(WM8994_POWER_MANAGEMENT_5, + ret |= wm8994_i2c_write(priv, WM8994_POWER_MANAGEMENT_5, WM8994_AIF1DACL_ENA | WM8994_AIF1DACR_ENA | WM8994_DAC1L_ENA | WM8994_DAC1R_ENA); } else if (aif_id == WM8994_AIF2) { /* Power enable for AIF2 and DAC1 */ - ret |= wm8994_update_bits(WM8994_POWER_MANAGEMENT_5, + ret |= wm8994_bic_or(priv, WM8994_POWER_MANAGEMENT_5, WM8994_AIF2DACL_ENA_MASK | WM8994_AIF2DACR_ENA_MASK | WM8994_DAC1L_ENA_MASK | WM8994_DAC1R_ENA_MASK, WM8994_AIF2DACL_ENA | WM8994_AIF2DACR_ENA | WM8994_DAC1L_ENA | WM8994_DAC1R_ENA); } /* Head Phone Initialisation */ - ret |= wm8994_update_bits(WM8994_ANALOGUE_HP_1, + ret |= wm8994_bic_or(priv, WM8994_ANALOGUE_HP_1, WM8994_HPOUT1L_DLY_MASK | WM8994_HPOUT1R_DLY_MASK, WM8994_HPOUT1L_DLY | WM8994_HPOUT1R_DLY);
- ret |= wm8994_update_bits(WM8994_DC_SERVO_1, + ret |= wm8994_bic_or(priv, WM8994_DC_SERVO_1, WM8994_DCS_ENA_CHAN_0_MASK | WM8994_DCS_ENA_CHAN_1_MASK , WM8994_DCS_ENA_CHAN_0 | WM8994_DCS_ENA_CHAN_1);
- ret |= wm8994_update_bits(WM8994_ANALOGUE_HP_1, + ret |= wm8994_bic_or(priv, WM8994_ANALOGUE_HP_1, WM8994_HPOUT1L_DLY_MASK | WM8994_HPOUT1R_DLY_MASK | WM8994_HPOUT1L_OUTP_MASK | WM8994_HPOUT1R_OUTP_MASK | @@ -743,53 +752,56 @@ static int wm8994_device_init(struct wm8994_priv *wm8994, WM8994_HPOUT1R_RMV_SHORT);
/* MIXER Config DAC1 to HP */ - ret |= wm8994_update_bits(WM8994_OUTPUT_MIXER_1, - WM8994_DAC1L_TO_HPOUT1L_MASK, WM8994_DAC1L_TO_HPOUT1L); + ret |= wm8994_bic_or(priv, WM8994_OUTPUT_MIXER_1, + WM8994_DAC1L_TO_HPOUT1L_MASK, + WM8994_DAC1L_TO_HPOUT1L);
- ret |= wm8994_update_bits(WM8994_OUTPUT_MIXER_2, - WM8994_DAC1R_TO_HPOUT1R_MASK, WM8994_DAC1R_TO_HPOUT1R); + ret |= wm8994_bic_or(priv, WM8994_OUTPUT_MIXER_2, + WM8994_DAC1R_TO_HPOUT1R_MASK, + WM8994_DAC1R_TO_HPOUT1R);
if (aif_id == WM8994_AIF1) { /* Routing AIF1 to DAC1 */ - ret |= wm8994_i2c_write(WM8994_DAC1_LEFT_MIXER_ROUTING, - WM8994_AIF1DAC1L_TO_DAC1L); + ret |= wm8994_i2c_write(priv, WM8994_DAC1_LEFT_MIXER_ROUTING, + WM8994_AIF1DAC1L_TO_DAC1L);
- ret |= wm8994_i2c_write(WM8994_DAC1_RIGHT_MIXER_ROUTING, + ret |= wm8994_i2c_write(priv, WM8994_DAC1_RIGHT_MIXER_ROUTING, WM8994_AIF1DAC1R_TO_DAC1R);
/* GPIO Settings for AIF1 */ - ret |= wm8994_i2c_write(WM8994_GPIO_1, WM8994_GPIO_DIR_OUTPUT - | WM8994_GPIO_FUNCTION_I2S_CLK - | WM8994_GPIO_INPUT_DEBOUNCE); + ret |= wm8994_i2c_write(priv, WM8994_GPIO_1, + WM8994_GPIO_DIR_OUTPUT | + WM8994_GPIO_FUNCTION_I2S_CLK | + WM8994_GPIO_INPUT_DEBOUNCE);
- ret |= wm8994_init_volume_aif1_dac1(); + ret |= wm8994_init_volume_aif1_dac1(priv); } else if (aif_id == WM8994_AIF2) { /* Routing AIF2 to DAC1 */ - ret |= wm8994_update_bits(WM8994_DAC1_LEFT_MIXER_ROUTING, - WM8994_AIF2DACL_TO_DAC1L_MASK, - WM8994_AIF2DACL_TO_DAC1L); + ret |= wm8994_bic_or(priv, WM8994_DAC1_LEFT_MIXER_ROUTING, + WM8994_AIF2DACL_TO_DAC1L_MASK, + WM8994_AIF2DACL_TO_DAC1L);
- ret |= wm8994_update_bits(WM8994_DAC1_RIGHT_MIXER_ROUTING, - WM8994_AIF2DACR_TO_DAC1R_MASK, - WM8994_AIF2DACR_TO_DAC1R); + ret |= wm8994_bic_or(priv, WM8994_DAC1_RIGHT_MIXER_ROUTING, + WM8994_AIF2DACR_TO_DAC1R_MASK, + WM8994_AIF2DACR_TO_DAC1R);
/* GPIO Settings for AIF2 */ /* B CLK */ - ret |= wm8994_update_bits(WM8994_GPIO_3, WM8994_GPIO_DIR_MASK | - WM8994_GPIO_FUNCTION_MASK , - WM8994_GPIO_DIR_OUTPUT); + ret |= wm8994_bic_or(priv, WM8994_GPIO_3, WM8994_GPIO_DIR_MASK | + WM8994_GPIO_FUNCTION_MASK, + WM8994_GPIO_DIR_OUTPUT);
/* LR CLK */ - ret |= wm8994_update_bits(WM8994_GPIO_4, WM8994_GPIO_DIR_MASK | - WM8994_GPIO_FUNCTION_MASK, - WM8994_GPIO_DIR_OUTPUT); + ret |= wm8994_bic_or(priv, WM8994_GPIO_4, WM8994_GPIO_DIR_MASK | + WM8994_GPIO_FUNCTION_MASK, + WM8994_GPIO_DIR_OUTPUT);
/* DATA */ - ret |= wm8994_update_bits(WM8994_GPIO_5, WM8994_GPIO_DIR_MASK | - WM8994_GPIO_FUNCTION_MASK, - WM8994_GPIO_DIR_OUTPUT); + ret |= wm8994_bic_or(priv, WM8994_GPIO_5, WM8994_GPIO_DIR_MASK | + WM8994_GPIO_FUNCTION_MASK, + WM8994_GPIO_DIR_OUTPUT);
- ret |= wm8994_init_volume_aif2_dac1(); + ret |= wm8994_init_volume_aif2_dac1(priv); }
if (ret < 0) @@ -810,7 +822,7 @@ err: * @return int value, 0 for success */ static int get_codec_values(struct sound_codec_info *pcodec_info, - const void *blob) + const void *blob) { int error = 0; enum fdt_compat_id compat; @@ -857,8 +869,8 @@ static int get_codec_values(struct sound_codec_info *pcodec_info,
/* WM8994 Device Initialisation */ int wm8994_init(const void *blob, enum en_audio_interface aif_id, - int sampling_rate, int mclk_freq, - int bits_per_sample, unsigned int channels) + int sampling_rate, int mclk_freq, int bits_per_sample, + unsigned int channels) { int ret = 0; struct sound_codec_info *pcodec_info = &g_codec_info; @@ -887,12 +899,12 @@ int wm8994_init(const void *blob, enum en_audio_interface aif_id, }
ret = wm8994_hw_params(&g_wm8994_info, aif_id, sampling_rate, - bits_per_sample, channels); + bits_per_sample, channels);
if (ret == 0) { - ret = wm8994_set_fmt(aif_id, SND_SOC_DAIFMT_I2S | - SND_SOC_DAIFMT_NB_NF | - SND_SOC_DAIFMT_CBS_CFS); + ret = wm8994_set_fmt(&g_wm8994_info, aif_id, + SND_SOC_DAIFMT_I2S | SND_SOC_DAIFMT_NB_NF | + SND_SOC_DAIFMT_CBS_CFS); } return ret; }
Also rename max98095_update_bits() to max98095_bic_or() which is more descriptive and shorter, thus breaking fewer lines with the parameter addition.
drivers/sound/max98095.c | 152 ++++++++++++++++++++------------------- 1 file changed, 78 insertions(+), 74 deletions(-)
diff --git a/drivers/sound/max98095.c b/drivers/sound/max98095.c index efaaeb8f3b8..6edf3736d79 100644 --- a/drivers/sound/max98095.c +++ b/drivers/sound/max98095.c @@ -41,12 +41,14 @@ int rate_table[] = {0, 8000, 11025, 16000, 22050, 24000, 32000, 44100, 48000, /* * Writes value to a device register through i2c * + * @param priv Private data for driver * @param reg reg number to be write * @param data data to be writen to the above registor * * @return int value 1 for change, 0 for no change or negative error code. */ -static int max98095_i2c_write(unsigned int reg, unsigned char data) +static int max98095_i2c_write(struct max98095_priv *priv, unsigned int reg, + unsigned char data) { debug("%s: Write Addr : 0x%02X, Data : 0x%02X\n", __func__, reg, data); @@ -56,12 +58,14 @@ static int max98095_i2c_write(unsigned int reg, unsigned char data) /* * Read a value from a device register through i2c * + * @param priv Private data for driver * @param reg reg number to be read * @param data address of read data to be stored * * @return int value 0 for success, -1 in case of error. */ -static unsigned int max98095_i2c_read(unsigned int reg, unsigned char *data) +static unsigned int max98095_i2c_read(struct max98095_priv *priv, + unsigned int reg, unsigned char *data) { int ret;
@@ -78,24 +82,25 @@ static unsigned int max98095_i2c_read(unsigned int reg, unsigned char *data) /* * update device register bits through i2c * + * @param priv Private data for driver * @param reg codec register * @param mask register mask * @param value new value * * @return int value 0 for success, non-zero error code. */ -static int max98095_update_bits(unsigned int reg, unsigned char mask, - unsigned char value) +static int max98095_bic_or(struct max98095_priv *priv, unsigned int reg, + unsigned char mask, unsigned char value) { int change, ret = 0; unsigned char old, new;
- if (max98095_i2c_read(reg, &old) != 0) + if (max98095_i2c_read(priv, reg, &old) != 0) return -1; new = (old & ~mask) | (value & mask); change = (old != new) ? 1 : 0; if (change) - ret = max98095_i2c_write(reg, new); + ret = max98095_i2c_write(priv, reg, new); if (ret < 0) return ret;
@@ -128,13 +133,13 @@ static int rate_value(int rate, u8 *value) /* * Sets hw params for max98095 * - * @param max98095 max98095 information pointer + * @param priv max98095 information pointer * @param rate Sampling rate * @param bits_per_sample Bits per sample * * @return -1 for error and 0 Success. */ -static int max98095_hw_params(struct max98095_priv *max98095, +static int max98095_hw_params(struct max98095_priv *priv, enum en_max_audio_interface aif_id, unsigned int rate, unsigned int bits_per_sample) { @@ -156,12 +161,12 @@ static int max98095_hw_params(struct max98095_priv *max98095,
switch (bits_per_sample) { case 16: - error = max98095_update_bits(M98095_DAI_FORMAT, - M98095_DAI_WS, 0); + error = max98095_bic_or(priv, M98095_DAI_FORMAT, M98095_DAI_WS, + 0); break; case 24: - error = max98095_update_bits(M98095_DAI_FORMAT, - M98095_DAI_WS, M98095_DAI_WS); + error = max98095_bic_or(priv, M98095_DAI_FORMAT, M98095_DAI_WS, + M98095_DAI_WS); break; default: debug("%s: Illegal bits per sample %d.\n", @@ -174,18 +179,18 @@ static int max98095_hw_params(struct max98095_priv *max98095, __func__, rate); return -1; } - max98095->rate = rate; + priv->rate = rate;
- error |= max98095_update_bits(M98095_DAI_CLKMODE, - M98095_CLKMODE_MASK, regval); + error |= max98095_bic_or(priv, M98095_DAI_CLKMODE, M98095_CLKMODE_MASK, + regval);
/* Update sample rate mode */ if (rate < 50000) - error |= max98095_update_bits(M98095_DAI_FILTERS, - M98095_DAI_DHF, 0); + error |= max98095_bic_or(priv, M98095_DAI_FILTERS, + M98095_DAI_DHF, 0); else - error |= max98095_update_bits(M98095_DAI_FILTERS, - M98095_DAI_DHF, M98095_DAI_DHF); + error |= max98095_bic_or(priv, M98095_DAI_FILTERS, + M98095_DAI_DHF, M98095_DAI_DHF);
if (error < 0) { debug("%s: Error setting hardware params.\n", __func__); @@ -198,18 +203,17 @@ static int max98095_hw_params(struct max98095_priv *max98095, /* * Configures Audio interface system clock for the given frequency * - * @param max98095 max98095 information + * @param priv max98095 information * @param freq Sampling frequency in Hz * * @return -1 for error and 0 success. */ -static int max98095_set_sysclk(struct max98095_priv *max98095, - unsigned int freq) +static int max98095_set_sysclk(struct max98095_priv *priv, unsigned int freq) { int error = 0;
/* Requested clock frequency is already setup */ - if (freq == max98095->sysclk) + if (freq == priv->sysclk) return 0;
/* Setup clocks for slave mode, and using the PLL @@ -218,11 +222,11 @@ static int max98095_set_sysclk(struct max98095_priv *max98095, * 0x03 (when master clk is 40MHz to 60MHz).. */ if ((freq >= 10000000) && (freq < 20000000)) { - error = max98095_i2c_write(M98095_026_SYS_CLK, 0x10); + error = max98095_i2c_write(priv, M98095_026_SYS_CLK, 0x10); } else if ((freq >= 20000000) && (freq < 40000000)) { - error = max98095_i2c_write(M98095_026_SYS_CLK, 0x20); + error = max98095_i2c_write(priv, M98095_026_SYS_CLK, 0x20); } else if ((freq >= 40000000) && (freq < 60000000)) { - error = max98095_i2c_write(M98095_026_SYS_CLK, 0x30); + error = max98095_i2c_write(priv, M98095_026_SYS_CLK, 0x30); } else { debug("%s: Invalid master clock frequency\n", __func__); return -1; @@ -233,20 +237,20 @@ static int max98095_set_sysclk(struct max98095_priv *max98095, if (error < 0) return -1;
- max98095->sysclk = freq; + priv->sysclk = freq; return 0; }
/* * Sets Max98095 I2S format * - * @param max98095 max98095 information + * @param priv max98095 information * @param fmt i2S format - supports a subset of the options defined * in i2s.h. * * @return -1 for error and 0 Success. */ -static int max98095_set_fmt(struct max98095_priv *max98095, int fmt, +static int max98095_set_fmt(struct max98095_priv *priv, int fmt, enum en_max_audio_interface aif_id) { u8 regval = 0; @@ -256,10 +260,10 @@ static int max98095_set_fmt(struct max98095_priv *max98095, int fmt, unsigned short M98095_DAI_FORMAT; unsigned short M98095_DAI_CLOCK;
- if (fmt == max98095->fmt) + if (fmt == priv->fmt) return 0;
- max98095->fmt = fmt; + priv->fmt = fmt;
if (aif_id == AIF1) { M98095_DAI_CLKCFG_HI = M98095_028_DAI1_CLKCFG_HI; @@ -276,10 +280,8 @@ static int max98095_set_fmt(struct max98095_priv *max98095, int fmt, switch (fmt & SND_SOC_DAIFMT_MASTER_MASK) { case SND_SOC_DAIFMT_CBS_CFS: /* Slave mode PLL */ - error |= max98095_i2c_write(M98095_DAI_CLKCFG_HI, - 0x80); - error |= max98095_i2c_write(M98095_DAI_CLKCFG_LO, - 0x00); + error |= max98095_i2c_write(priv, M98095_DAI_CLKCFG_HI, 0x80); + error |= max98095_i2c_write(priv, M98095_DAI_CLKCFG_LO, 0x00); break; case SND_SOC_DAIFMT_CBM_CFM: /* Set to master mode */ @@ -320,13 +322,11 @@ static int max98095_set_fmt(struct max98095_priv *max98095, int fmt, return -1; }
- error |= max98095_update_bits(M98095_DAI_FORMAT, - M98095_DAI_MAS | M98095_DAI_DLY | - M98095_DAI_BCI | M98095_DAI_WCI, - regval); + error |= max98095_bic_or(priv, M98095_DAI_FORMAT, + M98095_DAI_MAS | M98095_DAI_DLY | + M98095_DAI_BCI | M98095_DAI_WCI, regval);
- error |= max98095_i2c_write(M98095_DAI_CLOCK, - M98095_DAI_BSEL64); + error |= max98095_i2c_write(priv, M98095_DAI_CLOCK, M98095_DAI_BSEL64);
if (error < 0) { debug("%s: Error setting i2s format.\n", __func__); @@ -339,9 +339,10 @@ static int max98095_set_fmt(struct max98095_priv *max98095, int fmt, /* * resets the audio codec * + * @param priv Private data for driver * @return -1 for error and 0 success. */ -static int max98095_reset(void) +static int max98095_reset(struct max98095_priv *priv) { int i, ret;
@@ -349,13 +350,13 @@ static int max98095_reset(void) * Gracefully reset the DSP core and the codec hardware in a proper * sequence. */ - ret = max98095_i2c_write(M98095_00F_HOST_CFG, 0); + ret = max98095_i2c_write(priv, M98095_00F_HOST_CFG, 0); if (ret != 0) { debug("%s: Failed to reset DSP: %d\n", __func__, ret); return ret; }
- ret = max98095_i2c_write(M98095_097_PWR_SYS, 0); + ret = max98095_i2c_write(priv, M98095_097_PWR_SYS, 0); if (ret != 0) { debug("%s: Failed to reset codec: %d\n", __func__, ret); return ret; @@ -366,7 +367,7 @@ static int max98095_reset(void) * reset hardware control register. */ for (i = M98095_010_HOST_INT_CFG; i < M98095_REG_MAX_CACHED; i++) { - ret = max98095_i2c_write(i, 0); + ret = max98095_i2c_write(priv, i, 0); if (ret < 0) { debug("%s: Failed to reset: %d\n", __func__, ret); return ret; @@ -379,29 +380,29 @@ static int max98095_reset(void) /* * Intialise max98095 codec device * - * @param max98095 max98095 information + * @param priv max98095 information * * @returns -1 for error and 0 Success. */ -static int max98095_device_init(struct max98095_priv *max98095, +static int max98095_device_init(struct max98095_priv *priv, enum en_max_audio_interface aif_id) { unsigned char id; int error = 0;
/* reset the codec, the DSP core, and disable all interrupts */ - error = max98095_reset(); + error = max98095_reset(priv); if (error != 0) { debug("Reset\n"); return error; }
/* initialize private data */ - max98095->sysclk = -1U; - max98095->rate = -1U; - max98095->fmt = -1U; + priv->sysclk = -1U; + priv->rate = -1U; + priv->fmt = -1U;
- error = max98095_i2c_read(M98095_0FF_REV_ID, &id); + error = max98095_i2c_read(priv, M98095_0FF_REV_ID, &id); if (error < 0) { debug("%s: Failure reading hardware revision: %d\n", __func__, id); @@ -409,55 +410,58 @@ static int max98095_device_init(struct max98095_priv *max98095, } debug("%s: Hardware revision: %c\n", __func__, (id - 0x40) + 'A');
- error |= max98095_i2c_write(M98095_097_PWR_SYS, M98095_PWRSV); + error |= max98095_i2c_write(priv, M98095_097_PWR_SYS, M98095_PWRSV);
/* * initialize registers to hardware default configuring audio * interface2 to DAC */ if (aif_id == AIF1) - error |= max98095_i2c_write(M98095_048_MIX_DAC_LR, + error |= max98095_i2c_write(priv, M98095_048_MIX_DAC_LR, M98095_DAI1L_TO_DACL | M98095_DAI1R_TO_DACR); else - error |= max98095_i2c_write(M98095_048_MIX_DAC_LR, + error |= max98095_i2c_write(priv, M98095_048_MIX_DAC_LR, M98095_DAI2M_TO_DACL | M98095_DAI2M_TO_DACR);
- error |= max98095_i2c_write(M98095_092_PWR_EN_OUT, + error |= max98095_i2c_write(priv, M98095_092_PWR_EN_OUT, M98095_SPK_SPREADSPECTRUM); - error |= max98095_i2c_write(M98095_04E_CFG_HP, M98095_HPNORMAL); + error |= max98095_i2c_write(priv, M98095_04E_CFG_HP, M98095_HPNORMAL); if (aif_id == AIF1) - error |= max98095_i2c_write(M98095_02C_DAI1_IOCFG, + error |= max98095_i2c_write(priv, M98095_02C_DAI1_IOCFG, M98095_S1NORMAL | M98095_SDATA); else - error |= max98095_i2c_write(M98095_036_DAI2_IOCFG, + error |= max98095_i2c_write(priv, M98095_036_DAI2_IOCFG, M98095_S2NORMAL | M98095_SDATA);
/* take the codec out of the shut down */ - error |= max98095_update_bits(M98095_097_PWR_SYS, M98095_SHDNRUN, - M98095_SHDNRUN); - /* route DACL and DACR output to HO and Spekers */ - error |= max98095_i2c_write(M98095_050_MIX_SPK_LEFT, 0x01); /* DACL */ - error |= max98095_i2c_write(M98095_051_MIX_SPK_RIGHT, 0x01);/* DACR */ - error |= max98095_i2c_write(M98095_04C_MIX_HP_LEFT, 0x01); /* DACL */ - error |= max98095_i2c_write(M98095_04D_MIX_HP_RIGHT, 0x01); /* DACR */ + error |= max98095_bic_or(priv, M98095_097_PWR_SYS, M98095_SHDNRUN, + M98095_SHDNRUN); + /* + * route DACL and DACR output to HO and Speakers + * Ordering: DACL, DACR, DACL, DACR + */ + error |= max98095_i2c_write(priv, M98095_050_MIX_SPK_LEFT, 0x01); + error |= max98095_i2c_write(priv, M98095_051_MIX_SPK_RIGHT, 0x01); + error |= max98095_i2c_write(priv, M98095_04C_MIX_HP_LEFT, 0x01); + error |= max98095_i2c_write(priv, M98095_04D_MIX_HP_RIGHT, 0x01);
/* power Enable */ - error |= max98095_i2c_write(M98095_091_PWR_EN_OUT, 0xF3); + error |= max98095_i2c_write(priv, M98095_091_PWR_EN_OUT, 0xF3);
/* set Volume */ - error |= max98095_i2c_write(M98095_064_LVL_HP_L, 15); - error |= max98095_i2c_write(M98095_065_LVL_HP_R, 15); - error |= max98095_i2c_write(M98095_067_LVL_SPK_L, 16); - error |= max98095_i2c_write(M98095_068_LVL_SPK_R, 16); + error |= max98095_i2c_write(priv, M98095_064_LVL_HP_L, 15); + error |= max98095_i2c_write(priv, M98095_065_LVL_HP_R, 15); + error |= max98095_i2c_write(priv, M98095_067_LVL_SPK_L, 16); + error |= max98095_i2c_write(priv, M98095_068_LVL_SPK_R, 16);
/* Enable DAIs */ - error |= max98095_i2c_write(M98095_093_BIAS_CTRL, 0x30); + error |= max98095_i2c_write(priv, M98095_093_BIAS_CTRL, 0x30); if (aif_id == AIF1) - error |= max98095_i2c_write(M98095_096_PWR_DAC_CK, 0x01); + error |= max98095_i2c_write(priv, M98095_096_PWR_DAC_CK, 0x01); else - error |= max98095_i2c_write(M98095_096_PWR_DAC_CK, 0x07); + error |= max98095_i2c_write(priv, M98095_096_PWR_DAC_CK, 0x07);
err_access: if (error < 0)
With driver model we cannot pass in the global struct, but instead want to pass in the driver-private data. Split some of the code out of wm8994_init() to handle this.
