[PATCH v2] common/board_f: make sure to call fix_fdt() before reserve_fdt()
There may be a chance that board specific fix_fdt() will change the size of FDT blob so it's safe to call reserve_fdt() after fix_fdt() otherwise global data (gd) will overwrite with FDT blob values.
Fixes: a8492e25ac71 ("riscv: Expand the DT size before copy reserved memory node")
Signed-off-by: Pragnesh Patel pragnesh.patel@sifive.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Rick Chen rick@andestech.com --- common/board_f.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/common/board_f.c b/common/board_f.c index 88ff0424a7..7ae01e9fff 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -956,6 +956,9 @@ static const init_fnc_t init_sequence_f[] = { * - board info struct */ setup_dest_addr, +#ifdef CONFIG_OF_BOARD_FIXUP + fix_fdt, +#endif #ifdef CONFIG_PRAM reserve_pram, #endif @@ -984,9 +987,6 @@ static const init_fnc_t init_sequence_f[] = { setup_board_part2, #endif display_new_sp, -#ifdef CONFIG_OF_BOARD_FIXUP - fix_fdt, -#endif INIT_FUNC_WATCHDOG_RESET reloc_fdt, reloc_bootstage,
Pragnesh Patel
