[PATCH v3 1/5] rockchip: rk3128-cru: sync the clock dt-binding header from Linux
In order to update the DT for rk3128 sync the clock dt-binding header. This is the state as of v6.0 in Linux.
Signed-off-by: Johan Jonker jbx6244@gmail.com --- arch/arm/dts/rk3128.dtsi | 6 +- drivers/clk/rockchip/clk_rk3128.c | 8 +- include/dt-bindings/clock/rk3128-cru.h | 222 +++++++++++++++++-------- 3 files changed, 160 insertions(+), 76 deletions(-)
diff --git a/arch/arm/dts/rk3128.dtsi b/arch/arm/dts/rk3128.dtsi index 5d2499c1..3c5f54f6 100644 --- a/arch/arm/dts/rk3128.dtsi +++ b/arch/arm/dts/rk3128.dtsi @@ -172,7 +172,7 @@ interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; #dma-cells = <1>; - clocks = <&cru ACLK_DMAC2>; + clocks = <&cru ACLK_DMAC>; clock-names = "apb_pclk"; }; }; @@ -530,8 +530,8 @@ pinctrl-0 = <&spi0_txd_mux0 &spi0_rxd_mux0 &spi0_clk_mux0 &spi0_cs0_mux0 &spi0_cs1_mux0>; rockchip,spi-src-clk = <0>; num-cs = <2>; - clocks =<&cru SCLK_SPI>, <&cru PCLK_SPI>; - clock-names = "spi","pclk_spi0"; + clocks = <&cru SCLK_SPI0>, <&cru PCLK_SPI0>; + clock-names = "spiclk", "apb_pclk"; dmas = <&pdma 8>, <&pdma 9>; #dma-cells = <2>; dma-names = "tx", "rx"; diff --git a/drivers/clk/rockchip/clk_rk3128.c b/drivers/clk/rockchip/clk_rk3128.c index d5b2b63d..13e176cd 100644 --- a/drivers/clk/rockchip/clk_rk3128.c +++ b/drivers/clk/rockchip/clk_rk3128.c @@ -438,7 +438,7 @@ static ulong rk3128_vop_set_clk(struct rk3128_cru *cru, ulong clk_id, uint hz) VIO1_SEL_GPLL << VIO1_PLL_SHIFT | (src_clk_div - 1) << VIO1_DIV_SHIFT); break; - case DCLK_LCDC: + case DCLK_VOP: if (pll_para_config(hz, &cpll_config)) return -1; rkclk_set_pll(cru, CLK_CODEC, &cpll_config); @@ -471,7 +471,7 @@ static ulong rk3128_vop_get_rate(struct rk3128_cru *cru, ulong clk_id) div = (con >> 8) & 0x1f; parent = GPLL_HZ; break; - case DCLK_LCDC: + case DCLK_VOP: con = readl(&cru->cru_clksel_con[27]); div = (con >> 8) & 0xfff; parent = rkclk_pll_get_rate(cru, CLK_CODEC); @@ -497,7 +497,7 @@ static ulong rk3128_clk_get_rate(struct clk *clk) return rk3128_peri_get_pclk(priv->cru, clk->id); case SCLK_SARADC: return rk3128_saradc_get_clk(priv->cru); - case DCLK_LCDC: + case DCLK_VOP: case ACLK_VIO0: case ACLK_VIO1: return rk3128_vop_get_rate(priv->cru, clk->id); @@ -515,7 +515,7 @@ static ulong rk3128_clk_set_rate(struct clk *clk, ulong rate) switch (clk->id) { case 0 ... 63: return 0; - case DCLK_LCDC: + case DCLK_VOP: case ACLK_VIO0: case ACLK_VIO1: new_rate = rk3128_vop_set_clk(priv->cru, diff --git a/include/dt-bindings/clock/rk3128-cru.h b/include/dt-bindings/clock/rk3128-cru.h index cfb3afbb..6a47825d 100644 --- a/include/dt-bindings/clock/rk3128-cru.h +++ b/include/dt-bindings/clock/rk3128-cru.h @@ -1,6 +1,7 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ +/* SPDX-License-Identifier: GPL-2.0-or-later */ /* - * (C) Copyright 2017 Rockchip Electronics Co., Ltd + * Copyright (c) 2017 Rockchip Electronics Co. Ltd. + * Author: Elaine zhangqing@rock-chips.com */