drivers/sound/wm8994.c | 56 +++++++++++++++++++++++++----------------- 1 file changed, 33 insertions(+), 23 deletions(-)
diff --git a/drivers/sound/wm8994.c b/drivers/sound/wm8994.c index 3f56af9db4b..f83fcf9f430 100644 --- a/drivers/sound/wm8994.c +++ b/drivers/sound/wm8994.c @@ -867,44 +867,54 @@ static int get_codec_values(struct sound_codec_info *pcodec_info, return 0; }
-/* WM8994 Device Initialisation */ -int wm8994_init(const void *blob, enum en_audio_interface aif_id, - int sampling_rate, int mclk_freq, int bits_per_sample, - unsigned int channels) +static int _wm8994_init(struct wm8994_priv *priv, + enum en_audio_interface aif_id, int sampling_rate, + int mclk_freq, int bits_per_sample, + unsigned int channels) { - int ret = 0; - struct sound_codec_info *pcodec_info = &g_codec_info; - - /* Get the codec Values */ - if (get_codec_values(pcodec_info, blob) < 0) { - debug("FDT Codec values failed\n"); - return -1; - } - - /* shift the device address by 1 for 7 bit addressing */ - g_wm8994_i2c_dev_addr = pcodec_info->i2c_dev_addr; - wm8994_i2c_init(pcodec_info->i2c_bus); + int ret;
- ret = wm8994_device_init(&g_wm8994_info, aif_id); + ret = wm8994_device_init(priv, aif_id); if (ret < 0) { debug("%s: wm8994 codec chip init failed\n", __func__); return ret; }
- ret = wm8994_set_sysclk(&g_wm8994_info, aif_id, WM8994_SYSCLK_MCLK1, - mclk_freq); + ret = wm8994_set_sysclk(priv, aif_id, WM8994_SYSCLK_MCLK1, mclk_freq); if (ret < 0) { debug("%s: wm8994 codec set sys clock failed\n", __func__); return ret; }
- ret = wm8994_hw_params(&g_wm8994_info, aif_id, sampling_rate, - bits_per_sample, channels); + ret = wm8994_hw_params(priv, aif_id, sampling_rate, bits_per_sample, + channels);
if (ret == 0) { - ret = wm8994_set_fmt(&g_wm8994_info, aif_id, - SND_SOC_DAIFMT_I2S | SND_SOC_DAIFMT_NB_NF | + ret = wm8994_set_fmt(priv, aif_id, SND_SOC_DAIFMT_I2S | + SND_SOC_DAIFMT_NB_NF | SND_SOC_DAIFMT_CBS_CFS); } + return ret; } + +/* WM8994 Device Initialisation */ +int wm8994_init(const void *blob, enum en_audio_interface aif_id, + int sampling_rate, int mclk_freq, int bits_per_sample, + unsigned int channels) +{ + struct sound_codec_info *pcodec_info = &g_codec_info; + + /* Get the codec Values */ + if (get_codec_values(pcodec_info, blob) < 0) { + debug("FDT Codec values failed\n"); + return -1; + } + + /* shift the device address by 1 for 7 bit addressing */ + g_wm8994_i2c_dev_addr = pcodec_info->i2c_dev_addr; + wm8994_i2c_init(pcodec_info->i2c_bus); + + return _wm8994_init(&g_wm8994_info, aif_id, sampling_rate, mclk_freq, + bits_per_sample, channels); +}
With driver model we want to do a minimal probe when the device is probed and then set up the codec interface later when a sound is actully played.
Split this setup code out into its own function to help with this.
drivers/sound/wm8994.c | 34 +++++++++++++++++++++++----------- 1 file changed, 23 insertions(+), 11 deletions(-)
diff --git a/drivers/sound/wm8994.c b/drivers/sound/wm8994.c index f83fcf9f430..20a48231ebd 100644 --- a/drivers/sound/wm8994.c +++ b/drivers/sound/wm8994.c @@ -659,8 +659,7 @@ static int wm8994_init_volume_aif1_dac1(struct wm8994_priv *priv) * * @returns -1 for error and 0 Success. */ -static int wm8994_device_init(struct wm8994_priv *priv, - enum en_audio_interface aif_id) +static int wm8994_device_init(struct wm8994_priv *priv) { const char *devname; unsigned short reg_data; @@ -671,7 +670,7 @@ static int wm8994_device_init(struct wm8994_priv *priv, ret = wm8994_i2c_read(priv, WM8994_SOFTWARE_RESET, ®_data); if (ret < 0) { debug("Failed to read ID register\n"); - goto err; + return ret; }
if (reg_data == WM8994_ID) { @@ -680,21 +679,28 @@ static int wm8994_device_init(struct wm8994_priv *priv, priv->type = WM8994; } else { debug("Device is not a WM8994, ID is %x\n", ret); - ret = -1; - goto err; + return -ENXIO; }
ret = wm8994_i2c_read(priv, WM8994_CHIP_REVISION, ®_data); if (ret < 0) { debug("Failed to read revision register: %d\n", ret); - goto err; + return ret; } priv->revision = reg_data; debug("%s revision %c\n", devname, 'A' + priv->revision);
+ return 0; +} + +static int wm8994_setup_interface(struct wm8994_priv *priv, + enum en_audio_interface aif_id) +{ + int ret; + /* VMID Selection */ - ret |= wm8994_bic_or(priv, WM8994_POWER_MANAGEMENT_1, - WM8994_VMID_SEL_MASK | WM8994_BIAS_ENA_MASK, 0x3); + ret = wm8994_bic_or(priv, WM8994_POWER_MANAGEMENT_1, + WM8994_VMID_SEL_MASK | WM8994_BIAS_ENA_MASK, 0x3);
/* Charge Pump Enable */ ret |= wm8994_bic_or(priv, WM8994_CHARGE_PUMP_1, WM8994_CP_ENA_MASK, @@ -807,10 +813,10 @@ static int wm8994_device_init(struct wm8994_priv *priv, if (ret < 0) goto err;
- debug("%s: Codec chip init ok\n", __func__); + debug("%s: Codec chip setup ok\n", __func__); return 0; err: - debug("%s: Codec chip init error\n", __func__); + debug("%s: Codec chip setup error\n", __func__); return -1; }
@@ -874,7 +880,7 @@ static int _wm8994_init(struct wm8994_priv *priv, { int ret;
- ret = wm8994_device_init(priv, aif_id); + ret = wm8994_setup_interface(priv, aif_id); if (ret < 0) { debug("%s: wm8994 codec chip init failed\n", __func__); return ret; @@ -904,6 +910,7 @@ int wm8994_init(const void *blob, enum en_audio_interface aif_id, unsigned int channels) { struct sound_codec_info *pcodec_info = &g_codec_info; + int ret;
/* Get the codec Values */ if (get_codec_values(pcodec_info, blob) < 0) { @@ -914,6 +921,11 @@ int wm8994_init(const void *blob, enum en_audio_interface aif_id, /* shift the device address by 1 for 7 bit addressing */ g_wm8994_i2c_dev_addr = pcodec_info->i2c_dev_addr; wm8994_i2c_init(pcodec_info->i2c_bus); + ret = wm8994_device_init(&g_wm8994_info); + if (ret < 0) { + debug("%s: wm8994 codec chip init failed\n", __func__); + return ret; + }
return _wm8994_init(&g_wm8994_info, aif_id, sampling_rate, mclk_freq, bits_per_sample, channels);
drivers/sound/max98095.c | 36 ++++++++++++++++++++++++------------ 1 file changed, 24 insertions(+), 12 deletions(-)
diff --git a/drivers/sound/max98095.c b/drivers/sound/max98095.c index 6edf3736d79..51556c07f5e 100644 --- a/drivers/sound/max98095.c +++ b/drivers/sound/max98095.c @@ -384,12 +384,14 @@ static int max98095_reset(struct max98095_priv *priv) * * @returns -1 for error and 0 Success. */ -static int max98095_device_init(struct max98095_priv *priv, - enum en_max_audio_interface aif_id) +static int max98095_device_init(struct max98095_priv *priv) { unsigned char id; int error = 0;
+ /* Enable codec clock */ + set_xclkout(); + /* reset the codec, the DSP core, and disable all interrupts */ error = max98095_reset(priv); if (error != 0) { @@ -406,11 +408,19 @@ static int max98095_device_init(struct max98095_priv *priv, if (error < 0) { debug("%s: Failure reading hardware revision: %d\n", __func__, id); - goto err_access; + return error; } debug("%s: Hardware revision: %c\n", __func__, (id - 0x40) + 'A');
- error |= max98095_i2c_write(priv, M98095_097_PWR_SYS, M98095_PWRSV); + return 0; +} + +static int max98095_setup_interface(struct max98095_priv *priv, + enum en_max_audio_interface aif_id) +{ + int error; + + error = max98095_i2c_write(priv, M98095_097_PWR_SYS, M98095_PWRSV);
/* * initialize registers to hardware default configuring audio @@ -463,7 +473,6 @@ static int max98095_device_init(struct max98095_priv *priv, else error |= max98095_i2c_write(priv, M98095_096_PWR_DAC_CK, 0x07);
-err_access: if (error < 0) return -1;
@@ -477,13 +486,7 @@ static int max98095_do_init(struct sound_codec_info *pcodec_info, { int ret = 0;
- /* Enable codec clock */ - set_xclkout(); - - /* shift the device address by 1 for 7 bit addressing */ - g_max98095_i2c_dev_addr = pcodec_info->i2c_dev_addr >> 1; - - ret = max98095_device_init(&g_max98095_info, aif_id); + ret = max98095_setup_interface(&g_max98095_info, aif_id); if (ret < 0) { debug("%s: max98095 codec chip init failed\n", __func__); return ret; @@ -569,6 +572,15 @@ int max98095_init(const void *blob, enum en_max_audio_interface aif_id, }
i2c_set_bus_num(pcodec_info->i2c_bus); + + /* shift the device address by 1 for 7 bit addressing */ + g_max98095_i2c_dev_addr = pcodec_info->i2c_dev_addr >> 1; + ret = max98095_device_init(&g_max98095_info); + if (ret < 0) { + debug("%s: max98095 codec chip init failed\n", __func__); + return ret; + } + ret = max98095_do_init(pcodec_info, aif_id, sampling_rate, mclk_freq, bits_per_sample); i2c_set_bus_num(old_bus);
We can put this in the private structure and avoid a global.
drivers/sound/wm8994.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/sound/wm8994.c b/drivers/sound/wm8994.c index 20a48231ebd..a79f46bcc3a 100644 --- a/drivers/sound/wm8994.c +++ b/drivers/sound/wm8994.c @@ -38,6 +38,7 @@ struct wm8994_priv { int mclk[WM8994_MAX_AIF]; /* master clock frequency in Hz */ int aifclk[WM8994_MAX_AIF]; /* audio interface clock in Hz */ struct wm8994_fll_config fll[2]; /* fll config to configure fll */ + int i2c_addr; };
/* wm 8994 supported sampling rate values */ @@ -61,7 +62,6 @@ static int bclk_divs[] = { };
static struct wm8994_priv g_wm8994_info; -static unsigned char g_wm8994_i2c_dev_addr; static struct sound_codec_info g_codec_info;
/* @@ -92,7 +92,7 @@ static int wm8994_i2c_write(struct wm8994_priv *priv, unsigned int reg, val[1] = (unsigned char)(data & 0xff); debug("Write Addr : 0x%04X, Data : 0x%04X\n", reg, data);
- return i2c_write(g_wm8994_i2c_dev_addr, reg, 2, val, 2); + return i2c_write(priv->i2c_addr, reg, 2, val, 2); }
/* @@ -110,7 +110,7 @@ static unsigned int wm8994_i2c_read(struct wm8994_priv *priv, unsigned int reg, unsigned char val[2]; int ret;
- ret = i2c_read(g_wm8994_i2c_dev_addr, reg, 2, val, 2); + ret = i2c_read(priv->i2c_addr, reg, 2, val, 2); if (ret != 0) { debug("%s: Error while reading register %#04x\n", __func__, reg); @@ -919,7 +919,7 @@ int wm8994_init(const void *blob, enum en_audio_interface aif_id, }
/* shift the device address by 1 for 7 bit addressing */ - g_wm8994_i2c_dev_addr = pcodec_info->i2c_dev_addr; + g_wm8994_info.i2c_addr = pcodec_info->i2c_dev_addr; wm8994_i2c_init(pcodec_info->i2c_bus); ret = wm8994_device_init(&g_wm8994_info); if (ret < 0) {
drivers/sound/max98095.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/sound/max98095.c b/drivers/sound/max98095.c index 51556c07f5e..2ec67bf24a8 100644 --- a/drivers/sound/max98095.c +++ b/drivers/sound/max98095.c @@ -28,11 +28,11 @@ struct max98095_priv { unsigned int sysclk; unsigned int rate; unsigned int fmt; + int i2c_addr; };
static struct sound_codec_info g_codec_info; struct max98095_priv g_max98095_info; -unsigned int g_max98095_i2c_dev_addr;
/* Index 0 is reserved. */ int rate_table[] = {0, 8000, 11025, 16000, 22050, 24000, 32000, 44100, 48000, @@ -52,7 +52,7 @@ static int max98095_i2c_write(struct max98095_priv *priv, unsigned int reg, { debug("%s: Write Addr : 0x%02X, Data : 0x%02X\n", __func__, reg, data); - return i2c_write(g_max98095_i2c_dev_addr, reg, 1, &data, 1); + return i2c_write(priv->i2c_addr, reg, 1, &data, 1); }
/* @@ -69,7 +69,7 @@ static unsigned int max98095_i2c_read(struct max98095_priv *priv, { int ret;
- ret = i2c_read(g_max98095_i2c_dev_addr, reg, 1, data, 1); + ret = i2c_read(priv->i2c_addr, reg, 1, data, 1); if (ret != 0) { debug("%s: Error while reading register %#04x\n", __func__, reg); @@ -574,7 +574,7 @@ int max98095_init(const void *blob, enum en_max_audio_interface aif_id, i2c_set_bus_num(pcodec_info->i2c_bus);
/* shift the device address by 1 for 7 bit addressing */ - g_max98095_i2c_dev_addr = pcodec_info->i2c_dev_addr >> 1; + g_max98095_info.i2c_addr = pcodec_info->i2c_dev_addr >> 1; ret = max98095_device_init(&g_max98095_info); if (ret < 0) { debug("%s: max98095 codec chip init failed\n", __func__);
These are only used in two functions so can be made local.
drivers/sound/wm8994.c | 16 +++++++--------- 1 file changed, 7 insertions(+), 9 deletions(-)
diff --git a/drivers/sound/wm8994.c b/drivers/sound/wm8994.c index a79f46bcc3a..be27e2b1e7e 100644 --- a/drivers/sound/wm8994.c +++ b/drivers/sound/wm8994.c @@ -61,9 +61,6 @@ static int bclk_divs[] = { 640, 880, 960, 1280, 1760, 1920 };
-static struct wm8994_priv g_wm8994_info; -static struct sound_codec_info g_codec_info; - /* * Initialise I2C for wm 8994 * @@ -909,24 +906,25 @@ int wm8994_init(const void *blob, enum en_audio_interface aif_id, int sampling_rate, int mclk_freq, int bits_per_sample, unsigned int channels) { - struct sound_codec_info *pcodec_info = &g_codec_info; + struct sound_codec_info pcodec_info; + struct wm8994_priv wm8994_info; int ret;
/* Get the codec Values */ - if (get_codec_values(pcodec_info, blob) < 0) { + if (get_codec_values(&pcodec_info, blob) < 0) { debug("FDT Codec values failed\n"); return -1; }
/* shift the device address by 1 for 7 bit addressing */ - g_wm8994_info.i2c_addr = pcodec_info->i2c_dev_addr; - wm8994_i2c_init(pcodec_info->i2c_bus); - ret = wm8994_device_init(&g_wm8994_info); + wm8994_info.i2c_addr = pcodec_info.i2c_dev_addr; + wm8994_i2c_init(pcodec_info.i2c_bus); + ret = wm8994_device_init(&wm8994_info); if (ret < 0) { debug("%s: wm8994 codec chip init failed\n", __func__); return ret; }
- return _wm8994_init(&g_wm8994_info, aif_id, sampling_rate, mclk_freq, + return _wm8994_init(&wm8994_info, aif_id, sampling_rate, mclk_freq, bits_per_sample, channels); }
Also change the first argument of max98095_do_init() to suit.
