[U-Boot-Users] Ethernet Address
Hi
When I first started up my board (ebony) with u-boot, I set the Ethernet address incorrectly. Instead of using the colon format (00:04:ac:e3:1c:4c) I entered the hex values all together(0004ace31c4c). So I think now the Ethernet address environment variable is permanently wrong. When I use the command bdi it says ethhaddr = 4c:00:00:00:00:00. Is there a way to fix this, may be by using the JTAG hardware debugger or something?
Please help.
Anupam
This message (including any attachments) may contain confidential information intended for a specific individual and purpose. If you are not the intended recipient, delete this message. If you are not the intended recipient, disclosing, copying, distributing, or taking any action based on this message is strictly prohibited.
In message 2692A548B75777458914AC89297DD7DA026FADA0@bronze.dolby.net you wrote:
When I first started up my board (ebony) with u-boot, I set the Ethernet address incorrectly. Instead of using the colon format (00:04:ac:e3:1c:4c) I entered the hex values all together(0004ace31c4c). So I think now the Ethernet address environment variable is permanently wrong. When I use the command bdi it says ethhaddr =3D 4c:00:00:00:00:00. Is there a way to fix this, may be by using the JTAG hardware debugger or something?
Assuming you store your environment in flash:
- use "protect off" command to make sector containing the environment writable - use "erase" to erase sector containing the environment - "reset", and the board will come up with it's default environment
Just using "mw 0 0;cp 0 <addr> 1" instead of the erase will work, too, as it will overwrite the CRC32 checksum.
If you don;t want to lose your existting environment definitions, trickier approaches are possible, too: copy the environment to RAM, edit it using "mm", compute a new checksum and store it to the start of the envrionment (easy to be done with "crc32" command), and write it back to where you store it (flash, eeprom, etc.).
TIMTOWTDI.
This message (including any attachments) may contain confidential= information intended for a specific individual and purpose. If you are not= the intended recipient, delete this message. If you are not the intended= recipient, disclosing, copying, distributing, or taking any action based= on this message is strictly prohibited.
Please delete this nonsense, at least when posting to publich mailing lists.
------_=_NextPart_001_01C33D19.4389C548 Content-Type: text/html; charset="us-ascii" Content-Transfer-Encoding: quoted-printable
And *please* do not post HTML!
Dhanuka, Anupam