#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3128_H @@ -9,30 +10,31 @@ /* core clocks */ #define PLL_APLL 1 #define PLL_DPLL 2 -#define PLL_GPLL 3 -#define ARMCLK 4 +#define PLL_CPLL 3 +#define PLL_GPLL 4 +#define ARMCLK 5 +#define PLL_GPLL_DIV2 6 +#define PLL_GPLL_DIV3 7
/* sclk gates (special clocks) */ -#define SCLK_GPU 64 -#define SCLK_SPI 65 +#define SCLK_SPI0 65 +#define SCLK_NANDC 67 #define SCLK_SDMMC 68 #define SCLK_SDIO 69 #define SCLK_EMMC 71 -#define SCLK_NANDC 76 #define SCLK_UART0 77 #define SCLK_UART1 78 #define SCLK_UART2 79 -#define SCLK_I2S 82 +#define SCLK_I2S0 80 +#define SCLK_I2S1 81 #define SCLK_SPDIF 83 #define SCLK_TIMER0 85 #define SCLK_TIMER1 86 #define SCLK_TIMER2 87 #define SCLK_TIMER3 88 +#define SCLK_TIMER4 89 +#define SCLK_TIMER5 90 #define SCLK_SARADC 91 -#define SCLK_OTGPHY0 93 -#define SCLK_LCDC 100 -#define SCLK_HDMI 109 -#define SCLK_HEVC 111 #define SCLK_I2S_OUT 113 #define SCLK_SDMMC_DRV 114 #define SCLK_SDIO_DRV 115 @@ -40,115 +42,173 @@ #define SCLK_SDMMC_SAMPLE 118 #define SCLK_SDIO_SAMPLE 119 #define SCLK_EMMC_SAMPLE 121 -#define SCLK_PVTM_CORE 123 -#define SCLK_PVTM_GPU 124 -#define SCLK_PVTM_VIDEO 125 -#define SCLK_MAC 151 -#define SCLK_MACREF 152 -#define SCLK_SFC 160 +#define SCLK_VOP 122 +#define SCLK_MAC_SRC 124 +#define SCLK_MAC 126 +#define SCLK_MAC_REFOUT 127 +#define SCLK_MAC_REF 128 +#define SCLK_MAC_RX 129 +#define SCLK_MAC_TX 130 +#define SCLK_HEVC_CORE 134 +#define SCLK_RGA 135 +#define SCLK_CRYPTO 138 +#define SCLK_TSP 139 +#define SCLK_OTGPHY0 142 +#define SCLK_OTGPHY1 143 +#define SCLK_DDRC 144 +#define SCLK_PVTM_FUNC 145 +#define SCLK_PVTM_CORE 146 +#define SCLK_PVTM_GPU 147 +#define SCLK_MIPI_24M 148 +#define SCLK_PVTM 149 +#define SCLK_CIF_SRC 150 +#define SCLK_CIF_OUT_SRC 151 +#define SCLK_CIF_OUT 152 +#define SCLK_SFC 153 +#define SCLK_USB480M 154
-#define DCLK_LCDC 190 +/* dclk gates */ +#define DCLK_VOP 190 +#define DCLK_EBC 191
/* aclk gates */ -#define ACLK_DMAC2 194 -#define ACLK_VIO0 197 -#define ACLK_VIO1 203 -#define ACLK_VCODEC 208 -#define ACLK_CPU 209 +#define ACLK_VIO0 192 +#define ACLK_VIO1 193 +#define ACLK_DMAC 194 +#define ACLK_CPU 195 +#define ACLK_VEPU 196 +#define ACLK_VDPU 197 +#define ACLK_CIF 198 +#define ACLK_IEP 199 +#define ACLK_LCDC0 204 +#define ACLK_RGA 205 #define ACLK_PERI 210 +#define ACLK_VOP 211 +#define ACLK_GMAC 212 +#define ACLK_GPU 213