drivers/sound/max98095.c | 27 ++++++++++++--------------- 1 file changed, 12 insertions(+), 15 deletions(-)
diff --git a/drivers/sound/max98095.c b/drivers/sound/max98095.c index 2ec67bf24a8..d7313f9ad75 100644 --- a/drivers/sound/max98095.c +++ b/drivers/sound/max98095.c @@ -31,9 +31,6 @@ struct max98095_priv { int i2c_addr; };
-static struct sound_codec_info g_codec_info; -struct max98095_priv g_max98095_info; - /* Index 0 is reserved. */ int rate_table[] = {0, 8000, 11025, 16000, 22050, 24000, 32000, 44100, 48000, 88200, 96000}; @@ -479,31 +476,30 @@ static int max98095_setup_interface(struct max98095_priv *priv, return 0; }
-static int max98095_do_init(struct sound_codec_info *pcodec_info, +static int max98095_do_init(struct max98095_priv *priv, enum en_max_audio_interface aif_id, int sampling_rate, int mclk_freq, int bits_per_sample) { int ret = 0;
- ret = max98095_setup_interface(&g_max98095_info, aif_id); + ret = max98095_setup_interface(priv, aif_id); if (ret < 0) { debug("%s: max98095 codec chip init failed\n", __func__); return ret; }
- ret = max98095_set_sysclk(&g_max98095_info, mclk_freq); + ret = max98095_set_sysclk(priv, mclk_freq); if (ret < 0) { debug("%s: max98095 codec set sys clock failed\n", __func__); return ret; }
- ret = max98095_hw_params(&g_max98095_info, aif_id, sampling_rate, + ret = max98095_hw_params(priv, aif_id, sampling_rate, bits_per_sample);
if (ret == 0) { - ret = max98095_set_fmt(&g_max98095_info, - SND_SOC_DAIFMT_I2S | + ret = max98095_set_fmt(priv, SND_SOC_DAIFMT_I2S | SND_SOC_DAIFMT_NB_NF | SND_SOC_DAIFMT_CBS_CFS, aif_id); @@ -564,24 +560,25 @@ int max98095_init(const void *blob, enum en_max_audio_interface aif_id, { int ret; int old_bus = i2c_get_bus_num(); - struct sound_codec_info *pcodec_info = &g_codec_info; + struct sound_codec_info pcodec_info; + struct max98095_priv max98095_info;
- if (get_max98095_codec_values(pcodec_info, blob) < 0) { + if (get_max98095_codec_values(&pcodec_info, blob) < 0) { debug("FDT Codec values failed\n"); return -1; }
- i2c_set_bus_num(pcodec_info->i2c_bus); + i2c_set_bus_num(pcodec_info.i2c_bus);
/* shift the device address by 1 for 7 bit addressing */ - g_max98095_info.i2c_addr = pcodec_info->i2c_dev_addr >> 1; - ret = max98095_device_init(&g_max98095_info); + max98095_info.i2c_addr = pcodec_info.i2c_dev_addr >> 1; + ret = max98095_device_init(&max98095_info); if (ret < 0) { debug("%s: max98095 codec chip init failed\n", __func__); return ret; }
- ret = max98095_do_init(pcodec_info, aif_id, sampling_rate, mclk_freq, + ret = max98095_do_init(&max98095_info, aif_id, sampling_rate, mclk_freq, bits_per_sample); i2c_set_bus_num(old_bus);
Applied to u-boot-dm/master
This function has only one line in it. Drop it.
drivers/sound/wm8994.c | 12 +----------- 1 file changed, 1 insertion(+), 11 deletions(-)
diff --git a/drivers/sound/wm8994.c b/drivers/sound/wm8994.c index be27e2b1e7e..a888a0b4c95 100644 --- a/drivers/sound/wm8994.c +++ b/drivers/sound/wm8994.c @@ -61,16 +61,6 @@ static int bclk_divs[] = { 640, 880, 960, 1280, 1760, 1920 };
-/* - * Initialise I2C for wm 8994 - * - * @param bus no i2c bus number in which wm8994 is connected - */ -static void wm8994_i2c_init(int bus_no) -{ - i2c_set_bus_num(bus_no); -} - /* * Writes value to a device register through i2c * @@ -918,7 +908,7 @@ int wm8994_init(const void *blob, enum en_audio_interface aif_id,
/* shift the device address by 1 for 7 bit addressing */ wm8994_info.i2c_addr = pcodec_info.i2c_dev_addr; - wm8994_i2c_init(pcodec_info.i2c_bus); + i2c_set_bus_num(pcodec_info.i2c_bus); ret = wm8994_device_init(&wm8994_info); if (ret < 0) { debug("%s: wm8994 codec chip init failed\n", __func__);
Tidy up the ordering of header files in the sounds files.
drivers/sound/max98095.c | 11 +++++------ drivers/sound/samsung-i2s.c | 36 ++++++++++++++++++------------------ drivers/sound/wm8994.c | 8 ++++---- 3 files changed, 27 insertions(+), 28 deletions(-)
diff --git a/drivers/sound/max98095.c b/drivers/sound/max98095.c index d7313f9ad75..6a98dac04bb 100644 --- a/drivers/sound/max98095.c +++ b/drivers/sound/max98095.c @@ -10,17 +10,16 @@ * published by the Free Software Foundation. */
-#include <common.h> -#include <asm/arch/clk.h> -#include <asm/arch/cpu.h> -#include <asm/arch/power.h> -#include <asm/gpio.h> -#include <asm/io.h> #include <common.h> #include <div64.h> #include <fdtdec.h> #include <i2c.h> #include <sound.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <asm/arch/clk.h> +#include <asm/arch/cpu.h> +#include <asm/arch/power.h> #include "i2s.h" #include "max98095.h"
diff --git a/drivers/sound/samsung-i2s.c b/drivers/sound/samsung-i2s.c index 7f4388137a5..c07d3cdb4c8 100644 --- a/drivers/sound/samsung-i2s.c +++ b/drivers/sound/samsung-i2s.c @@ -4,13 +4,13 @@ * R. Chandrasekar rcsekar@samsung.com */
+#include <common.h> +#include <i2s.h> +#include <sound.h> #include <asm/arch/clk.h> #include <asm/arch/pinmux.h> #include <asm/arch/i2s-regs.h> #include <asm/io.h> -#include <common.h> -#include <sound.h> -#include <i2s.h>
#define FIC_TX2COUNT(x) (((x) >> 24) & 0xf) #define FIC_TX1COUNT(x) (((x) >> 16) & 0xf) @@ -170,7 +170,7 @@ static int i2s_set_fmt(struct i2s_reg *i2s_reg, unsigned int fmt) default: debug("%s: Invalid format priority [0x%x]\n", __func__, (fmt & SND_SOC_DAIFMT_FORMAT_MASK)); - return -1; + return -ERANGE; }
/* @@ -189,7 +189,7 @@ static int i2s_set_fmt(struct i2s_reg *i2s_reg, unsigned int fmt) default: debug("%s: Invalid clock ploarity input [0x%x]\n", __func__, (fmt & SND_SOC_DAIFMT_INV_MASK)); - return -1; + return -ERANGE; }
switch (fmt & SND_SOC_DAIFMT_MASTER_MASK) { @@ -201,13 +201,13 @@ static int i2s_set_fmt(struct i2s_reg *i2s_reg, unsigned int fmt) ret = i2s_set_sysclk_dir(i2s_reg, SND_SOC_CLOCK_OUT); if (ret != 0) { debug("%s:set i2s clock direction failed\n", __func__); - return -1; + return ret; } break; default: debug("%s: Invalid master selection [0x%x]\n", __func__, (fmt & SND_SOC_DAIFMT_MASTER_MASK)); - return -1; + return -ERANGE; }
mod &= ~(MOD_SDF_MASK | MOD_LR_RLOW | MOD_SLAVE); @@ -248,7 +248,7 @@ static int i2s_set_samplesize(struct i2s_reg *i2s_reg, unsigned int blc) default: debug("%s: Invalid sample size input [0x%x]\n", __func__, blc); - return -1; + return -ERANGE; } writel(mod, &i2s_reg->mod);
@@ -265,7 +265,7 @@ int i2s_transfer_tx_data(struct samsung_i2s_priv *pi2s_tx, unsigned int *data,
if (data_size < FIFO_LENGTH) { debug("%s : Invalid data size\n", __func__); - return -1; /* invalid pcm data size */ + return -ENODATA; /* invalid pcm data size */ }
/* fill the tx buffer before stating the tx transmit */ @@ -284,7 +284,7 @@ int i2s_transfer_tx_data(struct samsung_i2s_priv *pi2s_tx, unsigned int *data, if (get_timer(start) > TIMEOUT_I2S_TX) { i2s_txctrl(i2s_reg, I2S_TX_OFF); debug("%s: I2S Transfer Timeout\n", __func__); - return -1; + return -ETIMEDOUT; } } } @@ -312,20 +312,20 @@ int i2s_tx_init(struct samsung_i2s_priv *pi2s_tx) ret = set_epll_clk(pi2s_tx->audio_pll_clk); } else { debug("%s: unsupported i2s-%d bus\n", __func__, pi2s_tx->id); - return -1; + return -ERANGE; }
- if (ret != 0) { + if (ret) { debug("%s: epll clock set rate failed\n", __func__); - return -1; + return ret; }
/* Select Clk Source for Audio 0 or 1 */ ret = set_i2s_clk_source(pi2s_tx->id); - if (ret == -1) { + if (ret) { debug("%s: unsupported clock for i2s-%d\n", __func__, pi2s_tx->id); - return -1; + return ret; }
if (pi2s_tx->id == 0) { @@ -341,10 +341,10 @@ int i2s_tx_init(struct samsung_i2s_priv *pi2s_tx) (pi2s_tx->samplingrate * (pi2s_tx->rfs)), pi2s_tx->id); } - if (ret == -1) { + if (ret) { debug("%s: unsupported prescalar for i2s-%d\n", __func__, pi2s_tx->id); - return -1; + return ret; }
/* Configure I2s format */ @@ -355,7 +355,7 @@ int i2s_tx_init(struct samsung_i2s_priv *pi2s_tx) ret = i2s_set_samplesize(i2s_reg, pi2s_tx->bitspersample); if (ret != 0) { debug("%s:set sample rate failed\n", __func__); - return -1; + return ret; }
i2s_set_bitclk_framesize(i2s_reg, pi2s_tx->bfs); diff --git a/drivers/sound/wm8994.c b/drivers/sound/wm8994.c index a888a0b4c95..1714f430f39 100644 --- a/drivers/sound/wm8994.c +++ b/drivers/sound/wm8994.c @@ -4,15 +4,15 @@ * R. Chandrasekar rcsekar@samsung.com */ #include <common.h> -#include <asm/arch/clk.h> -#include <asm/arch/cpu.h> -#include <asm/gpio.h> -#include <asm/io.h> #include <div64.h> #include <fdtdec.h> #include <i2c.h> #include <i2s.h> #include <sound.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <asm/arch/clk.h> +#include <asm/arch/cpu.h> #include <asm/arch/sound.h> #include "wm8994.h" #include "wm8994_registers.h"
The codec is at address 0x11 on the i2c bus, in 7-bit format. The device tree and code are in 8-bit format (i.e. shifted left one bit). Fix both.
arch/arm/dts/exynos5250-snow.dts | 4 ++-- drivers/sound/max98095.c | 3 +-- 2 files changed, 3 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/exynos5250-snow.dts b/arch/arm/dts/exynos5250-snow.dts index e99f6e72bf6..cb5067b9669 100644 --- a/arch/arm/dts/exynos5250-snow.dts +++ b/arch/arm/dts/exynos5250-snow.dts @@ -214,8 +214,8 @@ }; };
- soundcodec@22 { - reg = <0x22>; + soundcodec@11 { + reg = <0x11>; compatible = "maxim,max98095-codec"; }; }; diff --git a/drivers/sound/max98095.c b/drivers/sound/max98095.c index 6a98dac04bb..7a3dbd09840 100644 --- a/drivers/sound/max98095.c +++ b/drivers/sound/max98095.c @@ -569,8 +569,7 @@ int max98095_init(const void *blob, enum en_max_audio_interface aif_id,
- /* shift the device address by 1 for 7 bit addressing */ - max98095_info.i2c_addr = pcodec_info.i2c_dev_addr >> 1; + max98095_info.i2c_addr = pcodec_info.i2c_dev_addr; ret = max98095_device_init(&max98095_info); if (ret < 0) { debug("%s: max98095 codec chip init failed\n", __func__);
The U-Boot sound system provides basic support for beeping. At present it does not use driver model, but it needs to be converted. Add an option to enable driver model for sound. For now it is not connected to anything. Future work will add drivers which use this option. It will then be removed once everything is converted.
configs/sandbox_defconfig | 1 + drivers/sound/Kconfig | 6 ++++++ 2 files changed, 7 insertions(+)
diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 4d65a01dc5b..ad7b25c5f35 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -176,6 +176,7 @@ CONFIG_SANDBOX_SERIAL=y CONFIG_SMEM=y CONFIG_SANDBOX_SMEM=y CONFIG_SOUND=y +CONFIG_DM_SOUND=y CONFIG_SOUND_SANDBOX=y CONFIG_SANDBOX_SPI=y CONFIG_SPMI=y diff --git a/drivers/sound/Kconfig b/drivers/sound/Kconfig index 5de86c05c60..93f6c36af32 100644 --- a/drivers/sound/Kconfig +++ b/drivers/sound/Kconfig @@ -12,6 +12,12 @@ config SOUND audio codecs are called from the sound-i2s code. This could be converted to driver model.
+config DM_SOUND + bool "Use driver model for sound" + help + Enable this option to use driver model for sound devices. This is a + migration option and will be removed. + config I2S bool "Enable I2S support" depends on SOUND
This structure contains information that is likely needed by any i2s driver so it seems useful to attach it to the (forthcoming) i2c uclass. For now, just rename it.
drivers/sound/samsung-i2s.c | 4 ++-- drivers/sound/sound-i2s.c | 10 +++++----- include/i2s.h | 6 +++--- 3 files changed, 10 insertions(+), 10 deletions(-)
diff --git a/drivers/sound/samsung-i2s.c b/drivers/sound/samsung-i2s.c index c07d3cdb4c8..5cd585808ab 100644 --- a/drivers/sound/samsung-i2s.c +++ b/drivers/sound/samsung-i2s.c @@ -255,7 +255,7 @@ static int i2s_set_samplesize(struct i2s_reg *i2s_reg, unsigned int blc) return 0; }
-int i2s_transfer_tx_data(struct samsung_i2s_priv *pi2s_tx, unsigned int *data, +int i2s_transfer_tx_data(struct i2s_uc_priv *pi2s_tx, unsigned int *data, unsigned long data_size) { int i; @@ -293,7 +293,7 @@ int i2s_transfer_tx_data(struct samsung_i2s_priv *pi2s_tx, unsigned int *data, return 0; }
-int i2s_tx_init(struct samsung_i2s_priv *pi2s_tx) +int i2s_tx_init(struct i2s_uc_priv *pi2s_tx) { int ret; struct i2s_reg *i2s_reg = diff --git a/drivers/sound/sound-i2s.c b/drivers/sound/sound-i2s.c index 106842a23db..ed130750b2e 100644 --- a/drivers/sound/sound-i2s.c +++ b/drivers/sound/sound-i2s.c @@ -20,15 +20,15 @@ #define SOUND_400_HZ 400 #define SOUND_BITS_IN_BYTE 8
-static struct samsung_i2s_priv g_i2stx_pri; +static struct i2s_uc_priv g_i2stx_pri;
/* * get_sound_i2s_values gets values for i2s parameters * - * @param samsung_i2s_priv i2s transmitter transfer param structure + * @param i2s_uc_priv i2s transmitter transfer param structure * @param blob FDT blob if enabled else NULL */ -static int get_sound_i2s_values(struct samsung_i2s_priv *i2s, const void *blob) +static int get_sound_i2s_values(struct i2s_uc_priv *i2s, const void *blob) { int node; int error = 0; @@ -97,7 +97,7 @@ static int get_sound_i2s_values(struct samsung_i2s_priv *i2s, const void *blob) * @param pi2s_tx i2s parameters required by codec * @return int value, 0 for success */ -static int codec_init(const void *blob, struct samsung_i2s_priv *pi2s_tx) +static int codec_init(const void *blob, struct i2s_uc_priv *pi2s_tx) { int ret; const char *codectype; @@ -145,7 +145,7 @@ static int codec_init(const void *blob, struct samsung_i2s_priv *pi2s_tx) int sound_init(const void *blob) { int ret; - struct samsung_i2s_priv *pi2s_tx = &g_i2stx_pri; + struct i2s_uc_priv *pi2s_tx = &g_i2stx_pri;
/* Get the I2S Values */ if (get_sound_i2s_values(pi2s_tx, blob) < 0) { diff --git a/include/i2s.h b/include/i2s.h index 800473abd9c..f23862ca040 100644 --- a/include/i2s.h +++ b/include/i2s.h @@ -76,7 +76,7 @@ struct i2s_reg { };
/* This structure stores the i2s related information */ -struct samsung_i2s_priv { +struct i2s_uc_priv { unsigned int rfs; /* LR clock frame size */ unsigned int bfs; /* Bit slock frame size */ unsigned int audio_pll_clk; /* Audio pll frequency in Hz */ @@ -96,7 +96,7 @@ struct samsung_i2s_priv { * * @return int value 0 for success, -1 in case of error */ -int i2s_transfer_tx_data(struct samsung_i2s_priv *pi2s_tx, uint *data, +int i2s_transfer_tx_data(struct i2s_uc_priv *pi2s_tx, unsigned int *data, unsigned long data_size);
/* @@ -106,6 +106,6 @@ int i2s_transfer_tx_data(struct samsung_i2s_priv *pi2s_tx, uint *data, * * @return int value 0 for success, -1 in case of error */ -int i2s_tx_init(struct samsung_i2s_priv *pi2s_tx); +int i2s_tx_init(struct i2s_uc_priv *pi2s_tx);
#endif /* __I2S_H__ */
An audio codec provides a way to convert digital data to sound and vice versa. Add a simple uclass which just supports setting the parameters for the codec.
arch/sandbox/dts/test.dts | 7 ++++- arch/sandbox/include/asm/test.h | 10 ++++++ drivers/sound/Makefile | 1 + drivers/sound/codec-uclass.c | 26 ++++++++++++++++ drivers/sound/sandbox.c | 55 +++++++++++++++++++++++++++++++++ include/audio_codec.h | 48 ++++++++++++++++++++++++++++ include/dm/uclass-id.h | 1 + test/dm/Makefile | 1 + test/dm/audio.c | 34 ++++++++++++++++++++ 9 files changed, 182 insertions(+), 1 deletion(-) create mode 100644 drivers/sound/codec-uclass.c create mode 100644 include/audio_codec.h create mode 100644 test/dm/audio.c
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 252aa7b6b63..4e4eaa2dceb 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -42,7 +42,12 @@ osd0 = "/osd"; };
- cros_ec: cros-ec { + audio: audio-codec { + compatible = "sandbox,audio-codec"; + #sound-dai-cells = <1>; + }; + + cros_ec: cros-ec { reg = <0 0>; compatible = "google,cros-ec-sandbox";
diff --git a/arch/sandbox/include/asm/test.h b/arch/sandbox/include/asm/test.h index 5e818392959..f70e0d84177 100644 --- a/arch/sandbox/include/asm/test.h +++ b/arch/sandbox/include/asm/test.h @@ -121,4 +121,14 @@ int sandbox_pwm_get_config(struct udevice *dev, uint channel, uint *period_nsp, */ void sandbox_sf_set_block_protect(struct udevice *dev, int bp_mask);
+/** + * sandbox_get_codec_params() - Read back codec parameters + * + * This reads back the parameters set by audio_codec_set_params() for the + * sandbox audio driver. Arguments are as for that function. + */ +void sandbox_get_codec_params(struct udevice *dev, int *interfacep, int *ratep, + int *mclk_freqp, int *bits_per_samplep, + uint *channelsp); + #endif diff --git a/drivers/sound/Makefile b/drivers/sound/Makefile index 696c5aecbe9..ae5fabed846 100644 --- a/drivers/sound/Makefile +++ b/drivers/sound/Makefile @@ -4,6 +4,7 @@ # R. Chandrasekar rcsekar@samsung.com
obj-$(CONFIG_SOUND) += sound.o +obj-$(CONFIG_DM_SOUND) += codec-uclass.o obj-$(CONFIG_I2S) += sound-i2s.o obj-$(CONFIG_I2S_SAMSUNG) += samsung-i2s.o obj-$(CONFIG_SOUND_SANDBOX) += sandbox.o diff --git a/drivers/sound/codec-uclass.c b/drivers/sound/codec-uclass.c new file mode 100644 index 00000000000..1ec77acfc1c --- /dev/null +++ b/drivers/sound/codec-uclass.c @@ -0,0 +1,26 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 Google LLC + * Written by Simon Glass sjg@chromium.org + */ + +#include <common.h> +#include <dm.h> +#include <audio_codec.h> + +int audio_codec_set_params(struct udevice *dev, int interface, int rate, + int mclk_freq, int bits_per_sample, uint channels) +{ + struct audio_codec_ops *ops = audio_codec_get_ops(dev); + + if (!ops->set_params) + return -ENOSYS; + + return ops->set_params(dev, interface, rate, mclk_freq, bits_per_sample, + channels); +} + +UCLASS_DRIVER(audio_codec) = { + .id = UCLASS_AUDIO_CODEC, + .name = "audio-codec", +}; diff --git a/drivers/sound/sandbox.c b/drivers/sound/sandbox.c index 94eff542824..d24eb9ae9ce 100644 --- a/drivers/sound/sandbox.c +++ b/drivers/sound/sandbox.c @@ -4,9 +4,19 @@ */
#include <common.h> +#include <dm.h> +#include <audio_codec.h> #include <asm/sound.h> #include <asm/sdl.h>
+struct sandbox_codec_priv { + int interface; + int rate; + int mclk_freq; + int bits_per_sample; + uint channels; +}; + int sound_play(uint32_t msec, uint32_t frequency) { sandbox_sdl_sound_start(frequency); @@ -20,3 +30,48 @@ int sound_init(const void *blob) { return sandbox_sdl_sound_init(); } + +void sandbox_get_codec_params(struct udevice *dev, int *interfacep, int *ratep, + int *mclk_freqp, int *bits_per_samplep, + uint *channelsp) +{ + struct sandbox_codec_priv *priv = dev_get_priv(dev); + + *interfacep = priv->interface; + *ratep = priv->rate; + *mclk_freqp = priv->mclk_freq; + *bits_per_samplep = priv->bits_per_sample; + *channelsp = priv->channels; +} + +static int sandbox_codec_set_params(struct udevice *dev, int interface, + int rate, int mclk_freq, + int bits_per_sample, uint channels) +{ + struct sandbox_codec_priv *priv = dev_get_priv(dev); + + priv->interface = interface; + priv->rate = rate; + priv->mclk_freq = mclk_freq; + priv->bits_per_sample = bits_per_sample; + priv->channels = channels; + + return 0; +} + +static const struct audio_codec_ops sandbox_codec_ops = { + .set_params = sandbox_codec_set_params, +}; + +static const struct udevice_id sandbox_codec_ids[] = { + { .compatible = "sandbox,audio-codec" }, + { } +}; + +U_BOOT_DRIVER(sandbox_codec) = { + .name = "sandbox_codec", + .id = UCLASS_AUDIO_CODEC, + .of_match = sandbox_codec_ids, + .ops = &sandbox_codec_ops, + .priv_auto_alloc_size = sizeof(struct sandbox_codec_priv), +}; diff --git a/include/audio_codec.h b/include/audio_codec.h new file mode 100644 index 00000000000..25870995469 --- /dev/null +++ b/include/audio_codec.h @@ -0,0 +1,48 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2018 Google LLC + * Written by Simon Glass sjg@chromium.org + */ + +#ifndef __AUDIO_CODEC_H__ +#define __AUDIO_CODEC_H__ + +/* + * An audio codec turns digital data into sound with various parameters to + * control its operation. + */ + +/* Operations for sound */ +struct audio_codec_ops { + /** + * set_params() - Set audio codec parameters + * + * @dev: Sound device + * @inteface: Interface number to use on codec + * @rate: Sampling rate in Hz + * @mclk_freq: Codec clock frequency in Hz + * @bits_per_sample: Must be 16 or 24 + * @channels: Number of channels to use (1=mono, 2=stereo) + * @return 0 if OK, -ve on error + */ + int (*set_params)(struct udevice *dev, int interface, int rate, + int mclk_freq, int bits_per_sample, uint channels); +}; + +#define audio_codec_get_ops(dev) ((struct audio_codec_ops *)(dev)->driver->ops) + +/** + * audio_codec_set_params() - Set audio codec parameters + * + * @dev: Sound device + * @inteface: Interface number to use on codec + * @rate: Sampling rate in Hz + * @mclk_freq: Codec clock frequency in Hz + * @bits_per_sample: Must be 16 or 24 + * @channels: Number of channels to use (1=mono, 2=stereo) + * @return 0 if OK, -ve on error + */ +int audio_codec_set_params(struct udevice *dev, int interface, int rate, + int mclk_freq, int bits_per_sample, uint channels); + +#endif /* __AUDIO_CODEC_H__ */ diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index a5fcb69dbad..4c2051a4c6f 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -29,6 +29,7 @@ enum uclass_id { /* U-Boot uclasses start here - in alphabetical order */ UCLASS_ADC, /* Analog-to-digital converter */ UCLASS_AHCI, /* SATA disk controller */ + UCLASS_AUDIO_CODEC, /* Audio codec with control and data path */ UCLASS_BLK, /* Block device */ UCLASS_BOARD, /* Device information from hardware */ UCLASS_CLK, /* Clock source, e.g. used by peripherals */ diff --git a/test/dm/Makefile b/test/dm/Makefile index 213e0fda946..592d992a75a 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -13,6 +13,7 @@ obj-$(CONFIG_UT_DM) += test-uclass.o # subsystem you must add sandbox tests here. obj-$(CONFIG_UT_DM) += core.o ifneq ($(CONFIG_SANDBOX),) +obj-$(CONFIG_DM_SOUND) += audio.o obj-$(CONFIG_BLK) += blk.o obj-$(CONFIG_BOARD) += board.o obj-$(CONFIG_CLK) += clk.o diff --git a/test/dm/audio.c b/test/dm/audio.c new file mode 100644 index 00000000000..77c3a3625bd --- /dev/null +++ b/test/dm/audio.c @@ -0,0 +1,34 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 Google LLC + * Written by Simon Glass sjg@chromium.org + */ + +#include <common.h> +#include <audio_codec.h> +#include <dm.h> +#include <dm/test.h> +#include <test/ut.h> +#include <asm/test.h> + +/* Basic test of the audio codec uclass */ +static int dm_test_audio(struct unit_test_state *uts) +{ + int interface, rate, mclk_freq, bits_per_sample; + struct udevice *dev; + uint channels; + + /* check probe success */ + ut_assertok(uclass_first_device_err(UCLASS_AUDIO_CODEC, &dev)); + ut_assertok(audio_codec_set_params(dev, 1, 2, 3, 4, 5)); + sandbox_get_codec_params(dev, &interface, &rate, &mclk_freq, + &bits_per_sample, &channels); + ut_asserteq(1, interface); + ut_asserteq(2, rate); + ut_asserteq(3, mclk_freq); + ut_asserteq(4, bits_per_sample); + ut_asserteq(5, channels); + + return 0; +} +DM_TEST(dm_test_audio, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
The i2s bus is commonly used with audio codecs. It provides a way to stream digital data sychronously in both directions. U-Boot only supports audio output, so this uclass is very simple, with a single tx_data() method.
Add a uclass and a test for i2s.
arch/sandbox/dts/test.dts | 7 +++- arch/sandbox/include/asm/test.h | 10 ++++++ drivers/sound/Makefile | 1 + drivers/sound/i2s-uclass.c | 25 ++++++++++++++ drivers/sound/sandbox.c | 58 ++++++++++++++++++++++++++++++++- include/dm/uclass-id.h | 1 + include/i2s.h | 25 ++++++++++++++ test/dm/Makefile | 1 + test/dm/i2s.c | 32 ++++++++++++++++++ 9 files changed, 158 insertions(+), 2 deletions(-) create mode 100644 drivers/sound/i2s-uclass.c create mode 100644 test/dm/i2s.c
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 4e4eaa2dceb..01ab409b388 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -47,7 +47,7 @@ #sound-dai-cells = <1>; };
- cros_ec: cros-ec { + cros_ec: cros-ec { reg = <0 0>; compatible = "google,cros-ec-sandbox";
@@ -378,6 +378,11 @@ u-boot,dm-pre-reloc; };
+ i2s: i2s { + compatible = "sandbox,i2s"; + #sound-dai-cells = <1>; + }; + misc-test { compatible = "sandbox,misc_sandbox"; }; diff --git a/arch/sandbox/include/asm/test.h b/arch/sandbox/include/asm/test.h index f70e0d84177..71bd50bd5bc 100644 --- a/arch/sandbox/include/asm/test.h +++ b/arch/sandbox/include/asm/test.h @@ -131,4 +131,14 @@ void sandbox_get_codec_params(struct udevice *dev, int *interfacep, int *ratep, int *mclk_freqp, int *bits_per_samplep, uint *channelsp);
+/** + * sandbox_get_i2s_sum() - Read back the sum of the audio data so far + * + * This data is provided to the sandbox driver by the I2S tx_data() method. + * + * @dev: Device to check + * @return sum of audio data + */ +int sandbox_get_i2s_sum(struct udevice *dev); + #endif diff --git a/drivers/sound/Makefile b/drivers/sound/Makefile index ae5fabed846..4aced9d22b9 100644 --- a/drivers/sound/Makefile +++ b/drivers/sound/Makefile @@ -5,6 +5,7 @@
obj-$(CONFIG_SOUND) += sound.o obj-$(CONFIG_DM_SOUND) += codec-uclass.o +obj-$(CONFIG_DM_SOUND) += i2s-uclass.o obj-$(CONFIG_I2S) += sound-i2s.o obj-$(CONFIG_I2S_SAMSUNG) += samsung-i2s.o obj-$(CONFIG_SOUND_SANDBOX) += sandbox.o diff --git a/drivers/sound/i2s-uclass.c b/drivers/sound/i2s-uclass.c new file mode 100644 index 00000000000..e2b4b2322dd --- /dev/null +++ b/drivers/sound/i2s-uclass.c @@ -0,0 +1,25 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 Google LLC + * Written by Simon Glass sjg@chromium.org + */ + +#include <common.h> +#include <dm.h> +#include <i2s.h> + +int i2s_tx_data(struct udevice *dev, uint *data, uint data_size) +{ + struct i2s_ops *ops = i2s_get_ops(dev); + + if (!ops->tx_data) + return -ENOSYS; + + return ops->tx_data(dev, data, data_size); +} + +UCLASS_DRIVER(i2s) = { + .id = UCLASS_I2S, + .name = "i2s", + .per_device_auto_alloc_size = sizeof(struct i2s_uc_priv), +}; diff --git a/drivers/sound/sandbox.c b/drivers/sound/sandbox.c index d24eb9ae9ce..59931ec0a12 100644 --- a/drivers/sound/sandbox.c +++ b/drivers/sound/sandbox.c @@ -4,8 +4,9 @@ */
#include <common.h> -#include <dm.h> #include <audio_codec.h> +#include <dm.h> +#include <i2s.h> #include <asm/sound.h> #include <asm/sdl.h>
@@ -17,6 +18,10 @@ struct sandbox_codec_priv { uint channels; };
+struct sandbox_i2s_priv { + int sum; /* Use to sum the provided audio data */ +}; + int sound_play(uint32_t msec, uint32_t frequency) { sandbox_sdl_sound_start(frequency); @@ -44,6 +49,13 @@ void sandbox_get_codec_params(struct udevice *dev, int *interfacep, int *ratep, *channelsp = priv->channels; }
+int sandbox_get_i2s_sum(struct udevice *dev) +{ + struct sandbox_i2s_priv *priv = dev_get_priv(dev); + + return priv->sum; +} + static int sandbox_codec_set_params(struct udevice *dev, int interface, int rate, int mclk_freq, int bits_per_sample, uint channels) @@ -59,6 +71,32 @@ static int sandbox_codec_set_params(struct udevice *dev, int interface, return 0; }
+static int sandbox_i2s_tx_data(struct udevice *dev, u32 *data, uint data_size) +{ + struct sandbox_i2s_priv *priv = dev_get_priv(dev); + + while (data_size-- > 0) + priv->sum += *data++; + + return 0; +} + +static int sandbox_i2s_probe(struct udevice *dev) +{ + struct i2s_uc_priv *uc_priv = dev_get_uclass_priv(dev); + + /* Use hard-coded values here */ + uc_priv->rfs = 256; + uc_priv->bfs = 32; + uc_priv->audio_pll_clk = 192000000; + uc_priv->samplingrate = 48000; + uc_priv->bitspersample = 16; + uc_priv->channels = 2; + uc_priv->id = 1; + + return 0; +} + static const struct audio_codec_ops sandbox_codec_ops = { .set_params = sandbox_codec_set_params, }; @@ -75,3 +113,21 @@ U_BOOT_DRIVER(sandbox_codec) = { .ops = &sandbox_codec_ops, .priv_auto_alloc_size = sizeof(struct sandbox_codec_priv), }; + +static const struct i2s_ops sandbox_i2s_ops = { + .tx_data = sandbox_i2s_tx_data, +}; + +static const struct udevice_id sandbox_i2s_ids[] = { + { .compatible = "sandbox,i2s" }, + { } +}; + +U_BOOT_DRIVER(sandbox_i2s) = { + .name = "sandbox_i2s", + .id = UCLASS_I2S, + .of_match = sandbox_i2s_ids, + .ops = &sandbox_i2s_ops, + .probe = sandbox_i2s_probe, + .priv_auto_alloc_size = sizeof(struct sandbox_i2s_priv), +}; diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index 4c2051a4c6f..ffafe08a4fe 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -46,6 +46,7 @@ enum uclass_id { UCLASS_I2C_EEPROM, /* I2C EEPROM device */ UCLASS_I2C_GENERIC, /* Generic I2C device */ UCLASS_I2C_MUX, /* I2C multiplexer */ + UCLASS_I2S, /* I2S bus */ UCLASS_IDE, /* IDE device */ UCLASS_AXI, /* AXI bus */ UCLASS_IRQ, /* Interrupt controller */ diff --git a/include/i2s.h b/include/i2s.h index f23862ca040..4839f13458b 100644 --- a/include/i2s.h +++ b/include/i2s.h @@ -87,6 +87,31 @@ struct i2s_uc_priv { unsigned int id; /* I2S controller id */ };
+/* Operations for i2s devices */ +struct i2s_ops { + /** + * tx_data() - Transmit audio data + * + * @dev: I2C device + * @data: Data buffer to play + * @data_size: Size of data buffer in units of 32-bit words + * @return 0 if OK, -ve on error + */ + int (*tx_data)(struct udevice *dev, u32 *data, uint data_size); +}; + +#define i2s_get_ops(dev) ((struct i2s_ops *)(dev)->driver->ops) + +/** + * i2s_tx_data() - Transmit audio data + * + * @dev: I2C device + * @data: Data buffer to play + * @data_size: Size of data buffer in units of 32-bit words + * @return 0 if OK, -ve on error + */ +int i2s_tx_data(struct udevice *dev, u32 *data, uint data_size); + /* * Sends the given data through i2s tx * diff --git a/test/dm/Makefile b/test/dm/Makefile index 592d992a75a..07d6f97cb77 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -21,6 +21,7 @@ obj-$(CONFIG_DM_ETH) += eth.o obj-$(CONFIG_FIRMWARE) += firmware.o obj-$(CONFIG_DM_GPIO) += gpio.o obj-$(CONFIG_DM_I2C) += i2c.o +obj-$(CONFIG_DM_SOUND) += i2s.o obj-$(CONFIG_LED) += led.o obj-$(CONFIG_DM_MAILBOX) += mailbox.o obj-$(CONFIG_DM_MMC) += mmc.o diff --git a/test/dm/i2s.c b/test/dm/i2s.c new file mode 100644 index 00000000000..523bf89d08b --- /dev/null +++ b/test/dm/i2s.c @@ -0,0 +1,32 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 Google LLC + * Written by Simon Glass sjg@chromium.org + */ + +#include <common.h> +#include <dm.h> +#include <i2s.h> +#include <dm/test.h> +#include <test/ut.h> +#include <asm/test.h> + +/* Basic test of the i2s codec uclass */ +static int dm_test_i2s(struct unit_test_state *uts) +{ + struct udevice *dev; + u32 data[3]; + + /* check probe success */ + ut_assertok(uclass_first_device_err(UCLASS_I2S, &dev)); + data[0] = 1; + data[1] = 4; + data[2] = 6; + ut_assertok(i2s_tx_data(dev, data, ARRAY_SIZE(data))); + ut_asserteq(11, sandbox_get_i2s_sum(dev)); + ut_assertok(i2s_tx_data(dev, data, 1)); + ut_asserteq(12, sandbox_get_i2s_sum(dev)); + + return 0; +} +DM_TEST(dm_test_i2s, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
The sound drive pulls together the audio codec and i2s drivers in order to actually make sounds. It supports setup() and play() methods. The sound_find_codec_i2s() function allows locating the linked codec and i2s devices. They can be referred to from uclass-private data.