/* pclk gates */ #define PCLK_SARADC 318 +#define PCLK_WDT 319 #define PCLK_GPIO0 320 #define PCLK_GPIO1 321 #define PCLK_GPIO2 322 #define PCLK_GPIO3 323 +#define PCLK_VIO_H2P 324 +#define PCLK_MIPI 325 +#define PCLK_EFUSE 326 +#define PCLK_HDMI 327 +#define PCLK_ACODEC 328 #define PCLK_GRF 329 #define PCLK_I2C0 332 #define PCLK_I2C1 333 #define PCLK_I2C2 334 #define PCLK_I2C3 335 -#define PCLK_SPI 338 +#define PCLK_SPI0 338 #define PCLK_UART0 341 #define PCLK_UART1 342 #define PCLK_UART2 343 +#define PCLK_TSADC 344 #define PCLK_PWM 350 #define PCLK_TIMER 353 -#define PCLK_HDMI 360 -#define PCLK_CPU 362 +#define PCLK_CPU 354 #define PCLK_PERI 363 -#define PCLK_DDRUPCTL 364 -#define PCLK_WDT 368 +#define PCLK_GMAC 367 +#define PCLK_PMU_PRE 368 +#define PCLK_SIM_CARD 369
/* hclk gates */ -#define HCLK_OTG0 449 -#define HCLK_OTG1 450 +#define HCLK_SPDIF 440 +#define HCLK_GPS 441 +#define HCLK_USBHOST 442 +#define HCLK_I2S_8CH 443 +#define HCLK_I2S_2CH 444 +#define HCLK_VOP 452 #define HCLK_NANDC 453 #define HCLK_SDMMC 456 #define HCLK_SDIO 457 #define HCLK_EMMC 459 -#define HCLK_I2S 462 -#define HCLK_LCDC 465 -#define HCLK_ROM 467 -#define HCLK_VIO_BUS 472 -#define HCLK_VCODEC 476 -#define HCLK_CPU 477 +#define HCLK_CPU 460 +#define HCLK_VEPU 461 +#define HCLK_VDPU 462 +#define HCLK_LCDC0 463 +#define HCLK_EBC 465 +#define HCLK_VIO 466 +#define HCLK_RGA 467 +#define HCLK_IEP 468 +#define HCLK_VIO_H2P 469 +#define HCLK_CIF 470 +#define HCLK_HOST2 473 +#define HCLK_OTG 474 +#define HCLK_TSP 475 +#define HCLK_CRYPTO 476 #define HCLK_PERI 478
#define CLK_NR_CLKS (HCLK_PERI + 1)
/* soft-reset indices */ -#define SRST_CORE0 0 -#define SRST_CORE1 1 -#define SRST_CORE0_DBG 4 -#define SRST_CORE1_DBG 5 -#define SRST_CORE0_POR 8 -#define SRST_CORE1_POR 9 -#define SRST_L2C 12 -#define SRST_TOPDBG 13 +#define SRST_CORE0_PO 0 +#define SRST_CORE1_PO 1 +#define SRST_CORE2_PO 2 +#define SRST_CORE3_PO 3 +#define SRST_CORE0 4 +#define SRST_CORE1 5 +#define SRST_CORE2 6 +#define SRST_CORE3 7 +#define SRST_CORE0_DBG 8 +#define SRST_CORE1_DBG 9 +#define SRST_CORE2_DBG 10 +#define SRST_CORE3_DBG 11 +#define SRST_TOPDBG 12 +#define SRST_ACLK_CORE 13 #define SRST_STRC_SYS_A 14 -#define SRST_PD_CORE_NIU 15 +#define SRST_L2C 15
-#define SRST_TIMER2 16 -#define SRST_CPUSYS_H 17 -#define SRST_AHB2APB_H 19 -#define SRST_TIMER3 20 +#define SRST_CPUSYS_H 18 +#define SRST_AHB2APBSYS_H 19 +#define SRST_SPDIF 20 #define SRST_INTMEM 21 #define SRST_ROM 22 #define SRST_PERI_NIU 23 -#define SRST_I2S 24 -#define SRST_DDR_PLL 25 -#define SRST_GPU_DLL 26 -#define SRST_TIMER0 27 -#define SRST_TIMER1 28 -#define SRST_CORE_DLL 29 +#define SRST_I2S_2CH 24 +#define SRST_I2S_8CH 25 +#define SRST_GPU_PVTM 26 +#define SRST_FUNC_PVTM 27 +#define SRST_CORE_PVTM 29 #define SRST_EFUSE_P 30 #define SRST_ACODEC_P 31
#define SRST_GPIO0 32 #define SRST_GPIO1 33 #define SRST_GPIO2 34 +#define SRST_GPIO3 35 +#define SRST_MIPIPHY_P 36 #define SRST_UART0 39 #define SRST_UART1 40 #define SRST_UART2 41 #define SRST_I2C0 43 #define SRST_I2C1 44 #define SRST_I2C2 45 +#define SRST_I2C3 46 #define SRST_SFC 47