Add a uclass and a test for sound.
arch/sandbox/dts/test.dts | 11 +++ arch/sandbox/include/asm/test.h | 20 +++++ cmd/sound.c | 21 +++++- drivers/sound/Makefile | 1 + drivers/sound/sandbox.c | 65 ++++++++++++++++ drivers/sound/sound-uclass.c | 129 ++++++++++++++++++++++++++++++++ include/dm/uclass-id.h | 1 + include/sound.h | 66 ++++++++++++++++ test/dm/Makefile | 1 + test/dm/sound.c | 34 +++++++++ 10 files changed, 348 insertions(+), 1 deletion(-) create mode 100644 drivers/sound/sound-uclass.c create mode 100644 test/dm/sound.c
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 01ab409b388..dbbd0495e7c 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -536,6 +536,17 @@ compatible = "sandbox,smem"; };
+ sound { + compatible = "sandbox,sound"; + cpu { + sound-dai = <&i2s 0>; + }; + + codec { + sound-dai = <&audio 0>; + }; + }; + spi@0 { #address-cells = <1>; #size-cells = <0>; diff --git a/arch/sandbox/include/asm/test.h b/arch/sandbox/include/asm/test.h index 71bd50bd5bc..74f96188220 100644 --- a/arch/sandbox/include/asm/test.h +++ b/arch/sandbox/include/asm/test.h @@ -141,4 +141,24 @@ void sandbox_get_codec_params(struct udevice *dev, int *interfacep, int *ratep, */ int sandbox_get_i2s_sum(struct udevice *dev);
+/** + * sandbox_get_setup_called() - Returns the number of times setup(*) was called + * + * This is used in the sound test + * + * @dev: Device to check + * @return call count for the setup() method + */ +int sandbox_get_setup_called(struct udevice *dev); + +/** + * sandbox_get_sound_sum() - Read back the sum of the sound data so far + * + * This data is provided to the sandbox driver by the sound play() method. + * + * @dev: Device to check + * @return sum of audio data + */ +int sandbox_get_sound_sum(struct udevice *dev); + #endif diff --git a/cmd/sound.c b/cmd/sound.c index d1cbc14f8df..b063863bc9a 100644 --- a/cmd/sound.c +++ b/cmd/sound.c @@ -6,6 +6,7 @@
#include <common.h> #include <command.h> +#include <dm.h> #include <fdtdec.h> #include <sound.h>
@@ -14,9 +15,18 @@ DECLARE_GLOBAL_DATA_PTR; /* Initilaise sound subsystem */ static int do_init(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) { +#ifdef CONFIG_DM_SOUND + struct udevice *dev; +#endif int ret;
+#ifdef CONFIG_DM_SOUND + ret = uclass_first_device_err(UCLASS_SOUND, &dev); + if (!ret) + ret = sound_setup(dev); +#else ret = sound_init(gd->fdt_blob); +#endif if (ret) { printf("Initialise Audio driver failed\n"); return CMD_RET_FAILURE; @@ -28,6 +38,9 @@ static int do_init(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) /* play sound from buffer */ static int do_play(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) { +#ifdef CONFIG_DM_SOUND + struct udevice *dev; +#endif int ret = 0; int msec = 1000; int freq = 400; @@ -37,9 +50,15 @@ static int do_play(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) if (argc > 2) freq = simple_strtoul(argv[2], NULL, 10);
+#ifdef CONFIG_DM_SOUND + ret = uclass_first_device_err(UCLASS_SOUND, &dev); + if (!ret) + ret = sound_beep(dev, msec, freq); +#else ret = sound_play(msec, freq); +#endif if (ret) { - printf("play failed"); + printf("Sound device failed to play (err=%d)\n", ret); return CMD_RET_FAILURE; }
diff --git a/drivers/sound/Makefile b/drivers/sound/Makefile index 4aced9d22b9..70d32c6d6f6 100644 --- a/drivers/sound/Makefile +++ b/drivers/sound/Makefile @@ -7,6 +7,7 @@ obj-$(CONFIG_SOUND) += sound.o obj-$(CONFIG_DM_SOUND) += codec-uclass.o obj-$(CONFIG_DM_SOUND) += i2s-uclass.o obj-$(CONFIG_I2S) += sound-i2s.o +obj-$(CONFIG_DM_SOUND) += sound-uclass.o obj-$(CONFIG_I2S_SAMSUNG) += samsung-i2s.o obj-$(CONFIG_SOUND_SANDBOX) += sandbox.o obj-$(CONFIG_SOUND_WM8994) += wm8994.o diff --git a/drivers/sound/sandbox.c b/drivers/sound/sandbox.c index 59931ec0a12..d8a971ca060 100644 --- a/drivers/sound/sandbox.c +++ b/drivers/sound/sandbox.c @@ -7,6 +7,7 @@ #include <audio_codec.h> #include <dm.h> #include <i2s.h> +#include <sound.h> #include <asm/sound.h> #include <asm/sdl.h>
@@ -22,6 +23,12 @@ struct sandbox_i2s_priv { int sum; /* Use to sum the provided audio data */ };
+struct sandbox_sound_priv { + int setup_called; + int sum; /* Use to sum the provided audio data */ +}; + +#ifndef CONFIG_DM_SOUND int sound_play(uint32_t msec, uint32_t frequency) { sandbox_sdl_sound_start(frequency); @@ -30,6 +37,7 @@ int sound_play(uint32_t msec, uint32_t frequency)
return 0; } +#endif /* CONFIG_DM_SOUND */
int sound_init(const void *blob) { @@ -56,6 +64,20 @@ int sandbox_get_i2s_sum(struct udevice *dev) return priv->sum; }
+int sandbox_get_setup_called(struct udevice *dev) +{ + struct sandbox_sound_priv *priv = dev_get_priv(dev); + + return priv->setup_called; +} + +int sandbox_get_sound_sum(struct udevice *dev) +{ + struct sandbox_sound_priv *priv = dev_get_priv(dev); + + return priv->sum; +} + static int sandbox_codec_set_params(struct udevice *dev, int interface, int rate, int mclk_freq, int bits_per_sample, uint channels) @@ -97,6 +119,30 @@ static int sandbox_i2s_probe(struct udevice *dev) return 0; }
+static int sandbox_sound_setup(struct udevice *dev) +{ + struct sandbox_sound_priv *priv = dev_get_priv(dev); + + priv->setup_called++; + + return 0; +} + +static int sandbox_sound_play(struct udevice *dev, uint *data, uint data_size) +{ + struct sandbox_sound_priv *priv = dev_get_priv(dev); + + while (data_size-- > 0) + priv->sum += *data++; + + return 0; +} + +static int sandbox_sound_probe(struct udevice *dev) +{ + return sound_find_codec_i2s(dev); +} + static const struct audio_codec_ops sandbox_codec_ops = { .set_params = sandbox_codec_set_params, }; @@ -131,3 +177,22 @@ U_BOOT_DRIVER(sandbox_i2s) = { .probe = sandbox_i2s_probe, .priv_auto_alloc_size = sizeof(struct sandbox_i2s_priv), }; + +static const struct sound_ops sandbox_sound_ops = { + .setup = sandbox_sound_setup, + .play = sandbox_sound_play, +}; + +static const struct udevice_id sandbox_sound_ids[] = { + { .compatible = "sandbox,sound" }, + { } +}; + +U_BOOT_DRIVER(sandbox_sound) = { + .name = "sandbox_sound", + .id = UCLASS_SOUND, + .of_match = sandbox_sound_ids, + .ops = &sandbox_sound_ops, + .priv_auto_alloc_size = sizeof(struct sandbox_sound_priv), + .probe = sandbox_sound_probe, +}; diff --git a/drivers/sound/sound-uclass.c b/drivers/sound/sound-uclass.c new file mode 100644 index 00000000000..dee04fd19bb --- /dev/null +++ b/drivers/sound/sound-uclass.c @@ -0,0 +1,129 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 Google LLC + * Written by Simon Glass sjg@chromium.org + */ + +#include <common.h> +#include <dm.h> +#include <i2s.h> +#include <sound.h> + +#define SOUND_BITS_IN_BYTE 8 + +int sound_setup(struct udevice *dev) +{ + struct sound_ops *ops = sound_get_ops(dev); + + if (!ops->setup) + return -ENOSYS; + + return ops->setup(dev); +} + +int sound_play(struct udevice *dev, uint *data, uint data_size) +{ + struct sound_ops *ops = sound_get_ops(dev); + + if (!ops->play) + return -ENOSYS; + + return ops->play(dev, data, data_size); +} + +int sound_beep(struct udevice *dev, int msecs, int frequency_hz) +{ + struct sound_uc_priv *uc_priv = dev_get_uclass_priv(dev); + struct i2s_uc_priv *i2s_uc_priv = dev_get_uclass_priv(uc_priv->i2s); + unsigned int *data; + unsigned long data_size; + int ret; + + ret = sound_setup(dev); + if (ret && ret != -EALREADY) + return ret; + + /* Buffer length computation */ + data_size = i2s_uc_priv->samplingrate * i2s_uc_priv->channels; + data_size *= (i2s_uc_priv->bitspersample / SOUND_BITS_IN_BYTE); + data = malloc(data_size); + if (!data) { + debug("%s: malloc failed\n", __func__); + return -ENOMEM; + } + + sound_create_square_wave(i2s_uc_priv->samplingrate, + (unsigned short *)data, + data_size / sizeof(unsigned short), + frequency_hz); + + while (msecs >= 1000) { + ret = sound_play(dev, data, (data_size / sizeof(int))); + msecs -= 1000; + } + if (msecs) { + unsigned long size = + (data_size * msecs) / (sizeof(int) * 1000); + + ret = sound_play(dev, data, size); + } + + free(data); + + return ret; +} + +int sound_find_codec_i2s(struct udevice *dev) +{ + struct sound_uc_priv *uc_priv = dev_get_uclass_priv(dev); + struct ofnode_phandle_args args; + ofnode node; + int ret; + + /* First the codec */ + node = ofnode_find_subnode(dev_ofnode(dev), "codec"); + if (!ofnode_valid(node)) { + debug("Failed to find /cpu subnode\n"); + return -EINVAL; + } + ret = ofnode_parse_phandle_with_args(node, "sound-dai", + "#sound-dai-cells", 0, 0, &args); + if (ret) { + debug("Cannot find phandle: %d\n", ret); + return ret; + } + ret = uclass_get_device_by_ofnode(UCLASS_AUDIO_CODEC, args.node, + &uc_priv->codec); + if (ret) { + debug("Cannot find codec: %d\n", ret); + return ret; + } + + /* Now the i2s */ + node = ofnode_find_subnode(dev_ofnode(dev), "cpu"); + if (!ofnode_valid(node)) { + debug("Failed to find /cpu subnode\n"); + return -EINVAL; + } + ret = ofnode_parse_phandle_with_args(node, "sound-dai", + "#sound-dai-cells", 0, 0, &args); + if (ret) { + debug("Cannot find phandle: %d\n", ret); + return ret; + } + ret = uclass_get_device_by_ofnode(UCLASS_I2S, args.node, &uc_priv->i2s); + if (ret) { + debug("Cannot find i2s: %d\n", ret); + return ret; + } + debug("Probed sound '%s' with codec '%s' and i2s '%s'\n", dev->name, + uc_priv->codec->name, uc_priv->i2s->name); + + return 0; +} + +UCLASS_DRIVER(sound) = { + .id = UCLASS_SOUND, + .name = "sound", + .per_device_auto_alloc_size = sizeof(struct sound_uc_priv), +}; diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index ffafe08a4fe..bebcb124171 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -82,6 +82,7 @@ enum uclass_id { UCLASS_SERIAL, /* Serial UART */ UCLASS_SIMPLE_BUS, /* Bus with child devices */ UCLASS_SMEM, /* Shared memory interface */ + UCLASS_SOUND, /* Playing simple sounds */ UCLASS_SPI, /* SPI bus */ UCLASS_SPMI, /* System Power Management Interface bus */ UCLASS_SPI_FLASH, /* SPI flash */ diff --git a/include/sound.h b/include/sound.h index c4ac3193fe7..a8235a75b9c 100644 --- a/include/sound.h +++ b/include/sound.h @@ -19,6 +19,21 @@ struct sound_codec_info { int i2c_dev_addr; };
+/** + * struct sound_uc_priv - private uclass information about each sound device + * + * This is used to line the codec and i2s together + * + * @codec: Codec that is used for this sound device + * @i2s: I2S bus that is used for this sound device + * @setup_done: true if setup() has been called + */ +struct sound_uc_priv { + struct udevice *codec; + struct udevice *i2s; + int setup_done; +}; + /* * Generates square wave sound data for 1 second * @@ -37,6 +52,56 @@ void sound_create_square_wave(uint sample_rate, unsigned short *data, int size, */ int sound_init(const void *blob);
+#ifdef CONFIG_DM_SOUND +/* + * The sound uclass brings together a data transport (currently only I2C) and a + * codec (currently connected over I2C). + */ + +/* Operations for sound */ +struct sound_ops { + /** + * setup() - Set up to play a sound + */ + int (*setup)(struct udevice *dev); + + /** + * play() - Play a beep + * + * @dev: Sound device + * @data: Data buffer to play + * @data_size: Size of data buffer + * @return 0 if OK, -ve on error + */ + int (*play)(struct udevice *dev, uint *data, uint data_size); +}; + +#define sound_get_ops(dev) ((struct sound_ops *)(dev)->driver->ops) + +/** + * setup() - Set up to play a sound + */ +int sound_setup(struct udevice *dev); + +/** + * play() - Play a beep + * + * @dev: Sound device + * @msecs: Duration of beep in milliseconds + * @frequency_hz: Frequency of the beep in Hertz + * @return 0 if OK, -ve on error + */ +int sound_beep(struct udevice *dev, int msecs, int frequency_hz); + +/** + * sound_find_codec_i2s() - Called by sound drivers to locate codec and i2s + * + * This finds the audio codec and i2s devices and puts them in the uclass's + * private data for this device. + */ +int sound_find_codec_i2s(struct udevice *dev); + +#else /* * plays the pcm data buffer in pcm_data.h through i2s1 to make the * sine wave sound @@ -44,5 +109,6 @@ int sound_init(const void *blob); * @return int 0 for success, -1 for error */ int sound_play(uint32_t msec, uint32_t frequency); +#endif /* CONFIG_DM_SOUND */
#endif /* __SOUND__H__ */ diff --git a/test/dm/Makefile b/test/dm/Makefile index 07d6f97cb77..0c1459cd4db 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -54,6 +54,7 @@ obj-$(CONFIG_AXI) += axi.o obj-$(CONFIG_MISC) += misc.o obj-$(CONFIG_DM_SERIAL) += serial.o obj-$(CONFIG_CPU) += cpu.o +obj-$(CONFIG_DM_SOUND) += sound.o obj-$(CONFIG_TEE) += tee.o obj-$(CONFIG_VIRTIO_SANDBOX) += virtio.o endif diff --git a/test/dm/sound.c b/test/dm/sound.c new file mode 100644 index 00000000000..0f818052152 --- /dev/null +++ b/test/dm/sound.c @@ -0,0 +1,34 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 Google LLC + * Written by Simon Glass sjg@chromium.org + */ + +#include <common.h> +#include <dm.h> +#include <sound.h> +#include <dm/test.h> +#include <test/ut.h> +#include <asm/test.h> + +/* Basic test of the sound codec uclass */ +static int dm_test_sound(struct unit_test_state *uts) +{ + struct sound_uc_priv *uc_priv; + struct udevice *dev; + + /* check probe success */ + ut_assertok(uclass_first_device_err(UCLASS_SOUND, &dev)); + uc_priv = dev_get_uclass_priv(dev); + ut_asserteq_str("audio-codec", uc_priv->codec->name); + ut_asserteq_str("i2s", uc_priv->i2s->name); + ut_asserteq(0, sandbox_get_setup_called(dev)); + + ut_assertok(sound_beep(dev, 1, 100)); + ut_asserteq(-1207191552, sandbox_get_sound_sum(dev)); + ut_assertok(sound_beep(dev, 1, 100)); + ut_asserteq(1880584192, sandbox_get_sound_sum(dev)); + + return 0; +} +DM_TEST(dm_test_sound, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
The current dev_read...() functions use s32 and u32 which are convenient for device tree but not so useful for normal code, which often wants to use normal integers for values.
Add a helper which supports returning an unsigned int. Also add signed versions of the unsigned readers.
arch/sandbox/dts/test.dts | 2 ++ drivers/core/read.c | 23 ++++++++++++++++ include/dm/read.h | 58 +++++++++++++++++++++++++++++++++++++++ test/dm/test-fdt.c | 35 +++++++++++++++++++++++ 4 files changed, 118 insertions(+)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index dbbd0495e7c..f44090377d3 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -87,6 +87,8 @@ test2-gpios = <&gpio_a 1>, <&gpio_a 4>, <&gpio_b 6 1 3 2 1>, <&gpio_b 7 2 3 2 1>, <&gpio_b 8 4 3 2 1>, <&gpio_b 9 0xc 3 2 1>; + int-value = <1234>; + uint-value = <(-1234)>; };
junk { diff --git a/drivers/core/read.c b/drivers/core/read.c index 96766c7876a..4644a8c0cee 100644 --- a/drivers/core/read.c +++ b/drivers/core/read.c @@ -21,6 +21,29 @@ int dev_read_u32_default(struct udevice *dev, const char *propname, int def) return ofnode_read_u32_default(dev_ofnode(dev), propname, def); }
+int dev_read_s32(struct udevice *dev, const char *propname, s32 *outp) +{ + return ofnode_read_u32(dev_ofnode(dev), propname, (u32 *)outp); +} + +int dev_read_s32_default(struct udevice *dev, const char *propname, int def) +{ + return ofnode_read_u32_default(dev_ofnode(dev), propname, def); +} + +int dev_read_u32u(struct udevice *dev, const char *propname, uint *outp) +{ + u32 val; + int ret; + + ret = ofnode_read_u32(dev_ofnode(dev), propname, &val); + if (ret) + return ret; + *outp = val; + + return 0; +} + const char *dev_read_string(struct udevice *dev, const char *propname) { return ofnode_read_string(dev_ofnode(dev), propname); diff --git a/include/dm/read.h b/include/dm/read.h index a27b8554fb1..27f751ba7a2 100644 --- a/include/dm/read.h +++ b/include/dm/read.h @@ -64,6 +64,38 @@ int dev_read_u32(struct udevice *dev, const char *propname, u32 *outp); */ int dev_read_u32_default(struct udevice *dev, const char *propname, int def);
+/** + * dev_read_s32() - read a signed 32-bit integer from a device's DT property + * + * @dev: device to read DT property from + * @propname: name of the property to read from + * @outp: place to put value (if found) + * @return 0 if OK, -ve on error + */ +int dev_read_s32(struct udevice *dev, const char *propname, s32 *outp); + +/** + * dev_read_s32_default() - read a signed 32-bit int from a device's DT property + * + * @dev: device to read DT property from + * @propname: name of the property to read from + * @def: default value to return if the property has no value + * @return property value, or @def if not found + */ +int dev_read_s32_default(struct udevice *dev, const char *propname, int def); + +/** + * dev_read_u32u() - read a 32-bit integer from a device's DT property + * + * This version uses a standard uint type. + * + * @dev: device to read DT property from + * @propname: name of the property to read from + * @outp: place to put value (if found) + * @return 0 if OK, -ve on error + */ +int dev_read_u32u(struct udevice *dev, const char *propname, uint *outp); + /** * dev_read_string() - Read a string from a device's DT property * @@ -467,6 +499,32 @@ static inline int dev_read_u32_default(struct udevice *dev, return ofnode_read_u32_default(dev_ofnode(dev), propname, def); }
+static inline int dev_read_s32(struct udevice *dev, + const char *propname, s32 *outp) +{ + return ofnode_read_s32(dev_ofnode(dev), propname, outp); +} + +static inline int dev_read_s32_default(struct udevice *dev, + const char *propname, int def) +{ + return ofnode_read_s32_default(dev_ofnode(dev), propname, def); +} + +static inline int dev_read_u32u(struct udevice *dev, + const char *propname, uint *outp) +{ + u32 val; + int ret; + + ret = ofnode_read_u32(dev_ofnode(dev), propname, &val); + if (ret) + return ret; + *outp = val; + + return 0; +} + static inline const char *dev_read_string(struct udevice *dev, const char *propname) { diff --git a/test/dm/test-fdt.c b/test/dm/test-fdt.c index 0fbd9be765a..b32f82fdcf1 100644 --- a/test/dm/test-fdt.c +++ b/test/dm/test-fdt.c @@ -658,3 +658,38 @@ static int dm_test_first_child(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_first_child, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +/* Test integer functions in dm_read_...() */ +static int dm_test_read_int(struct unit_test_state *uts) +{ + struct udevice *dev; + u32 val32; + s32 sval; + uint val; + + ut_assertok(uclass_first_device_err(UCLASS_TEST_FDT, &dev)); + ut_asserteq_str("a-test", dev->name); + ut_assertok(dev_read_u32(dev, "int-value", &val32)); + ut_asserteq(1234, val32); + + ut_asserteq(-EINVAL, dev_read_u32(dev, "missing", &val32)); + ut_asserteq(6, dev_read_u32_default(dev, "missing", 6)); + + ut_asserteq(1234, dev_read_u32_default(dev, "int-value", 6)); + ut_asserteq(1234, val32); + + ut_asserteq(-EINVAL, dev_read_s32(dev, "missing", &sval)); + ut_asserteq(6, dev_read_s32_default(dev, "missing", 6)); + + ut_asserteq(-1234, dev_read_s32_default(dev, "uint-value", 6)); + ut_assertok(dev_read_s32(dev, "uint-value", &sval)); + ut_asserteq(-1234, sval); + + val = 0; + ut_asserteq(-EINVAL, dev_read_u32u(dev, "missing", &val)); + ut_assertok(dev_read_u32u(dev, "uint-value", &val)); + ut_asserteq(-1234, val); + + return 0; +} +DM_TEST(dm_test_read_int, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
The current ID enums start from 1 but there does not seem to be any reason that they cannot start with 0. Adjust the code to avoid the +1 in codec_init() and elsewhere.
drivers/sound/max98095.h | 2 +- drivers/sound/sound-i2s.c | 6 ++---- drivers/sound/wm8994.c | 23 ++++++++++++----------- drivers/sound/wm8994.h | 2 +- 4 files changed, 16 insertions(+), 17 deletions(-)
diff --git a/drivers/sound/max98095.h b/drivers/sound/max98095.h index 44b1e3a97b4..13ae177a86b 100644 --- a/drivers/sound/max98095.h +++ b/drivers/sound/max98095.h @@ -13,7 +13,7 @@
/* Available audio interface ports in wm8994 codec */ enum en_max_audio_interface { - AIF1 = 1, + AIF1, AIF2, };
diff --git a/drivers/sound/sound-i2s.c b/drivers/sound/sound-i2s.c index ed130750b2e..a2fc78154f1 100644 --- a/drivers/sound/sound-i2s.c +++ b/drivers/sound/sound-i2s.c @@ -120,13 +120,11 @@ static int codec_init(const void *blob, struct i2s_uc_priv *pi2s_tx) debug("device = %s\n", codectype); if (!strcmp(codectype, "wm8994")) { /* Check the codec type and initialise the same */ - ret = wm8994_init(blob, pi2s_tx->id + 1, - pi2s_tx->samplingrate, + ret = wm8994_init(blob, pi2s_tx->id, pi2s_tx->samplingrate, (pi2s_tx->samplingrate * (pi2s_tx->rfs)), pi2s_tx->bitspersample, pi2s_tx->channels); } else if (!strcmp(codectype, "max98095")) { - ret = max98095_init(blob, pi2s_tx->id + 1, - pi2s_tx->samplingrate, + ret = max98095_init(blob, pi2s_tx->id, pi2s_tx->samplingrate, (pi2s_tx->samplingrate * (pi2s_tx->rfs)), pi2s_tx->bitspersample); } else { diff --git a/drivers/sound/wm8994.c b/drivers/sound/wm8994.c index 1714f430f39..b8c3ffb67eb 100644 --- a/drivers/sound/wm8994.c +++ b/drivers/sound/wm8994.c @@ -285,7 +285,6 @@ static int wm8994_hw_params(struct wm8994_priv *priv, int aif_id, int aif1 = 0; int aif2 = 0; int rate_val = 0; - int id = aif_id - 1; int i, cur_val, best_val, bclk_rate, best; unsigned short reg_data; int ret = 0; @@ -343,10 +342,11 @@ static int wm8994_hw_params(struct wm8994_priv *priv, int aif_id,
/* AIFCLK/fs ratio; look for a close match in either direction */ best = 0; - best_val = abs((fs_ratios[0] * sampling_rate) - priv->aifclk[id]); + best_val = abs((fs_ratios[0] * sampling_rate) - priv->aifclk[aif_id]);
for (i = 1; i < ARRAY_SIZE(fs_ratios); i++) { - cur_val = abs(fs_ratios[i] * sampling_rate - priv->aifclk[id]); + cur_val = abs(fs_ratios[i] * sampling_rate - + priv->aifclk[aif_id]); if (cur_val >= best_val) continue; best = i; @@ -363,7 +363,8 @@ static int wm8994_hw_params(struct wm8994_priv *priv, int aif_id, */ best = 0; for (i = 0; i < ARRAY_SIZE(bclk_divs); i++) { - cur_val = (priv->aifclk[id] * 10 / bclk_divs[i]) - bclk_rate; + cur_val = (priv->aifclk[aif_id] * 10 / bclk_divs[i]) - + bclk_rate; if (cur_val < 0) /* BCLK table is sorted */ break; best = i; @@ -375,7 +376,7 @@ static int wm8994_hw_params(struct wm8994_priv *priv, int aif_id, return -1; }
- bclk_rate = priv->aifclk[id] * 10 / bclk_divs[best]; + bclk_rate = priv->aifclk[aif_id] * 10 / bclk_divs[best]; bclk |= best << WM8994_AIF1_BCLK_DIV_SHIFT;
if (wm8994_i2c_read(priv, aif1_reg, ®_data) != 0) { @@ -386,7 +387,7 @@ static int wm8994_hw_params(struct wm8994_priv *priv, int aif_id, if ((channels == 1) && ((reg_data & 0x18) == 0x18)) aif2 |= WM8994_AIF1_MONO;
- if (priv->aifclk[id] == 0) { + if (priv->aifclk[aif_id] == 0) { debug("%s:Audio interface clock not set\n", __func__); return -1; } @@ -424,12 +425,12 @@ static int configure_aif_clock(struct wm8994_priv *priv, int aif) int ret;
/* AIF(1/0) register adress offset calculated */ - if (aif-1) + if (aif) offset = 4; else offset = 0;
- switch (priv->sysclk[aif - 1]) { + switch (priv->sysclk[aif]) { case WM8994_SYSCLK_MCLK1: reg1 |= SEL_MCLK1; rate = priv->mclk[0]; @@ -452,7 +453,7 @@ static int configure_aif_clock(struct wm8994_priv *priv, int aif)
default: debug("%s: Invalid input clock selection [%d]\n", - __func__, priv->sysclk[aif - 1]); + __func__, priv->sysclk[aif]); return -1; }
@@ -462,7 +463,7 @@ static int configure_aif_clock(struct wm8994_priv *priv, int aif) reg1 |= WM8994_AIF1CLK_DIV; }
- priv->aifclk[aif - 1] = rate; + priv->aifclk[aif] = rate;
ret = wm8994_bic_or(priv, WM8994_AIF1_CLOCKING_1 + offset, WM8994_AIF1CLK_SRC_MASK | WM8994_AIF1CLK_DIV, @@ -502,7 +503,7 @@ static int wm8994_set_sysclk(struct wm8994_priv *priv, int aif_id, int clk_id, int i; int ret = 0;
- priv->sysclk[aif_id - 1] = clk_id; + priv->sysclk[aif_id] = clk_id;
switch (clk_id) { case WM8994_SYSCLK_MCLK1: diff --git a/drivers/sound/wm8994.h b/drivers/sound/wm8994.h index ef2878f87ca..e36e6269f00 100644 --- a/drivers/sound/wm8994.h +++ b/drivers/sound/wm8994.h @@ -15,7 +15,7 @@
/* Avilable audi interface ports in wm8994 codec */ enum en_audio_interface { - WM8994_AIF1 = 1, + WM8994_AIF1, WM8994_AIF2, WM8994_AIF3 };
Move the existing hardware drivers over to use driver model.
arch/arm/dts/exynos5250-smdk5250.dts | 1 + arch/arm/dts/exynos5420-smdk5420.dts | 1 + drivers/sound/Makefile | 6 +- drivers/sound/max98095.c | 59 +++++++++++++++- drivers/sound/samsung-i2s.c | 91 +++++++++++++++++++++++- drivers/sound/samsung_sound.c | 101 +++++++++++++++++++++++++++ drivers/sound/wm8994.c | 53 +++++++++++++- 7 files changed, 306 insertions(+), 6 deletions(-) create mode 100644 drivers/sound/samsung_sound.c
diff --git a/arch/arm/dts/exynos5250-smdk5250.dts b/arch/arm/dts/exynos5250-smdk5250.dts index 8b695442b1a..bf60b82d449 100644 --- a/arch/arm/dts/exynos5250-smdk5250.dts +++ b/arch/arm/dts/exynos5250-smdk5250.dts @@ -62,6 +62,7 @@ i2c@12C70000 { soundcodec@1a { reg = <0x1a>; + u-boot,i2c-offset-len = <2>; compatible = "wolfson,wm8994-codec"; }; }; diff --git a/arch/arm/dts/exynos5420-smdk5420.dts b/arch/arm/dts/exynos5420-smdk5420.dts index cab5ddb61fa..daaa4666964 100644 --- a/arch/arm/dts/exynos5420-smdk5420.dts +++ b/arch/arm/dts/exynos5420-smdk5420.dts @@ -84,6 +84,7 @@ i2c@12C70000 { soundcodec@1a { reg = <0x1a>; + u-boot,i2c-offset-len = <2>; compatible = "wolfson,wm8994-codec"; }; }; diff --git a/drivers/sound/Makefile b/drivers/sound/Makefile index 70d32c6d6f6..75fa31ec534 100644 --- a/drivers/sound/Makefile +++ b/drivers/sound/Makefile @@ -6,9 +6,13 @@ obj-$(CONFIG_SOUND) += sound.o obj-$(CONFIG_DM_SOUND) += codec-uclass.o obj-$(CONFIG_DM_SOUND) += i2s-uclass.o -obj-$(CONFIG_I2S) += sound-i2s.o obj-$(CONFIG_DM_SOUND) += sound-uclass.o obj-$(CONFIG_I2S_SAMSUNG) += samsung-i2s.o obj-$(CONFIG_SOUND_SANDBOX) += sandbox.o +ifdef CONFIG_DM_SOUND +obj-$(CONFIG_I2S_SAMSUNG) += samsung_sound.o +else +obj-$(CONFIG_I2S) += sound-i2s.o +endif obj-$(CONFIG_SOUND_WM8994) += wm8994.o obj-$(CONFIG_SOUND_MAX98095) += max98095.o diff --git a/drivers/sound/max98095.c b/drivers/sound/max98095.c index 7a3dbd09840..d6710dfaa7a 100644 --- a/drivers/sound/max98095.c +++ b/drivers/sound/max98095.c @@ -11,6 +11,8 @@ */
#include <common.h> +#include <audio_codec.h> +#include <dm.h> #include <div64.h> #include <fdtdec.h> #include <i2c.h> @@ -28,6 +30,7 @@ struct max98095_priv { unsigned int rate; unsigned int fmt; int i2c_addr; + struct udevice *dev; };
/* Index 0 is reserved. */ @@ -48,7 +51,12 @@ static int max98095_i2c_write(struct max98095_priv *priv, unsigned int reg, { debug("%s: Write Addr : 0x%02X, Data : 0x%02X\n", __func__, reg, data); +#ifdef CONFIG_DM_SOUND + debug("dev = %s\n", priv->dev->name); + return dm_i2c_write(priv->dev, reg, &data, 1); +#else return i2c_write(priv->i2c_addr, reg, 1, &data, 1); +#endif }
/* @@ -65,7 +73,11 @@ static unsigned int max98095_i2c_read(struct max98095_priv *priv, { int ret;
+#ifdef CONFIG_DM_SOUND + return dm_i2c_read(priv->dev, reg, data, 1); +#else ret = i2c_read(priv->i2c_addr, reg, 1, data, 1); +#endif if (ret != 0) { debug("%s: Error while reading register %#04x\n", __func__, reg); @@ -484,7 +496,7 @@ static int max98095_do_init(struct max98095_priv *priv,
ret = max98095_setup_interface(priv, aif_id); if (ret < 0) { - debug("%s: max98095 codec chip init failed\n", __func__); + debug("%s: max98095 setup interface failed\n", __func__); return ret; }
@@ -507,6 +519,7 @@ static int max98095_do_init(struct max98095_priv *priv, return ret; }
+#ifndef CONFIG_DM_SOUND static int get_max98095_codec_values(struct sound_codec_info *pcodec_info, const void *blob) { @@ -582,3 +595,47 @@ int max98095_init(const void *blob, enum en_max_audio_interface aif_id,
return ret; } +#endif + +static int max98095_set_params(struct udevice *dev, int interface, int rate, + int mclk_freq, int bits_per_sample, + uint channels) +{ + struct max98095_priv *priv = dev_get_priv(dev); + + return max98095_do_init(priv, interface, rate, mclk_freq, + bits_per_sample); +} + +static int max98095_probe(struct udevice *dev) +{ + struct max98095_priv *priv = dev_get_priv(dev); + int ret; + + priv->dev = dev; + ret = max98095_device_init(priv); + if (ret < 0) { + debug("%s: max98095 codec chip init failed\n", __func__); + return ret; + } + + return 0; +} + +static const struct audio_codec_ops max98095_ops = { + .set_params = max98095_set_params, +}; + +static const struct udevice_id max98095_ids[] = { + { .compatible = "maxim,max98095" }, + { } +}; + +U_BOOT_DRIVER(max98095) = { + .name = "max98095", + .id = UCLASS_AUDIO_CODEC, + .of_match = max98095_ids, + .probe = max98095_probe, + .ops = &max98095_ops, + .priv_auto_alloc_size = sizeof(struct max98095_priv), +}; diff --git a/drivers/sound/samsung-i2s.c b/drivers/sound/samsung-i2s.c index 5cd585808ab..9978bfb19a5 100644 --- a/drivers/sound/samsung-i2s.c +++ b/drivers/sound/samsung-i2s.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <dm.h> #include <i2s.h> #include <sound.h> #include <asm/arch/clk.h> @@ -255,7 +256,7 @@ static int i2s_set_samplesize(struct i2s_reg *i2s_reg, unsigned int blc) return 0; }
-int i2s_transfer_tx_data(struct i2s_uc_priv *pi2s_tx, unsigned int *data, +int i2s_transfer_tx_data(struct i2s_uc_priv *pi2s_tx, u32 *data, unsigned long data_size) { int i; @@ -296,8 +297,8 @@ int i2s_transfer_tx_data(struct i2s_uc_priv *pi2s_tx, unsigned int *data, int i2s_tx_init(struct i2s_uc_priv *pi2s_tx) { int ret; - struct i2s_reg *i2s_reg = - (struct i2s_reg *)pi2s_tx->base_address; + struct i2s_reg *i2s_reg = (struct i2s_reg *)pi2s_tx->base_address; + if (pi2s_tx->id == 0) { /* Initialize GPIO for I2S-0 */ exynos_pinmux_config(PERIPH_ID_I2S0, 0); @@ -368,3 +369,87 @@ int i2s_tx_init(struct i2s_uc_priv *pi2s_tx)
return ret; } + +static int samsung_i2s_tx_data(struct udevice *dev, u32 *data, uint data_size) +{ + struct i2s_uc_priv *priv = dev_get_uclass_priv(dev); + + return i2s_transfer_tx_data(priv, data, data_size); +} + +static int samsung_i2s_probe(struct udevice *dev) +{ + struct i2s_uc_priv *priv = dev_get_uclass_priv(dev); + + return i2s_tx_init(priv); +} + +static int samsung_i2s_ofdata_to_platdata(struct udevice *dev) +{ + struct i2s_uc_priv *priv = dev_get_uclass_priv(dev); + ulong base; + + /* + * Get the pre-defined sound specific values from FDT. + * All of these are expected to be correct otherwise + * wrong register values in i2s setup parameters + * may result in no sound play. + */ + base = dev_read_addr(dev); + if (base == FDT_ADDR_T_NONE) { + debug("%s: Missing i2s base\n", __func__); + return -EINVAL; + } + priv->base_address = base; + + if (dev_read_u32u(dev, "samsung,i2s-epll-clock-frequency", + &priv->audio_pll_clk)) + goto err; + debug("audio_pll_clk = %d\n", priv->audio_pll_clk); + if (dev_read_u32u(dev, "samsung,i2s-sampling-rate", + &priv->samplingrate)) + goto err; + debug("samplingrate = %d\n", priv->samplingrate); + if (dev_read_u32u(dev, "samsung,i2s-bits-per-sample", + &priv->bitspersample)) + goto err; + debug("bitspersample = %d\n", priv->bitspersample); + if (dev_read_u32u(dev, "samsung,i2s-channels", &priv->channels)) + goto err; + debug("channels = %d\n", priv->channels); + if (dev_read_u32u(dev, "samsung,i2s-lr-clk-framesize", &priv->rfs)) + goto err; + debug("rfs = %d\n", priv->rfs); + if (dev_read_u32u(dev, "samsung,i2s-bit-clk-framesize", &priv->bfs)) + goto err; + debug("bfs = %d\n", priv->bfs); + + if (dev_read_u32u(dev, "samsung,i2s-id", &priv->id)) + goto err; + debug("id = %d\n", priv->id); + + return 0; + +err: + debug("fail to get sound i2s node properties\n"); + + return -EINVAL; +} + +static const struct i2s_ops samsung_i2s_ops = { + .tx_data = samsung_i2s_tx_data, +}; + +static const struct udevice_id samsung_i2s_ids[] = { + { .compatible = "samsung,s5pv210-i2s" }, + { } +}; + +U_BOOT_DRIVER(samsung_i2s) = { + .name = "samsung_i2s", + .id = UCLASS_I2S, + .of_match = samsung_i2s_ids, + .probe = samsung_i2s_probe, + .ofdata_to_platdata = samsung_i2s_ofdata_to_platdata, + .ops = &samsung_i2s_ops, +}; diff --git a/drivers/sound/samsung_sound.c b/drivers/sound/samsung_sound.c new file mode 100644 index 00000000000..4e8321eae26 --- /dev/null +++ b/drivers/sound/samsung_sound.c @@ -0,0 +1,101 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 Google, LLC + * Written by Simon Glass sjg@chromium.org + */ + +#include <common.h> +#include <audio_codec.h> +#include <dm.h> +#include <i2s.h> +#include <sound.h> +#include <asm/gpio.h> + +static int samsung_sound_setup(struct udevice *dev) +{ + struct sound_uc_priv *uc_priv = dev_get_uclass_priv(dev); + struct i2s_uc_priv *i2c_priv = dev_get_uclass_priv(uc_priv->i2s); + int ret; + + if (uc_priv->setup_done) + return -EALREADY; + ret = audio_codec_set_params(uc_priv->codec, i2c_priv->id, + i2c_priv->samplingrate, + i2c_priv->samplingrate * i2c_priv->rfs, + i2c_priv->bitspersample, + i2c_priv->channels); + if (ret) + return ret; + uc_priv->setup_done = true; + + return 0; +} + +static int samsung_sound_play(struct udevice *dev, uint *data, uint data_size) +{ + struct sound_uc_priv *uc_priv = dev_get_uclass_priv(dev); + + return i2s_tx_data(uc_priv->i2s, data, data_size); +} + +static int samsung_sound_probe(struct udevice *dev) +{ + struct sound_uc_priv *uc_priv = dev_get_uclass_priv(dev); + struct ofnode_phandle_args args; + struct gpio_desc en_gpio; + ofnode node; + int ret; + + ret = gpio_request_by_name(dev, "codec-enable-gpio", 0, &en_gpio, + GPIOD_IS_OUT | GPIOD_IS_OUT_ACTIVE); + + /* Turn on the GPIO which connects to the codec's "enable" line. */ + if (!ret) + gpio_set_pull(gpio_get_number(&en_gpio), S5P_GPIO_PULL_NONE); + + ret = uclass_get_device_by_phandle(UCLASS_AUDIO_CODEC, dev, + "samsung,audio-codec", + &uc_priv->codec); + if (ret) { + debug("Failed to probe audio codec\n"); + return ret; + } + node = ofnode_find_subnode(dev_ofnode(dev), "cpu"); + if (!ofnode_valid(node)) { + debug("Failed to find /cpu subnode\n"); + return -EINVAL; + } + ret = ofnode_parse_phandle_with_args(node, "sound-dai", + "#sound-dai-cells", 0, 0, &args); + if (ret) { + debug("Cannot find phandle: %d\n", ret); + return ret; + } + ret = uclass_get_device_by_ofnode(UCLASS_I2S, args.node, &uc_priv->i2s); + if (ret) { + debug("Cannot find i2s: %d\n", ret); + return ret; + } + debug("Probed sound '%s' with codec '%s' and i2s '%s'\n", dev->name, + uc_priv->codec->name, uc_priv->i2s->name); + + return 0; +} + +static const struct sound_ops samsung_sound_ops = { + .setup = samsung_sound_setup, + .play = samsung_sound_play, +}; + +static const struct udevice_id samsung_sound_ids[] = { + { .compatible = "google,snow-audio-max98095" }, + { } +}; + +U_BOOT_DRIVER(samsung_sound) = { + .name = "samsung_sound", + .id = UCLASS_SOUND, + .of_match = samsung_sound_ids, + .probe = samsung_sound_probe, + .ops = &samsung_sound_ops, +}; diff --git a/drivers/sound/wm8994.c b/drivers/sound/wm8994.c index b8c3ffb67eb..d2b22fb1d7f 100644 --- a/drivers/sound/wm8994.c +++ b/drivers/sound/wm8994.c @@ -4,6 +4,8 @@ * R. Chandrasekar rcsekar@samsung.com */ #include <common.h> +#include <audio_codec.h> +#include <dm.h> #include <div64.h> #include <fdtdec.h> #include <i2c.h> @@ -39,6 +41,7 @@ struct wm8994_priv { int aifclk[WM8994_MAX_AIF]; /* audio interface clock in Hz */ struct wm8994_fll_config fll[2]; /* fll config to configure fll */ int i2c_addr; + struct udevice *dev; };
/* wm 8994 supported sampling rate values */ @@ -79,7 +82,12 @@ static int wm8994_i2c_write(struct wm8994_priv *priv, unsigned int reg, val[1] = (unsigned char)(data & 0xff); debug("Write Addr : 0x%04X, Data : 0x%04X\n", reg, data);
+#ifdef CONFIG_DM_SOUND + debug("dev = %s\n", priv->dev->name); + return dm_i2c_write(priv->dev, reg, val, 2); +#else return i2c_write(priv->i2c_addr, reg, 2, val, 2); +#endif }
/* @@ -97,7 +105,11 @@ static unsigned int wm8994_i2c_read(struct wm8994_priv *priv, unsigned int reg, unsigned char val[2]; int ret;
+#ifdef CONFIG_DM_SOUND + ret = dm_i2c_read(priv->dev, reg, val, 1); +#else ret = i2c_read(priv->i2c_addr, reg, 2, val, 2); +#endif if (ret != 0) { debug("%s: Error while reading register %#04x\n", __func__, reg); @@ -808,6 +820,7 @@ err: return -1; }
+#ifndef CONFIG_DM_SOUND /* * Gets fdt values for wm8994 config parameters * @@ -860,6 +873,7 @@ static int get_codec_values(struct sound_codec_info *pcodec_info,
return 0; } +#endif
static int _wm8994_init(struct wm8994_priv *priv, enum en_audio_interface aif_id, int sampling_rate, @@ -874,7 +888,7 @@ static int _wm8994_init(struct wm8994_priv *priv, return ret; }
- ret = wm8994_set_sysclk(priv, aif_id, WM8994_SYSCLK_MCLK1, mclk_freq); + ret = wm8994_set_sysclk(priv, aif_id, WM8994_SYSCLK_MCLK1, mclk_freq); if (ret < 0) { debug("%s: wm8994 codec set sys clock failed\n", __func__); return ret; @@ -892,6 +906,7 @@ static int _wm8994_init(struct wm8994_priv *priv, return ret; }
+#ifndef CONFIG_DM_SOUND /* WM8994 Device Initialisation */ int wm8994_init(const void *blob, enum en_audio_interface aif_id, int sampling_rate, int mclk_freq, int bits_per_sample, @@ -919,3 +934,39 @@ int wm8994_init(const void *blob, enum en_audio_interface aif_id, return _wm8994_init(&wm8994_info, aif_id, sampling_rate, mclk_freq, bits_per_sample, channels); } +#endif + +static int wm8994_set_params(struct udevice *dev, int interface, int rate, + int mclk_freq, int bits_per_sample, uint channels) +{ + struct wm8994_priv *priv = dev_get_priv(dev); + + return _wm8994_init(priv, interface, rate, mclk_freq, bits_per_sample, + channels); +} + +static int wm8994_probe(struct udevice *dev) +{ + struct wm8994_priv *priv = dev_get_priv(dev); + + priv->dev = dev; + return wm8994_device_init(priv); +} + +static const struct audio_codec_ops wm8994_ops = { + .set_params = wm8994_set_params, +}; + +static const struct udevice_id wm8994_ids[] = { + { .compatible = "wolfson,wm8994" }, + { } +}; + +U_BOOT_DRIVER(wm8994) = { + .name = "wm8994", + .id = UCLASS_AUDIO_CODEC, + .of_match = wm8994_ids, + .probe = wm8994_probe, + .ops = &wm8994_ops, + .priv_auto_alloc_size = sizeof(struct wm8994_priv), +};
Update snow's device tree and config to use driver model for sound. Also update the others as best we can.