-#define SRST_PWM0 48 +#define SRST_PWM 48 +#define SRST_DAP_PO 50 #define SRST_DAP 51 #define SRST_DAP_SYS 52 +#define SRST_CRYPTO 53 #define SRST_GRF 55 -#define SRST_PERIPHSYS_A 57 -#define SRST_PERIPHSYS_H 58 -#define SRST_PERIPHSYS_P 59 +#define SRST_GMAC 56 +#define SRST_PERIPH_SYS_A 57 +#define SRST_PERIPH_SYS_H 58 +#define SRST_PERIPH_SYS_P 59 +#define SRST_SMART_CARD 60 #define SRST_CPU_PERI 61 #define SRST_EMEM_PERI 62 #define SRST_USB_PERI 63
-#define SRST_DMA2 64 -#define SRST_MAC 66 +#define SRST_DMA 64 +#define SRST_GPS 67 #define SRST_NANDC 68 #define SRST_USBOTG0 69 #define SRST_OTGC0 71 @@ -156,34 +216,58 @@ #define SRST_OTGC1 74 #define SRST_DDRMSCH 79
-#define SRST_MMC0 81 +#define SRST_SDMMC 81 #define SRST_SDIO 82 #define SRST_EMMC 83 -#define SRST_SPI0 84 +#define SRST_SPI 84 #define SRST_WDT 86 #define SRST_SARADC 87 #define SRST_DDRPHY 88 #define SRST_DDRPHY_P 89 #define SRST_DDRCTRL 90 #define SRST_DDRCTRL_P 91 +#define SRST_TSP 92 +#define SRST_TSP_CLKIN 93 +#define SRST_HOST0_ECHI 94
#define SRST_HDMI_P 96 +#define SRST_VIO_ARBI_H 97 +#define SRST_VIO0_A 98 #define SRST_VIO_BUS_H 99 +#define SRST_VOP_A 100 +#define SRST_VOP_H 101 +#define SRST_VOP_D 102 #define SRST_UTMI0 103 #define SRST_UTMI1 104 #define SRST_USBPOR 105 +#define SRST_IEP_A 106 +#define SRST_IEP_H 107 +#define SRST_RGA_A 108 +#define SRST_RGA_H 109 +#define SRST_CIF0 110 +#define SRST_PMU 111
#define SRST_VCODEC_A 112 #define SRST_VCODEC_H 113 #define SRST_VIO1_A 114 -#define SRST_HEVC 115 +#define SRST_HEVC_CORE 115 #define SRST_VCODEC_NIU_A 116 -#define SRST_LCDC1_A 117 -#define SRST_LCDC1_H 118 -#define SRST_LCDC1_D 119 +#define SRST_PMU_NIU_P 117 +#define SRST_LCDC0_S 119 #define SRST_GPU 120 #define SRST_GPU_NIU_A 122 +#define SRST_EBC_A 123 +#define SRST_EBC_H 124
-#define SRST_DBG_P 131 +#define SRST_CORE_DBG 128 +#define SRST_DBG_P 129 +#define SRST_TIMER0 130 +#define SRST_TIMER1 131 +#define SRST_TIMER2 132 +#define SRST_TIMER3 133 +#define SRST_TIMER4 134 +#define SRST_TIMER5 135 +#define SRST_VIO_H2P 136 +#define SRST_VIO_MIPI_DSI 137
#endif
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
}; };clocks = <&cru ACLK_DMAC>; clock-names = "apb_pclk";
dmas = <&pdma 8>, <&pdma 9>; #dma-cells = <2>; dma-names = "tx", "rx";clock-names = "spiclk", "apb_pclk";
- case DCLK_LCDC:
- case DCLK_VOP: if (pll_para_config(hz, &cpll_config)) return -1; rkclk_set_pll(cru, CLK_CODEC, &cpll_config);
- case DCLK_LCDC:
- case DCLK_VOP: con = readl(&cru->cru_clksel_con[27]); div = (con >> 8) & 0xfff; parent = rkclk_pll_get_rate(cru, CLK_CODEC);
- case DCLK_LCDC:
- case DCLK_VOP: case ACLK_VIO0: case ACLK_VIO1: return rk3128_vop_get_rate(priv->cru, clk->id);
- case DCLK_LCDC:
- case DCLK_VOP: case ACLK_VIO0: case ACLK_VIO1: new_rate = rk3128_vop_set_clk(priv->cru,
- (C) Copyright 2017 Rockchip Electronics Co., Ltd
- Copyright (c) 2017 Rockchip Electronics Co. Ltd.
- Author: Elaine zhangqing@rock-chips.com
#endif
Johan Jonker
Kever Yang