Spring does not appear to have audio support in the kernel. The smdk5250 and smdk5420 boards use a wolfson codec which I cannot test with. So the only board that is tested and known to work is snow.
arch/arm/dts/exynos5250-smdk5250.dts | 20 ++++++++++++++++++-- arch/arm/dts/exynos5250-snow.dts | 21 ++++++++++++++++----- arch/arm/dts/exynos5250-spring.dts | 24 ++++++++++++++++++++---- arch/arm/dts/exynos5250.dtsi | 15 ++++++++++----- arch/arm/dts/exynos5420-peach-pit.dts | 24 ++++++++++++++++++++---- arch/arm/dts/exynos5420-smdk5420.dts | 20 ++++++++++++++++++-- arch/arm/dts/exynos54xx.dtsi | 7 +++++++ configs/arndale_defconfig | 1 + configs/peach-pi_defconfig | 1 + configs/peach-pit_defconfig | 1 + configs/smdk5250_defconfig | 1 + configs/snow_defconfig | 1 + configs/spring_defconfig | 1 + drivers/sound/samsung_sound.c | 3 +++ 14 files changed, 118 insertions(+), 22 deletions(-)
diff --git a/arch/arm/dts/exynos5250-smdk5250.dts b/arch/arm/dts/exynos5250-smdk5250.dts index bf60b82d449..e542a790761 100644 --- a/arch/arm/dts/exynos5250-smdk5250.dts +++ b/arch/arm/dts/exynos5250-smdk5250.dts @@ -60,10 +60,26 @@ };
i2c@12C70000 { - soundcodec@1a { + wm8994: soundcodec@1a { reg = <0x1a>; u-boot,i2c-offset-len = <2>; - compatible = "wolfson,wm8994-codec"; + compatible = "wolfson,wm8994"; + #sound-dai-cells = <1>; + }; + }; + + sound { + compatible = "google,smdk5250-audio-wm8994"; + + samsung,model = "SMDK5250-I2S-WM8994"; + samsung,audio-codec = <&wm8994>; + + cpu { + sound-dai = <&i2s0 0>; + }; + + codec { + sound-dai = <&wm8994 0>; }; };
diff --git a/arch/arm/dts/exynos5250-snow.dts b/arch/arm/dts/exynos5250-snow.dts index cb5067b9669..7587dc0ff24 100644 --- a/arch/arm/dts/exynos5250-snow.dts +++ b/arch/arm/dts/exynos5250-snow.dts @@ -40,7 +40,6 @@ mmc3 = "/mmc@12230000"; serial0 = "/serial@12C30000"; console = "/serial@12C30000"; - i2s = "/sound@3830000"; };
memory { @@ -214,9 +213,10 @@ }; };
- soundcodec@11 { + max98095: codec@11 { + compatible = "maxim,max98095"; reg = <0x11>; - compatible = "maxim,max98095-codec"; + #sound-dai-cells = <1>; }; };
@@ -273,9 +273,20 @@ }; };
- sound@3830000 { - samsung,codec-type = "max98095"; + sound { + compatible = "google,snow-audio-max98095"; + + samsung,model = "Snow-I2S-MAX98095"; + samsung,audio-codec = <&max98095>; codec-enable-gpio = <&gpx1 7 GPIO_ACTIVE_HIGH>; + + cpu { + sound-dai = <&i2s0 0>; + }; + + codec { + sound-dai = <&max98095 0>; + }; };
sound@12d60000 { diff --git a/arch/arm/dts/exynos5250-spring.dts b/arch/arm/dts/exynos5250-spring.dts index 7633d36874f..191e12af6a1 100644 --- a/arch/arm/dts/exynos5250-spring.dts +++ b/arch/arm/dts/exynos5250-spring.dts @@ -34,7 +34,6 @@ mmc0 = "/mmc@12200000"; serial0 = "/serial@12C30000"; console = "/serial@12C30000"; - i2s = "/sound@3830000"; };
memory { @@ -639,10 +638,27 @@ }; };
- soundcodec@20 { - reg = <0x20>; - compatible = "maxim,max98088-codec"; + max98095: soundcodec@10 { + reg = <0x10>; + compatible = "maxim,max98095"; + #sound-dai-cells = <1>; }; + + sound { + compatible = "google,spring-audio-max98095"; + + samsung,model = "Spring-I2S-MAX98095"; + samsung,audio-codec = <&max98095>; + + cpu { + sound-dai = <&i2s0 0>; + }; + + codec { + sound-dai = <&max98095 0>; + }; + }; + };
#include "cros-ec-keyboard.dtsi" diff --git a/arch/arm/dts/exynos5250.dtsi b/arch/arm/dts/exynos5250.dtsi index 502c687802e..66c5b6dca95 100644 --- a/arch/arm/dts/exynos5250.dtsi +++ b/arch/arm/dts/exynos5250.dtsi @@ -78,9 +78,12 @@ #size-cells = <0>; };
- sound@3830000 { - compatible = "samsung,exynos-sound"; - reg = <0x3830000 0x50>; + i2s0: i2s@3830000 { + compatible = "samsung,s5pv210-i2s"; + reg = <0x03830000 0x100>; + samsung,idma-addr = <0x03000000>; + #clock-cells = <1>; + #sound-dai-cells = <1>; samsung,i2s-epll-clock-frequency = <192000000>; samsung,i2s-sampling-rate = <48000>; samsung,i2s-bits-per-sample = <16>; @@ -90,9 +93,11 @@ samsung,i2s-id = <0>; };
- sound@12d60000 { - compatible = "samsung,exynos-sound"; + i2s1: i2s@12d60000 { + compatible = "samsung,s5pv210-i2s"; reg = <0x12d60000 0x20>; + #clock-cells = <1>; + #sound-dai-cells = <1>; samsung,i2s-epll-clock-frequency = <192000000>; samsung,i2s-sampling-rate = <48000>; samsung,i2s-bits-per-sample = <16>; diff --git a/arch/arm/dts/exynos5420-peach-pit.dts b/arch/arm/dts/exynos5420-peach-pit.dts index c86f9d9035d..ca6dc2a5ac9 100644 --- a/arch/arm/dts/exynos5420-peach-pit.dts +++ b/arch/arm/dts/exynos5420-peach-pit.dts @@ -67,12 +67,28 @@ }; };
+ sound { + compatible = "google,peach-audio-max98090"; + + samsung,model = "PEACH-I2S-MAX98090"; + samsung,audio-codec = <&max98090>; + + cpu { + sound-dai = <&i2s0 0>; + }; + + codec { + sound-dai = <&max98090 0>; + }; + }; + i2c@12CD0000 { /* i2c7 */ clock-frequency = <100000>; - soundcodec@20 { - reg = <0x20>; - compatible = "maxim,max98090-codec"; - }; + max98090: soundcodec@20 { + reg = <0x20>; + compatible = "maxim,max98090"; + #sound-dai-cells = <1>; + };
edp-lvds-bridge@48 { compatible = "parade,ps8625"; diff --git a/arch/arm/dts/exynos5420-smdk5420.dts b/arch/arm/dts/exynos5420-smdk5420.dts index daaa4666964..7a5da674fbe 100644 --- a/arch/arm/dts/exynos5420-smdk5420.dts +++ b/arch/arm/dts/exynos5420-smdk5420.dts @@ -82,10 +82,26 @@ };
i2c@12C70000 { - soundcodec@1a { + wm8994: soundcodec@1a { reg = <0x1a>; u-boot,i2c-offset-len = <2>; - compatible = "wolfson,wm8994-codec"; + compatible = "wolfson,wm8994"; + #sound-dai-cells = <1>; + }; + }; + + sound { + compatible = "samsung,smdk5420-audio-wm8994"; + + samsung,model = "Snow-I2S-MAX98095"; + samsung,audio-codec = <&wm8994>; + + cpu { + sound-dai = <&i2s0 0>; + }; + + codec { + sound-dai = <&wm8994 0>; }; };
diff --git a/arch/arm/dts/exynos54xx.dtsi b/arch/arm/dts/exynos54xx.dtsi index 09bef56e6c2..38c9bdc8de0 100644 --- a/arch/arm/dts/exynos54xx.dtsi +++ b/arch/arm/dts/exynos54xx.dtsi @@ -104,6 +104,13 @@ interrupts = <0 203 0>; };
+ i2s0: i2s@3830000 { + compatible = "samsung,exynos5420-i2s"; + reg = <0x03830000 0x100>; + #sound-dai-cells = <1>; + samsung,idma-addr = <0x03000000>; + }; + mmc@12200000 { samsung,bus-width = <8>; samsung,timing = <1 3 3>; diff --git a/configs/arndale_defconfig b/configs/arndale_defconfig index 2b6af4b2215..22881c3a2c6 100644 --- a/configs/arndale_defconfig +++ b/configs/arndale_defconfig @@ -31,6 +31,7 @@ CONFIG_MMC_SDHCI_S5P=y CONFIG_SMC911X=y CONFIG_SMC911X_BASE=0x5000000 CONFIG_SOUND=y +CONFIG_DM_SOUND=y CONFIG_I2S=y CONFIG_I2S_SAMSUNG=y CONFIG_SOUND_MAX98095=y diff --git a/configs/peach-pi_defconfig b/configs/peach-pi_defconfig index 338eae20b41..2f82c2d82c7 100644 --- a/configs/peach-pi_defconfig +++ b/configs/peach-pi_defconfig @@ -50,6 +50,7 @@ CONFIG_REGULATOR_TPS65090=y CONFIG_DM_PWM=y CONFIG_PWM_EXYNOS=y CONFIG_SOUND=y +CONFIG_DM_SOUND=y CONFIG_I2S=y CONFIG_I2S_SAMSUNG=y CONFIG_SOUND_MAX98095=y diff --git a/configs/peach-pit_defconfig b/configs/peach-pit_defconfig index 933c823ea86..3a177f14f7c 100644 --- a/configs/peach-pit_defconfig +++ b/configs/peach-pit_defconfig @@ -49,6 +49,7 @@ CONFIG_REGULATOR_TPS65090=y CONFIG_DM_PWM=y CONFIG_PWM_EXYNOS=y CONFIG_SOUND=y +CONFIG_DM_SOUND=y CONFIG_I2S=y CONFIG_I2S_SAMSUNG=y CONFIG_SOUND_MAX98095=y diff --git a/configs/smdk5250_defconfig b/configs/smdk5250_defconfig index 161454b33fd..90ee0ffbc9d 100644 --- a/configs/smdk5250_defconfig +++ b/configs/smdk5250_defconfig @@ -44,6 +44,7 @@ CONFIG_DM_PMIC_MAX77686=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_MAX77686=y CONFIG_SOUND=y +CONFIG_DM_SOUND=y CONFIG_I2S=y CONFIG_I2S_SAMSUNG=y CONFIG_SOUND_MAX98095=y diff --git a/configs/snow_defconfig b/configs/snow_defconfig index 21080091a7d..4d1c53d4291 100644 --- a/configs/snow_defconfig +++ b/configs/snow_defconfig @@ -61,6 +61,7 @@ CONFIG_DM_PWM=y CONFIG_PWM_EXYNOS=y CONFIG_DEBUG_UART_S5P=y CONFIG_SOUND=y +CONFIG_DM_SOUND=y CONFIG_I2S=y CONFIG_I2S_SAMSUNG=y CONFIG_SOUND_MAX98095=y diff --git a/configs/spring_defconfig b/configs/spring_defconfig index ca1799895e8..8f9436c74af 100644 --- a/configs/spring_defconfig +++ b/configs/spring_defconfig @@ -61,6 +61,7 @@ CONFIG_DM_PWM=y CONFIG_PWM_EXYNOS=y CONFIG_DEBUG_UART_S5P=y CONFIG_SOUND=y +CONFIG_DM_SOUND=y CONFIG_I2S=y CONFIG_I2S_SAMSUNG=y CONFIG_SOUND_MAX98095=y diff --git a/drivers/sound/samsung_sound.c b/drivers/sound/samsung_sound.c index 4e8321eae26..d5acb574c91 100644 --- a/drivers/sound/samsung_sound.c +++ b/drivers/sound/samsung_sound.c @@ -89,6 +89,9 @@ static const struct sound_ops samsung_sound_ops = {
static const struct udevice_id samsung_sound_ids[] = { { .compatible = "google,snow-audio-max98095" }, + { .compatible = "google,spring-audio-max98095" }, + { .compatible = "samsung,smdk5420-audio-wm8994" }, + { .compatible = "google,peach-audio-max98095" }, { } };
This option is not needed anymore for all exynos boards except arndale. Update the config.
configs/peach-pi_defconfig | 1 - configs/peach-pit_defconfig | 1 - configs/smdk5250_defconfig | 1 - configs/smdk5420_defconfig | 1 - configs/snow_defconfig | 1 - configs/spring_defconfig | 1 - 6 files changed, 6 deletions(-)
diff --git a/configs/peach-pi_defconfig b/configs/peach-pi_defconfig index 2f82c2d82c7..e1e662d159f 100644 --- a/configs/peach-pi_defconfig +++ b/configs/peach-pi_defconfig @@ -28,7 +28,6 @@ CONFIG_CMD_TPM_TEST=y CONFIG_CMD_EXT4_WRITE=y CONFIG_DEFAULT_DEVICE_TREE="exynos5800-peach-pi" CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_DM_I2C_COMPAT=y CONFIG_I2C_CROS_EC_TUNNEL=y CONFIG_I2C_MUX=y CONFIG_I2C_ARB_GPIO_CHALLENGE=y diff --git a/configs/peach-pit_defconfig b/configs/peach-pit_defconfig index 3a177f14f7c..96ed4bd3be5 100644 --- a/configs/peach-pit_defconfig +++ b/configs/peach-pit_defconfig @@ -27,7 +27,6 @@ CONFIG_CMD_TPM_TEST=y CONFIG_CMD_EXT4_WRITE=y CONFIG_DEFAULT_DEVICE_TREE="exynos5420-peach-pit" CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_DM_I2C_COMPAT=y CONFIG_I2C_CROS_EC_TUNNEL=y CONFIG_I2C_MUX=y CONFIG_I2C_ARB_GPIO_CHALLENGE=y diff --git a/configs/smdk5250_defconfig b/configs/smdk5250_defconfig index 90ee0ffbc9d..1e058227e41 100644 --- a/configs/smdk5250_defconfig +++ b/configs/smdk5250_defconfig @@ -30,7 +30,6 @@ CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y CONFIG_DEFAULT_DEVICE_TREE="exynos5250-smdk5250" CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_DM_I2C_COMPAT=y CONFIG_MMC_DW=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_S5P=y diff --git a/configs/smdk5420_defconfig b/configs/smdk5420_defconfig index 433e9a8447f..4e4558944cc 100644 --- a/configs/smdk5420_defconfig +++ b/configs/smdk5420_defconfig @@ -25,7 +25,6 @@ CONFIG_CMD_TIME=y CONFIG_CMD_EXT4_WRITE=y CONFIG_DEFAULT_DEVICE_TREE="exynos5420-smdk5420" CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_DM_I2C_COMPAT=y CONFIG_MMC_DW=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_S5P=y diff --git a/configs/snow_defconfig b/configs/snow_defconfig index 4d1c53d4291..10e11fbb337 100644 --- a/configs/snow_defconfig +++ b/configs/snow_defconfig @@ -34,7 +34,6 @@ CONFIG_CMD_TPM_TEST=y CONFIG_CMD_EXT4_WRITE=y CONFIG_DEFAULT_DEVICE_TREE="exynos5250-snow" CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_DM_I2C_COMPAT=y CONFIG_I2C_CROS_EC_LDO=y CONFIG_I2C_MUX=y CONFIG_I2C_ARB_GPIO_CHALLENGE=y diff --git a/configs/spring_defconfig b/configs/spring_defconfig index 8f9436c74af..844a87734b8 100644 --- a/configs/spring_defconfig +++ b/configs/spring_defconfig @@ -34,7 +34,6 @@ CONFIG_CMD_TPM_TEST=y CONFIG_CMD_EXT4_WRITE=y CONFIG_DEFAULT_DEVICE_TREE="exynos5250-spring" CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_DM_I2C_COMPAT=y CONFIG_I2C_CROS_EC_LDO=y CONFIG_I2C_MUX=y CONFIG_I2C_ARB_GPIO_CHALLENGE=y
All users of sound are converted to use driver model. Drop the old code and the CONFIG_DM_SOUND option.
cmd/sound.c | 12 --- drivers/sound/Kconfig | 6 -- drivers/sound/Makefile | 10 +- drivers/sound/max98095.c | 88 ---------------- drivers/sound/sandbox.c | 11 -- drivers/sound/sound-i2s.c | 206 -------------------------------------- drivers/sound/wm8994.c | 95 ------------------ include/sound.h | 11 -- test/dm/Makefile | 6 +- 9 files changed, 6 insertions(+), 439 deletions(-) delete mode 100644 drivers/sound/sound-i2s.c
diff --git a/cmd/sound.c b/cmd/sound.c index b063863bc9a..d00a7738167 100644 --- a/cmd/sound.c +++ b/cmd/sound.c @@ -15,18 +15,12 @@ DECLARE_GLOBAL_DATA_PTR; /* Initilaise sound subsystem */ static int do_init(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) { -#ifdef CONFIG_DM_SOUND struct udevice *dev; -#endif int ret;
-#ifdef CONFIG_DM_SOUND ret = uclass_first_device_err(UCLASS_SOUND, &dev); if (!ret) ret = sound_setup(dev); -#else - ret = sound_init(gd->fdt_blob); -#endif if (ret) { printf("Initialise Audio driver failed\n"); return CMD_RET_FAILURE; @@ -38,9 +32,7 @@ static int do_init(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) /* play sound from buffer */ static int do_play(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) { -#ifdef CONFIG_DM_SOUND struct udevice *dev; -#endif int ret = 0; int msec = 1000; int freq = 400; @@ -50,13 +42,9 @@ static int do_play(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) if (argc > 2) freq = simple_strtoul(argv[2], NULL, 10);
-#ifdef CONFIG_DM_SOUND ret = uclass_first_device_err(UCLASS_SOUND, &dev); if (!ret) ret = sound_beep(dev, msec, freq); -#else - ret = sound_play(msec, freq); -#endif if (ret) { printf("Sound device failed to play (err=%d)\n", ret); return CMD_RET_FAILURE; diff --git a/drivers/sound/Kconfig b/drivers/sound/Kconfig index 93f6c36af32..5de86c05c60 100644 --- a/drivers/sound/Kconfig +++ b/drivers/sound/Kconfig @@ -12,12 +12,6 @@ config SOUND audio codecs are called from the sound-i2s code. This could be converted to driver model.
-config DM_SOUND - bool "Use driver model for sound" - help - Enable this option to use driver model for sound devices. This is a - migration option and will be removed. - config I2S bool "Enable I2S support" depends on SOUND diff --git a/drivers/sound/Makefile b/drivers/sound/Makefile index 75fa31ec534..df46a48568b 100644 --- a/drivers/sound/Makefile +++ b/drivers/sound/Makefile @@ -4,15 +4,11 @@ # R. Chandrasekar rcsekar@samsung.com
obj-$(CONFIG_SOUND) += sound.o -obj-$(CONFIG_DM_SOUND) += codec-uclass.o -obj-$(CONFIG_DM_SOUND) += i2s-uclass.o -obj-$(CONFIG_DM_SOUND) += sound-uclass.o +obj-$(CONFIG_SOUND) += codec-uclass.o +obj-$(CONFIG_SOUND) += i2s-uclass.o +obj-$(CONFIG_SOUND) += sound-uclass.o obj-$(CONFIG_I2S_SAMSUNG) += samsung-i2s.o obj-$(CONFIG_SOUND_SANDBOX) += sandbox.o -ifdef CONFIG_DM_SOUND obj-$(CONFIG_I2S_SAMSUNG) += samsung_sound.o -else -obj-$(CONFIG_I2S) += sound-i2s.o -endif obj-$(CONFIG_SOUND_WM8994) += wm8994.o obj-$(CONFIG_SOUND_MAX98095) += max98095.o diff --git a/drivers/sound/max98095.c b/drivers/sound/max98095.c index d6710dfaa7a..fa204bf7a96 100644 --- a/drivers/sound/max98095.c +++ b/drivers/sound/max98095.c @@ -29,7 +29,6 @@ struct max98095_priv { unsigned int sysclk; unsigned int rate; unsigned int fmt; - int i2c_addr; struct udevice *dev; };
@@ -51,12 +50,7 @@ static int max98095_i2c_write(struct max98095_priv *priv, unsigned int reg, { debug("%s: Write Addr : 0x%02X, Data : 0x%02X\n", __func__, reg, data); -#ifdef CONFIG_DM_SOUND - debug("dev = %s\n", priv->dev->name); return dm_i2c_write(priv->dev, reg, &data, 1); -#else - return i2c_write(priv->i2c_addr, reg, 1, &data, 1); -#endif }
/* @@ -73,11 +67,7 @@ static unsigned int max98095_i2c_read(struct max98095_priv *priv, { int ret;
-#ifdef CONFIG_DM_SOUND return dm_i2c_read(priv->dev, reg, data, 1); -#else - ret = i2c_read(priv->i2c_addr, reg, 1, data, 1); -#endif if (ret != 0) { debug("%s: Error while reading register %#04x\n", __func__, reg); @@ -519,84 +509,6 @@ static int max98095_do_init(struct max98095_priv *priv, return ret; }
-#ifndef CONFIG_DM_SOUND -static int get_max98095_codec_values(struct sound_codec_info *pcodec_info, - const void *blob) -{ - int error = 0; - enum fdt_compat_id compat; - int node; - int parent; - - /* Get the node from FDT for codec */ - node = fdtdec_next_compatible(blob, 0, COMPAT_MAXIM_98095_CODEC); - if (node <= 0) { - debug("EXYNOS_SOUND: No node for codec in device tree\n"); - debug("node = %d\n", node); - return -1; - } - - parent = fdt_parent_offset(blob, node); - if (parent < 0) { - debug("%s: Cannot find node parent\n", __func__); - return -1; - } - - compat = fdtdec_lookup(blob, parent); - switch (compat) { - case COMPAT_SAMSUNG_S3C2440_I2C: - pcodec_info->i2c_bus = i2c_get_bus_num_fdt(parent); - error |= pcodec_info->i2c_bus; - debug("i2c bus = %d\n", pcodec_info->i2c_bus); - pcodec_info->i2c_dev_addr = fdtdec_get_int(blob, node, - "reg", 0); - error |= pcodec_info->i2c_dev_addr; - debug("i2c dev addr = %x\n", pcodec_info->i2c_dev_addr); - break; - default: - debug("%s: Unknown compat id %d\n", __func__, compat); - return -1; - } - if (error == -1) { - debug("fail to get max98095 codec node properties\n"); - return -1; - } - - return 0; -} - -/* max98095 Device Initialisation */ -int max98095_init(const void *blob, enum en_max_audio_interface aif_id, - int sampling_rate, int mclk_freq, - int bits_per_sample) -{ - int ret; - int old_bus = i2c_get_bus_num(); - struct sound_codec_info pcodec_info; - struct max98095_priv max98095_info; - - if (get_max98095_codec_values(&pcodec_info, blob) < 0) { - debug("FDT Codec values failed\n"); - return -1; - } - - i2c_set_bus_num(pcodec_info.i2c_bus); - - max98095_info.i2c_addr = pcodec_info.i2c_dev_addr; - ret = max98095_device_init(&max98095_info); - if (ret < 0) { - debug("%s: max98095 codec chip init failed\n", __func__); - return ret; - } - - ret = max98095_do_init(&max98095_info, aif_id, sampling_rate, mclk_freq, - bits_per_sample); - i2c_set_bus_num(old_bus); - - return ret; -} -#endif - static int max98095_set_params(struct udevice *dev, int interface, int rate, int mclk_freq, int bits_per_sample, uint channels) diff --git a/drivers/sound/sandbox.c b/drivers/sound/sandbox.c index d8a971ca060..17cba616b56 100644 --- a/drivers/sound/sandbox.c +++ b/drivers/sound/sandbox.c @@ -28,17 +28,6 @@ struct sandbox_sound_priv { int sum; /* Use to sum the provided audio data */ };
-#ifndef CONFIG_DM_SOUND -int sound_play(uint32_t msec, uint32_t frequency) -{ - sandbox_sdl_sound_start(frequency); - mdelay(msec); - sandbox_sdl_sound_stop(); - - return 0; -} -#endif /* CONFIG_DM_SOUND */ - int sound_init(const void *blob) { return sandbox_sdl_sound_init(); diff --git a/drivers/sound/sound-i2s.c b/drivers/sound/sound-i2s.c deleted file mode 100644 index a2fc78154f1..00000000000 --- a/drivers/sound/sound-i2s.c +++ /dev/null @@ -1,206 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (C) 2012 Samsung Electronics - * R. Chandrasekar rcsekar@samsung.com - */ - -#include <malloc.h> -#include <common.h> -#include <asm/io.h> -#include <linux/libfdt.h> -#include <fdtdec.h> -#include <i2c.h> -#include <i2s.h> -#include <sound.h> -#include <asm/arch/sound.h> -#include "wm8994.h" -#include "max98095.h" - -/* defines */ -#define SOUND_400_HZ 400 -#define SOUND_BITS_IN_BYTE 8 - -static struct i2s_uc_priv g_i2stx_pri; - -/* - * get_sound_i2s_values gets values for i2s parameters - * - * @param i2s_uc_priv i2s transmitter transfer param structure - * @param blob FDT blob if enabled else NULL - */ -static int get_sound_i2s_values(struct i2s_uc_priv *i2s, const void *blob) -{ - int node; - int error = 0; - int base; - - node = fdt_path_offset(blob, "i2s"); - if (node <= 0) { - debug("EXYNOS_SOUND: No node for sound in device tree\n"); - return -1; - } - - /* - * Get the pre-defined sound specific values from FDT. - * All of these are expected to be correct otherwise - * wrong register values in i2s setup parameters - * may result in no sound play. - */ - base = fdtdec_get_addr(blob, node, "reg"); - if (base == FDT_ADDR_T_NONE) { - debug("%s: Missing i2s base\n", __func__); - return -1; - } - i2s->base_address = base; - - i2s->audio_pll_clk = fdtdec_get_int(blob, - node, "samsung,i2s-epll-clock-frequency", -1); - error |= i2s->audio_pll_clk; - debug("audio_pll_clk = %d\n", i2s->audio_pll_clk); - i2s->samplingrate = fdtdec_get_int(blob, - node, "samsung,i2s-sampling-rate", -1); - error |= i2s->samplingrate; - debug("samplingrate = %d\n", i2s->samplingrate); - i2s->bitspersample = fdtdec_get_int(blob, - node, "samsung,i2s-bits-per-sample", -1); - error |= i2s->bitspersample; - debug("bitspersample = %d\n", i2s->bitspersample); - i2s->channels = fdtdec_get_int(blob, - node, "samsung,i2s-channels", -1); - error |= i2s->channels; - debug("channels = %d\n", i2s->channels); - i2s->rfs = fdtdec_get_int(blob, - node, "samsung,i2s-lr-clk-framesize", -1); - error |= i2s->rfs; - debug("rfs = %d\n", i2s->rfs); - i2s->bfs = fdtdec_get_int(blob, - node, "samsung,i2s-bit-clk-framesize", -1); - error |= i2s->bfs; - debug("bfs = %d\n", i2s->bfs); - - i2s->id = fdtdec_get_int(blob, node, "samsung,i2s-id", -1); - error |= i2s->id; - debug("id = %d\n", i2s->id); - - if (error == -1) { - debug("fail to get sound i2s node properties\n"); - return -1; - } - - return 0; -} - -/* - * Init codec - * - * @param blob FDT blob - * @param pi2s_tx i2s parameters required by codec - * @return int value, 0 for success - */ -static int codec_init(const void *blob, struct i2s_uc_priv *pi2s_tx) -{ - int ret; - const char *codectype; - int node; - - /* Get the node from FDT for sound */ - node = fdt_path_offset(blob, "i2s"); - if (node <= 0) { - debug("EXYNOS_SOUND: No node for sound in device tree\n"); - debug("node = %d\n", node); - return -1; - } - - /* - * Get the pre-defined sound codec specific values from FDT. - * All of these are expected to be correct otherwise sound - * can not be played - */ - codectype = fdt_getprop(blob, node, "samsung,codec-type", NULL); - debug("device = %s\n", codectype); - if (!strcmp(codectype, "wm8994")) { - /* Check the codec type and initialise the same */ - ret = wm8994_init(blob, pi2s_tx->id, pi2s_tx->samplingrate, - (pi2s_tx->samplingrate * (pi2s_tx->rfs)), - pi2s_tx->bitspersample, pi2s_tx->channels); - } else if (!strcmp(codectype, "max98095")) { - ret = max98095_init(blob, pi2s_tx->id, pi2s_tx->samplingrate, - (pi2s_tx->samplingrate * (pi2s_tx->rfs)), - pi2s_tx->bitspersample); - } else { - debug("%s: Unknown codec type %s\n", __func__, codectype); - return -1; - } - - if (ret) { - debug("%s: Codec init failed\n", __func__); - return -1; - } - - return 0; -} - -int sound_init(const void *blob) -{ - int ret; - struct i2s_uc_priv *pi2s_tx = &g_i2stx_pri; - - /* Get the I2S Values */ - if (get_sound_i2s_values(pi2s_tx, blob) < 0) { - debug(" FDT I2S values failed\n"); - return -1; - } - - if (codec_init(blob, pi2s_tx) < 0) { - debug(" Codec init failed\n"); - return -1; - } - - ret = i2s_tx_init(pi2s_tx); - if (ret) { - debug("%s: Failed to init i2c transmit: ret=%d\n", __func__, - ret); - return ret; - } - - - return ret; -} - -int sound_play(uint32_t msec, uint32_t frequency) -{ - unsigned int *data; - unsigned long data_size; - unsigned int ret = 0; - - /*Buffer length computation */ - data_size = g_i2stx_pri.samplingrate * g_i2stx_pri.channels; - data_size *= (g_i2stx_pri.bitspersample / SOUND_BITS_IN_BYTE); - data = malloc(data_size); - - if (data == NULL) { - debug("%s: malloc failed\n", __func__); - return -1; - } - - sound_create_square_wave(g_i2stx_pri.samplingrate, - (unsigned short *)data, - data_size / sizeof(unsigned short), - frequency); - - while (msec >= 1000) { - ret = i2s_transfer_tx_data(&g_i2stx_pri, data, - (data_size / sizeof(int))); - msec -= 1000; - } - if (msec) { - unsigned long size = - (data_size * msec) / (sizeof(int) * 1000); - - ret = i2s_transfer_tx_data(&g_i2stx_pri, data, size); - } - - free(data); - - return ret; -} diff --git a/drivers/sound/wm8994.c b/drivers/sound/wm8994.c index d2b22fb1d7f..8421909f369 100644 --- a/drivers/sound/wm8994.c +++ b/drivers/sound/wm8994.c @@ -40,7 +40,6 @@ struct wm8994_priv { int mclk[WM8994_MAX_AIF]; /* master clock frequency in Hz */ int aifclk[WM8994_MAX_AIF]; /* audio interface clock in Hz */ struct wm8994_fll_config fll[2]; /* fll config to configure fll */ - int i2c_addr; struct udevice *dev; };
@@ -82,12 +81,7 @@ static int wm8994_i2c_write(struct wm8994_priv *priv, unsigned int reg, val[1] = (unsigned char)(data & 0xff); debug("Write Addr : 0x%04X, Data : 0x%04X\n", reg, data);
-#ifdef CONFIG_DM_SOUND - debug("dev = %s\n", priv->dev->name); return dm_i2c_write(priv->dev, reg, val, 2); -#else - return i2c_write(priv->i2c_addr, reg, 2, val, 2); -#endif }
/* @@ -105,11 +99,7 @@ static unsigned int wm8994_i2c_read(struct wm8994_priv *priv, unsigned int reg, unsigned char val[2]; int ret;
-#ifdef CONFIG_DM_SOUND ret = dm_i2c_read(priv->dev, reg, val, 1); -#else - ret = i2c_read(priv->i2c_addr, reg, 2, val, 2); -#endif if (ret != 0) { debug("%s: Error while reading register %#04x\n", __func__, reg); @@ -820,61 +810,6 @@ err: return -1; }
-#ifndef CONFIG_DM_SOUND -/* - * Gets fdt values for wm8994 config parameters - * - * @param pcodec_info codec information structure - * @param blob FDT blob - * @return int value, 0 for success - */ -static int get_codec_values(struct sound_codec_info *pcodec_info, - const void *blob) -{ - int error = 0; - enum fdt_compat_id compat; - int node; - int parent; - - /* Get the node from FDT for codec */ - node = fdtdec_next_compatible(blob, 0, COMPAT_WOLFSON_WM8994_CODEC); - if (node <= 0) { - debug("EXYNOS_SOUND: No node for codec in device tree\n"); - debug("node = %d\n", node); - return -1; - } - - parent = fdt_parent_offset(blob, node); - if (parent < 0) { - debug("%s: Cannot find node parent\n", __func__); - return -1; - } - - compat = fdtdec_lookup(blob, parent); - switch (compat) { - case COMPAT_SAMSUNG_S3C2440_I2C: - pcodec_info->i2c_bus = i2c_get_bus_num_fdt(parent); - error |= pcodec_info->i2c_bus; - debug("i2c bus = %d\n", pcodec_info->i2c_bus); - pcodec_info->i2c_dev_addr = fdtdec_get_int(blob, node, - "reg", 0); - error |= pcodec_info->i2c_dev_addr; - debug("i2c dev addr = %d\n", pcodec_info->i2c_dev_addr); - break; - default: - debug("%s: Unknown compat id %d\n", __func__, compat); - return -1; - } - - if (error == -1) { - debug("fail to get wm8994 codec node properties\n"); - return -1; - } - - return 0; -} -#endif - static int _wm8994_init(struct wm8994_priv *priv, enum en_audio_interface aif_id, int sampling_rate, int mclk_freq, int bits_per_sample, @@ -906,36 +841,6 @@ static int _wm8994_init(struct wm8994_priv *priv, return ret; }
-#ifndef CONFIG_DM_SOUND -/* WM8994 Device Initialisation */ -int wm8994_init(const void *blob, enum en_audio_interface aif_id, - int sampling_rate, int mclk_freq, int bits_per_sample, - unsigned int channels) -{ - struct sound_codec_info pcodec_info; - struct wm8994_priv wm8994_info; - int ret; - - /* Get the codec Values */ - if (get_codec_values(&pcodec_info, blob) < 0) { - debug("FDT Codec values failed\n"); - return -1; - } - - /* shift the device address by 1 for 7 bit addressing */ - wm8994_info.i2c_addr = pcodec_info.i2c_dev_addr; - i2c_set_bus_num(pcodec_info.i2c_bus); - ret = wm8994_device_init(&wm8994_info); - if (ret < 0) { - debug("%s: wm8994 codec chip init failed\n", __func__); - return ret; - } - - return _wm8994_init(&wm8994_info, aif_id, sampling_rate, mclk_freq, - bits_per_sample, channels); -} -#endif - static int wm8994_set_params(struct udevice *dev, int interface, int rate, int mclk_freq, int bits_per_sample, uint channels) { diff --git a/include/sound.h b/include/sound.h index a8235a75b9c..494d0a448ed 100644 --- a/include/sound.h +++ b/include/sound.h @@ -52,7 +52,6 @@ void sound_create_square_wave(uint sample_rate, unsigned short *data, int size, */ int sound_init(const void *blob);
-#ifdef CONFIG_DM_SOUND /* * The sound uclass brings together a data transport (currently only I2C) and a * codec (currently connected over I2C). @@ -101,14 +100,4 @@ int sound_beep(struct udevice *dev, int msecs, int frequency_hz); */ int sound_find_codec_i2s(struct udevice *dev);
-#else -/* - * plays the pcm data buffer in pcm_data.h through i2s1 to make the - * sine wave sound - * - * @return int 0 for success, -1 for error - */ -int sound_play(uint32_t msec, uint32_t frequency); -#endif /* CONFIG_DM_SOUND */ - #endif /* __SOUND__H__ */ diff --git a/test/dm/Makefile b/test/dm/Makefile index 0c1459cd4db..43c2e7535b1 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -13,7 +13,7 @@ obj-$(CONFIG_UT_DM) += test-uclass.o # subsystem you must add sandbox tests here. obj-$(CONFIG_UT_DM) += core.o ifneq ($(CONFIG_SANDBOX),) -obj-$(CONFIG_DM_SOUND) += audio.o +obj-$(CONFIG_SOUND) += audio.o obj-$(CONFIG_BLK) += blk.o obj-$(CONFIG_BOARD) += board.o obj-$(CONFIG_CLK) += clk.o @@ -21,7 +21,7 @@ obj-$(CONFIG_DM_ETH) += eth.o obj-$(CONFIG_FIRMWARE) += firmware.o obj-$(CONFIG_DM_GPIO) += gpio.o obj-$(CONFIG_DM_I2C) += i2c.o -obj-$(CONFIG_DM_SOUND) += i2s.o +obj-$(CONFIG_SOUND) += i2s.o obj-$(CONFIG_LED) += led.o obj-$(CONFIG_DM_MAILBOX) += mailbox.o obj-$(CONFIG_DM_MMC) += mmc.o @@ -54,7 +54,7 @@ obj-$(CONFIG_AXI) += axi.o obj-$(CONFIG_MISC) += misc.o obj-$(CONFIG_DM_SERIAL) += serial.o obj-$(CONFIG_CPU) += cpu.o -obj-$(CONFIG_DM_SOUND) += sound.o +obj-$(CONFIG_SOUND) += sound.o obj-$(CONFIG_TEE) += tee.o obj-$(CONFIG_VIRTIO_SANDBOX) += virtio.o endif
sjg@google.com
